04-组播分册
11-IPv6 MBGP命令
本章节下载 11-IPv6 MBGP命令  (294.31 KB)
docurl=/cn/Service/Document_Software/Document_Center/Wlan/WX/WX6100E/Command/Command_Manual/H3C_WX6100E_CM-Release_6600(V1.00)/04/201006/677413_30005_0.htm
11-IPv6 MBGP命令
  录
1 IPv6 MBGP配置命令
1.1 IPv6 MBGP配置命令
1.1.1 aggregate (IPv6 MBGP address family view)
1.1.2 balance (IPv6 MBGP address family view)
1.1.3 bestroute as-path-neglect (IPv6 MBGP address family view)
1.1.4 bestroute compare-med (IPv6 MBGP address family view)
1.1.5 bestroute med-confederation (IPv6 MBGP address family view)
1.1.6 compare-different-as-med (IPv6 MBGP address family view)
1.1.7 dampening (IPv6 MBGP address family view)
1.1.8 default local-preference (IPv6 MBGP address family view)
1.1.9 default med (IPv6 MBGP address family view)
1.1.10 default-route imported (IPv6 MBGP address family view)
1.1.11 display ipv6 multicast routing-table
1.1.12 display ipv6 multicast routing-table ipv6-address prefix-length
1.1.13 display bgp ipv6 multicast group
1.1.14 display bgp ipv6 multicast network
1.1.15 display bgp ipv6 multicast paths
1.1.16 display bgp ipv6 multicast peer
1.1.17 display bgp ipv6 multicast peer received ip-prefix
1.1.18 display bgp ipv6 multicast routing-table
1.1.19 display bgp ipv6 multicast routing-table as-path-acl
1.1.20 display bgp ipv6 multicast routing-table community
1.1.21 display bgp ipv6 multicast routing-table community-list
1.1.22 display bgp ipv6 multicast routing-table dampened
1.1.23 display bgp ipv6 multicast routing-table dampening parameter
1.1.24 display bgp ipv6 multicast routing-table different-origin-as
1.1.25 display bgp ipv6 multicast routing-table flap-info
1.1.26 display bgp ipv6 multicast routing-table peer
1.1.27 display bgp ipv6 multicast routing-table regular-expression
1.1.28 display bgp ipv6 multicast routing-table statistic
1.1.29 filter-policy export (IPv6 MBGP address family view)
1.1.30 filter-policy import (IPv6 MBGP address family view)
1.1.31 import-route (IPv6 MBGP address family view)
1.1.32 ipv6-family multicast
1.1.33 network (IPv6 MBGP address family view)
1.1.34 peer advertise-community (IPv6 MBGP address family view)
1.1.35 peer advertise-ext-community (IPv6 MBGP address family view)
1.1.36 peer allow-as-loop (IPv6 MBGP address family view)
1.1.37 peer as-path-acl (IPv6 MBGP address family view)
1.1.38 peer capability-advertise orf(IPv6 MBGP address family view)
1.1.39 peer default-route-advertise (IPv6 MBGP address family view)
1.1.40 peer enable (IPv6 MBGP address family view)
1.1.41 peer filter-policy (IPv6 MBGP address family view)
1.1.42 peer group (IPv6 MBGP address family view)
1.1.43 peer ipv6-prefix (IPv6 MBGP address family view)
1.1.44 peer keep-all-routes (IPv6 MBGP address family view)
1.1.45 peer next-hop-local (IPv6 MBGP address family view)
1.1.46 peer preferred-value (IPv6 MBGP address family view)
1.1.47 peer public-as-only (IPv6 MBGP address family view)
1.1.48 peer reflect-client (IPv6 MBGP address family view)
1.1.49 peer route-limit (IPv6 MBGP address family view)
1.1.50 peer route-policy (IPv6 MBGP address family view)
1.1.51 preference (IPv6 MBGP address family view)
1.1.52 reflect between-clients (IPv6 MBGP address family view)
1.1.53 reflector cluster-id (IPv6 MBGP address family view)
1.1.54 refresh bgp ipv6 multicast
1.1.55 reset bgp ipv6 multicast
1.1.56 reset bgp ipv6 multicast dampening
1.1.57 reset bgp ipv6 multicast flap-info
1 IPv6 MBGP配置命令
1.1  IPv6 MBGP配置命令
undo aggregate ipv6-address prefix-length
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
ipv6-address:IPv6组播聚合路由的目的IPv6地址。
prefix-length:IPv6组播聚合路由的网络掩码长度,取值范围为0~128。
as-set:生成具有AS集合段的路由。
attribute-policy route-policy-name根据指定的路由策略route-policy-name设置聚合路由的属性,route-policy-name表示路由策略名,为119个字符的字符串。
detail-suppressed:仅通告聚合路由。
suppress-policy route-policy-name:根据指定的路由策略route-policy-name抑制选定的具体路由,不通告部分具体路由,route-policy-name表示路由策略名,为119个字符的字符串。
origin-policy route-policy-name:根据指定的路由策略route-policy-name选择用于聚合的源路由,route-policy-name表示路由策略名,为119个字符的字符串。
【描述】
aggregate命令用来在BGP IPv6组播路由路由表中创建一条IPv6聚合路由。undo aggregate命令用来删除该IPv6组播聚合路由。
缺省情况下,不进行IPv6组播路由聚合。
上述命令的关键字的用法如1-1所示。
表1-1 关键字的用法
关键字
用法
as-set
通过设置该关键字,可创建一条聚合路由,该路由的AS路径包含了具体路由的AS路径信息。若需聚合较多AS路径时,请慎用此关键字,因为当具体路由的变化较频繁时,会导致路由振荡
detail-suppressed
该关键字不抑制聚合路由,但抑制所有具体路由的通告。如果只想对一部分具体路由进行抑制,可以使用peer filter-policy命令
suppress-policy
该关键字能产生聚合路由,但抑制指定路由的通告。可以用route-policyif-match子句有选择地抑制一些具体路由,其它具体路由仍被通告
origin-policy
该关键字仅选择符合路由策略的具体路由来生成聚合路由
attribute-policy
该关键字可设置聚合路由的属性。通过peer route-policy等方式也可以完成实现相同的功能。该关键字不能设置聚合路由的AS-PATH属性
# 在BGP IPv6组播路由路由表中创建一条IPv6组播聚合路由12::/64。
[Sysname] bgp 100
[Sysname-bgp] ipv6-family multicast
[Sysname-bgp-af-ipv6-mul] aggregate 12:: 64
balance number
undo balance
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
number:进行IPv6 MBGP负载分担的路由条数,取值范围1~8,当number取值为1时,相当于不进行负载分担。
【描述】
balance命令用来配置进行IPv6 MBGP负载分担的路由条数。undo balance命令用来取消路由负载分担功能。
缺省情况下,没有进行路由负载分担。
与IGP路由的负载分担不同,IPv6 MBGP没有明确的度量值决定是否对路由进行负载分担。IPv6 MBGP的负载分担是通过改变IPv6 MBGP选路规则来实现的。
相关配置可参考命令display ipv6 multicast routing-table
# 配置IPv6 MBGP负载分担的路由条数为2条。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] balance 2
undo bestroute as-path-neglect
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
【描述】
bestroute as-path-neglect命令用来禁止路由器将AS_PATH当作选路算法中的一个因素。undo bestroute as-path-neglect命令用来允许路由器将AS_PATH当作选路算法中的一个因素。
缺省情况下,路由器将AS_PATH当作选路算法中的一个因素。
# 在IPv6 MBGP地址族视图下,禁止路由器将AS_PATH当作选路算法中的一个因素。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] bestroute as-path-neglect
undo bestroute compare-med
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
【描述】
bestroute compare-med命令用来配置根据路由来自的自治系统进行分组对MED排序优选。undo bestroute compare-med命令用来取消根据路由来自的自治系统进行分组对MED排序优选。
缺省情况下,不根据路由来自的自治系统进行分组对MED排序优选。
配置该命令后,balance命令将不生效。
# 在IPv6 MBGP地址族视图下,配置在选择最佳路由时,根据路由来自的自治系统进行分组对MED排序优选。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] bestroute compare-med
undo bestroute med-confederation
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
【描述】
bestroute med-confederation命令用来配置允许比较联盟对等体的路由按MED值进行优选。undo bestroute med-confederation命令用来取消比较操作。
缺省情况下,比较联盟对等体的路由时不考虑MED值。
只有不包括外部自治系统(不在联盟内)的路径才可比较MED值。如果包含外部自治系统的路径,其MED将在联盟内传播,而不进行比较。
# 在IPv6 MBGP地址族视图下,配置允许比较联盟对等体的路由按MED值进行优选。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] bestroute med-confederation
undo compare-different-as-med
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
【描述】
compare-different-as-med命令用来配置允许比较来自不同自治系统的邻居路由的MED属性值。undo compare-different-as-med命令用来禁止进行比较。
缺省情况下,不允许比较来自不同自治系统邻居路由的MED属性值。
如果到达同一目的地址有多条可选有效路径,可以选择MED参数较小的路由作为最终实际使用的路由项。
需要注意的是,除非能够确认不同的自治系统采用了同样的IGP和路由选择方式,否则不要使用此命令。
#在IPv6 MBGP地址族视图下,配置允许比较来自不同自治系统邻居的路由的MED属性值。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] compare-different-as-med
undo dampening
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
half-life-reachable:指定可达路由的半衰期,取值范围为1~45,单位为分钟。缺省值为15分钟。
half-life-unreachable:指定不可达路由的半衰期,取值范围为1~45,单位为分钟。缺省值为15分钟。
reuse:指定路由解除抑制状态的阈值。当惩罚降低到该值以下,路由就再次启用,取值范围为1~20000。缺省值为750。
suppress:指定路由进入抑制状态的阈值。当惩罚超过该极限时,路由受到抑制,取值范围为1~20000,实际配置的值必须大于reuse。缺省值为2000。
ceiling:惩罚上限值,取值范围为1001~20000,实际配置的值必须大于suppress。缺省值为16000。
route-policy-name:路由策略名,为1~19个字符的字符串。
【描述】
dampening命令用来配置IPv6 MBGP路由衰减undo dampening命令用来取消路由衰减。
缺省情况下,没有配置路由衰减。
相关配置可参考命令reset bgp ipv6 dampeningreset bgp ipv6 flap-infodisplay bgp ipv6 multicast routing-table dampeneddisplay bgp ipv6 multicast routing-table dampening parameterdisplay bgp ipv6 multicast routing-table flap-info
# 在IPv6 MBGP地址族视图下,配置路由衰减。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] dampening 10 10 1000 3000 10000
undo default local-preference
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
value:指定的本地优先级的缺省值,取值范围为0~4294967295,该值越大则优先级越高。
【描述】
default local-preference命令用来配置本地优先级的缺省值。undo default local-preference命令用来恢复缺省情况。
缺省情况下,本地优先级的缺省值为100。
可以用配置不同本地优先级的方法来影响IPv6 MBGP的路由选择。
# 在IPv6 MBGP地址族视图下,配置本地优先级的缺省值为180。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] default local-preference 180
1.1.8  default med (IPv6 MBGP address family view)
default med med-value
undo default med
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
med-value:指定的MED的缺省值,取值范围为0~4294967295。
【描述】
default med命令用来配置缺省的MED值。undo default med命令用来恢复缺省情况。
缺省情况下,缺省的MED值为0。
MED(Multi-Exit Discriminator,多出口区分)属性是一个路由的外部度量(Metric),与本地优先级属性不同,MED在自治系统间交换,但进入自治系统的MED不会再发送到该自治系统以外。MED属性用于选择最佳路由,MED较小的路由被选择。当一个运行BGP的路由器通过不同的外部对等体(External Peer)得到目的地址相同、下一跳不同的路由时,将根据不同路由的MED值进行优先选择。在其它条件相同的情况下,MED较小的路由作为自治系统的外部路由。
# 设备A和B属于AS100,设备C属于AS200。设备C是A和B的对等体。可以配置A的MED为25,以使设备C优先选择B发送的路由。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] default med 25
undo default-route imported
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
【描述】
default-route imported命令用来允许将缺省路由引入到IPv6 MBGP路由表中。undo default-route imported命令用来取消该功能。
缺省情况下,IPv6 MBGP不允许将缺省路由引入到IPv6 MBGP路由表中。
# 配置将缺省路由从OSPFv3引入到IPv6 MBGP路由表中。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] default-route imported
[Sysname-bgp-af-ipv6-mul] import-route ospfv3 1
display ipv6 multicast routing-table [ verbose ]
【缺省级别】
1:监控级
verbose:显示全部IPv6 MBGP路由表的详细信息,包括处于inactive和active状态的IPv6 MBGP路由。如果不带此参数,将只显示处于active状态的IPv6 MBGP路由。
【描述】
display ipv6 multicast routing-table命令用来查看IPv6 MBGP路由表中的路由信息。
在IPv6 MBGP路由表中的路由有两种状态:一种是active状态,表示该条路由是通过IPv6 MBGP选出来的最优路由,将用于执行RPF检查;令另外一种是inactive状态,表示该条路由不是最优路由,不会用来执行RPF检查。
# 显示IPv6 MBGP路由表的概要信息。
<Sysname> display ipv6 multicast routing-table
Routing Table :
        Destinations : 1        Routes : 1
Destination :  ::1                                  PrefixLength : 128
NextHop      : ::1                                  Preference : 0
Interface    : InLoopBack0                          Protocol    : Direct
State        : Active NoAdv                         Cost        : 0
Tunnel ID    : 0x0                                  Label       : NULL
Age          : 156sec
表1-2 display ipv6 multicast routing-table命令显示信息描述表
Destination
目的网络/主机的IPv6地址
PrefixLength
前缀长度
Nexthop
下一跳地址
Preference
路由优先级
输出接口,即到该目的地址的数据包将从此接口发出
Protocol
发现该路由的路由协议
路由状态,包括:Active(激活)、Inactive(非激活)、Adv(向外发布)、NoAdv(不向外发布)等
Cost
路由的开销值
Tunnel ID
隧道ID
Label
标签
Age
此路由在路由表中存在的时间
# 显示IPv6 MBGP路由表的详细路由信息。
<Sysname> display ipv6 multicast routing-table verbose
Routing Table :
 RelayNextHop  : ::                                  Tag          : 0H
 Neighbour     : ::                                  ProcessID    : 0
 Age           : 17073sec
表1-3 display ipv6 multicast routing-table verbose命令显示信息描述表
Destination
目的网络/主机的IPv6地址
PrefixLength
前缀长度
Nexthop
下一跳地址
Preference
路由优先级
RelayNextHop
路由迭代出来得到的下一跳地址
Tag
路由标记
Neighbour
路由协议的邻居地址
ProcessID
进程号
Protocol
发现该路由的路由协议
Cost
路由的开销值
Tunnel ID
隧道ID
Label
标签
Age
从路由生成到现在所经历的时间
display ipv6 multicast routing-table ipv6-address prefix-length [ longer-match ] [ verbose ]
【缺省级别】
1:监控级
ipv6-address:目的IPv6地址。
prefix-length:前缀长度,取值范围为0~128。
longer-match:显示在前缀长度范围内匹配目的地址的路由。
verbose:显示通过过滤规则的激活和未激活路由的详细信息。不指定该参数,只显示通过过滤规则的激活路由的概要信息。
【描述】
display ipv6 multicast routing-table ipv6-address prefix-length命令用来显示指定目的地址的组播路由信息。
# 显示指定组播路由的概要信息。
<Sysname> display ipv6 multicast routing-table 4::1 32
Routing Table:
Summary Count 1
  Destination : 4::                              PrefixLength : 32
  NextHop     : 3::1                             Preference   : 60
  Interface   : Vlan-interface1                     Protocol     : Static
  State       : Active Adv                      Cost         : 0
  Age         : 19174sec
# 在掩码范围内没有匹配组播路由,只显示最长匹配路由的概要信息。
<Sysname> display ipv6 multicast  routing-table 4:: 16 longer-match
Routing Tables:
Summary Count 2
Age          : 766sec
Destination   : 4:4::                           PrefixLength : 64
Age           : 766sec
# 显示掩码范围内匹配组播路由的概要信息。
<Sysname> display ipv6 multicast  routing-table 4:4:: 32 verbose
Routing Tables:
Summary count:1
Age          : 19547sec
以上各显示信息域的解释请参见1-2
display bgp ipv6 multicast group [ ipv6-group-name ]
【缺省级别】
1:监控级
ipv6-group-name:为指定的对等体组名,为1~47个字符的字符串。
【描述】
display bgp ipv6 multicast group命令用来显示IPv6 MBGP对等体组信息。
如果不指定参数ipv6-group-name,则显示所有对等体组信息。
# 显示IPv6 MBGP对等体组aaa的信息。
<Sysname> display bgp ipv6 group aaa
 BGP peer-group is aaa
 remote AS number not specified
 Type : external
 Threshold: 75%
 Configured hold timer value: 180
 Keepalive timer value: 60
 Minimum time between advertisement runs is 30 seconds
 Optional capabilities:
  ORF advertise capability based on Prefix(type 64):
    Local: both
    Negotiated: send
 Peer Preferred Value: 0
  Members:
  Peer         V    AS  MsgRcvd  MsgSent  OutQ PrefRcv Up/Down  State
  20:20::20:1  4   200       170       141      0        2 02:13:35 Established
表1-4 display bgp ipv6 multicast group命令显示信息描述表
BGP peer-group
IPv6 MBGP对等体组名
remote AS
对等体组自治系统号
对等体组类型
可接受最大路由数
Threshold
门限值
保持时间定时器的值
存活时间定时器的值
路由发布最小时间间隔
已经使能了Refresh能力
ORF advertise capability based on prefix (type 64):
对等体支持ORF的地址前缀能力,能力值为64
Local: both
本地支持:发送和接收
Negotiated: send
协商成功:本端可以发送携带ORF信息的Route-refresh报文,对端可以接收携带ORF信息的Route-refresh报文(如果显示receive则表示本端可以接收携带ORF信息的Route-refresh报文,对端可以发送携带ORF信息的Route-refresh报文。如果send和receive都没有协商成功,则不会显示该行信息)
为来自邻居路由指定的首选值
没有针对该邻居指定任何路由策略
Members
成员
Peer
对等体的IPv6地址
V
对等体的BGP版本号
AS
自治系统号
MsgRcvd
收到的消息数
MsgSent
发送的消息数
OutQ
待发送的消息数
PrefRcv
收到的前缀数
Up/Down
会话已建立的时长/(会话未建立时)当前状态的时长
对等体的有限状态机
【缺省级别】
1:监控级
【描述】
display bgp ipv6 multicast network命令用来显示IPv6 MBGP通过network命令发布的IPv6路由信息。
# 显示IPv6 MBGP通过network命令发布的IPv6路由信息。
<Sysname> display bgp ipv6 multicast network
  BGP Local Router ID is 1.1.1.2.
  Local AS Number is 200.
  Network          Mask            Route-policy        Short-cut
  2002::           64
  2001::           64                                  Short-cut
表1-5 display bgp ipv6 multicast network命令显示信息描述表
BGP Local Router ID
本地路由器标识符
Local AS Number
本地自治系统号
Network
网络地址
Mask
前缀长度
Route-policy
配置的路由策略
Short-cut
是否为Short-cut路由
display bgp ipv6 multicast paths [ as-regular-expression ]
【缺省级别】
1:监控级
as-regular-expression:匹配的AS路径正则表达式。
【描述】
display bgp ipv6 multicast paths命令用来显示AS路径信息。
如果没有指定参数,则显示所有AS路径信息。
#  显示IPv6 MBGP地址族视图下路由的AS路径信息。
<Sysname> display bgp ipv6 multicast paths
    Address       Hash    Refcount  MED         Path/Origin
    0x5917098     1       1          0            i
    0x59171D0     9       2          0            100i
表1-6 display bgp ipv6 multicast paths命令显示信息描述表
Address
本地数据库中的路由地址,十六进制格式
Hash
哈希值
Refcount
使用该路径的路由条数
MED
该路由的度量值
Path
路由的自治系统路径(AS_PATH)属性,记录了此路由所穿过的所有自治系统区域,可以避免路由环路的出现
Origin
路由的起源(ORIGIN)属性,表示路由相对于发出它的自治系统的路由更新起点,它有如下3种取值:
i
此路由是自治系统内部的;BGP把聚合路由和用network命令定义的路由看成是自治系统内部的,起点类型设置为IGP
e
此路由是从外部网关协议EGP(Exterior Gateway Protocol)学习到的
此路由信息的来源为未知源,即通过其他方式学习到的;BGP把通过其它IGP协议引入的路由的起点设置为incomplete
display bgp ipv6 multicast peer [ [ ipv6-address ] verbose ]
【缺省级别】
1:监控级
ipv6-group-name:IPv4或IPv6对等体组的名称,为1~47个字符的字符串。
verbose:显示指定对等体的详细信息。
【描述】
display bgp ipv6 multicast peer命令用来显示对等体/对等体组信息。
如果没有指定参数,则显示所有对等体/对等体组的信息。
# 显示IPv6 MBGP对等体的信息。
<Sysname> display bgp ipv6 multicast peer
 BGP local router ID : 2.2.2.2
 Local AS number : 100
 Total number of peers : 1                 Peers in established state : 0
  2000::1                100        1        1    0       0 00:00:51 Active
表1-7 display bgp ipv6 multicast peer命令显示信息描述表
BGP Local Router ID
本地路由器标识符
Local AS Number
本地自治系统号
对等体的总个数
处于状态的established对等体的个数
Peer
对等体的IPv6地址
AS
自治系统号
MsgRcvd
收到的消息数
MsgSent
发送的消息数
OutQ
待发送的消息数
PrefRcv
收到的前缀数
Up/Down
对等体的有限状态机
display bgp ipv6 multicast peer ipv6-address received ipv6-prefix
【缺省级别】
1:监控级
ip-address:指定要显示的BGP对等体的IP地址。
Ipv6-address指定要显示的BGP对等体的IPv6地址。
【描述】
display bgp ipv6 multicast peer received ipv6-prefix命令用来显示收到的邻居ORF信息中的前缀信息。
# 显示对等体4::4的收到的前缀ORF信息。
<Sysname> display bgp ipv6 peer 4::4 received ipv6-prefix
ORF ipv6-prefix entries: 2
ge: greater-equal   le: less-equal
  index rule   prefix                ge    le
  10    permit 1::/64                80    128
  20    deny   100::/64              80    128
表1-8 display bgp ipv6 multicast peer received ipv6-prefix显示信息描述表
ORF ip-prefix entries
ORF地址前缀条目数
index
地址前缀索引号
rule
地址前缀匹配规则
prefix
地址前缀信息
ge
greater-equal,表示掩码长度大于或者等于
le
less-equal,表示掩码长度小于或者等于
display bgp ipv6 multicast routing-table [ ipv6-address prefix-length ]
【缺省级别】
1:监控级
prefix-length:目的IPv6地址前缀长度,取值范围为0128
【描述】
display bgp ipv6 multicast routing-table命令用来显示IPv6 MBGP路由信息。
# 显示IPv6 MBGP路由信息。
<Sysname> display bgp ipv6 routing-table
 Total Number of Routes: 2
 BGP Local router ID is 30.30.30.1
 Status codes: * - valid, > - best, d - damped,
               h - history,  i - internal, s - suppressed, S - Stale
               Origin : i - IGP, e - EGP, ? - incomplete
 *>  Network : 30:30::                                  PrefixLen : 64
     NextHop : 30:30::30:1                              LocPrf    :
     PrefVal : 0                                        Label     : NULL
     MED     : 0
     Path/Ogn: i
 *>  Network : 40:40::                                  PrefixLen : 64
     NextHop : 40:40::40:1                              LocPrf    :
     MED     : 0
     Path/Ogn: i
表1-9 display bgp ipv6 multicast routing-table命令显示信息描述表
Local router ID
本地路由器标识符
Status codes
路由状态代码:
l      *表示valid(合法)
l      >表示best(最佳路由)
l      d表示damped(震荡抑制)
l      h表示history(历史路由)
l      i表示internal(内部路由)
l      s表示suppressed(聚合抑制)
l      S表示Stale(过期路由)
Origin
路由的Origin属性
l      i表示IGP(网络层可达信息来源于自治系统内部)
l      e表示EGP(网络层可达信息通过EGP学习)
l      ?表示incomplete(网络层可达信息通过其他方式学习)
Network
目的网络地址
PrefixLen
前缀长度
NextHop
下一跳IP地址
MED
MULTI_EXIT_DISC属性值
LocPrf
本地优先级
Path
PrefVal
路由首选值
Label
标签
Ogn
i
e
display bgp ipv6 multicast routing-table as-path-acl as-path-acl-number
【缺省级别】
1:监控级
as-path-acl-number:指定匹配的AS路径过滤列表号,取值范围为1~256。
【描述】
display bgp ipv6 multicast routing-table as-path-acl命令用来显示匹配指定的AS路径过滤列表的IPv6 MBGP路由。
# 显示匹配编号为20的AS路径过滤列表的IPv6 MBGP路由。
<Sysname> display bgp ipv6 multicast routing-table as-path-acl 20
     MED     : 0
     Path/Ogn: i
以上各显示信息域的解释请参见表1-9。
display bgp ipv6 multicast routing-table community [ aa:nn&<1-13> ] [ no-advertise | no-export | no-export-subconfed ] * [ whole-match ]
【缺省级别】
1:监控级
aa:nn:指定的团体号,aann的取值范围为0~65535。&<1-13>:表示前面的参数可以输入1~13次。
no-advertise:具有此属性的路由在收到后,不能被通告给任何其他的BGP对等体。
no-export:具有此属性的路由在收到后,不能被发布到本地自治系统之外。如果使用了联盟,则不能被发布到联盟之外,但可以发布给联盟中的其他子自治系统。
no-export-subconfed:具有此属性的路由在收到后,不能被发布到本地自治系统之外,也不能发布到联盟中的其他子自治系统。
whole-match:精确匹配。
【描述】
display bgp ipv6 multicast routing-table community命令用来显示指定IPv6 MBGP团体的路由信息。
# 显示指定团体的IPv6 MBGP路由信息。
<Sysname> display bgp ipv6 multicast routing-table community no-export
     MED      : 0
     Path/Ogn: i
以上各显示信息域的解释请参见表1-9。
display bgp ipv6 multicast routing-table community-list { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16>
【缺省级别】
1:监控级
basic-community-list-number:为基本团体表号,取值范围为1~99。
adv-community-list-number:为高级团体表号,取值范围为100~199。
whole-match:为确切匹配,即匹配而且仅匹配basic-community-list-number定义的所有团体属性。
&<1-16>:表示前面的参数可以输入1~16次。
【描述】
display bgp ipv6 multicast routing-table community-list命令用来显示匹配指定IPv6 MBGP团体列表的路由信息。
# 显示匹配指定IPv6 MBGP团体列表的路由信息。
<Sysname> display bgp ipv6 multicast routing-table community-list 99
     MED     : 0
     Path/Ogn: i
以上各显示信息域的解释请参见表1-9。
【缺省级别】
1:监控级
【描述】
display bgp ipv6 multicast routing-table dampened命令用来显示IPv6 MBGP衰减的路由。
# 显示IPv6 MBGP衰减的路由。
<Sysname> display bgp ipv6 multicast routing-table dampened
 *d  Network : 111::                                  PrefixLen : 64
     From    : 122::1                                 Reuse     : 00:29:34
     Path/Ogn: 200?
表1-10 display bgp ipv6 multicast routing-table dampened命令显示信息描述表
From
路由的源IP地址
Reuse
路由恢复可用时间,即还需要等待多长时间该路由将由不可用状态转为可用状态
其他各显示信息域的解释请参见表1-9。
【缺省级别】
1:监控级
【描述】
display bgp ipv6 multicast routing-table dampening parameter命令用来显示IPv6 MBGP路由衰减参数。
相关配置可参考命令dampening
# 显示IPv6 MBGP路由衰减参数。
<Sysname> display bgp ipv6 multicast routing-table dampening parameter
 Maximum Suppress Time(in second)     : 3069
 Ceiling Value                        : 16000
 Reuse Value                          : 750
 Reach HalfLife Time(in second)  : 900
 Unreach HalfLife Time(in second): 900
 Suppress-Limit                       : 2000
表1-11 display bgp ipv6 multicast routing-table dampening parameter命令显示信息描述表
最大抑制时间
Ceiling Value
惩罚上限值
Reuse Value
路由解除抑制状态的阈值
可达路由的半衰期
不可达路由的半衰期
Suppress-Limit
路由进入抑制状态的阈值
【缺省级别】
1:监控级
【描述】
display bgp ipv6 multicast routing-table different-origin-as命令用来显示来自不同自治系统的IPv6 MBGP路由。
# 显示来自不同自治系统的IPv6 MBGP路由。
<Sysname> display bgp ipv6 multicast routing-table different-origin-as
BGP Local router ID is 2.2.2.2
 *>  Network : 222::                                    PrefixLen : 64
     NextHop : 122::2                                   LocPrf    :
     MED      : 0
     Path/Ogn: 100 ?
以上显示信息的说明请参见表1-9。
display bgp ipv6 multicast routing-table flap-info [ regular-expression as-regular-expression | as-path-acl as-path-acl-number | ipv6-address [ prefix-length [ longer-match ] ] ]
【缺省级别】
1:监控级
as-regular-expression:指定匹配的AS路径正则表达式。
as-path-acl-number:指定匹配的AS路径列表号,取值范围1~256。
ipv6-address:要显示的衰减路由的IPv6地址。
prefix-length:IPv6地址前缀长度,取值范围为1~128。
longer-match:匹配最长前缀。
【描述】
display bgp ipv6 multicast routing-table flap-info命令用来显示IPv6 MBGP路由振荡统计信息。
# 显示IPv6 MBGP路由振荡统计信息。
<Sysname> display bgp ipv6 multicast routing-table flap-info
     From     : 122::1                                Flaps     : 3
     Duration : 00:13:47                              Reuse     : 00:16:36
     Path/Ogn : 200?
表1-12 display bgp ipv6 multicast routing-table flap-info命令显示信息描述表
Flaps
振荡的总次数
Duration
振荡已经历的时长
Reuse
复用值
其他各显示信息域的解释请参见表1-9。
display bgp ipv6 multicast routing-table peer ipv6-address { advertised-routes | received-routes } [ network-address prefix-length | statistic ]
【缺省级别】
1:监控级
ipv6-address:指定要显示的对等体的IPv6地址。
advertised-routes:向指定对等体发布的路由信息。
received-routes:从指定对等体收到的路由信息。
network-address prefix-length:指定IPv6网络地址,prefix-length的取值范围为0~128。
statistic:显示路由的统计信息。
【描述】
display bgp ipv6 multicast routing-table peer命令用来显示向指定的IPv6 MBGP对等体发送或者从指定的IPv6 MBGP对等体收到的路由信息。
# 显示向指定对等体发布的IPv6 MBGP路由信息。
<Sysname> display bgp ipv6 multicast routing-table peer 10:10::10:1 advertised-routes
 BGP Local router ID is 20.20.20.1
 *>  Network : 20:20::                                  PrefixLen : 64
     NextHop : 20:20::20:1                              LocPrf    :
     MED     : 0
     Path/Ogn: i
     MED     : 0
     Path/Ogn: 300 i
以上各显示信息域的说明请参见表1-9。
display bgp ipv6 multicast routing-table regular-expression as-regular-expression
【缺省级别】
1:监控级
【描述】
display bgp ipv6 multicast  routing-table regular-expression命令用来显示匹配指定AS路径正则表达式的IPv6 MBGP路由信息。
# 显示匹配指定AS路径正则表达式的IPv6 MBGP路由信息。
<Sysname> display bgp ipv6 multicast routing-table regular-expression ^100
 *>  Network : 50:50::                                  PrefixLen : 64
     NextHop : 10:10::10:1                              LocPrf    :
     MED     : 0
     Path/Ogn: 100 i
以上各显示信息域的说明请参见表1-9。
display bgp ipv6 multicast routing-tabel statistic
【缺省级别】
1:监控级
【描述】
display bgp ipv6 multicast routing-table statistic命令用来显示IPv6 MBGP的路由统计信息。
# 显示IPv6 MBGP的路由统计信息。
<Sysname> display bgp ipv6 multicast routing-table statistic
 Total Number of Routes: 1
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ protocol  process-id ]
undo filter-policy export [ protocol process-id ]
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
acl6-number:用于匹配路由信息目的地址域的基本或高级IPv6 ACL的编号,取值范围为2000~3999。
ipv6-prefix-name:用于匹配路由信息目的地址域的IPv6地址前缀列表,为1~19个字符的字符串。
protocol:只过滤指定的路由协议的路由信息。目前可包括:directisisv6ospfv3ripngstatic。如果不指定此参数,则对所有要发布的路由进行过滤。
process-id:路由协议进程号,取值范围为1~65535。只有当protocolisisv6ospfv3ripng时,支持该参数。
【描述】
filter-policy export命令用来配置对发布的路由进行过滤,只有通过过滤器的路由才被IPv6 MBGP发布。undo filter-policy export命令用来取消对发布的路由进行过滤。
缺省情况下,不对发布的路由信息进行过滤。
如果指定protocol参数,只对这种路由协议产生的路由信息进行过滤。如果没有指定protocol 参数,将对所有路由协议产生的路由信息进行过滤。
# 使用编号为2001的IPv6 ACL对所有IPv6 MBGP发布的路由进行过滤。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] filter-policy 2001 export
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import
undo filter-policy import
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
【描述】
filter-policy import命令用来配置对接收的路由进行过滤,只有通过过滤器的路由信息才被IPv6 MBGP接收。undo filter-policy import命令用来取消对接收的路由信息进行过滤。
缺省情况下,不对接收的IPv6 MBGP路由信息进行过滤。
# 使用编号为2000的IPv6 ACL对所有IPv6 MBGP接收的路由进行过滤。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] filter-policy 2000 import
import-route protocol [ process-id ] [ med med-value | route-policy route-policy-name ] *
undo import-route protocol [ process-id ]
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
protocol:指定可引入的源路由协议,目前包括directisisv6ospfv3ripngstatic
process-id:用来指定只引入特定某一进程号的路由。取值范围为1~65535。只有当protocolisisv6ospfv3ripng时,支持该参数。
med-value:指定引入路由的MED度量值,取值范围为0~4294967295。如果没有指定度量值,将使用被引入路由的cost作为引入BGP域之后的MED值。
route-policy-name:从其他路由协议引入路由时,需使用该参数指定的路由策略过滤路由,为1~19个字符的字符串。
【描述】
import-route命令用来引入其它协议路由信息并通告。undo import-route命令用来取消已有的配置。
缺省情况下,IPv6 MBGP不引入且不通告其它协议的路由。
通过import-route命令引入到IPv6 MBGP路由表中的路由的ORIGIN属性为incomplete。
# 引入RIPng 1的路由。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] import-route ripng 1
undo ipv6-family multicast
BGP视图
【缺省级别】
2:系统级
【描述】
ipv6-family multicast命令用来进入IPv6 MBGP地址族视图。undo ipv6-family命令用来删除该视图下的所有配置。
缺省情况下,为BGP IPv4单播视图。
# 进入IPv6 MBGP地址族视图。
[Sysname] bgp 100
network ipv6-address prefix-length [ route-policy route-policy-name | short-cut ]
undo network ipv6-address prefix-length [ short-cut ]
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
ipv6-address:IPv6 MBGP通告的IPv6地址前缀。
prefix-length:IPv6地址前缀长度,取值范围为0~128。
short-cut:如果一条EBGP路由被配置成short-cut,那么这条路由在加入到路由表时将使用本地生成路由的路由管理值,而不是EBGP路由的路由管理值,一般来说,这条路由成为最佳路由的优先级被降低了很多。
route-policy-name:通告路由应用的路由策略,为1~19个字符的字符串。
【描述】
network命令用来将路由通告到IPv6 MBGP路由表中。undo network命令用来取消已有的配置。
缺省情况下,IPv6 MBGP不通告任何路由。
需要注意以下几点:
l              要发布的网段路由必须存在于本地的IPv6路由表中,通过使用路由策略可以更为灵活的控制所发布的路由。
l              使用network命令通告到IPv6 MBGP路由表中的网段路由的ORIGIN属性为IGP。
# 通告到达2002::/16的路由。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] network 2002:: 16
peer { ipv6-group-name | ipv6-address } advertise-community
undo peer { ipv6-group-name | ipv6-address } advertise-community
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
ipv6-group-name:IPv6 MBGP对等体组的名称,为1~47个字符的字符串。
ipv6-addres:IPv6 MBGP对等体的IPv6地址。
【描述】
peer advertise-community命令用来配置将团体属性发布给IPv6 MBGP对等体/对等体组。undo peer advertise-community命令用来取消已有的配置。
缺省情况下,不将团体属性发布给任何IPv6 MBGP对等体/对等体组。
# 将团体属性发布给IPv6 MBGP对等体1:2::3:4。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 as-number 100
[Sysname-bgp-af-ipv6] quit
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 enable
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 advertise-community
1.1.34  peer advertise-ext-community (IPv6 MBGP address family view)
peer { ipv6-group-name | ipv6-address } advertise-ext-community
undo peer { ipv6-group-name | ipv6-address } advertise-ext-community
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
【描述】
peer advertise-ext-community命令用来配置将扩展团体属性发布给IPv6 MBGP对等体/对等体组。undo peer advertise-ext-community命令用来取消已有的配置。
缺省情况下,不将扩展团体属性发布给任何IPv6 MBGP对等体/对等体组。
# 将扩展团体属性发布给IPv6 MBGP对等体1:2::3:4。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 advertise-ext-community
peer { ipv6-group-name | ipv6-address } allow-as-loop [ number ]
undo peer { ipv6-group-name | ipv6-address } allow-as-loop
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
ipv6-address:IPv6 MBGP对等体的IPv6地址。
number:表示本地自治系统号的重复次数,取值范围为1~10,缺省值为1。
【描述】
peer allow-as-loop命令用来配置允许本地自治系统号在所接收的路由的AS_PATH属性中出现,并可同时配置允许重复的次数。undo peer allow-as-loop命令用来取消该功能。
缺省情况下,不允许本地自治系统号重复。
# 配置允许本地自治系统号的重复次数为2。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 allow-as-loop 2
peer { ipv6-address | ipv6-group-name } as-path-acl as-path-acl-number { export | import }
undo peer { ipv6-address | ipv6-group-name } as-path-acl as-path-acl-number { export | import }
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
as-path-acl-number:AS路径过滤列表号,取值范围为1~256。
import:对接收的IPv6 MBGP路由信息进行过滤。
export:对发送的IPv6 MBGP路由信息进行过滤。
【描述】
peer as-path-acl命令用来为IPv6 MBGP对等体/对等体组配置基于AS路径过滤列表的IPv6 MBGP路由过滤策略。undo peer as-path-acl命令用来取消已经配置的过滤策略。
缺省情况下,没有为IPv6 MBGP对等体/对等体组配置基于AS路径过滤列表的IPv6 MBGP路由过滤策略。
# 配置向IPv6 MBGP对等体1:2::3:4对发布的路由应用AS路径列表3进行过滤。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 as-path-acl 3 export
1.1.37  peer capability-advertise orf(IPv6 MBGP address family view)
peer { group-name | ipv6-address } capability-advertise orf ipv6-prefix { both | receive | send }
undo peer { group-name | ipv6-address } capability-advertise orf ipv6-prefix { both | receive | send }
IPv6地址族视图
【缺省级别】
2:系统级
group-name:对等体组的名称,取值范围为1~47个字符。
ipv6-address:对等体的IPv6地址
both:支持发送和接收携带ORF信息的Route-refresh报文。
receive:支持接收携带ORF信息的Route-refresh报文。
send:支持发送携带ORF信息的Route-refresh报文。
【描述】
peer capability-advertise orf命令用来使能BGP邻居的ORF能力。undo peer capability-advertise orf 命令用来取消BGP邻居的ORF能力。
缺省情况下,BGP对等体/对等体组不使能邻居的ORF能力。
l              使能ORF能力后,本设备和对端会通过Open报文进行ORF能力协商。协商成功后,就能解析对端发送的携带了标准ORF信息的Route-refresh报文或者给对端发送携带标准ORF信息的Route-refresh报文。如果要进行非标准ORF能力协商,还需要配置peer capability-advertise orf non-standard
l              取消对等体/对等体组的ORF能力,则本路由器与指定对等体/对等体组之间不再进行ORF能力的协商。
表1-13 peer capability-advertise orf命令参数选择以及配置效果描述表
本地选择参数
对端选择参数
协商成功后
send
receive
本端的ORF发送能力,对端的ORF接收能力
both
receive
send
本端的ORF接收能力,对端的ORF发送能力
both
both
both
双向的ORF发送和接收能力
# 使能对等体1:2::3:4的ORF能力。协商成功后,本地路由器将可以与1:2::3:4 交换ORF信息。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 capability-advertise orf ipv6-prefix both
peer { ipv6-group-name | ipv6-address } default-route-advertise [ route-policy route-policy-name ]
undo peer { ipv6-group-name | ipv6-address } default-route-advertise
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
route-policy-name:指定路由策略名称,为1~19个字符的字符串。
【描述】
peer default-route-advertise命令用来向IPv6 MBGP对等体/对等体组发送缺省路由。undo peer default-route-advertise命令用来取消向IPv6 MBGP对等体/对等体组发送缺省路由。
缺省情况下,不向IPv6 MBGP对等体/对等体组发送缺省路由。
配置该条命令后不管在路由表中是否存在缺省路由,都会向IPv6 MBGP对等体/对等体组发送一个下一跳为自身的缺省路由。
# 配置向IPv6 MBGP对等体1:2::3:4发布缺省路由。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 default-route-advertise
peer { ipv6-group-name | ipv6-address } enable
undo peer { ipv6-group-name | ipv6-address } enable
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
ipv6-group-name:IPv6 MBGP对等体组的名称,为1~47个字符的字符串。IPv6 MBGP对等体组需要在IPv6地址族视图下创建成功才能在此激活。
Ipv6-address:IPv6 MBGP对等体的IPv6地址。
【描述】
peer enable命令用来激活指定IPv6 MBGP对等体/对等体组。undo peer enable命令用来取消激活指定IPv6 MBGP对等体组/对等体。
缺省情况下,IPv6 MBGP对等体/对等体组是未被激活的。
如果取消激活指定的IPv6 MBGP对等体/对等体组,则本路由器与指定IPv6 MBGP对等体/对等体组之间不再交换路由信息。
# 激活IPv6 MBGP对等体1:2::3:4。
[Sysname] bgp 100
peer { ipv6-group-name | ipv6-address } filter-policy acl6-number { import | export }
undo peer { ipv6-group-name | ipv6-address } filter-policy [ acl6-number ] { import | export }
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
acl6-number:基本或高级IPv6 ACL访问列表号,取值范围为2000~3999。
import:对从指定IPv6 MBGP对等体/对等体组接收的路由应用过滤策略。
export:对向指定IPv6 MBGP对等体/对等体组发布的路由应用过滤策略。
【描述】
peer filter-policy命令用来为IPv6 MBGP对等体/对等体组配置基于IPv6 ACL的过滤策略。undo peer filter-policy命令用来取消已有的配置。
缺省情况下,没有为IPv6 MBGP对等体/对等体组配置基于IPv6 ACL的过滤策略。
# 配置向IPv6 MBGP对等体1:2::3:4发布的路由应用编号为2000的IPv6 ACL进行过滤。
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source 2001:1:: 64
[Sysname-acl6-basic-2000] quit
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 filter-policy 2000 export
peer  ipv6-address  group ipv6-group-name
undo peer ipv6-address group ipv6-group-name
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
【描述】
peer group命令用来将IPv6 MBGP对等体加入已存在的IPv6 MBGP对等体组。undo peer group命令将IPv6 MBGP对等体从IPv6 MBGP对等体组中移出。
缺省情况下,IPv6 MBGP对等体不属于任何IPv6 MBGP对等体组。
# 创建IPv6 MBGP对等体组test,并将IPv6 MBGP对等体1:2::3:4加入该IPv6 MBGP对等体组。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] group test external
[Sysname-bgp-af-ipv6] peer 1:2::3:4 as-number 200
[Sysname-bgp-af-ipv6] peer 1:2::3:4 group test
[Sysname-bgp-af-ipv6-mul] peer test enable
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 group test
1.1.42  peer ipv6-prefix (IPv6 MBGP address family view)
peer { ipv6-group-name | ipv6-address } ipv6-prefix ipv6-prefix-name { import | export }
undo peer { ipv6-group-name | ipv6-address } ipv6-prefix { import | export }
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
ipv6-group-name:IPv6对等体组的名称,为1~47个字符的字符串。
ipv6-prefix-name:指定的IPv6地址前缀列表名称,为1~19个字符的字符串。
export:对向指定IPv6 MBGP对等体/对等体组发送的路由应用过滤策略。
【描述】
peer ipv6-prefix命令用来配置IPv6 MBGP对等体/对等体组基于IPv6地址前缀列表的路由过滤策略。undo peer ipv6-prefix命令用来取消IPv6 MBGP对等体/对等体组基于IPv6地址前缀列表的路由过滤策略。
缺省情况下,没有为IPv6 MBGP对等体/对等体组配置基于IPv6前缀列表的路由过滤策略。
# 配置向IPv6 MBGP对等体1:2::3:4发布的路由应用IPv6地址前缀列表list1进行过滤。
[Sysname] ip ipv6-prefix list1 permit 2002:: 64
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 ipv6-prefix list1 export
peer { ipv6-group-name | ipv6-address } keep-all-routes
undo peer { ipv6-group-name | ipv6-address } keep-all-routes
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
ipv6-address:对等体的IPv6地址。
【描述】
peer keep-all-routes命令用来保存所有来自IPv6 MBGP对等体/对等体组的原始路由信息,即使这些路由没有通过已配置的入口策略。undo peer keep-all-routes命令用来取消该功能。
缺省情况下,不保存IPv6 MBGP对等体/对等体组的原始路由信息。
# 配置保存所有来自IPv6 MBGP对等体1:2::3:4的原始路由信息。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 keep-all-routes
peer { ipv6-group-name | ipv6-address } next-hop-local
undo peer { ipv6-group-name | ipv6-address } next-hop-local
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
【描述】
peer next-hop-local命令用来向IPv6 MBGP对等体/对等体组发布路由时,将自身地址作为下一跳。undo peer next-hop-local命令用来恢复缺省情况。
缺省情况下,向EBGP对等体/对等体组发布路由时,将自身地址作为下一跳;向IBGP对等体/对等体发布路由时,不将自身地址作为下一跳。
# 向IBGP对等体组test发布路由时,将自身地址作为下一跳。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] group test internal
[Sysname-bgp-af-ipv6-mul] peer test next-hop-local
peer { ipv6-group-name | ipv6-address } preferred-value value
undo peer { ipv6-group-name | ipv6-address } preferred-value
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
value:要分配的路由首选值,取值范围0~65535。
【描述】
peer preferred-value命令用来为从IPv6 MBGP对等体/对等体组接收的路由分配首选值。undo peer preferred-value命令用来恢复缺省情况。
缺省情况下,从IPv6 MBGP对等体/对等体组接收的路由的首选值为0。
所有从邻居学来的路由都有一个首选值。在多条去往同一目的地的路由中,拥有最高首选值的路由将被选作到达指定网络的路由。
l              如果同时通过路由策略和peer preferred-value命令为从对等体组接收的IPv6 MBGP路由配置首选值,通过路由策略过滤的IPv6 MBGP路由的首选值将取路由策略中配置的首选值;没有通过路由策略过滤的IPv6 MBGP路由的首选值仍取peer preferred-value命令里配置的首选值。
l              只有当路由策略里配置的首选值为0时,IPv6 MBGP路由的首选值才会取peer preferred-value命令里配置的值;
通过路由策略配置BGP路由信息首选值的相关配置可参考命令peer route-policy和“IP路由分册/路由策略命令”中的apply preferred-value
# 为从IPv6 MBGP对等体1:2::3:4接收的路由配置首选值为50。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 preferred-value 50
peer { ipv6-group-name | ipv6-address } public-as-only
undo peer { ipv6-group-name | ipv6-address } public-as-only
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
【描述】
peer public-as-only命令用来配置发送IPv6 MBGP更新报文时不携带私有自治系统号。undo peer public-as-only命令用来配置发送IPv6 MBGP更新报文时携带私有自治系统号。
缺省情况下,发送IPv6 MBGP更新报文时携带私有自治系统号。
如果发送的IPv6 MBGP更新报文同时带有公有自治系统号和私有自治系统号,命令不生效。私有自治系统号的范围为64512~65535。
# 配置向IPv6 MBGP对等体1:2::3:4发送IPv6 MBGP更新报文时不携带私有自治系统号。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 public-as-only
peer { ipv6-group-name | ipv6-address } reflect-client
undo peer { ipv6-group-name | ipv6-address } reflect-client
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
【描述】
peer reflect-client命令用来配置将本机作为路由反射器,并将IPv6 MBGP对等体/对等体组作为路由反射器的客户。undo peer reflect-client命令用来取消已有的配置。
缺省情况下,没有配置路由反射器及其客户。
相关配置可参考命令reflect between-clientsreflector cluster-id
# 本地设备为路由反射器,将对等体组test配置为路由反射器的客户。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer test reflect-client
peer { ipv6-group-name | ipv6-address } route-limit limit [ percentage ]
undo peer { ipv6-group-name | ipv6-address } route-limit
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
limit:指定允许从对等体/对等体组接收的最大IPv6地址前缀数,取值范围1~65536。
percentage:指定路由器开始生成告警消息时的路由数量的百分比,取值范围1~100,缺省值为75。
【描述】
peer route-limit命令用来配置允许从IPv6 MBGP对等体/对等体组接收的最大IPv6地址前缀数。undo peer route-limit命令用来恢复缺省情况。
缺省情况下,允许从IPv6 MBGP对等体/对等体组接收的最大IPv6地址前缀数无限制。
如果收到的IPv6地址前缀数超出了设定的最大限额,本地路由器将断开与IPv6 MBGP对等体之间的TCP连接。
# 配置允许从IPv6 MBGP对等体1:2::3:4接收的最大IPv6地址前缀数为10000。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer 1:2::3:4 route-limit 10000
peer { ipv6-group-name | ipv6-address } route-policy route-policy-name { import | export }
undo peer { ipv6-group-name | ipv6-address } route-policy route-policy-name { import | export }
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
route-policy-name:指定路由策略,为1~19个字符的字符串。
import:对从IPv6 MBGP对等体/对等体组接收的路由应用路由策略。
export:对向IPv6 MBGP对等体/对等体组发布的路由应用路由策略。
【描述】
peer route-policy命令用来对来自IPv6 MBGP对等体/对等体组的路由或向IPv6 MBGP对等体/对等体组发布的路由指定路由策略。undo peer route-policy命令用来取消已有配置。
缺省情况下,不指定IPv6 MBGP对等体/对等体组的路由策略。
peer route-policy命令不过滤路由策略中的if-match interface策略。
相关配置可参考“IP路由分册”中的“路由策略命令”。
# 对来自IPv6 MBGP对等体组test的路由应用名为test-policy的路由策略。
[Sysname] route-policy test-policy permit node 10
[Sysname-route-policy] if-match cost 10
[Sysname-route-policy] apply cost 65535
[Sysname-route-policy] quit
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] peer test route-policy test-policy import
undo preference
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
external-preference:EBGP路由(从EBGP对等体学来的最佳路由)的管理优先级,取值范围为1~255。
internal-preference:IBGP路由(从IBGP对等体学来的路由)的管理优先级,取值范围为1~255。
local-preference:IPv6 MBGP本地产生的路由的管理优先级,取值范围为1~255。
route-policy-name:路由策略名称,为1~19个字符的字符串。应用路由策略,可以为匹配过滤条件的特定路由配置优先级。对于那些没有匹配的路由,使用缺省优先级。
【描述】
preference命令用来配置EBGP路由、IBGP路由和本地产生的IPv6 MBGP路由的管理优先级。undo preference命令用来恢复缺省情况。
缺省情况下,EBGP路由的管理优先级为255,IBGP路由的管理优先级为255,本地产生的IPv6 MBGP路由的管理优先级为130。
每一种路由协议都有自己的优先级,协议的优先级将最后决定路由策略采用哪种路由协议获取的路由作为最佳路由。优先级的数值越大,其实际的优先级越低。
# 配置EBGP路由、IBGP路由和本地产生的IPv6 MBGP路由的管理优先级分别为20、20和200。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] preference 20 20 200
undo reflect between-clients
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
【描述】
reflect between-clients命令用来使能各客户机之间的路由反射。undo reflect between-clients命令用来禁止客户机之间的路由反射。
缺省情况下,允许客户机到客户机的路由反射。
路由反射器的客户机之间不要求是全连接的,路由缺省通过反射器从一个客户机反射到其它客户机;如果客户机之间是全连接的,建议使用undo reflect between-clients命令禁止客户间的路由反射,以减少系统开销。
相关配置可参考命令reflector cluster-idpeer reflect-client
# 允许客户机之间的路由反射。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] reflect between-clients
reflector cluster-id cluster-id
undo reflector cluster-id
IPv6 MBGP地址族视图
【缺省级别】
2:系统级
cluster-id:路由反射器的集群ID,可以为十进制整数(取值范围为1~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。
【描述】
reflector cluster-id命令用来配置路由反射器的集群ID。undo reflector cluster-id命令用来删除路由反射器的集群ID。
缺省情况下,每个路由反射器是使用自己的Router ID作为集群ID。
通常,一个集群里只有一个路由反射器。此时,由反射器的Router ID来识别该集群。配置多个路由反射器可提高网络的稳定性。如果一个集群中配有多个路由反射器,请使用reflector cluster-id命令为所有的路由反射器配置同样的集群ID,以避免路由环路的产生。
相关配置可参考命令reflect between-clientspeer reflect-client
# 本地路由器是集群中的路由反射器之一,配置它的集群ID为50。
[Sysname] bgp 100
[Sysname-bgp-af-ipv6-mul] reflector cluster-id 50
1.1.53  refresh bgp ipv6 multicast
refresh bgp ipv6 multicast { ipv6-address | all | external | group ipv6-group-name | internal } { export | import }
【缺省级别】
1:监控级
ipv6-address:软复位与指定IPv6 MBGP对等体的连接。
all:软复位所有IPv6 MBGP的连接。
external:软复位EBGP连接。
group ipv6-group-name:软复位与指定对等体组的连接,ipv6-group-name是对等体组名称,为1~47个字符的字符串。
internal:软复位IBGP连接。
export:触发出方向的软复位。
import:触发入方向的软复位。
【描述】
refresh bgp ipv6 multicast命令用来软复位IPv6 MBGP连接。IPv6 MBGP软复位可以在不中断IPv6 MBGP连接的情况下重新刷新Pv6 BGP路由表,并应用新的策略。
IPv6 MBGP软复位要求网络中的所有IPv6 MBGP路由器支持Route-refresh功能。如果有的路由器不支持此特性,则需要配置peer keep-all-routes命令,以便保留对等体的所有原始路由信息,供IPv6 MBGP软复位时使用。
# 对入方向的IPv6 MBGP连接进行软复位。
<Sysname> refresh bgp ipv6 multicast all import
reset bgp ipv6 multicast { as-number | ipv6-address | all | group ipv6-group-name | external | internal }
【缺省级别】
2:系统级
as-number:复位与指定自治系统号的IPv6 MBGP邻居的IPv6 MBGP连接。
ipv6-address:复位与指定IPv6 MBGP对等体的连接。
flap-info:清除路由震荡的历史信息。
all:复位所有IPv6 MBGP的连接。
group ipv6-group-name:复位与指定IPv6 MBGP对等体组的连接。
external:复位所有EBGP连接。
internal:复位所有IBGP连接。
【描述】
reset bgp ipv6 multicast命令用来复位指定的IPv6 MBGP连接,即断开指定的IPv6 MBGP连接后再与IPv6 MBGP对等体重新建立连接。
# 复位所有IPv6 MBGP连接。
<Sysname> reset bgp ipv6 multicast all
reset bgp ipv6 multicast dampening [ ipv6-address prefix-length ]
【缺省级别】
1:监控级
ipv6-address:要清除衰减信息的IPv6地址前缀。
【描述】
reset bgp ipv6 multicast dampening命令用来清除路由振荡衰减信息以及解除对已抑制路由的抑制。
不指定ipv6-address prefix-length时,清除整个IPv6 MBGP路由表中的IPv6 MBGP路由衰减信息。
# 清除到2345::/64的路由衰减信息并释放被抑制的路由。
<Sysname> reset bgp ipv6 multicast dampening 2345::64
reset bgp ipv6 multicast flap-info [ ipv6-address/prefix-length | regexp as-path-regexp | as-path-acl as-path-acl-number ]
【缺省级别】
1:监控级
as-path-regexp:清除匹配AS路径正则表达式的路由振荡统计信息。
as-path-acl-number:清除匹配指定AS路径列表号的路由振荡统计信息。as-path-acl-number的取值范围为1~256。
【描述】
reset bgp ipv6 multicast flap-info命令用来清除IPv6 MBGP路由的振荡统计信息。
如果没有指定参数,系统将清除所有路由振荡统计信息。
# 清除所有匹配AS路径过滤列表10的路由的振荡统计信息。
<Sysname> reset bgp ipv6 multicast flap-info as-path-acl 10
