28-WLAN Command Reference (AC)
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References(V7)-R6749-6W10328-WLAN Command Reference (AC)
16-WLAN IP snooping commands
16-WLAN IP snooping commands 76.64 KB
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
client ip-snooping http-learning enable
Use client ip-snooping http-learning enable to enable snooping HTTP and HTTPS requests redirected to the portal server.
Use undo client ip-snooping http-learning enable to disable snooping HTTP and HTTPS requests redirected to the portal server.
Snooping HTTP and HTTPS requests is disabled.
Service template view
An AC can use this method to learn IP addresses of clients performing portal authentication. For more information about portal authentication, see Security Configuration Guide.
The priorities for learning IP addresses through snooping DHCP packets, ARP or ND packets, and HTTP/HTTPS requests are in descending order.
Make sure the service template is disabled when you execute this command.
# Enable snooping HTTP and HTTPS requests.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] client ip-snooping http-learning enable
client ip-snooping ip-recover enable
Use client ip-snooping ip-recover enable to enable IP address recovery for reassociated clients.
Use undo client ip-snooping ip-recover enable to disable IP address recovery for reassociated clients.
client ip-snooping ip-recover enable [ delay time ]
IP address recovery is disabled for reassociated clients.
delay time: Specifies the IP address recovery period, in the range of 5 to 300 seconds. The default value is 10.
This feature takes effect only on clients association of which is performed at the AC.
After a roaming, clients might fail to obtain new IP addresses through DHCP, DHCPv6, or ND for a long time, because the previously obtained addresses have not expired. If IP source guard is enabled, data packets from such clients will be discarded. To resolve the issue, you can enable IP address recovery for reassociated clients.
With this feature enabled, the AC reports the IP and MAC addresses of a client to the WLAN roaming center when the client leaves an AP. If the client fails to obtain a new address within the address recovery period after the roaming, it retrieves the old address from the WLAN roaming center for temporary network access.
After obtaining a new address, the client will update its address and use the new address to access the network.
# Enable IP address recovery for reassociated clients.
[Sysname-wlan-st-service1] client ip-snooping ip-recover enable delay 5
client ip-cache aging-time
client ipv4-snooping arp-learning enable
Use client ipv4-snooping arp-learning enable to enable snooping ARP packets.
Use undo client ipv4-snooping arp-learning enable to disable snooping ARP packets.
Snooping ARP packets is enabled.
# Disable snooping ARP packets.
[Sysname-wlan-st-service1] undo client ipv4-snooping arp-learning enable
client ipv4-snooping dhcp-learning enable
Use client ipv4-snooping dhcp-learning enable to enable snooping DHCPv4 packets.
Use undo client ipv4-snooping dhcp-learning enable to disable snooping DHCPv4 packets.
Snooping DHCPv4 packets is enabled.
# Disable snooping DHCPv4 packets.
[Sysname-wlan-st-service1] undo client ipv4-snooping dhcp-learning enable
client ipv4-snooping dhcp-learning timeout
Use client ipv4-snooping dhcp-learning timeout to set the timeout for IPv4 address learning through DHCP.
Use undo client ipv4-snooping dhcp-learning timeout to restore the default.
client ipv4-snooping dhcp-learning timeout time
The timeout is 0 and the system does not log off clients that fail to obtain an IPv4 address through DHCP.
time: Specifies the timeout in the range of 1 to 600 seconds.
With the timeout set, the system logs off clients that fail to obtain an IPv4 address through DHCP within the specified period.
Make sure the service template is enabled before you execute this command.
This configuration takes effect only on clients coming online afterwards from the AC.
# Set the timeout to 180 seconds for IPv4 address learning through DHCP.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] client ipv4-snooping dhcp-learning timeout 180
client ipv6-snooping dhcpv6-learning enable
Use client ipv6-snooping dhcpv6-learning enable to enable snooping DHCPv6 packets.
Use undo client ipv6-snooping dhcpv6-learning enable to disable snooping DHCPv6 packets.
Snooping DHCPv6 packets is disabled.
# Disable snooping DHCPv6 packets.
[Sysname-wlan-st-service1] client ipv6-snooping dhcpv6-learning enable
client ipv6-snooping nd-learning enable
Use client ipv6-snooping nd-learning enable to enable snooping ND packets.
Use undo client ipv6-snooping nd-learning enable to disable snooping ND packets.
Snooping ND packets is disabled.
# Disable snooping ND packets.
[Sysname-wlan-st-service1] undo client ipv6-snooping nd-learning enable
client ipv6-snooping snmp-nd-report enable
Use client ipv6-snooping snmp-nd-report enable to enable SNMP to obtain client IPv6 addresses learned from ND packets.
Use undo client ipv6-snooping snmp-nd-report enable to disable SNMP from obtaining client IPv6 addresses learned from ND packets.
SNMP obtains client IPv6 addresses learned from both DHCPv6 and ND packets.
# Disable SNMP from obtaining client IPv6 addresses learned from ND packets.
[Sysname-wlan-st-service1] undo client ipv6-snooping snmp-nd-report enable
display wlan statistics client-ip-conflict
Use display wlan statistics client-ip-conflict to display statistics about clients with conflict IP addresses.
# Display statistics about clients with conflict IP addresses.
<Sysname> display wlan statistics client-ip-conflict
IP             New-MAC/APID             Old-MAC/APID     Time
192.168.1.1    a4c1-5b79-fa5b/1     1111-e121-ff00/2     03-22 10:00:00
ff03::101      22d3-c5b7-a4b5/2     000d-88f8-0577/1     03-22 10:01:00
IP
Conflict IP obtained by the client.
New-MAC/APID
MAC address of the new client and the ID of the AP from which that client comes online.
Old-MAC/APID
MAC address of the old client and the ID of the AP to which the client is associated.
Time
Time when the client requested to add the IPCIM after it obtained a conflict IP address.
wlan client ip-conflict-detection enable
Use wlan client ip-conflict-detection enable to enable IP address conflict detection.
Use undo wlan client ip-conflict-detection enable to disable IP address conflict detection.
IP address conflict detection is enabled.
This feature enables the system to detect IP address conflicts between a client attempting to come online and online clients. The system logs off the online clients that use the same IP address as the new client and creates IP address conflict entries for the clients. The system deletes the IP address conflict entry for a client when the client cache expires or the client's IP address changes.
In an AC hierarchy network, you can disable IP address conflict detection on the central AC if portal authentication has been disabled or accounting has been disabled for 802.1X or MAC authentication clients. This allows clients from different local ACs to come online with the same IP address, simplifying DHCP configuration.
# Disable IP address conflict detection.
<Sysname> system
[Sysname] undo wlan client ip-conflict enable
client cache aging-time
