28-WLAN Command Reference (AC)
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References(V7)-R6749-6W10328-WLAN Command Reference (AC)
01-Compatibility of hardware and AC functionality
This document describes MSR routers that can function as ACs and compatible APs.
MSR routers that support Wi-Fi4 & Wi-Fi5 APs
Table 1 MSR routers that support Wi-Fi4 and Wi-Fi5 APs
MSR routers
Compatible APs
MSR810-W
MSR810-W-DB
MSR810-LM
MSR810-LM-HK
MSR810-LM-CNDE-SJK
MSR810-CNDE-SJK
MSR810-W-LM
MSR810-W-LM-HK
MSR810-LME
MSR2600-6-X1
MSR2600-10-X1
MSR3600-28-X1
MSR3600-28-X1-DP
MSR3600-51-X1
MSR3600-51-X1-DP
MSR3610-X1-DP
MSR3610-X1-DP-DC
MSR3610-I-DP
MSR3610-IE-DP
MSR3610-IE-EAD
MSR3610-IE-ES
MSR-EAD-AK770
MSR2630-G-X1
MSR3600-28-G-DP
MSR3600-28-G-X1-DP
MSR3600-51-G-DP
MSR3600-51-G-X1-DP
WA4320i-ACN
WA4320H-ACN
WA4320-CAN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
WA4320-ACN-SI
WA4320H
WA4320H-EI
WA5320
WA5320H
WA5320E
WA5320i
WA5320-SI
WA5530
WA5530-SI
WA5620
WA5620i-CAN
SIC-AP320 (supported only by MSR2600-6-X1, MSR3610-X1-DP, MSR3610-X1-DP-DC, MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-EAD, MSR3610-IE-ES, and MSR-EAD-AK770)
WA4320-H20
WA4320H-SI
SIC-AP220 (supported only by MSR3600-28-X1, MSR3600-28-X1-DP, MSR3600-51-X1, MSR3600-51-X1-DP, MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-EAD, MSR3610-IE-ES, and MSR-EAD-AK770)
MSR810-LM-EI
MSR-iMC
MSR1004S-5G-CN
MSR1104S-5G-CN
WA5320
WA5320H
WA5320E
WA5320i
WA5320-SI
WA5530
WA5530-SI
WA5620
WA5620i-CAN
WA4320-H20
WA4320H-ACN
WA4320H-SI
MSR810
MSR810-10-PoE
MSR830-10HI-GL
MSR3610-X1
MSR3610-X1-DC
MSR3620-DP
MSR3610-I-DP+DDR4-8GB
MSR3610-IE-DP+DDR4-16GB
MSR3610-I-IG
MSR3610-IE-IG
MSR3620-X1
MSR3640-X1
MSR3640-X1-HI
WA4320i-ACN
WA4320H-ACN
WA4320-ACN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
WA4320-ACN-SI
WA4320H
WA4320H-EI
WA5320
WA5320H
WA5320E
WA5320i
WA5320-SI
WA5530
WA5530-SI
WA5620
WA5620i-ACN
WA510H-WW
WA530-WW
WA530X-WW
WA536-WW
WA538-WW
WA560-WW
SIC-AP320 (supported only by MSR3610-X1, MSR3610-X1-DC, MSR3610-I-DP, MSR3610-IE-DP, MSR3610-I-IG, MSR3610-IE-IG, MSR3620-X1, MSR3640-X1, and MSR3640-X1-HI)
WA4320-H20
WA4320H-SI
SIC-AP220 (supported only by MSR3610-I-DP, MSR3610-IE-DP, MSR3610-I-IG, and MSR3610-IE-IG)
MSR810-EI
MSR1004S-5G
MSR2600-15-X1
WA5320
WA5320H
WA5320E
WA5320i
WA5320-SI
WA5530
WA5530-SI
WA5620
WA5620i-ACN
WA4320-H20
WA4320H-ACN
WA4320H-SI
WA510H-WW
WA530-WW
WA530X-WW
WA536-WW
WA538-WW
WA560-WW
MSR810-LM-GL
MSR810-W-LM-GL
MSR830-6EI-GL
MSR830-10EI-GL
MSR830-6HI-GL
MSR2600-6-X1-GL
MSR1004S-5G-GL
MSR810-LM-EA
MSR810-LMS-EA
WA510H-WW
WA530-WW
WA530X-WW
WA536-WW
WA538-WW
WA560-WW
MSR860-6EI-XS
MSR860-6HI-XS
MSR2600-15-X1-XS
MSR2630-XS
MSR3600-28-XS
MSR3610-XS
MSR3610-I-XS
MSR3610-IE-XS
MSR3620-XS
MSR3620-X1-XS
MSR3640-XS
MSR3660-XS
WA2610H
WA2610H-LI
WA4320H-SI
WA4320-ACN-E
WA4320-ACN-D
WA4320-ACN-C
WA4320i-X
WA4320H
WA5320H-LI
WA5320-D
WA5320-C
WA5320-C-IOT
WA5320
WA5320i-LI
WA5320H
WA5320-C-EI
WA5320X-E
WA5320X-SI
WA5320X
WA5320X-LI
WA5530S
WA5530-LI
WA5530
SIC-AP320 (supported only by MSR2600-15-X1-XS, MSR2630-XS, MSR3610-XS, MSR3610-I-XS, MSR3610-IE-XS, MSR3620-X1-XS, MSR3640-XS, and MSR3660-XS)
MSR810-W-WiNet
MSR810-LM-WiNet
MSR830-4LM-WiNet
MSR830-6EI-WiNet
MSR830-5BEI-WiNet
MSR830-10BEI-WiNet
MSR830-6BHI-WiNet
MSR830-10BHI-WiNet
MSR2600-6-WiNet
MSR2600-10-X1-WiNet
MSR3620-X1-WiNet
EWP-WAP712C-HI-FIT
EWP-WAP712C-LI
EWP-WAP712C-LI-G-FIT
EWP-WAP712C-LI-S-FIT
EWP-WAP712E-FIT
EWP-WAP722E-W2-FIT
EWP-WAP722S-W2
EWP-WAP722S-W2-FIT
EWP-WAP722S-W2-IOT-FIT
EWP-WAP922
EWP-WAP922E-FIT
WAP722S-HI
EWP-WAP723-W2-FIT
EWP-WAP923-FIT
EWP-WAP711H
EWP-WAP711H-FIT-G
EWP-WAP711H-FIT-W
EWP-WAP712H-FIT
EWP-WAP712H-G
EWP-WAP722H-FIT
EWP-WAP922H
EWP-WAP712X-FIT
EWP-WAP722XS-W2-FIT
EWP-WAP722X-W2
EWP-WAP722X-W2-FIT
EWP-WAP922X
EWP-WA2620E-WiNet-FIT
EWP-WA2620-WiNet-FIT
EWP-WA5320E-WiNet-FIT
EWP-WA5320H-WiNet-FIT
EWP-WA5320-WiNet-FIT
MSR610
MSR830-10HI-GL
WA530-WW
MSR routers that support Wi-Fi6 APs
Table 2 MSR routers that support Wi-Fi6 APs
MSR routers
Compatible APs
MSR810-W
MSR810-W-DB
MSR810-LM
MSR810-LM-HK
MSR810-LM-CNDE-SJK
MSR810-CNDE-SJK
MSR810-W-LM
MSR810-W-LM-HK
MSR810-LME
MSR810-LM-EI
MSR2600-6-X1
MSR2600-10-X1
MSR3600-28-X1
MSR3600-28-X1-DP
MSR3600-51-X1
MSR3600-51-X1-DP
MSR3610-X1-DP
MSR3610-X1-DP-DC
MSR3610-I-DP
MSR3610-IE-DP
MSR3610-IE-EAD
MSR3610-IE-ES
MSR-EAD-AK770
MSR-iMC
MSR1004S-5G-CN
MSR1104S-5G-CN
MSR2630-G-X1
MSR3600-28-G-X1-DP
MSR3600-51-G-X1-DP
WA6322
WA6338
WA6322H
WA6320-SI
WA6338-HI
WA6320-SI-H20
WA6320-HI
WA6528
WA6530
WA6522H-HI
WA6522
WA6520-HI
WA6620
WA6638i
WA6330
WA6320
WA6320H
WA6526
WA6526E
WA6520
WA6622
WA6628
WA6638
WA6620X
WA6636
MSR810
MSR810-EI
MSR810-10-PoE-Plus
MSR830-10HI-GL
MSR3610-X1
MSR3610-X1-DC
MSR3620-DP
MSR3610-I-IG
MSR3610-IE-IG
MSR3620-X1
MSR3640-X1
MSR3640-X1-HI
MSR2600-15-X1
MSR1004S-5G
WA6322
WA6338
WA6322H
WA6320-SI
WA6338-HI
WA6320-SI-H20
WA6320-HI
WA6528
WA6530
WA6522H-HI
WA6522
WA6520-HI
WA6620
WA6638i
WA6330
WA6320
WA6320H
WA6526
WA6526E
WA6520
WA6622
WA6628
WA6638
WA6630X
WA6620X
WA6636
MSR810-LM-GL
MSR810-W-LM-GL
MSR830-6EI-GL
MSR830-10EI-GL
MSR830-6HI-GL
MSR2600-6-X1-GL
MSR1004S-5G-GL
MSR810-LM-EA
MSR810-LMS-EA
WA6330
WA6320
WA6320H
WA6526
WA6526E
WA6622
WA6628
WA6638
WA6630X
WA6620X
MSR860-6EI-XS
MSR860-6HI-XS
MSR2630-XS
MSR3600-28-XS
MSR3610-XS
MSR3610-I-XS
MSR3610-IE-XS
MSR3620-XS
MSR3620-X1-XS
MSR3640-XS
MSR3660-XS
MSR2600-15-X1-XS
WA6330-LI
WA6320-C
WA6320-D
WA6320H-LI
WA6320S-E
WA6320S-C
WA6530-LI
WA6522-C
WA6520-C
WA6520S-C
WA6520S-E
WA6522H-LI
WA6520S-D
WA6520H-LI
WA6522H-D
MSR610
MSR830-10HI-GL
WA6126
WA6120
WA6120H
WA6120X
WA6020
WA6022H
Wireless AC licenses
The default number of supported APs on a device varies by device model. You can purchase and install licenses to increase the number of supported APs. The maximum number of supported APs on a device also varies by device model. For more information about licenses, see managing licenses in Fundamentals Configuration Guide.
Table 3 Default number and maximum number of supported APs
Model
Default number of supported APs
Max number of supported APs
MSR610
0
64
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
·     MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK: 2
·     MSR810-EI, MSR810-LM-EA, MSR810-LM-EI: 0
16
MSR810-LMS, MSR810-LUS
N/A
N/A
MSR810-SI, MSR810-LM-SI
N/A
N/A
MSR810-LMS-EA, MSR810-LME
4
16
MSR1004S-5G, MSR1004S-5G-CN
0
32
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL
·     MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-W-5G-CN, MSR1104S-W-5GGL: N/A
·     MSR1104S-5G-CN: 0
·     MSR1104S-5G-CN: 32
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
·     MSR2600-6-X1: 2
·     MSR2600-15-X1: 0
·     MSR2600-15-X1-T: N/A
·     MSR2600-6-X1: 64
·     MSR2600-15-X1: 32
MSR2600-10-X1
0
64
MSR2630-G-X1
0
32
MSR 2630
2
64
MSR3600-28, MSR3600-51
2
64
MSR3600-28-SI, MSR3600-51-SI
N/A
N/A
2
64
MSR3600-28-G-DP, MSR3600-51-G-DP
0
64
MSR3600-28-G-X1-DP, MSR3600-51-G-X1-DP
0
64
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
·     MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-I-IG, MSR3610-IE-IG: 2
·     MSR3610-IE-EAD, MSR-EAD-AK770: 0
·     MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-I-IG, MSR3610-IE-IG: 256
·     MSR3610-IE-EAD, MSR-EAD-AK770: 128
MSR-iMC
0
128
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
·     MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC: 2
·     MSR3620-X1, MSR3640-X1: 0
256
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
2
256
MSR3610-G, MSR3620-G
N/A
N/A
MSR3640-G
N/A
N/A
MSR3640-X1-HI
0
256
Model
MSR810-W-WiNet, MSR810-LM-WiNet
4
16
MSR830-4LM-WiNet
4
16
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
4
16
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
4
16
MSR2600-6-WiNet
2
16
MSR2600-10-X1-WiNet
2
16
MSR2630-WiNet
N/A
N/A
MSR3600-28-WiNet
N/A
N/A
MSR3610-X1-WiNet
N/A
N/A
MSR3620-X1-WiNet
0
256
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
N/A
N/A
Model
MSR860-6EI-XS
0
8
MSR860-6HI-XS
0
8
MSR2600-15-X1-XS
0
32
MSR2630-XS
0
64
MSR3600-28-XS
0
64
MSR3610-XS
0
256
MSR3620-XS
0
256
MSR3610-I-XS
0
256
MSR3610-IE-XS
0
256
MSR3620-X1-XS
0
256
MSR3640-XS
0
256
MSR3660-XS
0
256
Model
MSR810-LM-GL
0
16
MSR810-W-LM-GL
0
16
MSR830-6EI-GL
0
16
MSR830-10EI-GL
0
16
MSR830-6HI-GL
0
16
MSR830-10HI-GL
0
16
MSR1004S-5G-GL
0
32
MSR2600-6-X1-GL
0
64
MSR3600-28-SI-GL
N/A
N/A
