12-NetStream命令
本章节下载: 12-NetStream命令 (187.27 KB)
1.1.1 display ip netstream cache
1.1.2 display ip netstream export
1.1.3 display ip netstream template
1.1.6 ip netstream aggregation
1.1.7 ip netstream aggregation advanced
1.1.8 ip netstream export host
1.1.9 ip netstream export rate
1.1.10 ip netstream export source
1.1.11 ip netstream export v9-template refresh-rate packet
1.1.12 ip netstream export v9-template refresh-rate time
1.1.13 ip netstream export version
1.1.16 ip netstream timeout active
1.1.17 ip netstream timeout inactive
1.1.19 reset ip netstream statistics
display ip netstream cache [ verbose ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
verbose:显示NetStream流缓冲区的详细信息。
slot slot-number:显示IRF系统中指定设备上的NetStream流缓冲区的详细信息。slot-number表示IRF中设备的成员编号,取值范围取决于当前IRF中的成员数量和编号情况,可使用display irf命令查看。如果未形成IRF,则slot-number为当前设备编号。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display ip netstream cache命令用来查看NetStream流缓存区信息。
# 查看NetStream流缓冲区信息。
<Sysname> display ip netstream cache
IP netstream cache information:
Stream active timeout (in minutes) : 1
Stream inactive timeout (in seconds): 10
Stream max entry number : 8192
IP active stream entry number : 2
L2 active stream entry number : 6
IP stream entry been counted : 6292
L2 stream entry been counted : 9399
Last statistics reset time : Never
IP packet size distribution (0 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
Protocol Total Packets Stream Packets Active(sec) Idle(sec)
Streams /Sec /Sec /stream /stream /stream
IP-other 1757 0 0 1 0 10
UDP-other 945 0 0 1 1 10
TCP-other 196 0 0 17 67 7
ICMP 1848 0 0 2 4 10
UDP-NTP 758 0 0 1 0 10
UDP-NetBios 179 0 0 2 1 10
UDP-SysLog 516 0 0 2 1 10
TCP-Telnet 93 0 0 69 176 5
Type DstIP(Port) SrcIP(Port) Pro ToS If(Direc) Pkts
DstMAC(VLAN) SrcMAC(VLAN)
TopLblType(IP/MASK) Lbl-Exp-S-List
IP 192.168.0.58(23) 192.168.0.18(1708) 6 0 GE1/0/19(I) 48
L2 0180-c200-0014(1) 0000-fc00-6505(1) GE1/0/3(I) 12
IP 192.168.0.58(0) 192.168.0.18(771) 1 0 GE1/0/19(I) 4
L2 000f-e2d2-58fb(1) 000f-e200-0144(1) GE1/0/3(O) 1
L2 000f-e200-8048(1) 00e0-fc3d-9da8(1) GE1/0/3(O) 1
L2 ffff-ffff-ffff(1) 00e0-fc00-000b(1) GE1/0/3(O) 334
L2 0180-c200-0000(1) 000f-e207-f2e0(1) GE1/0/3(O) 138
L2 ffff-ffff-ffff(1) 000f-cbb8-5679(1) GE1/0/3(O) 302
表1-1 display ip netstream cache命令显示信息描述表
IP netstream cache information |
NetStream流缓存区信息 |
Stream active timeout (in minutes) |
当前的活跃老化时间(以分钟为单位) |
Stream inactive timeout (in seconds) |
当前的不活跃老化时间(以秒为单位) |
Stream max entry number |
NetStream流缓存区中允许的最大流数 |
IP active stream entry number |
NetStream流缓存区中活跃的IP流数 |
L2 active stream entry number |
NetStream流缓存区中活跃的二层流数 |
IP stream entry been counted |
被统计的IP流数 |
L2 stream entry been counted |
被统计的二层流数 |
Last statistics reset time |
上次清除统计的时间,此时间为清除时刻的绝对时间,它不会随系统时间的修改而变化 该字段只在执行了reset ip netstream statistics命令后才会出现,否则显示: Last statistics reset time : Never |
IP packet size distribution (0 total packets): |
IP报文按大小分布情况,括号中为IP报文总数。 分布值按占IP报文总数的比率显示,只显示3位小数,如“.027”表示占IP报文总数的0.027 |
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480 512 544 576 1024 1536 2048 2560 3072 3584 4096 4608 |
报文尺寸区间(报文长度不包括二层链路层的头)。长度不超过576字节时,以32字节为单位递增,例如:“1-32”是长度为1~32个字节的报文数目,“64”是长度为33~64字节的报文数。长度超过1024字节时,以512字节为单位递增,例如“1536”是长度为1025~1536字节的报文数。长度在577~1024间的报文记录在1024项中 |
Protocol Total Streams Packets /Sec Stream/Sec Packets/stream Active(sec)/stream Idle(sec)/stream |
按协议分类的报文统计信息:协议号、总流数、每秒的报文数、每秒的流数、平均每条流的报文数、平均每条流的活跃时间、平均每条流的非活跃时间 |
Type DstIP(Port) SrcIP(Port) Pro ToS If(Direc) Pkts |
当前流缓存区中活跃流的IP层信息:流的类型、目的IP地址(目的端口号)、源IP地址(源端口号)、协议、ToS、接口名(方向)、包数 其中流的类型包括:IP流(IP)、二层流(L2) |
DstMAC(VLAN) SrcMAC(VLAN) |
当前流缓存区中活跃流的二层信息:目的MAC地址、目的VLAN ID、源MAC地址、源VLAN ID |
TopLblType(IP/MASK) Lbl-Exp-S-List |
当前流缓存区中活跃流的MPLS信息:栈顶标签的类型(栈顶标签对应的IP地址及掩码长度)、标签列表 标签主要的三部分:20比特的Label字段表示标签值,3比特的EXP字段用来实现QoS,1比特S字段置1表示已达栈底 标签列表中至多列出三层标签 |
display ip netstream export [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display ip netstream export命令用来查看NetStream统计输出报文的各种信息。
# 查看NetStream统计输出信息。
<Sysname> display ip netstream export
IP export information:
Stream source interface :
Stream destination VPN-instance :
Stream destination IP (UDP) : 1.1.1.1 (1000)
Version 5 exported stream number : 4
Version 5 exported UDP datagram number (failed): 3 (3)
Version 9 exported stream number : 0
Version 9 exported UDP datagram number (failed): 0 (0)
L2 export information:
source-prefix aggreagtion export information:
Version 8 exported stream number : 3
Version 8 exported UDP datagram number (failed): 3 (3)
tos-destination-prefix aggreagtion export information:
Stream destination IP (UDP) : 121.1.1.7 (9991)
Version 8 exported stream number : 4
Version 8 exported UDP datagram number (failed): 3 (0)
表1-2 display ip netstream export命令显示信息描述表
IP export information |
IP流统计输出信息 |
Stream source interface |
输出信息的源接口 |
Stream destination VPN-instance |
输出信息的目的地址所在的VPN |
Stream destination IP (UDP) |
输出信息(UDP)的目的地址和目的端口号 |
Version 5 exported stream number |
使用版本5格式发送的流信息数 |
Version 5 exported UDP datagram number (failed) |
使用版本5格式发送的UDP报文数(发送失败数) |
Version 9 exported stream number |
使用版本9格式发送的流信息数 |
Version 9 exported UDP datagram number (failed) |
使用版本9格式发送的UDP报文数(发送失败数) |
source-prefix aggreagtion export information |
启用源前缀聚合的版本8统计输出信息。没有启用的聚合功能不显示(各项信息同上) |
Version 8 exported stream number |
使用版本8格式发送的流信息数 |
Version 8 exported UDP datagram number (failed) |
使用版本8格式发送的UDP报文数(发送失败数) |
display ip netstream template [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
slot slot-number:显示IRF系统中指定设备上的模板信息。slot-number表示IRF中设备的成员编号,取值范围取决于当前IRF中的成员数量和编号情况,可使用display irf命令查看。如果未形成IRF,则slot-number为当前设备编号。
【描述】
display ip netstream template命令用来查看NetStream模板的配置和状态信息。
# 查看NetStream模板信息。
<Sysname> display ip netstream template slot 2
Stream template refresh-rate packet : 20
Stream template refresh-rate time(in minute) : 30
Active stream templates : 4
Added stream templates : 10
source-prefix outbound template:
Template ID : 276
Packets : 0
Last template export time : Never
Field count : 13
Field type Field length (byte)
Flows 4
Out packets 8
Out bytes 8
First switched 4
Last switched 4
IPv4 source prefix 4
Source mask 1
Direction 1
Source AS 2
Input SNMP 2
Sampling algorithm 1
PAD 1
Sampling interval 4
表1-3 display ip netstream template命令显示信息描述表
Stream template refresh-rate packet |
模板的包刷新率 |
Stream template refresh-rate time(in minute) |
模板的时间刷新率(以分钟为单位) |
Active stream templates |
当前活跃的模板数 |
Added stream templates |
系统启动以来创建的模板总数 |
source-prefix outbound template |
源前缀出方向模板信息 |
source-prefix inbound template |
源前缀入方向模板信息 |
Packets |
使用该模板的发送报文数。由于一个报文中可能携带多条流,不同的流会使用到不同的模板,这里的Packets实际上是流数。 |
Last template export time |
该模板最近的一次输出时间 |
Template ID |
模板ID |
Field count |
模板的域总数 |
Field type |
域类型 |
Field length (byte) |
域长度,以字节为单位 |
Flows |
聚合流数量 |
In packets |
输入的数据包大小 |
In bytes |
输入的数据大小,以字节为单位 |
First switched |
记录第一个数据包的转发时间,单位为毫秒 |
Last switched |
记录最后一个数据包的转发时间,单位为毫秒 |
IPv4 source prefix |
IPv4源前缀聚合 |
Source mask |
聚合掩码长度 |
Direction |
方向字段 |
Source AS |
源AS号 |
Input SNMP |
输入接口的索引 |
Direction |
方向字段 |
Sampling algorithm |
采样算法 |
PAD |
空白占位符 |
Sampling interval |
采样率 |
【缺省级别】
3:管理级
enable命令用来使能当前聚合视图对应的聚合方式。undo enable命令用来禁止该聚合方式。
缺省情况下,未使能任何NetStream聚合功能。
相关配置可参考命令ip netstream aggregation。
# 使能NetStream的目的前缀聚合方式。
[Sysname] ip netstream aggregation destination-prefix
[Sysname-ns-aggregation-dstpre] enable
ip netstream { inbound | outbound }
undo ip netstream { inbound | outbound }
二层以太网端口视图/三层以太网端口视图
【缺省级别】
3:管理级
inbound:对入方向的流量进行NetStream统计。
outbound:对出方向的流量进行NetStream统计。
【描述】
ip netstream命令用来在当前端口启动NetStream功能。undo ip netstream命令用来在当前端口关闭NetStream功能。
缺省情况下,未启动NetStream功能。
目前仅支持在二层以太网端口或者三层以太网端口上启用NetStream统计功能。
# 在GigabitEthernet1/0/1端口上启用NetStream入统计功能。
[Sysname-GigabitEthernet1/0/1] ip netstream inbound
ip netstream aggregation { destination-prefix | prefix | prefix-port | protocol-port | source-prefix | tos-destination-prefix | tos-prefix | tos-protocol-port | tos-source-prefix }
【缺省级别】
3:管理级
destination-prefix:目的前缀聚合,根据NetStream流的目的自治系统号、目的掩码长度、目的前缀和输出接口索引4个关键值对流分类。
prefix:源和目的前缀聚合,根据NetStream流的源自治系统号、目的自治系统号、源掩码长度、目的掩码长度,源前缀、目的前缀、输入接口索引和输出接口索引8个关键值对流分类。
prefix-port:前缀端口聚合,根据NetStream流的源前缀、目的前缀、源掩码长度、目的掩码长度、ToS、协议号、源端口、目的端口、输入接口索引、输出接口索引10个关键值对流分类。
protocol-port:协议-端口聚合,根据NetStream流的协议号、源端口和目的端口3个关键值对流分类。
source-prefix:源前缀聚合,根据NetStream流的源自治系统号、源掩码长度、源前缀和输入接口索引4个关键值对流分类。
tos-destination-prefix:服务类型-目的前缀聚合,根据NetStream流的ToS、目的自治系统号、目的掩码长度、目的前缀和输出接口索引5个关键值对流分类。
tos-prefix:服务类型-前缀聚合,根据NetStream流的ToS、源自治系统号、源前缀、源掩码长度、目的自治系统号、目的掩码长度、目的前缀、输入接口索引和输出接口索引9个关键值对流分类。
tos-protocol-port:服务类型-协议-端口聚合,根据NetStream流的ToS、协议号、源端口、目的端口、输入接口索引和输出接口索引6个关键值对流分类。
tos-source-prefix:服务类型-源前缀聚合,根据NetStream流的ToS、源自治系统号、源前缀、源掩码长度和输入接口索引5个关键值对流分类。
【描述】
ip netstream aggregation命令用来设置NetStream流聚合方式,并进入相应的NetStream聚合视图。在聚合视图下,可以启用或关闭聚合功能,以及设置NetStream统计输出报文源接口、目的IP地址以及目的端口号。
相关配置可参考命令enable、ip netstream export host和ip netstream export source。
# 进入NetStream目的前缀聚合视图。
undo ip netstream aggregation advanced
【缺省级别】
3:管理级
无
【描述】
ip netstream aggregation advanced命令用来使能硬件流聚合功能。undo ip netstream aggregation advanced命令用于关闭硬件流聚合功能。
缺省情况下,未使能NetStream硬件流聚合功能。
l 使能硬件流聚合时,系统根据NetStream统计功能是否配置了统计信息输出的目的地址以及配置的聚合类型来决定是否进行硬件聚合。如果在系统视图下配置了统计信息输出的目的地址,则硬件聚合配置不生效。
l 使能硬件流聚合以后,硬件聚合流表项老化到普通流表项记录中,并进行表项的输出。
相关配置可参考命令ip netstream export host和ip netstream aggregation。
# 使能硬件流聚合功能。
[Sysname] ip netstream aggregation advanced
ip netstream export host ip-address udp-port [ vpn-instance vpn-instance-name ]
undo ip netstream export host [ ip-address [ vpn-instance vpn-instance-name ] ]
系统视图/NetStream聚合视图
【缺省级别】
3:管理级
ip-address:NetStream统计输出报文的目的IP地址。
udp-port:NetStream统计输出报文的目的UDP端口号,取值范围为0~65535。
vpn-instance vpn-instance-name:NetStream统计输出报文查询的VPN实例名称。
【描述】
ip netstream export host命令用来配置NetStream统计输出报文的目的地址。undo ip netstream export host命令用来删除已有配置,未指定IP地址时为取消指定本视图下配置的所有IP地址。
缺省情况下,系统视图下没有配置目的地址。聚合视图下目的IP地址和目的UDP端口号为系统视图下所配置的值。
l 不同聚合视图下可以配置不同的目的地址。
l 聚合视图下若没有配置目的地址,则使用系统视图下的配置。
l 一个视图下最多可配置4组目的地址,包括不同VPN实例。在同一视图下,若先后配置了IP地址相同、UDP端口号不同的目的地址,则后配置的目的地址生效。在用户配置了不同的VPN实例名称时,允许配置相同的IP地址和UDP端口号。
l 普通流统计输出报文会发给系统视图下配置的所有目的地址。聚合流统计输出报文会发给聚合类型对应的聚合视图下配置的所有目的地址。为了减少对网络带宽的占用,可以只在聚合视图下配置ip netstream export host命令,此时设备只会输出聚合流信息。
相关配置可参考命令ip netstream aggregation和ip netstream export source。
# 设置NetStream统计输出报文的目的IP地址为172.16.105.48,UDP端口号为5000,在vpn1中查询路由。
[Sysname] ip netstream export host 172.16.105.48 5000 vpn-instance vpn1
ip netstream export rate rate
undo ip netstream export rate
【缺省级别】
3:管理级
rate:NetStream统计输出报文的最大输出速度,单位为每秒允许输出最大报文个数。取值范围是1~1000。
【描述】
ip netstream export rate命令用来配置输出速率限制。undo ip netstream export rate命令用来关闭输出速率限制功能。
缺省情况下,NetStream统计输出报文的输出速率不受限制。
# 设置每秒最多允许10个报文被输出。
[Sysname] ip netstream export rate 10
ip netstream export source interface interface-type interface-number
undo ip netstream export source
系统视图/NetStream聚合视图
【缺省级别】
3:管理级
interface-type interface-number:NetStream统计输出报文的源接口,由接口类型和接口编号组成。
【描述】
ip netstream export source命令用来配置NetStream统计输出报文的源接口。undo ip netstream export source命令用来取消配置的输出报文的源接口。
缺省情况下,采用统计输出报文的出接口(即与服务器相连的接口)作为源接口。
l 不同聚合视图下可以配置不同的源接口。
l 聚合视图下若没有配置源接口,则使用系统视图下的配置。
l 建议使用网管口作为源接口,与服务器相连,并向服务器输出统计信息。
# 将NetStream统计输出报文源接口设置为Vlan-interface 1。
[Sysname] ip netstream export source interface Vlan-interface 1
ip netstream export v9-template refresh-rate packet packets
undo ip netstream export v9-template refresh-rate packet
【缺省级别】
3:管理级
packets:NetStream统计输出报文版本9模板的包刷新率,单位为上报报文的个数,即每隔多少个包发送一次模板,通知NetStream服务器最新的V9模版格式。取值范围为1~600。
【描述】
ip netstream export v9-template refresh-rate packet命令用来配置NetStream统计输出报文版本9模板的包刷新率。undo ip netstream export v9-template refresh-rate packet命令用来恢复缺省情况。
缺省情况下,每隔20个包设备发送一次版本9模板。
l 由于V9版本是基于模板方式的、可支持自定义格式,所以设备上需要定期刷新模板,并通知NetStream服务器最新的V9模版格式。用户可以根据实际情况,配置版本9模板的包刷新率,及时更新模板。
l 可以同时配置包刷新率和时间刷新率,只要满足任意一个刷新条件,设备就会将符合条件的模板发送给NetStream服务器。
相关配置可参考命令ip netstream export v9-template refresh-rate time。
# 将NetStream统计输出报文版本9模板的包刷新率设为100。
[Sysname] ip netstream export v9-template refresh-rate packet 100
ip netstream export v9-template refresh-rate time minutes
undo ip netstream export v9-template refresh-rate time
【缺省级别】
3:管理级
minutes:NetStream统计输出报文版本9模板的时间刷新率,单位为分钟,即每隔多少分钟发送一次模板,通知NetStream服务器最新的V9模版格式。取值范围为1~3600。
【描述】
ip netstream export v9-template refresh-rate time命令用来配置NetStream统计输出报文版本9模板的时间刷新率。undo ip netstream export v9-template refresh-rate time命令用来恢复缺省情况。
缺省情况下,每隔30分钟设备发送一次版本9模板。
l 由于V9版本是基于模板方式的、可支持自定义格式,所以设备上需要定期刷新模板,并通知NetStream服务器最新的V9模版格式。用户可以根据实际情况,配置版本9模板的时间刷新率,及时更新模板。
相关配置可参考命令ip netstream export v9-template refresh-rate packet。
# 将NetStream统计输出报文版本9模板的时间刷新率设为60分钟。
[Sysname] ip netstream export v9-template refresh-rate time 60
ip netstream export version 5 [ origin-as | peer-as ]
ip netstream export version 9 [ origin-as | peer-as ] [ bgp-nexthop ]
undo ip netstream export version
【缺省级别】
3:管理级
origin-as:流信息中记录的自治系统号为起始自治系统号。
peer-as:流信息中记录的自治系统号为邻接自治系统号。
bgp-nexthop:流信息中记录BGP下一跳。
【描述】
ip netstream export version 5命令用来配置NetStream版本5的AS参数。ip netstream export version 9命令用来配置NetStream版本9的AS参数和BGP下一跳选项。undo ip netstream export version命令用来恢复缺省情况。
缺省情况下,普通流信息通过版本5的NetStream统计输出报文发送,聚合流信息通过版本8的NetStream统计输出报文发送。自治系统选项使用邻接自治系统号(peer-as),流信息中不记录BGP下一跳地址。
l NetStream流信息中会记录流的源IP地址和目的IP地址的自治系统号,每个IP地址对应两个自治系统号:起始自治系统号和邻接自治系统号。设备会根据用户实际配置的自治系统参数来确定记录的自治系统号。
l 只有在版本号为9时,才可以配置BGP下一跳。
# 将NetStream统计输出报文版本号设为5,并采用起始自治系统号作为给定IP地址的自治系统号。
[Sysname] ip netstream export version 5 origin-as
ip netstream filter acl acl-number { inbound | outbound }
undo ip netstream filter acl acl-number { inbound | outbound }
二层以太网端口视图/三层以太网端口视图
【缺省级别】
3:管理级
acl acl-number:ACL规则号,取值范围为2000~3999和4000~4999。
inbound:入方向过滤。
outbound:出方向过滤。
【描述】
ip netstream filter命令用来启用按指定条件对流进行过滤。undo ip netstream filter命令用来禁用按指定条件对流进行过滤。
缺省情况下,NetStream统计所有IPv4报文,不启用过滤功能。
l 在配置过滤功能时,ACL引用后不允许删除和修改。如果过滤和采样同时配置,报文先进行过滤,而后采样。
l 配置过滤时,要求ACL必须存在。与ACL有关的内容请参见“ACL和QoS配置指导”中的“ACL”。
# 在端口GigabitEthernet 1/0/1上配置根据规则号为2003的ACL规则进行出方向过滤。
[Sysname-GigabitEthernet1/0/1] ip netstream filter acl 2003 outbound
ip netstream sampler sampler-name { inbound | outbound }
undo ip netstream sampler sampler-name { inbound | outbound }
二层以太网端口视图/三层以太网端口视图
【缺省级别】
3:管理级
sampler sampler-name:采样器名称,最长32个字符。
inbound:入方向采样。
outbound:出方向采样。
【描述】
ip netstream sampler命令用来启用NetStream采样功能。undo ip netstream sampler命令用来禁用NetStream采样功能。
缺省情况下,未使能采样功能。
目前设备不支持在Vlan接口上配置NetStream的采样功能。
# 使能NetStream入方向采样,使用名为abc的采样器。
[Sysname-GigabitEthernet1/0/1] ip netstream sampler abc inbound
ip netstream timeout active minutes
undo ip netstream timeout active
【缺省级别】
3:管理级
minutes:活跃流的老化时间,单位为分钟。取值范围为1~5。
【描述】
ip netstream timeout active命令用来配置活跃流的老化时间。undo ip netstream timeout active命令用来恢复缺省情况。
缺省情况下,活跃流的老化时间为5分钟。
l 活跃流的老化时间和不活跃流的老化时间只对普通流生效。
l 活跃流的老化时间和不活跃流的老化时间可以同时配置,满足任一个老化时间就会对流进行老化,时间精度为10秒钟。
相关配置可参考命令ip netstream timeout inactive。
# 将活跃流的老化时间设置为3分钟。
[Sysname] ip netstream timeout active 3
ip netstream timeout inactive seconds
undo ip netstream timeout inactive
【缺省级别】
3:管理级
seconds:不活跃流的老化时间,单位为秒。取值范围为10~300。
【描述】
ip netstream timeout inactive命令用来配置不活跃流的老化时间。undo ip netstream timeout inactive命令用来恢复缺省情况。
缺省情况下,不活跃流的老化时间为30秒。
相关配置可参考命令ip netstream timeout active。
# 将不活跃流的老化时间设置为60秒。
[Sysname] ip netstream timeout inactive 60
netstream filter { deny | permit }
undo netstream filter
流行为视图
【缺省级别】
2:系统级
deny:不对报文进行NetStream处理,直接转发。
permit:对报文进行NetStream处理。
【描述】
netstream filter命令用来为流行为配置NetStream过滤动作。undo netstream filter命令用来取消NetStream过滤动作配置。
# 为流行为配置对报文进行NetStream处理。
[Sysname-behavior-database] netstream filter permit
【缺省级别】
2:系统级
无
【描述】
reset ip netstream statistics命令用来将流缓存区中所有流强制老化,并清除NetStream缓冲区的状态信息和输出报文信息。
在执行清除缓冲区中老化流的动作时,命令行会给出提示,告知用户这个动作可能要持续几分钟,在这段时间内不能统计。
# 将流缓存区中所有流老化,并清除NetStream缓冲区的状态信息和输出报文信息。
<Sysname> reset ip netstream statistics
This process may take a few minutes.
Netstream statistic function is disabled during this process.
