06-QoS分册
01-QoS命令
本章节下载 01-QoS命令  (337.38 KB)
docurl=/cn/Service/Document_Software/Document_Center/Wlan/WX/WX6100E/Command/Command_Manual/H3C_WX6100E_CM-Release_6600(V1.00)/06/201006/677426_30005_0.htm
01-QoS命令
  录
1 QoS策略配置命令
1.1 定义类的命令
1.1.1 display traffic classifier
1.1.2 if-match
1.1.3 traffic classifier
1.2 定义流行为的命令
1.2.1 accounting
1.2.2 car
1.2.3 display traffic behavior
1.2.4 filter
1.2.5 redirect
1.2.6 remark dot1p
1.2.7 remark drop-precedence
1.2.8 remark dscp
1.2.9 remark ip-precedence
1.2.10 remark local-precedence
1.2.11 remark qos-local-id
1.2.12 traffic behavior
1.3 定义策略的命令
1.3.1 classifier behavior
1.3.2 control-plane
1.3.3 display qos policy
1.3.4 display qos policy control-plane
1.3.5 display qos policy control-plane pre-defined
1.3.6 display qos policy global
1.3.7 display qos policy interface
1.3.8 display qos vlan-policy
1.3.9 qos apply policy
1.3.10 qos apply policy (user-profile view)
1.3.11 qos apply policy global
1.3.12 qos policy
1.3.13 qos vlan-policy
1.3.14 reset qos policy control-plane
1.3.15 reset qos policy global
1.3.16 reset qos vlan-policy
2 优先级映射配置命令
2.1 优先级映射表配置命令
2.1.1 display qos map-table
2.1.2 import
2.1.3 qos map-table
2.2 端口优先级配置命令
2.2.1 qos priority
2.3 端口优先级信任模式配置命令
2.3.1 display qos trust interface
2.3.2 qos trust
3 流量整形和端口限速配置命令
3.1 流量整形配置命令
3.1.1 display qos gts interface
3.1.2 qos gts
3.2 端口限速配置命令
3.2.1 display qos lr interface
3.2.2 qos lr outbound
4 拥塞管理配置命令
4.1 拥塞管理配置命令
4.1.1 display qos sp interface
4.1.2 display qos wfq interface
4.1.3 display qos wrr interface
4.1.4 qos bandwidth queue
4.1.5 qos sp
4.1.6 qos wfq
4.1.7 qos wfq weight
4.1.8 qos wrr
4.1.9 qos wrr weight
5 拥塞避免配置命令
5.1 拥塞避免配置命令
5.1.1 display qos wred interface
5.1.2 display qos wred table
5.1.3 qos wred apply
5.1.4 qos wred queue table
5.1.5 queue
6 聚合CAR配置命令
6.1 聚合CAR配置命令
6.1.1 car name
6.1.2 display qos car name
6.1.3 qos car aggregative
6.1.4 reset qos car name
1 QoS策略配置命令
1.1  定义类的命令
display traffic classifier user-defined [ tcl-name ]
【缺省级别】
1:监控级
tcl-name:类的名称。
【描述】
display traffic classifier命令用来显示用户自定义类的配置信息。
如果没有指定类名,将显示所有用户自定义类的配置信息。
# 显示所有用户自定义类的配置信息。
  User Defined Classifier Information:
   Classifier: p
    Operator: AND
    Rule(s) : If-match acl 2001
表1-1 display traffic classifier user-defined命令显示信息描述表
用户自定义的类
Classifier
类的名称
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
1.1.2  if-match
if-match match-criteria
undo if-match match-criteria
undo if-match [ acl [ ipv6 ] { acl-number | name acl-name } [ update acl [ ipv6 ] { acl-number | name acl-name } ]
类视图
【缺省级别】
2:系统级
match-criteria:匹配规则,取值如下表所示。
表1-2 匹配规则
取值
acl acl-number
定义匹配IPv4 ACL的规则,acl-number的取值范围为2000~4999
acl name acl-name
使用指定ACL名称的方式定义匹配IPv4 ACL的规则,acl-name是IPv4 ACL的名称,设置方法请参见安全分册的“ACL配置”
acl ipv6 acl-number
定义匹配IPv6 ACL的规则,acl-number的取值范围为2000~3999
acl ipv6 name acl-name
使用指定ACL名称的方式定义匹配IPv6 ACL的规则,acl-name是IPv6 ACL的名称,设置方法请参见安全分册的“ACL配置”
any
定义匹配所有报文的规则(在SC系列单板上不包括IPv6报文)
customer-dot1p 8021p-list
定义匹配用户网络802.1p优先级的规则,8021p-list为CoS取值的列表,最多可以输入8个CoS取值,用空格隔开,CoS的取值范围为0~7
customer-vlan-id vlan-id-list
定义匹配用户网络VLAN ID的规则,vlan-id-listVLAN ID的列表,形式可以为vlan-id to vlan-id,也可以输入多个不连续的VLAN ID,用空格隔开,设备最多允许用户同时指定8VLAN IDVLAN ID的取值范围为14094
destination-mac mac-address
定义匹配目的MAC地址的规则
dscp dscp-list
定义匹配DSCP的规则,dscp-list为DSCP取值的列表,最多可以输入8个DSCP取值,用空格隔开,DSCP的取值范围为0~63
ip-precedence ip-precedence-list
定义匹配IP优先级的规则,ip-precedence-list为IP优先级取值的列表,最多可以输入8个IP优先级取值,用空格隔开,IP优先级的取值范围为0~7
protocol protocol-name
定义匹配协议的规则,protocol-name取值为IP或IPv6
qos-local-id local-id-value
定义匹配qos-local-id的规则,local-id-value为QoS本地ID,取值范围为1~4095
在WX6100E系列无线控制器以太网交换机上,能够支持的local-id-value值为1~3999
service-dot1p 8021p-list
定义匹配运营商网络802.1p优先级的规则,8021p-list为CoS取值的列表,最多可以输入8个CoS取值,用空格隔开,CoS的取值范围为0~7
service-vlan-id vlan-id-list
定义匹配运营商网络VLAN ID的规则,vlan-id-listVLAN ID的列表,形式可以为vlan-id to vlan-id,也可以输入多个不连续的VLAN ID,用空格隔开,设备最多允许用户同时指定8VLAN IDVLAN ID的取值范围为14094
source-mac mac-address
定义匹配源MAC地址的规则
system-index index-value-list
定义规则来匹配预定义的上送控制平面报文类型,index-value-list为系统预定义匹配字段索引号(system-index)的列表,最多可以输入8个system-index值,system-index值的取值范围为1~128
如果指定类的逻辑关系为and,使用if-match命令定义匹配规则时,有如下注意事项:
l    匹配规则含有aclacl ipv6时,如果在类中配置了多条这样的匹配规则,在应用策略时,匹配aclacl ipv6的规则之间的逻辑关系实际为or
l    匹配规则含有customer-vlan-idservice-vlan-id时,如果在类中配置了多条这样的匹配规则,在应用策略时,匹配customer-vlan-idservice-vlan-id的规则之间的逻辑关系实际为or
当流分类中各规则之间的逻辑关系为and时,对于以下匹配条件,用户虽然可以通过重复执行if-match命令来配置多条匹配不同取值的规则,或在一条规则中使用list形式输入多个匹配值,但在应用使用该类的QoS策略时,将会无法正常下发:
l    customer-dot1p 8021p-list
l    destination-mac mac-address(不支持list形式)
l    dscp dscp-list
l    ip-precedence ip-precedence-list
l    service-dot1p 8021p-list
l    source-mac mac-address(不支持list形式)
l    system-index index-value-list
如果用户需要创建匹配以上某一字段多个取值的规则,需要在创建流分类时指定各规则之间的逻辑关系为or,然后再配置匹配多个值的规则。
【描述】
if-match命令用来定义匹配报文的规则。undo if-match命令用来删除匹配报文的规则。
在定义各个规则的时候,注意事项如下:
(1)        定义匹配ACL的规则
l              如果类中引用的ACL不存在,则不能在硬件中下发。
l              对同一个类,允许通过ACL名称和序号的方式分别引用一次同一个ACL。
(2)        定义匹配目的MAC地址和源MAC地址的规则
l              一个类下可配置多条这样的命令,各个配置之间互相不覆盖。
(3)        定义匹配DSCP的规则
l              一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,dscp值将自动按照从小到大的顺序排序。
l              一条命令可以配置多个DSCP值,最多可指定8个;如果指定了多个相同的DSCP值,系统默认为一个;多个不同的DSCP值是或的关系,即只要有一个值匹配,就算匹配这条规则。
l              删除某条匹配DSCP的规则时,指定的所有DSCP值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(4)        定义匹配用户网络或运营商网络的802.1p优先级的规则
l              一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,8021p值将自动按照从小到大的顺序排序。
l              一条命令可以配置多个802.1p优先级值,最多可指定8个;如果指定了多个相同的802.1p优先级值,系统默认为一个;多个不同的802.1p优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
l              删除某条匹配802.1p优先级的规则时,指定的所有802.1p优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(5)        定义匹配IP优先级的规则
l              一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,IP优先级的值将自动按照从小到大的顺序排序。
l              一条命令可以配置多个IP优先级值,最多可指定8个;如果指定了多个相同的IP优先级值,系统默认为一个;多个不同的IP优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
l              删除某条匹配IP优先级的规则时,指定的所有IP优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(6)        定义匹配用户网络和运营商网络VLAN ID的规则
l              一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,vlan-id值将自动按照从小到大的顺序排序。
l              一条命令可以配置多个VLAN ID值,如果指定了多个相同的VLAN ID值,系统默认为一个;多个不同的VLAN ID值是或的关系,即只要有一个值匹配,就算匹配这条规则。
l              删除某条匹配VLAN ID的规则时,指定的所有VLAN ID值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(7)        定义匹配预定义的上送控制平面报文类型的规则
l              一条命令可以配置多个system-index值,如果指定了多个相同的system-index值,系统默认为一个;多个不同的system-index值是或的关系,即只要有一个值匹配,就算匹配这条规则。
l              删除某条匹配system-index的规则时,指定的所有system-index值必须与该规则中定义的完全相同才会删除,顺序可不一样。
l              系统预定义的报文类型信息可以通过display qos policy control-plane pre-defined命令查看。
# 定义类class1,匹配目的MAC地址为0050-ba27-bed3的报文。
# 定义类class2,匹配源MAC地址为0050-ba27-bed2的报文。
# 定义类class3,匹配高级IPv4 ACL 3101。
[Sysname] traffic classifier class3
[Sysname-classifier-class3] if-match acl 3101
# 定义类class4,匹配高级IPv6 ACL 3101。
[Sysname] traffic classifier class4
[Sysname-classifier-class4] if-match acl ipv6 3101
# 定义类class5,匹配所有报文。
[Sysname] traffic classifier class5
[Sysname-classifier-class5] if-match any
# 定义类class6,匹配DSCP优先级为1的报文。
[Sysname] traffic classifier class6
[Sysname-classifier-class6] if-match dscp 1
# 定义类class7,匹配IP优先级为1的报文。
[Sysname] traffic classifier class7
[Sysname-classifier-class7] if-match ip-precedence 1
# 定义类class8,匹配IP报文。
[Sysname] traffic classifier class8
[Sysname-classifier-class8] if-match protocol ip
# 定义类class9,匹配用户网络802.1p优先级为2的报文。
[Sysname] traffic classifier class9
[Sysname-classifier-class9] if-match customer-dot1p 2
# 定义类class10,匹配运营商网络802.1p优先级为5的报文。
[Sysname] traffic classifier class10
[Sysname-classifier-class10] if-match service-dot1p 5
# 定义类class11,匹配用户网络VLAN ID为1024的报文。
[Sysname] traffic classifier class11
[Sysname-classifier-class11] if-match customer-vlan-id 1024
# 定义类class12,匹配运营商网络VLAN ID为1000的报文。
[Sysname] traffic classifier class12
[Sysname-classifier-class12] if-match service-vlan-id 1000
traffic classifier tcl-name [ operator { and | or } ]
undo traffic classifier tcl-name
【缺省级别】
2:系统级
and:指定类中规则之间的关系为逻辑与,即报文必须匹配全部规则才属于该类。
or:指定类中规则之间的关系为逻辑或,即报文只要匹配其中任何一个规则就属于该类。
tcl-name:类的名称。
【描述】
traffic classifier命令用来定义一个类并进入类视图。undo traffic classifier命令用来删除一个类。
缺省情况下,类中各规则之间的关系为and,即逻辑与。
# 定义一个名为class1的类。
1.2  定义流行为的命令
1.2.1  accounting
accounting
undo accounting
流行为视图
【缺省级别】
2:系统级
【描述】
accounting命令用来为流行为配置统计动作。undo accounting命令用来取消流行为中统计动作的配置。
相关配置可参考命令qos policytraffic behaviorclassifier behavior
# 为流行为database配置统计动作。
[Sysname-behavior-database] accounting
1.2.2  car
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ green action ] [ red action ] [ yellow action ]
undo car
流行为视图
【缺省级别】
2:系统级
cir committed-information-rate:承诺信息速率。单位为kbps,取值范围为8~10000000。在不同单板上,实际生效的数值可能与用户输入的数值存在差异:
l              在SC单板上,如果用户输入的数值小于64,则实际生效的数值为64;如果用户输入的数值大于64且不是64的整数倍,则实际生效的数值为小于且最接近于用户输入值的64的整数倍。
l              在SD单板上,用户配置的数值必须是8的倍数。
cbs committed-burst-size:承诺突发尺寸。单位为byte,取值范围为512~16000000,缺省值为512byte。
ebs excess-burst-size:超出突发尺寸。单位为byte,取值范围为0~16000000,缺省值为512byte。
pir peak-information-rate:峰值信息速率。单位为kbps,取值范围为8~10000000。在不同单板上,实际生效的数值可能与用户输入的数值存在差异:
green action:报文的流量符合承诺信息速率时对报文采取的动作。action的取值如下:
l              discard:丢弃报文。
l              pass:发送报文。
l              remark-dscp-pass new-dscp:设置报文新的DSCP优先级,并发送报文。new-dscp的取值范围为0~63。
缺省情况下,对流量符合承诺信息速率的报文采取的动作为pass
red action:报文的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作。action的取值如下:
l              discard:丢弃报文。
l              pass:发送报文。
缺省情况下,对流量既不符合承诺信息速率也不符合峰值速率的报文采取的动作为discard
yellow action:报文的流量不符合承诺信息速率但是符合峰值信息速率时对报文采取的动作。action的取值如下:
l              discard:丢弃报文。
l              pass:发送报文。
缺省情况下,对流量不符合承诺信息速率但是符合峰值信息速率的报文采取的动作为pass
【描述】
car命令用来为流行为配置流量监管。undo car命令用来取消流行为中流量监管的配置。
需要注意的是,在流行为视图中反复执行本命令,最后一次配置的结果生效。
# 为流行为database配置流量监管,限制报文的速率为6400kbps,将超出限制的报文丢弃。
[Sysname-behavior-database] car cir 6400 red discard
display traffic behavior user-defined [ behavior-name ]
【缺省级别】
1:监控级
behavior-name:流行为的名称。
【描述】
display traffic behavior命令用来显示用户自定义流行为的配置信息。
如果没有指定流行为名,则显示所有用户自定义流行为的配置信息。
# 显示所有用户自定义流行为的配置信息。
  User Defined Behavior Information:
    Behavior: test
      Marking:
        Remark dot1p COS 4
      Committed Access Rate:
        CIR 64 (kbps), CBS 4000 (byte), EBS 4000 (byte), PIR 640 (kbps)
        Green Action: pass
        Red Action: discard
        Yellow Action: pass
表1-3 display traffic behavior user-defined命令显示信息描述表
用户自定义的流行为
Behavior
流行为的名称
Marking
重标记的相关信息
流量监管的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
EBS
超出突发尺寸,单位为byte
PIR
峰值信息速率,单位为kbps
Green Action
对流量符合承诺信息速率的报文采取的动作
Red Action
Yellow Action
1.2.4  filter
filter { deny | permit }
undo filter
流行为视图
【缺省级别】
2:系统级
deny:丢弃报文。
permit:发送报文。
【描述】
filter命令用来为流行为配置流量过滤动作。undo filter命令用来取消流行为中过滤动作的配置。
# 为流行为database配置丢弃数据包的过滤动作。
1.2.5  redirect
redirect { cpu | interface interface-type interface-number | next-hop { ipv4-add1 [ ipv4-add2 ] | ipv6-add1 [ interface-type interface-number ] [ ipv6-add2 [ interface-type interface-number ] ] } }
undo redirect { cpu | interface interface-type interface-number | next-hop }
流行为视图
【缺省级别】
2:系统级
cpu:重定向到CPU。
interface interface-type interface-number:重定向到指定的端口。interface-type interface-number为端口类型和端口编号。
next-hop:重定向到指定的下一跳。
ipv4-add1/ipv4-add2:指定下一跳的IPv4地址。其中ipv4-add2ipv4-add1的备份下一跳地址,如果重定向到ipv4-add1失败,报文将被重定向到ipv4-add2
ipv6-add1/ipv6-add2:指定下一跳的IPv6地址。其中ipv6-add2ipv6-add1的备份下一跳地址,如果重定向到ipv6-add1失败,报文将被重定向到ipv6-add2。IPv6地址为链路本地地址时,下一跳IPv6地址需要配置接口;IPv6地址为非链路本地地址时,下一跳IPv6地址不需要配置接口。
【描述】
redirect命令用来为流行为配置流量重定向动作。undo redirect命令用来取消流行为中流量重定向动作的配置。
# 为流行为database配置流量重定向动作,将匹配流分类的报文重定向到端口GigabitEthernet 2/0/1。
[Sysname-behavior-database] redirect interface GigabitEthernet 2/0/1
1.2.6  remark dot1p
remark dot1p 8021p
undo remark dot1p
流行为视图
【缺省级别】
2:系统级
8021p:802.1p优先级,取值范围为0~7。
【描述】
remark dot1p命令用来为流行为配置标记802.1p优先级的动作。undo remark dot1p命令用来取消流行为中标记802.1p优先级动作的配置。
需要注意的是,remark dot1p动作与remark local-precedence动作同时配置时,两者重标记的802.1p优先级和本地优先级的取值必须相同,否则策略将不能成功应用。
# 为流行为database配置标记802.1p优先级的动作,将匹配流分类的报文的802.1p优先级值标记为2。
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence drop-precedence-value
undo remark drop-precedence
流行为视图
【缺省级别】
2:系统级
drop-precedence-value:丢弃优先级,取值范围为0~2。
【描述】
remark drop-precedence命令用来为流行为配置标记丢弃优先级的动作。undo remark drop-precedence命令用来取消流行为中标记丢弃优先级动作的配置。
# 为流行为database配置标记丢弃优先级的动作,将匹配流分类的报文的丢弃优先级标记为2。
[Sysname-behavior-database] remark drop-precedence 2
1.2.8  remark dscp
remark dscp dscp-value
undo remark dscp
流行为视图
【缺省级别】
2:系统级
dscp-value:DSCP优先级,取值范围为0~63。用户也可输入如下表所示的关键字。
表1-4 DSCP优先级说明
关键字
DSCP优先级(十进制)
DSCP优先级(二进制)
af11
10
001010
af12
12
001100
af13
14
001110
af21
18
010010
af22
20
010100
af23
22
010110
af31
26
011010
af32
28
011100
af33
30
011110
af41
34
100010
af42
36
100100
af43
38
100110
be (default)
0
000000
cs1
8
001000
cs2
16
010000
cs3
24
011000
cs4
32
100000
cs5
40
101000
cs6
48
110000
cs7
56
111000
ef
46
101110
【描述】
remark dscp命令用来为流行为配置标记DSCP优先级的动作。undo remark dscp命令用来取消流行为中标记DSCP优先级动作的配置。
# 为流行为database配置标记DSCP优先级的动作,将匹配流分类的报文的DSCP优先级标记为6。
remark ip-precedence ip-precedence-value
undo remark ip-precedence
流行为视图
【缺省级别】
2:系统级
ip-precedence-value:IP优先级,取值范围为0~7。
【描述】
remark ip-precedence命令用来为流行为配置标记IP优先级的动作。undo remark ip-precedence命令用来取消流行为中标记IP优先级动作的配置。
# 为流行为database配置标记IP优先级的动作,将匹配流分类的报文的IP优先级标记为6。
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence local-precedence
undo remark local-precedence
流行为视图
【缺省级别】
2:系统级
local-precedence:本地优先级,取值范围为0~7。
【描述】
remark local-precedence命令用来为流行为配置标记本地优先级的动作。undo remark local-precedence命令用来取消流行为中标记本地优先级动作的配置。
需要注意的是,remark local-precedence动作与remark dot1p动作同时配置时,两者重标记的本地优先级和802.1p优先级的取值必须相同,否则策略将不能成功应用。
# 为流行为database配置标记本地优先级的动作,将匹配流分类的报文的本地优先级标记为2。
remark qos-local-id local-id-value
undo remark qos-local-id
流行为视图
【缺省级别】
2:系统级
local-id-value:标记的QoS本地ID值,取值范围为1~4095。在WX6100E系列无线控制器以太网交换机上,能够支持的local-id-value值为1~3999。
【描述】
remark qos-local-id命令用来配置标记报文的qos-local-id值。undo remark qos-local-id命令用来取消标记报文的qos-local-id值。
仅SD单板支持标记报文的qos-local-id值。
# 配置标记报文的qos-local-id值为2。
[Sysname-behavior-database] remark qos-local-id 2
【缺省级别】
2:系统级
【描述】
traffic behavior命令用来定义一个流行为并进入流行为视图。undo traffic behavior命令用来删除一个流行为。
相关配置可参考命令qos policyqos apply policyclassifier behavior
# 定义一个名为behavior1的流行为。
[Sysname-behavior-behavior1]
1.3  定义策略的命令
classifier tcl-name behavior behavior-name [ mode do1q-tag-manipulation ]
undo classifier tcl-name
策略视图
【缺省级别】
2:系统级
tcl-name:类的名称。
behavior–name:流行为的名称。
mode dot1q-tag-manipulation:设置该类和流行为对应关系应用于N:1 VLAN映射功能。
【描述】
classifier behavior命令用来在策略中为类指定流行为,使类与流行为关联。undo classifier命令用来取消策略中类和流行为的关联。
需要注意的是,策略中每个类只能与一个动作关联。
相关配置可参考命令qos policy
当用户在策略下配置了多组类和流行为的对应关系时,如果某个流行为中配置了nestremark customer-vlan-idremark service-vlan-id动作,建议用户不要在此流行为中配置其他动作,以保证应用策略后实际的运行结果与用户的配置意图一致。
# 在策略user1中为类database指定流行为test。
[Sysname] qos policy user1
1.3.2  control-plane
【缺省级别】
2:系统级
slot slot-numberslot-number表示单板的槽位号,取值范围请以设备的实际情况为准。
【描述】
control-plane命令用来进入控制平面视图。
# 进入3号板控制平面视图。
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
display qos policy user-defined [ policy-name [ classifier tcl-name ] ]
【缺省级别】
1:监控级
policy-name:策略的名称。
tcl-name:类的名称。
【描述】
display qos policy命令用来显示指定策略或所有策略中指定类或所有类以及与类关联的行为的配置信息。
如果没有指定策略名,则显示所有用户定义策略的配置信息。
# 显示所有用户定义策略的配置信息。
  User Defined QoS Policy Information:
  Policy: test
   Classifier: test
     Behavior: test
      Accounting Enable
        Green Action: pass
        Red Action: discard
        Yellow Action: pass
表1-5 display qos policy命令显示信息描述表
Policy
策略的名称
Classifier
类的名称以及对应的配置信息
Behavior
流行为的名称以及对应的配置信息
display qos policy control-plane slot slot-number [ inbound ]
【缺省级别】
1:监控级
slot slot-number:显示指定单板的控制平面策略信息。slot-number表示单板的槽位号,取值范围请以设备的实际情况为准。
inbound:显示对进入控制平面的报文应用的QoS策略信息。
【描述】
display qos policy control-plane命令用来显示控制平面策略信息。
# 显示应用到3号板控制平面入方向的QoS策略信息。
<Sysname> display qos policy control-plane slot 3 inbound
Control-plane slot 3
  Direction: Inbound
  Policy: 1
    Classifier: 2
      Operator: AND
      Rule(s) : If-match acl 2000
      Behavior: 2
          CIR 128 (kbps), CBS 8000 (byte), EBS 0 (byte)
          Red Action: discard
          Green : 12928(Bytes)
          Yellow: 7936(Bytes)
          Red   : 43904(Bytes)
        Filter Enable: deny
表1-6 display qos policy control-plane命令显示信息描述表
Control-plane
控制平面
Direction
对进控制平面(Inbound)的报文应用QoS策略
Policy
策略名称及其内容
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
流行为的名称及其内容,内容可以有多种类型
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,也就是容纳突发流量的令牌桶深度,单位为byte
EBS
超出突发尺寸,在双令牌桶算法中超出突发流量超过承诺突发流量的部分,单位为byte
Red Action
对红色报文的动作
Green
绿色报文的流量统计
Yellow
黄色报文的流量统计
Red
红色报文的流量统计
Filter Enable
包过滤的相关信息(deny表示丢弃数据包;permit表示允许数据包通过)
none
表示没有配置其他流行为
【缺省级别】
1:监控级
slot slot-number:显示指定单板的系统预定义的控制平面策略信息。slot-number表示单板的槽位号,取值范围请以设备的实际情况为准。
【描述】
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面策略信息。
如果不指定槽位号,则显示所有在位单板的系统预定义的控制平面策略信息。
# 显示3号板的预定义控制平面策略信息内容。
<Sysname> display qos policy control-plane pre-defined slot 3
 Pre-defined Control-plane Policy Slot 3
  Index | PacketType    | Priority | BandWidth(Kbps)
  1          ISIS            5         256
  29         ARP             2         256
  30         ARP_REPLY       3         256
  35         DOT1X           2         128
  36         STP             6         256
  37         LACP            6         64
  38         GVRP            3         64
  41         ICMP            1         512
  53         LLDP            4         64
  54         DLDP            4         64
表1-7 display qos policy control-plane pre-defined命令显示信息描述表
预定义控制平面策略内容
Index
系统预定义匹配字段索引号
Packet-type
匹配字段内容
Priority
优先级
BandWidth
带宽
【缺省级别】
1:监控级
inbound:显示设备在全局入方向应用的QoS策略。
outbound:显示设备在全局出方向应用的QoS策略。
slot slot-number:显示全局QoS策略在指定单板上的应用情况。某些情况下,在全局应用的QoS策略可能在某块单板上没有正常下发,用户可以通过使用slot参数来查看QoS策略在各个单板上的应用情况。slot-number表示单板的槽位号,取值范围请以设备的实际情况为准。
【描述】
display qos policy global命令用来显示全局策略的配置信息。
l              如果不指定显示方向,则同时显示出入两个方向的全局QoS策略信息。
l              如果不指定槽位号,则表示显示主控板上全局QoS策略信息,不显示各单板的全局QoS策略信息。
# 显示入方向上全局策略的配置信息。
<Sysname> display qos policy global inbound
  Direction: Inbound
  Policy: abc_policy
   Classifier: abc
     Operator: AND
     Rule(s) : If-match dscp cs1
     Behavior: abc
        CIR 640 (kbps), CBS 4000 (byte), EBS 4000 (byte)
        Green Action: pass
        Red Action: discard
        Yellow Action: pass
        Green : 0(Packets)
  Direction: Outbound
  Policy: 2
   Classifier: 2 (Failed)
     Operator: AND
     Rule(s) : If-match customer-dot1p 3
     Behavior: 1
      Marking:
        Remark local precedence 2
表1-8 display qos policy global命令输出信息描述
Direction
策略应用在全局的方向
Policy
策略的名称及其对应的配置信息
Classifier
类的名称及其内容;如果在类的名称后面显示“(Failed)”,表示该流分类以及与其关联的流行为所组成的关联组没有正常应用,其中:
l      如果在没有使用slot参数的情况下显示“(Failed)”,表示该关联组没有在设备全局正常应用
l      如果在使用了slot参数的情况下显示“(Failed)”,表示该关联组没有在指定单板上正常应用
一个QoS策略中可以存在多个关联组,某个关联组的下发失败并不影响其它关联组的正常应用
Behavior
流行为的名称及其对应的配置信息
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
【缺省级别】
1:监控级
interface-type interface-number:端口类型和端口编号。
inbound:入方向。
outbound:出方向。
【描述】
display qos policy interface命令用来显示端口上策略的配置情况和统计信息。
如果没有指定端口,将显示所有端口上策略的配置情况和统计信息。
# 显示端口GigabitEthernet 2/0/1上策略的配置情况和统计情况。
<Sysname> display qos policy interface GigabitEthernet 2/0/1
  Interface: GigabitEthernet2/0/1
  Direction: Inbound
  Policy: abc_policy
   Classifier: abc
     Operator: AND
     Behavior: abc
        Green Action: pass
        Red Action: discard
        Yellow Action: pass
        Green : 0(Packets)
表1-9 display qos policy interface命令显示信息描述表
端口名称,由端口类型和端口编号结合在一起组成
Direction
策略应用在端口的方向
Policy
策略的名称及其对应的配置信息
Classifier
类的名称及其对应的配置信息
Failed表示此策略应用失败
Operator
同一个类中多条分类规则的逻辑关系
Rule(s)
分类规则
Behavior
流行为的名称及其对应的配置信息
【缺省级别】
1:监控级
name policy-name:VLAN策略的名称。
vlan vlan-id:VLAN编号。如果没有指定vlan-id,将显示所有VLAN策略的配置信息。
inbound:显示对VLAN接收到的报文应用QoS策略信息。
outbound:显示对VLAN发送的报文应用QoS策略信息。
slot slot-number:显示VLAN策略在指定单板上的应用情况。某些情况下,在全局配置的VLAN策略可能在某块单板上没有正常下发,用户可以通过使用slot参数来查看VLAN策略在各个单板上的应用情况。slot-number表示单板的槽位号,取值范围请以设备的实际情况为准。
【描述】
display qos vlan-policy命令用来显示VLAN策略的配置信息。
l              如果不指定显示方向,则同时显示出入两个方向的VLAN策略信息。
l              如果不指定槽位号,则表示显示设备上所有的VLAN策略信息。
# 显示名字为test的VLAN策略的配置信息。
<Sysname> display qos vlan-policy name test
  Policy test
    Vlan 300:inbound
表1-10 display qos vlan-policy命令输出信息描述
域名
Policy
VLAN策略的名称
Vlan 300
应用策略的VLAN编号
inbound
对VLAN接收到的报文应用策略
# 显示VLAN 300上应用的VLAN策略的配置信息。
<Sysname> display qos vlan-policy vlan 300
  Vlan 300
  Direction: Inbound
  Policy: test
   Classifier: test
     Operator: AND
     Rule(s) : If-match customer-vlan-id 3
     Behavior: test
      Accounting Enable:
        0 (Packets)
        CIR 6400 (kbps), CBS 4000 (byte), EBS 4000 (byte)
        Green Action: pass
        Red Action: discard
        Yellow Action: pass
        Green : 0(Packets)
  Direction: Outbound
  Policy: 2
     Operator: AND
     Behavior: 1
      Marking:
表1-11 display qos vlan-policy命令输出信息描述
Vlan 300
应用策略的VLAN编号
Inbound
对VLAN接收的报文应用策略
Classifier
Behavior
流行为的名称及其对应的配置信息
undo qos apply policy { inbound | outbound }
以太网端口视图/端口组视图/控制平面视图
【缺省级别】
2:系统级
inbound:对端口接收的报文应用策略。
outbound:对端口发送的报文应用策略。在控制平面视图下不支持该参数。
policy-name:策略的名称。
【描述】
qos apply policy命令用来应用QoS策略。undo qos apply policy命令用来取消应用的QoS策略。
需要注意的是,应用策略时inboundoutbound方向的支持情况和流行为中定义的动作以及单板的类型有关,详细情况如下表所示。
表1-12 SC、SD单板对QoS策略的支持情况
单板类型
动作
SC单板
SD单板
inbound方向
outbound方向
inbound方向
outbound方向
流量统计
支持
支持
支持
支持
流量监管
支持
支持
支持
支持
流量过滤
支持
支持
支持
支持
流镜像
支持
支持
支持
支持
外层VLAN标签
支持
不支持
支持
不支持
重定向
支持
不支持
支持
不支持
标记报文的用户网络VLAN ID
不支持
支持
不支持
支持
标记报文的802.1p优先级
支持
支持
支持
支持
标记报文的丢弃优先级
支持
不支持
支持
不支持
标记报文的DSCP优先级
支持
支持
支持
支持
标记报文的IP优先级
支持
支持
支持
支持
标记报文的本地优先级
支持
不支持
支持
不支持
标记报文的运营商网络VLAN ID
支持
支持
支持
支持
重标记QoS本地优先级
不支持
不支持
支持
不支持
Netstream过滤
不支持
不支持
支持
支持
# 对端口GigabitEthernet 2/0/1接收的报文应用策略test。
[Sysname] interface GigabitEthernet 2/0/1
[Sysname-GigabitEthernet2/0/1] qos apply policy test inbound
# 对进入3号槽控制平面的报文应用策略aaa。
[Sysname-cp-slot3] qos apply policy aaa inbound
user-profile视图
【缺省级别】
2:系统级
inbound:对上线用户接收到的报文应用策略。
outbound:对上线用户发送的报文应用策略。
policy-name:策略名,为1~31个字符的字符串。
【描述】
qos apply policy命令用来为User Profile应用关联的策略。undo qos apply policy命令用来删除关联的策略。
l              如果User Profile处于激活状态,则不能删除已经应用到此User Profile的策略,除策略引用的ACL规则外也不能修改策略的其他具体内容。引用的ACL规则的具体内容在用户上线后也不能修改。
l              关联的策略只有在User Profile处于激活状态、且用户成功上线后才能生效。
l              user-profile视图下应用的策略中的流行为只支持remarkcarfilter三种动作。
l              user-profile视图下应用的策略不能为空策略。
# 对上线用户user发送的报文应用策略test(该策略已经建立)。
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
undo qos apply policy global { inbound | outbound }
【缺省级别】
2:系统级
policy-name:策略的名称。
inbound:对所有端口接收的报文应用策略。
outbound:对所有端口发送的报文应用策略。
【描述】
qos apply policy global命令用来全局应用QoS策略,全局应用的QoS策略对全部流量生效。undo qos apply policy global命令用来取消全局应用的QoS策略。
需要注意的是,应用策略时inboundoutbound方向的支持情况和流行为中定义的动作以及单板的类型有关,详细情况请参见表1-12
# 对全局接收的报文应用策略user1。
[Sysname] qos apply policy user1 global inbound
1.3.12  qos policy
qos policy policy-name
undo qos policy policy-name
【缺省级别】
2:系统级
policy-name:策略的名称。
【描述】
qos policy命令用来定义一个策略并进入策略视图。undo qos policy命令用来删除一个策略。
需要注意的是,如果某个策略处于应用状态,则不允许删除该策略。用户需要取消对该策略的应用,然后再使用undo qos policy命令删除该策略。
相关配置可参考命令classifier behaviorqos apply policy
# 定义一个名为user1的策略。
undo qos vlan-policy vlan vlan-id-list { inbound | outbound }
【缺省级别】
2:系统级
policy-name:策略的名称。
vlan-id-list:VLAN ID列表,形式可以为vlan-id to vlan-id,也可以输入多个不连续的VLAN ID。设备最多允许用户同时指定8个VLAN ID。
inbound:对VLAN接收的报文应用策略。
outbound:对VLAN发送的报文应用策略。
【描述】
qos vlan-policy命令用来在VLAN上应用策略。undo qos vlan-policy命令用来取消策略在VLAN上的应用。
需要注意的是,应用VLAN策略时inboundoutbound方向的支持情况和流行为中定义的动作以及VLAN内端口所属单板的类型有关,详细情况请参见表1-12
建议用户不要在VLAN上和此VLAN内的端口上同时应用策略。
# 对VLAN 200、300、400、500、600、700、800、900接收的报文应用策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 600 700 800 900 inbound
reset qos policy control-plane slot slot-number [ inbound ]
【缺省级别】
1:监控级
slot slot-number:清除指定单板的控制平面策略的统计信息。slot-number表示单板的槽位号,取值范围请以设备的实际情况为准。
inbound:清除进入控制平面的方向的控制平面策略的统计信息。
【描述】
reset qos policy control-plane命令用来清除控制平面策略的统计信息。
# 清空应用到3号板进入控制平面方向的QoS策略统计信息。
<Sysname> reset qos policy control-plane slot 3 inbound
reset qos policy global { inbound | outbound }
【缺省级别】
1:监控级
inbound:入方向。
outbound:出方向。
【描述】
reset qos policy global命令用来清除全局策略的统计信息。
# 清除全局策略入方向的统计信息。
<Sysname> reset qos policy global inbound
【缺省级别】
1:监控级
vlan vlan-id:VLAN的编号,取值范围为1~4094。
inbound:清除VLAN接收到的报文应用QoS策略的统计信息。
outbound:清除对VLAN发送的报文应用QoS策略的统计信息。
【描述】
reset qos vlan-policy命令用来清除应用于VLAN上的策略的统计信息。
如果没有指定VLAN的编号,将清除所有应用于VLAN上的策略的统计信息。
# 清除应用于VLAN 2上的策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
2 优先级映射配置命令
2.1  优先级映射表配置命令
display qos map-table [ dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | exp-dot1p | exp-dp ]
【缺省级别】
1:监控级
dot1p-dp:802.1p优先级到丢弃优先级映射表。
dot1p-exp:802.1p优先级到EXP映射表。
dot1p-lp:802.1p优先级到本地优先级映射表。
dscp-dot1p:DSCP优先级到802.1p优先级映射表。
dscp-dp:DSCP优先级到丢弃优先级映射表。
dscp-dscp:DSCP优先级到DSCP优先级映射表。
exp-dot1p:EXP到802.1p优先级映射表。
exp-dp:EXP到丢弃优先级映射表。
【描述】
display qos map-table命令用来显示优先级映射表的配置信息。
如果没有指定映射表,将显示所有优先级映射表的配置信息。
相关配置可参考命令qos map-table
# 显示802.1p优先级到丢弃优先级映射表的配置信息。
<Sysname> display qos map-table dot1p-dp
MAP-TABLE NAME: dot1p-dp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    0
   1    :    0
   2    :    0
   3    :    0
   4    :    0
   5    :    0
   6    :    0
   7    :    0
表2-1 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名称
TYPE
映射表的类型
IMPORT
映射表的输入项
EXPORT
映射表的输出项
2.1.2  import
优先级映射表视图
【缺省级别】
2:系统级
import-value-list:输入参数列表。
export-value:输出参数。
all:删除所有配置的输入参数。
【描述】
import命令用来配置优先级映射表参数,定义一条或一组映射规则。undo import命令用来恢复缺省情况。
需要注意的是,配置DSCP优先级与丢弃优先级的映射关系时,不支持将DSCP优先级映射为丢弃优先级1。
相关配置可参考命令display qos map-table
# 配置802.1p优先级到丢弃优先级映射表,将802.1p优先级4、5对应的丢弃优先级配置为1。
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
2.1.3  qos map-table
qos map-table { dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | exp-dot1p | exp-dp }
【缺省级别】
2:系统级
【描述】
# 进入802.1p优先级到丢弃优先级映射表视图。
2.2  端口优先级配置命令
2.2.1  qos priority
qos priority priority-value
undo qos priority
以太网端口视图/端口组视图
【缺省级别】
2:系统级
priority-value:端口优先级,取值范围为0~7。
【描述】
qos priority命令用来在端口或端口组上配置优先级。undo qos priority命令用来恢复缺省情况。
缺省情况下,端口的优先级为0。
需要注意的是,对于不带有802.1Q标签头的报文,交换机将使用端口的优先级作为该端口接收的报文的802.1p优先级,然后根据该优先级查找802.1p优先级到本地优先级/丢弃优先级映射表,为报文标记本地优先级/丢弃优先级。
# 配置端口GigabitEthernet 2/0/1的优先级为2。
[Sysname-GigabitEthernet2/0/1] qos priority 2
2.3  端口优先级信任模式配置命令
【缺省级别】
1:监控级
【描述】
display qos trust interface命令用来显示端口的优先级信任模式。
如果没有指定端口,将显示所有端口的优先级信任模式。
# 显示端口GigabitEthernet 2/0/1的优先级信任模式配置信息。
<Sysname> display qos trust interface GigabitEthernet 2/0/1
 Port priority information
  Port priority :0
Port priority trust type : dscp
表2-2 display qos trust interface命令显示信息描述表
端口名称,由端口类型和端口编号构成
Port priority
端口的优先级
优先级信任模式:
l      dscp表示信任报文的DSCP优先级
l      dot1p表示信任报文的802.1p优先级
2.3.2  qos trust
qos trust dscp
undo qos trust
以太网端口视图/端口组视图
【缺省级别】
2:系统级
dscp:信任报文的DSCP优先级。
【描述】
qos trust命令用来在端口或端口组上配置优先级信任模式。undo qos trust命令用来恢复缺省情况。
缺省情况下,信任模式为信任报文的802.1p优先级。
# 在端口GigabitEthernet 2/0/1上配置优先级信任模式为信任报文的DSCP优先级。
[Sysname-GigabitEthernet2/0/1] qos trust dscp
3 流量整形和端口限速配置命令
3.1  流量整形配置命令
【缺省级别】
1:监控级
interface-type:端口类型。
interface-number:端口编号。
【描述】
display qos gts interface命令用来显示流量整形的配置信息。
如不指定端口,将显示所有端口的流量整形配置信息。
# 显示所有端口的流量整形配置信息。
Rule(s): If-match queue 2
 CIR 640 (kbps), CBS 40960 (byte)
表3-1 display qos gts命令显示信息描述表
端口名,由端口类型和端口编号结合在一起组成
Rule(s)
匹配规则,If-match queue 2表示对队列2进行流量整形
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
3.1.2  qos gts
qos gts queue queue-number cir committed-information-rate [ cbs committed-burst-size ]
undo qos gts queue queue-number
以太网端口视图/端口组视图
【缺省级别】
2:系统级
queue queue-number:队列编号,取值范围为0~7。
cir committed-information-rate:承诺信息速率,单位为kbps。
l              在SC单板上,百兆端口的取值范围为64~102400,千兆端口的取值范围为64~1048576,万兆端口的取值范围为64~10485760。用户配置的数值必须是64的倍数。
l              在SD单板上,百兆端口的取值范围为8~102400,千兆端口的取值范围为8~1048576,万兆端口的取值范围为8~10485760,用户配置的数值必须是8的倍数。
cbs committed-burst-size:承诺突发尺寸,单位为byte。
l              如果不指定cbs参数,committed-burst-size缺省取值为62.5ms*committed-information-rate,在SC单板上且必须为4096的整数倍,如果乘积不是4096的整数倍,就取比乘积大的最近的4096的整数倍。在SD单板上且必须为512的整数倍,如果乘积不是512的整数倍,就取比乘积大的最近的512的整数倍。
l              如果指定cbs参数,在SC单板上取值范围为4096~16777216,committed-burst-size必须为4096的整数倍;在SD单板上取值范围为512~16777216,committed-burst-size必须为512的整数倍。
【描述】
qos gts命令用来配置流量整形。undo qos gts命令用来取消流量整形配置。
# 配置端口GigabitEthernet 2/0/1上队列2发送报文的速率为640 kbps。
[Sysname-GigabitEthernet2/0/1] qos gts queue 2 cir 640
3.2  端口限速配置命令
【缺省级别】
1:监控级
【描述】
display qos lr interface命令用来显示端口限速的配置信息。
如不指定端口,将显示所有端口的端口限速配置信息。
# 显示所有端口的端口限速配置信息。
Interface: GigabitEthernet2/0/10
Direction: Outbound
 CIR 64000 (kbps),  CBS 4000000 (byte)
表3-2 display qos lr interface命令显示信息描述表
Direction
端口限速的方向
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
以太网端口视图/端口组视图
【缺省级别】
2:系统级
outbound:对端口发送的报文进行限速。cir committed-information-rate:承诺信息速率,单位为kbps:
在SC单板上,用户配置的数值必须是64的倍数,取值范围如下:
l              百兆端口:64~100000
l              千兆端口:64~1000000
l              万兆端口:64~10000000
在SD单板上,用户配置的数值必须是8的倍数,取值范围如下:
l              百兆端口:8~100000
l              千兆端口:8~1000000
l              万兆端口:8~10000000
l              如果不指定cbs参数,缺省取值为62.5ms*committed-information-rate,但是最大值不能超过16000000。
l              如果指定cbs参数,在SC单板上,取值范围4000~16000000;在SD单板上,取值范围512~16000000。
【描述】
qos lr outbound命令用来限制端口发送报文的速率。undo qos lr outbound命令用来取消限制。
# 限制端口GigabitEthernet 2/0/1发送报文的速率为640kbps。
[Sysname-GigabitEthernet2/0/1] qos lr outbound cir 640
4 拥塞管理配置命令
4.1  拥塞管理配置命令
display qos sp interface [ interface-type interface-number ]
【缺省级别】
1:监控级
【描述】
display qos sp interface命令用来显示端口的SP(Strict Priority,严格优先级)队列配置信息。
如不指定端口,将显示所有端口的SP队列配置信息。
相关配置可参考命令qos sp
# 显示端口GigabitEthernet 2/0/1的SP队列配置信息。
<Sysname> display qos sp interface GigabitEthernet 2/0/1
Output queue: Strict-priority queue
display qos wfq interface [ interface-type interface-number ]
【缺省级别】
1:监控级
【描述】
display qos wfq interface命令用来显示端口的WFQ(Weighted Fair Queuing,加权公平队列)配置信息。
如果没有指定端口,将显示所有端口的WFQ配置信息。
相关配置可参考命令qos wfq
# 显示端口GigabitEthernet 3/0/1的WFQ配置信息。
< Sysname >display qos wfq interface gigabitethernet 3/0/1
Interface: GigabitEthernet3/0/1
 Output queue: Hardware weighted fair queue
Queue ID         Weight          Min-Bandwidth
0                1               64
1                1               64
2                1               64
3                1               64
4                1               64
5                1               64
6                1               64
7                1               64
表4-1 display qos wfq interface命令显示信息描述表
Output queue
当前队列的调度类型
Queue ID
队列编号
Weight
队列的权重
Min-Bandwidth
队列的最小保证带宽值
display qos wrr interface [ interface-type interface-number ]
【缺省级别】
1:监控级
【描述】
display qos wrr interface命令用来显示端口的WRR(Weighted Round Robin,加权轮询)队列配置信息。
如果没有指定端口,将显示所有端口的WRR队列配置信息。
相关配置可参考命令qos wrr
# 显示端口GigabitEthernet 2/0/1的WRR队列配置信息。
<Sysname> display qos wrr interface GigabitEthernet 2/0/1
Output queue:   Weighted round robin queue
Queue ID    Group    Weight
   0         sp       N/A
   1         sp       N/A
   2         1        3
   3         1        4
   4         1        5
   5         1        6
   6         1        7
   7         1        8
表4-2 display qos wrr interface命令显示信息描述表
Output queue
当前队列的调度类型
Queue ID
队列编号
Group
调度组号,表示队列属于哪一个调度组
Weight
队列的权重,N/A表示队列采用SP调度算法
undo qos bandwidth queue queue-id [ min bandwidth-value ]
以太网端口视图/端口组视图
【缺省级别】
2:系统级
queue-id:队列编号,取值范围为0~7。
bandwidth-value:端口队列的最小保证带宽值,单位为kbps。
【描述】
qos bandwidth queue命令用来配置流量拥塞时,端口/端口组队列的最小带宽保证值。undo qos bandwidth queue命令用来取消端口/端口组队列的最小带宽保证配置。
l              在以太网端口视图下执行该命令,则该配置只在当前端口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效。
l              在端口或端口组上开启WFQ(Weighted Fair Queuing,加权公平队列)调度算法的情况下,才需要配置最小带宽保证。
缺省情况下,队列的最小保证带宽为64kbps。
# 在GigabitEthernet 2/0/1上配置队列0的最小保证带宽值为100kbps。
[Sysname-GigabitEthernet 2/0/1] qos wfq
[Sysname-GigabitEthernet 2/0/1] qos bandwidth queue 0 min 100
4.1.5  qos sp
qos sp
undo qos sp
以太网端口视图/端口组视图
【缺省级别】
2:系统级
【描述】
qos sp命令用来在端口或端口组上配置SP调度算法。undo qos sp命令用来恢复缺省情况。
缺省情况下,所有端口采用SP调度算法。
相关配置可参考命令display qos sp interface
# 在端口GigabitEthernet 2/0/1上配置使用SP调度算法。
[Sysname-GigabitEthernet2/0/1] qos sp
4.1.6  qos wfq
qos wfq
undo qos wfq
以太网端口视图/端口组视图
【缺省级别】
2:系统级
【描述】
qos wfq命令用来在端口或端口组上开启WFQ(Weighted Fair Queuing,加权公平队列)调度算法。undo qos wfq命令用来恢复缺省情况。
缺省情况下,所有端口采用SP调度算法。
相关配置可参考命令display qos wfq interface
# 在端口GigabitEthernet 2/0/1上开启WFQ调度算法。
[Sysname-GigabitEthernet2/0/1] qos wfq
qos wfq queue-id weight schedule-value
undo qos wfq queue-id weight
以太网端口视图/端口组视图
【缺省级别】
2:系统级
weight schedule-value:队列的调度权重值,schedule-value的取值范围为0~15,即各队列根据调度权重值分配可分配带宽。
【描述】
qos wfq命令用来在端口或端口组上配置WFQ调度算法中每个队列的调度权重值。undo qos wfq命令用来恢复缺省情况。
缺省情况下,在端口或端口组上开启WFQ调度算法后,各个队列的调度权重值为1。
相关配置可参考命令display qos wfq interface,qos bandwidth queue
# 配置端口GigabitEthernet 2/0/1使用WFQ调度算法,队列0~7的调度权重值分别为1、2、4、6、8、10、12、14。
[Sysname-GigabitEthernet2/0/1] qos wfq 0 weight 1
[Sysname-GigabitEthernet2/0/1] qos wfq 1 weight 2
[Sysname-GigabitEthernet2/0/1] qos wfq 2 weight 4
[Sysname-GigabitEthernet2/0/1] qos wfq 3 weight 6
[Sysname-GigabitEthernet2/0/1] qos wfq 4 weight 8
[Sysname-GigabitEthernet2/0/1] qos wfq 5 weight 10
[Sysname-GigabitEthernet2/0/1] qos wfq 6 weight 12
[Sysname-GigabitEthernet2/0/1] qos wfq 7 weight 14
4.1.8  qos wrr
qos wrr
undo qos wrr
以太网端口视图/端口组视图
【缺省级别】
2:系统级
【描述】
qos wrr命令用来在端口或端口组上开启WRR(Weighted Round Robin,加权轮询)调度算法。undo qos wrr命令用来恢复缺省情况。
缺省情况下,所有端口采用SP调度算法。
在端口或端口组上开启WRR调度算法后,队列0~7的缺省权重值分别为1、2、3、4、5、6、7、8。
相关配置可参考命令display qos wrr interface
# 在端口GigabitEthernet 2/0/1上开启WRR队列调度算法。
[Sysname-GigabitEthernet2/0/1] qos wrr
qos wrr queue-id group { group-id weight schedule-value | sp }
undo qos wrr
以太网端口视图/端口组视图
【缺省级别】
2:系统级
group-id:调度组编号,取值只能为1。
weight schedule-value:队列的权重,取值范围为1~15。
sp:严格优先级调度算法。
【描述】
qos wrr命令用来在端口或端口组上配置WRR(Weighted Round Robin,加权轮询)或SP+WRR调度算法。undo qos wrr命令用来恢复缺省情况。
缺省情况下,所有端口采用SP调度算法。
WX6100E系列无线控制器以太网交换机的端口支持8个输出队列,用户可以根据需要配置端口上的部分队列使用SP调度算法,部分队列使用WRR调度算法。通过将端口上的队列分别加入SP调度组和WRR调度组(即group 1),实现SP+WRR的调度功能。在队列调度时,系统会优先保证SP调度组内的队列调度,当SP调度组内的队列中没有报文发送时,才会调度WRR调度组内的队列。SP调度组内各个队列执行严格优先级调度方式,WRR调度组内各个队列执行加权轮询调度方式。
# 配置端口GigabitEthernet 2/0/1使用SP+WRR队列调度算法,0、1、2、3队列属于SP调度组,4、5、6、7队列属于WRR调度组,权重分别为2、4、6、8。
[Sysname-GigabitEthernet2/0/1] qos wrr 0 group sp
[Sysname-GigabitEthernet2/0/1] qos wrr 1 group sp
[Sysname-GigabitEthernet2/0/1] qos wrr 2 group sp
[Sysname-GigabitEthernet2/0/1] qos wrr 3 group sp
[Sysname-GigabitEthernet2/0/1] qos wrr 4 group 1 weight 2
[Sysname-GigabitEthernet2/0/1] qos wrr 5 group 1 weight 4
[Sysname-GigabitEthernet2/0/1] qos wrr 6 group 1 weight 6
[Sysname-GigabitEthernet2/0/1] qos wrr 7 group 1 weight 8
5 拥塞避免配置命令
5.1  拥塞避免配置命令
【缺省级别】
1:监控级
【描述】
display qos wred interface命令用来显示端口的WRED配置信息。
如果没有指定端口,将显示所有端口的WRED配置信息。
相关配置可参考命令qos wred apply
# 显示端口GigabitEthernet 2/0/1的WRED配置信息。
<Sysname> display qos wred interface GigabitEthernet 2/0/1
 Current WRED configuration:
 Applied WRED table name: queue-table1
display qos wred table [ table-name ]
【缺省级别】
1:监控级
table-name:WRED表的名称。
【描述】
display qos wred table命令用来显示WRED表的配置信息。
如果没有指定表的名称,将显示所有WRED表的配置信息。
相关配置可参考命令queue
# 显示名称为queue-table1的WRED表的配置信息。
<Sysname> display qos wred table queue-table1
Table Name: queue-table1
Table Type: Queue based WRED
QID:  gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob
 0    10    NA    10    10    NA    10    10    NA    10
 1    10    NA    10    10    NA    10    10    NA    10
 2    10    NA    10    10    NA    10    10    NA    10
 3    10    NA    10    10    NA    10    10    NA    10
 4    10    NA    10    10    NA    10    10    NA    10
 5    10    NA    10    10    NA    10    10    NA    10
 6    10    NA    10    10    NA    10    10    NA    10
 7    10    NA    10    10    NA    10    10    NA    10
表5-1 display qos wred table命令显示信息描述表
Table name
WRED表的名称
Table type
WRED表的类型
QID
队列编号
gmin
绿色报文(丢弃优先级为0)的起始丢弃队列长度百分比
gmax
绿色报文(丢弃优先级为0)的完全丢弃队列长度百分比
gprob
绿色报文(丢弃优先级为0)的丢弃概率的斜率
ymin
黄色报文(丢弃优先级为1)的起始丢弃队列长度百分比
ymax
黄色报文(丢弃优先级为1)的完全丢弃队列长度百分比
yprob
黄色报文(丢弃优先级为1)的丢弃概率的斜率
rmin
红色报文(丢弃优先级为2)的起始丢弃队列长度百分比
rmax
红色报文(丢弃优先级为2)的完全丢弃队列长度百分比
rprob
红色报文(丢弃优先级为2)的丢弃概率的斜率
qos wred apply table-name
undo qos wred apply
以太网端口视图/端口组视图
【缺省级别】
2:系统级
【描述】
qos wred apply命令用来在端口或端口组上应用WRED表。undo qos wred apply用来取消WRED表在端口或端口组上的应用。
缺省情况下,端口或端口组上没有应用WRED表。
相关配置可参考命令display qos wred interface
# 在端口上GigabitEthernet 2/0/1上应用WRED表queue-table1。
[Sysname-GigabitEthernet2/0/1] qos wred apply queue-table1
undo qos wred table table-name
【缺省级别】
2:系统级
table-name:WRED表的名称,为1~32个字符的字符串。
【描述】
qos wred queue table命令用来创建WRED表,同时进入该WRED表视图。undo qos wred table命令用来删除WRED表。
缺省情况下,没有创建WRED表。
需要注意的是,用户不能删除已经应用的WRED表。
相关配置可参考命令queue
# 创建WRED表queue-table1。
[Sysname-wred-table-queue-table1]
5.1.5  queue
queue queue-id [ drop-level drop-level ] low-limit low-limit [ discard-probability discard-prob ]
undo queue { queue-id | all }
WRED表视图
【缺省级别】
2:系统级
drop-level drop-level:丢弃级别,取值范围为0~2。如果没有指定丢弃级别,后续配置的参数对该队列所有丢弃级别的报文都生效。
low-limit low-limit:起始丢弃队列长度百分比,low-limit的取值范围为0~100,缺省值为10。
discard-probability discard-prob:本参数含义因单板(该WRED表所应用的端口所在的单板)类型而异,具体请参见表5-2discard-prob的取值范围为0~90,缺省值为10,可针对每个丢弃级别进行设置。
表5-2 discard-probability discard-prob参数含义
单板类型
discard-probability discard-prob参数的含义
SD单板
在以队列长度百分比为横坐标,以丢弃概率为纵坐标的坐标图中,以(low-limit,0)为起点,以(100%,max-drop-probility)为终点的直线与横坐标的夹角度数,取值范围0~90。
l      当队列长度一定时,该参数取值越大,丢弃概率越大;
l      当该参数一定时,随着队列长度的增加,丢弃概率也增大
SC单板
丢弃概率的倒数,各数值对应的丢弃概率如下:
l      discard-prob参数设置为0时,丢弃概率为100%;
l      discard-prob参数设置为1~8时,丢弃概率为1/8;
l      discard-prob参数设置为9~16时,丢弃概率为1/16;
l      discard-prob参数设置为17~32时,丢弃概率为1/32;
l      discard-prob参数设置为33~64时,丢弃概率为1/64;
l      discard-prob参数设置为65~90时,丢弃概率为1/128
【描述】
queue命令用来编辑WRED表的内容。undo queue命令用来恢复WRED表的内容为缺省值。
缺省情况下,WRED表中所有丢弃级别的报文的起始丢弃队列长度百分比为10,丢弃概率与队列长度的夹角度数(SD单板)或丢弃概率的倒数(SC单板)为10。
相关配置可参考命令qos wred queue table
# 修改WRED表queue-table1的队列1的丢弃参数,将丢弃级别为1的报文的起始丢弃队列长度百分比配置为10,丢弃概率与队列长度的夹角度数为30(假设WRED表queue-table1应用在SD单板的端口上)。
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 discard-probability 30
6 聚合CAR配置命令
6.1  聚合CAR配置命令
6.1.1  car name
car name car-name
undo car
流行为视图
【缺省级别】
2:系统级
car-name:聚合CAR的名称。
【描述】
car name命令用来配置流行为的聚合CAR动作。undo car用来删除聚合CAR的动作。
仅有SD系列单板支持应用带有聚合CAR动作的QoS策略。
# 配置流行为be1的聚合CAR动作为aggcar-1。
【缺省级别】
1:监控级
car-name:聚合CAR的名称。
【描述】
display qos car name命令用来显示聚合CAR的配置和统计信息。
l              如果输入car-name参数,将显示指定聚合CAR的配置和统计信息。
l              如果不输入car-name参数,将显示所有聚合CAR的配置和统计信息。
# 显示聚合CAR aggcar-1的配置信息。
<Sysname> display qos car name aggcar-1
  Mode: aggregative
  CIR 1024(kbps)  CBS: 10000(byte)  EBS: 10000(byte)  PIR: 1024(kbps)
  Green Action: pass
  Yellow Action: pass
  Red Action: discard
  Green packet 0(Pkts)
  Red packet 0(Pkts)
表6-1 display qos car name命令显示信息描述表
Name
流量监管的名称
Mode
流量监管的类型
CIR  CBS  EBS  PIR
流量监管流量的参数配置
Green Action
对红色报文的动作
Yellow Action
对黄色报文的动作
Red Action
对红色报文的动作
Green packet
绿色报文的流量统计
Red packet
红色报文的流量统计
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peek-information-rate ] [ red action ]
undo qos car car-name
【缺省级别】
2:系统级
car-name:聚合CAR的名称。
cir committed-information-rate:承诺信息速率。单位为kbps,取值范围为8~10000000,在不同单板上,实际生效的数值可能与用户输入的数值存在差异:
pir peak-information-rate:峰值信息速率。单位为kbps,取值范围为8~10000000,在不同单板上,实际生效的数值可能与用户输入的数值存在差异:
l              discard:丢弃报文。
l              pass:发送报文。
l              discard:丢弃报文。
l              pass:发送报文。
l              discard:丢弃报文。
l              pass:发送报文。
【描述】
qos car aggregative命令用来配置聚合CAR。undo qos car命令用来取消聚合CAR的配置。
聚合CAR配置需要在接口上应用或在策略中引用后才能生效。
# 配置聚合CAR采取的CAR参数取值,cir取值为200,cbs取值为2000,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 200 cbs 2000 red discard
【缺省级别】
2:系统级
car-name:聚合CAR的名称。
【描述】
reset qos car name命令用来清除聚合CAR的统计信息。
l              如果输入car-name参数,将清除指定聚合CAR的统计信息。
l              如果不输入car-name参数,将清除所有聚合CAR的统计信息。
# 清除聚合CAR aggcar-1的统计信息。
<Sysname> reset qos car name aggcar-1
