- 07-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LswMAM-MIB
- 04-HH3C-LswMSTP-MIB
- 05-HH3C-LswVLAN-MIB
- 06-HH3C-MAC-INFORMATION-MIB
- 07-HH3C-QINQV2-MIB
- 08-IEEE8023-LAG-MIB
- 09-LLDP-EXT-MED-MIB
- 10-LLDP-EXT-DOT1-MIB
- 11-LLDP-EXT-DOT1-V2-MIB
- 12-LLDP-EXT-DOT3-MIB
- 13-LLDP-EXT-DOT3-V2-MIB
- 14-LLDP-MIB
- 15-LLDP-V2-MIB
- 16-MAU-MIB
- 17-P-BRIDGE-MIB
- 18-Q-BRIDGE-MIB
- 19-RBRIDGE-MIB
09-LLDP-EXT-MED-MIB | 158.68 KB |
lldpXMedLocDeviceClass (1.0.8802.1.1.2.1.5.4795.1.1.1)
lldpXMedFastStartRepeatCount (1.0.8802.1.1.2.1.5.4795.1.1.3)
lldpXMedLocHardwareRev (1.0.8802.1.1.2.1.5.4795.1.2.2)
lldpXMedLocFirmwareRev (1.0.8802.1.1.2.1.5.4795.1.2.3)
lldpXMedLocSoftwareRev (1.0.8802.1.1.2.1.5.4795.1.2.4)
lldpXMedLocSerialNum (1.0.8802.1.1.2.1.5.4795.1.2.5)
lldpXMedLocMfgName (1.0.8802.1.1.2.1.5.4795.1.2.6)
lldpXMedLocModelName (1.0.8802.1.1.2.1.5.4795.1.2.7)
lldpXMedLocAssetID (1.0.8802.1.1.2.1.5.4795.1.2.8)
lldpxMedLocXPoEDeviceType (1.0.8802.1.1.2.1.5.4795.1.2.10)
lldpXMedLocXPoEPSEPowerSource (1.0.8802.1.1.2.1.5.4795.1.2.12)
lldpXMedLocXPoEPDPowerReq (1.0.8802.1.1.2.1.5.4795.1.2.13)
lldpXMedLocXPoEPDPowerSource (1.0.8802.1.1.2.1.5.4795.1.2.14)
lldpXMedLocXPoEPDPowerPriority (1.0.8802.1.1.2.1.5.4795.1.2.15)
LLDP-EXT-MED-MIB
About this MIB
Use this MIB to obtain TIA-TR41.4 Media Endpoint Discovery (MED) information.
MIB file name
lldp-ext-med.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).lldpMIB(2).lldpObjects(1).lldpExtnesions(5).lldpXMedMIB(4795)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocDeviceClass (1.0.8802.1.1.2.1.5.4795.1.1.1) |
read-only |
LldpXMedDeviceClass |
Standard MIB values. |
MED device class. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedFastStartRepeatCount (1.0.8802.1.1.2.1.5.4795.1.1.3) |
read-write |
Unsigned32 |
Unsigned32 (1..8) |
Number of times the fast start LLDPDU are being sent. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocHardwareRev (1.0.8802.1.1.2.1.5.4795.1.2.2) |
read-only |
SnmpAdminString |
OCTET STRING (0..32) |
Local hardware revision. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocFirmwareRev (1.0.8802.1.1.2.1.5.4795.1.2.3) |
read-only |
SnmpAdminString |
Local firmware revision. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocSoftwareRev (1.0.8802.1.1.2.1.5.4795.1.2.4) |
read-only |
SnmpAdminString |
Local software revision. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocSerialNum (1.0.8802.1.1.2.1.5.4795.1.2.5) |
read-only |
SnmpAdminString |
Local serial number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocMfgName (1.0.8802.1.1.2.1.5.4795.1.2.6) |
read-only |
SnmpAdminString |
Local manufacturer name. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocModelName (1.0.8802.1.1.2.1.5.4795.1.2.7) |
read-only |
SnmpAdminString |
Local model name. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocAssetID (1.0.8802.1.1.2.1.5.4795.1.2.8) |
read-only |
SnmpAdminString |
Local asset tracking identifier. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpxMedLocXPoEDeviceType (1.0.8802.1.1.2.1.5.4795.1.2.10) |
read-only |
INTEGER |
unknown(1) pseDevice(2) pdDevice(3) none(4) |
Local PoE type. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocXPoEPSEPowerSource (1.0.8802.1.1.2.1.5.4795.1.2.12) |
read-only |
INTEGER |
unknown(1) primary(2) backup(3) |
Local PSE power supply type. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocXPoEPDPowerReq (1.0.8802.1.1.2.1.5.4795.1.2.13) |
read-only |
Gauge32 |
Power required by a PD. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocXPoEPDPowerSource (1.0.8802.1.1.2.1.5.4795.1.2.14) |
read-only |
INTEGER |
unknown(1) fromPSE(2) local(3) localAndPSE(4) |
Local PD power supply type. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocXPoEPDPowerPriority (1.0.8802.1.1.2.1.5.4795.1.2.15) |
read-only |
INTEGER |
unknown(1) critical(2) high(3) low(4) |
Local PD power priority. |
As per the MIB. |
Tabular objects
lldpXMedPortConfigEntry
About this table
Use this table to configure MED on ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is lldpPortConfigPortNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedPortCapSupported (1.0.8802.1.1.2.1.5.4795.1.1.2.1.1) |
read-only |
LldpXMedCapabilities |
Supported MED TLVs. |
As per the MIB. |
lldpXMedPortConfigTLVsTxEnable (1.0.8802.1.1.2.1.5.4795.1.1.2.1.2) |
read-write |
Enabled MED TLVs. |
By default, the networkPolicy bit is set to 0. On a port operating in bridging mode, the networkPolicy bit is set to 1. By default, the location and extendedPD bits are set to 0, and the other bits are set to 1. If the extendedPSE bit is set to 1 but a port does not support a capability, the bridge agents on the port does not send the related TLVs, and this bit is read-only. |
lldpXMedPortConfigNotifEnable (1.0.8802.1.1.2.1.5.4795.1.1.2.1.3) |
read-write |
TruthValue |
true(1) false(2) |
LLDP-MED trapping status. |
As per the MIB. |
lldpXMedLocMediaPolicyTable
About this table
Use this table to obtain local media policy configuration.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpLocPortNum and lldpXMedLocMediaPolicyAppType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocMediaPolicyAppType (1.0.8802.1.1.2.1.5.4795.1.2.1.1.1) |
not-accessible |
PolicyAppType |
Media policy type. |
As per the MIB. |
lldpXMedLocMediaPolicyVlanID (1.0.8802.1.1.2.1.5.4795.1.2.1.1.2) |
read-only |
Integer32 |
Integer32 (0|1..4094|4095) |
Media VLAN ID. |
As per the MIB. |
lldpXMedLocMediaPolicyPriority(1.0.8802.1.1.2.1.5.4795.1.2.1.1.3) |
read-only |
Integer32 |
Integer32 (0..7) |
Media policy priority. |
As per the MIB. |
lldpXMedLocMediaPolicyDscp (1.0.8802.1.1.2.1.5.4795.1.2.1.1.4) |
read-only |
Dscp |
DSCP value. |
As per the MIB. |
lldpXMedLocMediaPolicyUnknown (1.0.8802.1.1.2.1.5.4795.1.2.1.1.5) |
read-only |
TruthValue |
true(1) false(2) |
Whether the media policy type is unknown. |
As per the MIB. |
lldpXMedLocMediaPolicyTagged (1.0.8802.1.1.2.1.5.4795.1.2.1.1.6) |
read-only |
TruthValue |
true(1) false(2) |
Whether packets of the media VLAN are tagged. |
As per the MIB. |
lldpXMedLocLocationTable
About this table
Use this table to configure the local location information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are lldpLocPortNum and lldpXMedLocLocationSubtype.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocLocationSubtype (1.0.8802.1.1.2.1.5.4795.1.2.9.1.1) |
not-accessible |
LocationSubtype |
Local MED location type. |
Supports only civicAddress(3) and elin(4). |
lldpXMedLocLocationInfo (1.0.8802.1.1.2.1.5.4795.1.2.9.1.2) |
read-write |
OCTET STRING |
OCTET STRING (0..256) |
Local MED location information. |
As per the MIB. |
lldpXMedLocXPoEPSEPortTable
About this table
Use this table to obtain PSE information on ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is lldpLocPortNUm.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocXPoEPSEPortPowerAv (1.0.8802.1.1.2.1.5.4795.1.2.11.1.1) |
read-only |
Gauge32 |
Available PoE power on PSE ports. |
As per the MIB. |
lldpXMedLocXPoEPSEPortPDPriority (1.0.8802.1.1.2.1.5.4795.1.2.11.1.2) |
read-only |
INTEGER |
Unknown(1) Critical(2) High(3) Low(4) |
PSE port power priority. |
As per the MIB. |
lldpXMedRemCapabilitiesTable
About this table
Use this table to obtain the LLDP-MED capabilities of a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, and lldpRemIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemCapSupported (1.0.8802.1.1.2.1.5.4795.1.3.1.1.1) |
read-only |
As per the MIB. |
lldpXMedRemCapCurrent (1.0.8802.1.1.2.1.5.4795.1.3.1.1.2) |
read-only |
Sent MED TLVs. |
As per the MIB. |
lldpXMedRemDeviceClass (1.0.8802.1.1.2.1.5.4795.1.3.1.1.3) |
read-only |
MED device type. |
As per the MIB. |
lldpXMedRemMediaPolicyTable
About this table
Use this table to obtain the media policy configuration of a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, and lldpXMedRemMediaPolicyAppType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemMediaPolicyAppType (1.0.8802.1.1.2.1.5.4795.1.3.2.1.1) |
not-accessible |
PolicyAppType |
As per the MIB. |
lldpXMedRemMediaPolicyVlanID (1.0.8802.1.1.2.1.5.4795.1.3.2.1.2) |
read-only |
Integer32 |
Media VLAN ID. |
As per the MIB. |
lldpXMedRemMediaPolicyPriority (1.0.8802.1.1.2.1.5.4795.1.3.2.1.3) |
read-only |
Integer32 |
Integer32 (0..7) |
As per the MIB. |
lldpXMedRemMediaPolicyDscp (1.0.8802.1.1.2.1.5.4795.1.3.2.1.4) |
read-only |
Dscp |
DSCP value. |
As per the MIB. |
lldpXMedRemMediaPolicyUnknown (1.0.8802.1.1.2.1.5.4795.1.3.2.1.5) |
read-only |
TruthValue |
true(1) false(2) |
As per the MIB. |
lldpXMedRemMediaPolicyTagged (1.0.8802.1.1.2.1.5.4795.1.3.2.1.6) |
read-only |
TruthValue |
true(1) false(2) |
As per the MIB. |
lldpXMedRemInventoryTable
About this table
Use this table to obtain the inventory information about a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemHardwareRev (1.0.8802.1.1.2.1.5.4795.1.3.3.1.1) |
read-only |
SnmpAdminString |
Hardware revision. |
As per the MIB. |
lldpXMedRemFirmwareRev (1.0.8802.1.1.2.1.5.4795.1.3.3.1.2) |
read-only |
SnmpAdminString |
Firmware revision. |
As per the MIB. |
lldpXMedRemSoftwareRev (1.0.8802.1.1.2.1.5.4795.1.3.3.1.3) |
read-only |
SnmpAdminString |
Software revision. |
As per the MIB. |
lldpXMedRemSerialNum (1.0.8802.1.1.2.1.5.4795.1.3.3.1.4) |
read-only |
SnmpAdminString |
Serial number. |
As per the MIB. |
lldpXMedRemMfgName (1.0.8802.1.1.2.1.5.4795.1.3.3.1.5) |
read-only |
SnmpAdminString |
Manufacturer name. |
As per the MIB. |
lldpXMedRemModelName (1.0.8802.1.1.2.1.5.4795.1.3.3.1.6) |
read-only |
SnmpAdminString |
Model name. |
As per the MIB. |
lldpXMedRemAssetID (1.0.8802.1.1.2.1.5.4795.1.3.3.1.7) |
read-only |
SnmpAdminString |
Asset tracking identifier. |
As per the MIB. |
lldpXMedRemLocationTable
About this table
Use this table to obtain the location information about a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex ,and lldpXMedRemLocationSubtype.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemLocationSubtype(1.0.8802.1.1.2.1.5.4795.1.3.4.1.1) |
not-accessible |
LocationSubtype |
As per the MIB. |
lldpXMedRemLocationInfo (1.0.8802.1.1.2.1.5.4795.1.3.4.1.2) |
read-only |
OCTET STRING |
As per the MIB. |
lldpXMedRemXPoETable
About this table
Use this table to obtain the PoE type of a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemXPoEDeviceType (1.0.8802.1.1.2.1.5.4795.1.3.5.1.1) |
read-only |
INTEGER |
PoE type. |
As per the MIB. |
lldpXMedRemXPoEPSETable
About this table
Use this table to obtain the PSE information about a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemXPoEPSEPowerAv (1.0.8802.1.1.2.1.5.4795.1.3.6.1.1) |
read-only |
Gauge32 |
As per the MIB. |
lldpXMedRemXPoEPSEPowerSource (1.0.8802.1.1.2.1.5.4795.1.3.6.1.2) |
read-only |
INTEGER |
As per the MIB. |
lldpXMedRemXPoEPSEPowerPriority (1.0.8802.1.1.2.1.5.4795.1.3.6.1.3) |
read-only |
INTEGER |
As per the MIB. |
lldpXMedRemXPoEPDTable
About this table
Use this table to obtain the PD information about a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemXPoEPDPowerReq (1.0.8802.1.1.2.1.5.4795.1.3.7.1.1) |
read-only |
Gauge32 |
As per the MIB. |
lldpXMedRemXPoEPDPowerSource (1.0.8802.1.1.2.1.5.4795.1.3.7.1.2) |
read-only |
INTEGER |
As per the MIB. |
lldpXMedRemXPoEPDPowerPriority (1.0.8802.1.1.2.1.5.4795.1.3.7.1.3) |
read-only |
INTEGER |
As per the MIB. |
