- 28-WLAN Command Reference (AC)
- 01-Compatibility of hardware and AC functionality
- 02-AP management commands
- 03-Radio management commands
- 04-WLAN access commands
- 05-WLAN security commands
- 06-WLAN authentication commands
- 07-WIPS commands
- 08-WLAN QoS commands
- 09-WLAN roaming commands
- 10-WLAN load balancing commands
- 11-WLAN radio resource measurement commands
- 12-Channel scanning commands
- 13-Band navigation commands
- 14-WLAN multicast optimization commands
- 15-WLAN RRM commands
- 16-WLAN IP snooping commands
- 17-WLAN probe commands
- 18-Spectrum management commands
- 19-WLAN optimization commands
- 20-WLAN high availability commands
- 21-WLAN radio load balancing commands
- 22-User isolation commands
| 02-AP management commands | 990.47 KB |
dhcp snooping information circuit-id
dhcp snooping information enable
display wlan ap all feature band-navigation
display wlan ap all feature capwap
display wlan ap connection-record
display wlan ap running-configuration
display wlan ap statistics association-failure-record
display wlan ap statistics image-download
display wlan ap statistics online-record
display wlan ap statistics tunnel-down-record
display wlan ap tunnel latency
display wlan ap unauthenticated
display wlan ap-distribution ap-name
region-code (AP provision view/AP group provision view)
region-code (AP view/AP group view)
region-code (global configuration view)
remote-configuration synchronize
reset wlan ap connection-record
snmp-agent trap enable wlan ap
snmp-agent trap enable wlan capwap
statistics-interval fast-report
wlan ap-authentication permit-unauthenticated
wlan ap-certificate verification
wlan capwap discovery-policy unicast
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
ac
Use ac to specify an AC for an AP.
Use undo ac to delete the specified AC information.
ac { host-name hostname | ip ipv4-address }
undo ac { host-name | ip [ ipv4-address ] }
In AP provision view, an AP uses the configuration in AP group provision view. If no configuration exists in AP group provision view, the AP uses the configuration in global provision view.
In AP group provision view, an AP uses the configuration in global provision view.
In global provision view, no AC is specified for an AP.
AP provision view
Global provision view
host-name host-name: Specifies an AC by its host name, a case-insensitive string of 1 to 253 characters. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.).
ip ipv4-address: Specifies an AC by its IPv4 address.
You can configure a maximum of three AC IPv4 addresses and only one host name. If you configure multiple host names, the most recent configuration takes effect.
The configuration in AP provision view takes effect only on the AP. The configuration in AP group provision view takes effect on all APs in the AP group. The configuration in global provision view takes effect on all APs.
The priorities of configurations in AP provision view, AP group provision view, and global provision view are in descending order.
The undo form of the command deletes all AC IPv4 addresses if you do not specify the ipv4-address argument.
# Specify the AC whose IP address is 192.168.100.11 in AP provision view of AP ap1.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] provision
[Sysname-wlan-ap-ap1-prvs] ac ip 192.168.100.11
# Specify the AC whose IP address is 192.168.100.11 in AP group provision view of AP group group1.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] provision
[Sysname-wlan-ap-group-group1-prvs] ac ip 192.168.100.11
# Specify the AC whose IP address is 192.168.100.11 for APs in global provision view.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] provision
[Sysname-wlan-global-configuration-prvs] ac ip 192.168.100.11
ac discovery policy ipv6
Use ac discovery policy ipv6 to enable an AP to prefer discovering ACs by IPv6 address.
Use undo ac discovery policy ipv6 to restore the default.
In AP group provision view, an AP prefers to discover ACs by IPv4 address.
AP provision view
This feature enables an AP to discover ACs by using the static IP addresses, IPv6 multicast, DHCPv6 option, IPv6 DNS, DHCPv4 options, broadcast/IPv4 multicast, and IPv4 DNS successively. If the AP connects to an AC successfully with a discovered IP address, it stops AC discovery.
# Enable AP ap1 to prefer discovering ACs by IPv6 address.
[Sysname-wlan-ap-ap1-prvs] ac discovery policy ipv6
# Enable APs in AP group group1 to prefer discovering ACs by IPv6 address.
[Sysname-wlan-ap-group-group1-prvs] ac discovery policy ipv6
ap
Use ap to create an AP grouping rule by AP names.
Use undo ap to delete an AP grouping rule by AP names.
ap ap-name-list
undo ap ap-name-list
No AP grouping rules by AP names exist.
AP group view
ap-name-list: Specifies a maximum of 10 space-separated AP names. An AP name is a case-sensitive string of 1 to 64 characters that can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
This command does not identify whether the specified AP exists.
The priorities of AP grouping rules by AP names, serial IDs, MAC addresses, and IP addresses are in descending order. If an AP does not match any grouping rules, it is added to the default AP group.
If the created AP grouping rule already exists in another AP group, this command deletes the rule from that AP group.
You cannot execute this command in the view of the default AP group.
# Create an AP grouping rule by AP names to add APs ap1, ap2, and ap3 to AP group group1.
[Sysname-wlan-ap-group-group1] ap ap1 ap2 ap3
wlan ap-group
ap-name
Use ap-name to add an AP to an AP monitor group.
Use undo ap-name to remove an AP from an AP monitor group.
ap-name ap-name
undo ap-name ap-name
No APs exist in an AP monitor group.
Monitor group view
ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
APs in an AP monitor group can report client quantity, radio traffic, channel usage, and AP anomalies to the AC.
The functions and services provided by an AP are not affected after the AP is added to an AP monitor group.
You can add a maximum of 32 APs to an AP monitor group.
# Add AP ap1 to an AP monitor group.
[Sysname] wlan vip-ap-group
[Sysname-wlan-vip-ap-group] ap-name ap1
report-interval
wlan vip-ap-group
ap-mode fit
NOTE: Support for this command depends on the AP model. |
Use ap-mode fit to configure a fat AP or cloud-managed AP to operate in fit mode.
Use undo ap-mode fit to restore the default.
ap-mode fit
undo ap-mode fit
In AP view, the AP uses the configuration in AP group view.
In AP group view, if the device starts up with the initial configuration, a fat AP operates in fat mode and a cloud-managed AP operates in cloud mode. If the device starts up with the factory defaults, the default operating mode of a fat AP depends on the factory defaults. To view the factory defaults, use the display default-configuration command in any view. For more information about the initial configuration and the factory defaults, see configuration file management in Fundamentals Configuration Guide.
AP view
AP group view
For unified management of fat APs or cloud-managed APs, you can configure them to operate in fit mode.
After you configure this feature for a fat AP or cloud-managed AP, it performs either of the following tasks:
· If a fit AP image exists on the AP, the AP restarts and changes its mode immediately.
· If no fit AP image exists on the AP, the AP first attempts to obtain a fit AP image from the AC after associating with the AC and then restarts and changes the mode. If the AP fails to obtain a fit AP image, it does not change its mode. The image downloading process might take several or dozens of minutes.
After image downloading starts, do not perform any operations on the AP until the mode change fails or finishes.
If the AP is already in fit mode, this configuration does not affect AP operation.
If the AP is offline, save the configuration on the AC. The AP will automatically perform a mode change next time it comes online.
# Configure AP ap1 to operate in fit mode.
[Sysname-wlan-ap-ap1] ap-mode fit
Changing the working mode will reboot the AP. For the operation to succeed, make sure the corresponding AP image exists on the AC or AP. Continue? [Y/N]:y
# Configure APs in group g1 to operate in fit mode.
[Sysname] wlan ap-group g1
[Sysname-wlan-ap-group-g1] ap-mode fit
ap-model
Use ap-model to create an AP model and enter its view, or enter the view of an existing AP model.
Use undo ap-model to remove an AP model and its configuration.
ap-model ap-model
undo ap-model ap-model
If the device starts up with the initial configuration, no AP models exist. If the device starts up with the factory defaults, whether an AP group is specified with AP models depends on the factory defaults. To view the factory defaults, use the display default-configuration command in any view. For more information about the initial configuration and the factory defaults, see configuration file management in Fundamentals Configuration Guide.
AP group view
ap-model: Specifies an AP model name.
# Create an AP model named WA6320 and enter its view.
[Sysname-wlan-ap-group-group1] ap-model WA6320
[Sysname-wlan-ap-group-group1-ap-model-WA6320]
bridge-aggregation
Use bridge-aggregation to create a Layer 2 aggregate interface and enter its view, or enter the view of an existing Layer 2 aggregate interface.
Use undo bridge-aggregation to delete a Layer 2 aggregate interface.
bridge-aggregation interface-number
undo bridge-aggregation interface-number
In AP view, an AP uses the configuration in AP group view.
In an AP group's AP model view, no Layer 2 aggregate interfaces exist.
AP view
interface-number: Specifies a Layer 2 aggregate interface number. The value range for this argument varies by AP model.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number. The aggregation group operates in static aggregation mode by default.
Deleting a Layer 2 aggregate interface also deletes the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
The configuration will be synchronized to all online APs if remote configuration synchronization is activated.
The configuration in AP view takes precedence over the configuration in an AP group's AP model view.
# Create Layer 2 aggregate interface 1 for AP ap1, and enter its view.
[Sysname-wlan-ap-ap1] bridge-aggregation 1
[Sysname-wlan-ap-ap1-bridge-aggregation-1]
# Create Layer 2 aggregate interface 1 for APs with model in AP group group1, and enter its view.
[Sysname] wlan ap-group group1 WA6320
[Sysname-wlan-ap-group-1] ap-model WA6320
[Sysname-wlan-ap-group-1-ap-model-WA6320] bridge-aggregation 1
[Sysname-wlan-ap-group-1-ap-model-WA6320-bridge-aggregation-1]
control-address
Use control-address to specify the IP address to be carried in the CAPWAP Control IP Address message element.
Use undo control-address to restore the default.
control-address { ip ipv4-address | ipv6 ipv6-address }
undo control-address { ip | ipv6 }
In AP view, an AP uses the configuration in AP group view. If no configuration exists in AP group view, the AP uses the configuration in global configuration view.
In AP group view, an AP uses the configuration in global configuration view.
In global configuration view, the AC's IP address is inserted in the CAPWAP Control IP Address element.
AP view
AP group view
Global configuration view
ip ipv4-address: Specifies an IPv4 address in the CAPWAP Control IPv4 Address message element.
ipv6 ipv6-address: Specifies an IPv6 address in the CAPWAP Control IPv6 Address message element.
This command takes effect only when the AC rediscovery feature is enabled.
You can specify a maximum of three IPv4 or IPv6 addresses in the CAPWAP Control IP Address message element.
The configuration in AP view takes precedence over the configuration in AP group view. The configuration in AP group view takes precedence over the configuration in global configuration view.
# Specify 192.168.1.1 as the IPv4 address to be carried in the CAPWAP Control IPv4 Address message element in AP view.
[Sysname-wlan-ap-ap1] control-address ip 192.168.1.1
# Specify 192.168.1.1 as the IPv4 address to be carried in the CAPWAP Control IPv4 Address message element in AP group view.
[Sysname] wlan ap-group 10
[Sysname-ap-group-10] control-address ip 192.168.1.1
# Specify 192.168.1.1 as the IPv4 address to be carried in the CAPWAP Control IPv4 Address message element in global configuration view.
[Sysname-wlan-global-configuration] control-address ip 192.168.1.1
control-address enable
Use control-address enable to enable the AC rediscovery feature.
Use control-address disable to disable the AC rediscovery feature.
control-address { disable | enable }
In global configuration view, the AC rediscovery feature is disabled.
AP view
AP group view
An AC enabled with AC rediscovery adds the CAPWAP Control IP Address message element to the discovery responses sent to APs. Upon receiving such a discovery response, an AP establishes a CAPWAP tunnel with the IP address representing the optimal AC in the CAPWAP Control IP Address message element.
An AC disabled with AC rediscovery does not add the CAPWAP Control IP Address message element in discovery responses sent to APs. APs that receive the discovery responses will send join requests to the source IP address of the discovery responses to establish CAPWAP tunnels with the AC.
AC rediscovery applies to CMCC WLAN networks. As required by CMCC, an AC must carry the CAPWAP Control IP Address message element in discovery responses.
# Enable the AC rediscovery feature in AP view.
[Sysname-wlan-ap-ap1] control-address enable
# Enable the AC rediscovery feature in AP group view.
[Sysname-ap-group-10] control-address enable
# Enable the AC rediscovery feature in global configuration view.
[Sysname-wlan-global-configuration] control-address enable
control-address
data-tunnel encryption
Use data-tunnel encryption enable to enable CAPWAP data tunnel encryption.
Use data-tunnel encryption disable to disable CAPWAP data tunnel encryption.
Use undo data-tunnel encryption to restore the default.
data-tunnel encryption { disable | enable }
In AP group view, CAPWAP data tunnel encryption is disabled.
AP view
AP group view
When this feature is enabled, an AP exchanges encryption information including keys with the AC through the CAPWAP control tunnel upon receiving the first keepalive packet from the AC. After the exchange, the AC and the AP will encrypt data packets transmitted in a CAPWAP data tunnel. Keepalive packets are not encrypted.
This feature will cause an AP to reassociate with the AC.
# Enable CAPWAP data tunnel encryption for AP ap1.
[Sysname-wlan-ap-ap1] data-tunnel encryption enable
This operation will reconnect the AP. Continue? [Y/N]
# Enable CAPWAP data tunnel encryption for APs in AP group group1.
[Sysname-wlan-ap-group-group1] data-tunnel encryption enable
This operation will reconnect member APs that are not enabled with CAPWAP data tunnel encryption. Continue? [Y/N]
tunnel encryption
delete file
Use delete file to delete a file from an AP.
delete file filename
AP view
filename: Specifies a file by its file name, a string of 1 to 255 characters.
This command takes effect only after an AP establishes a CAPWAP tunnel with the master AC.
# Delete file startup.cfg from AP ap1.
[Sysname-wlan-ap-ap1] delete file startup.cfg
display wlan ap files
download file
description (AP group view)
Use description to configure a description for an AP group.
An AP group does not have a description.
AP group view
text: Specifies a description, a case-sensitive string of 1 to 64 characters.
Configure a description for an AP group for easy identification and management purposes.
You can use the display wlan ap-group command to view the configured description.
# Configure a description for AP group group1.
[Sysname-ap-group-group1] description L3-office
wlan ap-group
description (AP view)
Use description to configure a description for an AP.
An AP does not have a description.
AP view
# Configure a description for AP ap1.
[Sysname-ap-ap1] description L3-office
display wlan ap
description (AP's VLAN view)
Use description to configure the description of an AP VLAN.
In an AP's VLAN view, a VLAN uses the configuration in an AP group's VLAN view.
In an AP group's VLAN view, the description of a VLAN is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has less than four digits, leading zeros are added. For example, the default description of VLAN 100 is VLAN 0100.
AP's VLAN view
To manage VLANs efficiently, configure descriptions for them based on their functions or connections.
For this command to take effect on an AP, make sure the remote configuration assignment feature is enabled.
# Configure the description of VLAN 2 as sales-private in the VLAN view of AP ap1.
[Sysname-wlan-ap-ap1] vlan 2
[Sysname-wlan-ap-ap1-vlan2] description sales-private
# Configure the description of VLAN 2 as sales-private in the VLAN view of AP group 1.
[Sysname-wlan-ap-group-1] vlan 2
[Sysname-wlan-ap-group-1-vlan2] description sales-private
dhcp snooping enable
Use dhcp snooping enable to enable DHCP snooping.
Use undo dhcp snooping enable to disable DHCP snooping.
DHCP snooping is disabled.
AP view
After you enable DHCP snooping on the AC, trusted ports forward responses from DHCP servers and untrusted ports discard responses. This mechanism ensures that DHCP clients obtain IP addresses from authorized DHCP servers.
When DHCP snooping is disabled, all ports on the device can forward responses from DHCP servers.
When DHCP snoop is disabled, Option 82 is not supported.
# Enable DHCP snooping for AP ap1.
[Sysname-wlan-ap-ap1] dhcp snooping enable
Use dhcp snooping information circuit-id to configure the padding mode and padding format for the Circuit ID sub-option.
Use undo dhcp snooping information circuit-id to restore the default.
dhcp snooping information circuit-id { normal | wlan-private } [ format { ascii | hex } ]
The padding mode is normal and the padding format is hex.
AP view
normal: Specifies the normal mode. The padding content includes the VLAN ID and interface number.
wlan-private: Specifies the WLAN private padding format. The padding content includes the WLAN, interface name, VLAN ID, SSID, radio MAC (BSSID), host name, and AP MAC.
format: Specifies the padding format for the Circuit ID sub-option.
ascii: Specifies the ASCII padding format.
hex: Specifies the hex padding format.
The padding format for the string mode, the normal mode, or the verbose mode varies by command configuration. Table 1 shows how the padding format is determined for different modes.
Table 1 Padding format for different modes
Keyword (mode) |
If no padding format is set |
If the padding format is ascii |
If the padding format is hex |
normal |
Hex for the VLAN ID and interface number. |
ASCII. |
wlan-private |
ASCII. |
ASCII. |
ASCII for the WLAN, interface name, SSID, and host name. Hex for the VLAN ID, radio MAC (BSSID), and AP MAC. |
# Configure WLAN private as the padding mode, and ASCII as the padding format for the Circuit ID sub-option.
[Sysname-wlan-ap-ap1] dhcp snooping information enable
[Sysname-wlan-ap-ap1] dhcp snooping information circuit-id wlan-private format ascii
Use dhcp snooping information enable to enable DHCP snooping to support Option 82.
Use undo dhcp snooping information enable to disable this feature.
DHCP snooping does not support Option 82.
AP view
This command enables DHCP snooping to add Option 82 into DHCP requests that do not contain Option 82 before forwarding the requests to the DHCP server. The content of Option 82 is determined by the dhcp snooping information circuit-id and dhcp snooping information remote-id commands. If the received DHCP request packets contain Option 82, DHCP snooping handles the packets according to the strategy configured by the dhcp snooping information strategy command. For more information about the dhcp snooping information remote-id and dhcp snooping information strategy commands, see DHCP commands in Layer 3—IP Services Command Reference.
# Enable DHCP snooping to support Option 82.
discovery-response
Use discovery-response wait-time to set the discovery-response timeout timer.
Use undo discovery-response wait-time to restore the default.
discovery-response wait-time seconds
In AP group view, the discovery-response timeout timer is 2 seconds.
AP view
AP group view
seconds: Specifies the discovery-response timeout timer in the range of 2 to 20 seconds.
The discovery-response timeout timer specifies the timeout time for an AP to wait for another discovery response. Whenever an AP receives a discovery response packet, the discovery-response timeout timer is created or refreshed. When the timeout timer expires, the AP sends a join request to the optimal AC.
If the network condition is poor, set a larger discovery-response timeout timer.
# Set the discovery-response timeout timer to 3 seconds for AP ap1.
[Sysname] wlan ap ap3
[Sysname-wlan-ap-ap3] discovery-response wait-time 3
# Set the discovery-response timeout timer to 3 seconds for all APs in AP group group1.
[Sysname-wlan-ap-group-group1] discovery-response wait-time 3
display wlan ap
Use display wlan ap to display AP information.
display wlan ap { all | name ap-name } [ verbose ]
all: Specifies all APs.
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
verbose: Displays detailed information.
# Display information about all APs.
<Sysname> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 2048
Remaining APs: 2047
Total AP licenses: 128
Local AP licenses: 128
Server AP licenses: 0
Remaining local AP licenses: 127
Sync AP licenses: 0
AP information
State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
C = Config, DC = DataCheck, R = Run M = Master, B = Backup
AP name APID State Model Serial ID
ap1 1 I WA6320 219801A28N819CE0002T
Total number of connected common APs |
Total number of connected fit APs. |
Total number of inside APs |
This field is not supported in the current software version. Total number of connected inside APs. Inside APs are manual APs that are automatically created when anchor APs act as ACs. The name and the serial ID of an inside AP are the local MAC address and local serial ID, respectively. |
Maximum supported APs |
Maximum number of APs supported by the AC. |
Total AP licenses |
Total number of AP licenses. |
Local AP licenses |
Number of AP licenses installed on the AC. |
Server AP licenses |
This field is not supported in the current software version. Number of AP licenses requested from the license server. |
Remaining local AP licenses |
Number of unused AP licenses installed on the AC. |
Sync AP licenses |
This field is not supported in the current software version. Number of synchronized AP licenses. |
APID |
ID of the AP to uniquely identify the AP on the AC. |
State |
Current state of the AP: · I—Idle. · J—Join. · JA—Join acknowledge. · IL—The AP is downloading the image file. · C—The AP is downloading initial configurations. · DC—The AP is checking data. · R—The CAPWAP tunnel is operating. It indicates that the AP and the AC have established a CAPWAP tunnel. · R/M—The master CAPWAP tunnel is operating. It indicates that the AP and the master AC have established a CAPWAP tunnel. · R/B—The backup CAPWAP tunnel is operating. It indicates that the AP and the backup AC have established a CAPWAP tunnel. · M—The AP is connected to the master AC. · B—The AP is connected to the backup AC. · R/IL—The AP is online and is downloading the image file from the AC. |
Serial ID |
Serial ID of the AP. This field displays Not configured if the serial ID of the AP is not configured. |
# Display detailed information about AP ap1.
<Sysname> display wlan ap name ap1 verbose
AP name : ap1
AP ID : 1
AP group name : default-group
State : Run
Backup type : Master
Online time : 0 days 1 hours 25 minutes 12 seconds
System uptime : 0 days 2 hours 22 minutes 12 seconds
Model : WA6320
Region code : CN
Region code lock : Disable
Serial ID : 219801A28N819CE0002T
MAC address : 0AFB-423B-893C
IP address : 192.168.1.50
UDP control port number : 18313
UDP data port number : N/A
H/W version : Ver.C
S/W version : E2321
Boot version : 1.01
USB state : N/A
Power level : N/A
Power info : N/A
Description : wtp1
Priority : 4
Echo interval : 10 seconds
Echo count : 3 counts
Keepalive interval : 10 seconds
Discovery-response wait-time : 2 seconds
Statistics report interval : 50 seconds
Fragment size (data) : 1500
Fragment size (control) : 1450
MAC type : Local MAC & Split MAC
Tunnel mode : Local Bridging & 802.3 Frame & Native Frame
CWPCAP data-tunnel status : Down
Discovery type : Static Configuration
Retransmission count : 3
Retransmission interval : 5 seconds
Firmware upgrade : Enabled
Sent control packets : 1
Received control packets : 1
Echo requests : 147
Lost echo responses : 0
Average echo delay : 3
Last reboot reason : User soft reboot
Latest IP address : 10.1.0.2
Current AC IP : 192.168.1.1
Tunnel down reason : Request wait timer expired
Connection count : 1
Backup IPv4 : Not configured
Backup IPv6 : Not configured
Ctrl-tunnel encryption : Disabled
Ctrl-tunnel encryption state : Not encrypted
Data-tunnel encryption : Disabled
Data-tunnel encryption state : Not encrypted
LED mode : Normal
Remote configuration : Enabled
EnergySaving Level :0
Radio 1:
Basic BSSID : 7848-59f6-3940
Admin state : Up
Radio type : 802.11ax(5GHz)
Antenna type : internal
Client dot11ac-only : Disabled
Client dot11n-only : Disabled
Channel bandwidth : 20/40/80MHz
Operating bandwidth : 20/40/80MHz
Secondary channel offset : SCA
Short GI for 20MHz : Supported
Short GI for 40MHz : Supported
Short GI for 80MHz : Supported
Short GI for 160MHz : Not supported
mimo : Not Config
Green-Energy-Management : Disabled
A-MSDU : Enabled
A-MPDU : Enabled
LDPC : Not Supported
STBC : Supported
Operational VHT-MCS Set:
Mandatory : Not configured
Supported : NSS1 0,1,2,3,4,5,6,7,8,9
NSS2 0,1,2,3,4,5,6,7,8,9
Multicast : Not configured
Operational HT MCS Set:
Supported : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
10, 11, 12, 13, 14, 15
Channel : 44(auto)
Channel usage(%) : 15
Max power : -102 dBm
Operational rate:
Mandatory : 6, 12, 24 Mbps
Multicast : Auto
Supported : 9, 18, 36, 48, 54 Mbps
Disabled : Not configured
Distance : 1 km
ANI : Enabled
Fragmentation threshold : 2346 bytes
Beacon interval : 100 TU
Protection threshold : 2346 bytes
Long retry threshold : 4
Short retry threshold : 7
Maximum rx duration : 2000 ms
Noise Floor : 5 dBm
Smart antenna : Enabled
Smart antenna policy : Auto
Protection mode : rts-cts
MU-TxBF : Enabled
SU-TxBF : Enabled
Continuous mode : N/A
Client dot11ax-only : Disabled
Operational HE-MCS Set:
Supported : NSS1 0,1,2,3,4,5,6,7,8,9,10,11
NSS2 0,1,2,3,4,5,6,7,8,9,10,11
NSS3 0,1,2,3,4,5,6,7,8,9,10,11
NSS4 0,1,2,3,4,5,6,7,8,9,10,11
OFDMA random access RUs : Not Supported
DL-OFDMA : Enabled
UL-OFDMA : Enabled
UL-MU-MIMO : Disabled
BSS-COLOR : Enabled
TWT negotiation : Enabled
HT protection mode : No protection
Radio 2:
Basic BSSID : 7848-59f6-3950
Admin state : Down
Radio type : 802.11ax(2.4GHz)
Operating bandwidth : 20MHz
Channel auto-switch : Enabled
Short GI for 80MHz : Not supported
MIMO : 2*2
A-MSDU : Enabled
A-MPDU : Enabled
STBC : Supported
10, 11, 12, 13, 14, 15, 16, 17,
18, 19, 20, 21, 22, 23, 24, 25,
26, 27, 28, 29, 30, 31
Channel : 5(auto)
Channel usage(%) : 0
Max power : 20 dBm
Preamble type : Short
Operational rate:
Mandatory : 1, 2, 5.5, 11 Mbps
Multicast : Auto
Supported : 6, 9, 12, 18, 24, 36, 48, 54 Mbps
Distance : 1 km
ANI : Enabled
Noise Floor : 0 dBm
MU-TxBF : Enabled
SU-TxBF : Enabled
DL-OFDMA : Enabled
UL-OFDMA : Enabled
BSS-COLOR : Enabled
State |
Current state of the AP: · Idle—Idle. · Join—Join. · JoinAck—Join acknowledge. · Image—The AP is downloading the image file. · Config—The AP is downloading initial configurations. · Data Check—The AP is checking data. · Run—The CAPWAP tunnel is operating. It indicates that the AP and the AC have established a CAPWAP tunnel. · R/M—The master CAPWAP tunnel is operating. It indicates that the AP and the master AC have established a CAPWAP tunnel. · R/B—The backup CAPWAP tunnel is operating. It indicates that the AP and the backup AC have established a CAPWAP tunnel. · M—The AP is connected to the master AC. · B—The AP is connected to the backup AC. · R/IL—The AP is online and is downloading the image file from the AC. |
Backup type |
CAPWAP tunnel type: · Idle—The AP has not established a CAPWAP tunnel with the AC. · Master—The CAPWAP tunnel established between the AP and the master AC. · Backup—The CAPWAP tunnel established between the AP and the backup AC. |
Region code lock |
· Enabled. · Disabled. |
Serial ID |
Serial ID of the AP. If no serial ID is configured, this field displays Not configured. |
MAC address |
MAC address of the AP. If no MAC address is configured, this field displays Not configured. |
UDP control port number |
Port number used by the AP to establish the CAPWAP control tunnel. |
UDP data port number |
Port number used by the AP to establish the CAPWAP data tunnel. |
H/W version |
Hardware version of the AP. |
S/W version |
Software version of the AP. |
USB state |
USB state: · Enabled. · Disabled. This field displays N/A if no USB state information is available. |
Power level |
Power level: · Low. · Middle. · High. This field displays N/A if the power level is unknown. Support for this field depends on the AP model. |
Power info |
Power supply information. · Power adapter—The AP uses local power supply. · PoE (port1+port2)—The AP uses PoE power supply. The port1 and port2 arguments represent the power supply status of PoE+ ports. ¡ N/A. ¡ 802.3af. ¡ 802.3at. Support for this field depends on the AP model. |
PoE status |
PoE power supply state for each PI: · Enabled. · Disabled. Support for this field depends on the AP model. |
Description for the AP. If no description is configured, this field displays Not configured. |
Priority |
AP connection priority for the AC. |
Echo interval |
Interval for an AP to send echo requests to the AC. |
Echo count |
Maximum number of echo request transmission attempts. |
Keepalive interval |
Interval for an AP to send keepalive packets through the CAPWAP data tunnel. |
Discovery-response wait-time |
Discovery-response timeout timer. |
Statistics report interval |
Interval for an AP to send statistics reports to the AC. |
Fragment size (data) |
Maximum fragment size for CAPWAP data packets. |
Fragment size (control) |
Maximum fragment size for CAPWAP control packets. |
MAC type |
MAC type of the AP-AC connection: · Local MAC—The AP encapsulates frames in 802.3 format before sending them to the AC. · Split MAC—The AP encapsulates frames in 802.11 format before sending them to the AC. · Local & Split MAC—The AP can encapsulate frames in either 802.3 format or 802.11 format before sending them to the AC. |
Tunnel mode |
Supported tunnel mode of the AP: · Local Bridging—The AP supports local bridging and does not forward data to the AC. · 802.3 Frame—The AP encapsulates the frames in 802.3 format to send them to the AC. · Native Frame—The AP encapsulates the frames in 802.11 format to send them to the AC. · Local Bridging & 802.3 Frame—The AP supports the Local Bridging mode and the 802.3 Frame mode. · 802.3 Frame & Native Frame—The AP supports the 802.3 Frame mode and the Native Frame mode. · Local Bridging & Native Frame—The AP supports the Local Bridging mode and the Native Frame mode. |
CWPCAP data-tunnel status |
Running status of the CAPWAP data tunnel: · Up. · Down. |
Discovery type |
Discovery method of the AP: · Static Configuration—The AP uses the manually configured IPv4 or IPv6 address of the AC. · DHCP—The AP gets the IP address of an AC through DHCP. · DNS—The AP gets the IP address of an AC through DNS. · Unknown. |
Retransmission count |
Number of retransmission attempts for an AC request. |
Retransmission interval |
Interval at which AC requests can be retransmitted. |
Firmware upgrade |
AP software upgrade: · Enabled. · Disabled. |
Sent control packets |
Number of sent packets, including Change State Event Response packets after the AC enters Run state. . |
Received control packets |
Number of received packets, including Change State Event Response packets after the AC enters Run state. |
Echo requests |
Number of echo requests sent by the AP in RUN state. |
Lost echo responses |
Number of echo responses not received by the AP in RUN state. |
Average echo delay |
Average echo delay in milliseconds. |
Last reboot reason |
Last reboot reason for the AP: · Power on. · Hard reboot. · Watchdog reboot. · Unknown reboot. · User soft reboot. · Kernel exception soft reboot. · Kernel deadloop soft reboot. · Auto update soft reboot. · Unknown soft reboot. · Memory exhausted. · Other unknown soft reboot. |
Latest IP address |
IP address that was most recently used by the AP. |
Current AC IP |
IP address of the AC that is associated with the AP. |
Tunnel down reason |
Cause for the CAPWAP tunnel to go down: · Failed to create timer. · Neighbor dead timer expired. · Request wait timer expired. · Data check timer expired. · Failed to process data channel keep-alive message. · Failed to process request. · AP was reset. · AP was deleted. · Failed to come online. · Serial number changed. · MAC address changed. · Number of APs exceeded the limit. · Processed join request in Run state. · Failed to create AP context. · Received failure result code. · Failed to retransmit message. · Failed to download image file. · Image file downloaded successfully. · File operation timer expired. · Failed to add tunnel. · Received WTP tunnel down event from AP. · Backup AC closed the backup tunnel. · Master and backup tunnel switchover. · Failed to inherit configuration. · AP authentication failed. · Encryption status mismatch. · AP was reset due to inconsistent local and reported radio statistics. · AP was reset due to inconsistent AP state on APMGR and lib. · AP was reset due to inconsistent BSS state on AC and AP. This field displays N/A if the CAPWAP tunnel did not go down. |
Connection count |
Number of times that the AP connects to the AC. It is cleared in either one of the following cases: · The AC reboots. · The serial ID of the AP changes. The reset wlan ap command does not clear the connection count. |
Backup IPv4 |
IPv4 address of the backup AC. If no backup AC is specified, this field displays Not configured. |
Backup IPv6 |
IPv6 address of the backup AC. If no backup AC is specified, this field displays Not configured. |
Ctrl-tunnel encryption |
CAPWAP control tunnel encryption: · Enabled. · Disabled. |
Ctrl-tunnel encryption state |
CAPWAP control tunnel encryption state: · Encrypted. · Not encrypted. |
Data-tunnel encryption |
CAPWAP data tunnel encryption: · Enabled. · Disabled. |
Data-tunnel encryption state |
CAPWAP data tunnel encryption state: · Encrypted. · Not encrypted. |
LED mode |
LED lighting mode: · quiet—All LEDs are off. · awake—All LEDs flash once every minute. · always-on—All LEDs are steady on. · normal—How LEDs flash in this mode varies by AP model. |
Remote configuration |
Remote configuration assignment: · Enabled. · Disabled. |
EnergySaving Level |
Energy saving level: · 0—Disabled. · 1—Level 1. · 2—Level 2. |
Basic BSSID |
MAC address of the radio. This field displays N/A if the AP has not established a CAPWAP tunnel with the AC. |
Admin state |
Radio state: · Up. · Down. |
Radio type |
Wireless mode: · 5 GHz: ¡ 802.11a. ¡ 802.11n(5GHz). ¡ 802.11ac(5GHz). ¡ 802.11ax(5GHz). · 2.4 GHz: ¡ 802.11b. ¡ 802.11g. ¡ 802.11n(2.4GHz). ¡ 802.11ax(2.4GHz) |
Client dot11ac-only |
· Disabled—Allows 802.11a/b/g/n/ac clients to associate with the radio. · Enabled—Allows only 802.11ac clients to associate with the radio. |
Client dot11n-only |
· Disabled—Allows 802.11a/b/g/n/ac clients to associate with the radio. · Enabled—Allows only 802.11n or 802.11ac clients to associate with the radio. |
Channel bandwidth |
Channel bandwidth mode: · 20 MHz. · 20 or 40 MHz. · 20/40/80 MHz. · 20/40/80/160MHz. · 20/40/80/160/(80+80)MHz. |
Operating bandwidth |
Bandwidth being used by the radio. |
Channel auto-switch |
Current bandwidth. This field is available only when 20/40 MHz auto switching is enabled and it is the same as the bandwidth value carried in beacon frames. |
Secondary channel offset |
Secondary channel information for the 802.11n and 802.11ac radio mode: · SCA (Second Channel Above)—The AP operates in 40 MHz bandwidth mode, and the secondary channel is above the primary channel. · SCB (Second Channel Below)—The AP operates in 40 MHz bandwidth mode, and the secondary channel is below the primary channel. · SCN—The AP does not operate in 40 MHz bandwidth mode. This field is available only when the bandwidth that the radio is using is 20/40/80MHz. |
Secondary channel center frequency |
Center frequency information about the 80 MHz bandwidth of the secondary channel when the radio operates in 802.11ac radio mode with a channel bandwidth of 160/(80+80)MHz. This field is available only when the bandwidth that the radio is using is 160/(80+80)MHz. |
Short GI for 20MHz |
Whether the radio supports short GI when it operates in 20 MHz mode. |
Short GI for 40MHz |
Whether the radio supports short GI when it operates in 40 MHz mode. |
Short GI for 80MHz |
Whether the radio supports short GI when it operates in 80 MHz mode. |
Short GI for 160MHz |
Whether the radio supports short GI when it operates in 160 MHz mode. |
mimo |
MIMO mode: · 1x1—The radio sends and receives signals through one spatial stream. · 2x2—The radio sends and receives signals through two spatial streams. · 3x3—The radio sends and receives signals through three spatial streams. · 4x4—The radio sends and receives signals through four spatial streams. · Not configured—The radio sends and receives signals through the maximum number of spatial streams supported by the radio. If this field also displays (PowerLow) after any value option to indicate low power level, the radio can send and receive signals only through one spatial stream. |
Green-Energy-Management |
Energy-saving: · Disabled. · Enabled. |
A-MSDU |
A-MPDU |
LDPC |
· Supported. · Not supported. |
STBC |
Operational HE-MCS Set |
· Supported—Supported MCS set. · Mandatory—Mandatory MCS set. · Multicast—Multicast MCS set. |
Operational VHT MCS Set |
· Supported—Supported VHT MCS set. · Mandatory—Mandatory VHT MCS set. · Multicast—Multicast VHT MCS set. |
Operational HT MCS Set |
Channel |
This field displays Number<auto> if the current channel is the optimal channel automatically selected by the AP. This field displays Number if the current channel is manually configured. This field displays Number<avoid radar> if the current channel is automatically selected by the AP to avoid radar signals. |
Max power |
Maximum transmission power of the radio. |
Preamble type |
Preamble type: · Short. · Long. |
Operational rate |
· Mandatory. · Supported. · Multicast. · Disabled. · Not configured. |
Distance |
Maximum distance that the radio signal can reach. |
ANI |
Protection threshold |
Frame length threshold required for triggering the protection mechanism. |
Long retry threshold |
Maximum number of retransmission attempts for frames whose length exceeds the RTS threshold. |
Short retry threshold |
Maximum number of retransmission attempts for frames whose length is below the RTS threshold. |
Maximum rx duration |
Maximum buffer duration for frames. |
Smart antenna |
· Enabled. · Disabled. This field is not supported in the current software version. |
Smart antenna policy |
· Auto. · High availability. · High throughput. This field is not supported in the current software version. |
Protection mode |
Conflict avoidance mode: · cts-to-self. · rts-cts. |
Continuous mode configuration: · Rate. · MCS index. · NSS index. · VHT-MCS index. This field displays N/A if the continuous mode is not configured. |
Client dot11ax-only |
· Enabled—Allows only 802.11ax clients to associate with the radio. · Disabled—Allows 802.11a/b/g/n/ac or 802.11ax clients to associate with the radio. |
OFDMA random access RUs |
· Supported. · Not Supported. |
DL-OFDMA |
Downlink OFDMA: · Enabled. · Disabled. Support for this field depends on the AP model. |
UL-OFDMA |
Uplink OFDMA: · Enabled. · Disabled. Support for this field depends on the AP model. |
UL-MU-MIMO |
Uplink MU-MIMO: · Enabled. · Disabled. Support for this field depends on the AP model. |
BSS-COLOR |
BSS coloring: · Enabled. · Disabled. Support for this field depends on the AP model. |
TWT negotiation |
TWT negotiation: · Enabled. · Disabled. Support for this field depends on the AP model. |
HT protection mode |
802.11n protection mode: · No protection. ¡ AP-associated clients and nearby wireless devices are operating in 802.11n mode and AP-associated clients are 802.11n clients with a bandwidth of 40 MHz. ¡ AP-associated clients are 802.11n clients with a bandwidth of 20 MHz. · Non-member protection. · 20 MHz protection. · Non-HT mixed. |
MU-TxBF |
SU-TxBF |
display wlan ap address
Use display wlan ap address to display AP address information.
display wlan ap { all | name ap-name } address
# Display address information for all APs.
<Sysname> display wlan ap all address
AP name IP address MAC address
ap1 1.1.1.5 000b-6b8f-fc6a
Total number of APs |
Total number of fit APs. |
Total number of connected APs |
Total number of connected manual APs |
Total number of connected manual fit APs. |
Total number of connected auto APs |
Total number of connected auto fit APs. |
IP address |
IP address of an AP. This field displays N/A for an offline AP. |
MAC address |
MAC address of an AP. This field displays N/A for an offline AP. |
Use display wlan ap all feature band-navigation to display the configuration status of the band navigation feature for all APs.
# Display the configuration status of the band navigation feature for all APs.
<Sysname> display wlan ap all feature band-navigation
AP name Status
ap1 Enabled
Table 5 Command output
Status |
Band navigation: · Enabled. · Disabled. |
Use display wlan ap all feature capwap to display configuration status of CAPWAP tunnel features.
# Display configuration status of CAPWAP tunnel features.
<Sysname> display wlan ap all feature capwap
AP name Upgrade Encryption Control-address Switch-back
ap1 Disabled Both Enabled Disabled
Table 6 Command output
Upgrade |
Encryption |
CAPWAP tunnel encryption: · Control—Control tunnel encryption is enabled. · Data—Data tunnel encryption is enabled. · Both—Encryption is enabled for both control and data tunnels. · Disabled—Encryption is disabled for both control and data tunnels. |
Control-address |
AC rediscovery: · Enabled. · Disabled. |
Switch-back |
This field is not supported in the current software version. The CAPWAP tunnel switch-back feature for AC hierarchy: · Horizontal. · Vertical. · Disabled. · Both. |
Use display wlan ap connection-record to display AP connection records on the AC.
display wlan ap { all | name ap-name } connection-record
# Display all AP connection records on an AC.
<Sysname> display wlan ap all connection-record
AP name IP address State Time
ap2 192.168.100.27 Run 01-06 09:06:40
Table 7 Command output
State |
Current state of the AP: · Discovery—AC discovery. · Join—The CAPWAP tunnel is being established. · Offline—Offline. · Run—The CAPWAP tunnel is operating. It indicates that the AP and the AC have established a CAPWAP tunnel successfully. |
Time |
Most recent time when the AP established a CAPWAP tunnel with the AC. |
display wlan ap description
Use display wlan ap description to display AP descriptions on the AC.
display wlan ap { all | name ap-name } description
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Display AP descriptions on the AC.
<Sysname> display wlan ap all description
AP information
AP name AP ID Description
ap1 1 Not configured
Table 8 Command description
AP ID |
AP ID, a unique identifier of an AP on the AC. |
AP description. This field displays Not configured for auto APs or manual APs that are not configured with any description. |
Use display wlan ap files to display information about files and file folders on an AP.
display wlan ap name ap-name files
# Display information about files and file folders on AP ap1.
<Sysname> display wlan ap name ap1 files
Directory of flash:
0 13638656 wa6300-system.bin
1 2573312 wa6300-boot.bin
131072 KB total (114208 KB free)
Table 9 Command output
0 13638656 xx.xx |
File or file folder information: · 0—Serial number, which is automatically assigned by the system. · 13638656— File size in bytes. A hyphen (-) is displayed if it is a file folder. · xx.xx—Name of the file or file folder. |
delete file
download file
display wlan ap gps
Use display wlan ap gps to display Global Positioning System (GPS) information for the specified APs.
display wlan ap { all | name ap-name } gps
This command takes effect only on APs that support the GPS module.
# Display GPS information for AP ap1.
<Sysname> display wlan ap name ap1 gps
AP name : ap1
Serial ID : 219801A17C817200001
Model : WA5620
Longitude : 117.788887
Latitude : 30.822136
Velocity : 25.445878
Orientation: 8.054548
Elevation : 156.655897
Obtained at: 2017-02-20 15:32:19
Table 10 Command output
Name of the AP. |
Serial ID of the AP. |
AP model. |
Longitude rounded to six decimal places. |
Latitude |
Latitude rounded to six decimal places. |
Velocity |
Horizontal velocity rounded to six decimal places. |
Orientation |
Orientation rounded to six decimal places. |
Elevation |
Elevation rounded to six decimal places. |
Obtained at |
Time when the GPS information was obtained. |
display wlan ap group
Use display wlan ap group to display AP groups to which the specified APs belong.
display wlan ap { all | name ap-name } group
# Display AP groups for all APs.
<Sysname> display wlan ap all group
Remaining APs: 2047
Sync AP licenses: 0
AP information
State: I = Idle, J= Join, JA= JoinAck, IL= ImageLoad
C= Config, DC= DataCheck, R= Run M= Master, B= Backup
AP name APID State Model AP group name
ap1 1 I WA6320 default-group
Table 11 Command output
Maximum number of fit APs supported by the AC. |
Total AP licenses |
local AP licenses |
Sync AP licenses |
APID |
State |
Current state of the AP: · I—Idle. · J—Join. · JA—Join acknowledge. · IL—The AP is downloading the image file. · C—The AP is downloading initial configurations. · DC—The AP is checking data. · R—The CAPWAP tunnel is operating. It indicates that the AP and the AC have established a CAPWAP tunnel. · R/M—The master CAPWAP tunnel is operating. It indicates that the AP and the master AC have established a CAPWAP tunnel. · R/B—The backup CAPWAP tunnel is operating. It indicates that the AP and the backup AC have established a CAPWAP tunnel. · M—The AP is connected to the master AC. · B—The AP is connected to the backup AC. |
Model |
AP model |
AP group name |
Name of the AP group to which the AP belongs. |
display wlan ap interface
Use display wlan ap interface to display Ethernet interface statistics for all online APs or a specified online AP.
display wlan ap { all | name ap-name } interface [ verbose ]
name ap-name: Specifies an AP by its name ap-name, a case-sensitive string of 1 to 64 characters. It can contain letters, digits, underlines (_), dots (.), left square brackets ([), right square brackets (]), forward slashes (/), and hyphens (-).
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
# Display brief information about Ethernet interfaces on all online APs.
<Sysname> display wlan ap all interface
AP name Interface State Speed
ap1 GE1/0/1 UP 1Gbps
ap2 GE1/0/1 DOWN Unknown
ap3 GigabitEthernet1/0/1 DOWN N/A
# Display detailed information about Ethernet interfaces on all online APs.
<Sysname> display wlan ap all interface verbose
AP name: ap1
State : UP
Speed : 1 Gbps
Input : 10 packets, 200 bytes
2 unicasts, 6 broadcasts, 2 multicasts, 0 drops
0 errors
Output : 10 packets, 200 bytes
4 unicasts, 4 broadcasts, 2 multicasts, 0 drops
0 errors
AP name: ap2
State : DOWN
Speed : Unknown
Input : 0 packets, 0 bytes
0 unicasts, 0 broadcasts, 0 multicasts, 0 drops
0 errors
Output : 0 packets, 0 bytes
0 errors
AP name: ap3
State : DOWN
Speed : N/A
0 errors
0 errors
# Display brief information about Ethernet interfaces on an online AP.
<Sysname> display wlan ap name ap1 interface
# Display detailed information about Ethernet interfaces on an online AP.
<Sysname> display wlan ap name ap1 interface verbose
AP name: ap1
State : UP
Speed : 1 Gbps
0 errors
0 errors
Table 12 Command output
Interface name. If no interface information is obtained, the full interface name is displayed in the brief information. |
State |
Physical link state of the interface: · UP: The interface is physically up. · DOWN: The interface is physically down. |
Speed |
Interface speed. If this field displays N/A, no interface speed is obtained. If this field displays Unknown, the interface speed is unknown. |
Input |
Statistics about packets received by the interface |
Output |
Statistics about packets sent by the interface |
packets |
Number of packets sent or received by the interface |
bytes |
Number of bytes sent or received by the interface |
unicasts |
Number of unicast packets sent or received by the interface |
broadcasts |
Number of broadcast packets sent or received by the interface |
multicasts |
Number of multicast packets sent or received by the interface |
drops |
Number of packets dropped by the interface |
errors |
Number of error packets sent or received by the interface |
display wlan ap online-time
Use display wlan ap online-time to display the online duration for APs.
display wlan ap { all | name ap-name } online-time
# Display online duration for all APs.
<Sysname> display wlan ap all online-time
AP name IP address Time
ap1 1.1.1.2 0 days 0 hours 2 minutes 6 seconds
ap2 1.1.1.1 0 days 0 hours 5 minutes 6 seconds
ap3 1.1.1.6 0 days 0 hours 2 minutes 1 seconds
Table 13 Command output
IP address |
IP address of an AP. |
Time |
Real-time association duration of an AP since the AP came online. |
display wlan ap reboot-log
Use display wlan ap reboot-log to display reboot logs for an AP.
display wlan ap name ap-name reboot-log
If the AP has suffered a system crash, you can use this command to view detailed information about the crash.
To use this command, make sure the specified AP is in Run state.
# Display reboot logs for AP ap1.
<Sysname> display wlan ap name ap1 reboot-log
Debugging information is not available on the AC.
Downloading debugging data from AP. Continue? [Y/N]:y
Downloading debugging data. Please wait...
Please enter the same command again to view the log messages.
<Sysname>dis wlan ap name ap1 reboot-log
--------------------- Reboot record 1 ---------------------
Recorded at : 2018-07-20 03:29:43.324529
Occurred at : 2018-07-20 03:29:43.324529
Reason : 0x8
Thread : devd (TID: 50)
Context : thread context
Cpu : 0
Kernel module info : module name (system) module address (0xd145a000)
module name (addon) module address (0xd00d5000)
Last 5 thread switches : WDRVFwdKthread (3:29:43.323999)-->
swapper (3:29:43.324011)-->
WDRVFwdKthread (3:29:43.324467)-->
swapper (3:29:43.324478)-->
devd (3:29:43.324502)-->
reset wlan ap reboot-log
display wlan ap region-code
Use display wlan ap region-code to display region code information for all APs or the specified AP.
display wlan ap { all | name ap-name } region-code
# Display region code information for all APs.
<Sysname> display wlan ap all region-code
Region Code
AP name Region Code
ap1 CN CHINA
ap2 CN CHINA
ap3 CN CHINA
Table 14 Command output
Region Code |
Region code. For more information about region codes, see Table 29. |
Use display wlan ap running-configuration to display running configuration for the specified AP or all APs.
display wlan ap { all | name ap-name } running-configuration [ verbose ]
verbose: Displays detailed running configuration.
# Display detailed running configuration for all APs.
<Sysname> display wlan ap all running-configuration verbose
(i) -- Inherited from AP group
(ir) -- Inherited from AP group RF configuration
(g) -- Inherited from AP global-configuration
wlan ap ap1 model WA6320 id 5
ap group name 1
serial-id 219801A28N819CE0002T
region code 156
echo interval 10 (i)
retransmission count 3 (i)
retransmission interval 5 (i)
statistics interval 50 (i)
fragment-size data 1500 (i)
fragment-size control 1450 (i)
tunnel-preempt disable (g)
firmware-upgrade disable (g)
priority 4 (i)
radio 1
radio type 802.11ax(5GHz) (i)
radio disable (i)
channel auto<64> (i)
channel unlock (i)
fragment-threshold 2346 (i)
max-power 20 (i)
power unlock (i)
distance 1 kilometer (i)
ANI Enabled (i)
radio 2
radio type 802.11ax(2.4GHz) (i)
radio disable (i)
channel auto<11> (i)
channel unlock (i)
max-power 20 (i)
power unlock (i)
ANI Enabled (i)
wlan ap ap2 model WA6320 id 6
ap group name 2
region code 156
priority 4 (i)
radio 1
radio type 802.11ac (i)
radio disable (i)
channel auto<60> (i)
channel unlock (i)
max-power 20 (i)
power unlock (i)
ANI Enabled (i)
radio 2
radio type 802.11n(2.4GHz) (i)
radio disable (i)
channel auto<13> (i)
channel unlock (i)
max-power 20 (i)
power unlock (i)
ANI Enabled (i)
Use display wlan ap statistics association-failure-record to display association failure records for APs.
# Display association failure records for APs.
<Sysname> display wlan ap statistics association-failure-record
MAC address AP ID Last failed at Reason
9a48-45ed-0300 12312 07-07/15:56:25 AP authentication failed
Table 15 Command output
MAC address |
MAC address of an AP. |
AP ID |
ID of an AP, which uniquely identifies the AP on the AC. |
Last failed at |
Last time an AP associated with the AC. The format is date/hh:mm:ss. |
Reason |
Association failure reason: · Failed to create data check timer. · Memory is not enough. · The AP model doesn't exist. · Lack of AP license. · MAC address conflict. · Failed to add APLB. · AP chose another AC. · Reached AC max capability. · Received join request in Run state. · APLB check failed. · Rejected AP access in HA smooth. · AP authentication failed. · Failed to create auto AP. · The AP information has already existed. · Failed to download AP image file. · Timer for waiting change state event request expired. · Time for waiting image data request or configuration request expired. · Received failure result code in change state event request. · Failed to add tunnel. · AP configuration was not found. · Inconsistent AP IDs. · Failed to send query message. · Open image file timer expired. |
Use display wlan ap statistics image-download to display AP image downloading information.
display wlan ap statistics image-download [ failed | in-progress | succeeded ]
failed: Displays APs that have failed to download the images.
in-progress: Displays APs that are downloading images.
succeeded: Displays APs that have successfully downloaded images.
If you do not specify any keyword, the command displays brief information about AP image downloading.
# Display brief information about AP image downloading.
<Sysname> display wlan ap statistics image-download
Completed : 50%
Time consumed : xxd hh:mm:ss
Max. concurrent image downloads of online APs : 412
AP count:
Succeeded : 152
In-progress : 140
Failed : 8
Table 16 Command output
Completed |
Percentage of APs that have completed image downloading. |
Time consumed |
Time that has been consumed for image downloading. |
Total to download |
Total number of APs that need to be updated. |
Succeeded |
Number of APs that have successfully downloaded images. |
In-progress |
Number of APs that are downloading images. |
Failed |
Number of APs that have failed to download images. |
# Display APs that are downloading images.
<Sysname> display wlan ap statistics image-download in-progress
AP name Time consumed
ap6 xxd 00:45:11
ap7 N/A
ap8 xxd 00:14:05
ap9 xxd 01:16:09
------More----
Table 17 Command output
Time consumed |
Time that has been consumed for image downloading. This field displays N/A if the AP has not started image downloading. |
# Display APs that have failed to download images.
<Sysname> display wlan ap statistics image-download failed
AP name Failure reason
ap1 Tunnel down
ap2 AP memory not enough
ap3 Image file does not exist
ap5 Others
------More----
Table 18 Command output
Time consumed |
Failure reason: · Tunnel down. · AP memory not enough. · Image file does not exist. · Retransmission failed. · Others. |
# Display APs that have downloaded images successfully.
<Sysname> display wlan ap statistics image-download succeeded
AP name Version Downloaded at
ap1 R5220 05-06 14:37:05
ap2 R5220 05-06 14:37:05
ap3 R5220 05-06 14:37:05
ap5 R5220 05-06 14:37:05
------More----
display wlan ap statistics online-record
Use display wlan ap statistics online-record to display online AP quantity records.
display wlan ap statistics online-record [ datetime date time [ count count ] ]
datetime date time: Specifies the start time to display online AP quantity records. The date argument represents the date in the YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. The time argument represents the time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the command displays all statistics about online AP quantity over the past 7 days in descending order of time.
count count: Specifies the number of online AP quantity records to be displayed, in the range of 1 to 256. If you do not specify this option, 10 online AP quantity records are displayed.
The online AP quantity records are displayed one by one at intervals of 1 minute. This command supports displaying records generated only over the past 7 days. If a time is specified, this command displays the specified number of online AP quantity records generated after the specified time point.
# Display 11 online AP quantity records generated after 2017/10/11 10:16.
<Sysname> display wlan ap statistics online-record datetime 2017/10/11 10:16 count 11
Time Manual APs Auto APs Total Total delta
2017-10-11 10:16:00 20 10 30 -2
2017-10-11 10:17:00 22 10 32 +6
2017-10-11 10:18:00 16 10 26 0
2017-10-11 10:19:00 16 10 26 0
2017-10-11 10:20:00 16 10 26 0
2017-10-11 10:21:00 16 10 26 0
2017-10-11 10:22:00 16 10 26 0
2017-10-11 10:23:00 16 10 26 0
2017-10-11 10:24:00 16 10 26 0
2017-10-11 10:25:00 16 10 26 0
2017-10-11 10:26:00 16 10 26 0
Table 19 Command output
Time |
Date and time when the record was generated. |
Manual APs |
Number of online manual APs. |
Auto APs |
Number of online auto APs. |
Total |
Total number of online APs. |
Total delta |
Quantity change in comparison with the last minute. |
display wlan ap statistics tunnel-down-record
Use display wlan ap statistics tunnel-down-record to display CAPWAP tunnel down records.
# Display CAPWAP tunnel down records.
<Sysname> display wlan ap statistics tunnel-down-record
AP name AP ID Tunnel down at Tunnel Down Reason Tunnel Down Count
9a48-45ed-0300 123 07-07/15:56:25 Processed join request 3
in Run state
Table 20 Command output
AP name |
Name of an AP. The first 30 characters are displayed. |
AP ID |
Tunnel down at |
Time when the CAPWAP tunnel between an AP and the AC went down. The format is date/hh:mm:ss. |
CAPWAP tunnel down reason: · Failed to create data check timer. · Neighbor dead timer expired. · Request wait timer expired. · Data check timer expired. · Failed to process data channel keep-alive message. · Failed to process request. · AP was reset by admin. · AP was reset by Web. · Manual AP was deleted. · Failed to come online. · Serial ID changed. · MAC address changed. · Exceeded AC max capability. · Processed join request in Run state. · Unauthenticated AP tunnel down. · Failed to create AP context. · Received failure result code in change state event request. · Failed to retransmit message. · Failed to download image file. · Image file downloaded successfully. · File operation timer expired. · Failed to add tunnel. · Received WTP tunnel down event from AP. · Backup AC closed the backup tunnel. · Master and backup tunnel switchover. · Failed to inherit configuration. · AP authentication failed. · Backup AP upgrade failed. · Board is inactive. · Lack of AP license. · Encryption status mismatch. |
Tunnel Down Count |
Number of tunnel down events. |
display wlan ap tunnel latency
Use display wlan ap tunnel latency to display tunnel latency information for an AP.
display wlan ap name ap-name tunnel latency
Make sure CAPWAP tunnel latency detection is enabled before you execute this command.
# Display tunnel latency information for AP ap1.
<Sysname> display wlan ap name ap1 tunnel latency
AP name : ap1
Tunnel Latency : Enabled
Control Link Delay:
Current Delay : 1ms
Maximum Delay : 1ms
Minimum Delay : 1ms
Data Link Delay:
Current Delay : 1ms
Maximum Delay : 1ms
Minimum Delay : 1ms
Table 21 Command output
Tunnel Latency |
Current Delay |
The most recent delay. |
reset wlan tunnel latency ap
tunnel latency-detect
display wlan ap unauthenticated
Use display wlan ap unauthenticated to display information about unauthenticated auto APs.
display wlan ap unauthenticated [ verbose ]
verbose: Displays detailed information about unauthenticated auto APs. If you do not specify this keyword, this command displays brief information about unauthenticated auto APs.
# Display brief information about unauthenticated auto APs.
<Sysname> display wlan ap unauthenticated
Total number of connected manual APs: 0
Total number of connected auto APs: 1
Maximum supported APs: 3072
Remaining APs: 3071
Fit APs activated by license: 128
Remaining fit APs: 127
WTUs activated by license: 0
Remaining WTUs: 0
AP information
C = Config, DC = DataCheck, R = Run, M = Master, B = Backup
6649-99be-0300 6 R/M WA6320 219801A28N819CE0002T
Table 22 Command output
This field is not supported in the current software version. Total number of inside APs. Inside APs are manual APs that are automatically created when anchor APs act as ACs. The name and the serial ID of an inside AP are the local MAC address and local serial ID, respectively. |
APID |
State |
Current state of the AP: · I—Idle. · J—Join. · JA—Join acknowledge. · IL—The AP is downloading the software image file. · C—The AP is downloading initial configurations. · DC—The AP is checking data. · R—The CAPWAP tunnel is operating. It indicates that the AP and the AC have established a CAPWAP tunnel. · R/M—The master CAPWAP tunnel is operating. It indicates that the AP and the master AC have established a CAPWAP tunnel. · R/B—The backup CAPWAP tunnel is operating. It indicates that the AP and the backup AC have established a CAPWAP tunnel. · M—The AP is connected to the master AC. · B—The AP is connected to the backup AC. |
Serial ID |
# Display detailed information about unauthenticated auto APs.
<Sysname> display wlan ap unauthenticated verbose
Total number of connected APs: 0
Remaining APs: 3071
Remaining WTUs: 0
AP name : ap1
AP ID : 1
State : Run
Backup Type : Master
System up time : 0 days 2 hours 22 minutes 12 seconds
Model : WA6320
Region code : CN
UDP port number : 65488
H/W version : Ver.C
S/W version : V700R001B49D001
Boot version : 1.01
Description : wtp1
Priority : 4
Fragment-size data : 1500
Fragment-size control : 1450
Echo requests : 147
Tunnel encryption : Disabled
LED mode : Normal
Radio 1:
Admin state : Up
Radio type : 802.11ac
Channel band-width : 20/40/80MHz
Secondary channel offset : SCB
A-MSDU : Enabled
A-MPDU : Enabled
STBC : Supported
Channel : 44(auto)
Max power : 20 dBm
Operational rate:
Multicast : Auto
Distance : 1 km
ANI : Enabled
Noise Floor : 5 dBm
Protection mode : cts-to-self
Continuous-mode : N/A
Radio 2:
Admin state : Down
Radio type : 802.11b
Channel band-width : 20MHz
Secondary channel offset : SCN
A-MSDU : Enabled
A-MPDU : Enabled
STBC : Supported
Channel : 5(auto)
Max power : 20 dBm
Operational rate:
Multicast : Auto
Distance : 1 km
ANI : Enabled
Noise Floor : 5 dBm
Table 23 Command output
AP ID |
State |
Current state of the AP: · Idle—Idle. · Join—Join. · JoinAck—Join acknowledge. · Image—The AP is downloading the software image file. · Config—The AP is downloading initial configurations. · Data Check—The AP is checking data. · Run—The CAPWAP tunnel is operating. It indicates that the AP and the AC have established a CAPWAP tunnel. · R/M—The master CAPWAP tunnel is operating. It indicates that the AP and the master AC have established a CAPWAP tunnel. · R/B—The backup CAPWAP tunnel is operating. It indicates that the AP and the backup AC have established a CAPWAP tunnel. · M—The AP is connected to the master AC. · B—The AP is connected to the backup AC. |
Backup Type |
Region code lock |
Serial ID |
MAC address |
UDP port number |
H/W version |
S/W version |
Priority |
Echo interval |
Interval for the AP to send echo requests to the AC. |
Statistics report interval for the AP to send statistics reports to the AC |
Fragment-size data |
Fragment-size control |
MAC type |
Tunnel mode |
Discovery type |
Discovery type of the AP: · Static Configuration—The AP uses the manually configured IPv4 or IPv6 address of the AC. · DHCP—The AP gets the IP address of an AC through DHCP. · DNS—The AP gets the IP address of an AC through DNS. · Unknown. |
Firmware upgrade |
Echo requests |
Latest IP address |
Cause for the CAPWAP tunnel to go down: · Failed to create timer. · Neighbor dead timer expired. · Request wait timer expired. · Data check timer expired. · Failed to process data channel keep-alive message. · Failed to process request. · AP was reset. · AP was deleted. · Failed to come online. · Serial number changed. · MAC address changed. · Number of APs exceeded the limit. · Processed join request in Run state. · Failed to create AP context. · Received failure result code. · Failed to retransmit message. · Failed to download image file. · Image file downloaded successfully. · File operation timer expired. · Failed to add tunnel. · Received WTP tunnel down event from AP. · Backup AC closed the backup tunnel. · Master and backup tunnel switchover. · Failed to inherit configuration. · AP authentication failed. This field displays N/A if the CAPWAP tunnel did not go down. |
Connection count |
Backup IPv4 |
Backup IPv6 |
Tunnel encryption |
LED mode |
LED lighting mode: · Quiet—All LEDs are off. · Awake—All LEDs flash once every minute. · Always-on—All LEDs are steady on. · Normal—How LEDs flash in this mode varies by AP model. |
Basic BSSID |
Admin state |
Radio type |
Wireless mode: · 5 GHz: ¡ 802.11a. ¡ 802.11n(5GHz). ¡ 802.11ac. · 2.4 GHz: ¡ 802.11b. ¡ 802.11g. ¡ 802.11n(2.4GHz). |
Channel band-width |
Channel bandwidth: · 20 MHz. · 20 or 40 MHz. · 20/40/80 MHz. |
Secondary channel information for the 802.11n and 802.11ac radio mode: · SCA (Second Channel Above)—The AP operates in 40 MHz bandwidth mode, and the secondary channel is above the primary channel. · SCB (Second Channel Below)—The AP operates in 40 MHz bandwidth mode, and the secondary channel is below the primary channel. · SCN—The AP does not operate in 40 MHz bandwidth mode. |
A-MSDU |
A-MPDU |
LDPC |
STBC |
Channel |
Max power |
Preamble type |
Operational rate |
Distance |
ANI |
Smart antenna |
· Auto. · High availability. · High throughput. Support for this field depends on the AP model. |
Protection mode |
Continuous mode |
display wlan ap-distribution
Use display wlan ap-distribution to display AP distribution information.
In standalone mode:
display wlan ap-distribution all
In IRF mode:
display wlan ap-distribution { all | slot slot-number }
all: Displays distribution information for all APs.
slot slot-number: Specifies an IRF member device by its member ID. (In IRF mode.)
# Display distribution information for all APs.
<Sysname> display wlan ap-distribution all
Slot : 1
AP name : 722a-d561-0301
Slot 1 Total number of APs: 1
AP name AP ID AP IP AC IP
ap1 1 1.1.1.1 1.1.1.10
# On an IRF fabric, display distribution information for APs attached to the specified slot.
<Sysname> display wlan ap-distribution slot 0
AP information
722a-d561-0300 4 R/M WA6320 219801A28N819CE0002T
Table 24 Command output
APID |
State |
Model |
AP model information. |
Serial ID |
display wlan ap-distribution ap-name
Use display wlan ap-distribution ap-name to display the attachment location of an AP.
display wlan ap-distribution ap-name ap-name
# On an IRF fabric, display the attachment location of AP ap1.
<Sysname> display wlan ap-distribution ap-name ap1
The AP is attached to slot 0.
# On a non-IRF network, display the attachment location of AP ap1.
Use display wlan ap-group to display information about all AP groups or the specified AP group.
display wlan ap-group [ brief | name group-name ]
brief: Displays brief information about all AP groups.
name group-name: Displays detailed information about the specified AP group. The group-name argument represents the name of an AP group, a case-insensitive string of 1 to 31 characters.
If you do not specify any parameter, this command displays detailed information about all AP groups.
# Display detailed information about all AP groups.
[Sysname] display wlan ap-group
Total number of AP groups: 2
Description : Not configured
AP model : Not configured
APs : Not configured
AP group name : group1
Description : abcd
AP model : WA6320
AP grouping rules:
AP name : ap1, ap2
IPv4 address : Not configured
IPv6 address : Not configured
APs : ap1 (AP name)
# Display detailed information about AP group group1.
[Sysname] display wlan ap-group group1
AP model : WA6320
AP grouping rules:
AP name : ap1, ap2
Serial ID : 219801A28N819CE00021
APs : ap1 (AP name)
# Display brief information about all AP groups.
<Sysname> display wlan ap-group brief
Total number of AP groups: 4
AP group name Group ID Member APs Online APs
default-group 1 1 0
group1 2 2006 1986
group2 3 10 10
group3 4 4 4
wlan ap-group
display wlan ap-model
Use display wlan ap-model to display AP model information.
display wlan ap-model { all | name model-name }
name model-name: Specifies an AP model by its name.
# Display information about AP model WA6320.
<Sysname> display wlan ap-model name WA6320
AP model : WA6320
Alias : WA6320
Vendor name : H3C
Vendor ID : 25506
License weight : 100
License type : 1
Radio count : 2
Radio 1:
Mode : 802.11a, 802.11an, 802.11ac
Default mode : 802.11ac
BSS count : 16
Radio 2:
Mode : 802.11b, 802.11g, 802.11gn
Default mode : 802.11gn
BSS count : 16
Version Support List :
Hardware Version Ver.A:
Software Version : R2206P02
Default Software Version : R2206P02
Image Name : wa6300.ipe
Hardware Version Ver.B:
Hardware Version Ver.C:
Hardware Version Ver.D:
Hardware Version Ver.E:
Hardware Version Ver.F:
display wlan device role
Use display wlan device role to display the WLAN device role.
# Display the role of the WLAN device.
<Sysname> display wlan device role
Current device role: Local AC.
Table 26 Command output
Current device role |
Current device role. Options include: · AC. · FAT AP. · FIT AP. |
display wlan license
Use display wlan license to display the number of installed WLAN licenses.
# Display the number of installed WLAN licenses.
<Sysname> display wlan license
Installed common AP licenses : 64
Installed WTU licenses : 0
Table 27 Command output
Installed common AP licenses |
Number of installed common AP licenses. |
Installed WTU licenses |
This field is not supported in the current software version. Number of installed WTU licenses. |
dns domain
Use dns domain to specify a domain name for an AP.
Use undo dns domain to restore the default.
dns domain domain-name
undo dns domain
In AP provision view, an AP uses the configuration in AP group provision view. If no configuration exists in AP group provision view, the AP uses the configuration in global provision view.
In AP group provision view, an AP uses the configuration in global provision view.
In global provision view, no domain name is specified for an AP.
AP provision view
Global provision view
domain-name: Specifies a domain name, a case-insensitive string of 1 to 253 characters separated by dots. The string can contain letters, digits, hyphens (-), and underscores (_).
The configuration in AP provision view takes effect only on the AP. The configuration in AP group provision view takes effect on all APs in the AP group. The configuration in global provision view takes effect on all APs.
The priorities of configurations in AP provision view, AP group provision view, and global provision view are in descending order.
# Set the domain name to com in AP provision view of AP ap1.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] provision
[Sysname-wlan-ap-ap1-prvs] dns domain com
# Set the domain name for APs to com in AP group provision view of AP group group1.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] provision
[Sysname-wlan-ap-group-group-prvs] dns domain com
# Set the domain name for APs to com in global provision view.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] provision
[Sysname-wlan-global-configuration-prvs] dns domain com
dns server
dns server
Use dns server to specify a DNS server for an AP.
Use undo dns server to delete the DNS server configuration.
dns server { ip ipv4-address | ipv6 ipv6-address }
undo dns server { ip | ipv6 }
In global provision view, no DNS server is specified for an AP.
AP provision view
ip ipv4-address: Specifies a DNS server by its IPv4 address. Make sure you specify a valid IP address. Invalid IP addresses include loopback IP addresses, direct broadcast addresses, Class D IP addresses, Class E IP addresses, IP address 255.255.255.255, and IP addresses in the 0.X.X.X format.
ipv6 ipv6-address: Specifies a DNS server by its IPv6 address. This option is unavailable in global provision view.
You can specify only one IPv4 address and one IPv6 address in each view.
# Set the DNS server IP address to 192.168.100.123 in AP provision view of AP ap1.
[Sysname-wlan-ap-ap1-prvs] dns server ip 192.168.100.123
# Set the DNS server IP address to 192.168.100.123 in AP group provision view of AP group group1.
[Sysname-wlan-ap-group-group-prvs] dns server ip 192.168.100.123
# Set the DNS server IP address to 192.168.100.123 in global provision view.
[Sysname-wlan-global-configuration-prvs] dns server ip 192.168.100.123
dns domain
download file
Use download file to download an image file to an AP.
download file filename
AP view
filename: Specifies an image file by its name, a string of 1 to 255 characters.
This feature takes effect only on the master AC after a CAPWAP tunnel is established in WLAN high availability networking. For more information about WLAN high availability, see "Configuring WLAN high availability."
# Download image file main.ipe to AP ap1.
[Sysname-wlan–ap-ap1] download file main.ipe
echo-count
Use echo-count to set the maximum number of echo request transmission attempts.
Use undo echo-interval to restore the default.
echo-count count
undo echo-count
In AP view, an AP uses the configuration in AP group view.
In AP group view, the maximum number of echo request transmission attempts is 3.
AP view
AP group view
count: Specifies the maximum number of echo request transmission attempts in the range of 3 to 255.
An AP sends echo requests to the AC at the specified echo intervals to identify whether the CAPWAP control tunnel is operating correctly. The AC responds by sending echo responses. If the AP does not receive any echo responses before the keepalive timer expires, the AP terminates the connection. If the AC does not receive any echo requests before the keepalive timer expires, the AC terminates the connection. The keepalive timer is the echo interval multiplied by the maximum number of echo request transmission attempts.
The configuration in AP view takes precedence over the configuration in AP group view.
# Set the maximum number of echo request transmission attempts to 5 for AP ap3.
[Sysname] wlan ap ap3 model WA6320
[Sysname-wlan-ap-ap3] echo-count 5
# Set the maximum number of echo request transmission attempts to 5 for APs in AP group group1.
[Sysname-wlan-ap-group-group1] echo-count 5
echo-interval
Use echo-interval to set the interval for an AP to send echo requests to the AC.
echo-interval interval
undo echo-interval
In AP group view, the interval for an AP to send echo requests is 10 seconds.
AP view
AP group view
interval: Specifies the interval for sending echo requests, in seconds. The value range is 0 and 5 to 255.
CAUTION: Setting the echo interval to 0 seconds disables an AP from sending echo requests. This setting is for test use only. For correct AC and AP communication, do not set the echo interval to 0 seconds. |
An AP sends echo requests to the AC at the specified echo intervals to identify whether the CAPWAP control tunnel is operating correctly. If the AP does not receive any echo responses from the AC before the keepalive timer expires, the AP terminates the connection. If the AC does not receive any echo requests before the keepalive timer expires, the AC terminates the connection.
The keepalive time is the echo interval multiplied by the maximum number of echo request transmission attempts set by using the echo-count count command. If the calculated value exceeds 120 seconds, the keepalive time is rounded to 120 seconds.
# Set the echo interval for AP ap3 to 15 seconds.
[Sysname-wlan-ap-ap3] echo-interval 15
# Set the echo interval for APs in AP group group1 to 15 seconds.
[Sysname-wlan-ap-group-group1] echo-interval 15
ethernet
NOTE: Support for this command depends on the AP model. |
Use ethernet to enter Eth interface view of an AP.
ethernet interface-number
AP view
AP group's AP model view
# Enter Eth1 interface view of AP ap1 with model SIC-AP220.
[Sysname] wlan ap ap1 model SIC-AP220
[Sysname-wlan-ap-ap1] ethernet 1
[Sysname-wlan-ap-ap1-ethernet-1]
# Enter Eth1 interface view of APs in AP group group1 with model SIC-AP220.
[Sysname-wlan-ap-group-group1] ap-model SIC-AP220
[Sysname-wlan-ap-group-group1-ap-model-SIC-AP220] ethernet 1
[Sysname-wlan-ap-group-group1-ap-model-SIC-AP220-ethernet-1]
firmware-upgrade
Use firmware-upgrade enable to enable the software upgrade feature.
Use firmware-upgrade disable to disable the software upgrade feature.
Use undo firmware-upgrade to restore the default.
firmware-upgrade { disable | enable }
In AP view, an AP uses the configuration in AP group view. If no software upgrade configuration exists in AP group view, the AP uses the configuration in global configuration view.
In AP group view, an AP uses the configuration in global configuration view.
In global configuration view, the software upgrade feature is enabled.
AP view
AP group view
Global configuration view
This feature enables the AC to examine whether an AP's software version matches the hardware version and software version mappings stored on the AC during CAPWAP tunnel establishment.
· If a match is found, the AC establishes a CAPWAP tunnel with the AP.
· If no match is found, the CAPWAP tunnel establishment proceeds as follows:
a. The AC notifies the AP of software version inconsistency.
b. After receiving the notification, the AP requests the software version from the AC, upgrades the software, and then establishes a CAPWAP tunnel with the AC.
When this feature is disabled, the AC does not examine the software version of an AP and establishes a CAPWAP tunnel with the AP.
The configuration in AP view takes precedence over the configuration in AP group view. The configuration in AP group view takes precedence over the configuration in global configuration view.
# Enable the software upgrade feature for AP ap3.
[Sysname-wlan-ap-ap3] firmware-upgrade enable
# Enable the software upgrade feature for APs in AP group group1.
[Sysname-wlan-ap-group-group1] firmware-upgrade enable
# Enable the software upgrade feature globally.
[Sysname-wlan-global-configuration] firmware-upgrade enable
wlan apdb
fragment-size
Use fragment-size to set the maximum fragment size for CAPWAP control or data packets.
Use undo fragment-size to remove the configuration.
fragment-size { control control-size | data data-size }
undo fragment-size { control | data }
In AP group view, the maximum fragment size for CAPWAP control packets and data packets is 1450 bytes and 1500 bytes, respectively.
AP view
AP group view
control control-size: Specifies the maximum fragment size for CAPWAP control packets in bytes. The value range for the control-size argument is 1000 to 1450.
data data-size: Specifies the maximum fragment size for CAPWAP data packets in bytes. The value range for the control-size argument is 1000 to 1748.
This command prevents packets between AC and AP from being dropped by intermediate devices if the AP connects to the AC across the Internet.
Any maximum fragment size modification takes effect immediately on online APs.
# Set the maximum fragment size for CAPWAP data packets to 1500 bytes for AP ap1.
[Sysname-ap-ap1] fragment-size data 1500
# Set the maximum fragment size for CAPWAP data packets to 1500 bytes for APs in AP group group1.
[Sysname-wlan-ap-group-group1] fragment-size data 1500
gateway
Use gateway to specify a gateway for an AP.
Use undo gateway to delete the gateway configuration.
gateway { ip ipv4-address | ipv6 ipv6-address }
undo gateway { ip | ipv6 }
No gateway is specified for an AP.
AP provision view
ip ipv4-address: Specifies a gateway by its IPv4 address. Make sure you specify a valid IP address. Invalid IP addresses include loopback IP addresses, direct broadcast addresses, Class D IP addresses, Class E IP addresses, IP address 255.255.255.255, and IP addresses in the 0.X.X.X format.
ipv6 ipv6-address: Specifies a gateway by its IPv6 address.
You can set only one IPv4 address and one IPv6 address.
# Set the gateway IP address to 192.168.100.1 for AP ap1.
[Sysname-wlan-ap-ap1-prvs] gateway ip 192.168.100.1
gigabitethernet
Use gigabitethernet to enter the GigabitEthernet interface view of an AP.
gigabitethernet interface-number
AP view
interface-number: Specifies an interface number. The value range varies by AP model.
# Enter the interface view of GigabitEthernet 1 from AP view.
[Sysname-wlan-ap-ap1] gigabitethernet 1
[Sysname-wlan-ap-ap1-gigabitethernet-1]
# Enter the interface view of GigabitEthernet 1 from the AP model view of AP group 1.
[Sysname-wlan-ap-group-group1] ap-model WA6320
[Sysname-wlan-ap-group-group1-ap-model-WA6320] gigabitethernet 1
[Sysname-wlan-ap-group-group1-ap-model-WA6320-gigabitethernet-1]
hybrid-remote-ap
Use hybrid-remote-ap enable to enable remote AP.
Use hybrid-remote-ap disable to disable remote AP.
Use undo hybrid-remote-ap to restore the default.
hybrid-remote-ap { disable | enable }
In AP group view, remote AP is disabled.
AP view
AP group view
By default, an AP stops providing services after the tunnel between the AP and the associated AC is disconnected. This command enables the AP to act as a remote AP to still provide services.
This command takes effect only on an AP that operates in local forwarding mode.
# Enable remote AP for AP ap1.
[Sysname-wlan-ap-ap1] hybrid-remote-ap enable
# Enable remote AP for APs in AP group group1.
[Sysname-wlan-ap-group-group1] hybrid-remote-ap enable
if-match ip
Use if-match ip to create an AP grouping rule by IPv4 addresses.
Use undo if-match ip to delete AP grouping rules by IPv4 addresses.
if-match ip ip-address { mask-length | mask }
undo if-match ip [ ip-address { mask-length | mask } ]
No AP grouping rules by IPv4 addresses exist.
AP group view
ip-address: Specifies an IPv4 address in dotted decimal notation.
mask-length: Specifies the mask length in the range of 1 to 31.
mask: Specifies the mask in dotted decimal notation.
You cannot execute this command in the view of the default AP group.
AP grouping rules by IPv4 addresses for an AP group or for different AP groups cannot overlap with each other.
An AP group supports a maximum of 32 AP grouping rules by IPv4 addresses.
The priorities of AP grouping rules by AP names, serial IDs, MAC addresses, and IP addresses are in descending order. If an AP does not match any grouping rules, it is added to the default AP group.
You can create AP grouping rules by both IPv4 addresses and IPv6 addresses for an AP group.
If you do not specify any argument in the undo form of the command, the command deletes all AP grouping rules by IPv4 addresses.
# Add APs whose IP address belongs to 192.168.0.0/16 to AP group group1.
[Sysname-ap-group-group1] if-match ip 192.168.0.0 16
if-match ipv6
Use if-match ipv6 to create an AP grouping rule by IPv6 addresses.
Use undo if-match ipv6 to delete AP grouping rules by IPv6 addresses.
if-match ipv6 { ipv6-address prefix-length | ipv6-address/prefix-length }
undo if-match ip [ ipv6-address prefix-length | ipv6-address/prefix-length ]
No AP grouping rules by IPv6 addresses exist.
AP group view
ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies the IPv6 address prefix length in the range of 1 to 128.
AP grouping rules by IPv6 addresses for an AP group or for different AP groups cannot overlap with each other.
An AP group supports a maximum of 32 AP grouping rules by IPv6 addresses.
If you do not specify any argument in the undo form of the command, the command deletes all AP grouping rules by IPv6 addresses.
# Add APs whose IPv6 address belongs to 2001:DB0::/28 to AP group group1.
[Sysname-ap-group-group1] if-match ipv6 2001:DB8:: 28
interface-management
Use interface-management bringup to bring up an interface on a fit AP.
Use interface-management shutdown to shut down an interface on a fit AP.
Use undo interface-management to restore the default.
interface-management { bringup | shutdown }
In an AP's Ethernet interface view, the AP uses the configuration in an AP group's Ethernet interface view.
In an AP group's Ethernet interface view, the interface is up.
AP's Eth Ethernet interface view
AP group's Eth Ethernet interface view
AP's GE Ethernet interface view
AP group's GE Ethernet interface view
AP's 2.5GE Ethernet interface view
AP group's 2.5GE Ethernet interface view
AP's XGE Ethernet interface view
AP group's XGE Ethernet interface view
AP's Layer 2 aggregate interface view
AP group's Layer 2 aggregate interface view
This command does not take effect on the uplink interface of a fit AP that connects the AP to the AC.
Do not shut down an interface when it is being removed from an aggregation group.
The interface-management shutdown command does not take effect on member interfaces of an aggregation group.
If remote configuration assignment is enabled, the settings can be deployed to online APs only after the remote-configuration synchronize command is executed. APs that come online after you bring up or shut down the interfaces can obtain the interface configuration automatically.
The configuration in an AP's Ethernet interface view takes precedence over the configuration in an AP group's Ethernet interface view.
# Shut down GigabitEthernet 1 on AP ap1.
[Sysname-wlan-ap-ap1-gigabitethernet-1] interface-management shutdown
The command does not take effect if the AP port is an uplink port. Continue? [Y/N]:y
# Shut down GigabitEthernet 1 on APs in AP group 1.
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] ap-model WA6320
[Sysname-wlan-ap-group-1-ap-model-WA6320] gigabitethernet 1
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] interface-management shutdown
remote-configuration enable
ip address
Use ip address to specify an IPv4 address for the management VLAN interface for an AP.
Use undo ip address to restore the default.
ip address ip-address { mask | mask-length }
undo ip address
No IPv4 address is specified for the management VLAN interface of an AP.
AP provision view
The IP address of the management VLAN interface for an AP must be different from the following IP addresses:
· IP address of the management VLAN interface of another AP.
· AC IP address specified in provision view of any APs.
# Set the IP address of the management VLAN interface to 10.1.1.1/24 for AP ap1.
[Sysname-wlan-ap-ap1-prvs] ip address 10.1.1.1 24
ipv6 address
Use ipv6 address to specify an IPv6 address for the management VLAN interface for an AP.
Use undo ipv6 address to restore the default.
undo ipv6 address
No IPv6 address is specified for the management VLAN interface of an AP.
AP provision view
prefix-length: Specifies the prefix length in the range of 1 to 128.
# Set the IPv6 address of the management VLAN interface to 2001::1/64 for AP ap1.
[Sysname-wlan-ap-ap1-prvs] ipv6 address 2001::1/64
keepalive-interval
Use keepalive-interval to set the data tunnel keepalive interval.
Use undo keepalive-interval to restore the default.
keepalive-interval interval
In AP group view, the data tunnel keepalive interval is 10 seconds.
AP view
AP group view
interval: Specifies the interval for an AP to send keepalive packets over the CAPWAP data tunnel. The value range is 1 to 255 seconds.
# Set the data tunnel keepalive interval for AP ap1 to 15 seconds.
[Sysname-wlan-ap-ap1] keepalive-interval 15
# Set the data tunnel keepalive interval for APs in AP group 1 to 15 seconds.
[Sysname-ap-group-1] keepalive-interval 15
led-mode
Use led-mode to set a LED lighting mode.
Use undo led-mode to restore the default.
led-mode { always-on | awake | normal | quiet }
undo led-mode
In AP group view, the LED lighting mode is normal.
AP view
AP group view
always-on: Specifies the always-on mode. Support for this keyword depends on the AP model.
awake: Specifies the awake mode. Support for this keyword depends on the AP model.
normal: Specifies the normal mode. How LEDs flash in this mode varies by AP model.
quiet: Specifies the quiet mode.
If you set the LED lighting mode to awake or always-on in AP group view, the setting takes effect only on member APs that support the specified LED lighting mode.
# Set the LED lighting mode to normal for AP ap1.
[Sysname-wlan-ap-ap1] led-mode normal
# Set the LED lighting mode to awake for APs in AP group ap1.
[Sysname] wlan ap-group g1
[Sysname-wlan-ap-group-g1] led-mode awake
mac-address (AP group view)
Use mac-address to create an AP grouping rule by MAC addresses.
Use undo mac-address to delete an AP grouping rule by MAC addresses.
mac-address mac-address
undo mac-address mac-address
No AP grouping rules by MAC addresses exist.
AP group view
mac-address: Specifies the MAC address of an AP.
This command does not identify whether the specified AP exists.
You can configure multiple AP grouping rules by MAC addresses.
If the created AP grouping rule already exists in another AP group, this command deletes the rule from that AP group.
# Create an AP grouping rule by MAC addresses for AP group group1.
[Sysname-wlan-ap-group-group1] mac-address 0AC1-F9B2-B1C2
wlan ap-group
mac-address (AP view)
Use mac-address to assign a MAC address to an AP.
Use undo mac-address to restore the default.
undo mac-address
No MAC address is assigned to an AP.
AP view
mac-address: Specifies the MAC address in H-H-H format.
Changing or deleting the MAC address of an AP terminates the CAPWAP tunnel if the AP has established a CAPWAP tunnel with the AC. Then the AP will reestablish a CAPWAP tunnel with the AC.
# Assign the MAC address 0001-0000-0000 to AP ap1.
[Sysname-wlan-ap-ap1] mac-address 0001-0000-0000
name
Use name to assign a name to an AP's VLAN.
Use undo name to restore the default.
name text
undo name
In an AP's VLAN view, a VLAN uses the configuration in an AP group's VLAN view.
In an AP group's VLAN view, the name of a VLAN is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has less than four digits, leading zeros are added. For example, the name of VLAN 100 is VLAN 0100.
AP's VLAN view
text: Specifies a VLAN name, a case-sensitive string of 1 to 32 characters.
For this command to take effect on an AP, make sure the remote configuration assignment feature is enabled.
The configuration in an AP's VLAN view takes precedence over the configuration in an AP group's VLAN view.
# Assign name test vlan to VLAN 2 of AP ap1.
[Sysname-wlan-ap-ap1] vlan 2
[Sysname-wlan-ap-ap1-vlan2] name test vlan
# Assign name test vlan to VLAN 2 of all APs in AP group 1.
[Sysname-wlan-ap-group-1] vlan 2
[Sysname-wlan-ap-group-1-vlan2] name test vlan
port-isolate enable
Use port-isolate enable to enable port isolation.
Use port-isolate disable to disable port isolation.
Use undo port-isolate to restore the default.
port-isolate { enable | disable }
undo port-isolate
In an AP group's Ethernet interface view, port isolation is enabled.
AP's Eth interface view
AP group's Eth interface view
AP's GigabitEthernet interface view
AP group's GigabitEthernet interface view
AP's 2.5G Ethernet interface view
AP group's 2.5G Ethernet interface view
AP's 10-GE interface view
AP group's 10-GE interface view
The configuration in Ethernet interface view applies only to the interface.
The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
The configuration will be synchronized to all online APs if remote configuration synchronization is activated.
# Enable port isolation for GigabitEthernet 1 of AP ap1.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port-isolate enable
# Enable port isolation for GigabitEthernet 1 of APs in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port-isolate enable
port access vlan
Use port access vlan to assign an access port on an AP to the specified VLAN.
Use undo port access vlan to restore the default.
port access vlan vlan-id
In an AP's Ethernet interface view, an access port uses the configuration in an AP group's Ethernet interface view.
In an AP group's Ethernet interface view, all access ports on an AP belong to VLAN 1.
vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
Before assigning an access port to a VLAN, make sure the VLAN has been created.
# Assign GigabitEthernet 1 on AP ap1 to VLAN 3.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port access vlan 3
# Assign GigabitEthernet 1 on APs with model in AP group 1 to VLAN 3.
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port access vlan 3
port hybrid pvid
Use port hybrid pvid to set the PVID of a hybrid port on an AP.
Use undo port hybrid pvid to set the PVID of a hybrid port on an AP to 1.
port hybrid pvid vlan vlan-id
In an AP's Ethernet interface view, a hybrid port uses the configuration in an AP group's Ethernet interface view.
In an AP group's Ethernet interface view, the PVID of a hybrid port is the ID of the VLAN to which the port belongs when its link type is access.
You can use a nonexistent VLAN as the PVID of a hybrid port. When you delete the PVID of a hybrid port by using the undo vlan command, the PVID setting of the port does not change.
For correct packet transmission, set the same PVID for a hybrid port on an AP and the hybrid port on the switch connected to the AP.
To enable a hybrid port to transmit packets from its PVID, you must assign the hybrid port to the PVID by using the port hybrid vlan command.
# Configure GigabitEthernet 1 on AP ap1 as a hybrid port, and set its PVID to VLAN 100.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port link-type hybrid
[Sysname-wlan-ap-ap1-gigabitethernet-1] port hybrid pvid vlan 100
# Configure GigabitEthernet 1 on APs with model in AP group 1 as a hybrid port, and set its PVID to VLAN 100.
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port link-type hybrid
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port hybrid pvid vlan 100
port hybrid vlan
port link-type
port hybrid vlan
Use port hybrid vlan to assign a hybrid port to the specified VLANs.
Use undo port hybrid vlan to remove a hybrid port from the specified VLANs
undo port hybrid vlan vlan-id-list
In an AP group's Ethernet interface view, a hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument cannot be lower than the value for the vlan-id1 argument. The specified VLANs must already exist on the device.
tagged: Configures the port as a tagged member of the specified VLANs. A tagged member of a VLAN sends packets from the VLAN without removing VLAN tags.
untagged: Configures the port as an untagged member of the specified VLANs. An untagged member of a VLAN sends packets from the VLAN after removing VLAN tags.
A hybrid port can allow multiple VLANs. If you execute this command multiple times on a hybrid port, the hybrid port allows all the specified VLANs.
# Configure GigabitEthernet 1 on AP ap1 as a hybrid port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 as a tagged member.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port hybrid vlan 2 4 50 to 100 tagged
# Configure GigabitEthernet 1 on APs with model in AP group 1 as a hybrid port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 as a tagged member.
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port hybrid vlan 2 4 50 to 100 tagged
port link-type
port link-aggregation group
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
In an AP group's Ethernet interface view, an interface does not belong to an aggregation group.
group-id: Specifies an aggregation group by its aggregate interface number. The value range for the argument varies by AP model.
A Layer 2 Ethernet interface can be assigned only to a Layer 2 aggregation group and an Ethernet interface can belong to only one aggregation group.
After joining an aggregation group, an interface inherits the settings configured for the group.
Before you execute this command, make sure the specified aggregation group already exists and the AP supports Layer 2 aggregate interfaces.
# Assign interface GigabitEthernet 1 on AP ap1 to Layer 2 aggregation group 1.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port link-aggregation group 1
# Assign interface GigabitEthernet 1 on APs in AP group 1 to Layer 2 aggregation group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port link-aggregation group 1
port link-type
Use port link-type to set the link type of an Ethernet port on an AP.
Use undo port link-type to restore the default.
undo port link-type
In an AP's Ethernet interface view, an Ethernet port uses the configuration in an AP group's Ethernet interface view.
In an AP group's Ethernet interface view, each Ethernet port is an access port.
access: Sets the port link type to access.
hybrid: Sets the port link type to hybrid.
trunk: Sets the port link type to trunk.
To change the link type of an Ethernet port from trunk to hybrid or vice versa, first set the link type to access.
# Configure GigabitEthernet 1 on AP ap1 as a trunk port.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port link-type trunk
# Configure GigabitEthernet 1 on APs with model in AP group 1 as a trunk port.
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port link-type trunk
port trunk permit vlan
Use port trunk permit vlan to assign a trunk port to the specified VLANs.
Use undo port trunk permit vlan to remove a trunk port from the specified VLANs.
undo port trunk permit vlan { vlan-id-list | all }
In an AP's Ethernet interface view, a trunk port uses the configuration in an AP group's Ethernet interface view.
In an AP group's Ethernet interface view, a trunk port allows packets only from VLAN 1 to pass through.
all: Specifies all VLANs.
A trunk port can allow multiple VLANs. If you execute this command multiple times on a trunk port, the trunk port allows all the specified VLANs.
On a trunk port, packets only from the PVID can pass through untagged.
To prevent unauthorized VLAN users from accessing restricted resources through the port, use the port trunk permit vlan all command with caution.
# Configure GigabitEthernet 1 on AP ap1 as a trunk port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port trunk permit vlan 2 4 50 to 100
# Configure GigabitEthernet 1 on APs with model in AP group 1 as a trunk port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100.
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port trunk permit vlan 2 4 50 to 100
port link-type
port trunk pvid
Use port trunk pvid to set the PVID for a trunk port on an AP.
Use undo port trunk pvid to restore the default.
port trunk pvid vlan vlan-id
In an AP group's Ethernet interface view, the PVID of a trunk port is VLAN 1.
You can use a nonexistent VLAN as the PVID for a trunk port. When you delete the PVID of a trunk port by using the undo vlan command, the PVID setting of the port does not change.
To enable a trunk port to transmit packets from its PVID, you must assign the trunk port to the PVID by using the port trunk permit vlan command.
# Configure GigabitEthernet 1 on AP ap1 as a trunk port, set its PVID to VLAN 100, and assign it to VLAN 100.
[Sysname-wlan-ap-ap1-gigabitethernet-1] port trunk pvid vlan 100
[Sysname-wlan-ap-ap1-gigabitethernet-1] port trunk permit vlan 100
# Configure GigabitEthernet 1 on APs with model WA6320 AP group 1 as a trunk port, set its PVID to VLAN 100, and assign it to VLAN 100.
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port trunk pvid vlan 100
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] port trunk permit vlan 100
port link-type
power-level default
Use power-level default to set the default input power level for an AP in case the AP cannot obtain its input power level.
Use undo power-level default to restore the default.
power-level default { high | low | middle }
In AP view, an AP uses the configuration in an AP group's AP model view.
In an AP group's AP model view, the default input power level of an AP is middle.
AP view
high: Specifies the high default input power level.
low: Specifies the low default input power level.
middle: Specifies the middle default input power level.
Configure this command for an AP in case the AP cannot obtain its input power level at startup.
The power level of an AP can be high, middle, or low. An AP automatically performs power supply mode detection to obtain its input power level at startup. If the AP fails to obtain the input power level, it operates at the low input power level before associating with an AC. After the association, it operates at the configured default input power level.
The following table shows the relationship between the AP's power supply mode and input power level:
Power supply mode |
Input power level |
· Power adapter. · Multiple PoE+ ports. · Combination of PoE and PoE+ ports. |
High |
· Single PoE+ port · Multiple PoE ports |
Middle |
Single PoE port |
Low |
An AP's support for MIMO modes and USB interfaces varies by power level, as shown in Table 28.
Table 28 AP's support for MIMO modes and USB interfaces
Input power level |
MIMO modes |
Whether USB interfaces can be enabled |
High |
1×1, 2×2, 3×3, and 4×4. |
Yes. |
Middle |
Yes when the MIMO mode is 1×1 or 2×2. |
Low |
1×1. |
No. |
The configuration in AP view takes precedence over the configuration in AP group' AP model view.
# Set the default input power level to high for AP ap1 in AP view.
[Sysname-wlan-ap-ap1] power-level default high
# Set the default input power level to high in AP model view of AP group g1.
[Sysname-wlan-ap-group-g1] ap-model WA6320
[Sysname-wlan-ap-group-g1-ap-model-WA6320] power-level default high
priority
Use priority to set the AP connection priority for the AC.
Use undo priority to restore the default.
priority priority
undo priority
In AP group view, the AP connection priority for the AC is 4.
AP view
AP group view
priority: Specifies the AP connection priority for the AC, in the range of 0 to 7. A larger value represents a higher connection priority.
The AP prefers to establish a CAPWAP tunnel with an AC that has higher connection priority.
The AP connection priority only takes effect during AC discovery.
# Set the AP connection priority for the AC to 7 for AP ap3.
[Sysname-wlan-ap-ap3] priority 7
# Set the AP connection priority for the AC to 7 for AP group group1.
[Sysname-wlan-ap-group-group1] priority 7
provision
Use provision to enable AP preprovisioning and enter AP provision view, or enter AP provision view. if AP preprovisioning is already enabled.
Use undo provision to disable AP preprovisioning.
provision
undo provision
In AP view, an AP uses the configuration in AP group view. If no configuration exists in AP group view, the AP uses the configuration in global configuration view.
In global configuration view, AP preprovisioning is disabled.
AP view
AP group view
AP preprovisioning allows you to configure network settings for APs on the AC. The AC automatically assigns these settings to the APs.
If you disable AP preprovisioning, network settings configured on the AC will be deleted. However, the operation does not affect the network settings already assigned to the APs.
The priorities of configurations in AP view, AP group view, and global configuration view are in descending order.
# Enable AP preprovisioning and enter AP provision view of AP ap1.
# Enable AP preprovisioning and enter AP provision view of AP group group1.
[Sysname-wlan-ap-group-group1-prvs]
# Enable AP preprovisioning globally and enter global provision view.
provision auto-recovery
Use provision auto-recovery enable to enable auto loading of preprovisioned settings.
Use provision auto-recovery disable to disable auto loading of preprovisioned settings.
Use undo provision auto-recovery to restore the default.
provision auto-recovery { disable | enable }
In AP group view, auto loading of preprovisioned settings is enabled.
AP view
AP group view
Auto loading of preprovisioned settings ensures successful CAPWAP tunnel establishment between AP and AC. An AP uses the following procedure to discover an AC when you enable this feature:
1. Uses the preprovisioned settings to discover an AC that has the AP's manual or auto AP configuration.
2. Reboots and uses other methods to discover ACs if AC discovery fails.
3. Reboots and uses the preprovisioned settings again to discover ACs if the AP still fails to discover the target AC.
This AC discovery process will be repeated until the AP discovers the target AC to establish a CAPWAP tunnel.
# Disable auto loading of preprovisioned settings for AP ap1.
[Sysname-ap-ap1] provision auto-recovery disable
# Disable auto loading of preprovisioned settings for APs in AP group group1.
[Sysname-wlan-ap-group-group1] provision auto-recovery disable
provision auto-update
Use provision auto-update enable to enable auto assignment of preprovisioned settings.
Use provision auto-update disable to disable auto assignment of preprovisioned settings.
Use undo provision auto-update to restore the default.
provision auto-update { disable | enable }
In AP group view, auto assignment of preprovisioned settings is disabled.
AP view
AP group view
This command enables the AC to automatically assign preprovisioned settings to an AP so that the AP can use the preprovisioned settings to come online.
This command applies only to offline APs. To deploy preprovisioned settings to online APs, use the save wlan ap provision command.
The configuration in AP provision view has higher priority than the configuration in AP group provision view.
# Enable auto assignment of preprovisioned settings for AP ap1.
[Sysname-ap-ap1] provision auto-update enable
# Enable auto assignment of preprovisioned settings for APs in AP group group1.
[Sysname-wlan-ap-group-group1] provision auto-update enable
qos priority
Use qos priority to set the port priority.
Use undo qos priority to restore the default.
qos priority priority-value
undo qos priority
In an AP group's Ethernet interface view, the port priority is 0.
priority-value: Specifies the port priority in the range of 0 to 7.
The configuration will be synchronized to all online APs only if remote configuration synchronization is activated. You can activate remote configuration synchronization by using the remote-configuration synchronize command.
# Set the port priority to 2 for GigabitEthernet 1 on AP ap1.
[Sysname-wlan-ap-ap1-gigabitethernet-1] qos priority 2
# Set the port priority to 2 for GigabitEthernet 1 on APs with model WA5620i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] qos priority 2
qos trust
Use qos trust to set the trusted packet priority type.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp }
undo qos trust
In an AP group's Ethernet interface view, no trusted packet priority type is set.
dot1p: Uses the 802.1e priority carried in packets for priority mapping.
dscp: Uses the DSCP priority carried in packets for priority mapping.
# Set the trusted packet priority type to dot1p for GigabitEthernet 1 on AP ap1.
[Sysname-wlan-ap-ap1-gigabitethernet-1] qos trust dot1p
# Set the trusted packet priority type to dot1p for GigabitEthernet 1 on APs with model WA5620i-ACN in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-gigabitethernet-1] qos trust dot1p
region-code (AP provision view/AP group provision view)
Use region-code to specify a region code.
Use undo region-code to restore the default.
region-code code
undo region-code
In AP group provision view, no region code is specified.
AP provision view
code: Specifies a region code. For more information about region codes, see Table 29.
Table 29 Region code information
Country |
Code |
Country |
Code |
Andorra |
AD |
Kenya |
KE |
United Arab Emirates |
AE |
Kuwait |
KW |
Albania |
AL |
Kazakhstan |
KZ |
Armenia |
AM |
Lebanon |
LB |
Australia |
AU |
Liechtenstein |
LI |
Argentina |
AR |
Sri Lanka |
LK |
Australia |
AT |
Lithuania |
LT |
Azerbaijan |
AZ |
Luxembourg |
LU |
Bosnia and Herzegovina |
BA |
Latvia |
LV |
Belgium |
BE |
Libyan |
LY |
Bulgaria |
BG |
Morocco |
MA |
Bahrain |
BH |
Monaco |
MC |
Brunei Darussalam |
BN |
Moldova |
MD |
Bolivia |
BO |
Macedonia |
MK |
Brazil |
BR |
Macau |
MO |
Bahamas |
BS |
Martinique |
MQ |
Belarus |
BY |
Malta |
MT |
Belize |
BZ |
Mauritius |
MU |
Canada |
CA |
Mexico |
MX |
Switzerland |
CH |
Malay Archipelago |
MY |
Cote d'ivoire |
CI |
Namibia |
NA |
Chile |
CL |
Nigeria |
NG |
China |
CN |
Nicaragua |
NI |
Colombia |
CO |
Netherlands |
NL |
Costarica |
CR |
Norway |
NO |
Serbia |
RS |
New Zealand |
NZ |
Cyprus |
CY |
Oman |
OM |
Czech Republic |
CZ |
Panama |
PA |
Germany |
DE |
Peru |
PE |
Denmark |
DK |
Poland |
PL |
Dominica |
DO |
Philippines |
PH |
Algeria |
DZ |
Pakistan |
PK |
Ecuador |
EC |
Puerto Rico |
PR |
Estonia |
EE |
Portugal |
PT |
Egypt |
EG |
Paraguay |
PY |
Spain |
ES |
Qatar |
QA |
Faroe Islands |
FO |
Romania |
RO |
Finland |
FI |
Russian Federation |
RU |
France |
FR |
Saudi Arabia |
SA |
Britain |
GB |
Sweden |
SE |
Georgia |
GE |
Singapore |
SG |
Gibraltar |
GI |
Slovenia |
SI |
Greenland |
GL |
Slovak |
SK |
Guadeloupe |
GP |
San Marino |
SM |
Greece |
GR |
Salvador |
SV |
Guatemala |
GT |
Syrian |
SY |
Guam |
GU |
Thailand |
TH |
Guyana |
GY |
Tunisia |
TN |
Honduras |
HN |
Turkey |
TR |
Hong Kong |
HK |
Trinidad and Tobago |
TT |
Croatia |
HR |
Taiwan, China |
TW |
Hungary |
HU |
Ukraine |
UA |
Iceland |
IS |
United States of America |
US |
India |
IN |
Uruguay |
UY |
Indonesia |
ID |
Uzbekistan |
UZ |
Ireland |
IE |
The Vatican City State |
VA |
Israel |
IL |
Venezuela |
VE |
Iraq |
IQ |
Virgin Islands |
VI |
Italy |
IT |
Vietnam |
VN |
Jamaica |
JM |
Yemen |
YE |
Jordan |
JO |
South Africa |
ZA |
Japan |
JP |
Zimbabwe |
ZW |
Korea, Republic of Korea |
KR |
The region code will take effect after an AP reboots and become invalid after the AP associates with the target AC.
The configuration in AP provision view takes precedence over the configuration in AP group provision view.
# Specify US as the region code in AP provision view of AP ap1.
[Sysname-wlan-ap-ap1-prvs] region-code US
# Specify US as the region code in AP group provision view of AP group group1.
[Sysname-wlan-ap-group-group1-prvs] region-code US
region-code (AP view/AP group view)
region-code code
undo region-code
In AP view, an AP uses the configuration in AP group view. If no region code is specified in AP group view, the AP uses the configuration in global configuration view.
AP view
AP group view
A region code determines characteristics such as available frequencies, available channels, and transmit power level. Set a valid region code before configuring an AP.
The priorities for the configuration in AP view, AP group view, and global configuration view are in descending order.
# Specify US as the region code for AP ap1.
[Sysname-wlan-ap-ap1] region-code US
# Specify US as the region code for AP group group1.
[Sysname-wlan-ap-group-group1] region-code US
region-code-lock
region-code (global configuration view)
region-code code
The region code is CN.
# Specify US as the global region code.
[Sysname-wlan-global-configuration] region-code US
region-code-lock
region-code-ie
Use region-code-ie to include or exclude region codes in beacon frames and probe responses and specify the installation environment type.
Use undo region-code-ie to restore the default.
region-code-ie { disable | enable { any | indoor | outdoor } }
undo region-code-ie
Beacon frames and probe responses contain region codes and the installation environment type is any.
Service template view
disable: Excludes region codes in beacon frames and probe responses.
enable: Includes region codes in beacon frames and probe responses.
any: Specifies APs that can be installed both indoors and outdoors.
indoor: Specifies APs that can only be installed indoors.
outdoor: Specifies APs that can only be installed outdoors.
If you bind different service templates to radios of an AP, make sure the service templates are specified with the same installation environment type.
# Include region codes in beacon frames and probe responses and specify the type of installation environment as indoor.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] region-code-ie enable indoor
region-code
region-code-lock
Use region-code-lock enable to lock the region code.
Use region-code-lock disable to unlock the region code.
Use undo region-code-lock to restore the default.
region-code-lock { disable | enable }
In global configuration view, the region code is not locked.
AP view
AP group view
A locked region code cannot be changed.
The region-code-lock enable command does not take effect on an AP if you execute this command without specifying a region code first in AP view. The AP's region code is determined by the region code configuration for the AP group to which the AP belongs, or by the global configuration. The same rule applies to an AP group in the same situation.
# Lock the region code for AP ap1.
[Sysname-wlan-ap-ap1] region-code-lock enable
# Lock the region code for AP group group1.
[Sysname-wlan-ap-group-group1] region-code-lock enable
# Lock the global region code.
[Sysname-wlan-global-configuration] region-code-lock enable
region-code
Use remote-configuration enable to enable the remote configuration assignment feature.
Use remote-configuration disable to disable the remote configuration assignment feature.
Use undo remote-configuration to restore the default.
remote-configuration { disable | enable }
undo remote-configuration enable
In AP group view, remote configuration assignment is disabled.
AP view
AP group view
The AC will assign related VLAN settings to APs only when the remote configuration assignment feature is enabled.
# Enable the remote configuration assignment feature for AP ap1.
[Sysname-wlan-ap-ap1] remote-configuration enable
# Enable the remote configuration assignment feature for AP group group1.
[Sysname-wlan-ap-group-group1] remote-configuration enable
Use remote-configuration synchronize to activate remote configuration synchronization.
In AP group view, remote configuration synchronization is not activated.
AP view
AP group view
CAUTION: This command clears all VLAN, link aggregation, and port settings (except for port isolation settings) on online APs and issues the settings on the AC to the APs. Please use it with caution. |
To update APs' configuration file or configure features that require a configuration file, you can use the map-configuration command to deploy a configuration file to APs. However, you must write related commands to the configuration file before deployment. This is time-consuming and is not applicable to a network with a large number of APs to deploy.
This feature enables the AC to directly synchronize AP settings such as VLAN, link aggregation, and port isolation changes to online APs.
Make sure remote configuration assignment is enabled before you execute this command.
As a best practice, do not execute both this command and the map-configuration command on the AC. If you must use both of them on the AC, make sure the VLAN, link aggregation, and port isolation settings in the configuration file to be deployed do not conflict with the settings on the AC.
# Activate remote configuration synchronization for AP ap1.
[Sysname] wlan ap ap1 model WA6320N
[Sysname-wlan-ap-ap1] remote-configuration synchronize
# Activate remote configuration synchronization for APs in AP group group1.
[Sysname-wlan-ap-group-group1] remote-configuration synchronize
report-interval
Use report-interval to set the interval at which APs in an AP monitor group report statistics to the AC.
Use undo report-interval to restore the default.
report-interval interval
APs in an AP monitor group report statistics to the AC at intervals of 50 seconds.
Monitor group view
interval: Specifies the interval at which APs in an AP monitor group report statistics to the AC, in the range of 10 to 120 seconds.
# Set the interval to 30 seconds for APs in an AP monitor group to report statistics to the AC.
[Sysname] wlan vip-ap-group
[Sysname-wlan-vip-ap-group] report-interval 30
ap-name
wlan vip-ap-group
reset wlan ap
Use reset wlan ap to reset all APs or the specified APs.
reset wlan ap { all | ap-group group-name | model model-name | name ap-name | native }
all: Specifies all APs connected to the AC.
ap-group group-name: Specifies an AP group by its name, a case-sensitive string of 1 to 31 characters.
model model-name: Specifies an AP model by model name.
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
native: Specifies all APs that have established CAPWAP tunnels with the AC.
This command terminates the CAPWAP tunnel between an AP and the AC and deletes all connection information about the AP.
# Reset the AP ap1.
<Sysname> reset wlan ap name ap1
Resetting the APs will terminate the CAPWAP tunnels with the AC. Continue? [Y/N]:
reset wlan ap connection-record
Use reset wlan ap connection-record to clear AP connection records on the AC.
reset wlan ap { all | name ap-name } connection-record
all: Specifies all APs.
# Clear all the AP connection records on the AC.
<Sysname> reset wlan ap all connection-record
reset wlan ap provision
Use reset wlan ap provision to delete configuration file wlan_ap_prvs.xml from all APs or the specified AP.
reset wlan ap provision { all | name ap-name }
This command takes effect only on APs that have established CAPWAP tunnels with the master AC and are in Run state.
For this command to take effect on an AP, restart the AP.
# Delete configuration file wlan_ap_prvs.xml from AP ap1.
<Sysname> reset wlan ap provision name ap1
reset wlan ap reboot-log
Use reset wlan ap reboot-log to clear the reboot logs of all APs or the specified AP.
reset wlan ap reboot-log { all | name ap-name }
# Clear the reboot logs of AP ap1.
<Sysname> reset wlan ap reboot-log name ap1
display wlan ap reboot-log
reset wlan ap unauthenticated
Use reset wlan ap unauthenticated to restart unauthenticated auto APs for re-authentication.
# Restart unauthenticated auto APs.
<Sysname> reset wlan ap unauthenticated
reset wlan tunnel latency ap
Use reset wlan tunnel latency ap to clear tunnel latency information for all APs or the specified AP.
reset wlan tunnel latency ap { all | name ap-name }
This command takes effect only on APs that have established tunnels with the master AC and are in Run state.
# Clear tunnel latency information for AP ap1.
<Sysname> reset wlan tunnel latency ap name ap1
display wlan ap tunnel latency
tunnel latency-detect
retransmit-count
Use retransmit-count to set the maximum number of AC request retransmission attempts.
Use undo retransmit-count to restore the default.
retransmit-count value
In AP group view, the maximum number of AC request retransmission attempts is 3.
AP view
AP group view
value: Specifies the maximum number of AC request retransmission attempts, in the range of 2 to 5.
The AC sends a request to an AP at the retransmission interval until the maximum number of request retransmission attempts is reached or a response is received.
Requests sent by the AC to an AP include the following types:
· Image Data Request.
· Configuration Update Request.
· Reset Request.
· Data Transfer Request.
· IEEE 802.11 WLAN Configuration Request.
· Station Configuration Request.
# Set the maximum number of AC request retransmission attempts to 4 for AP ap3.
[Sysname-wlan-ap-ap3] retransmit-count 4
# Set the maximum number of AC request retransmission attempts to 4 for APs in AP group group1.
[Sysname-wlan-ap-group-group1] retransmit-count 4
retransmit-interval
retransmit-interval
Use retransmit-interval to set the request retransmission interval for the AC to retransmit requests to an AP.
Use undo retransmit-interval to restore the default.
retransmit-interval interval
In AP group view, the request retransmission interval is 5 seconds.
AP view
AP group view
interval: Specifies the request retransmission interval in the range of 3 to 8 seconds.
· Reset Request.
# Set the request retransmission interval to 6 seconds for the AC to send requests to AP ap3.
[Sysname-wlan-ap-ap3] retransmit-interval 6
# Set the request retransmission interval to 6 seconds for the AC to send requests to APs in AP group group1.
[Sysname-wlan-ap-group-group1] retransmit-interval 6
retransmit-count
Use save wlan ap provision to deploy the provision configuration to all APs or the specified AP.
save wlan ap provision { all | name ap-name }
This command saves the added or modified preprovisioned settings to the wlan_ap_prvs.xml configuration file.
This command takes effect only on online APs that have established tunnels with the master AC.
This command has the same effect as the reset wlan ap provision command if no AP preprovisioned settings exist.
Preprovisioned settings configured in provision view take effect immediately when you execute the save wlan ap provision command.
Cancellations of preprovisioned settings in provision view do not take effect when you execute the save wlan ap provision command. For the cancellations to take effect on an AP, restart the AP.
# Save the configuration in AP provision view to configuration file wlan_ap_prvs.xml on AP ap1.
[Sysname-wlan-ap-ap1-prvs] ac ip 192.168.0.1
[Sysname-wlan-ap-ap1-prvs] save wlan ap provision name ap1
serial-id (AP group view)
Use serial-id to create an AP grouping rule by serial IDs.
Use undo serial-id to delete an AP grouping rule by serial IDs.
serial-id serial-id
undo serial-id serial-id
No AP grouping rules by serial IDs exist.
AP group view
serial-id: Specifies an AP serial ID, a case-insensitive string of 1 to 63 characters.
You can configure multiple AP grouping rules by serial IDs.
# Create an AP grouping rule by serial IDs for AP group group1.
[Sysname-wlan-ap-group-group1] serial-id 210235A1BSC123000037
wlan ap-group
serial-id (AP view)
Use serial-id to specify the serial ID for an AP.
Use undo serial-id to restore the default.
serial-id serial-id
undo serial-id
No serial ID is specified for an AP.
AP view
serial-id: Specifies the serial ID for an AP, a case-insensitive string of 1 to 63 characters.
Changing or deleting the serial ID of an AP terminates the CAPWAP tunnel if the AP has established a CAPWAP tunnel with an AC. Then the AP will reestablish a CAPWAP tunnel with the AC.
# Set the serial ID of AP ap1 to 219801A28N819CE0002T.
[Sysname-ap-ap1] serial-id 219801A28N819CE0002T
smartrate-ethernet
Use smartrate-ethernet to enter 2.5 GigabitEthernet interface view of an AP.
smartrate-ethernet interface-number
AP view
# Enter the interface view of Smartrate-Ethernet 1 from AP view.
[Sysname-wlan-ap-ap1] smartrate-ethernet 1
[Sysname-wlan-ap-ap1-smartrate-ethernet-1]
# Enter the interface view of Smartrate-Ethernet 1 from the AP model view of AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320] smartrate-ethernet 1
[Sysname-wlan-ap-group-group1-ap-model-WA6320-smartrate-ethernet-1]
snmp-agent trap enable wlan ap
Use snmp-agent trap enable wlan ap to enable SNMP notifications for AP management.
Use undo snmp-agent trap enable wlan ap to disable SNMP notifications for AP management.
SNMP notifications are disabled for AP management.
To report critical AP management events to an NMS, enable SNMP notifications for AP management. For AP management event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for AP management.
[Sysname] snmp-agent trap enable wlan ap
snmp-agent trap enable wlan capwap
Use snmp-agent trap enable wlan capwap to enable SNMP notifications for CAPWAP.
Use undo snmp-agent trap enable wlan capwap to disable SNMP notifications for CAPWAP.
SNMP notifications are disabled for CAPWAP.
To report critical CAPWAP events to an NMS, enable SNMP notifications for CAPWAP. For CAPWAP event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for CAPWAP.
[Sysname] snmp-agent trap enable wlan capwap
statistics-interval
Use statistics-interval to set the statistics report interval for an AP to send statistics reports to the AC.
Use undo statistics-interval to restore the default.
statistics-interval interval
In global configuration view, the statistics report interval is 50 seconds.
AP view
AP group view
interval: Specifies the statistics report interval in the range of 0 to 240 seconds.
Execute this command to change the interval for an AP to report its statistics. You can use these statistics to monitor the operating status of radios on the AP.
To disable an AP from reporting radio statistics to the AC, set the statistics report interval to 0.
# Set the statistics reports interval to 10 seconds for AP ap1.
[Sysname-wlan-ap-ap1] statistics-interval 10
# Set the statistics reports interval to 10 seconds for APs in AP group group1.
[Sysname-wlan-ap-group-group1] statistics-interval 10
# Set the statistics reports interval to 10 seconds globally.
[Sysname-wlan-global-configuration] statistics-interval 10
statistics-interval fast-report
Use statistics-interval fast-report to set the interval at which an AP fast reports specific statistics to the AC.
Use undo statistics-interval fast-report to restore the default.
statistics-interval fast-report fast-report-interval
In AP group view, the fast report interval is 0 seconds. An AP does not fast report statistics to the AC.
AP view
AP group view
fast-report-interval: Specifies the fast report interval in the range of 0 to 120 seconds.
Setting the interval to 0 disables an AP from fast reporting statistics to the AC.
APs can fast report only channel usage statistics to the AC.
# Set the fast report interval to 10 seconds for AP ap1.
[Sysname-wlan-ap-ap1] statistics-interval fast-report 10
# Set the fast report interval to 10 seconds for APs in AP group group1.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] statistics-interval fast-report 10
statistics-interval
ten-gigabitethernet
Use ten-gigabitethernet to enter 10-GE interface view of an AP.
ten-gigabitethernet interface-number
AP view
# Enter 10-GE 1 interface view of AP ap1.
[Sysname] wlan ap ap1 model WA6628
[Sysname-wlan-ap-ap1] ten-gigabitethernet 1
[Sysname-wlan-ap-ap1-ten-gigabitethernet-1]
# Enter 10-GE 1 interface view of APs with model WA6628 in AP group group1.
[Sysname-wlan-ap-group-group1] ap-model WA6628
[Sysname-wlan-ap-group-group1-ap-model-WA6628] ten-gigabitethernet 1
[Sysname-wlan-ap-group-group1-ap-model-WA6628-ten-gigabitethernet-1]
tunnel encryption
Use tunnel encryption enable to enable CAPWAP control tunnel encryption.
Use tunnel encryption disable to disable CAPWAP control tunnel encryption.
Use undo tunnel encryption enable to restore the default.
tunnel encryption { disable | enable }
In AP group view, CAPWAP control tunnel encryption is disabled.
AP view
AP group view
This feature will cause an AP to reassociate with the AC.
With this feature enabled, an AP performs a DTLS handshake and establishes a CAPWAP tunnel with the AC after receiving a discovery response with the encryption flag from the AC. Then, the AC and the AP encrypt control packets transmitted in the CAPWAP control tunnel after the DTLS handshake.
# Enable CAPWAP control tunnel encryption for AP ap1.
[Sysname-wlan-ap-ap1] tunnel encryption enable
This operation will reconnect the AP. Continue? [Y/N]
# Enable CAPWAP control tunnel encryption for APs in AP group group1.
[Sysname-wlan-ap-group-group1] tunnel encryption enable
This operation will reconnect member APs that are not enabled with CAPWAP control tunnel encryption. Continue? [Y/N]
Use tunnel latency-detect to configure CAPWAP tunnel latency detection.
tunnel latency-detect { start | stop }
CAPWAP tunnel latency detection is not started.
AP view
start: Starts CAPWAP tunnel latency detection.
stop: Stops CAPWAP tunnel latency detection.
CAPWAP tunnel latency detection enables the AC to detect the transmission latency of CAPWAP control frames or data frames from an AP to the AC and back.
When an AP goes offline, CAPWAP tunnel latency detection automatically stops. To restart CAPWAP tunnel latency detection when the AP comes online again, execute the tunnel latency-detect start command again.
The tunnel latency-detect start command takes effect only on APs that have established CAPWAP tunnels with the master AC and are in Run state.
Inside APs do not support this command.
# Start CAPWAP tunnel latency detection for AP ap1.
[Sysname-wlan-ap-ap1] tunnel latency-detect start
usb
Use usb enable to enable USB interfaces on APs.
Use usb disable to disable USB interfaces on APs.
Use undo usb to restore the default.
usb { disable | enable }
undo usb
In an AP group's AP model view, USB interfaces are disabled.
AP view
This command takes effect on an AP only when either of the following requirements is met:
· The power level of the AP is high.
· The power level of the AP is middle and the MIMO mode is 1×1 or 2×2.
For information about power levels, see "power-level default." For information about MIMO modes, see radio management in WLAN Configuration Guide.
# Enable USB interfaces in AP view.
[Sysname-wlan-ap-ap1] usb enable
# Enable USB interfaces in AP model view of AP group g1.
[Sysname-wlan-ap-group-g1-ap-model-WA6320] usb enable
power-level default
vlan
Use vlan vlan-id to create a VLAN for an AP and enter the VLAN view of the AP, or enter the view of an existing VLAN of an AP.
Use vlan vlan-id1 to vlan-id2 to create VLANs vlan-id1 through vlan-id2 for an AP, except for reserved VLANs.
Use vlan all to create VLANs 1 through 4094 for an AP.
Use undo vlan to delete the specified VLANs of an AP.
vlan { vlan-id1 [ to vlan-id2 ] | all }
undo vlan { vlan-id1 [ to vlan-id2 ] | all }
In AP group view, VLAN 1 (the default VLAN) exists on an AP.
AP view
AP group view
vlan-id1: Specifies a VLAN ID in the range of 1 to 4094.
vlan-id1 to vlan-id2: Specifies a VLAN range. The vlan-id1 and vlan-id2 arguments specify VLAN IDs. The value range for each of the two arguments is 1 to 4094. The value for the vlan-id2 argument cannot be lower than the value for the vlan-id1 argument.
all: Specifies all VLANs except for reserved VLANs. The keyword is not supported when the maximum number of VLANs that can be created on an AP is less than 4094. Support for this keyword depends on the AP model.
You cannot create or delete VLAN 1 (the default VLAN) or reserved VLANs.
# Create VLAN 2 for AP ap1 and enter the VLAN view of the VLAN.
# Create VLAN 2 for AP group group1 and enter the VLAN view of the VLAN.
[Sysname-wlan-ap-group-group1] vlan 2
wlan ap
Use wlan ap to create a manual AP and enter its view, or enter the view of an existing manual AP.
Use undo wlan ap to delete an AP.
wlan ap ap-name [ model model-name ]
undo wlan ap ap-name
No manual APs exist.
model model-name: Specifies the model name of the AP. You must specify the model name when you create an AP.
If the specified AP has established a CAPWAP tunnel, the undo wlan ap command also terminates the tunnel.
# Create an AP named ap1 with model WA6320.
wlan ap-authentication
Use wlan ap-authentication to manually authenticate unauthenticated auto APs.
wlan ap-authentication { accept | reject } ap-unauthenticated { all | name ap-name }
Manual authentication is not configured for unauthenticated auto APs.
accept: Enables unauthenticated auto APs to pass authentication and generate ACL permit rules. Authenticated auto APs can provide wireless services.
reject: Rejects unauthenticated auto APs and generates ACL deny rules. If you specify this keyword, the command logs off all online unauthenticated auto APs.
all: Specifies all unauthenticated auto APs.
name ap-name: Specifies an unauthenticated auto AP by its name, a case-sensitive string of 1 to 64 characters.
Unauthenticated auto APs can associate with the AC but cannot provide wireless services. You can execute this command to authenticate these APs.
Before you execute this command, perform the following tasks:
· Use the acl wlan ap command to create a WLAN AP ACL.
· Use the wlan ap-authentication acl command to specify the ACL as the ACL for authenticating unauthenticated auto APs.
The generated ACL rules will be added to the specified ACL.
# Enable unauthenticated auto APs to pass authentication and generate permit rules in ACL 200.
[Sysname] acl wlan ap 200
[Sysname-acl-ap-200] quit
[Sysname] wlan ap-authentication acl 200
[Sysname] wlan ap-authentication accept ap-unauthenticated all
acl wlan ap
permit-unauthenticated
Use wlan ap-authentication acl to specify an ACL for authenticating auto APs.
Use undo wlan ap-authentication acl to restore the default.
wlan ap-authentication acl { acl-number | name acl-name }
No ACL is specified for authenticating auto APs.
acl-number: Specifies a WLAN AP ACL by its number, in the range of 200 to 299.
name acl-name: Specifies a WLAN AP ACL by its name, a case-insensitive string of 1 to 63 characters. The string must start with a letter and cannot be all.
Before you execute this command, use the acl wlan ap command to create a WLAN AP ACL and configure ACL rules. You can use either of the following methods to configure ACL rules:
· Use the ap-authentication import command.
· Use the rule command. If this method is used, make sure the match criterion used in the rule is consistent with the auto AP authentication method. To configure an auto AP authentication method, use the wlan ap-authentication method command.
Unauthenticated auto APs that match ACL permit rules are allowed to associate with the AC. Unauthenticated auto APs that match ACL deny rules or do not match any ACL rules are rejected to associate with the AC.
If you do not configure any ACL rules, all auto APs will become unauthenticated.
# Specify ACL 200 for authenticating auto APs by serial ID.
[Sysname-acl-ap-200] rule 0 permit serial-id 219801A28N819CE0002T
acl wlan ap
rule
wlan ap-authentication import
wlan ap-authentication domain
Use wlan ap-authentication domain to configure an ISP domain for auto AP authentication.
Use undo wlan ap-authentication domain to restore the default.
wlan ap-authentication domain domain-name
No ISP domain is configured for auto AP authentication.
domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters. For information about ISP domains, see AAA in Security Configuration Guide.
You must configure this command when remote authentication is configured. If the remote authentication succeeds, the AC accepts the AP. If it does not succeed, the AC rejects the AP.
# Configure the authentication domain as office for auto AP authentication.
[Sysname] wlan ap-authentication domain office
wlan ap-authentication enable
Use wlan ap-authentication enable to enable auto AP authentication.
Use undo wlan ap-authentication enable to disable auto AP authentication.
Auto AP authentication is disabled.
Auto AP authentication only takes effect on auto APs that have not come online. It does not take effect on online auto APs, manual APs, and manual APs converted from auto APs.
Auto AP authentication does not take effect on online auto APs.
# Enable auto AP authentication.
[Sysname] wlan ap-authentication enable
Use wlan ap-authentication import to import an authentication file and generate corresponding ACL permit rules for auto AP authentication.
wlan ap-authentication import file-name
file-name: Specifies the name of an auto AP authentication file. It is a case-insensitive string of 1 to 32 characters and must have extension .txt.
An auto AP authentication file contains either the MAC address or serial ID of auto APs but not both of them. The MAC addresses must be in the format of HH-HH-HH-HH-HH-HH. MAC addresses and serial IDs are comma-separated.
Before you execute this command, make sure the following tasks are completed:
· Use the wlan ap-authentication acl command to specify an ACL.
The generated permit rules will be added to the ACL.
· Use the wlan ap-authentication method command to specify an auto AP authentication method.
The ACL rules are generated according to the authentication method. Make sure the authentication file format is consistent with the authentication method.
# Import auto AP authentication file office.txt to generate ACL permit rules in ACL 200.
[Sysname] acl number 200
[Sysname] wlan ap-authentication import office.txt
Use wlan ap-authentication method to specify an auto AP authentication method.
Use undo wlan ap-authentication method to restore the default.
wlan ap-authentication method { mac-address | serial-id }
Auto APs are authenticated by MAC address.
mac-address: Specifies the MAC address authentication method.
serial-id: Specifies the serial ID authentication method.
# Authenticate auto APs by AP serial ID.
[Sysname] wlan ap-authentication method serial-id
wlan ap-authentication permit-unauthenticated
Use wlan ap-authentication permit-unauthenticated to enable unauthenticated auto APs to associate with the AC.
Use undo wlan ap-authentication permit-unauthenticated to disable unauthenticated auto APs from associating with the AC.
Unauthenticated auto APs are allowed to associate with the AC, but they cannot provide wireless services.
Unauthenticated auto APs are auto APs that do not match an ACL rule in local authentication. Unauthenticated auto APs can associate with the AC but cannot provide wireless services. You can use the undo wlan ap-authentication permit-unauthenticated command to log off all unauthenticated auto APs.
# Disable unauthenticated auto APs from associating with the AC.
[Sysname] undo wlan ap-authentication permit-unauthenticated
wlan ap-certificate verification
Use wlan ap-certificate verification to enable AP certificate verification.
Use undo wlan ap-certificate verification to restore the default.
AP certificate verification is disabled.
This feature takes effect at AP associations subsequent to feature enabling.
With this feature enabled, when an AP attempts to come online, the AC identifies whether any of its saved AP certificates uses the AP's MAC address as its CN. If a match is found, the AC permits the AP to come online. If no match is found, the AC denies the association request from the AP.
To use AP certificate verification, you must perform the following tasks:
· Generate AP certificates with APs' MAC addresses as certificate CNs. The MAC addresses must be in the aa:bb:cc:dd:ee:ff format.
· Upload the certificates to the AC through FTP or TFTP.
· Execute the download file command to download the certificates to the corresponding APs.
# Enable AP certificate verification.
[Sysname] wlan ap-certificate verification
tunnel encryption
wlan capwap encryption
wlan ap-image-deploy
Use wlan ap-image-deploy to deploy an image file to all the online APs.
wlan ap-image-deploy { all | ap-group group-name | name ap-name }
ap-group group-name: Specifies an AP group by its name, a case-insensitive string of 1 to 32 characters. The specified AP group must already exist.
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). The specified AP must already exist.
This feature enables you to upgrade the image of all the online APs. For the upgrade to take effect, reboot the APs after upgrade.
Before executing this command, you must upload the image file to the storage media of the AC. You can execute the wlan image-load filepath command to specify the storage media.
# Deploy an image file to all APs.
[Sysname] wlan ap-image-deploy all
wlan apdb
Use wlan apdb to configure the mapping between a software version and a hardware version of an AP model.
Use undo wlan apdb to restore the default.
wlan apdb model-name hardware-version software-version
undo wlan apdb model-name hardware-version
The software version for a hardware version of an AP model is the software version that is stored in APDB user scripts.
model-name: Specifies an AP model name in the APDB.
hardware-version: Specifies a hardware version in the APDB.
software-version: Specifies an AP software version, a case-insensitive string of 1 to 31 characters.
CAUTION: To avoid CAPWAP tunnel establishment failure, use this command under the guidance of H3C Support. |
This command is used together with the software upgrade feature for software version consistency check during software upgrade.
Use this command only when the software version you expect for an AP is inconsistent with the software version specified for the AP model stored in the APDB.
# Configure the mapping between software version E2108 and hardware version Ver.C of AP model WA6320.
[Sysname] wlan apdb WA6320 Ver.C E2108
firmware-upgrade
wlan apdb file
Use wlan apdb file to load an APDB user script.
Use undo wlan apdb file to delete an APDB user script.
wlan apdb file user.apdb
undo wlan apdb file
No APDB user script is loaded.
user.apdb: Specifies an APDB user profile by its name, a case-sensitive string of 1 to 63 characters. apdb is the filename extension.
When you load an APDB user script, follow these restrictions and guidelines:
· If you load multiple user scripts on the AC, the most recently loaded user script overwrites the old user scripts.
· Make sure the user script is valid. Invalid scripts can cause loading failure.
· The AP models in the user script must be different from the AP models in the system script.
· If you rename the user script in the file system, reload the user script to prevent AP model configuration in the user script from being lost after an AC reboot.
· If you replace the user script with a new user script in the file system, reload the new user script. If the new user script does not include AP model information saved in the replaced user script, the AP model information will be lost after an AC reboot.
· If you delete a user script in the file system, reload a new user script. If you do not reload a new user script, the AP model configuration in the user script will be lost after an AC reboot.
If an old user script already exists, follow these restrictions and guidelines when you load an APDB user script:
· If a manual AP or an online auto AP whose model is listed in the old user script exists ,you can load a new user script only when you delete the corresponding AP model information on the AC.
· If APs of an AP model listed in the old user script have been added to an AP group, you can load a new user script only when you remove the APs from the AP group.
· If the old user script includes an AP model whose software version was already configured, you can load a new user script only when you use the wlan apdb command to restore the original software version.
# Load user script user.apdb.
[Sysname] wlan apdb file user.apdb
wlan apdb
wlan ap-group
Use wlan ap-group to create an AP group and enter its view, or enter the view of an existing AP group.
Use undo wlan ap-group to delete an AP group.
wlan ap-group group-name
undo wlan ap-group group-name
The default AP group default-group exists, and it cannot be deleted.
group-name: Specifies an AP group by its name, a case-insensitive string of 1 to 31 characters.
# Create an AP group named group1.
display wlan ap-group
wlan auto-ap enable
Use wlan auto-ap enable to enable the auto AP feature.
Use undo wlan auto-ap enable to disable the auto AP feature.
wlan auto-ap enable
If the device starts up with the initial configuration, the auto AP feature is disabled. If the device starts up with the factory defaults, the initial state of the auto AP feature depends on the factory defaults. To view the factory defaults, use the display default-configuration command in any view. For more information about the initial configuration and the factory defaults, see configuration file management in Fundamentals Configuration Guide.
This command enables an AP to connect to an AC without manual AP configuration. It simplifies configuration when you deploy a large number of APs in a WLAN.
To configure an auto AP, you must use auto-AP persistence to convert the auto AP to a manual AP or configure it through an AP group.
# Enable the auto AP feature.
[Sysname] wlan auto-ap enable
wlan auto-ap persistent
Use wlan auto-ap persistent to convert online auto APs to manual APs.
wlan auto-ap persistent { all | name auto-ap-name [ new-ap-name ] }
all: Specifies all online auto APs. If you specify this keyword, the command converts all online auto APs to manual APs with AP names unchanged.
name auto-ap-name: Specifies an online auto AP.
new-ap-name: Specifies a new name for the AP, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify this argument, the converted manual AP uses the name of the auto AP.
# Convert the auto AP whose MAC address is 0001-ab12-cd36 to manual AP ap2.
[Sysname] wlan auto-ap persistent name 0001-ab12-cd36 ap2
wlan auto-persistent enable
Use wlan auto-persistent enable to convert auto APs to manual APs after they come online.
Use undo wlan auto-persistent enable to restore the default.
Auto AP conversion is disabled.
This command takes effect only on auto APs that come online after you execute this command. For auto APs that are already online, use the wlan auto-ap persistent command to convert them to manual APs.
# Enable auto AP conversion.
[Sysname] wlan auto-persistent enable
wlan capwap discovery-policy unicast
Use wlan capwap discovery-policy unicast to enable an AC to respond only to unicast discovery requests.
Use undo wlan capwap discovery-policy to disable an AC to respond only to unicast discovery requests.
An AC can respond to unicast, multicast, and broadcast discovery requests.
# Enable the AC to respond only to unicast discovery requests.
[Sysname] wlan capwap discovery-policy unicast
Use wlan capwap encryption to specify the certificate used by CAPWAP control tunnel encryption.
Use undo wlan capwap encryption to restore the default.
wlan capwap encryption certificate cer-name key key-name ca ca-name
CAPWAP control tunnel encryption uses the built-in certificate.
certificate cer-name: Specifies the certificate name with the file suffix attached, cer-name.pem for example. The certificate must be in the .pem or .cer format.
key key-name: Specifies the key file name with the file suffix attached, key-name.pem for example. The key file must be in the .pem or .cer format.
ca ca-name: Specifies the CA certificate name with the file suffix attached, ca-name.pem for example. The CA certificate must be in the .pem or .cer format.
Before specifying a certificate, you must first save the certificate, key, and CA certificate to the file system of the AC.
For the configuration to take effect, perform this task before you enable CAPWAP control tunnel encryption.
# Specify a certificate for CAPWAP control tunnel encryption.
[Sysname] wlan capwap encryption certificate server.cer key server.key ca cacert.cer
tunnel encryption
wlan description
Use wlan description to configure a description for the AC.
Use undo wlan description to restore the default.
wlan description text
An AC does not have a description.
text: Specifies the description, a case-sensitive string of 1 to 64 characters.
If multiple ACs exist in a WLAN, you can specify a description for each AC to help identify them.
To display the description of an AC, execute the display this command.
# Configure the AC's description as test.
[Sysname] wlan description test
wlan detect-anomaly enable
Use wlan detect-anomaly enable to enable service anomaly detection.
Use undo wlan detect-anomaly enable to disable service anomaly detection.
Service anomaly detection is disabled.
This feature enables an AC to check service status and start a reboot timer (10 minutes) upon detecting that no APs are associated with the AC. When the reboot timer expires, the AC restarts. If an AP comes online before the timer expires, the AC deletes the timer.
With this feature disabled, the AC cannot restart automatically if a service exception occurs. As a best practice, do not disable this feature.
# Enable service anomaly detection.
[Sysname] wlan detect-anomaly enable
wlan enable
Use wlan enable to enable the WLAN function.
Use undo wlan enable to disable the WLAN function.
wlan enable
undo wlan enable
The WLAN function is enabled.
CAUTION: Disabling the WLAN function logs off all online APs. Please use this feature with caution. |
# Disable the WLAN function.
[Sysname] undo wlan enable
Disabling the WLAN function will log off all the online APs. Continue? [Y/N]
wlan global-configuration
Use wlan global-configuration to enter global configuration view.
The configuration priorities for an AP in AP view, AP group view, and global configuration view are in descending order. If no settings are configured in one view, the settings in the view with a lower priority are used. If no settings are configured in any one of the three views, the AP uses the default configuration in the view that has the lowest priority.
# Enter global configuration view.
[Sysname] wlan global-configuration
Use wlan image-load filepath to specify the preferred location for the AC to obtain an AP image file for software version assignment.
Use undo wlan image-load filepath to restore the default.
wlan image-load filepath { local | ram }
The AC prefers the AP image file stored in the RAM when assigning a software version to APs.
local: Specifies the local folder as the preferred location to obtain an AP image file. If the local folder does not contain an AP image file, the AC obtains the AP image file from the RAM. If the RAM does not contain an AP image file, the AC fails to obtain an AP image file.
ram: Specifies the RAM as the preferred location to obtain an AP image file. If the RAM does not contain an AP image file, the AC obtains the AP image file from the local folder. If the local folder does not contain an AP image file, the AC fails to obtain an AP image file.
The AC image file contains AP image files. The AC reads the AP image files into the RAM when it starts.
Specify the local keyword only when the following conditions are met:
· The required AP image file is not contained in the AC's image file.
· The software version an AP uses when it comes online has been specified using the wlan apdb command.
When you specify the local keyword, make sure the AC uses a CF or flash card as the default file system and the AP image file is stored in the root directory of the file system on the AC.
The AC can assign only .ipe AP image files to APs.
# Specify the local folder as the preferred location to obtain an AP image file for AP software version assignment.
[Sysname] wlan image-load filepath local
wlan re-group
Use wlan re-group to move an AP grouping rule or a list of AP grouping rules to the specified AP group.
wlan re-group { ap ap-name | ap-group source-group-name | mac-address mac-address | serial-id serial-id } group-name
ap ap-name: Specifies an AP grouping rule by AP names.
ap-group source-group-name: Specifies the source AP group. The source AP group cannot be the default AP group.
mac-address mac-address: Specifies an AP grouping rule by MAC addresses.
serial-id serial-id: Specifies an AP grouping rule by serial IDs.
group-name: Specifies the target AP group. The target AP group cannot be the default AP group.
# Create an AP group named group1, and create AP grouping rules by AP names to add APs ap1, ap2, and ap3 to AP group group1.
[Sysname-wlan-ap-group-group1] ap ap1 ap2 ap3
[Sysname-wlan-ap-group-group1] quit
# Create an AP group named group2, and move an AP grouping rule by AP names to AP group group2.
[Sysname] wlan ap-group group2
[Sysname-wlan-ap-group-group2] quit
[Sysname] wlan re-group ap ap1 group2
wlan rename-ap
Use wlan rename-ap to rename a manual AP.
wlan rename-ap ap-name new-ap-name
ap-name: Specifies a manual AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
new-ap-name: Specifies a new AP name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Change the name of AP ap1 to ap1-office.
[Sysname] wlan rename-ap ap1 ap1-office
wlan tcp mss
Use wlan tcp mss to set the maximum TCP segment size (TCP MSS) for CAPWAP tunnels.
Use undo wlan tcp mss to restore the default.
wlan tcp mss value
undo wlan tcp mss
The TCP MSS is 1460 bytes for CAPWAP tunnels.
value: Specifies the TCP MSS in bytes in the range of 128 to 2048.
This command sets the value of the MSS option in SYN packets transmitted over a CAPWAP tunnel.
The MSS option informs the receiver of the largest segment that the sender can accept. Each end announces its MSS during TCP connection establishment. If the size of a TCP segment is smaller than or equal to the MSS of the receiver, TCP sends the TCP segment without fragmentation. If not, TCP fragments the segment based on the receiver's MSS.
# Set the TCP MSS to 2000 bytes for CAPWAP tunnels.
[Sysname] wlan tcp mss 2000
wlan timezone-sync enable
Use wlan timezone-sync enable to enable time zone synchronization.
Use undo wlan timezone-sync enable to restore the default.
Time zone synchronization is enabled.
# Enable time zone synchronization.
[Sysname] wlan timezone-sync enable
wlan trap ap-number threshold
Use wlan trap ap-number threshold to set the online AP quantity threshold for triggering an SNMP trap.
Use undo wlan trap ap-number threshold to restore the default.
wlan trap ap-number threshold percent
The online AP quantity threshold for triggering an SNMP trap is 100. The AC will not send SNMP traps.
percent: Specifies the online AP quantity threshold for triggering an SNMP trap, in the range of 30 to 100, in percentage.
With SNMP notifications and this command configured, the AC sends overload traps to the SNMP module when the number of online APs to the number of APs allowed by the license exceeds the specified threshold. If the threshold is exceeded, the AC sends an SNMP recover trap every time an AP comes online. When the number drops below the threshold, the AC sends recover traps to the SNMP module.
If you set the threshold to 100, the AC will not send overload traps, because the number of online APs will not exceed the number of APs allowed by the license.
# Set the online AP quantity threshold for triggering an SNMP trap to 50.
[Sysname] wlan trap ap-number threshold 50
wlan tunnel-down echo-check enable
Use wlan tunnel-down echo-check enable to enable APs to use ICMP echo requests to check reachability to the AC upon a CAPWAP control tunnel disconnection.
Use undo wlan tunnel-down echo-check enable to disable APs from using ICMP echo requests to check reachability to the AC upon a CAPWAP control tunnel disconnection.
APs are disabled from using ICMP echo requests to check reachability to the AC upon a CAPWAP control tunnel disconnection.
With this feature enabled, an AP sends an ICMP echo request to the AC to check reachability to the AC when the CAPWAP control tunnel between them goes down. The check result is saved as a TXT file named ap-diag on the AP. The file contains information about whether the CAPWAP control tunnel disconnection is caused by link failure betweeen the AC and the AP.
Disable this feature to reduce the load of an AC if that AC must send a large number of ICMP echo replies to APs. After you disable this feature, the ap-diag file will be deleted.
# Enable APs to use ICMP echo requests to check reachability to the AC upon a CAPWAP control tunnel disconnection.
<Sysname> sysname-view
[Sysname] wlan tunnel-down echo-check enable
wlan up-link type
Use wlan up-link type to specify the uplink interface type for APs.
Use undo wlan up-link type to restore the default.
wlan up-link type { dialer | vlan }
The uplink interface type is dialer for APs.
dialer: Specifies the dialer type.
vlan: Specifies the VLAN type.
An AP can use a dialer interface or VLAN interface as an uplink interface for connecting to the AC. You can perform this task to specify the uplink interface type.
If you specify the dialer type, an AP uses a dialer interface to connect to the AC unless no dialer interface is available or the IP address of the dialer interface cannot be obtained. If AC association with the VLAN interface also fails, the AP tries with the dialer interface and VLAN interface alternatively until a connection is established.
If you specify the VLAN type, an AP can only use a VLAN interface to connect to the AC.
# Specify the uplink interface as dialer for APs.
[sysname] wlan up-link type dialer
wlan vip-ap-group
Use wlan vip-ap-group to create an AP monitor group and enter its view or enter the view of an existing AP monitor group.
Use undo wlan vip-ap-group to delete the AP monitor group.
wlan vip-ap-group
No AP monitor group exists.
APs in an AP monitor group can report client quantity, radio traffic, channel usage, and AP anomalies to the AC.
# Create an AP monitor group.
ap-name
report-interval
