05-MPLS分册
02-MPLS基本配置命令
本章节下载 02-MPLS基本配置命令  (370.76 KB)
docurl=/cn/Service/Document_Software/Document_Center/Wlan/WX/WX6100E/Command/Command_Manual/H3C_WX6100E_CM-Release_6600(V1.00)/05/201006/677419_30005_0.htm
02-MPLS基本配置命令
目
1 MPLS基本配置命令
1.1 MPLS基本配置命令
1.1.1 accept-label
1.1.2 advertise-label
1.1.3 display mpls ilm
1.1.4 display mpls interface
1.1.5 display mpls label
1.1.6 display mpls ldp
1.1.7 display mpls ldp cr-lsp
1.1.8 display mpls ldp fec
1.1.9 display mpls ldp interface
1.1.10 display mpls ldp lsp
1.1.11 display mpls ldp peer
1.1.12 display mpls ldp remote-peer
1.1.13 display mpls ldp session
1.1.14 display mpls ldp vpn-instance
1.1.15 display mpls lsp
1.1.16 display mpls lsp statistics
1.1.17 display mpls nhlfe
1.1.18 display mpls nhlfe reflist
1.1.19 display mpls route-state
1.1.20 display mpls static-lsp
1.1.21 display mpls statistics interface
1.1.22 display mpls statistics lsp
1.1.23 du-readvertise
1.1.24 du-readvertise timer
1.1.25 graceful-restart (MPLS-LDP view)
1.1.26 graceful-restart mpls ldp
1.1.27 graceful-restart timer neighbor-liveness
1.1.28 graceful-restart timer reconnect
1.1.29 graceful-restart timer recovery
1.1.30 hops-count
1.1.31 label advertise
1.1.32 label-distribution
1.1.33 loop-detect
1.1.34 lsp-trigger
1.1.35 lsr-id
1.1.36 md5-password
1.1.37 mpls
1.1.38 mpls ldp (System view)
1.1.39 mpls ldp (Interface view)
1.1.40 mpls ldp remote-peer
1.1.41 mpls ldp timer hello-hold
1.1.42 mpls ldp timer keepalive-hold
1.1.43 mpls ldp transport-address
1.1.44 mpls lsr-id
1.1.45 path-vectors
1.1.46 ping lsp
1.1.47 prefix-label advertise
1.1.48 remote-ip
1.1.49 remote-ip bfd
1.1.50 reset mpls ldp
1.1.51 reset mpls statistics interface
1.1.52 reset mpls statistics lsp
1.1.53 static-lsp egress
1.1.54 static-lsp ingress
1.1.55 static-lsp transit
1.1.56 statistics interval
1.1.57 tracert lsp
1.1.58 ttl expiration enable
1.1.59 ttl expiration pop
1.1.60 ttl propagate
1 MPLS基本配置命令
l    目前支持MPLS能力和MPLS LDP能力的接口类型为VLAN接口(Vlan-interface)。
l    除了LDP的GR特性外,MPLS LDP视图下的命令都可以在MPLS-LDP-VPN实例视图下使用。MPLS LDP视图下的命令对公网LDP起作用;MPLS-LDP-VPN实例视图下的命令对LDP实例起作用。文中不再赘述。
1.1  MPLS基本配置命令
1.1.1  accept-label
accept-label peer peer-id ip-prefix ip-prefix-name
undo accept-label peer peer-id
MPLS-LDP视图/MPLS-LDP-VPN实例视图
【缺省级别】
2:系统级
peer-id:LDP peer的LSR ID。
ip-prefix-name:IP地址前缀列表名,为1~19个字符的字符串。指定地址前缀类型的FEC的地址前缀/掩码列表。
【描述】
accept-label命令用来限制从指定LDP PEER接受通告过来的标签映射。undo accept-label命令用来取消这种对标签映射的接受限制。
缺省情况下,从指定的LDP PEER通告过来的所有标签映射都被接受,除非收到的标签映射数超出了LDP能够保存的最大范围。
需要注意的是:指定的ip-prefix用于过滤指定PEER通告来的标签映射。如果标签映射的地址前缀通过ip-prefix检查,则接受标签映射,否则不接受且不保存标签映射。
LSR不保存无法通过标签接受控制ip-prefix规则而丢弃的标签映射,因此无法向PEER请求重新通告这些标签映射。LDP协议也没有提供一种要求PEER重新通告所有标签映射的方式。因此,由于发生配置变化而要求LSR重新获取之前丢弃的标签映射时,必须通过手工复位LDP会话的方式来获取,例如以下配置变化,执行undo accept-label peer peer-id命令;标签接受控制的ip-prefix规则修改,存在这样的标签映射:修改前不能通过ip-prefix规则检查,而规则修改后则能够通过。
# 对于指定的LDP PEER(LSR ID 1.1.1.9),只允许接受通告过来的网段地址 10.1.1.0/24和10.2.1.0/24的标签映射。
[Sysname] mpls ldp
[Sysname-mpls-ldp] accept-label peer 1.1.1.9 ip-prefix prefix-from-RTA
[Sysname-mpls-ldp] quit
[Sysname] ip ip-prefix prefix-from-RTA index 1 permit 10.1.1.0 24
[Sysname] ip ip-prefix prefix-from-RTA index 2 permit 10.2.1.0 24
advertise-label ip-prefix ip-prefix-name [ peer peer-ip-prefix-name ]
undo advertise-label ip-prefix ip-prefix-name
【缺省级别】
2:系统级
peer-ip-prefix-name:IP地址前缀列表名,为1~19个字符的字符串。指定Peer LSR ID列表。
【描述】
advertise-label命令用来控制指定的地址前缀是否向指定的LDP PEER通告标签映射。undo advertise-label命令用来删除配置。
缺省情况下,为满足水平分割的所有前缀向所有LDP PEER通告标签映射。
需要注意的是当LSR准备好为地址前缀通告标签映射时,LSR按照下面的规则来判断是否向指定的PEER通告标签映射:
l              如果准备通告的标签映射的IP地址前缀不通过IPv4 address ip-prefix检查,标签映射不向任何peer通告。
l              如果准备通告的标签映射的IP地址前缀通过IPv4 address ip-prefix检查,但Peer LSR ID ip-prefix为空,标签映射向所有peer通告。
l              如果准备通告的标签映射的IP地址前缀通过IPv4 address ip-prefix检查,并且Peer LSR ID ip-prefix不为空,标签映射只向通过Peer LSR ID ip-prefix检查的所有peer通告。
l              如果准备通告的标签映射的IP地址前缀通过多于一个IPv4 address ip-prefix(来自多条命令的)检查,以第一条advertise-label命令为准。
# 配置出站标签过滤策略,只通告网段地址10.1.1.0/24和10.2.1.0/24的标签映射,且只向LDP PEER(LSR ID 为3.3.3.9和4.4.4.9)通告。
[Sysname] mpls ldp
[Sysname-mpls-ldp] advertise-label ip-prefix prefix-to-CD peer to-peer-CD
[Sysname] ip ip-prefix prefix-to-CD index 1 permit 10.1.1.0 24
[Sysname] ip ip-prefix prefix-to-CD index 2 permit 10.2.1.0 24
[Sysname] ip ip-prefix to-peer-CD index 1 permit 3.3.3.9 32
[Sysname] ip ip-prefix to-peer-CD index 2 permit 4.4.4.9 32
display mpls ilm [ label ] [ slot slot-number ] [ include text ]
【缺省级别】
1:监控级
label:显示指定入标签的ILM表项,取值范围为16~4294967295。
include text:显示含有指定字符串的ILM表项。text为用户指定的字符串。
slot slot-number显示指定槽号上的ILM表项。slot-number为槽位号。
【描述】
display mpls ilm命令用来显示ILM表的信息。
如果不指定入标签,将显示所有标签的ILM表项信息。
# 显示指定入标签的ILM表项。
<Sysname> display mpls ilm 1024
Inlabel In-Interface        Token   VRF-Index Oper   LSP-Type      Swap-Label
1024    Vlan2               2         0       POP   NORMAL        ----
# 显示所有ILM表项。
表1-1 display mpls ilm命令显示信息描述表
Inlabel
入标签
In-Interface
入接口
Token
NHLFE表项索引
VRF-Index
VRF索引
Oper
操作类型
LSP-Type
LSP类型
Swap-Label
交换标签
display mpls interface [ interface-type interface-number ] [ verbose ]
【缺省级别】
1:监控级
verbose:显示详细信息。
【描述】
display mpls interface命令用来显示使能了MPLS能力的接口的信息。
l              如果不指定任何参数,则显示所有使能了MPLS能力的接口的简要信息;
l              如果只指定interface-type interface-number,则显示指定使能了MPLS能力的接口的简要信息。
相关配置可参考命令display mpls statistics interfacempls
# 显示所有使能了MPLS能力的接口的信息。
<Sysname> display mpls interface
Interface   Status     TE Attr    LSP Count   CRLSP Count
Vlan1         Up         En         0           0
Vlan2         Up         En         0           0
# 显示指定的使能了MPLS能力的接口的详细信息。
<Sysname> display mpls interface vlan-interface 2 verbose
No             : 1
Interface      : Vlan2
Status         : Down
TE Attribute   : Disable
LSPCount       : 0
CR-LSPCount    : 0
FRR            : Disabled
表1-2 display mpls interface命令显示信息描述表
No
序号
接口简要名称
Status
接口状态
TE Attr/TE Attribute
接口上是否使能TE
LSPCount
接口上LSP条数
CR-LSPCount
接口上CR-LSP条数
FRR
是否使能FRR(快速重路由),如果使能了FRR,还将显示绑定的隧道
有关FRR的介绍请参见“MPLS分册”中的“MPLS TE配置”。
display mpls label { label-value1 [ to label-value2 ] | all }
【缺省级别】
1:监控级
label-value1:显示指定标签的使用状态。当与label-value2一起使用时,表示标签范围的开始,取值范围为16~8191。
to label-value2:标签范围的结束,label-value2的取值范围为16~8191。
all:显示所有标签信息。
【描述】
display mpls label命令用来显示MPLS标签信息。
# 显示指定范围内标签的使用状态。
<Sysname> display mpls label 900 to 1500
Label alloc state: '.' means not used, '$' means used
------------------------------Static Label--------------------------------
900:........ ........ ........ ........  ........ ........ ........ ........
964:........ ........ ........ ........  ........ ........ ........ ....
------------------------------Dynamic Label-------------------------------
1024:...$.... ........ ........ ........  ........ ........ ........ ........
1088:........ ........ ........ ........  ........ ........ ........ ........
1152:........ ........ ........ ........  ........ ........ ........ ........
1216:........ ........ ........ ........  ........ ........ ........ ........
1280:........ ........ ........ ........  ........ ........ ........ ........
1344:........ ........ ........ ........  ........ ........ ........ ........
1408:........ ........ ........ ........  ........ ........ ........ ........
1472:........ ........ ........ .....
表1-3 display mpls label命令显示信息描述表
Label alloc state
标签分配状态
'.' means not used
‘.’表示没有使用
'$' means used
‘$’表示已经使用
Static Label
静态标签
Dynamic Label
动态标签
display mpls ldp [ all [ verbose ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all所有LDP信息。
verbose:显示详细信息。
|:使用正则表达式对显示进行过滤。有关正则表达式的详细介绍,请参见“系统分册/系统基本配置操作”中的“命令行显示”一节。
begin:显示特定行及其以后的所有行,该特定行必须包含指定正则表达式。
exclude:显示不包含指定正则表达式的所有行。
include:显示只包含指定正则表达式的所有行。
regular-expression:表示正则表达式,为1~80个字符的字符串,区分大小写。
【描述】
display mpls ldp命令用来显示LDP信息。
如果不指定参数,将显示所有LDP的详细信息。
相关配置可参考命令mpls ldp
# 显示所有LDP详细信息。
<Sysname> display mpls ldp all verbose
                           LDP Global Information
 Protocol Version        : V1           Neighbor Liveness    : 60 Sec
 Graceful Restart        : Off          FT Reconnect Timer   : 60 Sec
 MTU Signaling           : Off          Recovery Timer       : 60 Sec
                          LDP Instance Information
 Instance ID            : 0          VPN-Instance         :
 Instance Status        : Active     LSR ID               : 1.1.1.1
 Hop Count Limit        : 32         Path Vector Limit    : 32
 Loop Detection         : Off
 DU Re-advertise Timer  : 30 Sec     DU Re-advertise Flag : On
 DU Explicit Request    : Off        Request Retry Flag   : On
 Label Distribution Mode: Ordered    Label Retention Mode : Liberal
表1-4 display mpls ldp命令显示信息描述表
LDP全局信息
Protocol Version
LDP的协议版本
Neighbor Liveness
GR的邻居存活定时器间隔
Graceful Restart
是否使能Graceful Restart功能
FT Reconnect Timer
GR的重接定时器间隔
Recovery Timer
GR的恢复定时器间隔
MTU Signaling
是否支持MTU信令,目前设备不支持MTU信令
LDP实例信息
Instance ID
LDP实例序号
VPN-Instance
使能LDP能力的VPN实例的名称,如果是缺省的VPN实例,显示为空
Instance Status
LDP实例状态
LSR ID
LSR的标识符
Hop Count Limit
配置的跳次计数限制值
Loop Detection
是否使能环路
Path Vector Limit
配置的路径向量限制值
是否使能DU重新发布功能
DU重新发布定时器的间隔值
Request Retry Flag
是否使能重发送请求功能
DU Explicit Request
是否使能DU会话方式发送显式请求消息功能
此实例配置的标签保持方式
此实例配置的标签分布控制方式
display mpls ldp cr-lsp [ lspid lsr-id lsp-id ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
lspid:指定CR-LSP的标识符。
lsr-id:LSR的标识符,IP地址形式。
lsp-id:Ingress节点的本地LSP的标识符,取值范围为0~65535。
【描述】
display mpls ldp cr-lsp命令用来显示CR-LDP创建的CR-LSP信息。
相关配置可参考命令display mpls lsp
# 显示CR-LDP创建的CR-LSP信息。
<Sysname> display mpls ldp cr-lsp
        Displaying All LDP CR-LSP(s) for public network
 CR-LSP ID      DestAddress/Mask   In/OutLabel  In/Out-Interface
 1.1.1.9:0       2.2.2.9/32         NULL/1027    -------/Vlan2
 2.2.2.9:0       1.1.1.9/32         1027/NULL    Vlan2/-------
The Total LDP CR-LSP(s): 2
表1-5 display mpls ldp cr-lsp命令显示信息描述表
CR-LSP ID
指定基于约束路由的LSP标识符
DestAddress/Mask
FEC的目的地址和掩码
In/OutLabel
入/出标签值
In/Out-Interface
该CR-LSP的入接口/出接口名称
display mpls ldp fec [ vpn-instance vpn-instance-name ] dest-addr mask-length
【缺省级别】
1:监控级
vpn-instance vpn-instance-name:显示指定VPN实例的标签通告信息。vpn-instance-name表示VPN实例名称,为1~31字符的字符串,区分大小写。
dest-addr:目的地址。
mask-length:目的地址的掩码长度,取值范围为0~32。
【描述】
display mpls ldp fec命令用来显示指定FEC的标签通告信息。
# 显示指定FEC的标签通告信息。
<Sysname> display mpls ldp fec 3.3.3.9 32
                            LDP FEC Information
 Label Advertisement Policy:
 FEC IP-prefix     : prefix-from-rt1
 Peer IP-prefix    : peer-to-rt2
 Upstream Info:
 No.               : 1
 Upstream peer     : NULL
 Stale             : No
 Label Request ID  : NULL
 Label Space ID    : 0
 FEC Type          : Generic
 Incomming Label   : NULL
 State             : Estatblished
 Hop Count         : 1
 Path Vector Count : 0
 Path Vector       : NULL
 Downstream Info:
 No.               : 1
 Downstream Peer   : 2.2.2.9
 Stale             : No
 Label Type        : Generic
 Outgoing Label    : 1036
 Hop Count         : 2
 Path Vector Count : 1
 Path Vector       : 2.2.2.9
 Received MTU      : 1500
 OutIfCount        : 2
 OutGoing Info     : Interface                  Nexthop
                     Vlan200                    21.21.21.2
                     Vlan100                    12.12.12.2
表1-6 display mpls ldp fec命令显示信息描述表
Upstream Info
上游信息
Downstream Info
下游信息
No.
编号
Upstream peer
上游对等体
Downstream Peer
下游对等体
Stale
是否处于GR期间
Label Request ID
标签请求消息的标识符
Label Space ID
标签空间标识符
Label Type
标签类型,目前只支持Generic
FEC Type
FEC类型
Incomming Label
入标签值
Outgoing Label
出标签值
当前状态
Hop Count
跳数值
Path Vector Count
路径向量中包括的LSR数目
Path Vector
路径向量
Received MTU
最大传输单元
OutIfCount
出接口数目
OutGoing Info
出方向信息
出接口
Nexthop
下一跳地址
标签通告控制策略信息
FEC IP-prefix
检查FEC的IP地址前缀列表
Peer IP-prefix
检查Peer LSR ID的IP地址前缀列表
display mpls ldp interface [ all [ verbose ] | [ vpn-instance vpn-instance-name ] [ interface-type interface-number | verbose ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:显示所有信息。
verbose:显示详细信息。
vpn-instance vpn-instance-name:VPN实例的名字,为1~31个字符的字符串,区分大小写。
【描述】
display mpls ldp interface命令用来显示使能了LDP能力的接口信息。
相关配置可参考命令mpls ldp (System view)和mpls ldp (Interface view)。
# 显示使能了LDP的接口信息。
<Sysname> display mpls ldp interface
     LDP Interface Information in Public Network
 IF-Name         Status       LAM   Transport-Address   Hello-Sent/Rcv
 Vlan2           Inactive     DU    1.1.1.1             0/0
 LAM: Label Advertisement Mode         IF-Name: Interface name
# 显示所有接口的详细信息。
<Sysname> display mpls ldp interface verbose
 Interface Name : Vlan-interface2
 LDP ID         : 1.1.1.1:0             Transport Address : 1.1.1.1
 Entity Status  : Active                Interface MTU     : 1500
 Configured Hello Timer     : 15 Sec
 Negotiated Hello Timer     : 15 Sec
 Configured Keepalive Timer : 45 Sec
 Label Advertisement Mode   : Downstream Unsolicited
 Hello Message Sent/Rcvd    : 591/1033 (Message Count)
表1-7 display mpls ldp interface命令显示信息描述表
Interface Name
使能了LDP的接口名称
LDP ID
LDP的标识符
Transport Address
实体的传输地址,也用做TCP连接终端地址
Entity Status
实体状态:激活或非激活
Interface MTU
接口的最大传输单元
配置的Hello定时器时间
协商的Hello定时器时间
配置的Keepalive定时器时间
标签发布方式,目前取值只能为DU
Hello Message Sent/Rcvd [X/Y]
X:此接口发出的Hello消息数目
Y:此接口接收的Hello消息数目
display mpls ldp lsp [ all | [ vpn-instance vpn-instance-name ] [ destination-address mask-length ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all显示所有信息。
dest-addr:建立LSP的目的地址。
mask-length:地址掩码长度,取值范围为0~32。
【描述】
display mpls ldp lsp命令用来显示LDP创建的LSP相关信息。
# 显示LDP创建LSP信息。
<Sysname> display mpls ldp lsp
                              LDP LSP Information
 SN     DestAddress/Mask   In/OutLabel   Next-Hop        In/Out-Interface
 1      1.1.1.1/32         3/NULL        127.0.0.1        -------/InLoop0
 2      10.1.1.0/24        3/NULL        10.1.1.1         -------/Vlan10
*3      100.1.1.1/32       Liberal(1025)
A '*' before an LSP means the LSP is not established
A '*' before a Label means the USCB or DSCB is stale
表1-8 display mpls ldp lsp命令显示信息描述表
SN
该LSP的序号。SN前面如果有“*”表示未建立LSP
DestAddress/Mask
该LSP的FEC目的地址和掩码
In/OutLabel
入/出标签值。In/OutLabel前面如果有“*”表示该LSP处于GR过程中。Liberal(X),表示不可用LSP,标签值为X
Next-Hop
下一跳地址
In/Out-Interface
入接口与出接口
display mpls ldp peer [ all [ verbose ] | [ vpn-instance vpn-instance-name ] [ peer-id | verbose ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all显示所有对等体信息。
verbose:显示详细信息。
vpn-instance vpn-instance-name:VPN实例的名字。使用此参数显示指定VPN实例的所有对等体信息,为1~31字符的字符串,区分大小写。
peer-id:对等体的LSR ID。
【描述】
display mpls ldp peer命令用来显示对等体的信息。
相关配置可参考命令mpls ldp
# 显示对等体的信息。
<Sysname> display mpls ldp peer
         LDP Peer Information in Public network
 Total number of peers: 3
 Peer-ID                Transport-Address  Discovery-Source
 172.17.1.2:0           172.17.1.2         Vlan-interface1
 168.1.1.1:0            168.1.1.1          Vlan-interface2
 100.10.1.1:0           100.10.1.1         Vlan-interface3
表1-9 display mpls ldp peer命令显示信息描述表
对等体的数量
Peer-ID
对等体的LDP标识符
Transport-Address
对等体的传输地址
Discovery-Source
此对等体的发现源
# 显示对等体的详细信息。
<Sysname> display mpls ldp peer verbose
 Peer LDP ID         : 172.17.1.2:0
 Peer Max PDU Length : 4096            Peer Transport Address : 172.17.1.2
 Peer Loop Detection : Off             Peer Path Vector Limit : 0
 Peer FT Flag        : Off             Peer Keepalive Timer   : 45 Sec
 Recovery Timer      : ----            Reconnect Timer        : ----
 Peer Label Advertisement Mode : Downstream Unsolicited
 Peer Discovery Source         : Vlan-interface1
 Peer LDP ID         : 168.1.1.1:0
 Peer Max PDU Length : 4096            Peer Transport Address : 168.1.1.1
 Peer Discovery Source         : Vlan-interface2
 Peer LDP ID         : 100.10.1.1:0
 Peer Max PDU Length : 4096            Peer Transport Address : 100.10.1.1
 Peer Discovery Source         : Vlan-interface3
表1-10 display mpls ldp peer verbose命令显示信息描述表
Peer LDP ID
对等体的LDP标识符
Peer Max PDU Length
对等体最大PDU长度
对等体的传输地址
Peer Loop Detection
对等体是否使能环路检测功能
对等体的路径向量限制值
Peer FT Flag
对等体是否使能GR FT功能
对等体Keepalive定时器时间
Recovery Timer
GR的恢复定时器间隔
Reconnect Timer
GR的重接定时器间隔
对等体标签发布方式
此对等体的发现源
display mpls ldp remote-peer [ remote-name remote-peer-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
remote-name remote-peer-name:远端对等体的名称,为1~32字符的字符串,不区分大小写。
【描述】
display mpls ldp remote-peer命令用来显示远端对等体信息。
相关配置可参考命令mpls ldpremote-ip
# 显示指定远端对等体名称为BJI的信息。
<Sysname> display mpls ldp remote-peer remote-name BJI
                        LDP Remote Entity Information
 Remote Peer Name  : BJI
 Remote Peer IP    : 3.3.3.3          LDP ID : 1.1.1.1:0
 Configured Hello Timer     : 45 Sec
 Negotiated Hello Timer     : 45 Sec
 Hello Message Sent/Rcvd    : 3/2 (Message Count)
表1-11 display mpls ldp remote-peer命令显示信息描述表
LDP远端对等体的信息
Remote Peer Name
此远端对等体的名称
Remote Peer IP
远端对等体的IP地址
LDP ID
本地LDP的标识符
Transport Address
此远端对等体的传输地址
配置的Keepalive定时器时间
配置的Hello定时器时间
协商的Hello定时器时间
远端对等体发送/接收的Hello消息数
display mpls ldp session [ all [ verbose | statistics ] | [ vpn-instance vpn-instance-name ] [ peer-id | verbose ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:显示所有信息。
statistics:显示处于不同状态(Non-Existent/Initialized/Open-Received/Open-Sent/
Operational)的LDP会话统计信息。
verbose:显示详细信息。
vpn-instance vpn-instance-name:VPN实例的名字。使用此参数显示指定VPN的所有LDP会话信息,为1~31字符的字符串,区分大小写。
peer-id:对等体的LSR ID。
【描述】
display mpls ldp session命令用来显示对等体间会话信息。
如果不指定任何参数,则只显示所有公网LDP对等体间的会话信息。
相关配置可参考命令mpls ldp
# 显示所有公网LDP对等体间的会话信息。
<Sysname> display mpls ldp session
               LDP Session(s) in Public Network
 Total number of sessions: 1
 Peer-ID            Status        LAM  SsnRole  FT   MD5  KA-Sent/Rcv
 1.1.1.1:0          Operational   DU   Active   Off  Off  4582/4582
 LAM : Label Advertisement Mode         FT  : Fault Tolerance
表1-12 display mpls ldp session命令显示信息描述表
会话的数量
Peer-ID
对等体LDP标识符
Status
会话的状态
LAM
会话的标签发布方式
SsnRole
本地LSR在会话中的角色,取值为active和passive
FT
对等体是否使能会话的GR FT功能
MD5
对等体是否使能MD5密码特性
KA-Sent/Rcv
会话过程中,本地LSR发送或接收的keepalive消息数
# 显示所有公网LDP对等体间会话的详细信息。
<Sysname> display mpls ldp session verbose
 Peer LDP ID     : 1.1.1.1:0            Local LDP ID   : 3.3.3.3:0
 TCP Connection  : 3.3.3.3 -> 1.1.1.1
 Session State   : Operational          Session Role   : Active
 Session FT Flag : Off                  MD5 Flag       : Off
 Reconnect Timer : ---                  Recovery Timer : ---
 Negotiated Keepalive Timer        : 45 Sec
 Keepalive Message Sent/Rcvd       : 6/6 (Message Count)
 Label Resource Status(Peer/Local) : Available/Available
 Peer Discovery Mechanism          : Extended
 Session existed time              : 000:00:01  (DDD:HH:MM)
 LDP Extended Discovery Source     : Remote peer: 1
 Addresses received from peer: (Count: 2)
 10.1.1.1            1.1.1.1
 Peer LDP ID     : 2.2.2.2:0            Local LDP ID   : 3.3.3.3:0
 TCP Connection  : 3.3.3.3 -> 2.2.2.2
 Keepalive Message Sent/Rcvd       : 25/25 (Message Count)
 Peer Discovery Mechanism          : Basic
 Session existed time              : 000:00:06  (DDD:HH:MM)
 LDP Basic Discovery Source        : Ethernet1/1
 Label Acceptance Policy           : prefix-from-rt1
 Addresses received from peer: (Count: 3)
 10.1.1.2            20.1.1.1            2.2.2.2
表1-13 display mpls ldp session verbose命令显示信息描述表
Peer LDP ID
对等体LDP标识符
Local LDP ID
本地LDP标识符
TCP connection
该会话的TCP连接信息
Session State
会话的状态
Session Role
本地LSR在会话中的角色,取值为active(主动)和passive(被动)
Session FT Flag
对等体是否使能会话的GR FT功能
MD5 Flag
对等体是否使能MD5密码特性
Reconnect Timer
GR的重接定时器间隔
Recovery Timer
GR的恢复定时器间隔
Negotiated Keep Alive Timer
协商的Keepalive定时器时间
Keepalive Message Sent/Rcvd [X/Y]
X:会话过程中,本地LSR发送的keepalive消息数
Y:会话过程中,本地LSR接收的keepalive消息数
该会话的标签发布方式
对等体与本地的标签资源状态
对等体的发现机制,取值为Basic和Extended
Session持续时间
Session建立的接口,取值为基本发现时显示为接口名称,扩展发现时显示为远端对等体名称
该会话中,对等体发送的地址表
标签接受控制策略
# 显示所有LDP对等体间会话的统计信息。
<Sysname> display mpls ldp session all statistics
Total number of sessions : 1024
Session(s) in Non-Existent state  : 100
Session(s) in Initialized state   : 200
Session(s) in Open-Received state : 400
Session(s) in Open-Sent state     : 300
Session(s) in Operational state   : 24
表1-14 display mpls ldp session all statistics命令显示信息描述表
当前创建的LDP会话个数统计值
当前处于Non-Existent 状态的LDP会话个数统计值
当前处于Initialized 状态的LDP会话个数统计值
当前处于Open-Received状态的LDP会话个数统计值
当前处于Open-Sent状态的LDP会话个数统计值
当前处于Operational状态的LDP会话个数统计值
display mpls ldp vpn-instance vpn-instance-name [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
vpn-instance-name:指定使能LDP能力的VPN实例名称,为1~31字符的字符串,区分大小写。
【描述】
display mpls ldp vpn-instance命令用来显示指定LDP实例的信息。
相关配置可参考命令mpls ldp
# 显示名为vpn1的LDP实例的信息。
<Sysname> display mpls ldp vpn-instance vpn1
 Instance ID             : 1            VPN-Instance         : vpn1
 Instance Status         : Active       LSR ID               : 1.1.1.9
 Label Distribution Mode : Ordered      Label Retention Mode : Liberal
display mpls ldp vpn-instance命令显示信息描述表同1-4  display mpls ldp命令显示信息描述
display mpls lsp [ incoming-interface interface-type interface-number ] [ outgoing-interface interface-type interface-number ] [ in-label in-label-value ] [ out-label out-label-value ] [ asbr | [ vpn-instance vpn-instance-name ] [ protocol { bgp | bgp-ipv6 | crldp | ldp | rsvp-te | static | static-cr } ] ] [ egress | ingress | transit ] [ { exclude | include } dest-addr mask-length ] [ verbose ]
【缺省级别】
1:监控级
incoming-interface interface-type interface-number:LSP的入接口。interface-type interface-number为接口类型和接口编号。
outgoing-interface interface-type interface-number:LSP的出接口。interface-type interface-number为接口类型和接口编号。
in-label in-label-value:入标签值,取值范围为0~1048575。
out-label out-label-value:出标签值,取值范围为0~1048575。
asbr:显示ASBR产生的LSP信息。
vpn-instance vpn-instance-name:指定使能LDP能力的VPN实例名称,为1~31字符的字符串,区分大小写。
protocol:根据建立LSP的协议类型显示LSP信息。
bgp:显示BGP LSP信息。
bgp-ipv6:显示IPv6 BGP(即BGP4+协议)LSP信息。
crldp:显示基于约束路由的LDP CR-LSP信息。目前暂不支持该参数。
ldp:显示LDP LSP信息。
rsvp-te:显示RSVP-TE产生的CR-LSP信息。
static:显示通过手工配置的静态LSP信息。
static-cr:显示通过手工配置的静态CR-LSP信息。
egress:显示出节点的LSP信息。
ingress:显示入节点的LSP信息。
transit:显示中间节点的LSP信息。
exclude:显示不包含指定FEC的LSP信息。
include:显示包含指定FEC的LSP信息。
dest-addr:目的地址。
verbose:显示详细信息。
【描述】
display mpls lsp命令用来显示LSP信息。
如果不指定任何参数,将显示所有LSP的信息。
相关配置可参考命令display mpls lspdisplay mpls statistics lspdisplay mpls static-lsp
此命令支持的接口类型为VLAN接口(Vlan-interface)。
# 显示所有LSP信息。
<Sysname> display mpls lsp
                 LSP Information: L3VPN LSP
FEC              In/Out Label  In/Out IF Route-Distinguisher   Vrf Name
100.1.1.1/32     1025/1024     -/-       100:1                 ASBRLSP
                 LSP Information: LDP LSP
FEC              In/Out Label  In/Out IF                       Vrf Name
100.10.1.0/24    3/NULL        -/-
168.1.0.0/16     3/NULL        -/-
172.17.0.0/16    3/NULL        -/-
表1-15 display mpls lsp命令显示信息描述表
FEC
转发等价类,包括两种形式:
l      IP地址/掩码:表示根据目的地址分配标签
l      IP地址:表示根据下一跳地址分配标签
In/Out Label
入/出标签值
In/Out IF
入/出接口简称
Route-Distinguisher
路由标识符
Vrf Name
VPN实例名称
# 显示所有LSP的详细信息。
<Sysname> display mpls lsp verbose
                 LSP Information: BGP LSP
  No.                  :  4
  VrfIndex            :  vpn1
  FEC                 :  56.10.10.2
  Nexthop             :  -------
  In-Label            :  1024
  Out-Label           :  NULL
  In-Interface        :  ----------
  Out-Interface       :  ----------
  LspIndex            :  5121
  Tunnel ID           :  0x0
  LsrType             :  Egress
  Outgoing Tunnel ID  :  0x0
  Label Operation     :  POP
  No.                  :  1
  VrfIndex            :
  Fec                 :  1.1.1.9/32
  Nexthop             :  127.0.0.1
  In-Label            :  3
  Out-Label           :  NULL
  In-Interface        :  Vlan-interface3
  LspIndex            :  10241
  Tunnel ID           :  0x0
  LsrType             :  Egress
表1-16 display mpls lsp命令显示信息描述表
No.
序号
VrfIndex
VPN实例索引
Fec
转发等价类,包括两种形式:
Nexthop
下一条路由地址
In-Label
入标签值
Out-Label
出标签值
In-Interface
入接口
Out-Interface
出接口
LspIndex
LSP索引
Tunnel ID
标记(公网)
LsrType
LSR类型
Outgoing Tunnel ID
标记(跨域VPN)
【缺省级别】
1:监控级
【描述】
display mpls lsp statistics命令用来显示LSP的统计信息。
# 显示LSP统计信息。
<Sysname> display mpls lsp statistics
Lsp Type       Total     Ingress   Transit   Egress
STATIC LSP     1         1         0         0
STATIC CRLSP   1         1         0         0
LDP LSP        0         0         0         0
CRLDP CRLSP    0         0         0         0
RSVP CRLSP     1         1         0         0
BGP LSP        0         0         0         0
ASBR LSP       0         0         0         0
BGP IPV6 LSP   0         0         0         0
LSP            1         1         0         0
表1-17 display mpls lsp statistics命令显示信息描述表
Lsp Type
LSP的类型,具体类型请参见表1-18
LSP
所有LSP的相关节点的数量
CRLSP
所有CR-LSP的相关节点的数量
Total
该设备作为各种不同类型节点的对应LSP数量
Ingress
该设备作为入节点LSP数量
Transit
该设备作为中间节点LSP数量
Egress
该设备作为出节点LSP数量
表1-18 LSP类型表
STATIC LSP
静态LSP
STATIC CRLSP
静态CR-LSP
LDP LSP
LDP生成的LSP
CRLDP CRLSP
CR-LDP生成的CR-LSP
RSVP CRLSP
RSVP生成的CR-LSP
BGP LSP
BGP生成的LSP
ASBR LSP
ASBR生成的LSP
BGP IPV6 LSP
IPv6 BGP生成的LSP
WX6100E系列无线控制器以太网交换机暂不支持CR-LDP生成的CR-LSP。
display mpls nhlfe [ token ] [ slot slot-number ] [ include text ]
【缺省级别】
1:监控级
token:NHLFE表项索引,取值范围为0~102399。
include text:显示含有指定字符串的NHLFE表项。text为用户指定的字符串。
slot slot-number显示指定槽号上的NHLFE表项。slot-number为槽位号。
【描述】
display mpls nhlfe命令用来查看NHLFE表的信息。
如果不指定token参数,将显示所有NHLFE表项信息。
# 显示指定的NHLFE表项。
<Sysname> display mpls nhlfe 2
Out-Interface       Token      Oper     Nexthop         Deep Stack
Vlan2                  2       PUSH     88.1.1.2        1    1024
# 显示所有NHLFE表项。
表1-19 display mpls nhlfe命令显示信息描述表
Out-Interface
出接口
Token
NHLFE表项索引
Oper
操作类型
Nexthop
下一跳
Deep
MPLS标签栈深度
Stack
MPLS标签值
display mpls nhlfe reflist token [ slot slot-number ]
【缺省级别】
1:监控级
token:NHLFE表项索引,取值范围为0~4095。
slot slot-number:显示指定槽号上的NHLFE表项使用情况。slot-number为槽位号。
【描述】
display mpls nhlfe reflist命令用来显示NHLFE表项的使用情况。
# 显示指定NHLFE表项的使用情况。
<Sysname> display mpls nhlfe reflist 11
No.     Type            Key-Info
1       ILM             1023(Inlabel)         Vlan10(In-If)
2       FTN             1(VPN ID)             2.2.2.2/32
3       LPW             ----(SRV ID)          Vlan20(Private-If)
4       VPW             1(VSI ID)             1(Link ID)
5       FRR             11(Token)             ----
表1-20 display mpls nhlfe reflist命令显示信息描述表
No.
编号
关联节点的类型
Key-Info
表项的关键参数
表1-21 关联节点类型及关键参数对应表
类型
关键参数
FTN
前缀类型FEC到NHLFE的映射
l      VPN ID:VPN实例ID
l      地址前缀/掩码
ILM
入标签映射
l      In-Label:入标签
l      In-If:入接口
LPW
VPWS PW发送方向表项
l      SRV ID:服务实例ID
l      Private-If:私网接口
VPW
VPLS PW发送方向表项
l      VSI ID:虚交换实例ID
l      Link ID:链路ID
FRR
FRR的主NHLFE
Token:主NHLFE的Token
display mpls route-state [ vpn-instance vpn-instance-name ] [ dest-addr mask-length ]
【缺省级别】
1:监控级
vpn-instance vpn-instance-name:VPN实例的名称,为1~31字符的字符串,区分大小写。
dest-addr:目的IP地址。
【描述】
display mpls route-state命令用来显示路由的LSP相关信息。
如果不指定VPN实例,将显示公网实例的路由信息;如果不指定目的地址和掩码,将显示所有路由信息。
# 显示所有路由的LSP相关信息。
<Sysname> display mpls route-state
DEST/MASK   NEXT-HOP    OUT-INTERFACE  STATE LSP-COUNT  VPN-INDEX
1.1.1.1/32  10.0.0.1    Vlan2           ESTA  1           0
表1-22 display mpls route-state命令显示信息描述表
DEST/MASK
指定路由的目的地址和掩码
NEXT-HOP
指定路由的下一跳地址
OUT-INTERFACE
指定路由的出接口
STATE
指定路由的状态
LSP-COUNT
LSP的数量
VPN-INDEX
VPN实例索引
display mpls static-lsp [ lsp-name lsp-name ] [ { exclude | include } dest-addr mask-length ] [ verbose ]
【缺省级别】
1:监控级
lsp-name lsp-name:标签转发路径的名称,为1~15字符的字符串。
exclude:匹配不包含指定FEC的LSP信息。
include:匹配包含指定FEC的LSP信息。
dest-addr:目的地址。
verbose:使用此参数显示详细信息。
【描述】
display mpls static-lsp命令用来显示静态LSP的信息。
# 显示静态LSP的简要信息。
<Sysname> display mpls static-lsp
Name       FEC               I/O Label  I/O If                 State
lsp1       3.3.3.9/32        NULL/100   -/Vlan1                Up
表1-23 display mpls static-lsp命令显示信息描述表
Name
LSP名称
FEC
转发等价类
I/O Label
入/出标签值
I/O If
入接口/出接口名称
LSP当前的状态
# 显示静态LSP的详细信息。
<Sysname> display mpls static-lsp verbose
No             : 1
LSP-Name       : lsp1
LSR-Type       : Ingress
FEC            : 3.3.3.9/32
In-Label       : NULL
Out-Label      : 100
In-Interface   : -
Out-Interface  : Vlan-interface1
NextHop        : 30.1.1.2
Static-Lsp Type: IPTN
Lsp Status     : Up
表1-24 display mpls static-lsp命令显示信息描述表
No
序号
LSP-Name
LSP名称
LSR-Type
LSR的类型,取值为ingress、transit和egress
FEC
转发等价类
In-Label
入标签值
Out-Label
出标签值
In-Interface
入接口名称
Out-Interface
出接口名称
NextHop
下一跳地址
Static-Lsp Type
Static LSP类型
Lsp Status
LSP当前状态
display mpls statistics interface { interface-type interface-number | all }
【缺省级别】
1:监控级
all:显示所有接口的统计信息。
【描述】
display mpls statistics interface命令用来根据使能MPLS能力的接口显示MPLS统计信息。
需要注意的是,如果要显示统计信息,请先设置统计信息的时间间隔,缺省的时间间隔为0,即不统计信息。这种情况下显示出来的各项统计信息都为0。
相关配置可参考命令statistics interval
# 根据使能MPLS能力的接口显示MPLS统计信息。
<Sysname> display mpls statistics interface all
  Statistics for Interface IN :
  Incoming Interface Vlan-interface1
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
       Failed Label Lookup     : 0
       Start Time              : 2008/04/28  10:23:55
       End Time                : 2008/04/28  10:23:55
  Statistics for Interface OUT :
  Outgoing Interface Vlan-interface2
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
  Incoming Interface Vlan-interface3
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
       Start Time              : 2008/04/28  10:24:04
       End Time                : 2008/04/28  10:24:04
  Outgoing Interface Vlan-interface4
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
  Incoming Interface Vlan-interface53
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
       Start Time              : 2008/04/28  10:24:10
       End Time                : 2008/04/28  10:24:10
  Outgoing Interface Vlan-interface73
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
表1-25 display mpls statistics interface命令显示信息描述表
接口的入口处理的统计
Incoming Interface Serial2/0
入接口名称
Octets
从该接口进入的字节数
Packets
从该接口进入的报文数
Errors
从该接口进入的报文处理错误数
Disables
从该接口进入方向的MPLS的去使能次数
Failed Label Lookup
从该接口进入的报文查找标签失败次数
Start Time
从该接口进入的报文统计开始时间
End Time
从该接口进入的报文统计结束时间
接口的出口处理的统计
Outgoing Interface Serial2/0
出接口名称
Octets
从该接口发出的字节数
Packets
从该接口发出的报文数
Errors
从该接口发出的报文处理错误数
Disables
从该接口发出方向的MPLS的去使能次数
Start Time
从该接口发出的报文统计开始时间
End Time
从该接口发出的报文统计结束时间
display mpls statistics lsp { index | all | name lsp-name }
【缺省级别】
1:监控级
index:标签转发路径LSP的索引号,取值范围为0~4294967295。
all:所有标签转发路径LSP。
name lsp-name:标签转发路径LSP的名称,为1~15个字符的字符串。
【描述】
display mpls statistics lsp命令用来根据LSP显示MPLS统计信息。包括每一条LSP的入口和出口处理的字节数、报文数、错误数,丢弃报文数。
# 根据所有LSP显示MPLS统计信息。
<Sysname> display mpls statistics lsp all
Statistics for Lsp IN : LSP Name /LSP Index :  DynamicLsp/9217
   InSegment
       Octets                : 0
       Packets               : 0
       Errors                : 0
       Down                  : 0
       Start Time            : 2006/05/20  15:52:30
       End Time              : 2006/05/20  15:52:30
  Statistics for Lsp OUT : LSP Name /LSP Index :  DynamicLsp/9217
   OutSegment
       Octets                : 0
       Packets               : 0
       Errors                : 0
       Down                  : 0
       Start Time            : 0000/00/00  00:00:00
       End Time              : 0000/00/00  00:00:00
  Statistics for Lsp IN : LSP Name /LSP Index :  DynamicLsp/9218
   InSegment
       Octets                : 0
       Packets               : 0
       Errors                : 0
       Down                  : 0
  Statistics for Lsp OUT : LSP Name /LSP Index :  DynamicLsp/9218
   OutSegment
       Octets                : 0
       Packets               : 0
       Errors                : 0
       Down                  : 0
表1-26 display mpls statistics lsp命令显示信息描述表
Statistics for Lsp IN:LSP Name /LSP Index : DynamicLsp/10241
LSP的入口处理的统计,包括LSP名称(取值为动态LSP或静态LSP)和LSP索引值
InSegment
LSP的入表项信息
Octets
LSP的入口处理的字节数
Packets
LSP的入口处理的报文数
Errors
LSP的入口处理的错误数
Down
LSP的入口处理的丢弃报文数
Start Time
LSP的入口处理的统计开始时间
End Time
LSP的入口处理的统计结束时间
OutSegment
LSP的出表项信息
Octets
LSP的出口处理的字节数
Packets
LSP的出口处理的报文数
Errors
LSP的出口处理的错误数
Down
LSP的出口处理的丢弃报文数
Start Time
LSP的入口处理的统计开始时间
End Time
LSP的出口处理的统计结束时间
对于Ingress节点,不对入方向进行统计,因此,显示信息中InSegment的开始时间和结束时间都为0;Egress节点不对出方向进行统计,显示信息中OutSegment的开始时间和结束时间都为0。
du-readvertise
undo du-readvertise
【缺省级别】
1:监控级
【描述】
du-readvertise命令用来使能DU模式下标签重发布特性。undo du-readvertise命令用来禁止该特性。
缺省情况下,DU模式下已使能标签重发布特性。
# 使能公网LDP的DU模式下标签重发布特性。
[Sysname] mpls ldp
[Sysname-mpls-ldp] du-readvertise
# 使能名为vpn1的LDP实例的DU模式下标签重发布特性。
[Sysname] mpls ldp vpn-instance vpn1
[Sysname-mpls-ldp-vpn-instance-vpn1] du-readvertise
du-readvertise timer value
undo du-readvertise timer
【缺省级别】
1:监控级
value:标签重发布间隔时间,取值范围为1~65535,单位为秒。
【描述】
du-readvertise timer命令用来设置DU模式下定期重发布标签的定时器值。undo du-readvertise timer命令用来恢复缺省配置。
缺省情况下,DU模式下定期重发布标签的定时器值为30秒。
# 设置公网LDP的DU模式下定期重发布标签的定时器值为100秒。
[Sysname] mpls ldp
[Sysname-mpls-ldp] du-readvertise timer 100
# 设置名为vpn1的LDP实例的DU模式下定期重发布标签的定时器值为100秒。
[Sysname-mpls-ldp-vpn-instance-vpn1] du-readvertise timer 100
graceful-restart
undo graceful-restart
MPLS-LDP视图
【缺省级别】
1:监控级
【描述】
graceful-restart命令用来使能MPLS LDP协议的GR能力。undo graceful-restart命令用来关闭MPLS LDP协议的GR能力。
缺省情况下,MPLS LDP协议的GR能力处于关闭状态。
需要注意的是,使能或禁止GR功能会导致删除并重建所有的LDP会话,基于这些会话所创建的LSP也将被删除,并需要重建。
# 使能MPLS LDP协议的GR能力。
[Sysname] mpls lsr-id 1.1.1.1
[Sysname] mpls
[Sysname-mpls] quit
[Sysname] mpls ldp
[Sysname-mpls-ldp] graceful-restart
【缺省级别】
2:系统级
【描述】
graceful-restart mpls ldp命令用来平滑重启MPLS LDP。
l              本命令用来在不发生主备倒换的情况下测试MPLS LDP GR。正常情况下,请不要使用本命令。
l              执行本命令前需要先使能MPLS LDP GR能力。
相关配置可参考命令graceful-restart (MPLS-LDP view)。
# 平滑重启MPLS LDP。
<Sysname> graceful-restart mpls ldp
graceful-restart timer neighbor-liveness timer
undo graceful-restart timer neighbor-liveness
MPLS-LDP视图
【缺省级别】
1:监控级
timer:指定LDP邻居存活定时器值,取值范围为60~300,单位为秒。
【描述】
graceful-restart timer neighbor-liveness命令用来配置LDP邻居存活定时器值。undo graceful-restart timer neighbor-liveness命令用来恢复缺省情况。
缺省情况下,LDP邻居存活定时器的值为120秒。
l              更改邻居存活定时器的值会导致删除并重建所有的LDP会话,基于这些会话所创建的LSP也将被删除,并需要重建。
l              如果LDP会话配置了MD5认证,则需要适当增加邻居存活定时器的时长,以保证TCP连接能够重新建立。
# 配置LDP邻居存活定时器值为100秒。
[Sysname] mpls ldp
[Sysname-mpls-ldp] graceful-restart timer neighbor-liveness 100
graceful-restart timer reconnect timer
undo graceful-restart timer reconnect
MPLS-LDP视图
【缺省级别】
1:监控级
timer:指定FT重连定时器值,取值范围为60~300,单位为秒。
【描述】
graceful-restart timer reconnect命令用来配置FT重连定时器值。undo graceful-restart timer reconnect命令用来恢复缺省情况。
缺省情况下,FT重连定时器值为300秒。
l              FT重连定时器表示TCP连接失败后,LSR保留Stale标签状态的最长时间。
l              更改FT重连定时器的值会导致删除并重建所有的LDP会话,基于这些会话所创建的LSP也将被删除,并需要重建。
# 配置FT重连定时器值为100秒。
[Sysname] mpls ldp
[Sysname-mpls-ldp] graceful-restart timer reconnect 100
graceful-restart timer recovery timer
undo graceful-restart timer recovery
MPLS-LDP视图
【缺省级别】
1:监控级
timer:指定LDP恢复时间,取值范围为3~300,单位为秒。
【描述】
graceful-restart timer recovery命令用来配置LDP恢复时间。undo graceful-restart timer recovery命令用来恢复缺省情况。
缺省情况下,LDP恢复时间为300秒。
l              恢复时间表示TCP重建连接后,LSR保持Stale标签状态的最长时间。
l              更改恢复时间定时器的值会导致删除并重建所有的LDP会话,基于这些会话所创建的LSP也将被删除,并需要重建。
# 配置恢复时间为45秒。
[Sysname] mpls ldp
[Sysname-mpls-ldp] graceful-restart timer recovery 45
1.1.30  hops-count
hops-count hop-number
undo hops-count
【缺省级别】
1:监控级
hop-number:跳数值,取值范围为1~32。
【描述】
hops-count命令用来设置环路检测的最大跳数。undo hops-count命令用来恢复缺省配置。
缺省情况下,环路检测最大跳数为32。
此命令应该在所有接口LDP使能之前配置,跳数值的大小决定LSP建立过程中检测到环路的快慢程度,应根据实际的组网情况调整。
相关配置可参考命令loop-detectpath-vectors
# 设置公网LDP的环路检测的最大跳数为25。
[Sysname] mpls ldp
[Sysname-mpls-ldp] hops-count 25
# 设置名为vpn1的LDP实例的环路检测的最大跳数为25。
[Sysname-mpls-ldp-vpn-instance-vpn1] hops-count 25
label advertise { explicit-null | implicit-null | non-null }
undo label advertise
MPLS视图
【缺省级别】
2:系统级
explicit-nullEgress节点向倒数第二跳分配显式空标签,值为0
implicit-null:支持PHP特性,Egress节点向倒数第二跳分配隐式空标签,值为3
non-null:不支持PHP特性,Egress节点向倒数第二跳正常分配标签,即,分配的标签值不小于1024
【描述】
label advertise命令用来配置Egress节点向倒数第二跳弹出分配标签值。undo label advertise命令用来恢复缺省配置。
缺省情况下,支持PHP特性,Egress节点向倒数第二跳分配隐式空标签(implicit-null)。
l    选择哪种标签值需要根据倒数第二跳节点对PHP的支持情况而定。
l    会话建立后,需使用reset mpls ldp命令重启LDP会话,本命令的配置才能生效。
# 配置Egress节点向倒数第二跳分配显式空标签。
[Sysname] mpls
[Sysname-mpls] label advertise explicit-null
label-distribution { independent | ordered }
undo label-distribution
【缺省级别】
1:监控级
independent:独立标签分配控制模式,即,LSR可以在任何时间为邻居发布标签映射。
ordered:有序标签分配控制模式,即,只有当LSR收到某一特定FEC下一跳的特定标签映射消息、或者此LSR是某一特定FEC的LSP的出口节点时,LSR才向上游发送标签映射消息。
【描述】
label-distribution命令用来配置标签分配控制模式。undo label-distribution命令用来恢复缺省配置。
缺省情况下,标签分配控制模式为有序方式(ordered)。
会话建立后,需要使用reset mpls ldp命令重启LDP会话,本命令的配置才能生效。
# 配置公网LDP的标签分配控制模式为独立标签分配控制模式。
[Sysname] mpls ldp
[Sysname-mpls-ldp] label-distribution independent
# 配置名为vpn1的LDP实例的标签分配控制模式为独立标签分配控制模式。
[Sysname-mpls-ldp-vpn-instance-vpn1] label-distribution independent
1.1.33  loop-detect
loop-detect
undo loop-detect
【缺省级别】
1:监控级
【描述】
loop-detect命令用来开启环路检测功能。undo loop-detect 命令用来关闭环路检测功能。
缺省情况下,环路检测功能是关闭的。
此配置需要在所有接口LDP使能之前进行配置。
相关配置可参考命令hops-countpath-vectors
# 开启公网LDP的环路检测。
[Sysname] mpls ldp
[Sysname-mpls-ldp] loop-detect
# 开启名为vpn1的LDP实例的环路检测。
[Sysname-mpls-ldp-vpn-instance-vpn1] loop-detect
1.1.34  lsp-trigger
lsp-trigger [ vpn-instance vpn-instance-name ] { all | ip-prefix prefix-name }
undo lsp-trigger [ vpn-instance vpn-instance-name ] { all | ip-prefix prefix-name }
MPLS视图
【缺省级别】
2:系统级
vpn-instance vpn-instance-name:配置指定VPN实例的LSP触发策略。其中,vpn-instance-name为VPN实例名称,为1~31个字符的字符串,区分大小写。
all:所有FEC,即所有静态路由和IGP的路由项。
ip-prefix prefix-name:IP地址前缀列表名,为1~19个字符的字符串。
【描述】
lsp-trigger命令用来配置LSP的触发策略。undo lsp-trigger命令用来恢复缺省配置。
缺省情况下,只有32位掩码的环回地址能触发LDP来建立LSP。
l              指定all关键字时,所有静态路由和IGP路由项都会触发LDP建立LSP;
l              通过ip-prefix prefix-name指定前缀列表名时,只有通过IP地址前缀列表过滤的静态路由和IGP路由项能够触发LDP建立LSP,被IP地址前缀列表拒绝的静态路由和IGP路由项不能触发建立LSP。
l              IP地址前缀列表只对静态路由和IGP路由有效。
l              LSP的建立需要LSR上有精确匹配的路由项,如果使用32位掩码的Loopback接口,则必须有精确匹配的主机路由才能触发LSP的建立。
l              如果指定vpn-instance vpn-instance-name参数,则配置指定VPN实例的LSP触发策略;如果未指定vpn-instance vpn-instance-name参数,则配置公网路由的LSP触发策略。
l              有关IP前缀列表的介绍请参见“IP路由分册”中的“路由策略配置”。
# 设置建立LSP的所有静态路由和IGP的路由项。
[Sysname] mpls
[Sysname-mpls] lsp-trigger all
1.1.35  lsr-id
lsr-id lsr-id
undo lsr-id
【缺省级别】
1:监控级
lsr-id:LDP的LSR ID。
【描述】
lsr-id命令用来配置LDP的LSR ID。undo lsr-id命令用来删除配置的LSR ID并删除所有LDP会话。
缺省情况下,LDP的LSR ID等于MPLS LSR ID。
# 配置公网LDP的LSR ID。
[Sysname] mpls ldp
[Sysname-mpls-ldp] lsr-id 2.2.2.3
# 配置名为vpn1的LDP实例的LSR ID。
[Sysname-mpls-ldp-vpn-instance-vpn1] lsr-id 4.2.2.3
1.1.36  md5-password
md5-password { cipher | plain } peer-lsr-id password
undo md5-password peer-lsr-id
【缺省级别】
1:监控级
cipher:以密文形式显示配置的密码。
plain:以明文形式显示配置的密码。
peer-lsr-id:对等体的LSR ID,本LSR与此对等体使用相同的密码。
password:密码字符串,区分大小写。如果采用明文(plain)形式,为1~16个字符的字符串;如果采用密文(cipher)形式,既可以是为1~16个字符的明文,也可以是24个字符的密文。
【描述】
md5-password命令来用使能LDP的MD5认证。undo md5-password命令用来禁止此特性。
缺省情况下,未使能LDP的MD5认证。
配置的密码必须与对等体的配置相同。改变对等体密码会重新创建会话,与原来会话相关的LSP将被删除。
只有在相应视图中使能了MPLS LDP后,该命令才会生效。
# 配置公网LDP的明文形式显示对等体密码。
[Sysname] mpls ldp
[Sysname-mpls-ldp] md5-password plain 3.3.3.3 beijingpass
# 配置名为vpn1的LDP实例的明文形式显示对等体密码。
[Sysname-mpls-ldp-vpn-instance-vpn1] md5-password plain 3.3.3.3 beijingpass
1.1.37  mpls
mpls
undo mpls
系统视图/接口视图
【缺省级别】
2:系统级
【描述】
l              在系统视图下,mpls命令用来使能本节点的MPLS能力,并进入MPLS视图。undo mpls命令用来取消MPLS能力。
l              在接口视图下,mpls命令用来使能接口的MPLS能力。undo mpls命令用来取消接口的MPLS能力。
缺省情况下,未使能MPLS能力。
l              在使能MPLS能力之前,必须先配置LSR-ID。
l              只有在全局使能了MPLS能力后,才能在接口下使能MPLS能力。
相关配置可参考命令mpls lsr-id
# 使能MPLS能力,并进入MPLS视图。
<Sysname> System-view
[Sysname] mpls
[Sysname-mpls] quit
# 在接口Vlan-interface1上使能MPLS能力。
[Sysname-Vlan-interface1] mpls
mpls ldp [ vpn-instance vpn-instance-name ]
undo mpls ldp [ vpn-instance vpn-instance-name ]
【缺省级别】
1:监控级
vpn-instance vpn-instance-name:VPN实例名称,为1~31个字符的字符串,区分大小写。
【描述】
mpls ldp命令用来使能LDP能力。undo mpls ldp命令用来全局去使能LDP,并删除所有LDP实例。
配置了MPLS LSR ID并全局使能MPLS后,可以配置此命令。
缺省情况下,未使能LDP能力。
l              mpls ldp命令用来使能本节点的LDP能力,并进入MPLS-LDP视图。
l              mpls ldp vpn-instance命令对指定VPN实例使能LDP能力,建立LDP实例,并进入MPLS-LDP-VPN实例视图。
# 使能本节点的LDP能力,并进入MPLS-LDP视图。
[Sysname] mpls
[Sysname-mpls] quit
[Sysname] mpls ldp
[Sysname-mpls-ldp]
# 对指定VPN实例使能LDP能力,建立LDP实例,并进入MPLS-LDP-VPN实例视图。
mpls ldp
undo mpls ldp
【缺省级别】
1:监控级
【描述】
mpls ldp命令用来在接口上使能LDP能力。undo mpls ldp命令用来取消接口的LDP能力。
缺省情况下,在接口上未使能LDP能力。
使能LDP能力后,接口上将定期发送Hello报文。
在接口视图下使能LDP能力前,需要完成下列操作:
l              在系统视图下使用mpls lsr-id命令设定本节点的LSR ID。
l              在系统视图下使用mpls命令使能MPLS能力。
l              在系统视图下使用mpls ldp命令使能LDP能力。
l              在接口视图下使用mpls命令使能MPLS能力。
如果接口已与某个VPN实例绑定,则需要先使用mpls ldp vpn-instance命令在此VPN上使能LDP能力,然后才能在此接口上使能LDP能力。
目前支持的接口类型为VLAN接口(Vlan-interface)。
# 在接口Vlan-interface1上使能LDP能力。
[Sysname-Vlan-interface1] mpls ldp
mpls ldp remote-peer remote-peer-name
undo mpls ldp remote-peer remote-peer-name
【缺省级别】
1:监控级
remote-peer-name:远端对等体名称,为1~32个字符的字符串,不区分大小写。
【描述】
mpls ldp remote-peer命令用来创建远端对等体实体并进入MPLS-LDP远端对等体视图。undo mpls ldp remote-peer命令用来删除远端对等体实体。
相关配置可参考命令remote-ip
# 建立远端对等体实体BJI,并进入MPLS-LDP远端对等体视图。
[Sysname] mpls ldp remote-peer BJI
[Sysname-mpls-ldp-remote-bji]
mpls ldp timer hello-hold value
undo mpls ldp timer hello-hold
接口视图/MPLS-LDP远端对等体视图
【缺省级别】
1:监控级
value:Hello保持定时器时间,取值范围为1~65535秒。
【描述】
mpls ldp timer hello-hold命令用来配置Hello保持定时器的值。undo mpls ldp timer hello-hold命令用来恢复缺省配置。
接口视图下配置的是链路Hello保持定时器,MPLS-LDP远端对等体视图下配置的是目标Hello保持定时器。
缺省情况下,链路Hello保持定时器为15秒,目标Hello保持定时器为45秒。
修改Hello定时器的值不会影响原会话。
相关配置可参考命令mpls ldp(System view)和mpls ldp(Interface view)。
# 在接口Vlan-interface1上为本地会话配置链路Hello保持定时器时间,值为100。
[Sysname-Vlan-interface1] mpls ldp timer hello-hold 100
# 为远端会话配置目标Hello保持定时器时间,值为1000。
[Sysname-mpls-ldp-remote-bji] remote-ip 3.3.3.3
[Sysname-mpls-ldp-remote-bji] mpls ldp timer hello-hold 1000
mpls ldp timer keepalive-hold value
undo mpls ldp timer keepalive-hold
【缺省级别】
1:监控级
value:Keepalive保持定时器的值,取值范围为1~65535秒。
【描述】
mpls ldp timer keepalive-hold命令用来配置Keepalive保持定时器的值。undo mpls ldp timer keepalive-hold命令用来恢复缺省配置。
接口视图下配置的是链路Keepalive保持定时器(Link Keepalive),MPLS-LDP远端对等体视图下配置的是目标Keepalive保持定时器(Target Keepalive)。
缺省情况下,Keepalive保持定时器的值为45秒。
l    如果两个LSR之间使能LDP的链路条数超过1条(多个接口相连),所有链路的Keepalive保持时间必须相同,否则,会话可能不稳定;
l    修改Keepalive保持定时器的值会引起重新创建原始会话。基于此会话建立的LSP也将被删除重建。
# 在接口Vlan-interface1上为本地会话配置链路Keepalive保持定时器时间,值为50。
[Sysname-Vlan-interface1] mpls ldp timer keepalive-hold 50
# 为远端会话配置目标Keepalive保持定时器时间,值为1000。
[Sysname-mpls-ldp-remote-bji] mpls ldp timer keepalive-hold 1000
mpls ldp transport-address { ip-address | interface }
undo mpls ldp transport-address
【缺省级别】
1:监控级
ip-address:LDP使用此地址做为TCP传输地址。
interface:LDP使用当前接口的IP地址做为TCP传输地址。该参数只在接口视图下可选。
【描述】
mpls ldp transport-address命令用来配置LDP传输地址。undo mpls ldp transport-address命令用来恢复缺省配置。
缺省情况下,传输地址为本LSR的LSR ID。
l              在接口视图下,mpls ldp transport-address命令用于配置链路Hello的传输地址;
l              MPLS-LDP远端对等体视图下,mpls ldp transport-address命令用于配置目标Hello的传输地址。
# 在接口Vlan-interface1上为本地会话配置链路Hello的传输地址为本接口的IP地址。
[Sysname-Vlan-interface1] mpls ldp transport-address interface
# 为远端会话配置目标Hello的传输地址为10.1.1.1。
[Sysname-mpls-ldp-remote-bji] mpls ldp transport-address 10.1.1.1
1.1.44  mpls lsr-id
mpls lsr-id lsr-id
undo mpls lsr-id
【缺省级别】
2:系统级
lsr-id:LSR的ID,点分十进制格式,用于标识一个LSR。
【描述】
mpls lsr-id命令用来配置本节点的LSR ID。undo mpls lsr-id命令用来删除LSR的ID。
缺省情况下,未配置LSR ID。
配置LSR ID是配置其它MPLS命令的前提。推荐使用LSR某个Loopback接口的地址做为LSR ID。
相关配置可参考命令display mpls interface
# 配置LSR的ID为3.3.3.3。
[Sysname] mpls lsr-id 3.3.3.3
1.1.45  path-vectors
path-vectors pv-number
undo path-vectors
【缺省级别】
1:监控级
pv-number:路径向量最大值,取值范围为1~32。
【描述】
path-vectors命令用来设置路径向量最大值。undo path-vectors命令用来恢复缺省配置。
缺省情况下,路径向量值为32。
此命令应该在所有接口LDP使能之前配置。
相关配置可参考命令loop-detecthops-count
# 设置公网LDP的路径向量最大值为3。
[Sysname] mpls ldp
[Sysname-mpls-ldp] path-vectors 3
# 设置名为vpn1的LDP实例路径向量最大值为3。
[Sysname-mpls-ldp-vpn-instance-vpn1] path-vectors 3
1.1.46  ping lsp
ping lsp [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -s packet-size | -t time-out | -v ] * { ipv4 dest-addr mask-length [ destination-ip-addr-header ] | te interface-type interface-number }
【缺省级别】
0:访问级
-a source-ip:用于指定Echo Request的源地址。
-c count:指定发送请求报文的次数,取值范围为1~4294967295。
-exp exp-value:用于指定发送出一个Echo Request报文中的EXP值,指定的请求报文中的EXP值,取值范围为0~7。
-h ttl-value:用于指定发送出一个Echo Request报文中的TTL值,指定的发送请求报文中的TTL值,取值范围为1~255。
-m wait-time:指定发送出一个Echo Request报文后,发送下一个Echo Request报文的时间间隔,指定的发送报文的时间间隔,取值范围为1~10000,单位为毫秒。
-r reply-mode:用于指定接收Echo Request报文后应答模式(Reply Mode),取值范围为1和2,1表示不回应,2表示使用UDP报文回应。
-s packet-size:指定Echo Request净荷报文长度,取值范围为64-8100,单位为字节。
-t time-out:用于指定发送出Echo Request报文后等待响应的超时时间,指定的超时时间,取值范围为0~65535,单位为毫秒。
-v:用于指定显示详细的应答信息。
ipv4 dest-addr mask-length:指定LDP LSP的IPv4目的地址,mask-length为LDP LSP的IPv4目的地址的掩码,取值范围为0~32。
destination-ip-addr-header:指定发送数据包的IP头地址,该地址必须是127.0.0.0/8网段的任意地址(本机环回地址)。
te interface-type interface-number指定隧道接口类型和接口编号。
【描述】
ping lsp命令用来检测MPLS LSP的有效性和可达性。
# 指定IPv4目的地址并且发送5个测试数据包的LSP PING命令。
<Sysname> ping lsp –c 5 ipv4 3.3.3.9 32
LSP PING FEC: LDP IPV4 PREFIX 3.3.3.9/32 : 100  data bytes, press CTRL_C to break
    Reply from 100.1.2.1: bytes=100 Sequence=0 time = 31 ms
    Reply from 100.1.2.1: bytes=100 Sequence=1 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=2 time = 62 ms
    Reply from 100.2.3.1: bytes=100 Sequence=3 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=4 time = 62 ms
  --- FEC: LDP IPV4 PREFIX 3.3.3.9/32 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 31/55/62 ms
undo prefix-label advertise
MPLS-LDP远端对等体视图
【缺省级别】
2:系统级
【描述】
prefix-label advertise命令用来配置通过远端会话通告基于地址前缀的标签。undo prefix-label advertise命令用来恢复缺省情况。
缺省情况下,不会通过远端会话通告基于地址前缀的标签。
本命令的配置只决定设备是否可以通过远端会话向远端对等体通告基于地址前缀的标签。不论是否配置了通过远端会话通告基于地址前缀的标签,设备都可以接收远端对等体通告的标签。
接收到远端对等体通告的标签后,要想建立对应的LDP LSP,必须满足以下三个条件:
l              FEC的路由出接口为MPLS TE隧道接口;
l              MPLS TE隧道的目的地址、通过remote-ip命令指定的远端对等体地址、远端对等体的LSR ID,三者必须相同。
l              MPLS TE隧道接口必须使能MPLS能力。
# 配置通过远端会话通告基于地址前缀的标签。
[Sysname] mpls ldp remote-peer bji
[Sysname-mpls-ldp-remote-bji] prefix-label advertise
1.1.48  remote-ip
remote-ip ip-address
undo remote-ip
MPLS-LDP远端对等体视图
【缺省级别】
1:监控级
ip-address:远端对等体的IP地址。
【描述】
remote-ip命令用来指定LDP远端对等体的IP地址。undo remote-ip命令用来删除配置。
远端对等体的IP地址应该为远端LSR的LSR ID。两个远端对等体使用LSR ID做为传输地址建立TCP连接。
相关配置可参考命令mpls ldp remote-peer
# 配置远端对等体地址。
remote-ip bfd
undo remote-ip bfd
MPLS-LDP远端对等体视图
【缺省级别】
2:系统级
【描述】
remote-ip bfd命令用来开启BFD为LDP远端对等体提供链路检测功能。undo remote-ip bfd命令用来恢复缺省情况。
缺省情况下,LDP远端对等体不使用BFD提供的链路检测功能。
# 配置远程peer名称bji,使能BFD提供的链路检测功能。
[Sysname-mpls-ldp-remote-bji] remote-ip bfd
reset mpls ldp [ all | [ vpn-instance vpn-instance-name ] [ fec mask | peer peer-id ] ]
【缺省级别】
2:系统级
all:重启所有LDP实例的会话,包括公网LDP实例和私网LDP实例。
vpn-instance vpn-instance-name:重启指定LDP实例的会话。vpn-instance-name表示VPN实例的名称,为1~31个字符的字符串,区分大小写。
fec mask:重启指定FEC的LDP会话。fec为FEC的目的IP地址,mask为目的IP地址的掩码。
peer peer-id:重启与指定对等体之间的LDP会话。peer-id为对等体的LSR ID。
【描述】
reset mpls ldp命令用来重启LDP会话。
没有指定任何参数时,该命令用来重启所有公网LDP实例的会话;
# 重启所有公网LDP实例的会话。
<Sysname> reset mpls ldp
# 重启所有LDP实例的会话。
<Sysname> reset mpls ldp all
# 重启指定LDP实例的会话。
<Sysname> reset mpls ldp vpn-instance vpn1
# 重启指定FEC的会话。
<Sysname> reset mpls ldp 2.2.2.2 24
# 重启与指定对等体之间的LDP会话。
<Sysname> reset mpls ldp peer 2.2.2.9
reset mpls statistics interface { interface-type interface-number | all }
【缺省级别】
2:系统级
all:所有接口。
【描述】
reset mpls statistics interface命令用来清除已使能MPLS功能的接口的统计信息。
# 清除已使能MPLS的接口Vlan-interface1的统计信息。
<Sysname> reset mpls statistics interface vlan-interface 1
reset mpls statistics lsp { index | all | name lsp-name }
【缺省级别】
2:系统级
all:所有LSP。
name lsp-name:标签转发路径名称,为1~15个字符的字符串。
【描述】
reset mpls statistics lsp命令用来清除MPLS全部或单个LSP的统计信息。
相关配置可参考命令display mpls statistics lsp
# 清除名为lsp1的LSP统计信息。
<Sysname> reset mpls statistics lsp lsp1
static-lsp egress lsp-name incoming-interface interface-type interface-number in-label in-label
undo static-lsp egress lsp-name
【缺省级别】
2:系统级
in-label:入标签值,取值范围为0,3,16~1023。
【描述】
static-lsp egress命令用来为Egress节点配置静态LSP。undo static-lsp egress命令用来为Egress节点删除一条静态LSP。
相关配置可参考命令static-lsp ingressstatic-lsp transitdisplay mpls static-lsp
# 在Egress节点上配置一条名为bj-sh的静态LSP。
[Sysname] static-lsp egress bj-sh incoming-interface Vlan-interface 2 in-label 233
static-lsp ingress lsp-name destination dest-addr { mask | mask-length } nexthop next-hop-addr out-label out-label
undo static-lsp ingress lsp-name
【缺省级别】
2:系统级
dest-addr:目的IP地址。
mask:目的IP地址掩码。
mask-length:目的IP地址掩码长度,取值范围为0~32。
nexthop next-hop-addr:下一跳地址。
out-label:出标签值,取值范围为0,3,16~1023。
【描述】
static-lsp ingress命令用来为Ingress节点配置静态LSP。undo static-lsp ingress命令用来为Ingress节点删除一条静态LSP。
l    如果在配置静态LSP时指定了下一跳,并且下一条地址存在于路由信息表中,则在配置IP静态路由时也必须指定下一跳;如果在配置静态LSP时指定了出接口,则在配置IP静态路由时也必须指定出接口。
l    本地公网IP地址不能被指定为下一跳。
相关配置可参考命令static-lsp egressstatic-lsp transitdisplay mpls static-lsp
# 为Ingress节点配置一条到目的地址202.25.38.1的静态LSP。
[Sysname] static-lsp ingress bj-sh destination 202.25.38.1 24 nexthop 202.55.25.33 out-label 237
static-lsp transit lsp-name incoming-interface interface-type interface-number in-label in-label nexthop next-hop-addr out-label out-label
undo static-lsp transit lsp-name
【缺省级别】
2:系统级
in-label:入标签值,取值范围为16~1023。
【描述】
static-lsp transit命令用来为Transit节点配置静态LSP。undo static-lsp transit命令用来为Transit节点删除一条静态LSP。
相关配置可参考命令static-lsp egressstatic-lsp ingress
# 为Transit节点的Vlan-interface2接口配置一条静态LSP,其中入标签为123,出标签为253。
[Sysname] static-lsp transit bj-sh incoming-interface Vlan-interface 2 in-label 123 nexthop 202.34.114.7 out-label 253
statistics interval interval-time
undo statistics interval
MPLS视图
【缺省级别】
2:系统级
interval-time:时间间隔,取值范围为30~65535,单位为秒。
【描述】
statistics interval命令用来配置LSP统计数据输出时间间隔。undo statistics interval命令用来恢复缺省配置。
缺省情况下,LSP统计数据输出时间间隔为0秒,即不统计信息。
相关配置可参考命令display mpls statistics interfacedisplay mpls statistics lsp
# 配置LSP统计数据输出时间间隔。
[Sysname] mpls
[Sysname-mpls] statistics interval 30
1.1.57  tracert lsp
tracert lsp [-a source-ip | -exp exp-value | -h ttl-value | -r reply-mode |-t time-out ] * { ipv4 dest-addr mask-length [ destination-ip-addr-header ] | te interface-type interface-number }
【缺省级别】
0:访问级
-t time-out:用于指定发送出Echo Request报文后等待响应的超时时间,取值范围为0~65535,单位为毫秒。
ipv4 dest-addr mask-length:指定LDP IPv4目的地址,mask-length为LDP IPv4目的地址的掩码,取值范围为0~32。
【描述】
tracert lsp命令用来对MPLS LSP的错误进行定位。通过检查测试数据包是否经过LSP的中间LSR来判断网络在什么地方发生了故障。
# 主机1.1.1.1用tracert lsp命令显示去3.3.3.9的LSP的中间LSR。
<Sysname> tracert lsp ipv4 3.3.3.9 32
LSP Trace Route FEC: LDP IPV4 PREFIX 3.3.3.9/32 , press CTRL_C to break.
  TTL   Replier            Time    Type      Downstream
  0                                Ingress   10.4.5.1/[1025]
  1     10.4.5.1           1       Transit   100.3.4.1/[1024]
  2     100.1.4.2          63      Transit   100.1.2.1/[3]
  3     100.1.2.1          129     Egress
undo ttl expiration enable
MPLS视图
【缺省级别】
2:系统级
【描述】
ttl expiration enable命令用来开启MPLS TTL超时发送ICMP差错报文功能。undo ttl expiration enable命令用来关闭MPLS TTL超时发送ICMP差错报文功能。
缺省情况下,MPLS TTL超时发送ICMP差错报文功能处于开启状态。
相关配置可参考命令ttl expiration pop
开启MPLS TTL超时发送ICMP报文功能后,关于发送ICMP差错报文请参考命令行ttl expiration pop的描述。
# 关闭MPLS TTL超时发送ICMP差错报文功能。
[Sysname] mpls
[Sysname-mpls] undo ttl expiration enable
ttl expiration pop
undo ttl expiration pop
MPLS视图
【缺省级别】
2:系统级
【描述】
ttl expiration pop命令用来配置MPLS TTL超时后,使用本地IP路由转发ICMP响应报文。
undo ttl expiration pop命令用来配置MPLS TTL超时后,使用LSP转发ICMP响应报文。
缺省情况下,对于一层标签的MPLS TTL超时时,使用本地IP路由转发ICMP响应报文。
undo mpls命令将清除所有ttl expiration pop的相关配置。
相关配置可参考命令ttl propagate
# 配置MPLS TTL超时时,沿LSP返回ICMP报文。
[Sysname] mpls
[Sysname-mpls] undo ttl expiration pop
ttl propagate { public | vpn }
undo ttl propagate { public | vpn }
MPLS视图
【缺省级别】
2:系统级
public:对公网报文进行设置。
vpn:对VPN报文进行设置。
【描述】
ttl propagate命令用来使能MPLS的IP TTL复制功能。undo ttl propagate命令用来禁止MPLS的IP TTL复制功能。
缺省情况下,只对公网报文使能TTL复制功能。
# 使能VPN报文的MPLS IP TTL复制功能。
[Sysname] mpls
[Sysname-mpls] ttl propagate vpn
