07-Layer 2 - LAN Switching
HomeSupportNFVH3C VSRReference GuidesMIB CompanionH3C VSR Series Virtual Service Router MIB Reference-R1362-6W10007-Layer 2 - LAN Switching
06-HH3C-MAC-INFORMATION-MIB
06-HH3C-MAC-INFORMATION-MIB 94.58 KB
About this MIB
Use this MIB to configure MAC Information.
MIB file name
hh3c-mac-information.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMACInformation(87)
Scalar objects
hh3cMACInformationEnabled (1.3.6.1.4.1.25506.2.87.1.1.1)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enabled(1)
disabled(2)
Status of the MAC Information feature.
As per the MIB.
hh3cMACInformationcSendInterval (1.3.6.1.4.1.25506.2.87.1.1.2)
Object (OID)
Access
Value range
Implementation
hh3cMACInformationcSendInterval(1.3.6.1.4.1.25506.2.87.1.1.2)
read-write
Integer32
Integer32 (1..20000)
MAC change notification interval.
As per the MIB.
hh3cMACInformationLearntMACNum (1.3.6.1.4.1.25506.2.87.1.1.3)
Object (OID)
Access
Value range
Implementation
hh3cMACInformationLearntMACNum(1.3.6.1.4.1.25506.2.87.1.1.3)
read-only
Counter32
Standard MIB values.
Total number of the MAC addresses learned since MAC information is enabled.
As per the MIB.
hh3cMACInformationRemovedMACNum (1.3.6.1.4.1.25506.2.87.1.1.4)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of the MAC addresses deleted or aged since MAC information is enabled.
As per the MIB.
hh3cMACInformationTrapSendNum (1.3.6.1.4.1.25506.2.87.1.1.5)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Number of sent SNMP notifications.
As per the MIB.
hh3cMACInformationSyslogSendNum (1.3.6.1.4.1.25506.2.87.1.1.6)
Object (OID)
Access
Value range
Implementation
read-write
Counter32
Number of sent syslog messages.
As per the MIB.
hh3cMACInformationCacheLen (1.3.6.1.4.1.25506.2.87.1.1.7)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Integer32 (0..1000)
MAC Information queue length.
As per the MIB.
hh3cMACInfomationWorkMode (1.3.6.1.4.1.25506.2.87.1.1.8)
Object (OID)
Access
Value range
Implementation
read-write
Hh3cMACInfoWorkMode
trap(1)
syslog(2)
MAC Information mode
As per the MIB.
hh3cMACInfoTrapVerExt (1.3.6.1.4.1.25506.2.87.1.4.2.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Integer32
SNMP version.
As per the MIB.
hh3cMACInfoTrapIndexExt (1.3.6.1.4.1.25506.2.87.1.4.2.2)
Object (OID)
Access
Value range
Implementation
Integer32
Integer32 (0..4294967295)
Notification index.
As per the MIB.
hh3cMACInfoTrapCountExt (1.3.6.1.4.1.25506.2.87.1.4.2.3)
Object (OID)
Access
Value range
Implementation
Integer32
Notification count.
As per the MIB.
hh3cMACInfoTrapMsgExt (1.3.6.1.4.1.25506.2.87.1.4.2.4)
Object (OID)
Access
Value range
Implementation
OCTET STRING
OCTET STRING  (0..255)
Notification contents.
As per the MIB.
Tabular objects
hh3cMACInfomationIfTable
About this table
Use this table to configure MAC Information on ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cMACLearntEnable (1.3.6.1.4.1.25506.2.87.1.2.1.1.1)
read-write
INTEGER
enabled(1)
disabled(2)
MAC learning event reporting.
As per the MIB.
hh3cMACRemovedEnable (1.3.6.1.4.1.25506.2.87.1.2.1.1.2)
read-write
INTEGER
enabled(1)
disabled(2)
MAC aging or deletion event reporting.
As per the MIB.
