- 07-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LswMAM-MIB
- 04-HH3C-LswMSTP-MIB
- 05-HH3C-LswVLAN-MIB
- 06-HH3C-MAC-INFORMATION-MIB
- 07-HH3C-QINQV2-MIB
- 08-IEEE8023-LAG-MIB
- 09-LLDP-EXT-MED-MIB
- 10-LLDP-EXT-DOT1-MIB
- 11-LLDP-EXT-DOT1-V2-MIB
- 12-LLDP-EXT-DOT3-MIB
- 13-LLDP-EXT-DOT3-V2-MIB
- 14-LLDP-MIB
- 15-LLDP-V2-MIB
- 16-MAU-MIB
- 17-P-BRIDGE-MIB
- 18-Q-BRIDGE-MIB
- 19-RBRIDGE-MIB
07-HH3C-QINQV2-MIB | 50.27 KB |
hh3cQinQv2ServiceTPID (1.3.6.1.4.1.25506.2.137.1.1.1)
HH3C-QINQV2-MIB
About this MIB
Use this MIB to manage, configure, and obtain 802.1Q in 802.1Q (QinQ) information.
MIB file name
hh3c-qinqv2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cQinQv2(137)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQinQv2ServiceTPID (1.3.6.1.4.1.25506.2.137.1.1.1) |
read-write |
Integer32 |
Integer32 (1..65535) |
SVLAN TPID |
Implementation varies by product |
hh3cQinQv2CustomerTPID (1.3.6.1.4.1.25506.2.137.1.1.2)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQinQv2CustomerTPID (1.3.6.1.4.1.25506.2.137.1.1.2) |
read-write |
Integer32 |
CVLAN TPID |
Tabular objects
hh3cQinQv2IfConfigTable
About this table
Use this table to enable QinQ, set the CVLAN TPID and SVLAN TPID, and configure VLAN transparent transmission on a port.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQinQv2IfState (1.3.6.1.4.1.25506.2.137.1.2.1.1) |
read-write |
TruthValue |
true(1), false(2) |
This variable is used to enable or disable QinQ on the port. |
Supported. Implementation varies by product |
hh3cQinQv2IfServiceTPID (1.3.6.1.4.1.25506.2.137.1.2.1.2) |
read-write |
Integer32 |
SVLAN TPID on the port. |
hh3cQinQv2IfCustomerTPID (1.3.6.1.4.1.25506.2.137.1.2.1.3) |
read-write |
Integer32 |
CVLAN TPID on the port. |
hh3cQinQv2IfTransparentVlanList (1.3.6.1.4.1.25506.2.137.1.2.1.4) |
read-write |
OCTET STRING |
OCTET STRING (512) |
List of transparent VLANs the port. |
