07-Layer 2 - LAN Switching
HomeSupportNFVH3C VSRReference GuidesMIB CompanionH3C VSR Series Virtual Service Router MIB Reference-R1362-6W10007-Layer 2 - LAN Switching
19-RBRIDGE-MIB
19-RBRIDGE-MIB 164.32 KB
RBRIDGE-MIB
About this MIB
Use this MIB to manage TRILL-capable RBridges.
MIB file name
rfc6850-rbridge.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).rbridgeMIB(214)
Scalar objects
rbridgeBaseTrillVersion (1.3.6.1.2.1.214.1.1.1)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Standard MIB values.
Maximum TRILL version number that this RBridge supports.
As per the MIB.
rbridgeBaseNumPorts (1.3.6.1.2.1.214.1.1.2)
Object (OID)
Access
Value range
Implementation
rbridgeBaseNumPorts
read-only
Unsigned32
Number of ports controlled by an RBridge.
As per the MIB.
rbridgeBaseUniMultipathEnable (1.3.6.1.2.1.214.1.1.4)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Enabling state of unicast TRILL multipathing. true(1) means enabled.
As per the MIB.
rbridgeBaseMultiMultipathEnable (1.3.6.1.2.1.214.1.1.5)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Enabling state of multidestination TRILL multipathing. true(1) means enabled.
The object can only be read.
rbridgeBaseAcceptEncapNonadj (1.3.6.1.2.1.214.1.1.6)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Accept TRILL-encapsulated frames from a neighbor with which this RBridge does not have an IS-IS adjacency when the value of this object is true (1).
The object can only be read. The value is fixed at False(2).
rbridgeBaseNicknameNumber (1.3.6.1.2.1.214.1.1.7)
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Unsigned32 (1..256)
Number of nicknames this RBridge should acquire.
The object can only be read. The value is fixed at 1.
rbridgeDtreePriority (1.3.6.1.2.1.214.1.7.1)
Object (OID)
Access
Value range
Implementation
Read-write
Unsigned32
Unsigned32 (1..65535)
Distribution tree root priority for this RBridge.
As per the MIB.
rbridgeDtreeActiveTrees (1.3.6.1.2.1.214.1.7.2)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Total number of trees being computed by all RBridges in the network.
As per the MIB.
rbridgeDtreeMaxTrees (1.3.6.1.2.1.214.1.7.3)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Maximum number of trees this RBridge can compute.
The value is fixed at 15.
rbridgeDtreeDesiredUseTrees (1.3.6.1.2.1.214.1.7.4)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Maximum number of trees this RBridge would like to use for transmission of ingress multi-destination frames.
As per the MIB.
rbridgeTrillMinMtuDesired (1.3.6.1.2.1.214.1.8.1)
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Desired minimum acceptable inter-RBridge link MTU for the network.
The value range is 512 to 16384.
rbridgeTrillSz (1.3.6.1.2.1.214.1.8.2)
Object (OID)
Access
Value range
Implementation
rbridgeTrillSz(1.3.6.1.2.1.214.1.8.2)
read-only
Unsigned32
Minimum acceptable inter-RBridge link size for the network for the proper operation of TRILL IS-IS.
As per the MIB.
Tabular objects
rbridgeBaseNicknameTable
About this table
Use this table to obtain information about nicknames configured by an operator or learned dynamically by this RBridge.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is rbridgeBaseNicknameName.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.214.1.1.8.1.1)
not-accessible
RbridgeNickname
16-bit abbreviation for an RBridge's 48-bit IS-IS system ID.
As per the MIB.
rbridgeBaseNicknamePriority
(1.3.6.1.2.1.214.1.1.8.1.2)
read-create
Unsigned32
Unsigned32 (0..255)
RBridge's priority to hold this nickname.
In an automatically generated entry, this object cannot be modified.
rbridgeBaseNicknameDtrPriority
(1.3.6.1.2.1.214.1.1.8.1.3)
read-create
Unsigned32
Distribution tree root priority for this nickname.
rbridgeBaseNicknameType
(1.3.6.1.2.1.214.1.1.8.1.4)
read-only
INTEGER
static(1),
dynamic(2)
Nickname type. The default is static(1).
As per the MIB.
rbridgeBaseNicknameRowStatus
(1.3.6.1.2.1.214.1.1.8.1.5)
read-create
RowStatus
State of the current entry.
Available values are active(1), createAndGo(4), and destroy(6).
An RBridge can have only one such an entry. When a new entry is added, the old entry is overwritten. When an entry is deleted, a new entry is automatically generated.
In an automatically generated entry, this object cannot be deleted.
rbridgeBasePortTable
About this table
Use this to obtain basic information about ports associated with an RBridge.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is rbridgeBasePort.
Object (OID)
Access
Value range
Implementation
rbridgeBasePort (1.3.6.1.2.1.214.1.1.9.1.1)
not-accessible
Unsigned32
Port number of the port for which this entry contains RBridge management information.
As per the MIB.
rbridgeBasePortIfIndex (1.3.6.1.2.1.214.1.1.9.1.2)
read-only
InterfaceIndex
Index of the interface corresponding to this port in the IF-MIB.
As per the MIB.
rbridgeBasePortTrunkPort (1.3.6.1.2.1.214.1.1.9.1.4)
read-write
TruthValue
true(1),
false(2)
Bit for disabling the endpoint service.
When this bit is set (true), all native frames received on the port and all native frames that would have been sent on the port are discarded.
The default is false (2).
The rbridgeBasePortTrunkPort and rbridgeBasePortAccessPort objects cannot be both set to false(2).
rbridgeBasePortAccessPort (1.3.6.1.2.1.214.1.1.9.1.5)
read-write
TruthValue
true(1),
false(2)
Bit for disabling TRILL traffic.
If this bit is set to true(1), the port does not send any TRILL frames except TRILL-Hello frames.
The default is true (1).
rbridgeBasePortState (1.3.6.1.2.1.214.1.1.9.1.7)
read-only
INTEGER
uninhibited(1),
portInhibited(2),
vlanInhibited(3),
disabled(4),
broken(5)
Current state of a port.
As per the MIB.
rbridgeBasePortInhibitionTime (1.3.6.1.2.1.214.1.1.9.1.8)
read-write
Unsigned32
Time in seconds that this RBridge will inhibit forwarding on this port after it observes a spanning tree root bridge change on a link or receives conflicting VLAN forwarder information.
The default is 30.
The value range is 0 to 30.
rbridgeBasePortDesiredDesigVlan (1.3.6.1.2.1.214.1.1.9.1.10)
read-write
VlanId
VLAN that a Designated RBridge (DRB) will specify in its TRILL-Hellos as the VLAN to be used by all RBridges on the link for TRILL frames.
The default is that of rbridgeBasePortDesigVlan.
rbridgeBasePortDesigVlan (1.3.6.1.2.1.214.1.1.9.1.11)
read-only
VlanId
VLAN being used on this link for TRILL frames.
The object does not return any value when the port state is down or no VLAN is enabled.
rbridgeBasePortStpRoot (1.3.6.1.2.1.214.1.1.9.1.12)
read-only
BridgeId
Bridge identifier of the root of the spanning tree learned from a Bridge PDU (BPDU) received on this port.
As per the MIB.
rbridgeBasePortStpRootChanges (1.3.6.1.2.1.214.1.1.9.1.13)
read-only
Counter32
Number of times a change in the root bridge is seen from spanning tree BPDUs received on this port, indicating a change in bridged LAN topology.
As per the MIB.
rbridgeUniFdbTable
About this table
Use this table to obtain the information about unicast entries for which the device has forwarding and/or filtering information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are rbridgeFdbId and rbridgeUniFdbAddr.
Object (OID)
Access
Value range
Implementation
rbridgeFdbId
(1.3.6.1.2.1.214.1.2.4.1.1)
not-accessible
Unsigned32
Unsigned32 (0..4294967295)
ID of this filtering database.
As per the MIB.
rbridgeUniFdbAddr
(1.3.6.1.2.1.214.1.2.4.1.2)
not-accessible
MacAddress
MAC address for which the device has forwarding information.
As per the MIB.
rbridgeUniFdbNickname
(1.3.6.1.2.1.214.1.2.4.1.4)
read-only
RbridgeNickname
RBridge nickname that is placed in the egress nickname field of a TRILL frame sent to the current address.
As per the MIB.
rbridgeUniFdbStatus
(1.3.6.1.2.1.214.1.2.4.1.6)
read-only
INTEGER
other(1),
invalid(2),
learned(3),
self(4),
mgmt(5),
esadi(6)
As per the MIB.
rbridgeUniFibTable
About this table
Use this table to obtain the known nicknames of an RBridge.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are rbridgeUniFibNickname, rbridgeUniFibPort, and rbridgeUniFibNextHop.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.214.1.2.5.1.1)
not-accessible
RbridgeNickname
RBridge nickname for which this RBridge has forwarding information.
As per the MIB.
rbridgeUniFibPort
(1.3.6.1.2.1.214.1.2.5.1.2)
not-accessible
Unsigned32
Unsigned32 (0..65535)
RBridge port number of the corresponding RBridge.
As per the MIB.
(1.3.6.1.2.1.214.1.2.5.1.3)
not-accessible
RbridgeNickname
Nickname of the next-hop RBridge for the path towards the RBridge whose nickname is specified in this entry.
As per the MIB.
rbridgeUniFibHopCount
(1.3.6.1.2.1.214.1.2.5.1.4)
read-only
Unsigned32
Hop count from this ingress RBridge to the egress RBridge.
As per the MIB.
rbridgeMultiFibTable
About this table
Use this table to obtain information about egress nicknames used for multi-destination frame forwarding by this RBridge.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is rbridgeMultiFibNickname.
Object (OID)
Access
Value range
Implementation
rbridgeMultiFibNickname (1.3.6.1.2.1.214.1.2.6.1.1)
not-accessible
RbridgeNickname
Nickname of the multicast distribution tree.
As per the MIB.
rbridgeMultiFibPorts (1.3.6.1.2.1.214.1.2.6.1.2)
read-only
PortList
List of ports to which a frame destined to this multicast distribution tree is flooded.
As per the MIB.
rbridgeVlanTable
About this table
Use this to obtain VLAN information of RBridges.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is rbridgeVlanIndex.
Object (OID)
Access
Value range
Implementation
rbridgeVlanIndex (1.3.6.1.2.1.214.1.3.1.1.1)
not-accessible
Unsigned32
Unsigned32 (1..4094|4096..4294967295)
ID of a VLAN.
As per the MIB.
rbridgeVlanSnooping (1.3.6.1.2.1.214.1.3.1.1.4)
read-only
INTEGER
notSupported(1),
ipv4(2),
ipv6(3),
ipv4v6(4)
IP multicast snooping on this VLAN.
As per the MIB.
rbridgeVlanPortTable
About this table
Use this table to obtain VLAN information of RBridge ports.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are rbridgeBasePort and rbridgeVlanIndex.
Object (OID)
Access
Value range
Implementation
rbridgeVlanPortInhibited (1.3.6.1.2.1.214.1.3.2.1.1)
read-only
TruthValue
true(1),
false(2)
Setting this object to true(1) means this VLAN has been inhibited by the RBridge due to conflicting forwarder information received from another RBridge.
As per the MIB.
rbridgeVlanPortForwarder (1.3.6.1.2.1.214.1.3.2.1.2)
read-only
TruthValue
true(1),
false(2)
Setting this object to true(1) means this RBridge is an appointed forwarder for this VLAN on this port.
As per the MIB.
rbridgeVlanPortAnnouncing (1.3.6.1.2.1.214.1.3.2.1.3)
read-write
TruthValue
true(1),
false(2)
Setting this object to true(1) means TRILL Hellos tagged with this VLAN can be sent by this RBridge on this port.
As per the MIB.
rbridgeSnoopingPortTable
About this table
Use this table to obtain information about ports on which the presence of IPv4 or IPv6 multicast routers has been detected for RBridges implementing IP multicast snooping.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
rbridgeSnoopingPortAddrType
(1.3.6.1.2.1.214.1.6.1.1.1)
read-only
INTEGER
ipv4(1),
ipv6(2),
ipv4v6(3)
IP address type of an IP multicast router detected on this port and VLAN.
As per the MIB.
rbridgeDtreeTable
About this table
Use this to obtain information about distribution trees being computed by this RBridge.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is rbridgeDtreeNumber.
Object (OID)
Access
Value range
Implementation
rbridgeDtreeNumber  (1.3.6.1.2.1.214.1.7.5.1.1)
not-accessible
Unsigned32
Number of trees in a distribution tree computed by this RBridge.
As per the MIB.
rbridgeDtreeNickname (1.3.6.1.2.1.214.1.7.5.1.2)
read-only
RbridgeNickname
Nickname of the distribution tree.
As per the MIB.
rbridgeDtreeIngress(1.3.6.1.2.1.214.1.7.5.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates whether this RBridge might choose this distribution tree to receive a multi-destination frame.
The value is fixed at true(1).
