- 28-WLAN Command Reference (AC)
- 01-Compatibility of hardware and AC functionality
- 02-AP management commands
- 03-Radio management commands
- 04-WLAN access commands
- 05-WLAN security commands
- 06-WLAN authentication commands
- 07-WIPS commands
- 08-WLAN QoS commands
- 09-WLAN roaming commands
- 10-WLAN load balancing commands
- 11-WLAN radio resource measurement commands
- 12-Channel scanning commands
- 13-Band navigation commands
- 14-WLAN multicast optimization commands
- 15-WLAN RRM commands
- 16-WLAN IP snooping commands
- 17-WLAN probe commands
- 18-Spectrum management commands
- 19-WLAN optimization commands
- 20-WLAN high availability commands
- 21-WLAN radio load balancing commands
- 22-User isolation commands
| 20-WLAN high availability commands | 160.03 KB |
display wlan ap backup multislot
wlan ap-backup hot-backup enable global
display dot1x connection-backup
display mac-authentication connection-backup
wlan client-backup hot-backup enable
wlan client-backup hot-backup delay
WLAN uplink detection commands
Dual-link backup commands
backup-ac
Use backup-ac to specify a backup AC.
Use undo backup-ac to remove the backup AC configuration.
backup-ac { ip ipv4-address | ipv6 ipv6-address }
undo backup-ac { ip | ipv6 }
In AP view, an AP uses the configuration in AP group view.
In AP group view, no backup AC is specified.
AP view
AP group view
ip ip-address: Specifies a backup AC by its IPv4 address.
ipv6 ipv6-address: Specifies a backup AC by its IPv6 address.
You can specify only one IPv4 address or one IPv6 address in either AP view or AP group view.
The configuration in AP view takes precedence over the configuration in AP group view. If you execute the undo command in AP view, the backup AC specified in AP group view will be used.
Executing the undo command also terminates the backup CAPWAP tunnel.
# Specify a backup AC for AP ap1.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] backup-ac ip 192.168.1.1
# Specify a backup AC for AP group group1.
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] backup-ac ip 192.168.1.1
wlan tunnel-preempt
Use wlan tunnel-preempt enable to enable master CAPWAP tunnel preemption.
Use wlan tunnel-preempt disable to disable master CAPWAP tunnel preemption.
Use undo wlan tunnel-preempt to restore the default.
wlan tunnel-preempt { disable | enable }
In AP view, an AP uses the configuration in AP group view. If no configuration exists in AP group view, the AP uses the configuration in global configuration view.
In AP group view, an AP uses the configuration in global configuration view.
In global configuration view, master CAPWAP tunnel preemption is disabled.
AP view
AP group view
Global configuration view
When this feature is enabled, the backup CAPWAP tunnel will become the master tunnel after a 10-minute delay if the backup AC has higher AP connection priority than the master AC.
When this feature is disabled, the backup CAPWAP tunnel becomes the master tunnel only when the master AC fails.
# Enable master CAPWAP tunnel preemption for AP ap1.
[Sysname-ap-ap1] wlan tunnel-preempt enable
# Enable master CAPWAP tunnel preemption for APs in AP group group1.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] wlan tunnel-preempt enable
# Enable master CAPWAP tunnel preemption globally.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] wlan tunnel-preempt enable
AP backup commands
Use display wlan ap backup multislot to display AP backup status for all IRF member ACs.
# Display AP backup status for all IRF member ACs.
<Sysname> display wlan ap backup multislot
Total number of slots: 2
Slot ID State
1 Active-backup
2 Active-only
Total number of slots |
Number of IRF member ACs. |
Slot ID |
IRF member ID of an AC. |
State |
AP backup status: · Active-backup—The AC is an active AC and backs up AP information. · Active-only—The AC is an active AC only. · Backup-only—The AC only backs up AP information. · Inactive—The AC is not active AC and does not back up AP information. |
Use wlan ap-backup hot-backup enable global to enable AP backup in an IRF fabric.
Use undo wlan ap-backup hot-backup enable global to disable AP backup in an IRF fabric.
AP backup is disabled.
AP backup enables the active AC (master AC) in an IRF fabric to synchronize information about connected APs to all the non-active ACs. When the active AC fails, one of the non-active ACs becomes active to provide services, ensuring service continuity.
This feature does not take effect on online APs. Disabling this feature removes backup AP information from all ACs.
# Enable AP backup.
[Sysname] wlan ap-backup hot-backup enable global
Client backup commands
Use display dot1x connection-backup to display backup information about 802.1X clients associated with the specified AC.
display dot1x connection-backup [ ap ap-name [ radio radio-id ] ] slot slot-number
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify an AP, this command displays backup information about all 802.1X clients.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command displays backup information about 802.1X clients associated with all radios of the specified AP.
slot slot-number: Specifies an IRF member device by its member ID.
# Display backup information about 802.1X clients associated with AP ap1 connected to IRF member device 1.
<Sysname> display dot1x connection-backup ap ap1 slot 1
Total backup connections: 1
User MAC address : 0015-e9a6-7cfe
AP name : ap1
Radio ID : 1
SSID : EASY
BSSID : 0015-e9a6-7cf0
Username : ias
IPv4 address : 192.168.1.1
IPv6 address : 2000:0:0:0:1:2345:6789:abcd
Authentication method : CHAP
Authentication domain : 1
Initial VLAN : 1
Authorization VLAN : 100
Authorization ACL number : 3001
Authorization user profile : N/A
Authorization CAR :
Average input rate : 102400 bps
Average output rate : 102400 bps
Authorization URL : N/A
Termination action : Radius-request
Session timeout period : 2 sec
Online from : 2017/03/02 13:14:15
Online duration : 0h 2m 15s
Total backup connections |
Number of backup 802.1X clients. |
User MAC address |
MAC address of the client. |
AP name |
Name of the AP with which the client is associated. |
Radio ID |
ID of the radio with which the client is associated. |
SSID |
SSID with which the client is associated. |
BSSID |
ID of the BSS with which the client is associated. |
Username |
Username of the client. |
IPv4 address |
IPv4 address of the client. If the device does not obtain the IPv4 address of the client, this field is not displayed. |
IPv6 address |
IPv6 address of the client. If the device does not obtain the IPv6 address of the client, this field is not displayed. |
Authentication method |
EAP message handling method: · CHAP—Performs EAP termination and uses CHAP to communicate with the RADIUS server. · EAP—Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server. · PAP—Performs EAP termination and uses PAP to communicate with the RADIUS server. |
Authentication domain |
Name of the ISP domain for authentication. |
Initial VLAN |
VLAN to which the client belongs before 802.1X authentication. |
Authorization VLAN |
VLAN authorized to the client. |
Authorization ACL number |
ACL authorized to the client. |
Authorization user profile |
User profile authorized to the client. |
Authorization CAR |
Authorization CAR: · Average input rate—Average uplink rate in bps. · Average output rate—Average downlink rate in bps. · N/A—This field displays N/A if the authentication server is not configured with authorization CAR for users. |
Authorization URL |
Redirect URL authorized to the client. |
Termination action |
Action attribute assigned by the server to terminate the user session: · Default—Logs off the online authenticated 802.1X client when the session timeout timer expires. This attribute does not take effect when 802.1X periodic reauthentication is enabled and the periodic reauthentication timer is shorter than the session timeout timer. · Radius-request—Reauthenticates the online client when the session timeout timer expires, regardless of whether the 802.1X periodic reauthentication feature is enabled or not. If the device performs local authentication, this field displays N/A. |
Session timeout period |
Session timeout timer assigned by the server. If the device performs local authentication, this field displays N/A. |
Online from |
Time from which the 802.1X client came online. |
Online duration |
Online duration of the 802.1X client. |
Use display mac-authentication connection-backup to display backup information about MAC authentication clients associated with the specified AC.
display mac-authentication connection-backup [ ap ap-name [ radio radio-id ] ] slot slot-number
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify an AP, this command displays backup information about all MAC authentication clients.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command displays backup information about MAC authentication clients associated with all radios of the specified AP.
# Display backup information about MAC authentication clients associated with AP ap1 connected to IRF member device 1.
<Sysname> display mac-authentication connection-backup ap ap1 slot 1
AP name : ap1
Radio ID : 1
SSID : EASY
Username : ias
Initial VLAN : 1
Authorization CAR :
Number of backup MAC authentication clients. |
User MAC address |
AP name |
Radio ID |
SSID |
BSSID |
Username |
Initial VLAN |
VLAN to which the client belongs before MAC authentication. |
Authorization CAR |
Authorization URL |
Action attribute assigned by the server when the session timeout timer expires. The following server-assigned action attributes are available: · Default—Logs off the online authenticated user when the session timeout timer expires. · Radius-request—Reauthenticates the online user when the session timeout timer expires. If the device performs local authentication, this field displays N/A. |
Online from |
Time from which the MAC authentication client came online. |
Online duration |
Online duration of the MAC authentication client. |
display wlan client-backup
Use display wlan client-backup to display backup client information.
In standalone mode:
display wlan client-backup [ ap ap-name [ radio radio-id ] | mac-address mac-address ] [ verbose ]
In IRF mode:
display wlan client-backup [ ap ap-name [ radio radio-id ] | mac-address mac-address ] [ verbose ] [ slot slot-number ]
ap-name name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command displays client backup information for all radios on the specified AP.
mac-address mac-address: Specifies the MAC address of a client.
verbose: Displays detailed client information. If you do not specify this keyword, the command displays brief client information.
slot slot-number: Specifies an IRF member device by its member ID. (In IRF mode.)
If you do not specify the ap ap-name [ radio radio-id ] option, this command displays all client information backed up on the device.
# Display brief backup client information in slot 2.
<Sysname> display wlan client-backup slot 2
Total number of clients: 3
MAC address Username AP name RID IP address IPv6 address VLAN
7854-2e1c-c59e user ap1 1 1.1.1.1 1::2:0:0:3 1
000b-c002-9d09 N/A 5866-ba74-e780 1 192.168.33.16 200
000f-e265-6400 N/A ap2 1 1.3.1.2 100
MAC address |
Username |
Username of the client. · If the client uses 802.1X or MAC authentication, this field displays the username used for authentication. · If the client does not use 802.1X or MAC authentication, this field displays N/A. NOTE: If the client uses portal authentication, this field will not display the portal username of the client. |
AP name |
Name of the AP associated with the client. |
RID |
ID of the radio associated with the client. |
IP address |
IPv4 address of the client. |
IPv6 address |
IPv6 address of the client. |
VLAN |
VLAN to which the client belongs. |
# Display detailed backup client information in slot 2.
<Sysname> display wlan client-backup slot 2 verbose
Total number of clients: 1
MAC address : 000f-e265-6400
IPv4 address : 10.1.1.114
IPv6 address : 2001::1234:5678:0102:0304
Username : N/A
AID : 1
AP ID : 1
AP name : ap1
Radio ID : 1
SSID : office
BSSID : 0026-3e08-1150
VLAN ID : 3
Sleep count : 1
Power save mode : Active
Wireless mode : 802.11ac
Channel bandwidth : 80MHz
SM power save : Enabled
SM power save mode : Dynamic
Short GI for 20MHz : Supported
Short GI for 40MHz : Supported
Short GI for 80MHz : Supported
Short GI for 160/80+80MHz : Not supported
STBC RX capability : Not supported
STBC TX capability : Not supported
LDPC RX capability : Not supported
SU beamformee capability : Not supported
MU beamformee capability : Not supported
Beamformee STS capability : N/A
Block Ack : TID 0 In
Supported VHT-MCS set : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8
NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8
Supported HT MCS set : 0, 1, 2, 3, 4, 5, 6, 7,
8, 9, 10, 11, 12, 13, 14,
15, 16, 17, 18, 19, 20,
21, 22, 23
Supported rates : 6, 9, 12, 18, 24, 36,
48, 54 Mbps
QoS mode : WMM
Listen interval : 10
RSSI : 62
Rx/Tx rate : 130/11 Mbps
Authentication method : Open system
Security mode : PRE-RSNA
AKM mode : Not configured
Cipher suite : N/A
User authentication mode : Bypass
Authorization ACL ID : 3001(Not effective)
Roam status : N/A
Key derivation : SHA1
PMF status : Enabled
Forward policy : Not configured
Online time : 0 days 0 hours 1 minutes 13 seconds
FT status : Inactive
Table 5 Command output
MAC address |
IPv4 address |
IPv4 address of the client. If no IPv4 address is available, this field displays N/A. |
IPv6 address |
IPv6 address of the client. If no IPv6 address is available, this field displays N/A. |
Username |
Username of the client. · If the client uses 802.1X or MAC authentication, this field displays the username used for authentication. · If the client does not uses 802.1X or MAC authentication, this field displays N/A. NOTE: If the client uses portal authentication, this field will not display the portal username of the client. |
AID |
Association ID of the client. |
AP ID |
ID of the AP associated with the client. |
AP name |
Radio ID |
SSID |
SSID associated with the client. |
VLAN ID |
ID of the VLAN to which the client belongs. |
Sleep count |
Number of transitions to the sleep state. |
Power save mode |
Power saving mode of the client: · Active. · Sleep. |
Wireless mode |
Radio mode of the client: · 802.11a. · 802.11b. · 802.11g. · 802.11gn. · 802.11an. · 802.11ac. |
Channel bandwidth |
Channel bandwidth: · 20 MHz. · 40 MHz. · 80 MHz. · 160 MHz. |
SM power save |
SM power save status: · Enabled—Only one antenna of the client operates in active state, and others operate in sleep state to save power. · Disabled. |
SM power save mode |
Power saving mode: · Dynamic. · Static. |
Short GI for 20MHz |
Whether the client supports short GI when its channel bandwidth is 20 MHz: · Supported. · Not supported. |
Short GI for 40MHz |
Whether the client supports short GI when its channel bandwidth is 40 MHz: · Supported. · Not supported. |
Short GI for 80MHz |
Whether the client supports short GI when its channel bandwidth is 80 MHz: · Supported. · Not supported. |
Short GI for 160/80+80MHz |
Whether the client supports short GI when its channel bandwidth is 160 MHz or 80 + 80 MHz: · Supported. · Not supported. |
STBC RX capability |
Client STBC receive capability: · Supported. · Not supported. |
STBC Tx capability |
Client STBC transmit capability: · Supported. · Not supported. |
LDPC Rx capability |
Client LDPC receive capability; · Supported. · Not supported. |
SU beamformee capability |
Client SU beamformee capability: · Supported. · Not supported. |
MU beamformee capability |
Client MU beamformee capability: · Supported. · Not supported. |
Beamformee STS capability |
Client beamformee STS capability. This field displays N/A if the feature is not supported. |
Negotiation result of Block ACK with TID: · TID 0 In—Sends Block ACK for inbound traffic. · TID 0 Out—Sends Block ACK for outbound traffic. · TID 0 Both—Sends Block ACK for both inbound and outbound traffic. · N/A—Does not send Block ACK for both inbound and outbound traffic. |
Supported VHT-MCS set |
VHT-MCS supported by the client. |
Supported HT MCS set |
Supported rates |
Rates supported by the client, in Mbps. |
QoS mode |
QoS mode: · N/A—WMM is not supported. · WMM—WMM is supported. An AP and a client negotiates WMM information. This field displays WMM only when both the AP and the client support WMM. |
Listen interval |
Interval at which the client wakes up to listen for beacon frames. It is counted by beacon interval. |
RSSI |
Received signal strength indication. This value indicates the client signal strength detected by the AP. |
Rx/Tx rate |
Sending and receiving rates of data, management, and control frames, in Mbps. |
Authentication method: · Open system. · Shared key. |
Security mode |
Security mode: · RSN—Beacons and probe responses carry RSN IE. · WPA—Beacons and probe responses carry WPA IE. · PRE-RSNA—Beacons and probe responses do not carry RSN IE or WPA IE. |
AKM mode |
AKM mode: · 802.1X. · PSK. This field displays Not configured if no AKM mode is configured. |
Cipher suite |
Cipher suite: · N/A. · WEP40. · WEP104. · WEP128. · CCMP. · TKIP. |
User authentication mode |
User authentication mode: · Bypass—No client authentication. · MAC. · 802.1X. · OUI. |
Authorized ACL number. · This field displays the ACL number if the authorized ACL takes effect. · This field displays ACL number(Not effective) if the authorized ACL does not take effect. · This field displays N/A if the authentication server is configured without any authorization ACL. |
Name of the authorized user profile. · This field displays the authorized user profile name if the authorized user profile takes effect. · This field displays authorized user profile name(Not effective) if the authorized user profile does not take effect. · This field displays N/A if the authentication server is configured without any authorization user profile. |
Roam status |
Roam status: · Roaming in progress. · Inter-AC roam. · Inter-MA roam. · Intra-AC roam. · Intra-MA roam. This field displays N/A if the client stays in one BSS after coming online. |
Key derivation |
Key derivation type: · SHA1—Uses the HMAC-SHA1 hash algorithm. · SHA256—Uses the HMAC-SHA256 hash algorithm. This field displays N/A if no key derivation algorithm is involved for the authentication type. |
PMF status |
PMF status: · Enabled—Management frame protection is enabled. · Disabled—Management frame protection is disabled. This field displays N/A if management frame protection is not involved. |
Forward policy |
Name of the WLAN forwarding policy. This field displays Not configured if no WLAN forwarding policy is configured. |
Online time |
Client online duration. |
FT status |
Fast BSS transition (FT): · Active—FT is enabled. · Inactive—FT is disabled. |
Use wlan client-backup hot-backup enable to enable client backup in an IRF fabric.
Use undo wlan client-backup hot-backup enable to disable client backup in an IRF fabric.
Client backup is disabled in an IRF fabric.
For this command to take effect, make sure AP backup is enabled.
After client backup is enabled, an active AC backs up information about associated clients to other member ACs. When the active AC fails, the associated clients can associate with another member AC so that the clients are always online. Client backup is triggered every time client information changes.
This command takes effect only on clients that come online after client backup is enabled. Disabling client backup deletes client backup information from all member ACs.
# Enable client backup.
[Sysname] wlan client-backup hot-backup enable
Use wlan client-backup hot-backup delay to set the client backup delay.
Use undo wlan client-backup hot-backup delay to restore the default.
wlan client-backup hot-backup delay delay-time
The client backup delay is 60 seconds.
delay-time: Specifies the client backup delay time in the range of 0 to 300 seconds. If you set the delay time to 0, the AC backs up information changes about associated clients to other ACs in real time.
This feature takes effect only when client backup is enabled.
This command takes effect only on clients that come online after the client backup delay is set.
If an active/standby switchover occurs during the delay time, online clients whose information has not been backed up will be logged off and need to come online again. An active/standby switchover can be triggered by a restart of the active AC process.
# Set the client backup delay to 240 seconds.
<System> system-view
[System] wlan client-backup hot-backup delay 240
wlan uplink track
Use wlan uplink track to associate a track entry with WLAN uplink detection.
Use undo wlan uplink track to restore the default.
wlan uplink track track-entry-number
WLAN uplink detection is not associated with any track entry.
track-entry-number: Specifies a track entry ID in the range of 1 to 1024.
This command enables the AC to adjust radio state based on the uplink state associated with a track entry. When the track entry is in Negative state, the AC disables radios of all connected APs. When the track entry is in Positive state, the AC enables radios of all connected APs.
# Associate track entry 1 with WLAN uplink detection.
[Sysname] wlan uplink track 1
