15-BRAS Services Configuration Guide
HomeSupportRoutersCR16000-M1A SeriesCR16000-M1A SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C CR16000-M1A Router Configuration Guides-R8630Pxx-6W10215-BRAS Services Configuration Guide
10-IPoE configuration
10-IPoE configuration 4.51 MB
Configuring IPoE·· 1
About IPoE· 1
IPoE access modes· 1
IPoE user types· 2
IPoE session· 3
IPoE addressing· 4
IPoE access procedure by using bind authentication· 5
IPoE access procedure by using Web authentication· 11
IPoE quick Web authentication· 12
IPoE 802.1X authentication user access procedure‌· 15
HTTP extension header authentication user access procedure· 16
Support for MPLS L3VPN· 18
Support for EAP authentication· 18
Restrictions and guidelines: IPoE configuration· 19
IPoE tasks at a glance· 20
IPoE bind authentication user tasks at a glance· 20
IPoE Web authentication individual user tasks at a glance· 21
IPoE 802.1X authentication access user tasks at a glance‌· 22
Prerequisites for IPoE· 22
Configuring the remote portal authentication server 22
Specifying the HTTPS redirect listening port number 23
Obtaining user access information from ARP or ND entries· 23
Enabling IPoE and setting the IPoE access mode· 23
Configuring the authentication method· 23
Configuring dynamic individual users· 26
Dynamic individual user tasks at a glance· 26
Configuring a dynamic individual session initiation method· 27
Configuring authentication user naming conventions for dynamic individual users· 28
Configuring passwords for dynamic individual users· 30
Configuring ISP domains for dynamic individual users· 31
Setting the dynamic individual session limit 33
Configuring trusted DHCP options for DHCP users· 34
Configuring the parsing format for the circuit ID and remote ID in the DHCP option· 35
Configuring trusted ISP domains for DHCP users· 35
Configuring domain name generation rules for dynamic IPoE DHCP users· 36
Allowing abnormally logged out IPoE users to come online again through packet initiation· 37
Allowing DHCP users to access in loose mode· 39
Configuring automatic IPoE user backup‌· 41
Allowing users to come online through ND RS only after they come online through IA_PD‌·· 43
Enabling immediate sending of accounting-update messages when the user IPv6 address changes· 44
Configuring static users· 45
Static user tasks at a glance· 45
Configuring a static session initiation method· 45
Configuring static individual sessions· 46
Configuring static leased sessions· 49
Configuring authentication user naming conventions for static users· 51
Configuring passwords for static users· 52
Configuring ISP domains for static users· 53
Configuring session conflict detection· 53
Configuring leased users· 54
Leased user tasks at a glance· 54
Configuring an interface-leased user 54
Configuring subnet-leased users· 55
Configuring family-leased users· 56
Configuring an L2VPN-leased user 57
Configuring ISP domains for leased users· 58
Configuring Web authentication advanced features· 58
Web authentication advanced feature tasks at a glance· 58
Configuring an ISP domain for Web authentication individual users· 59
Configuring HTTP packet fast reply· 61
Configuring an SSL server policy for HTTPS redirection· 62
Configuring URL redirection· 62
Configuring captive-bypass Web authentication and captive-bypass Web authentication optimization  63
Configuring Web authentication fail-permit 65
Configuring the URL allowlist for Web authentication· 66
Configuring IPoE web support for HTTP/HTTPS attack defense‌· 67
Configuring IPoE quick Web authentication· 68
Restrictions and guidelines· 68
Configuring transparent MAC-trigger authentication· 68
Configuring transparent MAC authentication· 69
Configuring the advanced 802.1X authentication features‌· 69
Configuring the static 802.1X user authentication feature· 69
Configuring the device to retrigger 802.1X authentication based on the specified type of packets sent by a user 70
Configuring the suppression interval for retriggering 802.1X authentication based on ARP and ND packets  72
Forcibly logging out an 802.1X client 72
Forcibly logging out an IPoE user when the 802.1X client goes offline· 73
Enabling unclassified-IP packet attack defense· 73
Rate-limiting DHCP packets· 75
Setting the maximum number of individual sessions and leased subuser sessions on an interface· 75
Configuring service-specific ISP domains· 76
Configuring the quiet feature for users· 77
Configuring online detection for IPoE users· 77
Configuring NAS-Port-ID formats· 79
Configuring NAS-Port-ID binding for IPoE access users· 80
Enabling IPoE access-out authentication· 81
Enabling roaming for IPoE individual users· 82
Enabling roaming for IPoE users· 82
Enabling recording IPoE user roaming behaviors on the device· 84
Forcing an existing online user with the same MAC address as a new online user to go offline if they are in different roaming groups· 85
Enabling roaming for a new online user with the same IP and MAC addresses as an existing online user in a different roaming group· 86
Configuring the IPoE user access response delay policy· 87
Configuring the IPoE user access response delay time· 87
Configuring the MAC address offset value for IPoE user access response delay· 89
Configuring IPoE user access management 90
Configuring trusted IP addresses for IPoE authentication· 90
Forbidding IPoE users from coming online· 91
Configuring re-authentication for IPoE users‌· 92
Configuring the IP address type on which the main service of IPoE users depends· 93
Configuring the device to trust the IP addresses authorized by the AAA server‌ 94
Configuring features by using the old-style IPoE commands‌· 95
Configuring DHCPv4 packet initiation· 95
Configuring the IPoE access interface type· 96
Display and maintenance commands for IPoE· 97
IPoE configuration examples(on unified network) 101
Example: Configuring unclassified-IP packet initiation· 101
Example: Configuring reauthentication for unclassified-IP users· 103
Example: Configuring DHCPv4 packet initiation (assigning a remote BAS IP address pool) 106
Example: Configuring DHCPv4 packet initiation (assigning an IP address pool group) 108
Example: Configuring DHCPv6 packet initiation (assigning a remote IPv6 address pool) 111
Example: Configuring IPv6 ND RS packet initiation (AAA-authorized prefix) 113
Example: Configuring IPv6 ND RS packet initiation (ND prefix pool-authorized prefix) 115
Example: Configuring IPv6 ND RS+DHCPv6 (IA_PD) initiation· 117
Example: Configuring ARP packet initiation· 121
Example: Configuring NS/NA packet initiation· 122
Example: Configuring unclassified-IP packet initiation for static IPoE users with IPv6 PD prefixes· 124
Example: Configuring subnet-leased users· 127
Example: Configuring an interface-leased user 128
Example: Configuring an L2VPN-leased user 130
Example: Configuring IPoE static leased users· 133
Example: Configuring a VPN DHCP user 137
Example: Configuring IPoE common Web authentication for static individual users· 140
Example: Configuring IPoE common Web authentication for DHCPv4 users (assigning a remote BAS IP address pool) 151
Example: Configuring IPoE common Web authentication for multi-network-segment DHCPv4 users (assigning a remote BAS IP address pool) 163
Example: Configuring IPoE common Web authentication for DHCPv6 users (assigning a remote IPv6 address pool) 171
Example: Configuring IPoE common Web authentication for IPoE ND RS users (ND prefix pool-authorized prefix) 184
Example: Configuring IPoE transparent MAC-trigger authentication (Layer 2 transparent) 190
Example: Configuring IPoE common transparent MAC authentication (Layer 2 transparent) 203
Example: Configuring IPoE HTTP extension header authentication (Layer 2 transparent) 212
Example: Configuring IPoE transparent MAC-trigger authentication (Layer 3 transparent) 218
Example: Configuring IPoE transparent MAC authentication (Layer 3 transparent) 231
Example: Configuring IPoE Web authentication with EAP· 240
Example: Configuring IPoE 802.1X authentication· 249
Example: Configuring IPoE common Web authentication for dual-stack IPoE users (URL allowlist) 254
Example: Configuring IPoE common Web authentication and intelligent multi-egress for dual-stack IPoE users  273
Example: Configuring IPoE common transparent MAC authentication for dual-stack IPoE users· 290
Example: Configuring a dual-stack DHCP user 303
Example: Configuring a dynamic/static dual-stack IPoE user 306
Example: Configuring an IPoE DHCPv4+IPv6 ND RS dual-stack roaming user 309
Configuring portal authentication· 312
Restrictions and guidelines: Portal configuration· 312
Portal authentication tasks at a glance· 312
Configuring a remote portal authentication server 313
Configuring local portal service features· 314
About the local portal service· 314
Restrictions and guidelines for configuring local portal service features· 314
Customizing authentication pages· 314
Configuring a local portal Web service· 316
Configuring portal detection features· 317
Configuring portal authentication server detection· 317
Configuring portal user synchronization· 318
Configuring portal packet attributes· 319
Configuring the BAS-IP or BAS-IPv6 attribute· 319
Excluding an attribute from portal protocol packets· 320
Configuring MAC-based quick portal authentication· 320
Restrictions and guidelines for configuring MAC-based quick portal authentication· 320
Configuring a MAC binding server 320
Specifying a MAC binding server on an interface· 322
Obtaining user access information from ARP or ND entries· 322
Display and maintenance commands for portal 322
Configuring IPoE
About IPoE
IP over Ethernet (IPoE) enables a broadband remote access server (BRAS) to connect and authenticate users over IPoE connections.
IPoE supports the following authentication methods:
·     Bind authentication—The BRAS automatically generates usernames and passwords for users based on the user access location. Users are not required to enter usernames and passwords.
·     Web authentication—The BRAS requires users to enter usernames and passwords on the Web authentication page.
·     802.1X authentication—The BRAS requires users to enter usernames and passwords on an 802.1X client. To access a Layer 3 interface through 802.1X, configure the 802.1X authentication method.
As shown in Figure 1, a BRAS connects hosts over IPoE connections, and provides AAA, security, DHCP, and portal services for the hosts. The host can be a browser running HTTP or HTTPS or a cellphone running the H3C iNode client.
Figure 1 IPoE network diagram
IPoE access modes
IPoE supports Layer 2 and Layer 3 access modes.
·     Layer 2 access mode—Hosts directly access the BRAS. The hosts connect to the BRAS directly or through Layer 2 devices. The BRAS uses MAC addresses to identify the hosts.
·     Layer 3 access mode—Hosts use routing to access the BRAS. The hosts connect to the BRAS directly or through Layer 3 devices. On a Layer 3 device between the hosts and BRAS, the source MAC address of packets received by the BRAS is the MAC address of the Layer 3 device. Therefore, the BRAS uses IP addresses or VLAN IDs to identify hosts.
IPoE user types
IPoE sessions can be initiated by IP, ARP, NS, NA, ND RS, or DHCP packets. Depending on whether an IPoE user has independent service attributes, IPoE users include individual users and leased users.
Individual users
Individual users use independent IPoE services. The BRAS authenticates, authorizes, and accounts individual users based on user location and packet information. Individual users include dynamic and static individual users.
·     Dynamic individual users
IPoE defines the following dynamic individual users:
¡     DHCP user—Sends DHCP packets to initiate IPoE sessions and obtains an IP address from the DHCP server.
¡     IPv6 ND RS user—Sends IPv6 ND RS packets to initiate IPoE sessions and obtains an IP address from the BRAS.
¡     Unclassified-IP userSends packets other than DHCP and IPv6 ND RS packets to initiate IPoE sessions.
·     Static individual users
Static individual users initiate IPoE sessions by sending IP, ARP, NS, or NA packets. If an IP packet matches a manually configured IPoE session, the BRAS authenticates the user and establishes an IPoE session.
A DHCP or IPv6 ND RS user is abnormally logged out if the IPoE session of the user is deleted for a reason except the user actively releases its IP address. With the function of allowing abnormally logged out IPoE users to come online again enabled, when the device receives IP, ARP, or NS/NA packets from the user, the device can restore the IPoE session for the user. The restored IPoE session is a DHCP or IPv6 ND RS session. For more information about re-logging in abnormally logged out IPoE users, see "Allowing abnormally logged out IPoE users to come online again through packet initiation."
Leased users
Leased users include the following types:
·     Interface-leased user—Represents hosts that rent the same interface.
·     Subnet-leased user—Represents hosts that rent a subnet of an interface.
·     Family-leased users—Represents all users accessing the same interface and VLAN. Similar to interface-leased users, all users accessing this interface undergo unified authentication, authorization, and accounting.
·     L2VPN-leased user—Represents hosts that rent the same interface on an L2VPN network.
·     Static leased user—A static leased user is a special type of leased line in the following aspects:
¡     Independent service attributes—Similar to an interface-leased line, unified authentication, authorization, and accounting are performed for all users on an interface. When a static leased session comes online, packets with any source IP address can pass through the leased interface.
¡     Packet initiation—Similar to a global static individual session, with IPoE enabled on an access interface in up state, when IP, ARP, NS, or NA packets pass through the access device, the access interface will try to initiate authentication by using the configured username and password. If a user passes authentication, a static leased session is established. If a user fails to pass authentication, no static leased session is established.
Because static leased sessions are special, leased users include only interface-leased users, L2VPN-leased users, subnet-leased users, and family-leased users and do not include static leased users unless otherwise specified.
IPoE session
An IPoE session represents all network connections of one IPoE client or a group of IPoE clients. An IPoE session can be identified by the IP packet characteristics or access location of clients. An IPoE session records the identification information, authentication status, authorization attributes, and DHCP address assignment information of IPoE clients.
Depending on the IPoE user types, IPoE sessions include individual sessions and leased sessions. .
Individual sessions
Depending on how a session is initiated, IPoE individual sessions include IPoE dynamic individual sessions and IPoE static individual sessions.
·     IPoE dynamic individual session
IPoE sessions established for dynamic individual users are IPoE dynamic individual sessions.
The BRAS deletes a dynamic individual session in one of the following cases:
¡     The AAA-authorized session duration expires.
¡     The AAA server logs out the user.
¡     The user traffic is less than the AAA-authorized traffic during the idle-timeout time.
¡     The BRAS cannot detect the user after the number of detection attempts reaches the maximum.
-     For a single-stack user, the session is deleted when the number of detection attempts reaches the maximum.
-     For a dual-stack user, the session is deleted when the number of detection attempts reaches the maximum for both stacks.
¡     The IP address lease expires for IPoE sessions initiated by DHCP packets.
-     For a single-stack user, the session is deleted when the IP address lease expires.
-     For a dual-stack user, the session is deleted when the IP address leases of both stacks expire.
¡     The access interface goes down.
·     IPoE static individual session
An IPoE static individual session represents all network connections of an IPoE client with the specified IP address (IPv6 or dual-stack global static sessions can contain IPv6 delegation prefixes). Typically, IPoE static individual sessions provide stable access services for clients with known IP addresses.
On an IPoE-enabled interface in up state, the BRAS initiates authentication based on the configured username and password upon receiving IP, ARP, NS, or NA packets from users. The BRAS creates a static individual session only when the authentication succeeds.
IPoE leased sessions
IPoE leased sessions are IPoE sessions established for IPoE leased users. IPoE leased sessions include the following types:
·     Interface-leased session—Represents network connections of all IPoE clients on an interface.
·     Subnet-leased session—Represents network connections of all IPoE clients in a subnet of an interface.
·     Family-leased session—Represents network connections of all IPoE clients within the same VLAN on an interface.
·     L2VPN-leased session—Represents network connections of all IPoE client on an interface.
·     Static leased session—Represents network connections of all IPoE clients on an interface.
For leased users, the BRAS initiates user authentication based on the configured username and password after you enable IPoE on an interface in up state. Authentication does not need to be initiated by user traffic. If the authentication succeeds, a leased session is established. If the authentication fails, no leased session is established.
A static leased session is a special type of leased line in the following aspects:
·     Independent service attributes—Similar to an interface-leased line, unified authentication, authorization, and accounting are performed for all users on an interface. When a static leased session comes online, packets with any source IP address can pass through the leased interface.
·     Packet initiation—Similar to a global static individual session, with IPoE enabled on an access interface in up state, when IP, ARP, NS, or NA packets pass through the access device, the access interface will try to initiate authentication by using the configured username and password. If a user passes authentication, a static leased session is established. If a user fails to pass authentication, no static leased session is established.
IPoE addressing
IPoE addressing varies with user types.
A DHCP user obtains IP addresses in the following sequence:
1.     Obtains an IP address from the AAA-authorized IP address pool.
2.     Obtains an IP address from the IP address pool configured in the ISP domain if the AAA server does not authorize any IP address pools.
3.     Obtains an IP address in the same network segment as the interface IP address if no IP address pool is configured in the ISP domain.
On an IPv6 network, a host can get an IPv6 global unicast address through the following methods:
·     NDRA—The host obtains an IPv6 prefix in an RA message if the host sends RS packets to initiate authentication and successfully passes authentication. The host then generates an IPv6 global unicast address based on the IPv6 prefix. IPv6 prefixes include the following types in descending order of priority: AAA-authorized IPv6 prefix, prefix in the AAA-authorized ND prefix pool, RA prefix configured on an interface, and IPv6 global unicast address prefix configured on an interface. Among these prefixes:
¡     The following three prefix methods apply to the prefix sharing scenario: AAA-authorized IPv6 prefix, RA prefix configured on an interface, and IPv6 global unicast address prefix configured on an interface. In this scenario, multiple users share one IPv6 prefix.
¡     The AAA-authorized ND prefix pool (or ND prefix pool group) applies to the scenario of one prefix per user. In this scenario, each user has an exclusive IPv6 prefix.
¡     The assigned IPv6 prefix length for users must be 64 bits.
·     DHCPv6 (IA_NA)—The host requests an IPv6 global unicast address through DHCPv6. After an IPv6 address pool is authorized to users, IA_NA also supports authorizing the specified 128-bit IPv6 global unicast addresses to DHCP users through the following methods:
¡     Authorizing 128-bit IPv6 global unicast addresses by an AAA server through the Framed-IPv6-Address attribute.
¡     Authorizing 128-bit IPv6 global unicast addresses by using the authorization-attribute ipv6 command in local user view.
Make sure the 128-bit IPv6 global unicast addresses authorized by using the two methods above are within the authorized IPv6 address pool. Otherwise, the 128-bit IPv6 global unicast addresses authorized by using the two methods above are not used, and IPv6 addresses in the IPv6 address pool are randomly allocated to users.
·     DHCPv6 (IA_PD)—A CPE requests prefixes through DHCPv6 and assigns them to downstream hosts. The hosts then use the prefixes to generate IPv6 global unicast addresses. This method uses the same principle of selecting address pools as the DHCPv6 (IA_NA) method.
You can configure the combination of NDRA+IA_PD or IA_NA+IA_PD methods as needed to meet the address allocation requirements in different scenarios.
If an ND prefix pool is used to allocate prefixes to users (in the one prefix per user scenario), the following restrictions apply to these users:
·     These users cannot be leased users, including interface-leased users, subnet-leased users, and L2VPN-leased users.
·     The ICMPv6 detection method is not supported.
·     Prefixes of these users cannot be configured for static IPoE users.
·     On an access interface of these users, you cannot configure an IPv6 global unicast address.
In DHCPv6 (IA_PD) method, you cannot configure an IPv6 global unicast address on the access interface of a user.
Other users use static IP addresses or obtain IP addresses from the DHCP server without using IPoE.
IPoE access by using bind authentication includes the following steps:
1.     The BRAS initiates authentication.
The BRAS obtains information from user packets or IPoE sessions statically configured, and sends authentication requests.
2.     The AAA server authenticates users.
The AAA server completes user authentication and sends the result to the BRAS. The security server, if configured, completes security authorization and sends the result to the BRAS.
3.     (Optional.) DHCP allocates IP addresses and IPoE allocates IPv6 prefixes.
The DHCP server assigns an IP address to a DHCP user and the IPoE assigns an IPv6 prefix to an IPv6 ND RS user.
4.     The BRAS performs access control.
The BRAS permits the user to get online and performs access control and accounting based on the authorized result.
Access procedure for DHCP single-stack users
This section uses a DHCPv4 user as an example to illustrate the access procedure for DHCP single-stack users. The BRAS acts as a DHCP relay agent.
Figure 2 Access procedure for a DHCPv4 user
1.     The DHCP client sends a DHCP-DISCOVER message to the BRAS.
2.     The BRAS inserts Option 82 in the DHCP-DISCOVER message, and creates an IPoE session.
3.     The BRAS sends the AAA server an access request that includes user information, such as the client ID and source MAC address.
4.     The AAA server returns an Access-Accept packet that contains authorization information to the BRAS if the authentication succeeds. If the authentication fails, the AAA server returns an Access-Reject message.
5.     The BRAS marks the IPoE session state as success and forwards the DHCP-DISCOVER message to the DHCP server if the authentication succeeds. If the authentication fails, the BRAS marks the session as failure and drops the DHCP-DISCOVER message.
6.     The DHCP server sends a DHCP-OFFER message to the BRAS.
7.     The BRAS forwards the DHCP-OFFER message to the DHCP client.
8.     The DHCP client sends a DHCP-REQUEST message to the BRAS.
9.     The BRAS forwards the DHCP-REQUEST message to the specified DHCP sever.
10.     The DHCP server sends a DHCP-ACK message containing the assigned IP address to the BRAS.
11.     The BRAS performs the following operations:
a.     Obtains address information from the DHCP-ACK message.
b.     Assigns a user profile.
c.     Updates the IPoE session information.
d.     Forwards the DHCP-ACK message to the client.
e.     Marks the session state as online.
12.     The DHCP client obtains configuration information from the DHCP-ACK message.
13.     The BRAS sends the AAA server a message to start accounting.
Access procedure for DHCP dual-stack users
This section illustrates the access procedure for DHCP dual-stack users. The BRAS acts as a DHCP relay agent. DHCPv6 packet initiation include IA_NA and IA_PD methods. IA_NA assigns global unicast IPv6 addresses to hosts through DHCPv6. IA_PD assigns PD prefixes to clients through DHCPv6.
Figure 3 Access procedure for a DHCP dual-stack user
1.     The DHCPv4 client sends a DHCP-DISCOVER message.
2.     The DHCPv4 relay agent inserts Option 82 in the DHCP-DISCOVER message, and creates an IPoE session.
3.     The relay agent sends the AAA server an access request including user information, such as the client ID and source MAC address in DHCPv4 packets.
4.     The AAA server returns an Access-Accept packet that contains authorization information to the DHCPv4 relay agent if the authentication succeeds. If the authentication fails, the AAA server returns an Access-Reject message.
5.     The DHCPv4 relay agent obtains the user authentication and authorization result, and updates the session status to success or failure.
6.     The DHCPv4 relay agent forwards the DHCP-DISCOVER message to the DHCP server if the authentication succeeds. If the authentication fails, the DHCPv4 relay agent drops the DHCP-DISCOVER message.
7.     The DHCPv4 server sends a DHCP-OFFER message to the DHCPv4 relay agent. The DHCPv4 relay agent forwards the DHCP-OFFER message to the DHCP client.
8.     The DHCPv4 client sends a DHCP-REQUEST message to the DHCPv4 relay agent. The DHCPv4 relay agent forwards the DHCP-REQUEST message to the specified DHCP sever.
9.     The DHCP server sends a DHCP-ACK message containing the assigned IP address to the DHCPv4 relay agent.
10.     The DHCPv4 relay agent performs the following operations:
d.     Marks the session state as online.
11.     The DHCPv4 relay agent forwards the DHCP-ACK message to the client. The DHCP client obtains configuration information from the DHCP-ACK message.
12.     The DHCPv4 relay agent sends the AAA server a message to start accounting.
13.     The DHCPv6 client sends a Solicit message. The DHCPv6 relay agent updates IPoE session information based on the Solicit message. The IA_NA field in packets corresponds to the obtained global unicast IPv6 address. The IA_PD field in packets corresponds to the obtained IPv6 address prefix.
14.     The DHCPv6 server responds with an Advertise message. Then, the DHCPv6 relay agent forwards the Advertise message to the DHCPv6 client.
15.     The DHCPv6 client select a DHCPv6 server according to the Advertise message and sends a request. The DHCPv6 relay agent forwards the request to the DHCPv6 server.
16.     The DHCPv6 server responds with a reply message.
17.     The DHCPv6 relay agent parses the IPv6 address, IPv6 address prefix, and other address parameters in the reply message, and updates the IPoE session.
18.     The DHCPv6 relay agent forwards the reply message to the DHCPv6 client. The DHCPv6 client obtains the IPv6 address and related address parameters.
Access procedure for IPv6 ND RS users
This example uses a Layer 2 device as the BRAS.
Figure 4 Access procedure for IPv6 ND RS users
1.     The host sends an IPv6 ND RS packet to the BRAS.
2.     The BRAS initiates an IPoE session and sends the AAA server an access request that contains user information, such as the source MAC address.
3.     The AAA server returns an Access-Accept packet that contains authorization information to the BRAS if the authentication succeeds. If the authentication fails, the AAA server returns an Access-Reject message.
4.     The BRAS performs the following operations:
a.     Generates an IPv6 address based on the host's MAC address and the IPv6 prefix.
b.     Updates the IPoE session information.
c.     Marks the session as success.
If the authentication fails, the BRAS marks the session as failure and drops the IPv6 ND RS packet.
5.     The BRAS assigns a user profile and sends the host an IPv6 ND RA packet containing the IPv6 prefix.
6.     The host generates an IPv6 address based on the received IPv6 prefix.
7.     The BRAS sends the AAA server a message to start the service accounting.
Access procedure for unclassified-IP users
Figure 5 Access procedure for unclassified-IP users
1.     The host sends an IP packet to the BRAS.
2.     The BRAS obtains user information from the IP packet, and compares the user information with existing IPoE sessions.
¡     If no match is found, the BRAS initiates an IPoE session for the user. (This section uses this case as an example.)
¡     If the information matches an authenticated session, the BRAS forwards the IP packet.
¡     If the information matches an unauthenticated session, the BRAS drops the IP packet.
3.     The BRAS sends the AAA server an access request containing the obtained information, such as the source IP address or source MAC address.
4.     The AAA server returns an Access-Accept packet that contains authorization information if the authentication succeeds. If the authentication fails, the AAA server returns an Access-Reject message.
5.     The BRAS assigns a user profile and marks the IPoE session state as online.
6.     The BRAS sends the AAA server a message to start the service accounting.
Access procedure for static and leased users
The access procedure for static users is the same as that for unclassified-IP users except in the following aspects:
·     The IPoE static session is configured at the CLI.
·     The IPoE static session can be initiated by IP, ARP, NS, or NA packets.
If you specify a global static user with an IPv6 delegation prefix, after the user comes online, the traffic matching the IPv6 delegation prefix network segment can also be directly forwarded.
The access procedure for leased users is the same as that for unclassified-IP users except in the following aspects:
·     The IPoE leased session is configured at the CLI.
·     The IPoE leased session does not need to be initiated by packets. Users are not required to send IP packets to trigger authentication. The BRAS initiates user authentication based on the configured username and password.
IPoE Web authentication applies to unclassified-IP users, DHCP users, IPv6 ND RS users, and static individual users. The authentication process includes two phases: preauthentication and Web authentication (also known as postauthentication).
Preauthentication access procedure
The access procedure in the preauthentication phase is the same as the access procedure by using bind authentication for users. For more information about the access procedure, see "Access procedure for DHCP single-stack users," "Access procedure for IPv6 ND RS users," and "Access procedure for static and leased users."
Web authentication access procedure
In the Web authentication phase, the authentication procedure is basically the same for users. This section uses a DHCPv4 user as an example to illustrate the access procedure by using Web authentication. The BRAS acts as a DHCP relay agent.
Figure 6 Web authentication access procedure
The user can perform Web authentication through the Web browser or the iNode client. This section uses the Web browser as an example.
1.     The DHCP client initiates an HTTP/HTTPS GET message.
2.     The BRAS checks the destination IP address of the HTTP/HTTPS GET message.
¡     If the message is destined for the portal Web server, the BRAS forwards the message to the portal Web server. The DHCP client directly accesses the Web authentication page of the portal Web server. .
¡     If the message is not destined for the portal Web server, the BRAS sends the message containing the Web server URL information to the DHCP client.
3.     The DHCP client automatically accesses the redirected URL based on configured Web server URL information.
4.     The portal Web server sends the Web authentication page to the DHCP client.
5.     The user enters a username and password on the Web authentication page.
6.     The portal server forwards the Web authentication information to the BRAS.
7.     The BRAS sends the AAA server an access request based on the Web authentication information.
8.     The AAA server returns to the BRAS one of the following results:
¡     An Access-Accept packet that contains authorization information if the authentication succeeds.
¡     An Access-Reject message if the authentication fails.
9.     The BRAS performs one of the following operations based on the received result:
¡     Updates the IPoE session state as failed upon receiving an Access-Reject message.
¡     Updates the IPoE session state as authorized upon receiving an Access-Accept packet.
10.     If the authentication succeeds, the BRAS sends the AAA server a message to start accounting.
When the user performs Web authentication through the iNode client, the user can directly open the client authentication page and enter the authentication information. The remaining steps 6 through 10 are the same.
In an IPoE Web environment, IPoE Web authentication supports quick authentication. With quick authentication, users that access the network frequently do not need to enter authentication information each time they come online in the Web authentication phase.
For valid users that access the network frequently, you can implement MAC-based quick authentication. It allows users to pass authentication without entering authentication information. MAC-based quick authentication is also called transparent authentication. Based on the location where the usernames, passwords, and MAC-to-account bindings of users are stored, transparent authentication includes the following types:
·     Transparent MAC-trigger authentication—To use transparent MAC-trigger authentication, you must deploy a MAC binding server in the network. The MAC binding server records the MAC-to-account bindings of users for authentication.
·     Transparent MAC authentication—To use transparent MAC authentication, you must deploy an AAA server that can bind the Web authentication information of users to MAC addresses of user endpoints for authentication.
Depending on the IP address allocation methods, transparent MAC authentication includes the following types:
¡     Common transparent MAC authentication—Only one IP address allocation is performed in the whole authentication and coming online process. A user triggers transparent MAC authentication in the Web authentication phase. After the user passes transparent MAC authentication, the user comes online in the Web authentication phase.
¡     Re-DHCP transparent MAC authentication—Two IP address allocations are performed in the whole authentication and coming online process. A user triggers transparent MAC authentication in the preauthentication phase. After the user passes transparent MAC authentication, the user comes online in the preauthentication phase.
When transparent MAC-trigger authentication or common transparent MAC authentication is configured, IPoE queries the MAC bindings for a user when receiving any IP packets of the user in the preauthentication domain. For a user that uses Web access for the first time, the authentication procedure includes the querying process.
When re-DHCP transparent MAC-authentication is configured, IPoE triggers preauthentication and queries the MAC binding for a user when receiving DHCP-DISCOVER (IPv4) or Solicit (IPv6) packets.
Transparent MAC-trigger authentication procedure
IMPORTANT
IMPORTANT:
Transparent MAC-trigger authentication supports only Web authentication that is triggered through the Web browser.
1.     The client initiates HTTP/HTTP requests after coming online in the preauthentication domain.
2.     The BRAS checks the destination IP of the HTTP/HTTPS request.
3.     If the message is destined for the portal Web server, the BRAS forwards the message to the portal Web server.
4.     If the message is not destined for the portal Web server, the BRAS sends a binding query request to the portal server. The portal server returns the query result.
If the query result shows that the user has not been bound, the following operations are performed:
a.     The BRAS redirects the subsequent HTTP/HTTPS requests to the Web authentication page of portal Web server. The BRAS sends HTTP/HTTPS messages containing the Web authentication page URL of the portal Web server to the client.
b.     The client browser automatically accesses the Web authentication page of the portal Web server.
c.     The portal Web server sends the Web authentication page contents to the client.
d.     The user enters the username and password and click Log in to send the authentication information to the portal server.
If the query result shows that the user has been bound, the BRAS waits for the Web authentication information from the portal server.
5.     The portal Web server sends the Web authentication information to the BRAS.
6.     The BRAS sends the AAA server an access request based on the Web authentication information.
7.     The AAA server returns to the BRAS one of the following results:
¡     An Access-Accept packet that contains the authorization information if the authentication succeeds.
8.     The BRAS performs one of the following operations based on the received result:
9.     If the authentication succeeds, the BRAS sends the AAA server a message to start accounting.
10.     (Applicable only to users that perform Web authentication the first time.) After the user comes online, the BRAS notifies the portal server of the event. After receiving the notification, the portal server notifies the MAC binding server to add a MAC binding for the user.
When the user accesses the network the next time, the user can come online through quick authentication based on the queried MAC binding entry after the BRAS receives any IP packets of the user.
Common transparent MAC authentication procedure
IMPORTANT
IMPORTANT:
Common transparent MAC authentication supports only Web authentication that is triggered through the Web browser.
The common transparent MAC authentication procedure is as follows (take the first login as an example):
4.     If the message is not destined for the portal Web server, the BRAS uses the MAC address of the user as the username to send authentication requests to the AAA server. Because the user logs in for the first time, the AAA server fails to query the binding of the user based on the MAC address and returns authentication failure.
7.     The authentication succeeds. The AAA server returns to the BRAS an Access-Accept packet that contains the authorization information.
8.     The BRAS updates the IPoE session state as authorized upon receiving an Access-Accept packet.
9.     The authentication succeeds. The BRAS sends the AAA server a message to start accounting.
10.     After the user comes online, the BRAS notifies the AAA server of the event. After receiving the notification, the AAA server adds a MAC binding for the user.
When the user accesses the network the next time, the BRAS uses the MAC address of the user as the username to send authentication requests to the AAA server after receiving any IP packets of the user. The AAA server can query the MAC binding for the user and returns authentication success. Then, the user can come online without entering the username and password.
Re-DHCP transparent MAC authentication procedure
IMPORTANT
IMPORTANT:
·     Re-DHCP transparent MAC authentication is only supported by DHCP users (including IPv4 and IPv6 users). For a dual-stack user to support re-DHCP transparent MAC authentication, make sure the user is a DHCP user in at least one protocol stack.
·     Re-DHCP transparent MAC authentication supports only Web authentication that is triggered through the Web browser.
The re-DHCP transparent MAC authentication procedure is as follows (take the first login as an example):
1.     When the device receives DHCP-DISCOVER (IPv4) or Solicit (IPv6) packets from a user, the device triggers preauthentication and uses the user MAC address as the username to initiate authentication on the AAA server. (In this phase, suppose ISP domain dm1 is used, which is configured by using the ip subscriber pre-auth domain command.)
2.     Because the user logs in for the first time, the AAA server fails to query the binding of the user based on the MAC address and returns authentication failure. After the user fails authentication, the user uses the reauthentication domain dm2 to trigger preauthentication again. Domain dm2 is configured not to perform authentication by using the none keyword. The user comes online in the preauthentication domain and obtains a temporary IP address. (In this phase, suppose reauthentication domain dm2 is used, which is configured by using the authen-fail online domain command.)
3.     After the user comes online in the preauthentication domain, the user initiates HTTP/HTTPS requests and comes online in the Web authentication phase through the common Web authentication process. Then, the AAA server adds a MAC binding entry for the user. (In this phase, suppose ISP domain dm3 is used, which is configured by using the ip subscriber web-auth domain command.)
4.     After the device receives accounting response packets from the AAA server, the device clears session information for the DHCP user and forcibly logs out the user. For a dual-stack user, the user will be forcibly logged out in both stacks only if it is a DHCP user in one protocol stack. If the user wants to come online again, the user needs to trigger preauthentication again (if the user is not a DHCP user in a protocol stack, the user must come online again based on the original configuration). Later, if the device receives DHCP lease renewal requests from the user, the device directly replies with NAK, so that the user can come online as soon as possible through transparent MAC authentication in the preauthentication domain.
5.     When the device receives DHCP-DISCOVER (IPv4) or Solicit (IPv6) packets from the user again, the device triggers preauthentication and uses the user MAC address as the username to initiate authentication on the AAA server. The AAA server queries the MAC binding for the user based on the user MAC address and returns authentication success packets carrying the authorization domain (dm4 in this example). The device allocates a public network IP address to the user according to the IP address pool in the authorization domain.
6.     If the authentication success packets returned by the AAA server do not carry an authorization domain, authorize an IP address pool in authentication domain dm1. Then, the device allocates a public network IP address in the authorized IP address pool to the user.
IPoE 802.1X authentication supports unclassified-IP users, DHCP users, IPv6 ND RS users, and global static users. The authentication process includes two phases, including preauthentication and postauthentication. For a user configured with a static IP address to come online through 802.1X authentication without configuring the corresponding IPoE static user access on the BRAS, you can enable the static 802.1X user authentication feature. For more information, see the ip subscriber static-dot1x-user enable command.
When 802.1X authentication is not prioritized, an 802.1X user must perform IPoE preauthentication and 802.1X postauthentication to come online. When 802.1X authentication is prioritized, an 802.1X user only needs to perform one authentication on the 802.1X client. Select whether to prioritize 802.1X authentication as needed.
When 802.1X authentication is not prioritized, an IPoE comes online in the following process:
·     In the preauthentication phase:
The  user access procedure in the preauthentication phase is the same as the user access procedure in the bind authentication mode. This phase does not involve 802.1X authentication.
·     In the postauthentication phase:
After an IPoE user comes online in the preauthentication domain, the system determines the processing method in the postauthentication domain according to the authentication result of the 802.1X client as follows:
¡     If the 802.1X client of the user is already online, IPoE uses the 802.1X authentication result to have the user come online directly in the postauthentication domain. In this case, the recorded user information is the 802.1X user information, including the 802.1X username, authentication domain, and authorized attributes.
¡     If the 802.1X client of the user is not online, the IPoE user stays in the preauthentication phase. When the 802.1X client of the user comes online, the processing is the same as that in the previous step.
¡     When both 802.1X authentication and Web authentication are configured on an interface, the following rules apply:
-     If an IPoE user has come online in the postauthentication domain through Web authentication before the 802.1X client comes online, the device will force the user to return to the preauthentication domain from the postauthentication domain of Web authentication after the 802.1X client comes online, and then the user uses 802.1X authentication to come online in the postauthentication domain of 802.1X authentication.
-     After an IPoE user uses 802.1X authentication to come online in the postauthentication domain, the user cannot use Web authentication to come online in the postauthentication domain.
When 802.1X authentication is prioritized, the following rules apply when an IPoE user tries to come online in the preauthentication phase:
·     In the scenario where 802.1X authentication prioritization in loose mode and that in strict mode are used together:
¡     If the 802.1X client of the IPoE user is not online, the IPoE user will stay in the state before the preauthentication phase. After the 802.1X client of the user comes online, IPoE uses the 802.1X authentication result to have the user come online directly in the postauthentication domain. In this case, the recorded user information is the 802.1X user information, including the 802.1X username, authentication domain, and authorized attributes.
¡     If the 802.1X client of the IPoE user is already online, IPoE uses the 802.1X authentication result to have the user come online directly in the postauthentication domain. In this case, the recorded user information is the 802.1X user information, including the 802.1X username, authentication domain, and authorized attributes.
·     In the scenario of 802.1X authentication prioritization in loose mode:
¡     An IPoE user cannot perform authentication to come online before the 802.1X client of the IPoE user is authenticated. However, when the 802.1X client fails to pass authentication, the IPoE user can perform authentication and come online through the normal IPoE process. In this case, the recorded user information is the IPoE user information, including the IPoE username, authentication domain, and authorized attributes.
¡     As a best practice to ensure that an endpoint can pop up the 802.1X authentication page to complete the authentication and come online, execute the ip subscriber authentication dot1x-retrigger command.
·     In the scenario of 802.1X authentication prioritization in strict mode:
¡     Before the 802.1X client of an IPoE user successfully passes authentication and comes online (the 802.1X client has not been authenticated or the 802.1X client has been authenticated but failed to pass authentication), the IPoE user cannot perform authentication and come online through the normal IPoE process.
¡     The BRAS actively sends EAP-Request/Identity packets to an endpoint each time the BRAS receives ARP, ND, or DHCP packets from the endpoint before the 802.1X client of the IPoE user successfully comes online. This mechanism ensures that the endpoint can respond to the EAP-Request/Identity packets, and pop up the 802.1X authentication page normally to complete 802.1X authentication and come online. After the 802.1X client comes online, when the 802.1X client of the IPoE user initiates the offline process, it will also bring offline the IPoE user (clear the IPoE user session).
HTTP extension header authentication is transparent to users during the postauthentication phase. The BRAS automatically obtains the username and password by resolving the extension header in the HTTP packets.
The HTTP extension header authentication user access procedure includes the following steps:
Preauthentication phase
A user must first perform preauthentication. After passing preauthentication, the user can obtain an IP address (for a DHCP user) and will be assigned the authorization attributes configured in the specified preauthentication domain. Then, the user can obtain the permissions to access the corresponding network resources (for example, the redirect URL of the gateway) based on the authorization information. However, the user cannot access intranet resources of the enterprise until the user completes postauthentication. Postauthentication is transparent to the user, which is automatically completed by the BRAS gateway.
The preauthentication process is the same as the IPoE bind authentication user access process. For more information, see "Access procedure for DHCP single-stack users," "Access procedure for IPv6 ND RS users," and "Access procedure for static and leased users."
Postauthentication phase
As shown in Figure 7, in a 5G network, the postauthentication process for HTTP extension header authentication is as follows:
Figure 7 Postauthentication process for HTTP extension header authentication
1.     A user endpoint accesses intranet resources of the enterprise through HTTP, and the sent HTTP request is forwarded through the user plane function (UPF) device to the BRAS that acts as the 5G gateway.
2.     The 5G gateway determines that the user is accessing intranet resources of the enterprise based on the destination IP address in the HTTP request and requires postauthentication. Therefore, the 5G gateway redirects the HTTP request to an extension URL that is pre-planned on the 5G gateway and the UPF device.
3.     The user endpoint sends an HTTP request to the extension URL based on HTTP redirect.
4.     After receiving an HTTP request for the extension URL from the user, the UPF device adds an extension header to the HTTP request. The extension header includes a unique ID for the user endpoint, which can be used for postauthentication of the user. The UPF device sends the HTTP request with the extension header to the 5G gateway.
5.     When the 5G gateway receives the HTTP request with the extension URL, it extracts the unique ID (typically the user's phone number) from the extension header, and sends an authentication request with the unique ID as the username and password to the AAA server on the enterprise intranet. After authenticating the user, the AAA server sends a reply to the 5G gateway.
6.     If the user fails to pass authentication on the AAA server, the user cannot access intranet resources of the enterprise through HTTP. If the user passes authentication, it indicates that the user passes postauthentication and comes online. The 5G gateway then redirects the HTTP request with the extension URL again to the originally requested URL, which is the URL for intranet resources of the enterprise.
7.     When the user requests to access intranet resources of the enterprise again through HTTP, the 5G gateway directly forwards the request to the enterprise intranet.
IPoE supports MPLS L3VPN. It uses AAA to authorize VPNs for users. Before you bind a VPN instance to an interface, you must delete existing IPoE sessions on the interface for the users to communicate in their authorized VPNs.
·     When an unclassified IPoE user comes online through an authorized VPN, you must configure a gateway IP address or use the gateway command to advertise the gateway IP address in the IP address pool of the public network on the access interface. As a best practice, advertise the gateway IP address in the IP address pool of the public network. For more information about the gateway command, see DHCP commands in BRAS Services Command Reference.
·     When a non-unclassified IPoE user comes online through an authorized VPN, you must configure a gateway IP address or enable proxy ARP by using the proxy-arp enable command on the access interface. As a best practice, enable proxy ARP. For more information, see proxy ARP configuration in Layer 3—IP Services Configuration Guide.
·     Leased users do not support AAA-authorized VPNs through ISP domains or AAA servers. For more information about VPN authorization through ISP domains, see BRAS Services Configuration Guide.
To use IPoE authentication that supports Extensible Authentication Protocol (EAP), make sure the portal authentication server and client are the H3C IMC portal server and the H3C iNode portal client, respectively.
Compared with username and password based authentication, digital certificate-based authentication provides higher security.
EAP supports several digital certificate-based authentication methods, for example, EAP-TLS. Working together with EAP, IPoE authentication can implement digital certificate-based user authentication.
Figure 8 IPoE support for EAP working flow
As shown in Figure 8, the authentication client and the portal authentication server exchange EAP authentication packets. The portal authentication server and the access device exchange portal authentication packets that carry the EAP-Message attributes. The access device and the RADIUS server exchange RADIUS packets that carry the EAP-Message attributes. The RADIUS server that supports the EAP server function processes the EAP packets encapsulated in the EAP-Message attributes, and provides the EAP authentication result.
The access device does not process but only transports EAP-Message attributes between the portal authentication server and the RADIUS server. The access device requires no additional configuration to support EAP authentication.
When you execute the following commands for IPoE Web authentication, make sure these commands are executed or not executed in both the preauthentication domain and Web authentication. Additionally, make sure the command configurations are the same as a best practice.
·     connection-limit amount.
·     connection-limit rate.
For more information about these commands, see BRAS Services Command Reference.
This feature does not take effect on global L3VE interfaces.
For IPoE web authentication, follow these restrictions and guidelines:
·     Do not execute the users-per-account command in the preauthentication domain. For more information about this command, see AAA commands in BRAS Services Command Reference.
·     In an IPv6 network, an endpoint might use a temporary IPv6 address for IPoE Web authentication, which will cause authentication failure. To avoid this problem, configure the ipv6 nd ra prefix { ipv6-prefix prefix-length | ipv6-prefix/prefix-length } no-advertise command on the interface through which the user comes online to prevent the endpoint from obtaining a temporary IPv6 address. The ipv6-prefix prefix-length | ipv6-prefix/prefix-length argument specifies the IPv6 prefix and prefix length of the network segment where the user resides. For information about temporary IPv6 addresses, see IPv6 basics in Layer 3—IP Services Configuration Guide.
When the device acts as the DHCP server that assigns IP addresses to IPoE users, you must execute the following commands:
·     For an IPv4 address pool, execute the dhcp server forbidden-ip command or the forbidden-ip command to exclude the gateway IP address from dynamic allocation.
·     For an IPv6 address pool, execute the ipv6 dhcp server forbidden-address command to exclude the gateway IPv6 address from dynamic allocation.
For more information, see DHCP commands and DHCPv6 commands in BRAS Services Command Reference.
If both the ISP domain and DHCP server are configured to assign the DNS servers to IPoE DHCP users, the following rules apply:
·     If the IPoE device acts as a DHCP server, the DHCP users preferentially use the DNS servers assigned by the ISP domain.
·     If the IPoE device acts as a DHCP relay agent, the DHCP users preferentially use the DNS servers assigned by the DHCP server.
In a DHCP relay agent network, follow these restrictions and guidelines:
·     For DHCP users to come online properly when IPoE operates in Layer 3 access mode and the BRAS acts as a DHCP server, do not execute the ip subscriber initiator arp enable command on the access interface.
·     When address pools are allocated to users through configuring an IP address, enabling the DHCP relay agent (by using the dhcp select relay command), and configuring the relay server address (by using the remote-server command) on an interface, you must create a relay address pool corresponding to the DHCP server on the DHCP relay agent. In the current software version, the following types of IP address pools can be configured as relay address pools:
¡     Remote BAS IP address pool (configured by using the ip pool pool-name bas remote command).
¡     Common IP address pool (configured by using the ip pool pool-name command).
For a complete example for remote BAS IP address pools and common IP address pools, see "Example: Configuring IPoE common Web authentication for multi-network-segment DHCPv4 users (assigning a remote BAS IP address pool)."
When a BRAS acts as a DHCP relay agent, the following command settings must be the same on the DHCP relay agent and the remote DHCP server for a common IP address pool:
·     In a DHCPv4 network:
¡     network: Specifies a network segment for dynamic allocation in an IP pool.
¡     address range: Configures an IP address range in an IP pool for dynamic allocation.
¡     forbidden-ip: Exclude IP addresses from dynamic allocation in an IP pool.
For more information about these commands, see DHCP commands in BRAS Services Command Reference.
·     In a DHCPv6 network:
¡     network: Specifies an IPv6 subnet for dynamic allocation in an IPv6 address pool.
¡     address range: Specifies a non-temporary IPv6 address range in an IPv6 address pool for dynamic allocation.
¡     forbidden-address: Excludes IPv6 addresses from dynamic allocation in an IPv6 address pool.
¡     forbidden-prefix: Excludes IPv6 prefixes from dynamic allocation in an IPv6 address pool.
¡     prefix-pool: Applies a prefix pool to an IPv6 address pool, so the DHCPv6 server can dynamically select a prefix from the prefix pool for a client.
For more information about these commands, see DHCPv6 commands in BRAS Services Command Reference.
In an IPoE application, the advertisement push function takes effect only on HTTP packets using port number 80 and HTTPS packets using port number 443.
After you enable IPoE and set the IPoE access mode, you can configure different types of IPoE users based on the network requirements.
To configure bind authentication users, perform the following tasks:
1.     Enabling IPoE and setting the IPoE access mode
2.     (Optional.) Configuring the authentication method
3.     Configure bind authentication user types
¡     Configuring dynamic individual users
¡     Configuring static users
¡     Configuring leased users
4.     (Optional.) Enabling unclassified-IP packet attack defense
5.     (Optional.) Rate-limiting DHCP packets
6.     (Optional.) Setting the maximum number of individual sessions and leased subuser sessions on an interface
7.     (Optional.) Configuring service-specific ISP domains
8.     (Optional.) Configuring the quiet feature for users
9.     (Optional.) Configuring online detection for IPoE users
10.     (Optional.) Configuring NAS-Port-ID formats
11.     Configuring NAS-Port-ID binding for IPoE access users
Perform this task when you need to acquire the physical location of the access interface by NAS-Port-ID.
12.     Enabling IPoE access-out authentication
Perform this task in a dual-authentication network.
13.     Enabling roaming for IPoE individual users
Perform this task in a roaming network.
14.     (Optional.) Configuring the IPoE user access response delay policy
15.     (Optional.) Configuring IPoE user access management
16.     (Optional.) Configuring features by using the old-style IPoE commands‌
To configure Web authentication individual users, perform the following tasks:
1.     Configuring the remote portal authentication server
2.     (Optional.) Specifying the HTTPS redirect listening port number
Perform this task only when HTTPS is used.
3.     Obtaining user access information from ARP or ND entries
4.     Enabling IPoE and setting the IPoE access mode
5.     Configuring the authentication method
6.     Configuring IPoE Web authentication user types
Perform this task for only IPv6 ND RS users.
Perform this task for only static individual users.
7.     (Optional.) Configuring Web authentication advanced features
8.     (Optional.) Enabling unclassified-IP packet attack defense
9.     (Optional.) Rate-limiting DHCP packets
10.     (Optional.) Setting the maximum number of individual sessions and leased subuser sessions on an interface
11.     (Optional.) Configuring service-specific ISP domains
12.     (Optional.) Configuring the quiet feature for users
13.     (Optional.) Configuring online detection for IPoE users
14.     (Optional.) Configuring NAS-Port-ID formats
15.     Configuring NAS-Port-ID binding for IPoE access users
16.     Configuring IPoE quick Web authentication
Configure this feature when you configure IPoE quick authentication in the network.
17.     Enabling roaming for IPoE individual users
18.     (Optional.) Configuring the IPoE user access response delay policy
19.     (Optional.) Configuring IPoE user access management
20.     (Optional.) Configuring features by using the old-style IPoE commands‌
IPoE 802.1X authentication access user tasks at a glance
To configure IPoE 802.1X authentication access users, perform the following tasks:
1.     Configure basic IPoE functions.
For more information, see IPoE bind authentication configuration.
2.     Configure 802.1X-related functions.
The authentication and authorization function for the 802.1X client are completed by the 802.1X module. Therefore, you must correctly configure 802.1X authentication domain-related functions. For more information, see 802.1X authentication in BRAS Services Configuration Guide.
3.     (Optional.) Configuring the advanced 802.1X authentication features‌
¡     Configuring the static 802.1X user authentication feature
¡     Forcibly logging out an 802.1X client
¡     Forcibly logging out an IPoE user when the 802.1X client goes offline
Prerequisites for IPoE
Complete the following configuration as required:
·     Configure the DHCP server.
·     Enable the DHCP relay agent on the BRAS.
Configure the RADIUS server and client. Configure security policies on the H3C IMC security server and configure the security server's IP address on the BRAS. For more information about configuring a RADIUS client and a security server, see AAA configuration in BRAS Services Configuration Guide.
·     Configure local user accounts on the BRAS if local authentication is used. For more information about configuring a local user account, see AAA configuration in BRAS Services Configuration Guide.
·     Make sure the hosts, BRAS, and servers can reach each other.
For more information, see "Configuring portal."
For more information, see HTTP redirect configuration in Layer 3—IP Services Configuration Guide.
IPoE configurations for the IPv4 or IPv6 protocol stack take effect on an interface only when IPoE is enabled on the interface for the IPv4 or IPv6 protocol stack.
For IPoE to operate correctly, to use the ip subscriber basic-service-ip-type command to configure the IP address type (IPv4 or IPv6) on which the main service of IPoE users depends on an interface, make sure dual-stack IPoE is enabled on the interface by using the ip subscriber enable command.
For interface-leased users, family-leased users, L2VPN-leased users, and dual-stack static users to come online, you must enable IPoE for both IPv4 and IPv6 protocol stacks.
In an IPv4 network, when IPoE operates in Layer 2 mode, you must execute the gateway command in an IP address pool to specify the gateway address for users. Do not specify the gateway address for users through configuring an IP address for the access interface.
2.     Enter interface view.
3.     Enable IPoE and set the IPoE access mode on an interface.
ip subscriber { l2-connected | routed } enable [ ipv4 | ipv6 ]
By default, IPoE is disabled.
If you do not specify the ipv4 or ipv6 keyword, this command enables IPoE for both IPv4 and IPv6 protocol stacks.
To change the IPoE access mode or protocol stack on an interface, you must disable IPoE, and then enable IPoE with a new IPoE access mode or protocol stack.
·     Bind authentication—Authenticates users by the usernames and passwords that the BRAS automatically generates based on user location information. Bind authentication is applicable to all types of IPoE users.
Users using bind authentication support reauthentication. With reauthentication enabled, when a bind authentication user passes the first authentication, the BRAS will reauthenticate the user according to the information (for example, username and domain) authorized by the AAA server in the first authentication.
·     802.1X authentication—Authenticates users by the usernames and passwords on an 802.1X client. To access a Layer 3 interface through 802.1X, configure the 802.1X authentication method.
·     Web authentication—Authenticates users by the usernames and passwords that users enter on the Web authentication page. Web authentication applies to DHCP users and static individual users.
·     Web MAC authentication—A user has to enter the username and password only for the first login. Then, the user can quickly come online without entering the username and password.
·     Extension HTTP header authentication—Adds specific authentication information to the HTTP request header to achieve transparent postauthentication for users.
By default, bind authentication is configured for IPoE users. To perform Web authentication for IPoE users, you must configure Web authentication for the IPoE users.
On an IPoE Web authentication network, to authorize VPNs to users after they pass postauthentication so that the users can have different access permissions, you can specify the support-authorized-vpn keyword to enable the postauthentication domain of Web authentication to support VPN authorization.
With this feature enabled, when IPoE Web users come online in the postauthentication domain, AAA can be used to authorize VPN instances to users. When a user with a VPN instance authorized comes online in the postauthentication domain, the host route of the user will be switched to the specified VPN instance. Then, the user can access only network resources in the authorized VPN instance.
On an IPoE Web authentication network, follow these restrictions and guidelines for static IPoE users:
·     If the vpn-instance keyword is specified in the static session of a static IPoE user, the static user does not support the VPN authorization feature in the postauthentication domain.
·     If the vpn-instance keyword is not specified in the static session of a static IPoE user, the following rules apply:
¡     If the strict-check access-interface vpn-instance command is executed in the authorization domain of a static user, the static user does not support the VPN authorization feature in the postauthentication domain.
¡     If the strict-check access-interface vpn-instance command is not executed in the authorization domain of a static user, the static user supports the VPN authorization feature in the postauthentication domain.
In a VSRP network, VPN authorization is not supported in the postauthentication domain of Web authentication.
When you switch the IPoE authentication method, the device performs operations depending on the session type:
·     For dynamic individual sessions, the device deletes all the dynamic individual sessions on the interface and logs out users.
·     For interface-level static individual sessions, the device deletes all static individual sessions and logs out users.
·     For global static individual sessions, the device deletes all global static individual sessions created on the interface and logs out users.
·     For leased sessions (including static leased sessions), you cannot switch the authentication method if leased sessions are configured on the interface.
When specifying reauthentication in the bind authentication mode, follow these restrictions and guidelines:
·     Reauthentication is supported only in Layer 3 IPoE access mode.
·     Only unclassified-IP users support reauthentication.
·     Use the ip subscriber unclassified-ip username include source-ip command to make sure the username used in the first authentication is the source IP address of unclassified-IP, ARP, or NS/NA packets.
When you configure 802.1X authentication, follow these restrictions and guidelines:
·     IPoE 802.1X authentication supports unclassified-IP users, DHCP users, IPv6 ND RS users, and global static users. For a user configured with a static IP address to come online through 802.1X authentication without configuring the corresponding IPoE static user access on the BRAS, you can enable the static 802.1X user authentication feature. For more information, see the ip subscriber static-dot1x-user enable command.
·     When both 802.1X authentication and Web authentication are configured on an interface, a user can use only one of them to perform authentication and come online at a time. 802.1X authentication takes priority over Web authentication.
·     If a global static session without the support-ds keyword specified exists on the device, before configuring 802.1X authentication, you must first use the undo ip subscriber session static command to delete all global static sessions without the support-ds keyword specified and then execute the ip subscriber session static command to re-configure global static sessions with the support-ds keyword specified.
·     When static users do not support 802.1X authentication on an interface, do not configure both 802.1X authentication and interface-level IPoE static individual sessions on the interface. If you do that, the interface-level IPoE static individual sessions configured on the interface might not function normally.
·     On an interface, 802.1X authentication is mutually exclusive with Layer 3 IPoE access mode, IPoE interface-leased users, IPoE subnet-leased users, and IPoE L2VPN-leased users.
·     You can configure 802.1X authentication on an interface only when the interface operates in Layer 2 IPoE access mode.
·     By default, both IPv4 and IPv6 are enabled on an 802.1X client. As a best practice, enable both IPv4 and IPv6 for IPoE when configuring the 802.1X authentication method.
·     The authentication and authorization function for the 802.1X client are completed by the 802.1X module. Therefore, you must correctly configure 802.1X-related functions. For more information about 802.1X configuration, see BRAS Services Configuration Guide.
·     Only Layer 3 Ethernet interfaces/subinterfaces and Layer 3 aggregate interfaces/subinterfaces support 802.1X authentication.
·     For IPoE 802.1X authentication to support unclassified-IP users, specify the support-unclassified-ip keyword when configuring 802.1X authentication.
When IPoE Web authentication and portal authentication are both configured on an interface, only IPoE Web authentication takes effect. The configuration of IPoE Web authentication does not affect an online portal user. When the portal user goes offline, the user cannot access the interface through portal authentication again. For more information portal authentication, see portal configuration in BRAS Services Configuration Guide.
When a DHCP user or static user comes online through Web authentication, the user can use common Web authentication, transparent MAC-trigger authentication, and transparent MAC authentication. When multiple authentication methods are configured, an authentication method is selected as follows:
·     If Web authentication is configured on an interface, the following rules apply:
¡     If no MAC binding server is configured by using the portal apply mac-trigger-server command on the interface, the DHCP user or static user uses common Web authentication.
¡     If a MAC binding server is configured by using the portal apply mac-trigger-server command on the interface, the DHCP user or static user uses transparent MAC-trigger authentication.
¡     If the ip subscriber web-redhcp enable command is executed to enable re-DHCP for IPoE Web authentication, the DHCP user uses re-DHCP transparent MAC authentication no matter whether a MAC binding server is configured by using the portal apply mac-trigger-server command on the interface.
·     If Web MAC authentication is configured on an interface, the DHCP user or static user uses common transparent MAC authentication no matter whether a MAC binding server is configured by using the portal apply mac-trigger-server command on the interface.
When configuring HTTP extension header authentication, make sure the web-server url-parameter original-url command is executed in the preauthentication domain.
3.     Configure the authentication method for IPoE users.
Syntax I:
ip subscriber authentication-method { bind [ reauth ] | { dot1x [ high-priority] | web [ mac-auth ] [ basic-service-ipv4 ] [ support-authorized-vpn ] [ inherit-pppoe ] } * [ support-unclassified-ip ] | http-x-header [ x-header-name ] [ support-authorized-vpn ] }
Syntax II:
ip subscriber authentication-method dot1x high-priority-strict [ support-unclassified-ip ]
4.     Enable re-DHCP for IPoE Web authentication.
By default, re-DHCP is disabled for IPoE Web authentication.
Execute this command on a re-DHCP transparent MAC authentication network.
Dynamic individual user tasks at a glance
To configure dynamic individual users, perform the following tasks:
1.     Configuring a dynamic individual session initiation method
2.     (Optional.) Configuring authentication user naming conventions for dynamic individual users
3.     (Optional.) Configuring passwords for dynamic individual users
4.     (Optional.) Configuring ISP domains for dynamic individual users
5.     (Optional.) Setting the dynamic individual session limit
6.     (Optional.) Configuring trusted DHCP options for DHCP users
7.     (Optional.) Configuring the parsing format for the circuit ID and remote ID in the DHCP option
8.     (Optional.) Configuring trusted ISP domains for DHCP users
9.     (Optional.) Configuring domain name generation rules for dynamic IPoE DHCP users
10.     (Optional.) Allowing abnormally logged out IPoE users to come online again through packet initiation
11.     (Optional.) Allowing DHCP users to access in loose mode
12.     (Optional.) Configuring automatic IPoE user backup‌
13.     (Optional.) Allowing users to come online through ND RS only after they come online through IA_PD‌
14.     (Optional.) Enabling immediate sending of accounting-update messages when the user IPv6 address changes
Dynamic individual session initiation methods include unclassified-IP packet initiation, IPv6 ND RS packet initiation, and DHCP packet initiation (enabled by default and cannot be disabled). After IPoE is enabled on an interface, the BRAS drops packets from users by default. You must configure a dynamic individual session initiation method on the interface to initiate IPoE sessions. You can configure multiple dynamic individual session initiation method on an interface.
For unclassified-IPv4 packet initiation, you must execute the dhcp enable command to enable DHCP. For more information about this command, see DHCP commands in BRAS Services Command Reference.
When you use IPv6 ND RS packet initiation, follow these restrictions and guidelines:
·     IPv6 ND RS packet initiation requires the BRAS to send IPv6 ND RA packets. As a best practice, make sure the interval for sending IPv6 ND RA packets is no less than 6 minutes.
·     IPv6 single-stack IPoE sessions initiated by IPv6 ND RS packets support only hosts that use Layer 2 access mode.
·     PCs running Windows generate temporary IPv6 addresses randomly or generate public addresses by using the EUI-64 method. The temporary addresses might change. When AAA is used to authorize prefixes to users (prefixes are shared), users might fail to come online through temporary addresses if the temporary addresses change. To solve this problem, configure both unclassified-IPv6 packet initiation and IPv6 ND RS packet initiation for an IPv6 interface as a best practice.
3.     Configure an IPv4 dynamic individual session initiation method.
ip subscriber initiator unclassified-ip enable
By default, no IPv4 dynamic individual session initiation method is enabled.
4.     Configure an IPv6 dynamic individual session initiation method.
ip subscriber initiator { ndrs | unclassified-ipv6 } enable
By default, no IPv6 dynamic individual session initiation method is enabled.
Usernames configured for dynamic individual users must be the same as those configured on the AAA server.
Bind authentication method
For dynamic individual users using bind authentication, a username is selected in the following order until a match is found:
1.     Username configured by using the command specific to the users.
¡     For DHCP users, username obtained by using the ip subscriber dhcp username command.
¡     For ND RS users, username obtained by using the ip subscriber ndrs username command.
¡     For unclassified-IP users and static individual users, username obtained by using the ip subscriber unclassified-ip username command.
2.     Username configured by using the ip subscriber username command.
3.     Default user name.
¡     For DHCP users, MAC address of the user. If the user MAC address cannot be obtained, the source MAC address of packets is used.
¡     For ND RS users, source MAC address of packets.
¡     For unclassified-IP users and static individual users, source IP address of packets.
Web authentication method
For Web authentication in the preauthentication phase, a username is selected for dynamic individual users in the order a username is selected for dynamic individual users using bind authentication.
For Web authentication in the Web authentication phase, a username is selected in the following order for dynamic individual users until a match is found:
4.     Username that the user enters when logging in.
5.     Username configured by using the ip subscriber username command.
6.     Default user name.
Web MAC authentication method
For Web MAC authentication in the preauthentication phase, a username is selected for dynamic individual users in the order a username is selected for dynamic individual users using bind authentication.
For Web MAC authentication in the Web authentication phase, a username is selected in the following order for dynamic individual users until a match is found:
7.     Username configured by using the ip subscriber username command.
8.     Default user name.
3.     Configure an authentication user naming convention for DHCP users.
ip subscriber dhcp username include { circuit-id [ mac ] [ separator separator ] | client-id [ separator separator ] | hostname [ original ] [ separator separator ] | nas-port-id [ separator separator ] | port [ separator separator ] | remote-id [ separator separator ] | second-vlan [ separator separator ] | slot [ separator separator ] | source-mac [ address-separator address-separator [ address-format-version-two ] ] [ separator separator ] | string string [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vendor-class [ absent-replace | original ] * [ separator separator ] | vendor-specific [ original ] [ separator separator ] | vlan [ separator separator ] } *
By default, no authentication user naming conventions are configured for DHCP users.
For DHCPv4 users accessing in loose mode, the packets do not carry DHCP Option information. Therefore, the circuit-id, mac, client-id, remote-id, vendor-class, original, or vendor-specific keyword does not take effect. Even these keywords are specified, usernames are generated according to the situation where these keywords are not specified. DHCPv6 users cannot access in loose mode.
4.     Configure an authentication user naming convention for unclassified-IP users.
ip subscriber unclassified-ip username include { nas-port-id [ separator separator ] | port [ separator separator ] | second-vlan [ separator separator ] | slot [ separator separator ] | source-ip [ address-separator address-separator ] [ separator separator ] | source-mac [address-separator address-separator ] [ separator separator ] | string string [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vlan [ separator separator ] } *
By default, no authentication user naming conventions are configured for unclassified-IP users.
5.     Configure an authentication user naming convention for IPv6 ND RS users.
ip subscriber ndrs username include { nas-port-id [ separator separator ] | port [ separator separator ] | second-vlan [ separator separator ] | slot [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | string string [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vlan [ separator separator ] } *
By default, no authentication user naming conventions are configured for IPv6 ND RS users.
6.     Configure the username for IPoE individual users.
ip subscriber username { mac-address [ address-separator address-separator ] [ lowercase | uppercase ] | string string }
By default, no username is configured for IPoE individual users.
To avoid configuring usernames for each initiation method separately when multiple individual session initiation methods are configured on an interface, you can use this command to uniformly configure authentication usernames for all individual users on an interface.
The password selection rule for DHCPv4 users in this section applies to only DHCPv4 users accessing in non-loose mode. For how the password is selected for DHCPv4 users accessing in loose mode, see Layer 2—WAN Access Command Reference. For information about accessing in loose mode, see "Allowing DHCP users to access in loose mode."
Passwords configured for dynamic individual users must be the same as those configured on the AAA server.
For dynamic individual users using bind authentication, a password is selected in the following order until a match is found:
1.     Password obtained by using the ip subscriber dhcp password and ip subscriber dhcpv6 password option16 commands. (Applicable to only DHCP users.)
2.     Password configured by using the ip subscriber password command.
3.     The string vlan.
For Web authentication in the preauthentication phase, a password is selected for dynamic individual users in the same order a password is selected for dynamic individual users using bind authentication.
For Web authentication in the Web authentication phase, a password is selected in the following order for dynamic individual users until a match is found:
4.     Password that the user enters when logging in.
5.     Password configured by using the ip subscriber password command.
6.     The string vlan.
For Web MAC authentication in the preauthentication phase, a password is selected for dynamic individual users in the same order a password is selected for dynamic individual users using bind authentication.
For Web MAC authentication in the Web authentication phase, a password is selected in the following order for dynamic individual users until a match is found:
7.     Password configured by using the ip subscriber password command.
8.     The string vlan.
3.     Set the password for dynamic individual users.
ip subscriber password { mac-address [ address-separator address-separator ] [ lowercase | uppercase ] | { ciphertext | plaintext } string }
The default password for dynamic individual users is vlan.
To avoid configuring passwords for each initiation method separately when multiple individual session initiation methods are configured on an interface, you can use this command to uniformly configure authentication passwords for all individual users on an interface.
4.     Specify a string from the DHCPv4 as the password for DHCPv4 users.
ip subscriber dhcp password { circuit-id mac | option60 [ offset offset ] [ length length ] [ original ] | user-class }
By default, the BRAS does not use the password specified in DHCPv4 packets for DHCP users.
To use the string in Option 60 or Option 77 as the password, configure Option 60 or Option 77 as the trusted DHCP option. For more information about trusting Option 60 or Option 77, see "Configuring trusted DHCP options for DHCP users."
5.     Specify a string from Option 16 or Option 17 as the password for DHCPv6 users:
ip subscriber dhcpv6 password option16 [ offset offset ] [ length length ] [ original ]
By default, the BRAS does not use the password specified in Option 16 or Option 17 for DHCPv6 users.
Configure DHCPv6 Option 16 or Option 17 as the trusted DHCP option for the password specified by using this command to take effect. For more information about Option 16 or Option 17, see "Configuring trusted DHCP options for DHCP users."
The ISP domain selection rule in this section applies to only IPoE users accessing in non-loose mode. For how the ISP domain is selected for IPoE users accessing in loose mode, see Layer 2—WAN Access Command Reference. For information about accessing in loose mode, see "Allowing DHCP users to access in loose mode."
In bind authentication, a dynamic individual user can obtain ISP domains in various ways. An ISP domain is selected for a dynamic individual user in the following order until a match is found (steps 1 and 2 apply to only DHCP users, and step 3 applies to only DHCP users and unclassified-IP users):
1.     Forced ISP domain configured by using the ip subscriber dhcp domain command. If the ISP domain has not been created, the user fails to come online. (Applicable to only DHCP users.)
2.     Information obtained from the option. (Applicable to only DHCP users.)
For a DHCPv4 user, an ISP domain in information obtained from the option is selected in the following order until a match is found:
a.     ISP domain generated based on the domain name generation rule configured by the ip subscriber dhcp domain include command if the following conditions exist:
-     The string selected from Option 60 contains the trusted domain.
-     The BRAS trusts Option 60.
-     The interface is configured with the ip subscriber dhcp domain include command.
If the ISP domain has not been created, proceed with step 3.
b.     Trusted ISP domain configured by the ip subscriber dhcp option60 match command if the following conditions exist:
-     The interface is not configured with the ip subscriber dhcp domain include command.
c.     ISP domain selected according to the rule for packets that do not carry Option 60 if the following conditions exist:
-     The string selected from Option 60 does not contain the trusted domain.
In this case, the contents of Option 60 are ignored and not used for generating a domain name.
d.     ISP domain generated based on the domain name generation rule configured by the ip subscriber dhcp domain include command if the following conditions exist:
-     The interface is not configured with the ip subscriber dhcp option60 match command.
-     Option 60 does not contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), or right angle bracket (>).
e.     ISP domain automatically selected from Option 60 if the following conditions exist:
-     The interface is not configured with the ip subscriber dhcp option60 match or ip subscriber dhcp domain include command.
-     All information in Option 60 does not contain invalid characters. Invalid characters include the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), and right angle bracket (>).
For a DHCPv6 user, an ISP domain in information obtained from the option is selected in the following order until a match is found:
f.     Trusted ISP domain configured by the ip subscriber dhcpv6 option16 match command if the following conditions exist:
-     The string selected from Option 16 contains the trusted domain.
-     The BRAS trusts Option 16.
g.     ISP domain selected according to the rule for packets do not carry Option 16 if the following conditions exist:
-     The interface is configured with the ip subscriber dhcpv6 option16 match command, but the specified string cannot be matched in the specified position of Option 16. Or, the interface is not configured with the ip subscriber dhcpv6 option16 match command.
-     All information in Option 16 does not contain invalid characters. Invalid characters include the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), and right angle bracket (>).
3.     Service-specific ISP domain. If the ISP domain has not been created, the user fails to come online. (Applicable to only DHCP users and unclassified-IP users.)
4.     ISP domain configured by using the domain configuration command specific to the user:
¡     For a DHCP user, non-forced ISP domain configured by using the ip subscriber dhcp domain command. If the ISP domain has not been created, the user fails to come online.
¡     For an unclassified-IP user, ISP domain configured by using the ip subscriber unclassified-ip domain command. If the ISP domain has not been created, the user fails to come online.
¡     For an IPv6 ND RS user, ISP domain configured by using the ip subscriber ndrs domain command. If the ISP domain has not been created, the user fails to come online.
5.     ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
For more information about domain name generation rules, see "Configuring domain name generation rules for dynamic IPoE DHCP users."
For more information about configuring trusted ISP domains, see "Configuring trusted ISP domains for DHCP users."
For more information about configuring service-specific ISP domains, see "Configuring service-specific ISP domains."
In Web authentication, for how the BRAS selects ISP domains for dynamic individual users, see "Configuring an ISP domain for Web authentication individual users."
Configure trusted DHCP options before you configure the trusted ISP domains. For more information about configuring trusted DHCP options, see "Configuring trusted DHCP options for DHCP users."
For a user to pass authentication, make sure the ISP domain selected for the user exists on the BRAS.
3.     Configure an ISP domain for dynamic individual users.
ip subscriber dhcp domain domain-name [ force ]
ip subscriber { ndrs | unclassified-ip } domain domain-name
By default, no ISP domain is configured for dynamic users.
This feature limits the total number of dynamic individual sessions on an interface to limit the total number of dynamic individual users.
You can set a smaller value than the number of existing dynamic individual sessions on an interface. In this scenario, the existing dynamic individual sessions are not affected.
In a dual-stack IPoE network, as a best practice, make sure the following requirements are met:
·     For DHCP users, set the same IPoE session limit for DHCPv4 users and DHCPv6 users.
·     For unclassified-IP users, set the same IPoE session limit for unclassified-IPv4 users and unclassified-IPv6 users.
3.     Configure the dynamic individual session limit.
ip subscriber { dhcp | dhcpv6 | ndrs | unclassified-ip | unclassified-ipv6 } max-session max-number
By default, the dynamic individual session limit is not configured.
When this command is configured together with the ip subscriber max-session command, the two commands both take effect. The two commands control sessions in different perspectives, and the number of sessions is controlled by both commands. A new session can be established only when neither limit is reached. For more information about the ip subscriber max-session command, see "Setting the maximum number of individual sessions and leased subuser sessions on an interface."
This feature enables a BRAS to obtain user access information from trusted DHCP options when the BRAS acts as a DHCP relay agent. The BRAS includes the obtained user access information in the RADIUS attributes sent to the RADIUS server based on the following matrix.
Table 1 Associated DHCP options for RADIUS attributes
RADIUS attributes
NAS-PORT-ID
·     DHCPv4 Option 82 Circuit-ID
·     DHCPv6 Option 18
DSL_AGENT_CIRCUIT_ID
·     DHCPv6 Option 18
DSL_AGENT_REMOTE_ID
·     DHCPv4 Option 82 Remote-ID
·     DHCPv6 Option 37
If DHCPv6 Option79 is trusted, a MAC address can be obtained from Option79 and used as a required condition for recognizing a DHCPv6 user. If a DHCPv4 user uses the same MAC address, the two users can form a dual-stack user. Follow these restrictions and guidelines:
·     If IPoE can obtain user MAC addresses from both the Option79 and Client ID fields, the user MAC address obtained from Option79 takes priority.
·     For a BRAS to receive DHCPv6 packets carrying Option79, execute the ipv6 dhcp relay client-link-address enable command to enable the DHCPv6 relay agent to support Option 79 on the first DHCPv6 relay agent that the requests from a DHCPv6 client pass through. For more information about the ipv6 dhcp relay client-link-address enable command, see DHCPv6 commands in BRAS Services Command Reference.
By default, the BRAS uses the ASCII format to parse the circuit-ID and remote-ID fields in Option 82, Option 18, and Option 37. For more information about the circuit-ID and remote-ID parsing formats, see "Configuring the parsing format for the circuit ID and remote ID in the DHCP option."
If the BRAS trusts DHCPv4 Option 60, DHCPv6 Option 16, and DHCPv6 Option 17, IPoE can use the ISP domains specified in the options when certain conditions exist. For more information about selecting ISP domains, see "Configuring ISP domains for dynamic individual users."
3.     Configure trusted DHCP options for DHCP users.
ip subscriber trust { option12 | option60 | option77 | option82 | option16 | option17 | option18 | option37 | option79 }
By default, only Option79 in DHCP packets are trusted.
On the same interface, you can execute this command multiple times to configure multiple trusted options. However, you cannot configure the interface to trust both Option 16 and Option 17. For example, if you have configured Option 16 as a trusted option, you cannot configure Option 17 as a trusted option.
For IPoE to correctly parse information in the circuit ID and remote ID, perform this task to set a proper parsing format according to the format of the circuit ID and remote ID information sent by downstream devices.
This feature takes effect only after the ip subscriber trust command is configured to trust the specified option.
3.     Configure trusted DHCP options.
ip subscriber trust { option82 | option18 | option37 }
By default, the BRAS does not trust DHCP options.
4.     Configure the IPoE parsing format for the circuit ID in the DHCP option.
ip subscriber access-line-id circuit-id trans-format { ascii | hex }
By default, the IPoE parsing format for the circuit ID in the DHCP option is ASCII.
5.     Configure the IPoE parsing format for the remote ID in the DHCP option.
ip subscriber access-line-id remote-id trans-format { ascii | hex }
By default, the IPoE parsing format for the remote ID in the DHCP option is ASCII.
If DHCP packet initiation is enabled and portal authentication is configured, the following situations occur:
·     If the string selected from Option 60/Option 16/Option 17 contains the trusted ISP domain, DHCP packet initiation triggers IPoE authentication and selects an ISP domain for IPoE authentication in the following order until a match is found:
a.     Forced ISP domain. If the ISP domain has not been created, the user fails to come online.
b.     When Option 60/Option 16/Option 17 in DHCP packets is trusted, the following rules apply:
-     If the domain name generation rule is configured, the domain name generated according to the generation rule is used.
-     If no domain name generation rule is configured, the trusted ISP domain is used.
For information about domain name generation rules, see "Configuring domain name generation rules for dynamic IPoE DHCP users."
c.     When the interface is not configured to trust Option 60/Option 16/Option 17 in DHCP packets, for how to select an ISP domain, see "Configuring ISP domains for dynamic individual users."
d.     ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
·     If the string selected from Option 60/Option 16/Option 17 does not contain the trusted ISP domain, DHCP packets do not trigger IPoE authentication.
3.     Configure trusted ISP domains for DHCPv4 users.
ip subscriber dhcp option60 match string [ offset offset] [length length]
By default, no trusted ISP domain is configured for DHCPv4 users.
4.     Configure trusted ISP domains for DHCPv6 users.
ip subscriber dhcpv6 { option16 | option17 } match string [ offset offset ] [ length length ]
By default, no trusted ISP domain is configured for DHCPv6 users.
In some scenarios, the access information and Option 60 must be combined as an ISP domain for authentication. For example, user A and user B belong to different VLANs but have the same Option 60 and come online through the same interface. To assign user A and user B to different ISP domains and authorize different address pools based on ISP domains, you can use this feature. This feature can generate ISP domain names by using the Option 60 + VLAN combination.
If the DHCP users use information in Option 60 as the ISP domains and a domain name generation rule is configured, the parameters configured in this generation rule are used for generating the ISP domain names. The domain name generated is Field in Option 60 used as the ISP domain name + parameters configured in this rule. If Option 60 is trusted, the fields in Option 60 are selected for generating ISP domains as follows:
·     If the ip subscriber dhcp option60 match command is configured, the following rules apply:
¡     If the string selected from Option 60 contains the trusted domain, the trusted domain is used for generating the ISP domain names.
¡     If the string selected from Option 60 does not contain the trusted domain, the contents of Option60 are ignored and not used as ISP domains. In this case, an ISP domain name is selected according to the rule for packets that do not carry Option 60.
·     If the ip subscriber dhcp option60 match command is not configured, the string selected by using the ip subscriber trust option60 command is used for generating the ISP domain names.
To configure this feature on an interface, you must configure the interface to trust Option 60. For Option 60 configuration, see "Configuring trusted ISP domains for DHCP users."
3.     Configure the interface to trust Option 60 in DHCPv4 packets.
By default, no option in DHCPv4 packets is trusted.
4.     Configure the trusted domains for IPv4 DHCP users.
ip subscriber dhcp option60 match string [ offset offset ] [ length length ]
By default, no trusted domain is configured for DHCPv4 users.
5.     Configure the domain name generation rules for DHCPv4 users.
ip subscriber dhcp domain include vendor-class [ separator separator ] {  second-vlan [ separator separator ] | string string [ separator separator ] | vlan [ separator separator ] } *
By default, no domain name generation rule is configured for DHCPv4 users.
When the slot hosting the access interface of a user is restarted, the access interface of a user goes down, online detection for a user times out, or an operation is mistakenly performed (for example, the cut access-user command is executed), the session for the user on the interface is deleted. Because some users cannot sense the failure or mistaken operation on the device, the users will not send request packets to come online again. As a result, the access device cannot generate IPoE sessions for these users again. To resolve this issue, IPoE allows abnormally logged out users to come online again through packet initiation.
The device uniquely identifies and records an abnormally logged out IPoE user as follows:
·     For DHCPv4 users and NDRS users, the device records an abnormally logged out IPoE user according to the user MAC address, inner VLAN ID, outer VLAN ID, and access interface.
·     For DHCPv6 users, the device records an abnormally logged out IPoE user according to the user DUID, inner VLAN ID, outer VLAN ID, and access interface.
In the current software version, IPoE allows abnormally logged out DHCP users and ND RS users to come online again through packet initiation.
·     DHCP users—The device records information about abnormally logged out DHCP users. When the device receives IP, ARP, or NS/NA packets from these users, the device restores IPoE sessions for these users according to the recorded information.
·     ND RS users—The device records information about abnormally logged out ND RS users. When the device receives IP or NS/NA packets from these users, the device restores IPoE sessions for these users according to the recorded information.
When the number of abnormally logged out IPoE users recorded on the device reaches the maximum number, a new record will overwrite the oldest one.
This feature is typically used in a scenario where the device is not rebooted.
When an interface receives IP, ARP, or NS/NA packets of a user that match both an IPoE static session and the abnormally logged out user records, the user comes online as a static user.
For an abnormally logged out user to come online again through packet initiation on an interface, follow these guidelines:
·     In the user authentication domain or on the AAA server, you must authorize the corresponding IP address pool or IP address pool group. If you do not authorize the corresponding IP address pool or IP address pool group in the user authentication domain or on the AAA server, make sure the following requirements are met:
¡     When a BRAS acts as a DHCP server, you must configure an IPv4 or IPv6 address on the access interface. Then, the BRAS can allocate an IPv4 address or IPv6 PD prefix to a user by searching for an IP address from the address pool in the same subnet as the access interface IP address.
¡     When a BRAS acts as a DHCP relay agent, you must configure an IPv4 or IPv6 address on the access interface, and use the dhcp relay server-address or ipv6 dhcp relay server-address command to specify a remote DHCP server address. For more information about these commands, see DHCP commands and DHCPv6 commands in BRAS Services Command Reference.
·     In an IPv6 network, when a BRAS acts as a DHCP relay agent, you must use the ipv6 dhcp server allow-hint command on the DHCPv6 server to enable desired address/prefix assignment. For more information about this command, see DHCPv6 commands in BRAS Services Command Reference.
For ND RS users, this feature takes effect on the scenario of one prefix per user instead of the prefix sharing scenario.
When an IPoE Web authentication user comes online again after being abnormally logged out, only the session in the preauthentication domain can be recovered. For the user to come online during the Web authentication phase, the user must undergo the normal Web authentication process.
Any of the following operations can clear the abnormally logged out DHCP user records:
·     Disassociating all BRAS service-enabled interfaces from a VSRP instance by using the undo bras vsrp-instance command in a VSRP network. In this case, abnormally logged out DHCP user records of the VSRP instance are deleted. For more information about the undo bras vsrp-instance command, see VSRP commands in High Availability Command Reference.
This feature is not supported in a VSRP network. For more information about VSRP, see High Availability Configuration Guide.
2.     Configure the maximum number of abnormally logged out IPoE users that can be recorded on the device.
ip subscriber abnormal-logout max-user max-user
By default, the maximum number of abnormally logged out IPoE users that can be recorded on the device is 512000.
3.     Enter interface view.
4.     Enable unclassified-IPv4 packet initiation, ARP packet initiation, or both. Choose the options to configure as needed:
¡     Enable unclassified-IPv4 packet initiation.
ip subscriber initiator unclassified-ip enable [ matching-user ]
By default, unclassified-IPv4 packet initiation is disabled.
¡     Enable ARP packet initiation.
By default, ARP packet initiation is disabled.
5.     Enable unclassified-IPv6 packet initiation, NS/NA packet initiation, or both. Choose the options to configure as needed:
¡     Enable unclassified-IPv6 packet initiation.
ip subscriber initiator unclassified-ipv6 enable [ matching-user ]
By default, unclassified-IPv6 packet initiation is disabled.
¡     Enable NS/NA packet initiation.
ip subscriber initiator nsna enable
By default, NS/NA packet initiation is disabled.
6.     (Optional.) Configure the lease expiration time when the abnormally logged out user logs in again as the time when the user is logged out.
ip subscriber lease-end-time original
By default, the lease expiration time is renewed when the abnormally logged out user logs in again.
When the sessions of online IPoE users are deleted because the system is rebooted, DHCP users will not send DHCP packets to trigger access again because these user cannot sense the reboot. As a result, the access device cannot regenerate DHCP sessions for these users. To solve this problem, you can specify IPoE users to access in loose mode.
With this feature enabled, after the system is rebooted, IPoE users can use IP, ARP, or NS/NA packets to trigger access and generating DHCP sessions within the duration specified by the loose-time argument or all time.
This feature is typically used in a scenario where the device is abnormally rebooted. Within the specified duration, this feature can restore IPoE sessions for abnormally logged out DHCP users.
During the loose access duration after the system is rebooted, the interface processes the packets in the following order when an interface receives IP, ARP, or NS/NA packets from a user:
1.     If the packets match a configured IPoE static session, the user is processed as a static user.
2.     If the packets match a roaming-capable user, the user is processed as a roaming user.
3.     If the packets match abnormally logged out DHCP user records, the interface restores the session information for the abnormally logged out DHCP user according to the recorded information.
4.     The user accesses in loose mode.
IPoE DHCP users can access in loose mode only when all the following conditions exist:
·     The Layer 2 access mode is configured on the access interface.
·     An IPv4 address pool is assigned to users through the authentication domain or AAA server.
For IPoE Web authentication users that access in loose mode, only the sessions in the preauthentication domain can be regenerated. To come online in the Web authentication phase, these users must follow the normal Web authentication procedure.
For IPoE to operate properly when IPoE users access in loose mode, do not configure portal on access interfaces of these IPoE users.
3.     Enable unclassified-IPv4 packet initiation, ARP packet initiation, or both. Choose the options to configure as needed:
4.     Enable unclassified-IPv6 packet initiation, NS/NA packet initiation, or both. Choose the options to configure as needed:
5.     Return to system view.
6.     Configure the loose access feature.
ip subscriber access-trigger loose { loose-time | all-time }
By default, the loose access feature is disabled after the system is rebooted.
In an IPoE DHCP or ND RS user access scenario, users are abnormally logged out and user information is lost if the device or the slot hosting the access interface reboots or the access interface goes down. If the users cannot sense the failure, users will not send DHCP or ND RS packets to trigger coming online again. As a result, the device cannot recover information for abnormally offline users. To resolve the issue, enable automatic IPoE user backup on the device.
With this feature enabled, the device will back up user information after users come online. If a failure occurs and then recovers, the device can recover online information for abnormally offline users according to the backup information.
After the device is rebooted, the IPoE user information saved in the memory will be lost. As a result, the device cannot automatically recover the abnormally logged out users according to the backup information in the memory. In this case, you can enable the device to save the user information in the memory to the specified file and automatically recover the user information in the file to the memory. Depending on the backup and recovery mechanism, automatic backup includes the following types:
·     Manually backup and recovery—Before rebooting the device, you must execute the ip subscriber save-file command to save the backup user information in the memory to a file. After rebooting the device, you must execute the ip subscriber recover-file command to recover backup user information to the memory. Then, the device can recover online user information for abnormally offline users based on the backup user information in the memory.
·     Periodical automatic backup and recovery—With this feature enabled, the device periodically, automatically backs up the user information into the specified backup file in the root directory of the system at the specified interval. After the whole device is rebooted, the device will automatically recover information in the file to the memory. Then, the device can recover abnormally logged out users according to the information in the memory.
Compared to manual backup, periodical automatic backup avoids user information loss when the device randomly fails and manual backup is not performed.
This feature is supported for only DHCP users and ND RS users.
This feature is not applicable in Layer 3 IPoE access mode.
This feature is typically used in a scenario where the device is rebooted as planned or the interface goes down.
For this feature to take effect, you must execute the ip subscriber auto-save max-user command in system view and execute the access-user auto-save enable command (default configuration) in the ISP domain of users.
When the number of IPoE users to be backed up in an ISP domain exceeds the maximum number of IPoE users that can be automatically backed up, the exceeding users are not backed up.
With automatic backup enabled, you can periodically, automatically update the backup file without executing the ip subscriber save-file command. Additionally, to prevent the device from frequently reading and writing the storage medium, as a best practice, set the automatic backup interval as needed.
When an IPoE Web authentication user comes online again after going offline, only the session in the preauthentication domain can be restored for the user. For the user to come online in the Web authentication phase, the user still needs the normal Web authentication process.  For a dual-stack IPoE user, if the ip subscriber authentication-method command with the basic-service-ipv4 keyword is executed on the access interface of the user, the user is recorded as online only after the user comes online through Web authentication in both protocol stacks. If the user does not come online through Web authentication in both protocol stacks, the user will be recorded as in wait-recover state.
2.     Enable automatic user backup in the ISP domain of IPoE users.
Enter ISP domain view.
domain name isp-name
Enable automatic user backup.
By default, automatic user backup is enabled.
3.     Enable automatic IPoE user backup and set the maximum number of users that can be automatically backed up.
ip subscriber auto-save max-user max-user
By default, automatic IPoE user backup is disabled.
4.     Enable automatic IPoE user recovery.
ip subscriber auto-recover enable
By default, automatic IPoE user recovery is disabled.
This command enables the device to automatically recover online information for abnormally offline users according to the backup information in the memory after the failure recovers.
5.     (Optional.) Configure the speed for automatic IPoE user recovery.
ip subscriber auto-recover speed { fast | normal | slow } [ recover-delay delay-time ]
By default, the speed for automatic IPoE user recovery is normal, and the recovery delay is 5 seconds.
The fast mode is resource-intensive. Select the fast mode as needed.
6.     Enter interface view.
7.     (Optional.) Configure the lease expiration time when an auto backed-up user logs in again as the lease expiration time when the user is logged out.
By default, the lease expiration time is renewed when an auto backed-up user logs in again.
8.     Return to system view.
9.     Back up the user information to the specified file. Choose at least one of the following items.
¡     Manually back up data.
Save backup user information in the memory to the specified file.
ip subscriber save-file filename
By default, backup user information in the memory is not saved to the specified file.
ip subscriber recover-file filename
By default, the backup user information in a file is not recovered to the memory.
¡     Configure automatic backup.
Enable periodical automatic IPoE user backup.
ip subscriber auto-save-file file-name interval interval
By default, periodical automatic IPoE user backup is disabled.
(Optional.) Immediately back up the IPoE user information to the file specified for periodical automatic IPoE user backup.
ip subscriber auto-save-file now
If the automatic backup interval specified for periodical automatic IPoE user backup is too long, to avoid user information loss before rebooting the device, you can use this command to immediately back up the user information in the memory to the backup file specified for periodical automatic backup.
As shown in Figure 9, a CPE supports applying for ND prefixes and PD prefixes from the BRAS through the following methods:
·     NDRA—The CPE actively sends an ND RS packet to the BRAS. The BRAS returns an ND prefix to the connected CPE WAN interface through an ND RA packet. The CPE uses the ND prefix to generate a global unicast IPv6 address for the CPE WAN interface. The IPv6 address is used for remotely managing the CPE.
·     IA_PD—The CPE actively sends DHCPv6 requests to the CPE. The BRAS allocates a PD prefix to the CPE through DHCPv6 (IA_PD). The CPE automatically allocates the obtained PD prefix to the attached hosts. These hosts use the PD prefix to generate global unicast IPv6 addresses.
Figure 9 Network diagram for address assignment through NDRA+DHCPv6 (IA_PD)
In the network as shown in Figure 9, if a CEP fails to come online through IA_PD, hosts attached to the CPE cannot generate global unicast IPv6 addresses to access network resources. In this case, even if the CPE comes online through NDRA, the hosts cannot obtain IPv6 addresses. Additionally, the NDRS user entries of the CPE occupy the system resources of the BRAS. As a best practice to resolve this issue, use this command to allow users to come online through ND RS only after they come online through IA_PD in an NDRA+DHCPv6 (IA_PD) network.
For users to successfully come online through ND RS in any other network, do not configure this feature.
3.     Allow users to come online through ND RS only after they come online through IA_PD on the interface.
ip subscriber ndrs wait-delegation-prefix
By default, the users can come online through IA_PD and ND RS in any order.
Application scenarios
When the AAA-authorized ND prefix pool or ND prefix pool group method is used to implement the one prefix per user scenario, each user exclusively occupies one ND prefix. The user IPv6 address is generated by the ND prefix allocated by the BRAS and the endpoint's own interface ID.
To enhance security, some user endpoints will automatically change the interface IDs and inform the BRAS through NS packets. In this scenario, when the BRAS detects a change in the user IPv6 address, the BRAS will refresh the IPv6 address in the user session. By default, the BRAS will not immediately send an accounting-update message to the AAA server to update the accounting information in real time.
By default, the device will send accounting-update messages at the interval configured by the administrator to update user information. To update the accounting information in a timely manner when the user IPv6 address changes and ensure the timeliness and accuracy of the accounting information, you can enable this feature.
Operating mechanism
With this feature enabled, when the BRAS receives NS packets of a user and detects a change in the user IPv6 address, the BRAS will refresh the IPv6 address in the user session and select the user IPv6 address to be added to attribute 158 (Framed-IPv6-Address) based on the following principles:
·     For IPoE ND RS Web authentication, the BRAS fills in attribute 158 with the user IPv6 address at the time of initiating IPv6 Web authentication. No matter how the user IPv6 address changes in the subsequent NS packets, the BRAS always uses the user IPv6 address at the time of initiating IPv6 Web authentication to fill in attribute 158.
·     In cases other than those mentioned above, the BRAS fills attribute 158 with the latest user IPv6 address notified in the NS packets.
Then, the BRAS will immediately send an accounting-update message carrying attribute 158 to the AAA server to update user information and thus update accounting information in real time.
·     This feature is only applicable to the one ND prefix per user scenario.
·     In the shared prefix scenario where multiple users share the same ND prefix, immediate sending of accounting-update messages when the user IPv6 address changes is enabled by default and cannot be disabled by using this command.
·     In the following cases, do not enable this feature as a best practice.
¡     In scenarios where the network capacity is limited or real-time accounting information is not required, as a best practice to avoid generating excessive accounting-update messages that might impact network performance and bandwidth, do not enable this feature.
¡     In scenarios where the network load is heavy or the AAA server's processing capability is limited, as a best practice to avoid frequent accounting-update requests, which might impact network efficiency and stability, do not enable this feature.
2.     Enable immediate sending of accounting-update messages when the user IPv6 address changes.
ip subscriber ipv6-address-change send-accounting-update
By default, when a user IPv6 address changes, immediate sending of accounting-update messages is disabled.
Static user tasks at a glance
To configure static individual users, perform the following tasks:
1.     Configuring a static session initiation method
2.     Configuring static individual sessions
3.     Configuring static leased sessions
4.     (Optional.) Configuring authentication user naming conventions for static users
5.     (Optional.) Configuring passwords for static users
6.     (Optional.) Configuring ISP domains for static users
7.     (Optional.) Configuring session conflict detection
For IP packets to initiate static  sessions, you must enable unclassified-IP packet initiation.
For ARP packets to initiate IPv4 static  sessions, you must enable ARP packet initiation. Disabling ARP packet initiation does not affect online ARP-initiated static  users.
For NS or NA packets to initiate IPv6 static  sessions, you must enable NS/NA packet initiation. Disabling NS/NA packet initiation does not affect online NS/NA-initiated static  users.
The gateway IP address allocated to the static  users must be one of the following IP addresses:
·     The IP address of the access interface.
·     The shared gateway address in the IP address pool, for example, the gateway address specified by using the gateway command in a BAS IP address pool.
NS or NA packets can initiate sessions only in Layer 2 access mode. For a user to initiate a session by using NS/NA packets, execute the ip subscriber initiator nsna enable command to enable NS/NA packet initiation.
If you specify a global static user with an IPv6 delegation prefix, users matching the session can come online only when the interface is configured to operate in Layer 2 access mode and uses the bind authentication mode.
3.     Configure an IPv4 static  session initiation method. Choose the options to configure as needed:
By default, unclassified-IPv4 packet initiation is not enabled.
ip subscriber initiator arp enable
4.     Configure an IPv6 static  session initiation method. Choose the options to configure as needed:
Static individual users initiate IPoE sessions by sending IP, ARP, NS, or NA packets. If an IP or ARP packet matches a manually configured IPoE session, the BRAS authenticates the user and establishes an IPoE session.
Interface-level static individual sessions take precedence over global static individual sessions.
On one interface, a maximum of one static individual session can be configured for one IP address.
A maximum of one global static individual session can be configured for one IP address in the public network or a VPN instance.
Configuration prerequisites
As a best practice to avoid conflict of IP addresses used by dynamic and static users, perform the following tasks:
·     Before configuring an IPv4 static individual session or dual-stack individual session, make sure the following conditions are met:
¡     DHCP has been enabled by using the dhcp enable command.
¡     All IPv4 addresses specified in the static session are excluded from dynamic allocation by using the forbidden-ip command in the IP address pool. For more information about IP address pools and the forbidden-ip and dhcp enable commands, see DHCP configuration in BRAS Services Configuration Guide.
·     Before configuring IPv6 static individual sessions or dual-stack static individual sessions, make sure all IPv6 addresses to be specified in static sessions have already been excluded by using the forbidden-address command from the IPv6 address pool. For more information about the IPv6 address pool and the forbidden-address command, see DHCPv6 configuration in BRAS Services Configuration Guide.
Configuring interface-level static individual sessions
2.     (Optional). Configure the interval at which the device sends online requests to static individual users.
ip subscriber static-session request-online interval seconds
By default, the interval at which the device sends online requests to static individual users is 180 seconds.
4.     Configure IPv4 static individual sessions.
ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] [ vlan vlan-id [ second-vlan vlan-id ] ] [ mac mac-address ] [ domain domain-name ] [ password mac ] [ request-online ] [ description string ] [ gateway ip ipv4-address ] [ vpn-instance vpn-instance-name ] [ keep-online ]
By default, no IPv4 static individual session is configured.
5.     Configure IPv6 static individual sessions.
ip subscriber session static ipv6 start-ipv6-address[ end-ipv6-address ] [ vlan vlan-id [ second-vlan vlan-id ] ] [ mac mac-address ] [ domain domain-name ] [ password mac ] [ request-online ] [ description string ] [ gateway ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ] [ keep-online ]
By default, no IPv6 static individual session is configured.
6.     Configure dual-stack static individual sessions.
ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] ipv6 start-ipv6-address [ end-ipv6-address ] [ vlan vlan-id [ second-vlan vlan-id ] ] [ mac mac-address ] [ domain domain-name ] [ password mac ] [ request-online { ip | ipv6 } ] [ description string ] [ gateway { ip ipv4-address | ipv6 ipv6-address } * ] [ vpn-instance vpn-instance-name ] [ keep-online ]
By default, no dual-stack static individual session is configured.
If you first enable IPoE and then configure dual-stack static users, you must enable IPoE for both IPv4 and IPv6 protocol stacks in order that you can configure dual-stack static users. If you first configure dual-stack static users and then enable IPoE, you must enable IPoE for both IPv4 and IPv6 stacks. Otherwise, you cannot enable IPoE.
Configuring global static individual sessions
2.     Create a static user interface list and enter its view.
static-user interface-list list-id
You need to perform this step only when you use syntax II to configure global static individual users.
3.     Add an interface to the static user interface list.
add interface interface-type interface-number
By default, an interface is not added to a static user interface list.
4.     Configure global IPv4 static individual sessions.
Syntax I:
ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] [ mac mac-address ] [ domain domain-name ] [ username name ] [ password { { ciphertext | plaintext } string | mac } ] [ interface interface-type interface-number [ vlan vlan-id [ second-vlan vlan-id ] ] [ request-online ] ] [ description string ] [ gateway ip ipv4-address ] [ vpn-instance vpn-instance-name ] [ keep-online | support-ds ]
Syntax II:
ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] interface-list list-id [ mac mac-address ] [ domain domain-name ] [ username name ] [ password { { ciphertext | plaintext } string | mac } ] [ description string ] [ vpn-instance vpn-instance-name ] [ keep-online | support-ds ]
By default, no global IPv4 static individual session is configured.
5.     Configure global IPv6 static individual sessions.
Syntax I:
ip subscriber session static ipv6 start-ipv6-address [ end-ipv6-address ] [ delegation-prefix start-ipv6-prefix [ end-ipv6-prefix ] prefix-length ] [ mac mac-address ] [ domain domain-name ] [ username name ] [ password { { ciphertext | plaintext } string | mac } ] [ interface interface-type interface-number [ vlan vlan-id [ second-vlan vlan-id ] ] [ request-online ] ] [ description string ] [ gateway ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ] [ keep-online | support-ds ]
Syntax II:
ip subscriber session static ipv6 start-ipv6-address [ end-ipv6-address ] interface-list list-id  [ delegation-prefix start-ipv6-prefix [ end-ipv6-prefix ] prefix-length ] [ mac mac-address ] [ domain domain-name ] [ username name ] [ password { { ciphertext | plaintext } string | mac } ] [ description string ] [ vpn-instance vpn-instance-name ] [ keep-online | support-ds ]
By default, no global IPv6 static individual session is configured.
6.     Configure global dual-stack static individual sessions.
Syntax I:
ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] ipv6 start-ipv6-address [ end-ipv6-address ] [ delegation-prefix start-ipv6-prefix [ end-ipv6-prefix ] prefix-length ] [ mac mac-address ] [ domain domain-name ] [ username name ] [ password { { ciphertext | plaintext } string | mac } ] [ interface interface-type interface-number [ vlan vlan-id [ second-vlan vlan-id ] ] [ request-online [ ip | ipv6 ] ] [ description string ] [ gateway { ip ipv4-address | ipv6 ipv6-address } * ] [ vpn-instance vpn-instance-name ] [ keep-online ]
Syntax II:
ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] ipv6 start-ipv6-address [ end-ipv6-address ] interface-list list-id [ delegation-prefix start-ipv6-prefix [ end-ipv6-prefix ] prefix-length ] [ mac mac-address ] [ domain domain-name ] [ username name ] [ password { { ciphertext | plaintext } string | mac } ] [ description string ] [ vpn-instance vpn-instance-name ] [ keep-online ]
By default, no global dual-stack static individual session is configured.
When you configure dual-stack static sessions with the interface keyword specified, follow these restrictions and guidelines:
¡     If you first enable IPoE on the interface specified by the interface keyword and then configure dual-stack static users, you must enable IPoE for both IPv4 and IPv6 protocol stacks in order that you can configure dual-stack static users.
¡     If you first configure dual-stack static users and then enable IPoE on the interface specified by the interface keyword, you must enable IPoE for both IPv4 and IPv6 stacks. Otherwise, you cannot enable IPoE.
7.     (Optional). Configure the interval at which the device sends online requests to static individual users.
As shown in Figure 10, in a service provider leased line, the Layer 3 device Device of an enterprise has multiple hosts attached. The uplink port Port A of Device needs a public network IP address assigned by the service provider. The BRAS device needs to perform unified authentication, authorization, and accounting for all hosts attached to Device. In this case, for the administrator to properly allocate and easily maintain public network IP addresses in addition to meeting the leased line service requirements, the administrator also hopes to search for the public network IP addresses allocated to the device of each leased line service on the BRAS. To meet these requirements, you can deploy IPoE static leased lines on the BRAS.
Figure 10 IPoE static leased line application network diagram
A static leased session is a special type of leased line in the following aspects:
·     Independent service attributes—Similar to an interface-leased line, unified authentication, authorization, and accounting are performed for all users on an interface. When a static leased session comes online, packets with any source IP address can pass through the leased interface.
·     Packet initiation—Similar to a global static individual session, with IPoE enabled on an access interface in up state, when IP, ARP, NS, or NA packets pass through the access device, the access interface will try to initiate authentication by using the configured username and password. If a user passes authentication, a static leased session is established. If a user fails to pass authentication, no static leased session is established.
Only one static leased session can be configured on an interface.
Static leased sessions are supported only when the bind authentication mode is used and IPoE operates in Layer 2 access mode.
On the access interface of a static user, you cannot configure an IPv4 address or IPv6 global unicast address. Follow these restrictions and guidelines:
·     For IPv4: Use the shared gateway address in the IP address pool, for example, the gateway address specified by using the gateway command in a BAS IP address pool.
·     For IPv6: Use the ipv6 address auto link-local command to generate a link-local address on the access interface of the static user.
·     Before configuring IPv4 single-stack IPoE static leased sessions or dual-stack IPoE static leased sessions, make sure DHCP has been enabled by using the dhcp enable command, and all IPv4 addresses to be specified in static leased sessions have already been excluded by using the forbidden-ip command from the IP address pool. For more information about the dhcp enable command, IP address pool, and the forbidden-ip command, see DHCP configuration in BRAS Services Configuration Guide.
·     Before configuring IPv6 single-stack IPoE static leased sessions or dual-stack IPoE static leased sessions, make sure all IPv6 addresses to be specified in static leased sessions have already been excluded by using the forbidden-address command from the IPv6 address pool. For more information about the IPv6 address pool and the forbidden-address command, see DHCPv6 configuration in BRAS Services Configuration Guide.
2.     Configure an IPv4 single-stack IPoE static leased session.
ip subscriber session static-leased ip ipv4-address interface interface-type interface-number [ mac mac-address ] [ domain domain-name ] [ password mac ] [ vlan vlan-id [ second-vlan vlan-id ] ] [ request-online ] [ description string ] [ gateway ip ipv4-address ] [ vpn-instance vpn-instance-name ] [ keep-online ]
By default, no IPv4 single-stack IPoE static leased session is configured.
3.     Configure an IPv6 single-stack IPoE static leased session.
ip subscriber session static-leased ipv6 ipv6-address interface interface-type interface-number [ mac mac-address ] [ domain domain-name ] [ password mac ] [ vlan vlan-id [ second-vlan vlan-id ] ] [ request-online ] [ description string ] [ gateway ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ] [ keep-online ]
By default, no IPv6 single-stack IPoE static leased session is configured.
4.     Configure a dual-stack IPoE static leased session.
ip subscriber session static-leased ip ipv4-address ipv6 ipv6-address interface interface-type interface-number [ mac mac-address ] [ domain domain-name ] [ password mac ] [ vlan vlan-id [ second-vlan vlan-id ] ] [ request-online [ ip | ipv6 ] ] [ description string ] [ gateway { ip ipv4-address | ipv6 ipv6-address } * ] [ vpn-instance vpn-instance-name ] [ keep-online ]
By default, no dual-stack IPoE static leased session is configured.
Usernames configured for static users must be the same as those configured on the AAA server.
For bind authentication, a username is selected in the following order for static users until a match is found:
1.     The username parameter specified in the ip subscriber session static command is used as the authentication username. (Applicable only to global static access users.)
2.     Username obtained by using the ip subscriber unclassified-ip username command.
3.     Username configured by using the ip subscriber username command.
4.     Source IP address of packets.
Web authentication and Web MAC authentication methods (preauthentication phase)
For Web authentication and Web MAC authentication in the preauthentication phase, a username is selected in the following order for static users until a match is found:
Web authentication method (postauthentication phase)
For Web authentication in the Web authentication phase, a username is selected in the following order for static users until a match is found:
1.     Username that the user enters when logging in.
3.     Source IP address of packets.
Web MAC authentication method (postauthentication phase)
For Web MAC authentication in the Web authentication phase, a username is selected in the following order for static users until a match is found:
1.     Username configured by using the ip subscriber username command.
2.     Source IP address of packets.
2.     Enter interface view.
3.     Configure an authentication user naming convention for static users.
ip subscriber unclassified-ip username include { nas-port-id [ separator separator ] | port [ separator separator ] | second-vlan [ separator separator ] | slot [ separator separator ] | source-ip [ address-separator address-separator ] [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | string string [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vlan [ separator separator ] } *
The default username is the source IP address of packets sent by users.
4.     Configure an authentication user naming convention for individual IPoE users.
By default, no authentication user naming convention is configured for individual IPoE users.
Passwords configured for static users must be the same as those configured on the AAA server.
For bind authentication, a password is selected in the following order for static users until a match is found:
1.     The password parameter specified in the ip subscriber session static command.
3.     The string vlan.
For Web authentication and Web MAC authentication in the preauthentication phase, a password is selected in the following order for static users until a match is found:
3.     The string vlan.
For Web authentication in the Web authentication phase, a password is selected in the following order for static users until a match is found:
1.     Password that the user enters when logging in.
3.     The string vlan.
For Web MAC authentication in the Web authentication phase, a password is selected in the following order for static users until a match is found:
1.     Password configured by using the ip subscriber password command.
2.     The string vlan.
3.     Set the password for static users.
The default password for a static user is vlan.
If you configure multiple ISP domains for a static user, an ISP domain is selected for the user in the following order until a match is found:
·     When bind authentication is used:
a.     ISP domain specified by using the domain domain-name option in the ip subscriber session static command. If the ISP domain has not been created, the user fails to come online.
b.     Service-specific domain. If the ISP domain has not been created, the user fails to come online.
c.     ISP domain configured by using the ip subscriber unclassified-ip domain command. If the ISP domain has not been created, the user fails to come online.
·     When Web authentication is used, for how the BRAS selects ISP domains for static users, see "Configuring an ISP domain for Web authentication individual users."
For more information about configuring service-specific ISP domains, see "Configuring service-specific ISP domains." For more information about configuring the default system domain, see Security Configuration Guide.
The specified ISP domain must exist on the BRAS.
3.     Configure an ISP domain for unclassified-IP users.
ip subscriber unclassified-ip domain domain-name
By default, no ISP domain is configured for unclassified-IP users.
In a Layer 2 IPoE network, after an IPoE session moves from an interface to another interface, the device still maintains the session information on the original interface. This wastes resources and increases maintenance complexity.
When a user comes online on an interface, this feature uses the user's IP address and MAC address to detect whether the user has come online on other interfaces. If yes, this feature forcibly logs out the user from other interfaces.
This feature takes effect only when IPoE operates in Layer 2 access mode.
This feature takes effect only on IPoE global static users whose sessions do not have the interface keyword specified.
This feature is mutually exclusive with roaming configuration on an interface.
3.     Configure session conflict detection.
ip subscriber session-conflict action offline
By default, session conflict detection is disabled.
Configuring leased users
Leased user tasks at a glance
To configure leased users, perform the following tasks:
1.     Configuring leased users
¡     Configuring an interface-leased user
¡     Configuring subnet-leased users
¡     Configuring family-leased users
¡     Configuring an L2VPN-leased user
Interface-leased users, subnet-leased users, and L2VPN-leased users cannot be configured on the same interface.
2.     Configuring ISP domains for leased users
An interface-leased user represents all access users of the interface. AAA is performed for these users uniformly. With IPoE enabled for both IPv4 and IPv6 protocol stacks on an interface in up state, the session does not need to be initiated by user traffic. The BRAS actively initiates authentication by using the configured username and password. After the authentication succeeds and the leased session is successfully set up for users, traffic of all users on the interface is permitted, and the users share one IPoE session.
In Layer 2 access mode, leased users are considered as main users, while all IP users accessing through the leased user interfaces are considered as subusers. These subusers depend on the leased users (main users) for network access and share the network resources of the main users. This relationship between main users and subusers only exists in Layer 2 access mode. In Layer 3 access mode, all leased users are independent network entities and perform network access individually without the distinction between main users and subusers.
To facilitate management, use the display access-user or cut access-user command to view or delete the subuser information. For more information about viewing and deleting subuser information, see UCM commands in BRAS Services Command Reference.
You can configure up to one interface-leased user on an interface.
Interface-leased subusers support DHCP packet initiation, unclassified-IP packet initiation, and IPv6 ND RS packet initiation.
The interface-leased subusers initiated by IPv6 ND RS packets support only the prefix sharing scenario, and do not support the scenario of one prefix per user.
If you first enable IPoE and then configure interface-leased users, you must enable IPoE for both IPv4 and IPv6 protocol stacks in order that you can configure interface-leased users. If you first configure interface-leased users and then enable IPoE, you must enable IPoE for both IPv4 and IPv6 stacks. Otherwise, you cannot enable IPoE.
3.     Configure an interface-leased user.
ip subscriber interface-leased username name password { ciphertext | plaintext } string [ domain domain-name ]
By default, no interface-leased user is configured.
A subnet-leased user on an interface refers to all IP users in the specified subnet on the interface. AAA is performed for these users uniformly.
You can configure multiple subnet-leased users on an interface. Make sure these subnets do not overlap. Each subnet can be bound to only one subnet-leased user.
In the current software version, subnet-leased subusers support only unclassified-IP packet initiation.
If you first enable IPoE and then configure subnet-leased users, you must enable IPoE for the IPv4 or IPv6 protocol stack in order that you can configure subnet-leased users for the protocol stack. If you first configure subnet-leased users and then enable IPoE, you must enable IPoE for the protocol stack of the subnet-leased users or dual stacks.
For IPv4 subnet-leased users, you must execute the dhcp enable command to enable DHCP. For more information this command, see DHCP commands in BRAS Services Command Reference.
For IPv6 subnet-leased users, you must execute DHCPv6 operation commands (for example, the ipv6 pool command) to enable DHCPv6. For more information this command, see DHCPv6 commands in BRAS Services Command Reference.
1.     ‍Enter system view.
3.     Configure an IPv4 subnet-leased user.
ip subscriber subnet-leased ip ipv4-address { mask | mask-length } username name password { ciphertext | plaintext } string [ domain domain-name ] [ vpn-instance vpn-instance-name ]
By default, no IPv4 subnet-leased user is configured.
4.     Configure an IPv6 subnet-leased user.
ip subscriber subnet-leased ipv6 ipv6-address prefix-length username name password { ciphertext | plaintext } string [ domain domain-name ] [ vpn-instance vpn-instance-name ]
By default, no IPv6 subnet-leased user is configured.
An IPoE family-leased user represents all users accessing the same interface and VLAN. With IPoE enabled for both IPv4 and IPv6 protocol stacks on an access interface in up state, the access interface will actively try to initiate authentication by using the configured username and password. After the user successfully passes authentication, a family-leased session is set up. The traffic of all users accessing the same interface and VLAN is permitted to pass through, and the traffic shares a single IPoE session. These users are authorized and accounted based on the interface.
In Layer 2 access mode, leased users are considered as main users, while all IP users accessing through the leased user interfaces are considered as subusers. These subusers depend on the leased users (main users) for network access and share the network resources of the main users. This relationship between main users and subusers only exists in Layer 2 access mode. In Layer 3 access mode, family-leased users are not supported.
To facilitate management, use the display access-user and cut access-user commands to view or delete information of the specific subusers. For more information about the commands used to view and delete the specified subusers, see UCM commands in BRAS Services Command Reference.
·     In the current software version, subusers of family-leased users can initiate the online process through ARP packets, unclassified-IP packets, and NS/NA packets.
·     If you enable IPoE before configuring family-leased users, you must also enable IPoE for both the IPv4 and IPv6 protocol stacks. If you do not do that, the configured family-leased users cannot come online. Similarly, if you configure family-leased users before enabling IPoE, you must also enable IPoE for both the IPv4 and IPv6 protocol stacks. If you do not do that, the configured family-leased users cannot come online.
·     Each interface can be configured with only one IPoE family-leased user. Additionally, you cannot change the username or password of the configured IPoE family-leased user by repeatedly executing this command. To modify these parameters, first remove the configured IPoE family-leased user by executing the undo ip subscriber family-leased command and then execute the ip subscriber family-leased command again.
·     On the same interface, the IPoE family-leased user is mutually exclusive with the following users: interface-leased, subnet-leased, L2VPN-leased, unclassified-IP, and static. The system does not automatically check for function conflicts. Make sure normal access and use for all types of users, and avoid configuration errors that lead to function anomalies.
·     To avoid function conflicts, do not specify the following interfaces as the access interfaces of family-leased users: interfaces already added to the static user interface list or interfaces specified in the global static session configuration. If an interface is specified as a family-leased user access interface, do not add it to the static user interface list or specify it in the global static session configuration. The system does not automatically check for function conflicts. Make sure the preceding requirements are met, and avoid configuration errors that lead to function anomalies.
·     For family-leased users, specify the associated VPN in the home broadband leased line configuration. Do not specify the VPN through AAA authorization or interface-VPN binding. If you do that, family-leased users might fail to successfully come online.
·     This feature is not supported on VSRP networks.
·     For network isolation between different homes, make sure the VPN of each family-leased user is unique. If you cannot do that, function anomalies will occur.
2.     Configure a family-leased user.
ip subscriber family-leased interface interface-type interface-number [ vlan vlan-id [ second-vlan vlan-id ] ] username name password { ciphertext | plaintext } string gateway ipv4 { ipv4-address { mask | mask-length } vpn-instance vpn-instance-name } [ access-limit limit-number ]
By default, family-leased users are not configured.
An L2VPN-leased user represents hosts that rent the same interface on an L2VPN network.
You can configure one L2VPN-leased user on an interface on an L2VPN network. An L2VPN-leased user carries IPv4 and IPv6 traffic from hosts. On a Layer 3 Ethernet or aggregate subinterface, the L2VPN-leased user is mutually exclusive with the packet statistics collection feature. For more information about packet statistics collection on Ethernet subinterfaces, see Ethernet interface configuration in Interface Configuration Guide. For more information about packet statistics collection on Layer 3 aggregate subinterfaces, see Ethernet link aggregation configuration in Layer 2—LAN Switching Configuration Guide.
If you first enable IPoE and then configure L2VPN-leased users, you must enable IPoE for both IPv4 and IPv6 protocol stacks in order that you can configure L2VPN-leased users. If you first configure L2VPN-leased users and then enable IPoE, you must enable IPoE for both IPv4 and IPv6 stacks. Otherwise, you cannot enable IPoE.
3.     Configure an L2VPN-leased user.
ip subscriber l2vpn-leased username name password { ciphertext | plaintext } string [ domain domain-name ]
By default, no L2VPN-leased user is configured.
An ISP domain is selected for an IPoE leased user in the following order until a match is found:
1.     ISP domain specified for the leased user by using the specific command:
¡     For an interface-leased user, ISP domain specified by using the domain domain-name option in the ip subscriber interface-leased command. If the ISP domain has not been created, the user fails to come online.
¡     For a subnet-leased user, ISP domain specified by using the domain domain-name option in the ip subscriber subnet-leased command. If the ISP domain has not been created, the user fails to come online.
¡     For an L2VPN-leased user, ISP domain specified by using the domain domain-name option in the ip subscriber l2vpn-leased command. If the ISP domain has not been created, the user fails to come online.
2.     Service-specific ISP domain. If the ISP domain has not been created, the user fails to come online. (Applicable to only family-leased users.)
3.     ISP domain specified by using the ip subscriber unclassified-ip domain command. (Applicable to only interface-leased users, subnet-leased users, and family-leased users.) If the ISP domain has not been created, the user fails to come online.
4.     ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
3.     Configure a domain collectively for leased users.
Configuring Web authentication advanced features
Web authentication advanced feature tasks at a glance
To configure Web authentication individual users, perform the following tasks:
1.     (Optional.) Configuring an ISP domain for Web authentication individual users
2.     (Optional.) Configuring HTTP packet fast reply
3.     (Optional.) Configuring an SSL server policy for HTTPS redirection
4.     (Optional.) Configuring URL redirection
5.     (Optional.) Configuring captive-bypass Web authentication and captive-bypass Web authentication optimization
6.     (Optional.) Configuring Web authentication fail-permit
7.     (Optional.) Configuring the URL allowlist for Web authentication
8.     (Optional.) Configuring authentication user naming conventions for dynamic individual users
9.     (Optional.) Configuring passwords for dynamic individual users
10.     (Optional.) Setting the dynamic individual session limit
11.     (Optional.) Configuring trusted DHCP options for DHCP users
12.     (Optional.) Allowing abnormally logged out IPoE users to come online again through packet initiation
13.     (Optional.) Allowing DHCP users to access in loose mode
14.     (Optional.) Configuring IPoE web support for HTTP/HTTPS attack defense‌
IPoE Web authentication process includes preauthentication and Web authentication phases. Web authentication is triggered when users pass preauthentication. The preauthenticated users obtain IP addresses (applicable to only DHCP users) and authorization attributes configured for the preauthentication domain. Web authentication is triggered when preauthenticated users access an unauthorized HTTP/HTTPS address.
The BRAS selects an ISP domain for Web authentication in the following order until a match is found:
Preauthentication phase (applicable to IPoE static individual users)
1.     Authentication domain configured by using the ip subscriber session static command. If the ISP domain has not been created, the user fails to come online.
2.     Preauthentication domain configured by using the ip subscriber pre-auth domain command. If the ISP domain has not been created, the user fails to come online.
3.     Service-specific domain. If the ISP domain has not been created, the user fails to come online.
4.     Domain configured by using the ip subscriber unclassified-ip domain command. If the ISP domain has not been created, the user fails to come online.
a.     ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
Preauthentication phase (applicable to IPoE DHCP dynamic individual users)
1.     Domain information obtained from the option. For how domain information is obtained from the option, see how domain information is obtained from the option in the bind authentication method. If the ISP domain has not been created, proceed with the next step.
2.     Service-specific domain. If the ISP domain has not been created, the user fails to come online.
3.     Preauthentication domain configured by using the ip subscriber pre-auth domain command. If the ISP domain has not been created, the user fails to come online.
Preauthentication phase (applicable to IPv6 ND RS dynamic individual users)
1.     Preauthentication domain configured by using the ip subscriber pre-auth domain command. If the ISP domain has not been created, the user fails to come online.
Postauthentication phase (Web authentication method)
When Web authentication is used, if multiple types of ISP domains are configured, an ISP domain is selected in the following order during the Web authentication phase:
1.     Domain carried in the username is used. If the domain has not been created, the user fails to come online.
2.     Web authentication domain specified by using the ip subscriber web-auth domain command. If the specified domain has not been created, the user fails to come online.
3.     ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
Postauthentication phase (Web MAC authentication method)
When Web MAC authentication is used, if multiple types of ISP domains are configured, an ISP domain is selected in the following order during the Web authentication phase:
1.     Domain carried in the username. If the domain has not been created, the user fails to come online.
2.     MAC authentication domain specified by using the ip subscriber mac-auth domain command. If the specified domain has not been created, the user fails to come online. (Applicable to only transparent MAC authentication.)
3.     Web authentication domain specified by using the ip subscriber web-auth domain command. If the specified domain has not been created, the user fails to come online
3.     Configure a preauthentication ISP domain.
ip subscriber pre-auth domain domain-name
By default, no preauthentication ISP domain is configured.
4.     Configure the domain for MAC authentication.
ip subscriber mac-auth domain domain-name
By default, no domain is configured for MAC authentication.
The domain for MAC authentication is used for transparent MAC authentication during the Web authentication phase for only individual users using Web MAC authentication.
5.     Configure the domain for Web authentication.
ip subscriber web-auth domain domain-name
By default, no domain is configured for Web authentication.
The ISP domain configured for Web authentication applies to only individual users using Web authentication and Web MAC authentication during the Web authentication phase.
When a user using a browser to perform Web authentication does not access the portal Web server, the access device will redirect the HTTP requests to the CPU. Then, the CPU pushes the Web authentication page of the portal Web server to the user. If an attacker sends a large number of HTTP requests to the device, the device suffers DoS attacks.
After the HTTP packet fast reply feature is enabled, the device will preferentially use the hardware to identify HTTP requests and automatically respond with HTTP replies. Additionally, this feature uses a URL with status code 302 to push the Web authentication page to users. In this way, this feature reduces the CPU workload and prevents DoS attacks. However, if the hardware cannot use a URL with status code 302 to respond to the user's HTTP requests due to reasons such as the URL is too long, the device will redirect the HTTP requests to the CPU for processing. In this case, depending on whether the redirect move-temporarily enable command is executed in the user authentication domain, the device will work differently as follows:
·     If the redirect move-temporarily enable command is executed in the user authentication domain, the CPU will use an URL with status code  302 to push the Web authentication page to the user.
·     If the redirect move-temporarily enable command is not executed in the user authentication domain, the CPU will use a URL with status code 200 to push the Web authentication page to the user.
This processing method improves the device's adaptability and reliability, and also ensures the user's network usage experience.
For more information about the redirect move-temporarily enable command, see BRAS Services Command Reference.
The maximum URL length in fast HTTP replies is 178 bytes.
This feature does not immediately take effect on users that have passed preauthentication and come online before this feature is enabled. This feature takes effect only when these users go offline and come online again after passing preauthentication or return to the preauthentication domain after passing Web authentication.
With both this feature and transparent authentication configured, a user first attempts to come online through transparent authentication. The hardware responds and pushes the Web authentication page if the user fails to come online through transparent authentication for one of the following reasons:
·     Transparent authentication binding query request times out.
·     The portal server returns a message showing that the user is not bound.
·     The AAA server returns authentication failure.
3.     Enable HTTP packet fast reply.
ip subscriber http-fast-reply enable
By default, HTTP packet fast reply is disabled.
When a DHCP user uses HTTPS packets to trigger Web authentication, you can use the default SSL server policy or customize an SSL server policy.
1.     Configure a PKI policy, and successfully apply for or import local certificates and CA certificates. For more information, see PKI configuration in Security Configuration Guide.
2.     Configure an SSL server policy named https_redirect, and specify the policy to use an existing PKI domain.
You must install a certificate that the browser trusts. Otherwise, the browser displays the alarm that "The used certificate is insecure" when you set up an SSL connection to the device on the browser. For more information, see SSL configuration in Security Configuration Guide.
This feature pushes authentication pages to users based on the user-requested URL or User-Agent information.
A URL redirection match rule matches HTTP or HTTPS requests by user-requested URL or User-Agent information, and redirects the matching HTTP or HTTPS requests to the specified redirection URL.
For a user to successfully access a redirection URL, configure a preauthentication domain user group ACL to allow HTTP or HTTPS requests destined for the redirection URL to pass.
You can configure the web-server { url | ipv6-url } command in an ISP domain and the ip subscriber if-match command for URL redirection. The web-server { url | ipv6-url } command redirects all HTTP or HTTPS requests from unauthenticated users to the Web server for authentication. The ip subscriber if-match command allows for flexible URL redirection by redirecting specific HTTP or HTTPS requests to specific redirection URLs. If both commands are executed, the ip subscriber if-match command takes priority to perform URL redirection.
1.     Configure an ACL to permit HTTP or HTTPS packets destined for the redirection URL.
For more information about configuring ACLs, see ACL and QoS Configuration Guide.
2.     Enter system view.
4.     Configure a URL redirection match rule.
ip subscriber if-match { original-url url-string redirect-url url-string [ url-param-encryption { aes | des } key { cipher | simple } string ] | user-agent user-agent redirect-url url-string }
By default, no URL redirection rule is configured.
·     Automatically opening the Web authentication page
The feature of automatically opening the Web authentication page on the user endpoint is implemented as follows. After an endpoint is associated with an SSID, it actively sends an HTTP probe request packet to identify whether the destination address (usually a fixed URL, which varies by endpoint or app) is reachable and whether the response content meets expectations. According to the detection result, the endpoint identifies whether the accessed network requires Web authentication.
¡     If the destination address is reachable and the response content meets expectations, the network is reachable and no Web authentication is required.
¡     If the destination address is not reachable or the response content does not meet expectations, Web authentication is required. The endpoint will call the browser to send an HTTP request again, and the device will intercept this request and redirect it to automatically open the Web authentication page on the endpoint.
The Web authentication page might fail to automatically open because of the following reasons:
¡     The endpoint does not actively send a probe request packet.
¡     The endpoint can initiate a probe request packet, but it might fail to call the browser and send a request again due to certain installed apps. As a result, the Web authentication page fails to automatically open.
¡     For most Android phones, the feature of automatically opening the Web authentication page must be triggered by manually clicking the SSID interface.
·     Captive-bypass Web authentication
By default, in a wireless access scenario, when a user endpoint connects to a network with IPoE Web authentication enabled, the device will actively push the Web authentication page to the user endpoint. In this way, the user endpoint can automatically open the Web authentication page. However, this automatic page opening method requires the device to intercept the probe packets from endpoints, which might cause some endpoints to automatically disconnect from the Wi-Fi network if they cannot detect the network. In this case, the device cannot push the Web authentication page to the user because the Wi-Fi connection has been disconnected. As a result, the authentication process cannot be completed.
To address this issue, you can enable IPoE captive-bypass Web authentication, which allows users to trigger the device to push the Web authentication page by accessing the Internet by using a browser to complete the authentication.
Enabling captive-bypass Web authentication ensures that the device does not intercept the probe request packets from endpoints and the endpoints maintain their Wi-Fi connections. When a user connects to the network, the device does not immediately push the Web authentication page to the user. The page is pushed to the user only when the user attempts to access the Internet by using a browser. The Web authentication page requires the user to enter the username and password to complete the authentication process.
·     Captive-bypass Web authentication optimization (applicable only to iOS systems)
By default, Apple endpoints use their own Captive Network Assistant (CNA) tool to detect http://captive.apple.com. If the network is reachable, the endpoint will receive a Success response. If not, the browser will be called again to detect the network and implement the function of automatically opening the Web authentication page.
However, the mechanism for automatically opening the Web authentication page on an endpoint might fail in the following conditions:
¡     If the page uses HTTPS and the certificate is not issued by a third-party organization trusted by the endpoint, the mechanism for automatically opening the Web authentication page will fail.
¡     The apps installed on an Apple endpoint (such as Wi-Fi assistant) have a significant impact on the detection mechanism of the endpoint. They might cause the automatic detection feature to fail or cause the Wi-Fi signal on the Apple endpoint to fail to be turned on and the Wi-Fi connection to disconnect.
¡     If the user directly presses the home button to return to the desktop before the detection is completed, the Wi-Fi signal on the Apple endpoint might fail to be turned on, and the Wi-Fi connection might be disconnected.
To address the preceding issues, you can enable the captive-bypass Web authentication optimization for IPoE.
Enabling the IPoE captive-bypass Web authentication optimization feature specifically benefits iOS users. When the device receives a probe request packet from an Apple endpoint, it will construct a Success response, making the Apple endpoint consider the network is connected. Then, the Wi-Fi signal will be turned on and the Web authentication page will be automatically opened.
In the scenario of IPoE captive-bypass Web authentication or captive-bypass Web authentication optimization, do not execute the ip subscriber http-fast-reply enable command to enable the HTTP packet fast reply feature. If you do that, the IPoE captive-bypass Web authentication or captive-bypass Web authentication optimization feature will not work.
·     IPoE captive-bypass Web authentication takes effect on both iOS and Android users.
·     IPoE captive-bypass Web authentication optimization takes effect only on iOS users and do not take effect on Android users.
·     The effects of these commands are as follows:
¡     If the ip subscriber captive-bypass enable command is executed:
-     An Apple endpoint does not automatically open the Web authentication page. An Apple endpoint might disconnect from Wi-Fi when the home button is pressed depending on the software version of the endpoint.
-     Android endpoints do not automatically open the Web authentication page.
¡     If the ip subscriber captive-bypass enable optimize command is executed:
-     Apple endpoints automatically open the Web authentication page and do not disconnect from Wi-Fi when the home button is pressed.
¡     (Recommend.) If the ip subscriber captive-bypass enable ios optimize command is executed:
-     Android endpoints automatically open the Web authentication page. (Default.)
¡     If the ip subscriber captive-bypass enable ios command is executed:
¡     Executing the ip subscriber captive-bypass enable android command has the same effect as executing the ip subscriber captive-bypass enable android optimize command.
-     An Apple endpoint automatically opens the Web authentication page. An Apple endpoint might disconnect from Wi-Fi when the home button is pressed depending on the software version of the endpoint. (Default.)
3.     Enable captive-bypass Web authentication or captive-bypass Web authentication optimization for IPoE.
ip subscriber captive-bypass enable [ android | ios ] [ optimize ]
By default, both captive-bypass Web authentication and captive-bypass Web authentication optimization are disabled for IPoE.
With this feature configured, when the device detects that the Web authentication server or AAA server is unreachable, the device allows users to access network resources without Web authentication. You can implement Web authentication fail-permit by associating a fail-permit user group with a track entry.
By default, the Web authentication users that come online in the preauthentication domain belong to the user group authorized by AAA or authorized in the ISP domain when the users come online. After a fail-permit user group is associated with a track entry, the following rules apply:
·     When the status of the track entry becomes Negative, the access device moves all online users in the current preauthentication domain from the authorized user group to the fail-permit user group. Then, the users can access network resources according to the privilege of the fail-permit user group.
·     When the status of the track entry becomes Positive, the access device will move all online users in the current preauthentication domain back to the authorized user group. Then, the users can access network resources only after passing Web authentication.
This command takes effect only on users in the IPoE Web preauthentication domain.
1.     Configure a track entry.
Track can monitor the server status in various method, such as NQA and BFD. For more information, see track configuration in High Availability Configuration Guide.
2.     Configure the privilege for a fail-permit user group.
For information on how to configure a user group, see AAA configuration in BRAS Services Configuration Guide.
3.     Enter system view.
4.     Enter interface view.
5.     Associate the fail-permit user group with the track entry.
ip subscriber pre-auth track track-entry-number fail-permit user-group group-name
By default, the fail-permit user group is not associated with a track entry.
With this feature configured, the unauthenticated or defaulting users can still access the network resource list.
For example, on a campus network that uses IPoE Web authentication, you can add the internal websites of the campus and the payment page to the URL allowlist.
·     When a student does not pass IPoE Web authentication or has passed IPoE Web authentication but has owed fees, the student is still allowed to access the internal websites of the campus. In this way, the student can still learn and communicate normally.
·     When a student owes fees, the student can still access the payment page of the service provider and pay the charge on the payment page pushed by the service provider. In this way, the student can quickly restore access to Internet.
Depending on the application scenarios, the URL allowlists for IPoE Web authentication include IP-based URL allowlists and domain name-based URL allowlists.
The URL allowlists for IPoE Web authentication are implemented through object groups. For more information about object groups, see object group configuration in Security Configuration Guide.
1.     Configure an object group
This configuration is used to define the URL allowlist, including the internal websites of the campus and the payment page.
a.     Enter system view.
b.     Create an object group.
IPv4:
object-group ip address object-group-name
By default, the system default IPv4 address object group named any exists.
IPv6:
Create an IPv6 address object group, and enter its view.
object-group ipv6 address object-group-name
By default, the system default IPv6 address object group named any exists.
c.     Configure the URL allowlist. Choose at least one of the following items.
-     Configure an IP address-based URL allowlist.
network host address ip-address
For more information about this command, see object group commands in Security Command Reference.
-     Configure a domain name-based URL allowlist.
network host name host-name
2.     Configure user groups
This configuration is used to authorize users in different application scenarios. (Details not shown.)
3.     Configure and apply a QoS policy
a.     Configure an ACL.
This ACL is used to match packets that users in the specified user group use to access the addresses on the allowlist.
b.     Define a class to match the service flows of users. Use the ACL configured in the step above as the match criterion in the class. Configure a traffic behavior, and specify the actions to take on users before passing authentication and defaulting users.
c.     Create a QoS policy, and associate the traffic class with the traffic behavior.
d.     Apply the QoS policy to the inbound and outbound directions of user traffic.
(Details not shown.) For more information about ACL and QoS commands, see QoS policy configuration in ACL and QoS Configuration Guide.
When various tool software products (for example, Baidu cloud) are installed on a client, each tool software product will periodically send HTTP/HTTPS requests to a fixed destination IP address. HTTP/HTTPS requests generated by these tool software products will result in high resource usage before users perform IPoE Web authentication. As a result, the authentication efficiency of users is affected, and the authentication might even fail. To resolve this issue, you can enable destination IP-based IPoE HTTP/HTTPS attack defense. Use the attack defense function in the following scenarios:
·     To limit the HTTP/HTTPS requests frequently initiated and reduce the resource usage of these massive HTTP/HTTPS packets, use the ip subscriber http-defense destination-ip enable action block command to generate blocked entries when the blocking conditions are met and block HTTP/HTTPS requests sent to the specified destination IP addresses based on the blocked entries.
·     Blocking HTTP/HTTPS requests will affect users’ access to the specified destination IP addresses. To only detect the HTTP/HTTPS requests frequently initiated to the specified destination IP addresses rather than block them, use the ip subscriber http-defense destination-ip enable action logging command to output attack logs and generate attack defense blocked entries that are used to view blocked users but will not block attack packets when the blocking conditions are met. The generated attack log messages by the device will be sent to the information center. The information center configuration specifies the log message sending rule and destination. For more information about the information center, see Network Management and Monitoring Configuration Guide.
After you enable destination IP-based IPoE HTTP/HTTPS attack defense, the device will monitor and collect statistics of HTTP/HTTPS packets that IPoE Web preauthentication users send to any destination IP address. If the total number of HTTP/HTTPS packets sent to a destination IP address within a statistics collection interval exceeds the specified threshold, the device will generate blocked entries to block attack packets or output attack logs as configured in the ip subscriber http-defense destination-ip enable command.
During the packet blocking period, the device directly drops packets destined to the specified destination IP address to reduce the impact on the user onboarding speed. If the device receives packets sent to the destination IP address again after the blocking period expires, the device monitors and collects statistics of packets again.
In the current software version, the IPoE HTTP/HTTPS attack defense function takes effect only on HTTP/HTTPS packets sent by IPoE Web users that have come online in the preauthentication domain.
If the administrator does not want to collect attack defense statistics of HTTP/HTTPS packets sent by users to the specified destination IP addresses and wants to unconditionally push the Web authentication page to users accessing these destination IP addresses, you can use the ip subscriber http-defense free-destination-ip command to add these destination IP addresses to the allowlist.
2.     Enable destination IP-based IPoE HTTP/HTTPS attack defense.
ip subscriber http-defense destination-ip enable [ action { block [ period blocking-period ] | logging } ]
By default, destination IP-based IPoE HTTP/HTTPS attack defense is disabled.
3.     (Optional.) Configure the threshold for IPoE HTTP/HTTPS attack defense.
ip subscriber http-defense destination-ip threshold packet-number interval interval
By default, when the total number of HTTP/HTTPS packets sent to the same destination IP address within 300 seconds reaches 6000, the attack defense threshold is triggered.
4.     (Optional.) Configure allowlist addresses for IPoE HTTP/HTTPS attack defense.
ip subscriber http-defense free-destination-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
By default, no allowlist addresses are configured for IPoE HTTP/HTTPS attack defense.
Execute this command multiple times to add multiple destination IP addresses to the allowlist.
Configuring IPoE quick Web authentication
When H3C IMC runs on the portal authentication server, the IP address specified on the server must be the same as the BAS-IP attribute carried in the portal packets. You can configure the BAS-IP attribute carried in the portal packets by using the portal bas-ip command.
Configuring transparent MAC-trigger authentication
Configuring the MAC binding server
For more information about the MAC binding server authentication, see "Configuring portal."
Specifying the MAC binding server on an interface
3.     Specify a MAC binding server on the access interface of IPoE Web authentication users.
portal apply mac-trigger-server server-name
By default, no MAC binding server is specified on the access interface of IPoE Web authentication users.
For more information about this command, see portal commands in IPoE Command Reference.
Configuring transparent MAC authentication
The AAA server used for transparent MAC authentication must support MAC binding.
·     Configure common transparent MAC authentication.
Configure IPoE to user Web MAC authentication.
·     Configure re-DHCP transparent MAC authentication.
You can configure IPoE to use Web authentication or Web MAC authentication. As a best practice, configure IPoE to use Web authentication.
For more information, see "Configuring the authentication method."
Configuring the advanced 802.1X authentication features
Configuring the static 802.1X user authentication feature
Application scenarios
By default, in the IPoE 802.1X authentication scenario, IPoE 802.1X authentication supports unclassified-IP users, DHCP users, IPv6 ND RS users, and global static users. For a user configured with a static IP address to come online through 802.1X authentication, you must configure the corresponding static IPoE user access for the static IP address of the user on the BRAS.
For a user configured with a static IP address to come online through 802.1X authentication without configuring the corresponding static IPoE user access for the user on the BRAS, enable this feature.
Operating mechanism
With this feature enabled, when the 802.1X client of a user passes authentication and comes online, the BRAS will generate a temporary session entry according to the MAC+VLAN information (without IP information) of the user. When the BRAS receives the ARP packets, unclassified-IP packets, and NS/NA packets of the user, the following rules apply:
·     If a temporary session entry can be obtained for the user, IPoE uses the 802.1X authentication result to make the user directly come online in the postauthentication domain. After the user comes online in the postauthentication domain, the BRAS will replace the temporary session entry with the formal session entry of the user. Then, the BRAS processes packets of the user based on the formal session entry. In this case, the formal session entry records the 802.1X user information (including 802.1X username, authentication domain, and authorized attributes) of the user.
·     If a temporary session entry cannot be obtained for the user, the packets are dropped.
To deploy both dynamic 802.1X users and static 802.1X users on a live network, as a best practice, deploy them on different interfaces. For example, deploy them on different subinterfaces of the same main interface.
Both 802.1X authentication and IPoE static user access are configured on an interface, and the following functions are enabled:
·     For 802.1X authentication access, the static 802.1X user authentication feature is enabled.
·     For IPoE static user access, unclassified-IP packet initiation is enabled with the matching-user keyword specified.
If the preceding conditions are met, when the packets of a user received by the BRAS match both the 802.1X temporary session entry and the IPoE static user session, the user comes online as an IPoE static user.
With this feature enabled in the IPoE 802.1X authentication scenario, when the 802.1X client of a user passes authentication and comes online, only if the ARP packets, unclassified-IP packets, or NS/NA packets from the user can match the temporary session entry, the user can directly come online in the postauthentication domain, and you do not need to execute one of the following commands to enable ARP packet initiation, unclassified-IP packet initiation, or NS/NA packet initiation.
·     ip subscriber initiator unclassified-ip enable
·     ip subscriber initiator unclassified-ipv6 enable
·     ip subscriber initiator arp enable
·     ip subscriber initiator nsna enable
When you configure the static 802.1X user authentication feature, follow these restrictions and guidelines:
·     On an interface, static 802.1X user authentication is mutually exclusive with Layer 3 IPoE access mode, IPoE interface-leased users, IPoE subnet-leased users, and IPoE L2VPN-leased users.
·     You can configure static 802.1X user authentication on an interface only when the interface operates in Layer 2 IPoE access mode.
3.     Enable static 802.1X user authentication.
ip subscriber static-dot1x-user enable
By default, static 802.1X user authentication is disabled.
Configuring the device to retrigger 802.1X authentication based on the specified type of packets sent by a user
By default, in a scenario where 802.1X authentication is prioritized in loose mode, the BRAS will not immediately trigger the IPoE authentication process when it receives ARP, ND, or DHCP packets from an endpoint. Instead, the BRAS will cache the packets and actively send an EAP request (EAP-Request/Identity packet) to the endpoint to trigger 802.1X authentication. If no reply is received from the endpoint within the specified time (set by using the dot1x timer tx-period command), the BRAS will retransmit the EAP request packet to the endpoint. If the number of EAP request attempts reaches the limit (set by the dot1x retry command) and the BRAS still does not receive a reply from the endpoint, the BRAS will stop sending authentication requests. At this point, the BRAS determines that the endpoint has failed to come online through 802.1X authentication, triggers the IPoE authentication process based on cached packets, and allows the user to come online in the preauthentication domain.
After the user comes online in the preauthentication domain, the BRAS will no longer send EAP-Request/Identity packets to the endpoint when receiving ARP, ND, or DHCP packets from the endpoint.
Some endpoints (such as Apple endpoints) must receive the EAP-Request/Identity packets in order to pop up the 802.1X authentication page. If the EAP-Request/Identity packets sent by the BRAS to such endpoints are lost due to poor network quality, these endpoints fail to receive EAP-Request/Identity packets.  In this case, these endpoints cannot come online through 802.1X authentication even if you plug/unplug the network cables or restart the network cards for the endpoints.
To resolve this issue, configure this feature to allow the specified types of packets to retrigger 802.1X authentication before an endpoint successfully comes online through 802.1X authentication.
Operating mechanism
With this feature configured, for a user that has already come online in the preauthentication domain, the BRAS will actively retrigger 802.1X authentication by sending an EAP-Request/Identity packet to the user endpoint when the BRAS receives a specific type of packets (specified by the ip subscriber authentication dot1x-retrigger command) from the user endpoint. This feature ensures that the endpoint can receive and respond to the EAP-Request/Identity packets, pop up the 802.1X authentication page, complete 802.1X authentication, and come online. After the 802.1X client comes online, IPoE uses the 802.1X authentication result to have the user come online directly in the postauthentication domain. In this case, the recorded user information is the 802.1X user information, including the 802.1X username, authentication domain, and authorized attributes.
·     This feature takes effect only when 802.1X authentication is prioritized in loose mode.
·     If a user has already come online in the postauthentication domain before coming online through 802.1X authentication, this feature does not take effect.
·     For an Apple endpoint, suppose the endpoint receives an EAP Request/Identity packet from the BRAS and pops up the 802.1X authentication window, and then you close the window without entering a username/password for authentication. In this case, the 802.1X authentication window will not pop up again even if the endpoint receives EAP Request/Identity packets from the BRAS later again. To resolve this issue, plug/unplug or restart the network card for the Apple endpoint.
3.     Configure the BRAS to retrigger 802.1X authentication based on the specified type of packets sent by an IPoE user when the IPoE user fails to come online through 802.1X authentication.
ip subscriber authentication dot1x-retrigger { arp | dhcpv4 | dhcpv6 | nd } *
By default, the BRAS does not retrigger 802.1X authentication based on any type of packets sent by an IPoE user when the IPoE user fails to come online through 802.1X authentication.
Configuring the suppression interval for retriggering 802.1X authentication based on ARP and ND packets
When a large number of ARP and ND packets exist in the network and the ip subscriber authentication dot1x-retrigger command is executed, a network attack might occur if the BRAS sends EAP-Request/Identity packets to endpoints each time the BRAS receives ARP or ND packets. For security purposes, adjust the suppression interval for retriggering 802.1X authentication based on ARP and ND packets on the BRAS according to the actual network requirements.
Operating mechanism
After you configure the suppression interval, whenever the BRAS sends an EAP-Request/Identity packet to an endpoint, the BRAS will record the time (T1) of sending the packet. When the BRAS receives ARP or ND packets from the endpoint, the BRAS will record the time (T2) of receiving ARP or ND packets.
·     If T2-T1≥interval, the BRAS will send an EAP-Request/Identity packet to the endpoint to retrigger 802.1X authentication.
·     If T2-T1 < interval, the BRAS will not send an EAP-Request/Identity packet to the endpoint.
·     For ARP packets and ND packets, the BRAS separately calculates the suppression intervals, and the two intervals do not affect each other.
·     For NS packets, NA packets, and RS packets among the ND packets, the BRAS calculates the suppression interval uniformly. For example, suppose the BRAS sends an EAP-Request/Identity packet at time T1 to the endpoint based on the received NA packets, and the BRAS receives an RS packet at time T2. The BRAS will decide whether to send an EAP-Request/Identity packet to the endpoint again based on the difference between T2 and T1 and the value for the interval argument.
·     This feature takes effect only when the ip subscriber authentication dot1x-retrigger command has been executed.
3.     Configure the suppression interval for retriggering 802.1X authentication based on ARP and ND packets.
ip subscriber authentication dot1x-retrigger interval interval
By default, the suppression interval for retriggering 802.1X authentication based on ARP and ND packets is 60 seconds.
Forcibly logging out an 802.1X client
For an IPoE user that comes online through 802.1X authentication, the 802.1X client of the user refers to the 802.1X authentication-capable client software installed on the user's host.
By default, when the IP address lease expires or fails to be renewed for an IPoE DHCP user or the device receives the DHCP-RELEASE, DHCP-DECLINE, and DHCP-NAK packets from an IPoE DHCP user, the IPoE user that comes online through 802.1X authentication will go offline. However, the 802.1X client of the user still stays online. To log out the 802.1X client of an IPoE user when the IPoE user goes offline, configure this feature.
3.     Log out the 802.1X client of an IPoE user when the IP address of the IPoE user is released.
ip subscriber dhcp-release-ip dot1x-offline
By default, the 802.1X client of an IPoE user stays online when the IP address of the IPoE user is released.
Forcibly logging out an IPoE user when the 802.1X client goes offline
By default, for an IPoE user that comes online through 802.1X authentication, if the 802.1X client of the user goes offline, the device will move the IPoE user from the postauthentication domain to the preauthentication domain, and the IPoE user stays online in the preauthentication domain. To log out an IPoE user when the 802.1X client of the IPoE user goes offline, configure this feature.
3.     Log out an IPoE user when the 802.1X client of the IPoE user goes offline. .
ip subscriber dot1x-offline user-offline
By default, an IPoE user stays online when the 802.1X client of the IPoE user goes offline.
Enabling unclassified-IP packet attack defense
To avoid excessive resource usage caused by a large number of illegal IP packets, which can affect the onboarding efficiency of normal users, you can enable unclassified-IP packet attack defense.
Operating mechanism
When this feature is enabled, the device generates an attack defense blocking entry (also called statistics entry) for a user upon receiving the first IP packet of the user. Then, the device checks whether the user meets the trigger conditions for IPoE user onboarding based on the device configuration.
·     Before the check result is confirmed, the device drops all IP packets from the user based on the attack defense blocking entry. The first IP packet is also counted as a dropped packet because it is used to check the configuration. Even if the user packet count reaches the blocking threshold during this phase, no attack defense blocked entries will be generated.
·     After the check result is confirmed, the following rules apply:
¡     If the trigger conditions are met, the device will initiate the IPoE user onboarding process based on the first IP packet of the user.
-     The device continues to drop IP packets from the user based on the attack defense blocking entry until the onboarding result (successful or failed) of the user is determined. Even if the user packet count reaches the blocking threshold during this phase, no attack defense blocked entries will be generated.
-     After the onboarding result (successful or failed) of the user is determined, the device will automatically delete the attack defense blocking entry of the user.
¡     If the trigger conditions are not met, the device checks whether the packet count of the user has reached the blocking threshold configured by using the ip subscriber unclassified-ip-defense threshold command:
-     If the blocking threshold is reached, the device deletes the attack defense blocking entry of the user and generates an attack defense blocked entry for the user. Subsequently, the device drops IP packets from the user based on the attack defense blocked entry and outputs attack log messages. The attack log messages generated by the device will be sent to the information center. The information center configuration specifies the log message sending rule and destination. For more information about the information center, see Network Management and Monitoring Configuration Guide.
-     If the blocking threshold is not reached, the device continues to wait for subsequent packets. If the IP packets of the user are not received within a packet statistics collection interval (configured by using the interval parameter in the ip subscriber unclassified-ip-defense threshold command), the device will delete the attack defense blocking entry of the user. If the IP packets of the user are received again within a packet statistics collection interval, the device will re-check whether the user meets the trigger conditions for IPoE user onboarding based on the existing configuration and repeat the preceding process. During this phase, the device will not regenerate an attack defense blocking entry for the user but will directly use the existing one.
Executing the undo form of this command on an interface to disable attack defense will also delete all attack defense blocking entries and attack defense blocked entries generated on the interface.
3.     Enable unclassified-IP packet attack defense.
ip subscriber unclassified-ip-defense enable
By default, unclassified-IP packet attack defense is disabled.
4.     (Optional.) Configure the blocking threshold for unclassified-IP packet attack defense.
ip subscriber unclassified-ip-defense threshold packet-number interval interval
By default, the blocking threshold for attack defense is reached when the total number of IP packets received from the same source IP address within 300 seconds reaches 6000.
5.     (Optional.) Configure the blocking duration for unclassified-IP packet attack defense.
ip subscriber unclassified-ip-defense block-period blocking-period
By default, the blocking duration for unclassified-IP packet attack defense is 600 seconds when the blocking threshold is reached.
Rate-limiting DHCP packets
When a large number of DHCP users come online at the same time, you can enable this feature to avoid congestion caused by a large number of DHCP packets and ensure users can come online properly.
(In standalone mode.) (In IRF mode.) With this feature enabled, when the device or slot receives DHCPv4 packets (including Discover packets and the unauthenticated users' Request packets) exceeding the rate limit+1 within 1 second, the exceeding packets are dropped.
(In standalone mode.) (In IRF mode.) With this feature enabled, when the device or slot receives DHCPv6 Solicit packets (excluding those with a Relay-Forward header after being forwarded by the relay) exceeding the rate limit+1 within 1 second, the exceeding packets are dropped.
This command takes effect on only the dynamic DHCP users and the Layer 2 interface-leased DHCP subusers.
2.     Enable rate-limiting the DHCPv4 packets of DHCP users.
ip subscriber dhcp rate-limit rate
By default, rate-limiting the DHCPv4 packets of DHCP users is disabled.
When you execute this command multiple times, the most recent configuration takes effect.
3.     Enable rate-limiting the DHCPv6 packets of DHCP users.
ip subscriber dhcpv6 rate-limit rate
By default, rate-limiting the DHCPv6 packets of DHCP users is disabled.
Setting the maximum number of individual sessions and leased subuser sessions on an interface
This feature controls the maximum number of individual users (including dynamic individual users and static individual users) and leased subusers on an interface.
When the number of individual sessions and leased subuser sessions on an interface has reached the limit, new IPoE sessions cannot be established. The number of IPoE sessions created includes the number of IPv4 single-stack users, the number of IPv6 single-stack users, and the number of dual-stack sessions. A single-stack user occupies one session resource, and a dual-stack user occupies one session resource. If a single-stack user has come online successfully, the other stack of the same user can directly come online, and the two stacks share one session resource.
If the configured limit is smaller than the number of existing sessions on an interface, the configuration succeeds and the existing sessions are not affected. However, new sessions cannot be initiated on the interface.
2.     Enter interface view.
3.     Set the maximum number of individual sessions and leased subuser sessions on the interface.
ip subscriber max-session max-number
By default, the maximum number of individual sessions and leased subuser sessions is not set on an interface.
When this command is configured together with the ip subscriber { dhcp | dhcpv6 | ndrs | unclassified-ip | unclassified-ipv6 } max-session command, the two commands both take effect. The two commands control sessions in different perspectives, and the number of sessions is controlled by both commands. A new session can be established only when neither limit is reached. For more information about the ip subscriber { dhcp | dhcpv6 | ndrs | unclassified-ip | unclassified-ipv6 } max-session command, see "Setting the dynamic individual session limit."
This task enables you to assign ISP domains to users based on services. You can classify services by VLAN ID, 802.1P, and DSCP carried in packets from users.
For DHCPv4 users, the trusted Option 60 configuration takes precedence over the global service identifier configuration.
For DHCPv6 users, the trusted Option 16 or Option 17 configuration takes precedence over the global service identifier configuration.
You must specify an identifier for a service before you bind an ISP domain to the service. Otherwise, the binding does not take effect.
3.     Configure a service identifier for IPoE users.
ip subscriber service-identify { 8021p { second-vlan | vlan } | dscp | second-vlan | vlan }
By default, no service identifier is configured for IPv4 users.
4.     Bind an ISP domain to IPoE users who send IP packets with the specified VLANs.
ip subscriber vlan vlan-list domain domain-name
By default, no ISP domain is bound to IPoE users who send IP packets with the specified VLANs.
5.     Bind an ISP domain to IPoE users who send IP packets with the specified 802.1p values.
ip subscriber 8021p 8021p-list domain domain-name
By default, no ISP domain is bound to IPoE users who send IP packets with the specified 802.1p values.
6.     Bind an ISP domain to IPoE users who send IP packets with the specified DSCP values.
ip subscriber dscp dscp-value-list domain domain-name
By default, no ISP domain is bound to IPoE users who send IP packets with the specified DSCP values.
For this command, IPoE users include DHCP users, unclassified-IP users, and static users.
Configuring the quiet feature for users
If this feature is enabled, the quiet timer starts when number of consecutive authentication failures of a user reaches the limit in the specified period. During the quiet timer period, packets from the user are dropped. After the quiet timer expires, the BRAS performs authentication upon receiving a packet from the user. This feature can prevent password attacks.
If no dual-stack IPoE session is generated for a dual-stack user, the authentication failures of the two protocol stacks are counted separately. The dual-stack user is quieted only when the number of consecutive authentication failures reaches the limit in the specified period for each protocol stack.
If a dual-stack IPoE session is generated for a dual-stack user, the authentication failures of the two protocol stacks are counted together. The dual-stack user is quieted when the number of consecutive authentication failures reaches the limit in the specified period.
3.     Configure the quiet timer for IPoE users.
ip subscriber timer quiet time
By default, the quite timer is disabled for IPoE users.
4.     (Optional.) Configure the authentication failure limit in the specified period that triggers the quiet timer for IPoE users.
ip subscriber authentication chasten auth-failure auth-period
By default, the quiet timer starts immediately upon one authentication failure.
Configuring online detection for IPoE users
Online detection enables the BRAS to periodically detect the online status of a user. It uses ARP or ICMP requests to detect IPv4 users, and uses NS packets of the ND protocol or ICMPv6 requests to detect IPv6 users.
After you configure online detection, the BRAS starts a detection timer to detect online users. If the BRAS receives no user packets from a user when the timer expires, it sends a detection packet to the user and performs the following operations:
·     If the BRAS receives user packets within the maximum number of detection attempts (retries or retransmit-times-1), the BRAS assumes the user is online. It resets the failure counter, and starts the next detection attempt.
·     If the BRAS receives no user packets within the maximum number of detection attempts, the BRAS assumes the user is offline and deletes the session.
This feature supports only individual users and leased subusers in Layer 2 access mode.
On a Layer 3 network (when Layer 3 devices exist between a user and the BRAS), as a best practice, disable online user detection.
When the accounting mode is merge for dual-stack users, the sum of IPv4 uplink traffic and IPv6 uplink traffic is used to determine whether the user uplink traffic is updated.
For online detection to operate properly, make sure the source IP address and destination IP address of detection packets belong to the same VPN instance or are both in the public network.
To balance the overall device performance and ensure that the device operates at the best performance, the device uses the periodical statistics collection mechanism to collect user traffic update conditions. When a large number of users are online, you can configure the device not to send detection packets after the detection interval expires if the uplink traffic of a user is updated within one detection interval. As a best practice, increase the detection interval specified by using the interval argument. If you do not do that, when the traffic of some users is updated within one detection interval, the device might fail to timely collect traffic update conditions of these users. As a result, the device considers that the traffic is not updated for these users, and sends detection packets to these users.
3.     Configure online detection for IPv4 users.
ip subscriber user-detect ip { arp | icmp } retry retries interval interval [ no-datacheck ]
By default, online detection is enabled for IPv4 protocol stack users.
¡     For leased subusers, no matter whether user uplink traffic is updated within a detection timer period (120 seconds), the BRAS sends ARP request packets to detect the online status of users after the detection timer expires. The BRAS performs a maximum of five detection attempts after the first detection failure.
¡     For other users, no detection packets are sent after the detection timer expires if user uplink traffic is updated within a detection timer period (120 seconds). If user uplink traffic is not updated within a detection timer period, the BRAS uses the ARP request packets to detect the online status of IPv4 protocol stack users. The BRAS performs a maximum of five detection attempts after the first detection failure.
The no-datacheck keyword does not take effect on leased subusers.
4.     Configure online detection for IPv6 users.
ip subscriber user-detect ipv6 { icmp | nd } retry retries interval interval [ no-datacheck ]
By default, online detection is enabled for IPv6 protocol stack users.
¡     For leased subusers, no matter whether user uplink traffic is updated within a detection timer period (120 seconds), the BRAS sends ND Neighbor Solicitation (NS) packets to detect the online status of users after the detection timer expires. The BRAS performs a maximum of five detection attempts after the first detection failure.
¡     For other users, no detection packets are sent after the detection timer expires if user uplink traffic is updated within a detection timer period (120 seconds). If user uplink traffic is not updated within a detection timer period, the BRAS uses the ND NS packets to detect the online status of IPv6 protocol stack users. The BRAS performs a maximum of five detection attempts after the first detection failure.
5.     Configure IPv6 addresses generated in EUI-64 method as the destination addresses of online detection.
ip subscriber ndrs user-detect-address eui-64
By default, the link-local addresses of endpoints (in the format of FE80+endpoint interface ID) are used as the destination addresses of online detection.
When you use the ND NS packets as the probe packets to perform online detection for IPv6 ND RS users, for the device to use the IPv6 address generated in the method of ND prefix+interface ID in EUI-64 format as the destination address of online detection, execute this command.
Configuring NAS-Port-ID formats
The NAS-Port-ID RADIUS attribute specifies access location of a user. The BRAS supports the following formats for NAS-Port-ID:
·     version 1.0—Format for China Telecom.
·     version 2.0—Format specified in YDT 2275-2011 Subscriber Access Loop (Port) Identification in Broadband Access Networks
·     version3.0—SlotID/00/IfNO/VlanID, where the slashes(/) are not displayed.
·     version4.0—Adds the specified option of DHCP packets to the NAS-Port-ID in version 3.0 format.
When the received DHCPv4 packets carry Option 82 Circuit-ID and Option 82 is trusted or the received DHCPv6 packets carry Option 18 and Option 18 is trusted, the format adds the following information to the NAS-Port-ID in the version 3.0 format:
¡     For IPv4 users, DHCP Option82 is added, and the format is SlotID/00/IfNO/VlanID/Option82 Circuit-ID, where slashes (/) are not displayed.
¡     For IPv6 users, DHCP Option18 is added, and the format is SlotID/00/IfNO/VlanID/Option18, where slashes (/) are not displayed.
In the other cases, the version 4.0 format is the same as the version 3.0 format.
·     version5.0—Version 5.0 format specified in YDT 2275-2011 Subscriber Access Loop (Port) Identification in Broadband Access Networks.
You can configure the following settings if version 2.0 or version 5.0 is used when the BRAS acts as a DHCP relay agent:
·     Configure DHCPv4 Option 82 Circuit-ID or DHCPv6 Option 18 as a trusted DHCP option and extract information from the trusted option.
·     Include the NAS information and extracted option information in NAS-Port-ID.
If the attribute 87 format command is executed in RADIUS scheme view, the format of the NAS-Port-ID attribute sent to the RADIUS server is determined by using this command. In this case, the NAS-Port-ID attribute format defined in IPoE does not take effect. For more information about the attribute 87 format command, see AAA commands in BRAS Services Command Reference.
3.     Configure the NAS-Port-ID format for IPoE users.
ip subscriber nas-port-id format cn-telecom { version1.0 | version2.0 | version3.0 | version4.0 | version5.0 }
The default format is version1.0.
4.     (Optional.) Configure the trusted DHCPv4 option 82 for IPv4 users or the trusted DHCPv6 option 18 for IPv6 users.
ip subscriber trust { option82 | option18 }
By default, the BRAS does not trust DHCPv4 Option 82 or DHCPv6 Option 18.
5.     (Optional.) Include the NAS information and DHCPv4 option 82 information or DHCPv6 option 18 information in NAS-Port-ID for users.
ip subscriber nas-port-id nasinfo-insert
By default, the BRAS includes only information extracted from the trusted DHCPv4 option 82 or trusted DHCPv6 option 18 in NAS-Port-ID.
Configuring NAS-Port-ID binding for IPoE access users
a device uses information about the interface through which a user comes online to fill in the NAS-Port-ID attribute and sends it to the RADIUS server by default. In some special applications, when you need to manually specify the access interface information to be filled in the NAS-Port-ID attribute, you can use this command. For example, suppose the RADIUS server restricts user A's access to only interface A. When user A accesses through interface B and you do not want to modify the RADIUS server configuration, you can configure this command to use information about interface A to fill in the NAS-Port-ID attribute for user A and send the attribute to the RADIUS server.
When the NAS-PORT-ID information format is version 1.0 and the ip subscriber nas-port-id interface command is executed, the following rules apply:
·     If the access-user four-dimension-mode enable command is also executed, the interface information specified in the ip subscriber nas-port-id interface command will be used to fill in the following access interface information field in the NAS-PORT-ID attribute:
¡     chassis=NAS_chassis;slot=NAS_slot;subslot=NAS_subslot;port=NAS_port.
·     If the access-user four-dimension-mode enable command is not executed, the interface information specified in the ip subscriber nas-port-id interface command will be used to fill in the following access interface information field in the NAS-PORT-ID attribute: slot=NAS_slot;subslot=NAS_subslot;port=NAS_port.
When the NAS-PORT-ID information format is version 2.0 or version 5.0 and the ip subscriber nas-port-id interface command is executed, the following rules apply:
·     If the access-user four-dimension-mode enable command is also executed, the interface information specified in this command will be used to fill in the following NAS information field in the NAS-PORT-ID attribute:
¡     {eth|trunk|atm} NAS_chassis/NAS_slot/NAS_subslot/NAS_port.
·     If the access-user four-dimension-mode enable command is not executed, the interface information specified in this command will be used to fill in the following access interface information field in the NAS-PORT-ID attribute: {eth|trunk|atm} NAS_slot/NAS_subslot/NAS_port.
When version 3.0 is specified as the NAS-Port-ID format, the interface specified in this feature will be used to fill in the NAS information SlotID/IfNO.
When version 4.0 is specified as the NAS-Port-ID format, the interface specified in this feature will be used to fill in the following NAS information:
·     For IPv4 users: SlotID/IfNO/Option82 Circuit-ID.
·     For IPv6 users: SlotID/IfNO/Option18.
The information configured in this feature is also used to fill in the NAS-Port attribute.
3.     Use information of the interface to fill in the NAS-Port-ID attribute.
ip subscriber nas-port-id interface interface-type interface-number
By default, the device uses information of the interface through which the user comes online to fill in the NAS-Port-ID attribute.
Enabling IPoE access-out authentication
In a dual-authentication network, one device performs access-in authentication and another device performs access-out authentication. Users who pass access-in authentication can access the intranet and users who pass access-out authentication can access the extranet.
3.     Enable IPoE access-out authentication for IPoE users.
ip subscriber access-out
By default, IPoE access-out authentication for users is disabled.
Enabling roaming for IPoE individual users
Enabling roaming for IPoE users
IPoE user roaming allows an IPoE user to stay online when moving among areas covered by multiple wireless networks specified. In the current software version, the following roaming methods are supported:
·     Inter-VLAN roaming—An IPoE user roams between different VLANs on the same subinterface or between different VLANs on different subinterfaces on the BRAS.
·     Inter-interface roaming—An IPoE user roams between different interfaces on the same card or between different interfaces on different cards on the BRAS.(In standalone mode.)
·     Inter-member device roaming—An IPoE user roams between different IRF member devices of an IRF system. (In IRF mode.)
To reduce roaming users' impact on other users, you can limit the roaming range by using a roaming group. An online user can roam only within the roaming group of the interface through which the user comes online. For example, user A and user B both use the IP address 1.1.1.1/24 and belong to the same VPN instance. User A first comes online on interface A through unclassified-IP packet initiation. Both interface A and interface B are enabled with roaming but not configured with roaming groups. In this case, when user B comes online on interface B through unclassified-packet initiation, the device will log off user A. For user A and user B to come online simultaneously, you can configure different roaming groups for interface A and interface B. This configuration isolates the roaming range of user A from the roaming range of user B.
For an IPoE user to roam correctly, configure the interface before roaming and the interface after roaming as follows:
·     Enable IPoE for the same protocol stack.
·     Configure the same IPoE authentication method, authentication domain, roaming group, IP address type (IPv4 or IPv6) on which the main service of IPoE users depends, and Option79 trusting state (required only for DHCPv6 users).
Typically, the following packets can trigger roaming: ARP packets, IPv4 packets, and IPv6 packets.
In an IPv4 network:
·     To use IPv4 packets to trigger roaming, you must configure the ip subscriber initiator unclassified-ip enable matching-user command on the target interface of roaming.
·     To use ARP packets to trigger roaming, you must configure the ip subscriber initiator arp enable and ip subscriber initiator unclassified-ip enable matching-user commands on the target interface of roaming.
As a best practice for roaming in an IPv4 network, configure both unclassified-IPv4 packet initiation and ARP packet initiation.
In an IPv6 network:
·     To use IPv6 packets to trigger roaming, you must execute the ip subscriber initiator unclassified-ipv6 enable matching-user command on the target interface of roaming.
·     To use NS or NA packets to trigger roaming, you must execute both the ip subscriber initiator nsna enable command and the ip subscriber initiator unclassified-ipv6 enable matching-user command on the target interface of roaming.
For roaming in an IPv6 network, as a best practice, use both use IPv6 packets and NS or NA packets to trigger roaming.
For IPoE DHCP user roaming, make sure the following requirements are met:
·     For IPoE DHCPv4 users, you must execute the dhcp session-mismatch action roam command on all interfaces for roaming.
·     For IPoE DHCPv6 users, you must execute the ipv6 dhcp session-mismatch action roam command on all interfaces for roaming.
·     In a DHCP relay agent network, you must execute the dhcp-proxy enable command (default configuration) on the DHCP relay agent interface to enable DHCP server proxy on the relay agent. For more information about DHCP relay agents, see DHCP configuration in BRAS Services Configuration Guide.
The following events might lead to failures in the process of roaming:
·     The user IP address that the user belongs to is changed.
·     The target interface is not configured with the same IPoE session initiation method as the interface before the roaming.
·     The roaming will fail if the following conditions exist:
¡     The roaming target interface and the roaming source interface are not in the same roaming group.
¡     The ip subscriber roam-group-mismatch unclassified-ip roam command is not executed or is executed but does not meet the conditions for roaming between roaming group roamings.
·     For dynamic individual users:
¡     If a VPN instance is authorized to the roaming user and the target interface is bound to a VPN instance, the target interface can be bound to a VPN instance different from the authorized VPN instance. In this case, when the user roams to the target interface, the authorized VPN instance still takes effect.
¡     If no VPN instance is authorized to the roaming user and the interface before roaming is bound to a VPN instance, the target interface must be bound to the same VPN instance.
·     For global static individual users:
¡     If a VPN instance is authorized to the roaming user, the following rules apply:
-     If the strict-check access-interface vpn-instance command is executed in the authorized domain, the target interface must be bound to a VPN instance the same as the authorized VPN instance. If you cannot do that, the user cannot roam to the target interface.
-     If the strict-check access-interface vpn-instance command is not executed in the authorized domain, the target interface can be not bound to a VPN instance, or the target interface can be bound to a VPN instance different from the authorized VPN instance.
¡     No VPN instance is authorized to the roaming user, and no VPN instance is specified in the static session. The interface before roaming is bound to a VPN instance. The target interface is bound to a different VPN instance.
·     For dual-stack users formed by global static individual users and dynamic individual users:
¡     If the dynamic individual user roams—A VPN instance is specified in the global static individual session, and the target interface is bound to a VPN instance different from the VPN instance specified in the global static individual session.
¡     If the global static individual user roams—The events that lead to roaming failures are the same as that for common global static individual users.
If the roaming fails, the user must perform authentication again on the destination interface in order to come online. Re-authentication takes a certain period of time.
For static individual users, the roaming function takes effect as follows:
·     For interface-level static individual users, roaming is supported only when you configure IPoE static sessions in interface view by using the ip subscriber session static command without specifying a VLAN. In this case, only roaming across different VLANs of the interface is supported.
·     For global static individual users or dual-stack users formed by global static individual users and dynamic individual users, when you configure the ip subscriber session static command in system view, the following rules apply:
¡     If a user access interface is specified but no VLAN is specified, roaming across different VLANs of the interface is supported.
¡     If no user access interface is specified and a user comes online through a roaming-enabled interface, roaming across all roaming-enabled interfaces is supported.
¡     If you specify an IPv6 delegation prefix, users in the static session do not support roaming.
3.     Enable roaming for IPoE individual users.
ip subscriber roaming enable [ roam-group roam-group-name ]
By default, roaming is disabled for IPoE individual users.
Enabling recording IPoE user roaming behaviors on the device
To perform network security checks based on user roaming behaviors or assist in troubleshooting when the user roaming feature is abnormal, you can enable recording user roaming behaviors.
With this feature enabled, the device will record information of each user before and after user roaming,  such as the access interface, VLAN, and user MAC address. To view this information, execute the display ip subscriber roam-record command.
·     The count value is the maximum number of roaming records for all users. To prevent a single user from excessively occupying roaming record resources due to frequent roaming, the system sets the upper limit to 10 for the roaming records of a single user.
·     When the specified count value is less than the number of user roaming behaviors recorded by the device, the device will delete the older roaming records of some users based on the roaming time until the remaining number of roaming records equals the specified count value.
·     When a user roams, the system first identifies whether the number of roaming records of the user has reached the upper limit for a single user. If yes, the system deletes the oldest roaming record for that user and then adds the new roaming record. If the number of roaming records of the user has not reached the upper limit for a single user but the total number of roaming records for all users on the device has reached the set count value, the device deletes the oldest roaming record from all roaming records and then records the new roaming behavior.
·     The roaming records of a user are not automatically deleted when the user goes offline. These records can only be overwritten by the new roaming records of other users or deleted by disabling recording user roaming behaviors.
2.     Enable recording IPoE user roaming behaviors on the device.
ip subscriber roam-record max count
By default, recording IPoE user roaming behaviors is disabled on a device.
Forcing an existing online user with the same MAC address as a new online user to go offline if they are in different roaming groups
In roaming scenarios, when a roaming-enabled interface receives an NDRS or DHCP user online request, the system first checks for any online users with the same MAC address by default.
·     If no online user exists with the same MAC address, the user comes online as a new user.
·     If an online user exists with the same MAC address, the system will further determine whether the new online user and the existing online user with the same MAC belong to the same roaming group.
¡     If yes, the new user roams.
¡     If not, the new NDRS user will come online as a new user, while the new DHCP user cannot come online.
When a user switches areas across roaming groups without going offline in the original roaming group area and comes online in the new roaming group area, the following issues might occur:
·     For an NDRS user, the device maintains separate session information in different roaming groups, which consumes device resources and increases maintenance complexity.
·     A DHCP user cannot come online.
To address the preceding issues, you can enable the function of forcing an existing online user with the same MAC address as a new online user to go offline if they are in different roaming groups.
With this feature enabled, when a roaming-enabled interface receives an online request from a DHCP or NDRS user, the request is processed as follows if an existing online user with the same MAC address belongs to a different roaming group on the device:
·     If the existing online user is a single-stack user, the device forces the existing online user to go offline and allows the new user to come online on the new interface.
·     If the existing user is a dual-stack user, the device forces the existing user to go offline in the protocol stack of the new user's online request, keeps the existing user online in the other protocol stack, and allows the new user to come online on the new interface.
When this feature is enabled in the system view, the following rules apply to DHCP users across roaming groups:
·     If you execute the following commands on roaming target interface A, the commands take effect in the protocol stack of the users on interface A.
¡     dhcp session-mismatch action fast-renew
¡     ipv6 dhcp session-mismatch action fast-renew
·     If you do not execute the following commands on roaming target interface B, the ip subscriber roam-group-mismatch dhcp fast-renew command takes effect in the protocol stack of the users on interface B.
This feature only applies to IPoE DHCP users and NDRS users and is effective only when roaming is enabled on both the source and target interfaces.
Configure this feature only when users roam across roaming groups.
1.     ‍Enter system view.
2.     Enable the function of forcing an existing online user with the same MAC address as a new online user to go offline if they are in different roaming groups.
By default, the function of forcing an existing online user with the same MAC address as a new online user to go offline if they are in different roaming groups is disabled.
Enabling roaming for a new online user with the same IP and MAC addresses as an existing online user in a different roaming group
When a roaming-enabled interface receives online requests triggered by IP/ARP/NS/NA packets from a new unclassified-IP user, the interface checks for online users with the same IP and MAC addresses on the device by default.
·     If such a user does not exist, the new user comes online as a new user.
·     If such a user exist, the system identifies whether the new online user and the existing online user with the same IP and MAC addresses belong to the same roaming group:
¡     If not, the new user comes online as a new user.
When a user switches areas across roaming groups without going offline in the original roaming group area and comes online in the new roaming group area, the new user might either come online successfully or fail to come online.
·     If the new user comes online successfully, the device maintains separate session information for the user across different roaming groups, which consumes device resources and increases maintenance complexity.
·     If the new user fails to come online, the user will fail to access the system.
To address the preceding issues, you can enable roaming for a new online user with the same IP and MAC addresses as an existing online user in a different roaming group.
With this feature enabled, the system processes the packets received by an interface depending on the packet type:
·     When a roaming-enabled interface receives online requests triggered by a user's IP/ARP/NS/NA packets, the following rules apply:
¡     If the device has an existing online user with the same IP and MAC addresses but belonging to a different roaming group, the device will perform roaming for the user. For example, on a BRAS, interface A and interface B belong to two different roaming groups. User1 initially came online successfully through DHCP on interface A. The device will roam User1 from interface A to interface B if the following conditions exist:
-     User1 moves to interface B without going offline on interface A.
-     User1 directly uses the IP address obtained when initially coming online on interface A to send IP/ARP/NS/NA packets to trigger online requests.
¡     If no online user exists with the same IP and MAC addresses, User1 comes online as a new user.
·     When a roaming-enabled interface receives an online request from a DHCP user or NDRS user, the following rules apply:
¡     If the device has an existing online user with the same MAC address but belonging to a different roaming group, the device will perform the following operations:
-     Force the existing online user to go offline in all protocol stacks, whether single-stack or dual-stack.
-     Allow the new user to come online on a new interface.
For example, on a BRAS, interface A and interface B belong to two different roaming groups. User1 initially came online successfully through DHCP on interface A. If User1 moves to interface B without going offline on interface A and initiates a new DHCP online request on interface B, the device will force the user with the same MAC address as User1 on interface A to go offline and allow User1 to come online again on interface B.
¡     If no online user with the same MAC address exists, User1 comes online as a new user.
This command takes effect only in Layer 2 IPoE access mode.
2.     Enable roaming for a new online user with the same IP and MAC addresses as an existing online user in a different roaming group.
By default, roaming is disabled for a new online user with the same IP and MAC addresses as an existing online user in a different roaming group.
Configuring the IPoE user access response delay policy
Configuring the IPoE user access response delay time
This feature is applicable in the scenario where the administrator wants to deploy multiple BRASs on the network and perform load sharing and backup for users with odd MAC addresses and even MAC addresses among these BRASs.
As shown in Figure 11, to implement device-level backup and traffic load sharing, deploy two BRASs in the network and configure them as follows:
·     On BRAS A, set the response delay for users with even MAC addresses and use the default settings (do not set the response delay) for users with odd MAC addresses.
·     On BRAS B, set the response delay for users with odd MAC addresses and use the default settings (do not set the response delay) for users with even MAC addresses.
After the preceding configuration, BRAS A will respond to the online requests of users with odd MAC addresses before BRAS B in normal conditions. As a result, users with odd MAC addresses will preferentially come online through BRAS A. Similarly, BRAS B will respond to the online requests of users with even MAC addresses before BRAS A. As a result, users with even MAC addresses will preferentially come online through BRAS B. In this way, user traffic is load-balanced between BRAS A and BRAS B.
Figure 11 Schematic diagram (all BRASs are operating normally)
When a BRAS  fails (for example, BRAS A fails) as shown in Figure 12, users with odd MAC addresses can come online through BRAS B. In this case, BRAS B provides access services for all users to achieve device-level backup. Among them:
·     Users with odd MAC addresses who did not come online before BRAS A fails can now come online through BRAS B after BRAS A fails.
·     Users with odd MAC addresses who came online before BRAS A fails must go offline before they can come online through BRAS B after BRAS A fails.
Figure 12 Schematic diagram (a BRAS fails)
Operating mechanism
After you set the response delay for IPoE users, the system will delay the response to IPoE users’ online requests according to the set delay. The system supports setting different response delays for users with odd MAC addresses and users with even MAC addresses.
·     In this case, the public address pool, private address pool, and NAS-IP address on each BRAS must be unique. If you cannot do that, route issues might occur. For example, if you have configured the NAS-IP address as 1.1.1.1 on one BRAS, you cannot configure the NAS-IP address as 1.1.1.1 on another BRAS.
·     This feature can be used in conjunction with the ip subscriber access-delay odd-even mac offset command to flexibly deploy the access response delay policy for users with odd and even MAC addresses based on MAC address offset values. For more information, see the ip subscriber access-delay odd-even mac offset command.
·     This feature takes effect only on newly connected IPoE DHCP users (including new users who access during the preauthentication phase). It does not affect existing online IPoE users (including IPoE Web users in the online state during the preauthentication phase) and users in the Web authentication phase.
3.     Set the response delay time for IPoE users.
ip subscriber access-delay delay-time [ even-mac | odd-mac ]
By default, no response delay time is set for IPoE users on an interface.
¡     If you do not specify any keyword in this command, the set response delay applies to users with even MAC addresses and users with odd MAC addresses that come online through the current interface.
¡     If you first execute this command with the even-mac or odd-mac keyword specified and then execute this command without specifying any keyword, the latter configuration takes effect, and vice versa.
Configuring the MAC address offset value for IPoE user access response delay
The parity bit refers to the bit used by the BRAS to determine the parity of a user MAC address. If the bit takes a value of 0, it means that the user has an even MAC. If the bit takes a value of 1, it means that the user has an odd MAC.
By default, the device can only select the lowest bit of a user MAC address as the parity bit to determine the parity of the MAC address. Then, based on the delay time configured by using the ip subscriber access-delay command for users with even MAC addresses or odd MAC addresses, the device can delay the response to the user's online requests.
To flexibly specify a certain bit in a user MAC address as the basis for determining the parity of the MAC address as needed, configure this feature.
Operating mechanism
After the MAC address offset value is configured, the device determines whether a user MAC address is an odd or even MAC address based on the offset-value+1 bit (from lowest to highest) of the MAC address when the device receives an IPoE user online request. Then, the device delays the response to the user's online requests according to the delay time configured by using the ip subscriber access-delay command for users with the odd or even MAC addresses.
For example, as shown in Figure 13, an IPoE user has a MAC address of 0012-3400-ABCD. When the default MAC address offset value is used, the parity bit of the user MAC address is the 1st bit and takes the value of 1, so the MAC address is an odd MAC address. If the MAC address offset value is set to 17, the parity bit of the user MAC address is the 18th bit and takes the value of 0, so the MAC address is an even MAC address.
Figure 13 MAC address offset calculation example
·     To be significant, this feature must be used in conjunction with the ip subscriber access-delay command. Configuring this feature alone without the ip subscriber access-delay command executed is insignificant. In this case, regardless of the configured MAC address offset value, the device will immediately respond to the IPoE user's online requests.
·     This feature takes effect only on IPoE DHCP users. If the Web authentication method is used, this feature only takes effect for users in the pre-authentication phase and has no impact on users in the Web authentication phase.
·     This feature takes effect only on newly connected IPoE users. It does not affect existing online IPoE users (including IPoE Web users in the online state during the preauthentication phase).
3.     Configure the MAC address offset value for the IPoE user access response delay.
ip subscriber access-delay odd-even mac offset offset-value
By default, the MAC addresses of IPoE users are not offset for matching. The system determines the parity of a MAC address based on the lowest bit (higher on the left and lower on the right) of the MAC address.
Configuring IPoE user access management
Configuring trusted IP addresses for IPoE authentication
In a network requiring high security, you can configure trusted IP addresses for IPoE authentication. Then, the device processes only packets with the source IP addresses as trusted IP addresses, and the other packets are dropped.
After trusted IP addresses are configured, the following rules apply:
·     If IP packets from a user match a static IPoE session, the user comes online as a static IPoE user no matter whether the source IP address in the IP packets is trusted.
·     If IP packets from users do not match a static IPoE session, only packets with source IP addresses as trusted IP addresses can initiate IPoE authentication, and other packets are dropped.
This feature takes effect only on unclassified-IP users and leased unclassified-IP subusers.
3.     Configure trusted IPv4 addresses for IPoE authentication.
ip subscriber unclassified-ip ip match start-ip-address [ end-ip-address ]
By default, all IPv4 addresses are trusted.
4.     Configure trusted IPv6 addresses for IPoE authentication.
ip subscriber unclassified-ip ipv6 match start-ipv6-address [ end-ipv6-address ]
By default, all IPv6 addresses are trusted.
Forbidding IPoE users from coming online
With this feature configured, the device directly drops received online request packets of IPoE users to forbid new IPoE users from coming online through this interface.
This command does not affect existing IPoE users, including IPoE Web users in online state during the preauthentication phase.
2.     Forbid IPoE users from coming online.
In standalone mode:
ip subscriber access-block [ interface interface-type interface-number | slot slot-number ]
In IRF mode:
ip subscriber access-block [ interface interface-type interface-number | chassis chassis-number slot slot-number ]
By default, IPoE users are allowed to come online.
Configuring re-authentication for IPoE users
To perform special permission control for some users whose IP addresses are allocated by DHCP (for example, dumb terminals whose IP addresses and MAC addresses are bound in the static address binding method), you can enable re-authentication for IPoE users in the specified IP address range. After you enable this feature, when an IPoE user passes authentication and comes online with an IP address in the IP address range specified by using this command, the device will immediately use the ISP domain specified in this command to re-authenticate the user. Then, the device can perform unified permission control for users in the re-authentication domain.
In the current software version, this feature supports only IPoE DHCP users.
For a dual-stack IPoE DHCP user:
·     If the user meets the conditions for triggering re-authentication after coming online in the first protocol stack (for example, IPv4) and has passed re-authentication, and the user also meets the conditions for triggering re-authentication after coming online in the second protocol stack (for example, IPv6), the user does not need to perform re-authentication in the second protocol stack, and directly comes online in the re-authentication domain.
·     If the user meets the conditions for triggering re-authentication after coming online in the first protocol stack (for example, IPv4) and has passed re-authentication, but the user does not meet the conditions for triggering re-authentication after coming online in the second protocol stack (for example, IPv6), the user will be switched to the ISP domain for the first authentication.
·     If the user does not meet the conditions for triggering re-authentication after coming online in the first protocol stack (for example, IPv4), re-authentication is not triggered for the user even if the user meets the conditions for triggering re-authentication after coming online in the second protocol stack (for example, IPv6).
Executing or editing this command takes effect only on new users.
To provide the access service for IPoE Web authentication users, plan the IP addresses reasonably to prevent IPoE Web authentication users from matching the IP address range specified in this command. If you do not do that, the IPoE Web authentication feature might fail to operate normally.
2.     Enable re-authentication for IPoE users in the specified IP address range.
IPv4:
ip subscriber reauth ip start-ipv4-address [ end-ipv4-address ] [ vpn-instance vpn-instance-name ] domain domain-name
undo ip subscriber reauth ip start-ipv4-address [ end-ipv4-address ]
IPv6:
ip subscriber reauth ipv6 start-ipv6-address [ end-ipv6-address ] [ vpn-instance vpn-instance-name ] domain domain-name
undo ip subscriber reauth ipv6 start-ipv6-address [ end-ipv6-address ]
Dual-stack:
ip subscriber reauth ip start-ipv4-address [ end-ipv4-address ] ipv6 start-ipv6-address [ end-ipv6-address ] [ vpn-instance vpn-instance-name ] domain domain-name
undo ip subscriber reauth ip start-ipv4-address [ end-ipv4-address ] ipv6 start-ipv6-address [ end-ipv6-address ]
By default, re-authentication is disabled for IPoE users.
Configuring the IP address type on which the main service of IPoE users depends
By default, the device does not limit the order in which an IPoE user comes online in the IPv4 protocol stack and IPv6 protocol stack.
In the dual-stack scenario, if you want to specify the main service to depend on a protocol stack as needed, configure this feature. Then, when a user has not come online in the specified protocol stack, the user cannot come online in the other protocol stack.
With this feature configured, an IPoE bind authentication user can come online in the other protocol stack only after the user has come online in the protocol stack on which the user’s main service depends. If a user goes offline in the protocol stack on which the user's main service depends, the device will forcibly log out the user in the other protocol stack. As a result, the whole user goes offline.
With this feature configured, the following rules apply to IPoE Web authentication users:
·     Coming online:
¡     This feature takes effect in only the preauthentication domain and does not take effect in the postauthentication domain. For example, an IPoE user first comes online in the IPv4 protocol stack in the preauthentication domain. If you configure the main service of IPoE users to depend on the IPv6 protocol stack before the user moves from the preauthentication domain to the postauthentication domain, the user can still move to the postauthentication domain in the IPv4 protocol stack.
¡     An IPoE Web authentication user can come online in the other protocol stack (for example, IPv6) only after the user has come online in the protocol stack (for example, IPv4) on which the user's main service depends in the preauthentication domain.
¡     If the user comes online in the other protocol stack earlier than in the protocol stack on which the user’s main service depends in the postauthentication domain, the whole user comes online in the postauthentication domain.
·     Going offline:
¡     If the user returns to the preauthentication domain in the protocol stack on which the user's main service depends, the whole user returns to the preauthentication domain.
¡     If a user goes offline in the protocol stack on which the user's main service depends, the device will forcibly log out the user in the other protocol stack. As a result, the whole user goes offline.
After this feature is configured, this feature takes effect on online IPoE users as follows:
·     If a user first comes online in the IPv4 or IPv6 protocol stack and then the user’s main service is configured to depend on the IPv6 or IPv4 protocol stack, this feature does not affect the online status of the user and allows the user to stay online in the IPv4 or IPv6 protocol stack.
·     If a user first comes online in both the IPv4 and IPv6 protocol stacks and then the user’s main service is configured to depend on the IPv6 or IPv4 protocol stack, when the user goes offline in the IPv6 or IPv4 protocol stack, the user will also be forcibly logged out in the IPv4 or IPv6 protocol stack.
·     This feature applies to only IPoE bind authentication users and IPoE Web authentication users.
·     For IPoE users, if the ip subscriber authentication-method web command is executed with the basic-service-ipv4 keyword specified on an interface, the ip subscriber basic-service-ip-type command does not take effect on this interface, and only the ip subscriber authentication-method web command takes effect.
·     For IPoE to operate correctly, to use the ip subscriber basic-service-ip-type command to configure the IP address type (IPv4 or IPv6) on which the main service of IPoE users depends on an interface, make sure dual-stack IPoE is enabled on the interface by using the ip subscriber enable command.
·     This feature does not apply to the following IPoE users:
¡     IPoE static users (including static leased users).
¡     IPoE interface-leased users (excluding subusers).
¡     IPoE subnet-leased users (including subusers).
¡     IPoE L2VPN-leased users.
¡     Unclassified-IPv4/IPv6 users in Layer 3 IPoE access mode.
·     For the roaming feature to operate normally, configure the same IP address type on which the main service of IPoE users depends on the access interfaces before and after roaming.
3.     Configure the IP address type on which the main service of IPoE users depends.
ip subscriber basic-service-ip-type { ipv4 | ipv6 }
By default, the main service of IPoE users does not depend on any IP address type.
Configuring the device to trust the IP addresses authorized by the AAA server
This feature applies to scenarios where user endpoints must access the network by using the specific IP addresses, preventing unauthorized access and enhancing network security.
With this feature enabled, when the device receives a reply to an AAA authentication request, the device will process the reply according to the following principles:
·     For an unclassified-IP user (including dynamic individual users initiated by unclassified-IP packets, ARP packets, and NS/NA packets), the device compares the IP address carried by the user with the IP address authorized by the AAA server:
¡     If the IP addresses match, the device will proceed with the subsequent processing for the user to come online.
¡     If the IP addresses do not match, the device will disconnect and prevent the user from coming online. Meanwhile, the device will record one authentication failure for the user. When the number of authentication failures reaches the threshold set by using the ip subscriber authentication chasten command, the device will block the user.
·     For a DHCP user, the device processes the user according to the IP address authorized by the AAA server and the authorized IP address pool of the user authentication domain as follows:
¡     If the IP address authorized by AAA is within the authorized address pool range of the domain and is available, the device will allocate the IP address to the DHCP user. If the address is unavailable or fails to be allocated, the device will disconnect and prevent the user from coming online.
¡     If the IP address authorized by AAA is not within the authorized address pool range of the domain, the device will disconnect and prevent the user from coming online.
·     This feature is only applicable to the bind authentication scenarios and not applicable to Web authentication scenarios.
·     This feature is only applicable to unclassified-IP users (including dynamic individual users initiated by unclassified-IP packets, ARP packets, and NS/NA packets) and DHCP users.
·     This feature takes effect only when the AAA server authorizes IP addresses.
·     Before configuring this feature, make sure the AAA server has been properly deployed and the server has pre-configured endpoint-IP bindings.
·     In scenarios where DHCP users come online, to prevent issues such as allocation failure, make sure the IP address authorized by the AAA server is within the authorized address pool range of the user authentication domain on the device and the address is available.
2.     Configure the device to trust the IP addresses authorized by the AAA server.
ip subscriber trust aaa-authorized-ip
By default, the device does not trust the IP addresses authorized by the AAA server.
Configuring features by using the old-style IPoE commands
CAUTION
CAUTION:
Configure features in this section for compatibility with old-style commands reserved in the network management software. As a best practice, use these commands only in situations where the network management software does not support the corresponding new-style commands and you want to manage BRASs by using old-style commands.
Configuring DHCPv4 packet initiation
To meet business development requirements, you might need to upgrade the software versions of BRASs to implement new function requirements. After software upgrade, some functional commands might change. For example, the ip subscriber initiator dhcp enable command is obsoleted in the new software version. The feature configured by using this command is enabled by default and cannot be disabled in the new software version. To use the ip subscriber initiator dhcp enable command to manage the upgraded BRAS in the network management software without upgrading the network management software for BRASs, execute this command.
After the bras compatible old-style-commands enable command is executed to enable compatibility with old-style commands on the BRAS, DHCPv4 packet initiation is enabled by default and cannot be disabled. In this case, even if you execute the undo ip subscriber initiator dhcp enable command, the device configuration file (which can be viewed by using the display current-configuration command) still displays the positive configuration of the ip subscriber initiator dhcp enable command.
DHCPv4 packet initiation is enabled by default and cannot be disabled on the current device. In any cases, executing the ip subscriber initiator dhcp enable or undo ip subscriber initiator dhcp enable command does not affect the DHCPv4 packet initiation feature on the interface.
If the bras compatible old-style-commands enable command is not used to enable compatibility with old-style commands on the BRAS, you cannot view the configuration of the ip subscriber initiator dhcp enable command on the interface in the device configuration file.
2.     Enable compatibility with old-style commands on the BRAS.
By default, compatibility with old-style commands is disabled on the BRAS.
For more information about this command, see UCM commands in BRAS Services Command Reference.
3.     Enter interface view.
4.     Enable DHCPv4 packet initiation.
By default, DHCPv4 packet initiation is enabled.
Configuring the IPoE access interface type
To meet business development requirements, you might need to upgrade the software versions of BRASs to implement new function requirements. After software upgrade, some functional commands might change. For example, the ip subscriber nas-port-type cable command changes to nas-port-type cable after software upgrade. To use the ip subscriber nas-port-type cable command to manage the upgraded BRAS in the network management software without upgrading the network management software for BRASs, execute this command.
The NAS-Port-Type attribute configured by this command is mainly applied to the NAS-Port-Type attribute carried during RADIUS authentication and accounting.
For more information about the NAS-Port-Type attribute, see RFC 2865.
This command takes effect only on new users and does not take effect on existing users.
To execute the ip subscriber nas-port-type cable command, first execute the bras compatible old-style-commands enable command to enable compatibility with old-style commands on the BRAS.
4.     Configure the IPoE access interface type.
By default, the IPoE access interface type is Ethernet, with the code value of 15.
Display and maintenance commands for IPoE
Display entry information about abnormally logged out IPoE users.
In standalone mode:
display ip subscriber abnormal-logout [ vsrp-instance vsrp-instance-name ] [ access-type { dhcpv4 | dhcpv6 | ndrs } | { mac mac-address | ip-type { ipv4 | ipv6 } } * | { ip ipv4-address | ipv6 ipv6-address | ipv6-prefix prefix-address/prefix-length } ] [ verbose ] [ slot slot-number ]
In IRF mode:
display ip subscriber abnormal-logout [ vsrp-instance vsrp-instance-name ] [ access-type { dhcpv4 | dhcpv6 | ndrs } | { mac mac-address | ip-type { ipv4 | ipv6 } } * | { ip ipv4-address | ipv6 ipv6-address | ipv6-prefix prefix-address/prefix-length } ] [ verbose ] [ chassis chassis-number slot slot-number ]
Display information about blocked IPoE users.
In standalone mode:
display ip subscriber chasten user quiet [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | user-type { dhcp | dhcpv6 | ndrs | unclassified-ip | unclassified-ipv6 | static } ] [ verbose ] [ slot slot-number ]
In IRF mode:
display ip subscriber chasten user quiet [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | user-type { dhcp | dhcpv6 | ndrs | unclassified-ip | unclassified-ipv6 | static } ] [ verbose ] [ chassis chassis-number slot slot-number ]
Display IPoE user roaming records.
In standalone mode:
display ip subscriber roam-record { user-id user-id | mac-address mac-address | ip-address ipv4-address | ipv6-address ipv6-address | ipv6-prefix ipv6-prefix/prefix-length | interface interface-type interface-number | start-time start-time start-date [ end-time end-time end-date ] } * [ count ] [ slot slot-number ]
In IRF mode:
display ip subscriber roam-record { user-id user-id | mac-address mac-address | ip-address ipv4-address | ipv6-address ipv6-address | ipv6-prefix ipv6-prefix/prefix-length | interface interface-type interface-number | start-time start-time start-date [ end-time end-time end-date ] } * [ count ] [ chassis chassis-number slot slot-number ]
Display information about IPoE individual users who have authentication failure records but whose blocking conditions are not met.
In standalone mode:
display ip subscriber chasten user auth-failed [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | user-type { dhcp | dhcpv6 | ndrs | unclassified-ip | unclassified-ipv6 | static } ] [ slot slot-number ]
In IRF mode:
display ip subscriber chasten user auth-failed [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | user-type { dhcp | dhcpv6 | ndrs | unclassified-ip | unclassified-ipv6 | static } ] [ chassis chassis-number slot slot-number ]
Display information about auto backed-up IPoE users.
In standalone mode:
display ip subscriber auto-save { access-type { dhcpv4 | dhcpv6 | ndrs } | domain domain-name | ip-type { ipv4 | ipv6 | dual-stack } | mac-address mac-address | online | wait-recover } [ interface interface-type interface-number [ s-vlan s-vlan [ c-vlan c-vlan ] ] ] [ slot slot-number ]
In IRF mode:
display ip subscriber auto-save { access-type { dhcpv4 | dhcpv6 | ndrs } | domain domain-name | ip-type { ipv4 | ipv6 | dual-stack } | mac-address mac-address | online | wait-recover } [ interface interface-type interface-number [ s-vlan s-vlan [ c-vlan c-vlan ] ] ] [ chassis chassis-number slot slot-number ]
Display the state of the file specified for automatic IPoE user backup.
display ip subscriber auto-save file-status
Display statistics about auto backed-up IPoE users.
In standalone mode:
display ip subscriber auto-save statistics [ slot slot-number ]
In IRF mode:
display ip subscriber auto-save statistics [ chassis chassis-number slot slot-number ]
Display entries of the destination IP addresses blocked by IPoE HTTP/HTTPS attack defense.
In standalone mode:
display ip subscriber http-defense blocked-destination-ip [ slot slot-number ]
In IRF mode:
display ip subscriber http-defense blocked-destination-ip [ chassis chassis-number slot slot-number ]
Display the allowlist addresses configured for IPoE HTTP/HTTPS attack defense.
display ip subscriber http-defense free-destination-ip
Display entries of the destination IP addresses not blocked by IPoE HTTP/HTTPS attack defense.
In standalone mode:
display ip subscriber http-defense unblocked-destination-ip [ slot slot-number ]
In IRF mode:
display ip subscriber http-defense unblocked-destination-ip [ chassis chassis-number slot slot-number ]
Display information about IPoE individual sessions and static IPoE leased sessions.
display ip subscriber session interface interface-type interface-number  [ verbose ]
In standalone mode:
display ip subscriber auto-save statistics [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display ip subscriber auto-save statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display static IPoE session configuration information.
display ip subscriber static-session configuration [ interface interface-type interface-number | { description string | { ip start-ipv4-address [ end-ipv4-address ] | ipv6 start-ipv6-address [ end-ipv6-address ] | delegation-prefix start-ipv6-prefix [ end-ipv6-prefix ] prefix-length } } | domain domain-name ] [ all-vpn-instance | vpn-instance instance-name ] [ verbose ]
Display information of the unclassified-IP packet attack defense entries.
In standalone mode:
display ip subscriber unclassified-ip-defense [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address | statistics ] [ slot slot-number ]
In IRF mode:
display ip subscriber unclassified-ip-defense [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address | statistics ] [ chassis chassis-number slot slot-number ]
Display information about static user interface lists.
display static-user interface-list [ list-id ]
Clear information about abnormally logged out IPoE users.
reset ip subscriber abnormal-logout [ vsrp-instance vsrp-instance-name ]
Clear information about IPoE individual users with authentication failure records that have not met the blocking conditions.
reset ip subscriber chasten user auth-failed [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address | mac mac-address ]
Clear information about blocked IPoE users.
reset ip subscriber chasten user quiet [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address | mac mac-address ]
Clear destination IP-based IPoE HTTP/HTTPS attack defense entries.
In standalone mode:
reset ip subscriber http-defense destination-ip [ slot slot-number ] [ ip ipv4-address | ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ]
In IRF mode:
reset ip subscriber http-defense destination-ip [ chassis chassis-number slot slot-number ] [ ip ipv4-address | ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ]
Clear information of the unclassified-IP packet attack defense entries.
reset ip subscriber unclassified-ip-defense [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address ]
Clear all IPoE user roaming records.
reset ip subscriber roam-record
IPoE configuration examples(on unified network)
Example: Configuring unclassified-IP packet initiation
As shown in Figure 14, the host accesses the BRAS as an unclassified-IP user. The BRAS performs AAA for the host through the RADIUS server. This example uses the Linux Free RADIUS server.
Figure 14 Network diagram
Configure IP addresses for interfaces, and make sure devices can reach each other at Layer 3. (Details not shown.)
1.     ‍Configure the RADIUS server:
# Add BRAS IP address 4.4.4.2 and secret radius to the clients.conf file.
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Add the username and password to the users user information file. The username is the host IP address, and the password is radius.
2.2.2.2   Cleartext-Password :="radius"
2.     Configure the BRAS:
a.     Configure a RADIUS scheme:
# Create a RADIUS scheme named rs1 and enter its view.
[Device] radius scheme rs1
# Configure primary servers and keys for authentication and accounting.
[Device-radius-rs1] primary authentication 4.4.4.1
[Device-radius-rs1] primary accounting 4.4.4.1
[Device-radius-rs1] key authentication simple radius
[Device-radius-rs1] key accounting simple radius
# Exclude the ISP name from the username sent to the RADIUS server.
[Device-radius-rs1] user-name-format without-domain
[Device-radius-rs1] quit
b.     Configure the ISP domain:
# Create an ISP domain named dm1 and enter its view.
[Device] domain name dm1
# Configure dm1 to use RADIUS scheme rs1.
[Device-isp-dm1] authentication ipoe radius-scheme rs1
[Device-isp-dm1] authorization ipoe radius-scheme rs1
[Device-isp-dm1] accounting ipoe radius-scheme rs1
[Device-isp-dm1] quit
c.     Configure IPoE:
# Enable DHCP.
[Device] dhcp enable
# Enable IPoE and configure Layer 3 access mode on Ten-GigabitEthernet 0/0/16.
[Device] interface ten-gigabitethernet 0/0/16
[Device–Ten-GigabitEthernet0/0/16] ip subscriber routed enable
# Enable unclassified-IP packet initiation on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber initiator unclassified-ip enable
# Specify dm1 as the ISP domain for unclassified-IP users.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber unclassified-ip domain dm1
# Configure plaintext password radius for authentication.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber password plaintext radius
[Device–Ten-GigabitEthernet0/0/16] quit
# Display IPoE session information to verify that the host has come online.
[Device] display access-user interface ten-gigabitethernet 0/0/16
UserID      Interface            IP address              MAC address     S-/C-VLAN
            Username             Access type
            IPv6 address
0x50        XGE0/0/16            2.2.2.2                 000c-29a6-b656  -/-
            2.2.2.2              L3 IPoE dynamic(U/-)
Example: Configuring reauthentication for unclassified-IP users
The host is assigned an IP address manually or through DHCP, and accesses the BRAS in IPoE mode through a Layer 3 network.
Use the RADIUS server as the authentication, authorization, and accounting server. This section uses the Linux Free RADIUS server as an example.
Use the ip subscriber unclassified-ip username include source-ip command to make sure the username used in the first authentication is the source IP address of unclassified-IP packets.
Figure 15 Network diagram
Configure IP addresses for interfaces, and make sure devices can reach each other at Layer 3. (Details not shown)
1.     ‍Configure RADIUS server 1:
# Configure the RADIUS client.
Add the following contents to the clients.conf file.
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
The contents above configure the RADIUS client IP address as 4.4.4.2 and configure the shared key as radius.
# Configure users.
2.2.2.2  Cleartext-Password :="radius",
User-Name = “user1”,
H3c-Domain-Name = “dm2”
Then, the username and password used in the first authentication are the source IP address of packets (2.2.2.2) and radius, respectively. The username used in reauthentication is user1 and the reauthentication domain is dm2.
2.     Configure RADIUS server 2:
client 5.5.5.2/32 {
ipaddr = 5.5.5.2
netmask=32
secret=radius
The contents above configure the RADIUS client IP address as 5.5.5.2 and configure the shared key as radius.
# Configure users.
user1  Cleartext-Password :="radius"
The username and password used in reauthentication are user1 and radius, respectively.
3.     Configure Device:
a.     Configure RADIUS scheme rs1:
# Create RADIUS scheme rs1, and enter its view.
# Configure primary servers and keys for authentication and accounting in RADIUS scheme rs1.
# Configure the device to use server-assigned usernames for AAA processes subsequent to authentication.
[Device-radius-rs1] username-authorization apply
b.     Configure RADIUS scheme rs2:
# Create RADIUS scheme rs2, and enter its view.
[Device] radius scheme rs2
[Device-radius-rs2] primary authentication 5.5.5.1
[Device-radius-rs2] primary accounting 5.5.5.1
[Device-radius-rs2] key authentication simple radius
[Device-radius-rs2] key accounting simple radius
# Exclude the ISP name from the username sent to the RADIUS server in RADIUS scheme rs2.
[Device-radius-rs2] user-name-format without-domain
[Device-radius-rs2] quit
c.     Configure an ISP domain:
# Create ISP domain dm1, and enter its view.
# Configure the ISP domain to use RADIUS scheme rs1 for authentication, authorization, and accounting and authorize the remote BAS IP address pool.
# Create ISP domain dm2, and enter its view.
[Device] domain name dm2
# Configure the ISP domain to use RADIUS scheme rs2 for authentication, authorization, and accounting and authorize the remote BAS IP address pool.
[Device-isp-dm2] authentication ipoe radius-scheme rs2
[Device-isp-dm2] authorization ipoe radius-scheme rs2
[Device-isp-dm2] accounting ipoe radius-scheme rs2
[Device-isp-dm2] quit
d.     Configure IPoE:
# Enable the DHCP service.
# Enter the view of interface Ten-GigabitEthernet 0/0/16.
# Enable IPoE and configure Layer 3 access mode.
# Enable the reauthentication mode.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber authentication-method bind reauth
# Enable unclassified-IP packet initiation.
# Configure ISP domain dm1 for unclassified-IP users.
# Configure an unclassified-IP user to use the source IP address of unclassified-IP packets as the username.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber unclassified-ip username include source-ip
# Configure plaintext password radius for dynamic user authentication. In this example, a user uses this password in both the first authentication and reauthentication.
# After a user passes reauthentication, execute the following command to view the online information of the IPoE user.
            IPv6 address
            user1                L3 IPoE dynamic(U/-)
Example: Configuring DHCPv4 packet initiation (assigning a remote BAS IP address pool)
As shown in Figure 16, the host accesses the BRAS as a DHCP user. It obtains configuration information from the DHCP server. The BRAS performs AAA for the host through the RADIUS server. This example uses the Linux Free RADIUS server. After the DHCP client is abnormally logged out, the DHCP client can come online again through IPv4 packet initiation.
Figure 16 Network diagram
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Add the username and password to the users user information file. The username is the host MAC address and the password is radius.
000c29a6b656  Cleartext-Password :="radius"
2.     Configure the DHCP server:
# Enable DHCP.
<DHCP-server> system-view
[DHCP-server] dhcp enable
# Enable the DHCP server to return a DHCP-NAK message if the client notions of their IP addresses are incorrect.
[DHCP-server] dhcp server request-ip-address check
# Create an IP address pool named pool1 and enter its view.
[DHCP-server] ip pool pool1
# Specify the subnet 3.3.3.0/24 for dynamic allocation and DNS server 8.8.8.8 in the pool.
[DHCP-server-ip-pool-pool1] network 3.3.3.0 24
[DHCP-server-ip-pool-pool1] dns-list 8.8.8.8
# Specify gateway address 3.3.3.1 in the address pool.
[DHCP-server-ip-pool-pool1] gateway-list 3.3.3.1
# Exclude IP address 3.3.3.1 from dynamic allocation in the pool.
[DHCP-server-ip-pool-pool1] forbidden-ip 3.3.3.1
[DHCP-server-ip-pool-pool1] quit
# Configure the default route.
[DHCP-server] ip route-static 0.0.0.0 0 4.4.4.2
3.     Configure the BRAS:
a.     Configure the DHCP relay agent:
# Enable DHCP.
# Create a remote BAS IP address pool pool1, specify a gateway address in the address pool, exclude IP address 3.3.3.1 from dynamic allocation in the address pool, and specify a DHCP server for the address pool.
[Device] ip pool pool1 bas remote
[Device-ip-pool-pool1] gateway 3.3.3.1 24
[Device-ip-pool-pool1] forbidden-ip 3.3.3.1
[Device-ip-pool-pool1] remote-server 4.4.4.3
[Device-ip-pool-pool1] quit
b.     Configure a RADIUS scheme:
c.     Configure the ISP domain:
# Configure ISP domain dm1 to use RADIUS scheme rs1 and assign a remote BAS IP address pool.
[Device-isp-dm1] authorization-attribute ip-pool pool1
d.     Configure IPoE:
# Enable IPoE and configure Layer 2 access mode on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber l2-connected enable
# Enable unclassified-IP packet initiation on Ten-GigabitEthernet 0/0/16, and allow abnormally logged out DHCP client to come online again through IPv4 packet initiation.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber initiator unclassified-ip enable matching-user
# Specify dm1 as the ISP domain for DHCP users.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber dhcp domain dm1
            IPv6 address
0x5c        XGE0/0/16            3.3.3.2                 000c-29a6-b656  -/-
            000c29a6b656         L2 IPoE dynamic(D/-)
Example: Configuring DHCPv4 packet initiation (assigning an IP address pool group)
As shown in Figure 17, the host accesses the BRAS as a DHCP user. Users obtain IPv4 addresses from an address pool in the IP address pool group. The BRAS performs AAA for the host through the RADIUS server. This example uses the Linux Free RADIUS server.
Figure 17 Network diagram
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Add the usernames and passwords to the users user information file.
000c29a6b657  Cleartext-Password :="radius"
# Enable DHCP.
# Create an IP address pool named pool2 and enter its view.
[DHCP-server] ip pool pool2
# Specify the subnet 2.2.2.0/24 for dynamic allocation and DNS server 8.8.8.8 in the address pool.
[DHCP-server-ip-pool-pool2] network 2.2.2.0 24
[DHCP-server-ip-pool-pool2] dns-list 8.8.8.8
# Specify gateway address 2.2.2.1 in the address pool.
[DHCP-server-ip-pool-pool2] gateway-list 2.2.2.1
# Exclude IP address 2.2.2.1 from dynamic allocation in the address pool.
[DHCP-server-ip-pool-pool2] forbidden-ip 2.2.2.1
[DHCP-server-ip-pool-pool2] quit
# Create an IP address pool named pool3 and enter its view.
[DHCP-server] ip pool pool3
[DHCP-server-ip-pool-pool3] network 3.3.3.0 24
[DHCP-server-ip-pool-pool3] dns-list 8.8.8.8
[DHCP-server-ip-pool-pool3] gateway-list 3.3.3.1
[DHCP-server-ip-pool-pool3] forbidden-ip 3.3.3.1
[DHCP-server-ip-pool-pool3] quit
# Enable DHCP.
# Create a local BAS IP address pool pool1.
[Device] ip pool pool1 bas local
# Specify gateway address 1.1.1.1 and DNS server 8.8.8.8 in the address pool.
[Device-ip-pool-pool1] gateway 1.1.1.1 24
[Device-ip-pool-pool1] dns-list 8.8.8.8
# Exclude IP address 1.1.1.1 from dynamic allocation in the address pool.
[Device-ip-pool-pool1] forbidden-ip 1.1.1.1
# Create a remote BAS IP address pool pool2, specify a gateway address in the address pool, exclude IP address 2.2.2.1 from dynamic allocation in the address pool, and specify a DHCP server for the address pool.
[Device] ip pool pool2 bas remote
[Device-ip-pool-pool2] gateway 2.2.2.1 24
[Device-ip-pool-pool2] forbidden-ip 2.2.2.1
[Device-ip-pool-pool2] remote-server 4.4.4.3
[Device-ip-pool-pool2] quit
# Create a remote BAS IP address pool pool3, specify a gateway address in the address pool, exclude IP address 3.3.3.1 from dynamic allocation in the address pool, and specify a DHCP server for the address pool.
[Device] ip pool pool3 bas remote
[Device-ip-pool-pool3] gateway 3.3.3.1 24
[Device-ip-pool-pool3] forbidden-ip 3.3.3.1
[Device-ip-pool-pool3] remote-server 4.4.4.3
[Device-ip-pool-pool3] quit
# Create IP address pool group poolgroup1, and assign local BAS IP address pool pool1 and remote BAS IP address pools pool2 and pool3 to the IP address pool group.
[Device] ip pool-group poolgroup1
[Device-ip-pool-group-poolgroup1] pool pool1
[Device-ip-pool-group-poolgroup1] pool pool2
[Device-ip-pool-group-poolgroup1] pool pool3
[Device-ip-pool-group-poolgroup1] quit
# Configure ISP domain dm1 to use RADIUS scheme rs1 and assign an IP address pool group.
[Device-isp-dm1] authorization-attribute ip-pool-group poolgroup1
d.     Configure IPoE:
# Specify ISP domain dm1 as the ISP domain for DHCP users.
# After 253 users come online, display the statistics of the local DHCP address group pool1.
[Device] display dhcp server statistics pool pool1
    Total IP addresses:                254
    Free IP addresses:                 0
    Used:                              253
    Pool utilization:                  100.00%
    Bindings:
      Automatic:                       253
      Manual:                          0
      Expired:                         0
    Conflicts:                         0
The output shows that the usage of local DHCP address group pool1 is 100% and does not have allocable IP addresses.
When the resources in local IP address group pool1 are exhausted, the address resources on the DHCP server associated with remote BAS IP address pool pool2 are used to allocate IP addresses to new users.
Example: Configuring DHCPv6 packet initiation (assigning a remote IPv6 address pool)
As shown in Figure 18, the host accesses the BRAS as a DHCP user. It obtains configuration information from the DHCP server. The BRAS performs AAA for the host through the RADIUS server. This example uses the Linux Free RADIUS server.
Figure 18 Network diagram
# Add BRAS IP address 4::2 and secret radius to the clients.conf file.
client 4::2/64 {
ipaddr6 = 4::2
netmask=64
secret=radius
# Create an IPv6 address pool named pool1 and enter its view.
[DHCP-server] ipv6 pool pool1
# Specify the IPv6 subnet 3::/64 for dynamic allocation and specify DNS server 8::8 in the address pool pool1.
[DHCP-server-ipv6-pool-pool1] network 3::/64
[DHCP-server-ipv6-pool-pool1] dns-server 8::8
[DHCP-server-ipv6-pool-pool1] quit
# Enable the DHCPv6 server on Ten-GigabitEthernet 0/0/15.
[DHCP-server] interface ten-gigabitethernet 0/0/15
[DHCP-server-Ten-GigabitEthernet0/0/15] ipv6 dhcp select server
[DHCP-server-Ten-GigabitEthernet0/0/15] quit
[DHCP-server] ipv6 route-static :: 0 4::2
# Create a remote IPv6 address pool pool1, specify a gateway address in the address pool, exclude IPv6 address 3::/64 from dynamic allocation in the address pool, and specify a DHCP server for the address pool.
[Device] ipv6 pool pool1
[Device-ipv6-pool-pool1] gateway-list 3::1
[Device-ipv6-pool-pool1] network 3::/64 export-route
[Device-ipv6-pool-pool1] remote-server 4::3
[Device-ipv6-pool-pool1] quit
# Enable the DHCPv6 relay agent on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ipv6 dhcp select relay
# Automatically generate a link-local address for Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ipv6 address auto link-local
# Disable RA message suppression on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] undo ipv6 nd ra halt
# Set the managed address configuration flag (M) to 1 in RA advertisements to be sent. Then, the host uses a DHCPv6 server to obtain IPv6 addresses.
[Device–Ten-GigabitEthernet0/0/16] ipv6 nd autoconfig managed-address-flag
# Set the other stateful configuration flag (O) to 1 in RA advertisements to be sent. Then, the host uses a DHCPv6 server to obtain configuration information other than IPv6 addresses.
[Device–Ten-GigabitEthernet0/0/16] ipv6 nd autoconfig other-flag
[Device-radius-rs1] primary authentication ipv6 4::1
[Device-radius-rs1] primary accounting ipv6 4::1
# Configure ISP domain dm1 to use RADIUS scheme rs1 and assign a remote IPv6 address pool.
[Device-isp-dm1] authorization-attribute ipv6-pool pool1
d.     Configure IPoE:
# Display IPoE session information to verify that the host has come online and obtained IPv6 address 3::2.
            IPv6 address
0x2c2       XGE0/0/16            -                       000c-29a6-b656  -/-
            000c29a6b656         L2 IPoE dynamic(-/D)
            3::2
Example: Configuring IPv6 ND RS packet initiation (AAA-authorized prefix)
As shown in Figure 19, the host accesses the BRAS as an IPv6 ND RS user. The BRAS performs AAA for the host through the RADIUS server. This example uses the Linux Free RADIUS server.
Figure 19 Network diagram
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Add the username and password to the users user information file. The username is the host MAC address, the password is radius, and the authorized IPv6 prefix is 10::/64.
 Framed-IPv6-Prefix =10::/64
a.     Disable RA message suppression on Ten-GigabitEthernet 0/0/16.
b.     Automatically generate a link-local address for Ten-GigabitEthernet 0/0/16.
c.     Configure a RADIUS scheme:
d.     Create an IPv6 address pool and enter its view. Specify the subnet for DHCPv6 clients and advertise the subnet route.
[Device-ipv6-pool-pool1] network 10::/64 export-route
e.     Configure the ISP domain:
# Authorize a IPv6 DNS address pool to users.
[Device-isp-dm1] authorization-attribute primary-dns ipv6 8::8
f.     Configure IPoE:
# Enable IPv6 ND RS packet initiation on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber initiator ndrs enable
# Specify dm1 as the ISP domain for IPv6 ND RS users.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber ndrs domain dm1
            IPv6 address
0xc         XGE0/0/16            -                       000c-29a6-b656  -/-
            000c29a6b656         L2 IPoE dynamic(-/N)
            10::20C:29FF:FEA6:B656
Example: Configuring IPv6 ND RS packet initiation (ND prefix pool-authorized prefix)
Figure 20 Network diagram
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Add the username and password to the users user information file. The username is the host MAC address, and the password is radius.
c.     Configure the ND prefix pool:
# Create prefix pool 1 that contains the prefix 10::/32 and specify the length of prefixes to be assigned as 64. Prefix pool 1 can assign 4294967296 prefixes in the range of 10::/64 to 10:0:FFFF:FFFF::/64.
[Device] ipv6 dhcp prefix-pool 1 prefix 10::/32 assign-len 64
# Create an IPv6 address pool named pool1, and reference prefix pool 1.
[Device-ipv6-pool-pool1] prefix-pool 1 export-route
d.     Configure a RADIUS scheme:
# Configure dm1 to use RADIUS scheme rs1, and authorize an ND prefix pool and IPv6 DNS address pool to users.
[Device-isp-dm1] authorization-attribute ipv6-nd-prefix-pool pool1
f.     Configure IPoE:
            IPv6 address
Example: Configuring IPv6 ND RS+DHCPv6 (IA_PD) initiation
As shown in Figure 21, the CPE supports applying for ND prefixes and PD prefixes from the BRAS through the following methods:
·     NDRA—The CPE actively sends an ND RS packet to the BRAS. The BRAS returns an ND prefix to the connected CPE interface Ten-GigabitEthernet 0/0/15 through an ND RA packet. The CPE uses the ND prefix to generate a global unicast IPv6 address for the CPE interface Ten-GigabitEthernet 0/0/15. The IPv6 address is used for remotely managing the CPE.
·     IA_PD—The CPE actively sends DHCPv6 requests to the CPE. The BRAS allocates a PD prefix to the CPE through DHCPv6 (IA_PD). The CPE automatically allocates the obtained PD prefix to the attached hosts. These hosts use the PD prefix to generate global unicast IPv6 addresses.
Figure 21 Network diagram
1.     ‍Configuring the RADIUS server:
# Configure the RADIUS client IP address as 4.4.4.2 and configure the shared key as radius.
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Add the username and password to the users user information file. The username is the host MAC address 6a4c310a0207 and the password is radius.
6a4c310a0207  Cleartext-Password :="radius"
2.     Configure Router B:
a.     Configure IP addresses for interfaces. (Details not shown.)
b.     Disable RA message suppression on Ten-GigabitEthernet 0/0/16.
<RouterB> system-view
[RouterB] interface ten-gigabitethernet 0/0/16
[RouterB–Ten-GigabitEthernet0/0/16] undo ipv6 nd ra halt
c.      Automatically generate a link-local address for Ten-GigabitEthernet 0/0/16.
[RouterB–Ten-GigabitEthernet0/0/16] ipv6 address auto link-local
d.     Enable the DHCPv6 server on Ten-GigabitEthernet 0/0/16.
[RouterB–Ten-GigabitEthernet0/0/16] ipv6 dhcp select server
[RouterB–Ten-GigabitEthernet0/0/16] quit
e.     Configure the ND prefix pool and PD prefix pool:
# (For NDRS.) Create prefix pool 1 that contains the prefix 10::/32 and specify the length of prefixes to be assigned as 64. Prefix pool 1 can assign 4294967296 prefixes in the range of 10::/64 to 10:0:FFFF:FFFF::/64.
[RouterB] ipv6 dhcp prefix-pool 1 prefix 10::/32 assign-len 64
# Create an IPv6 address pool named nd, and reference prefix pool 1.
[RouterB] ipv6 pool nd
[RouterB-ipv6-pool-nd] prefix-pool 1 export-route
[RouterB-ipv6-pool-nd] quit
# (For IA_PD.) Create prefix pool 2 that contains the prefix 20::/32 and specify the length of prefixes to be assigned as 64. Prefix pool 2 can assign 4294967296 prefixes in the range of 20::/64 to 20:0:FFFF:FFFF::/64. NOTE: The maximum length of prefixes assigned by a PD prefix pool is 120 bits.
[RouterB] ipv6 dhcp prefix-pool 2 prefix 20::/32 assign-len 64
# Create an IPv6 address pool named pd, and reference prefix pool 2.
[RouterB] ipv6 pool pd
[RouterB-ipv6-pool-pd] prefix-pool 2 export-route
[RouterB-ipv6-pool-pd] quit
f.     Configure a RADIUS scheme:
[RouterB] radius scheme rs1
[RouterB-radius-rs1] primary authentication 4.4.4.1
[RouterB-radius-rs1] primary accounting 4.4.4.1
[RouterB-radius-rs1] key authentication simple radius
[RouterB-radius-rs1] key accounting simple radius
[RouterB-radius-rs1] user-name-format without-domain
[RouterB-radius-rs1] quit
g.     Configuring ISP domains:
[RouterB] domain name dm1
# Configure dm1 to use RADIUS scheme rs1, and authorize ND prefix pool nd and PD prefix pool pd to users.
[RouterB-isp-dm1] authentication ipoe radius-scheme rs1
[RouterB-isp-dm1] authorization ipoe radius-scheme rs1
[RouterB-isp-dm1] accounting ipoe radius-scheme rs1
[RouterB-isp-dm1] authorization-attribute ipv6-pool pd
[RouterB-isp-dm1] authorization-attribute ipv6-nd-prefix-pool nd
[RouterB-isp-dm1] quit
h.     Configuring IPoE:
[RouterB–Ten-GigabitEthernet0/0/16] ip subscriber l2-connected enable
[RouterB–Ten-GigabitEthernet0/0/16] ip subscriber initiator ndrs enable
# Specify dm1 as the ISP domain for IPv6 DHCP users on Ten-GigabitEthernet 0/0/16.
[RouterB–Ten-GigabitEthernet0/0/16] ip subscriber dhcp domain dm1
# Specify dm1 as the ISP domain for IPv6 ND RS users on Ten-GigabitEthernet 0/0/16.
[RouterB–Ten-GigabitEthernet0/0/16] ip subscriber ndrs domain dm1
# Allow users to come online through ND RS only after they come online through IA_PD on Ten-GigabitEthernet 0/0/16.
[RouterB–Ten-GigabitEthernet0/0/16] ip subscriber ndrs wait-delegation-prefix
# Configure plaintext password radius for authentication on Ten-GigabitEthernet 0/0/16.
[RouterB–Ten-GigabitEthernet0/0/16] ip subscriber password plaintext radius
3.     Configure Router A:
a.     Automatically generate a link-local address for Ten-GigabitEthernet 0/0/15.
[RouterA] interface ten-gigabitethernet 0/0/15
[RouterA–Ten-GigabitEthernet0/0/15] ipv6 address auto
b.     Configure Ten-GigabitEthernet 0/0/15 as the DHCPv6 client to use DHCPv6 to obtain an IPv6 prefix and other configuration parameters. After obtaining an IPv6 prefix, the client assigns ID 1 to the IPv6 prefix.
[RouterA–Ten-GigabitEthernet0/0/15] ipv6 dhcp client pd 1
[RouterA–Ten-GigabitEthernet0/0/15] quit
c.     Configure the default route.
[RouterA] ipv6 route-static :: 0 10::1
d.     Disable RA message suppression on Ten-GigabitEthernet 0/0/16.
[RouterA] interface ten-gigabitethernet 0/0/16
[RouterA-Ten-GigabitEthernet0/0/16] undo ipv6 nd ra halt
e.     Configure Ten-GigabitEthernet 0/0/16 to use IPv6 prefix 1 to generate the IPv6 address 20::123:1:1 (which must be configured as the gateway for users attached to the CPE) and advertise this prefix.
[RouterA-Ten-GigabitEthernet0/0/16] ipv6 address 1 123::123:1:1/64
[RouterA-Ten-GigabitEthernet0/0/16] quit
# The client uses ND RS and IA_PD packets to initiate authentication. After the client comes online, use the following command to view online IPoE user information. The output shows that the user obtains ND prefix 10:: and PD prefix 20::/64.
[RouterB] display access-user verbose
Basic:
  Description: N/A
  User ID: 0x1d
  Username: 6a4c310a0207
  Authorization domain : dm1
  Authentication domain: dm1
  Interface: XGE0/0/16
  Service-VLAN/Customer-VLAN: -/-
  VXLAN ID: -
  MAC address: 6a4c-310a-0207
  IP address: -
  IP pool: -
  Primary DNS server: -
  Secondary DNS server: -
  IPv6 address: 10::684C:31FF:FE0A:207
  IPv6 pool: pd
  Primary IPv6 DNS server: -
  Secondary IPv6 DNS server: -
  IPv6 PD prefix: 20::/64
  IPv6 ND prefix: 10::/64
…Omitted…
The output shows that Router B assigns a PD prefix to Router A through DHCPv6.
# Display information about IPv6 prefixes created on Router A.
[RouterA] display ipv6 prefix
Number   Prefix                                     Type
1        20::/64                                    Dynamic
The output shows that Router A creates an IPv6 prefix with ID 1 according to the ipv6 dhcp client pd 1 command after obtaining a PD prefix from Router B.
Example: Configuring ARP packet initiation
As shown in Figure 22, an ARP-initiated static user accesses the BRAS through a Layer 2 device and is assigned the gateway IP address 3.3.3.1. The BRAS performs AAA for the host through the RADIUS server. This example uses the Linux Free RADIUS server.
Figure 22 Network diagram
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Add the username and password to the users user information file. The username is the host IP address 3.3.3.2. The password is radius.
3.3.3.2   Cleartext-Password :="radius"
# Configure ISP domain dm1 to use RADIUS scheme rs1.
c.     Configure the DHCP server.
# Enable DHCP globally.
[Device] dhcp server request-ip-address check
# Create local BAS IP address pool pool1, and specify the user gateway address. Exclude IP address 3.3.3.2 (which must be the IP address specified in static IPoE session configuration) from dynamic allocation.
[Device-ip-pool-pool1] forbidden-ip 3.3.3.2
d.     Configure IPoE:
# Enable ARP packet initiation on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber initiator arp enable
# Configure a static individual session with IP address 3.3.3.2 (which must be excluded from dynamic allocation in the IP address pool) and ISP domain dm1 on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber session static ip 3.3.3.2 domain dm1
            IPv6 address
0x10        XGE0/0/16            3.3.3.2                 147b-1924-0206  -/-
            3.3.3.2              L2 IPoE static
Example: Configuring NS/NA packet initiation
As shown in Figure 23, the host accesses the BRAS as a static NS/NA user. The BRAS performs AAA for the host through the RADIUS server. This example uses the Linux Free RADIUS server.
Figure 23 Network diagram
client 4::2/64 {
ipaddr6 = 4::2
netmask=64
secret=radius
# Add the username and password to the users user information file. The username is the host IP address 3::1 and the password is radius.
3::1  Cleartext-Password :="radius"
c.     Configure the DHCP server:
# Create an IPv6 address pool, and enter its view. Specify a subnet for dynamic address allocation in the address pool, and exclude IPv6 address 3::1 from the address pool for dynamic allocation.
[Device-ipv6-pool-pool1] forbidden-address 3::1
d.     Configure IPoE:
# Automatically generate a link-local address for Ten-GigabitEthernet 0/0/16. The IPv6 address is to be used as the gateway of users.
# Enable NS/NA packet initiation on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber initiator nsna enable
# Create a static session with the IPv6 address 3::1 and authentication domain dm1.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber session static ipv6 3::1 domain dm1
[Device] display access-user interface Ten-GigabitEthernet 0/0/16
            IPv6 address
0x4         XGE0/0/16                -                   0010-9400-0002 -/-
            3::1                     L2 IPoE static
            3::1
Example: Configuring unclassified-IP packet initiation for static IPoE users with IPv6 PD prefixes
As shown in Figure 24, Host A and Host B attached to the Layer 3 device Device use the same IPv6 address prefix (20::/64) and both obtain IPv6 addresses through stateless automatic configuration.
The BRAS uses the IPoE static user online method to enable all attached hosts to come online through IPv6 packets and performs unified authentication, accounting, rate limiting, and management for these user packets using the same IPv6 address prefix.
Figure 24 Network diagram
client 4::2/64 {
ipaddr6 = 4::2
netmask=64
secret=radius
The contents above configure the RADIUS client IP address as 4::2 and configure the shared key as radius.
# Configure users.
Add the following contents to the users file:
10::2  Cleartext-Password :="radius"
# Add the username and password to the users user information file. The username is 10::2 and the password is radius.
<BRAS> system-view
[BRAS] radius scheme rs1
[BRAS-radius-rs1] primary authentication ipv6 4::1
[BRAS-radius-rs1] primary accounting ipv6 4::1
[BRAS-radius-rs1] key authentication simple radius
[BRAS-radius-rs1] key accounting simple radius
[BRAS-radius-rs1] user-name-format without-domain
[BRAS-radius-rs1] quit
b.     Configure an ISP domain:
[BRAS] domain name dm1
# Configure users to use RADIUS scheme rs1 for authentication, authorization, and accounting in the ISP domain.
[BRAS-isp-dm1] authentication ipoe radius-scheme rs1
[BRAS-isp-dm1] authorization ipoe radius-scheme rs1
[BRAS-isp-dm1] accounting ipoe radius-scheme rs1
[BRAS-isp-dm1] quit
# Create a local BAS IP address pool named pool1. Specify the network for address allocation in the address pool. Exclude IPv6 address 10::2 (which must be the same as the user address specified in the IPoE static session) from the address pool for dynamic allocation.
[BRAS] ipv6 pool pool1
[BRAS-ipv6-pool-pool1] network 10::/64 export-route
[BRAS-ipv6-pool-pool1] forbidden-address 10::2
[BRAS-ip-pool-pool1] quit
d.     Configure IPoE:
# Configure a global IPoE static session to allow users with IPv6 address 10::2 on prefix network segment 20::/64 to come online as static users, and configure the BRAS to actively request users to come online.
[BRAS] ip subscriber session static ipv6 10::2 delegation-prefix 20:: 64 domain dm1 interface ten-gigabitethernet 0/0/16 request-online
# Enter the view of interface Ten-GigabitEthernet0/0/16.
[BRAS] interface ten-gigabitethernet 0/0/16
# Enable IPoE and configure Layer 2 access mode.
[BRAS–Ten-GigabitEthernet0/0/16] ip subscriber l2-connected enable
# Enable unclassified-IPv6 packet initiation and NS/NA packet initiation.
[BRAS–Ten-GigabitEthernet0/0/16] ip subscriber initiator unclassified-ipv6 enable matching-user
[BRAS–Ten-GigabitEthernet0/0/16] ip subscriber initiator nsna enable
# Configure the password as radius for the IPoE individual users.
[BRAS–Ten-GigabitEthernet0/0/16] ip subscriber password plaintext radius
[BRAS–Ten-GigabitEthernet0/0/16] quit
# Generate an IPv6 address based on an IPv6 prefix on the interface, and assign the prefix to endpoints.
[Device] ipv6 prefix 1 20::/64
[Device–Ten-GigabitEthernet0/0/16] ipv6 address 1 ::1/64
# After Host A sends IPv6 packets and passes authentication, execute the following command to view online information of IPoE users.
[BRAS] display access-user interface ten-gigabitethernet 0/0/16
            IPv6 address
            10::2                    L2 IPoE static
            10::2
Example: Configuring subnet-leased users
As shown in Figure 25, three hosts access the BRAS as subnet-leased users. The BRAS performs AAA for the hosts through the RADIUS server. This example uses the Linux Free RADIUS server.
Figure 25 Network diagram
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Add usernames and passwords to the users user information file. Usernames for the three subnet user groups are us1, us2, and us3. Passwords for the three subnet user groups are pw1, pw2, and pw3.
us1  Cleartext-Password :="pw1"
us2  Cleartext-Password :="pw2"
us3  Cleartext-Password :="pw3"
c.     Configure IPoE:
# Enable DHCP.
# Configure three subnet-leased users and specify their usernames, passwords, and ISP domains.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber subnet-leased ip 5.5.5.0 24 username us1 password plaintext pw1 domain dm1
[Device–Ten-GigabitEthernet0/0/16] ip subscriber subnet-leased ip 6.6.6.0 24 username us2 password plaintext pw2 domain dm1
[Device–Ten-GigabitEthernet0/0/16] ip subscriber subnet-leased ip 7.7.7.0 24 username us3 password plaintext pw3 domain dm1
            IPv6 address
0x16        XGE0/0/16           5.5.5.0          -              -/-
            us1                 L3 IPoE subnet leased
0x17        XGE0/0/16           6.6.6.0          -              -/-
            us2                 L3 IPoE subnet leased
0x18        XGE0/0/16           7.7.7.0          -              -/-
            us3                 L3 IPoE subnet leased
Example: Configuring an interface-leased user
As shown in Figure 26, three hosts access the BRAS as one interface-leased user. The BRAS performs AAA for the hosts through the RADIUS server. This example uses the Linux Free RADIUS server.
Figure 26 Network diagram
# Add the BRAS IP address 4.4.4.2 and the secret radius to the clients.conf file.
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Add host username and password to the users user information file. The username is us1 and the password is pw1.
c.     Configure IPoE:
# Enable DHCP.
# Configure the interface-leased user and specify its username, password, and ISP domain.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber interface-leased username us1 password plaintext pw1 domain dm1
            IPv6 address
0xec        XGE0/0/16            -                -                 -/-
            us1                  L3 IPoE interface leased
Example: Configuring an L2VPN-leased user
As shown in Figure 27, an L2VPN-leased host accesses the BRAS through a Layer 2 device. The BRAS performs AAA for the hosts through the RADIUS server. The username and password are us1 and pw1, respectively. This example uses the Linux Free RADIUS server.
Figure 27 Network diagram
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
2.     Configure PE 2:
# Configure an LSR ID.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 2.2.2.9
# Enable L2VPN.
[PE2] l2vpn enable
# Enable LDP globally.
[PE2] mpls ldp
[PE2-ldp] quit
# Configure Ten-GigabitEthernet 0/0/16 (the interface connected to PE 1), and enable LDP on the interface.
[PE2] interface ten-gigabitethernet 0/0/16
[PE2-Ten-GigabitEthernet0/0/16] ip address 20.1.1.2 24
[PE2-Ten-GigabitEthernet0/0/16] mpls enable
[PE2-Ten-GigabitEthernet0/0/16] mpls ldp enable
[PE2-Ten-GigabitEthernet0/0/16] quit
# Configure OSPF for LDP to create LSPs.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1] quit
# Create a VSI and configure the peer PE.
[PE2] vsi vpn1
[PE2-vsi-vpn1] pwsignaling static
[PE2-vsi-vpn1-static] peer 1.1.1.9 pw-id 3 in-label 100 out-label 100
[PE2-vsi-vpn1-static-1.1.1.9-3] quit
[PE2-vsi-vpn1-static] quit
[PE2-vsi-vpn1] quit
# Bind Ten-GigabitEthernet 0/0/15 to the VSI. Ten-GigabitEthernet 0/0/15 does not require IP address configuration.
[PE2] interface ten-gigabitethernet 0/0/15
[PE2-Ten-GigabitEthernet0/0/15] xconnect vsi vpn1
[PE2-Ten-GigabitEthernet0/0/15] quit
3.     Configure PE1:
a.     Configure VPLS:
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.9
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
# Configure Ten-GigabitEthernet 0/0/16 (the interface connected to PE 2), and enable LDP on the interface.
[PE1] interface ten-gigabitethernet 0/0/16
[PE1-Ten-GigabitEthernet0/0/16] ip address 20.1.1.1 24
[PE1-Ten-GigabitEthernet0/0/16] mpls enable
[PE1-Ten-GigabitEthernet0/0/16] mpls ldp enable
[PE1-Ten-GigabitEthernet0/0/16] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
[PE1] vsi vpn1
[PE1-vsi-vpn1] pwsignaling static
[PE1-vsi-vpn1-static] peer 2.2.2.9 pw-id 3 in-label 100 out-label 100
[PE1-vsi-vpn1-static-2.2.2.9-3] quit
[PE1-vsi-vpn1-static] quit
[PE1-vsi-vpn1] quit
[PE1] interface ten-gigabitethernet 0/0/15
[PE1-Ten-GigabitEthernet0/0/15] xconnect vsi vpn1
[PE1-Ten-GigabitEthernet0/0/15] quit
<PE1> system-view
[PE1] radius scheme rs1
[PE1-radius-rs1] primary authentication 4.4.4.1
[PE1-radius-rs1] primary accounting 4.4.4.1
[PE1-radius-rs1] key authentication simple radius
[PE1-radius-rs1] key accounting simple radius
[PE1-radius-rs1] user-name-format without-domain
[PE1-radius-rs1] quit
[PE1] domain name dm1
[PE1-isp-dm1] authentication ipoe radius-scheme rs1
[PE1-isp-dm1] authorization ipoe radius-scheme rs1
[PE1-isp-dm1] accounting ipoe radius-scheme rs1
[PE1-isp-dm1] quit
d.     Configure IPoE:
# Enable DHCP.
[PE1] dhcp enable
# Enable IPoE and configure Layer 2 access mode on Ten-GigabitEthernet 0/0/15.
[PE1–Ten-GigabitEthernet0/0/15] ip subscriber l2-connected enable
# Configure the L2VPN-leased user and specify the username, password, and ISP domain for the user.
[PE1–Ten-GigabitEthernet0/0/15] ip subscriber l2vpn-leased username us1 password plaintext pw1 domain dm1
[PE1–Ten-GigabitEthernet0/0/15] quit
[PE1] display access-user interface ten-gigabitethernet 0/0/16
            IPv6 address
0xec        XGE0/0/15            -                -                 -/-
            us1                  IPoE L2VPN leased
Example: Configuring IPoE static leased users
All users on subnet 192.168.1.0/24 access the BRAS as IPoE static leased users through a gateway.
When the static leased session performs authentication, it uses username us1 and password pw1.
Figure 28 Network diagram
1.     ‍‍Configure the RADIUS server:
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Configure users.
# Add the username and password to the users user information file. The username is us1 and the password is pw1.
2.     Configure the gateway device:
# Enable DHCP.
<Gateway> system-view
[Gateway] dhcp enable
# Configure IP address pool pool1 to allocate private IPv4 addresses to internal network users.
[Gateway] ip pool pool1
[Gateway-ip-pool-pool1] network 192.168.1.0 24
[Gateway-ip-pool-pool1] gateway-list 192.168.1.1
[Gateway-ip-pool-pool1] dns-list 8.8.8.8
# Exclude IP address 192.168.1.1 from dynamic allocation.
[Gateway-ip-pool-pool1] forbidden-ip 192.168.1.1
[Gateway-ip-pool-pool1] quit
# Configure the IPv4 gateway address for internal network users on Ten-GigabitEthernet 0/0/16.
[Gateway] interface ten-gigabitethernet 0/0/16
[Gateway-Ten-GigabitEthernet0/0/16] ip address 192.168.1.1 24
# Configure an IPv6 global unicast address and disable RA message suppression on the interface.
[Gateway-Ten-GigabitEthernet0/0/16] ipv6 address 192::1/64
[Gateway-Ten-GigabitEthernet0/0/16] undo ipv6 nd ra halt
[Gateway-Ten-GigabitEthernet0/0/16] quit
# Enter the view of interface Ten-GigabitEthernet 0/0/15.
[Gateway] interface ten-gigabitethernet 0/0/15
# Configure an IPv4 address for the interface.
[Gateway-Ten-GigabitEthernet0/0/15] ip address 3.3.3.2 24
# (For IPv4.) Directly use the IP address of interface Ten-GigabitEthernet 0/0/15 to perform NAT for IP traffic from the internal network to the external network.
[Gateway-Ten-GigabitEthernet0/0/15] nat outbound
# Configure an IPv6 global multicast address for the interface.
[Gateway-Ten-GigabitEthernet0/0/15] ipv6 address 3::2/64
[Gateway] ip route-static 0.0.0.0 0 3.3.3.1  //The next hop is the shared gateway address
[Gateway] ipv6 route-static :: 0 3::1 //The next hop can be any IPv6 global unicast address on the same network segment as address 3::2/64 of interface Ten-GigabitEthernet0/0/15.
a.     ‍Configure IP addresses for interfaces. (Details not shown.)
b.     Configuring a RADIUS scheme:
# Consider a user as idle and forcibly log out the user if the user generates less than 10240 bytes of data traffic within the detection period of 30 minutes.
[Device-isp-dm1] authorization-attribute idle-cut 30 10240
d.     Configure the DHCP server:
# Create a local BAS IP address pool named pool1. Specify a gateway for the address pool. Exclude IP addresses 3.3.3.1 and 3.3.3.2 (which must be the same as the user address specified in the IPoE static session) from the address pool for dynamic allocation.
[Device-ip-pool-pool1] forbidden-ip 3.3.3.1 3.3.3.2
# Create an IPv6 address pool named pool1. Specify a gateway for the address pool. Exclude IP addresses 3::1 and 3::2 (which must be the same as the user addresses specified in the IPoE static sessions) from the address pool for dynamic allocation.
[Device-ipv6-pool-pool1] forbidden-address 3::1 3::2
e.     Configure a static route.
# Configure a static route for downlink traffic from the BRAS to the user side.
[Device] ipv6 route-static 192:: 64 3::2
f.     Configure IPoE authentication:
# Configure a static leased session with IPv4 address 3.3.3.2, IPv6 address 3::2, and domain dm1, and actively request users to come online.
[Device] ip subscriber session static-leased ip 3.3.3.2 ipv6 3::2 interface GigabitEthernet 1/0/2 domain dm1 request-online
# Automatically generate a link-local address for the interface.
# Configure unclassified-IP packet initiation for IPoE static individual users.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber initiator unclassified-ipv6 enable matching-user
# Enable ARP packet initiation.
# Enable NS/NA packet initiation.
# Configure the username and password of the static individual IPoE user as us1 and pw1.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber username string us1
[Device–Ten-GigabitEthernet0/0/16] ip subscriber password plaintext pw1
# Disable online user detection.
[Device–Ten-GigabitEthernet0/0/16] undo ip subscriber user-detect ip
[Device–Ten-GigabitEthernet0/0/16] undo ip subscriber user-detect ipv6
# After the static leased user passes authentication, all user traffic passing through the interface can be forwarded properly. Execute the following command to view online information of the IPoE static leased users.
            IPv6 address
            us1                  L2 IPoE static
            3::2
Example: Configuring a VPN DHCP user
As shown in Figure 29, the host in a VPN accesses the BRAS as a DHCP user. The BRAS performs AAA for the host through the RADIUS server. This example uses the Linux Free RADIUS server.
Figure 29 Network diagram
Analysis
For traffic to be properly forwarded  between VPNs, configure static routes and policy-based routes on the device.
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Add host username, password, VPN, and address pool to the users user information file. The username is the host MAC address, the password is radius, the VPN is vpn1, and the address pool is pool1.
 H3C-VPN-Instance :="vpn1",
 Framed-Pool := " pool1"
# Enable DHCP.
# Specify the subnet 3.3.3.0/24 for dynamic allocation in the pool.
c.     Create a VPN instance named vpn1.
[Device] ip vpn-instance vpn1
[Device-vpn-instance-vpn1] quit
d.     Configure the DHCP relay agent:
# Enable DHCP.
# Enable the DHCP relay agent on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] dhcp select relay
# Create an address pool named pool1 and assign pool1 to vpn1.
[Device-ip-pool-pool1] vpn-instance vpn1
# Configure a gateway IP address for the host and enable route exporting. Route exporting automatically adds the gateway IP address and related static IP address to the routing table of vpn1.
# Exclude IP address 3.3.3.1 from dynamic allocation in the address pool.
# Configure an IP address for the DHCP sever
e.     Configure IPoE:
f.     Enable proxy ARP on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] proxy-arp enable
g.     Configure a static route to direct the DHCP requests from VPN vpn1 to the DHCP server.
[Device] ip route-static vpn-instance vpn1 4.4.4.0 24 4.4.4.3 public
h.     Configure a policy-based route to direct the traffic from the DHCP server to VPN vpn1:
# Configure a policy named to_vpn1 with a node number of 0 and match mode of permit, and specify packets to be transmitted in VPN vpn1.
[Device] policy-based-route to_vpn1 permit node 0
[Device-pbr-to_vpn1-0] apply access-vpn vpn-instance vpn1
[Device-pbr-to_vpn1-0] quit
# Apply policy to_vpn1 to Ten-GigabitEthernet 0/0/15.
[Device] interface ten-gigabitethernet 0/0/15
[Device–Ten-GigabitEthernet0/0/15] ip policy-based-route to_vpn1
[Device–Ten-GigabitEthernet0/0/15] quit
# Display IPoE session information to verify the configuration.
[Device]display access-user interface ten-gigabitethernet 0/0/16
            IPv6 address
0xf8        XGE0/0/16            3.3.3.2                 000c-29a6-b656  -/-
Example: Configuring IPoE common Web authentication for static individual users
As shown in Figure 30, the host accesses the BRAS through a Layer 2 switch. A server installed with H3C IMC acts as the RADIUS server, the portal authentication server, and the portal Web server. This example uses IMC PLAT 7.1(E0303), IMC UAM 7.1(E0305), and IMC EIP 7.1(E0305). The FTP server is an internal network server.
Figure 30 Network diagram
1.     ‍‍Configure the BRAS:
a.     ‍‍Configure the IP address of the portal authentication server newpt as 4.4.4.5 and the plaintext key 123456.
[Device] portal server newpt
[Device-portal-server-newpt] ip 4.4.4.5 key simple 123456
[Device-portal-server-newpt] quit
b.     Specify 11111 as the HTTPS redirect listening port number. Make sure the port number is not used by any other service. To see the TCP port numbers used by other services, execute the display tcp command.
[Device] http-redirect https-port 11111
c.     Configure the device to get user access information from ARP and ND entries.
[Device] portal access-info trust arp
[Device] portal access-info trust nd
d.     Create a local user group named pre.
[Device] user-group pre
New user group added.
[Device-ugroup-pre] quit
e.     Configure ACLs for preauthentication:
# Create an IPv4 advanced ACL named web_permit. Configure a rule to permit all packets destined for the portal server from users in user group pre.
[Device] acl advanced name web_permit
[Device-acl-ipv4-adv-web_permit] rule 0 permit ip destination 4.4.4.5 0 user-group pre
[Device-acl-ipv4-adv-web_permit] quit
# Create an IPv4 advanced ACL named neiwang. Configure a rule to permit all packets destined for the internal network server from users in user group pre.
[Device] acl advanced name neiwang
[Device-acl-ipv4-adv-neiwang] rule 0 permit ip destination 4.4.4.6 0 user-group pre
[Device-acl-ipv4-adv-neiwang] quit
# Create an IPv4 advanced ACL named web_http. Configure a rule to permit TCP packets with the destination port 80 (HTTP packets) from users in user group pre.
[Device] acl advanced name web_http
[Device-acl-ipv4-adv-web_http] rule 0 permit tcp destination-port eq www user-group pre
[Device-acl-ipv4-adv-web_http] quit
# Create an IPv4 advanced ACL named web_https, and configure a rule to permit TCP packets with the destination port 443 (HTTPS packets) from users in user group pre.
[Device] acl advanced name web_https
[Device-acl-ipv4-adv-web_https] rule 0 permit tcp destination-port eq 443 user-group pre
[Device-acl-ipv4-adv-web_https] quit
# Create an IPv4 advanced ACL named ip, and configure a rule to permit IP packets from users in user group pre.
[Device] acl advanced name ip
[Device-acl-ipv4-adv-ip] rule 0 permit ip user-group pre
[Device-acl-ipv4-adv-ip] quit
# Create an IPv4 advanced ACL named neiwang_out, and configure a rule to permit IP packets from the internal network server in user group pre.
[Device] acl advanced name neiwang_out
[Device-acl-ipv4-adv-neiwang_out] rule 0 permit ip source 4.4.4.4 0 user-group pre
[Device-acl-ipv4-adv-neiwang_out] quit
# Create an IPv4 advanced ACL named web_out, and configure a rule to permit IP packets from the portal server in user group pre.
[Device] acl advanced name web_out
[Device-acl-ipv4-adv-web_out] rule 0 permit ip source 4.4.4.5 0 user-group pre
[Device-acl-ipv4-adv-web_out] quit
f.     Configure QoS traffic classes for preauthentication users:
# Create the traffic class web_permit and specify ACL web_permit as the match criterion.
[Device] traffic classifier web_permit operator and
[Device-classifier-web_permit] if-match acl name web_permit
[Device-classifier-web_permit] quit
# Create the traffic class neiwang and specify ACL neiwang as the match criterion.
[Device] traffic classifier neiwang operator and
[Device-classifier-neiwang] if-match acl name neiwang
[Device-classifier-neiwang] quit
# Create the traffic class web_http and specify ACL web_http as the match criterion.
[Device] traffic classifier web_http operator and
[Device-classifier-web_http] if-match acl name web_http
[Device-classifier-web_http] quit
# Create the traffic class web_https and specify ACL web_https as the match criterion.
[Device] traffic classifier web_https operator and
[Device-classifier-web_https] if-match acl name web_https
[Device-classifier-web_https] quit
# Create the traffic class web_deny and specify ACL ip as the match criterion.
[Device] traffic classifier web_deny operator and
[Device-classifier-web_deny] if-match acl name ip
[Device-classifier-web_deny] quit
# Create the traffic class neiwang_out and specify ACL neiwang_out as the match criterion.
[Device] traffic classifier neiwang_out operator and
[Device-classifier-neiwang_out] if-match acl name neiwang_out
[Device-classifier-neiwang_out] quit
# Create the traffic class web_out and specify ACL web_out as the match criterion.
[Device] traffic classifier web_out operator and
[Device-classifier-web_out] if-match acl name web_out
[Device-classifier-web_out] quit
g.     Configure QoS traffic behaviors:
# Configure the traffic behavior web_permit to permit traffic to pass through without rate limiting or accounting.
[Device] traffic behavior web_permit
[Device-behavior-web_permit] filter permit
[Device-behavior-web_permit] free account
[Device-behavior-web_permit] quit
# Configure the traffic behavior neiwang to permit traffic to pass through.
[Device] traffic behavior neiwang
[Device-behavior-neiwang] filter permit
[Device-behavior-neiwang] quit
# Configure the traffic behavior web_http to redirect HTTP packets to the CPU.
[Device] traffic behavior web_http
[Device-behavior-web_http] redirect http-to-cpu
[Device-behavior-web_http] quit
# Configure the traffic behavior web_https to redirect HTTPS packets to the CPU.
[Device] traffic behavior web_https
[Device-behavior-web_https] redirect https-to-cpu
[Device-behavior-web_https] quit
# Configure the traffic behavior web_deny to deny traffic.
[Device] traffic behavior web_deny
[Device-behavior-web_deny] filter deny
[Device-behavior-web_deny] free account
[Device-behavior-web_deny] quit
# Configure the traffic behavior neiwang_out to permit traffic to pass through.
[Device] traffic behavior neiwang_out
[Device-behavior-neiwang_out] filter permit
[Device-behavior-neiwang_out] quit
# Configure the traffic behavior web_out to permit traffic without rate limiting or traffic accounting.
[Device] traffic behavior web_out
[Device-behavior-web_out] filter permit
[Device-behavior-web_out] free account
[Device-behavior-web_out] quit
h.     Configure the QoS policies:
# Create a QoS policy named web.
[Device] qos policy web
# Associate the traffic class web_permit with the traffic behavior web_permit.
[Device-qospolicy-web] classifier web_permit behavior web_permit
# Associate the traffic class neiwang with the traffic behavior neiwang.
[Device-qospolicy-web] classifier neiwang behavior neiwang
# Associate the traffic class web_http with the traffic behavior web_http.
[Device-qospolicy-web] classifier web_http behavior web_http
# Associate the traffic class web_https with the traffic behavior web_https.
[Device-qospolicy-web] classifier web_https behavior web_https
# Associate the traffic class web_deny with the traffic behavior web_deny.
[Device-qospolicy-web] classifier web_deny behavior web_deny
[Device-qospolicy-web] quit
# Configure a QoS policy named out.
[Device] qos policy out
# Associate the traffic class web_out with the traffic behavior web_out. Associate the traffic class neiwang_out with the traffic behavior neiwang_out. Associate the traffic class web_deny with the traffic behavior web_deny.
[Device-qospolicy-out] classifier web_out behavior web_out
[Device-qospolicy-out] classifier neiwang_out behavior neiwang_out
[Device-qospolicy-out] classifier web_deny behavior web_deny
[Device-qospolicy-out] quit
i.     Apply the QoS policies:
# Apply the QoS Policy web to the inbound traffic globally. To identify whether the QoS policy takes effect, execute the display qos policy global inbound command.
[Device] qos apply policy web global inbound
# Apply the QoS Policy out to the outbound traffic globally. To identify whether the QoS policy takes effect, execute the display qos policy global outbound command.
[Device] qos apply policy out global outbound
j.     Configure a RADIUS scheme:
[Device-radius-rs1] primary authentication 4.4.4.5
[Device-radius-rs1] primary accounting 4.4.4.5
# (Optional.) Enable RADIUS session control. As a best practice, configure this feature when an IMC server acts as the RADIUS server.
[Device] radius session-control enable
k.     Configure the preauthentication ISP domain and Web authentication ISP domain:
# Configure the ISP domain dm1 for IPoE user preauthentication.
[Device-isp-dm1] authentication ipoe none
[Device-isp-dm1] authorization ipoe none
[Device-isp-dm1] accounting ipoe none
# Configure the authorized user group in ISP domain dm1.
[Device-isp-dm1] authorization-attribute user-group pre
# Configure the Web authentication page URL and Web server IP address in ISP domain dm1.
[Device-isp-dm1] web-server url http://4.4.4.5:8080/portal/
[Device-isp-dm1] web-server ip 4.4.4.5
# Configure the ISP domain dm2 for IPoE user Web authentication.
[Device-isp-dm2] authentication ipoe radius-scheme rs1
[Device-isp-dm2] authorization ipoe radius-scheme rs1
[Device-isp-dm2] accounting ipoe radius-scheme rs1
l.     Configure the DHCP server.
# Create local BAS IP address pool pool1, and specify the user gateway address. Exclude IP address 192.168.0.2 (which must be the IP address specified in static IPoE session configuration) from dynamic allocation.
[Device-ip-pool-pool1] gateway 192.168.0.1 24
[Device-ip-pool-pool1] forbidden-ip 192.168.0.2
m.     Configure IPoE:
# Enable unclassified-IPv4 packet initiation.
# Configure an IPoE static user with IP address 192.168.0.2, which must be excluded from dynamic allocation in the IP address pool.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber session static ip 192.168.0.2
# Configure Web authentication for IPoE users on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber authentication-method web
The operation may cut all users on this interface. Continue?[Y/N]:y
# Configure the ISP domain dm1 for preauthentication and the ISP domain dm2 for Web authentication on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber pre-auth domain dm1
[Device–Ten-GigabitEthernet0/0/16] ip subscriber web-auth domain dm2
2.     Configure the RADIUS server:
a.     ‍‍Configure the access device:
-     Log in to the IMC platform and click the User tab.
-     Select User Access Policy > Access Device Management > Access Device from the navigation tree to open the access device configuration page.
-     Click Add to open the page as shown in Figure 31.
-     Enter the shared key radius.
-     Use the default settings for other parameters.
Figure 31 Adding an access device
-     Click Add Manually in the Device List area to open the page as shown in Figure 32.
-     Enter the access device's IP address 4.4.4.2.
-     Click OK.
Figure 32 Manually adding an access device
b.     ‍Add an access policy:
-     Select User Access Policy > Access Policy from the navigation tree to open the access policy page.
-     Click Add to open the page as shown in Figure 33.
-     Enter the access policy name AccessPolicy.
Figure 33 Adding an access policy
c.     ‍Add an access service:
-     Select User Access Policy > Access Service from the navigation tree to open the access service page.
-     Click Add to open the page as shown in Figure 34.
-     Enter the service name IPoE_Server.
-     Select AccessPolicy from the default access policy list.
Figure 34 Adding an access service
d.     ‍Add a user:
-     Select User Management > Add User from the navigation tree to open the adding user page, as shown in Figure 35.
-     Enter the username IPoE_Web001 and the user ID 001.
-     Click OK.
Figure 35 Adding a user
e.     ‍Add an access user:
-     Select Access User > All Access Users from the navigation tree to open the access user page.
-     Click Add to open the page as shown in Figure 36.
-     Select IPoE_Web001 for the username.
-     Enter the account name user1.
-     Enter the password pass1.
-     Select the access service IPoE_Server.
Figure 36 Adding an access user
3.     Configure the portal server:
a.     ‍‍Configure the portal homepage:
-     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page, as shown in Figure 37.
-     Click OK.
Figure 37 Portal server configuration page
b.     ‍Configure portal authentication source IP address range:
-     Select User Access Policy > Portal Service > IP Group from the navigation tree to open the portal IP address group configuration page.
-     Click Add to open the page as shown in Figure 38.
-     Enter the IP group name IPoE_Web_User.
-     Enter the start IP address (192.168.0.1) and end IP address (192.168.0.255) of the IP group. Make sure the host IP address is in the IP group.
-     Click OK.
Figure 38 Adding an IP address group
c.     ‍Add a portal device:
-     Select User Access Policy > Portal Service > Device from the navigation tree to open the portal device configuration page.
-     Click Add to open the page as shown in Figure 39.
-     Enter the device name NAS.
-     Enter the IP address of the portal packets' outgoing interface Ten-GigabitEthernet 0/0/15 (4.4.4.2).
-     Enter the key 123456.
-     Select Directly Connect for access method.
-     Click OK.
Figure 39 Adding a portal device
d.     ‍Associate the portal device with the IP address group:
-     Click the icon in the Port Group Information Management column of device NAS to open the port group configuration page, as shown in Figure 40.
-     Click Add to open the page as shown in Figure 41.
-     Enter the port group name group.
-     Select the configured IP address group IPoE_Web_User. Make sure the IP address used by the user to access the network is within this IP address group.
-     Click OK.
Figure 40 Device list
Figure 41 Port group configuration
# Display IPoE session information to verify that the host has passed preauthentication.
[Device] display access-user auth-type pre-auth
            Username             IPv6 address            Access type
0x33d       XGE0/0/16            192.168.0.2             0015-e947-f4d4  -/-
            192.168.0.2          -                       L2 IPoE static
As shown in Figure 42, the Web login page opens after preauthentication. Enter the username and password on the page.
Figure 42 Web login page
# Display IPoE session information to verify that the host has passed Web authentication and come online.
[Device] display access-user auth-type web-auth
            user1@dm2            Web auth(S/-)
Example: Configuring IPoE common Web authentication for DHCPv4 users (assigning a remote BAS IP address pool)
As shown in Figure 43, the host accesses the BRAS as a DHCP client through a Layer 2 device. It obtains configuration information from the DHCP server through the BRAS. The BRAS performs AAA for the host through the RADIUS server. A server installed with H3C IMC acts as the RADIUS server, the portal authentication server, and the portal Web server. The FTP server is an internal network server.
Figure 43 Network diagram
1.     ‍Configure the DHCP server:
# Enable DHCP.
# Specify primary subnet 192.168.0.0/24 for dynamic allocation in address pool pool1.
[DHCP-server-ip-pool-pool1] network 192.168.0.0 24
# Specify gateway address 192.168.0.1 in address pool pool1.
[DHCP-server-ip-pool-pool1] gateway-list 192.168.0.1
# Specify DNS server address 8.8.8.8 in address pool pool1.
# Exclude IP address 192.168.0.1 from dynamic allocation in address pool pool1.
[DHCP-server-ip-pool-pool1] forbidden-ip 192.168.0.1
# Enable DHCP.
# Create a remote BAS IP address pool named pool1.
[Device-ip-pool-pool1] forbidden-ip 192.168.0.1
# Specify DHCP server 4.4.4.3 in address pool pool1.
b.     Configure the IP address of the portal authentication server newpt as 4.4.4.5 and the plaintext key 123456.
c.     Specify 11111 as the HTTPS redirect listening port number. Make sure the port number is not used by any other service. To see the TCP port numbers used by other services, execute the display tcp command.
d.     Configure the device to get user access information from ARP and ND entries.
e.     Create a local user group named pre.
f.     Configure ACLs for preauthentication:
g.     Configure QoS traffic classes for preauthentication users:
h.     Configure QoS traffic behaviors:
i.     Configure the QoS policies:
j.     Apply the QoS policies:
k.     Configure a RADIUS scheme:
l.     Configure the preauthentication ISP domain and Web authentication ISP domain:
# Configure the authorized IP address pool and user group in preauthentication ISP domain dm1.
m.     Configure IPoE:
3.     Configure the RADIUS server:
a.     Configure the access device:
-     Click Add to open the page as shown in Figure 44.
Figure 44 Adding an access device
-     Click Add Manually in the Device List area to open the page as shown in Figure 45.
-     Click OK.
Figure 45 Manually adding an access device
b.     Add an access policy:
-     Click Add to open the page as shown in Figure 46.
Figure 46 Adding an access policy
c.     Add an access service:
-     Click Add to open the page as shown in Figure 47.
Figure 47 Adding an access service
d.     Add a user:
-     Select User Management > Add User from the navigation tree to open the adding user page, as shown in Figure 48.
-     Click OK.
Figure 48 Adding a user
e.     Add an access user:
-     Click Add to open the page as shown in Figure 49.
Figure 49 Adding an access user
4.     Configure the portal server:
a.     Configure the portal homepage:
-     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page, as shown in Figure 50.
-     Click OK.
Figure 50 Portal server configuration page
b.     Configure portal authentication source IP address range:
-     Click Add to open the page as shown in Figure 51.
-     Click OK.
Figure 51 Adding an IP address group
c.     Add a portal device:
-     Click Add to open the page as shown in Figure 52.
-     Click OK.
Figure 52 Adding a portal device
d.     Associate the portal device with the IP address group:
-     Click the icon in the Port Group Information Management column of device NAS to open the port group configuration page, as shown in Figure 53.
-     Click Add to open the page as shown in Figure 54.
-     Click OK.
Figure 53 Device list
Figure 54 Port group configuration
UserID      Interface            IP address              MAC address     S-/C-VLAN
            Username             Access type
            IPv6 address
            192.168.0.2          L2 IPoE static(D/-)
As shown in Figure 55, the Web login page opens after preauthentication. Enter the username and password on the page.
Figure 55 Web login page
            IPv6 address
            user1@dm2            Web auth(D/-)
Example: Configuring IPoE common Web authentication for multi-network-segment DHCPv4 users (assigning a remote BAS IP address pool)
As shown in Figure 56:
·     Host A belongs to VLAN 100 and resides on network segment 192.168.100.0/24, and comes online through Ten-GigabitEthernet 0/0/16.100 on the BRAS.
·     Host B belongs to VLAN 200 and resides on network segment 192.168.200.0/24, and comes online through Ten-GigabitEthernet 0/0/16.200 on the BRAS.
·     Host A and Host B access the BRAS as DHCP clients through a Layer 2 device. They obtain configuration information from the DHCP server through the BRAS.
·     The BRAS performs AAA for the hosts through the RADIUS server.
·     A server installed with H3C IMC acts as the RADIUS server, the portal authentication server, and the portal Web server.
·     The FTP server is an internal network server.
Figure 56 Network diagram
Configure IP addresses for interfaces, and make sure devices can reach each other at Layer 3. (Details not shown.)
# Enable DHCP.
# Specify primary subnet 192.168.100.0/24 for dynamic allocation in address pool pool1.
[DHCP-server-ip-pool-pool1] network 192.168.100.0 24
# Specify gateway address 192.168.100.1 in address pool pool1.
[DHCP-server-ip-pool-pool1] gateway-list 192.168.100.1
# Exclude IP address 192.168.100.1 from dynamic allocation in address pool pool1.
[DHCP-server-ip-pool-pool1] forbidden-ip 192.168.100.1
# Specify primary subnet 192.168.200.0/24 for dynamic allocation in address pool pool2.
[DHCP-server-ip-pool-pool2] network 192.168.200.0 24
# Specify gateway address 192.168.200.1 in address pool pool2.
[DHCP-server-ip-pool-pool2] gateway-list 192.168.200.1
# Specify DNS server address 8.8.8.8 in address pool pool2.
# Exclude IP address 192.168.200.1 from dynamic allocation in address pool pool2.
[DHCP-server-ip-pool-pool2] forbidden-ip 192.168.200.1
2.     Configure the BRAS:
IMPORTANT
IMPORTANT:
A DHCP relay address pool can be a remote BAS IP address pool or common IP address pool. In this example, the network segment 192.168.100.0/24 where host A resides uses remote BAS IP address pool pool1 as a relay address pool, and the network segment 192.168.200.0/24 where host B resides uses common IP address pool pool2 as a relay address pool.
# Enable DHCP.
[Device] dhcp enable
[Device-ip-pool-pool1] gateway 192.168.100.1 24
[Device-ip-pool-pool1] forbidden-ip 192.168.100.1
# Create a common IP address pool named pool2.
# Specify network segment 192.168.200.1/24 for dynamic allocation in address pool pool2.
[Device-ip-pool-pool2] network 192.168.200.1 24 export-route
[Device-ip-pool-pool2] gateway-list 192.168.200.1 export-route
[Device-ip-pool-pool2] forbidden-ip 192.168.200.1
# Specify DHCP server 4.4.4.3 in address pool pool2.
# Assign IP address 192.168.100.1 to interface Ten-GigabitEthernet 0/0/16.100, enable the DHCP relay agent on the interface, and specify the DHCP server address 4.4.4.3.
[Device] interface ten-gigabitethernet 0/0/16.100
[Device–Ten-GigabitEthernet0/0/16.100] ip address 192.168.100.1 24
[Device–Ten-GigabitEthernet0/0/16.100] dhcp select relay
[Device–Ten-GigabitEthernet0/0/16.100] dhcp relay server-address 4.4.4.3
[Device–Ten-GigabitEthernet0/0/16.100] quit
# Assign IP address 192.168.200.1 to interface Ten-GigabitEthernet 0/0/16.200, enable the DHCP relay agent on the interface, and specify the DHCP server address 4.4.4.3.
[Device] interface ten-gigabitethernet 0/0/16.200
[Device–Ten-GigabitEthernet0/0/16.200] ip address 192.168.200.1 24
[Device–Ten-GigabitEthernet0/0/16.200] dhcp select relay
[Device–Ten-GigabitEthernet0/0/16.200] dhcp relay server-address 4.4.4.3
[Device–Ten-GigabitEthernet0/0/16.200] quit
b.     Configure VLAN termination:
# Enable user mode of VLAN termination on Ten-GigabitEthernet 0/0/16.100 and Ten-GigabitEthernet 0/0/16.200. This feature prevents the subinterface restart and protects the online user state.
[Device] interface range ten-gigabitethernet 0/0/16.100 ten-gigabitethernet 0/0/16.200
[Device–if-range] vlan-termination user-mode
[Device–if-range] quit
# Configure Ten-GigabitEthernet 0/0/16.100 to terminate VLAN-tagged packets with the outermost VLAN tag as 100.
[Device–Ten-GigabitEthernet0/0/16.100] user-vlan dot1q vid 100
# Configure Ten-GigabitEthernet 0/0/16.200 to terminate VLAN-tagged packets with the outermost VLAN tag as 200.
[Device–Ten-GigabitEthernet0/0/16.200] user-vlan dot1q vid 200
c.     Configure the IP address of the portal authentication server newpt as 4.4.4.5 and the plaintext key 123456.
d.     Specify 11111 as the HTTPS redirect listening port number. Make sure the port number is not used by any other service. To see the TCP port numbers used by other services, execute the display tcp command.
e.     Configure the device to get user access information from ARP and ND entries.
f.     Create a local user group named pre.
g.     Configure ACLs for preauthentication:
[Device-acl-ipv4-adv-neiwang] rule 0 permit ip destination 4.4.4.4 0 user-group pre
h.     Configure QoS traffic classes for preauthentication users:
i.     Configure QoS traffic behaviors:
j.     Configure the QoS policies:
k.     Apply the QoS policies:
l.     Configure a RADIUS scheme:
# Create a RADIUS scheme named rs1 and enter its view.
[Device] radius scheme rs1
# Configure primary servers and keys for authentication and accounting.
[Device-radius-rs1] key authentication simple radius
[Device-radius-rs1] key accounting simple radius
# Exclude the ISP name from the username sent to the RADIUS server.
[Device-radius-rs1] user-name-format without-domain
[Device-radius-rs1] quit
m.     Configure the preauthentication ISP domain and Web authentication ISP domain:
[Device] domain name dm1
# Configure the authorized user group in preauthentication ISP domain dm1.
[Device-isp-dm1] quit
[Device] domain name dm2
[Device-isp-dm2] quit
n.     Configure IPoE:
# Enable IPoE and configure Layer 2 access mode on subinterfaces Ten-GigabitEthernet 0/0/16.100 and Ten-GigabitEthernet 0/0/16.200.
[Device–if-range] ip subscriber l2-connected enable
# Configure Web authentication for IPoE users on subinterfaces Ten-GigabitEthernet 0/0/16.100 and Ten-GigabitEthernet 0/0/16.200.
[Device–if-range] ip subscriber authentication-method web
# Configure the ISP domain dm1 for preauthentication and the ISP domain dm2 for Web authentication on subinterfaces Ten-GigabitEthernet 0/0/16.100 and Ten-GigabitEthernet 0/0/16.200.
[Device–if-range] ip subscriber pre-auth domain dm1
[Device–if-range] ip subscriber web-auth domain dm2
3.     Configure the RADIUS server and portal server.
For more information, see "Example: Configuring IPoE common Web authentication for DHCPv4 users (assigning a remote BAS IP address pool)."
# Display IPoE session information to verify that hosts A and B have passed preauthentication.
            IPv6 address
0x1         XGE0/0/16.100          192.168.100.2           0015-e947-f4d4  100/-
            0015e947f4d4         L2 IPoE dynamic(D/-)
0x2         XGE0/0/16.200          192.168.200.2           0015-e947-f4d5  200/-
            0015e947f4d5         L2 IPoE dynamic(D/-)
As shown in Figure 57, the Web login page opens after preauthentication. Enter the username and password on the page.
Figure 57 Web login page
            IPv6 address
Example: Configuring IPoE common Web authentication for DHCPv6 users (assigning a remote IPv6 address pool)
As shown in Figure 58:
·     The host accesses the BRAS as a DHCP client though a Layer 2 device.
·     The host obtains configuration information from the DHCP server through the BRAS.
·     The BRAS performs AAA for the host through the RADIUS server. A server installed with H3C IMC acts as the RADIUS server, the portal authentication server, and the portal Web server.
·     Limit the access rate to 5 Mbps for the user after passing Web authentication.
Figure 58 Network diagram
Configure the DNS server properly, so that the server can parse the IPv6 URL corresponding to the Web authentication page http://www.ipv6.web.com. (Details not shown.)
Configure IP addresses for interfaces and make sure the BRAS and servers can reach each other at Layer 3. (Details not shown.)
<DHCP-server> system-view
# Specify primary subnet 192::/64 and DNS server address 8::8 for dynamic allocation in IPv6 address pool pool1.
[DHCP-server-ipv6-pool-pool1] network 192::/64
# Exclude IP address 192::1 from dynamic allocation in IPv6 address pool pool1.
[DHCP-server] ipv6 dhcp server forbidden-address 192::1
[DHCP] interface ten-gigabitethernet 0/0/15
# Configure the default route.
a.     Configure the DHCP relay agent:
# Create an IP address pool named pool1 for the DHCP relay agent.
# Specify gateway address 192::1 in IP address pool pool1.
[Device-ipv6-pool-pool1] gateway-list 192::1
# Specify network 192::/64 for address allocation  in IP address pool pool1.
[Device-ipv6-pool-pool1] network 192::/64 export-route
# Specify DHCP server 4::3 in IP address pool pool1.
# Enable recording client information in DHCPv6 relay entries.
[Device–Ten-GigabitEthernet0/0/16] ipv6 dhcp relay client-information record
# Disable Ten-GigabitEthernet 0/0/16 from advertising the specified prefix in RA messages, preventing the endpoint from obtaining a temporary IPv6 address. In an IPv6 network, an endpoint might use a temporary IPv6 address for IPoE Web authentication, which will cause authentication failure.
[Device–Ten-GigabitEthernet0/0/16] ipv6 nd ra prefix 192::/64 no-advertise
[Device–Ten-GigabitEthernet0/0/16] quit
b.     Configure the IPv6 address of the IPv6 portal authentication server newpt1 as 4::5 and the plaintext key 123456.
[Device] portal server newpt1
[Device-portal-server-newpt1] ipv6 4::5 key simple 123456
[Device-portal-server-newpt1] quit
# Create an IPv6 advanced ACL named web_permit. Configure a rule to permit all packets destined for the portal server from users in user group pre.
[Device] acl ipv6 advanced name web_permit
[Device-acl-ipv6-adv-web_permit] rule 0 permit ipv6 destination 4::5 128 user-group pre
[Device-acl-ipv6-adv-web_permit] quit
# Create an IPv6 advanced ACL named neiwang. Configure a rule to permit all packets destined for the internal network server from users in user group pre.
[Device] acl ipv6 advanced name neiwang
[Device-acl-ipv6-adv-neiwang] rule 0 permit ipv6 destination 4::1 128 user-group pre
[Device-acl-ipv6-adv-neiwang] quit
# Create an IPv6 advanced ACL named web_http. Configure a rule to permit TCP packets with the destination port 80 (HTTP packets) from users in user group pre.
[Device] acl ipv6 advanced name web_http
[Device-acl-ipv6-adv-web_http] rule 0 permit tcp destination-port eq www user-group pre
[Device-acl-ipv6-adv-web_http] quit
# Create an IPv6 advanced ACL named web_https, and configure a rule to permit TCP packets with the destination port 443 (HTTPS packets) from users in user group pre.
[Device] acl ipv6 advanced name web_https
[Device-acl-ipv6-adv-web_https] rule 0 permit tcp destination-port eq 443 user-group pre
[Device-acl-ipv6-adv-web_https] quit
# Create an IPv6 advanced ACL named ip, and configure a rule to permit IP packets from users in user group pre.
[Device] acl ipv6 advanced name ip
[Device-acl-ipv6-adv-ip] rule 0 permit ipv6 user-group pre
[Device-acl-ipv6-adv-ip] quit
# Create an IPv6 advanced ACL named neiwang_out, and configure a rule to permit IP packets from the internal network server in user group pre.
[Device] acl ipv6 advanced name neiwang_out
[Device-acl-ipv6-adv-neiwang_out] rule 0 permit ipv6 source 4::1 128 user-group pre
[Device-acl-ipv6-adv-neiwang_out] quit
# Create an IPv6 advanced ACL named web_out, and configure a rule to permit IP packets from the portal server in user group pre.
[Device] acl ipv6 advanced name web_out
[Device-acl-ipv6-adv-web_out] rule 0 permit ipv6 source 4::5 128 user-group pre
[Device-acl-ipv6-adv-web_out] quit
[Device] traffic classifier web_permit operator or
[Device-classifier-web_permit] if-match acl ipv6 name web_permit
[Device] traffic classifier neiwang operator or
[Device-classifier-neiwang] if-match ipv6 acl name neiwang
[Device] traffic classifier web_http operator or
[Device-classifier-web_http] if-match ipv6 acl name web_http
[Device] traffic classifier web_https operator or
[Device-classifier-web_https] if-match ipv6 acl name web_https
[Device] traffic classifier web_deny operator or
[Device-classifier-web_deny] if-match ipv6 acl name ip
[Device] traffic classifier neiwang_out operator or
[Device-classifier-neiwang_out] if-match ipv6 acl name neiwang_out
[Device] traffic classifier web_out operator or
[Device-classifier-web_out] if-match ipv6 acl name web_out
[Device-radius-rs1] primary authentication ipv6 4::5
[Device-radius-rs1] primary accounting ipv6 4::5
# Set the IP address of the RADIUS DAE client to 4::5, and set the shared key to radius for the RADIUS DAE client to exchange DAE packets.
[Device] radius dynamic-author server
[Device-radius-da-server] client ipv6 4::5 key simple radius
[Device-radius-da-server] quit
# Configure the authorized user group and IPv6 address pool in preauthentication ISP domain dm1.
# Configure the Web authentication page URL in ISP domain dm1.
[Device-isp-dm1] web-server ipv6-url http://www.ipv6.web.com
[Device-isp-dm2] authorization-attribute car inbound cir 5120 outbound cir 5120
m.     Configure IPoE:
# Enable IPoE for the IPv6 protocol stack and configure Layer 2 access mode on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber l2-connected enable ipv6
-     Click Add to open the page as shown in Figure 59.
Figure 59 Adding an access device
-     Click Add IPv6 Dev in the Device List area to open the page as shown in Figure 60.
-     Enter the access device's IPv6 address 4::2.
-     Click OK.
Figure 60 Manually adding an access device
-     Click Add to open the page as shown in Figure 61.
Figure 61 Adding an access policy
-     Click Add to open the page as shown in Figure 62.
Figure 62 Adding an access service
d.     Add a user:
-     Select User Management > Add User from the navigation tree to open the adding user page, as shown in Figure 63.
-     Click OK.
Figure 63 Adding a user
-     Click Add to open the page as shown in Figure 64.
Figure 64 Adding an access user
-     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page, as shown in Figure 65.
-     Click OK.
Figure 65 Portal server configuration page
-     Click Add to open the page as shown in Figure 66.
-     Enter the IP group name IPoE_Web_User-2.
-     Select Yes from the IPv6 list.
-     Enter the start IP address (192::1) and end IP address (192::FFFF) of the IP group. Make sure the host IPv6 address is in the IP group.
-     Click OK.
Figure 66 Adding an IP address group (IPv6)
-     Click Add to open the page as shown in Figure 67.
-     Enter the device name NAS-2.
-     Select Portal 3.0 from the Version list.
-     Enter the IP address of the portal packets' outgoing interface Ten-GigabitEthernet 0/0/15 (4::2).
-     Click OK.
Figure 67 Adding a portal device (IPv6)
-     Click the icon in the Port Group Information Management column of device NAS to open the port group configuration page, as shown in Figure 68.
-     Click Add to open the page as shown in Figure 69.
-     Enter the port group name group-2.
-     Select the configured IP address group IPoE_Web_User-2. Make sure the IPv6 address used by the user to access the network is within this IPv6 address group.
-     Click OK.
Figure 68 Device list
Figure 69 Port group configuration
# Display IPoE session information to verify that the host has passed preauthentication and obtained IPv6 address 192::2.
            IPv6 address
0x33d       XGE0/0/16            -                       001b-21a8-0949  -/-
            001b21a80949         L2 IPoE dynamic(-/D)
            192::2
As shown in Figure 70, the Web login page opens after preauthentication. Enter the username and password on the page.
Figure 70 Web login page
            IPv6 address
            user1@dm2            Web auth(-/D)
            192::2
Example: Configuring IPoE common Web authentication for IPoE ND RS users (ND prefix pool-authorized prefix)
As shown in Figure 71, the host accesses the BRAS as an IPv6 ND RS user though a Layer 2 device. The BRAS can send IPv6 ND RA packets. A server installed with H3C IMC acts as the RADIUS server, the portal authentication server, and the portal Web server.
Figure 71 Network diagram
1.     ‍Configure IP addresses and routes.
As shown in Figure 71, configure IP addresses for interfaces and make sure the BRAS and servers can reach each other at Layer 3. (Details not shown.)
a.     Disable RA message suppression on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] undo ipv6 nd ra halt
b.     Automatically generate a link-local address for Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ipv6 address auto link-local
c.     Configure the ND prefix pool:
# Create prefix pool 1 that contains the prefix 10::/32 and specify the length of prefixes to be assigned as 64. Prefix pool 1 can assign 4294967296 prefixes in the range of 10::/64 to 10:0:FFFF:FFFF::/64.
[Device] ipv6 dhcp prefix-pool 1 prefix 10::/32 assign-len 64
# Create an IPv6 address pool named pool1, and reference prefix pool 1.
[Device] ipv6 pool pool1
[Device-ipv6-pool-pool1] prefix-pool 1 export-route
[Device-ipv6-pool-pool1] quit
d.     Configure the IPv6 address of the IPv6 portal authentication server newpt2 as 4::5 and the plaintext key 123456.
[Device] portal server newpt2
[Device-portal-server-newpt2] ipv6 4::5 key simple 123456
[Device-portal-server-newpt2] quit
e.     Specify 11111 as the HTTPS redirect listening port number. Make sure the port number is not used by any other service. To see the TCP port numbers used by other services, execute the display tcp command.
f.     Configure the device to get user access information from ARP and ND entries.
g.     Create a local user group named pre.
h.     Configure ACLs for preauthentication:
i.     Configure QoS traffic classes for preauthentication users:
[Device-classifier-web_http] if-match acl ipv6 name web_http
[Device-classifier-web_https] if-match acl ipv6 name web_https
[Device-classifier-web_deny] if-match acl ipv6 name ip
[Device-classifier-neiwang_out] if-match acl ipv6 name neiwang_out
[Device-classifier-web_out] if-match acl ipv6 name web_out
j.     Configure QoS traffic behaviors:
k.     Configure the QoS policies:
l.     Apply the QoS policies:
m.     Configure a RADIUS scheme:
n.     Configure the preauthentication ISP domain and Web authentication ISP domain:
# Configure the authorized user group, ND prefix pool, and IPv6 DNS address pool in preauthentication ISP domain dm1.
[Device-isp-dm1] authorization-attribute ipv6-nd-prefix-pool pool1
[Device-isp-dm1] authorization-attribute primary-dns ipv6 8::8
[Device-isp-dm1] web-server ipv6-url http://[4::5]:8080/portal
o.     Configure IPoE:
# Enable IPoE and configure Layer 2 access mode on Ten-GigabitEthernet 0/0/16.
# Enable IPv6 ND RS packet initiation.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber initiator ndrs enable
For more information, see related configuration in "Example: Configuring IPoE common Web authentication for dual-stack IPoE users (URL allowlist)."
# Display IPoE session information to verify that the host has passed preauthentication and obtained IPv6 prefix 10::/64.
            IPv6 address
0xc         XGE0/0/16            -                       000c-29a6-b656  -/-
            000c29a6b656         L2 IPoE dynamic(-/N)
            10::20C:29FF:FEA6:B656
As shown in Figure 72, the Web login page opens after preauthentication. Enter the username and password on the page.
Figure 72 Web login page
            IPv6 address
            user1@dm2            Web auth(-/N)
Example: Configuring IPoE transparent MAC-trigger authentication (Layer 2 transparent)
As shown in Figure 73, the host accesses the BRAS as a DHCP client though a Layer 2 device. It obtains configuration information from the DHCP server through the BRAS. A server installed with H3C IMC acts as the RADIUS server, the portal authentication server, the portal Web server, and the MAC binding server. This example uses IMC PLAT 7.1(E0303), IMC UAM 7.1(E0305), and IMC EIP 7.1(E0305). The FTP server is an internal network server.
Figure 73 Network diagram
# Enable DHCP.
[DHCP-server] dhcp enable
# Enable the DHCP server to return a DHCP-NAK message if the client notions of their IP addresses are incorrect.
[DHCP-server] dhcp server request-ip-address check
# Create an IP address pool named pool1 and enter its view.
[DHCP-server] ip pool pool1
[DHCP-server-ip-pool-pool1] dns-list 8.8.8.8
[DHCP-server-ip-pool-pool1] quit
[DHCP-server] ip route-static 0.0.0.0 0 4.4.4.2
# Enable DHCP.
[Device] ip pool pool1 bas remote
[Device-ip-pool-pool1] remote-server 4.4.4.3
[Device-ip-pool-pool1] quit
[Device-acl-ipv4-adv-neiwang_out] rule 0 permit ip source 4.4.4.6 0 user-group pre
# Create the traffic class ip_cpu and specify ACL ip as the match criterion.
[Device] traffic classifier ip_cpu operator or
[Device-classifier-ip_cpu] if-match acl name ip
[Device-classifier-ip_cpu] if-match acl ipv6 name ip
[Device-classifier-ip_cpu] quit
# Create the traffic class ip_deny and specify ACL ip as the match criterion.
[Device] traffic classifier ip_deny operator or
[Device-classifier-ip_deny] if-match acl name ip
[Device-classifier-ip_deny] if-match acl ipv6 name ip
[Device-classifier-ip_deny] quit
# Associate the traffic class ip_cpu with the traffic behavior web_cpu.
[Device-qospolicy-web] classifier ip_cpu behavior web_cpu
# Associate the traffic class ip_deny with the traffic behavior web_deny.
[Device-qospolicy-web] classifier ip_deny behavior web_deny
[Device-qospolicy-out] classifier ip_deny behavior web_deny
# Configure the authorized IP address pool and user group in ISP domain dm1.
[Device-isp-dm1] authorization-attribute ip-pool pool1
m.     Configure IPoE:
n.     Configure MAC-based quick portal authentication:
# Create MAC binding server mts.
[Device] portal mac-trigger server mts
# Specify the IP address of the MAC binding server as 4.4.4.5.
[Device-portal-mac-trigger-server-mts] ip 4.4.4.5
[Device-portal-mac-trigger-server-mts] quit
# Specify the MAC binding server mts on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] portal apply mac-trigger-server mts
-     Click Add to open the page as shown in Figure 74.
Figure 74 Adding an access device
-     Click Add Manually in the Device List area to open the page as shown in Figure 75.
-     Click OK.
Figure 75 Manually adding an access device
-     Click Add to open the page as shown in Figure 76.
Figure 76 Adding an access policy
-     Click Add to open the page as shown in Figure 77.
Figure 77 Adding an access service
d.     Add a user:
-     Select User Management > Add User from the navigation tree to open the adding user page, as shown in Figure 78.
-     Click OK.
Figure 78 Adding a user
-     Click Add to open the page as shown in Figure 79.
Figure 79 Adding an access user
-     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page, as shown in Figure 80.
-     Click OK.
Figure 80 Portal server configuration page
-     Click Add to open the page as shown in Figure 81.
-     Click OK.
Figure 81 Adding an IP address group
-     Click Add to open the page as shown in Figure 82.
-     Click OK.
Figure 82 Adding a portal device
-     Click the icon in the Port Group Information Management column of device NAS to open the port group configuration page, as shown in Figure 83.
-     Click Add to open the page as shown in Figure 84.
-     Select Supported in the Transparent Authentication list.
-     Click OK.
Figure 83 Device list
Figure 84 Port group configuration
e.     From the navigation tree, select User Access Manager > Service Parameters > Validate System Configuration to validate the settings.
            IPv6 address
As shown in Figure 85, the Web login page opens after preauthentication. Enter the username and password on the page.
Figure 85 Web login page
            IPv6 address
# Click Log Out on the Web login page as shown in Figure 85.
# Verify that the user returns to the preauthentication status.
            IPv6 address
# Open the browser, and enter an address randomly, for example, http://63.1.1.240.
# Verify that the user has come online through IPoE Web authentication.
            IPv6 address
            0015e947f4d4         Web auth(D/-)
Example: Configuring IPoE common transparent MAC authentication (Layer 2 transparent)
As shown in Figure 86, the host accesses the BRAS as a DHCP client though a Layer 2 device. It obtains configuration information from the DHCP server through the BRAS. The BRAS performs AAA for the host through the RADIUS server. A server installed with H3C IMC acts as the portal authentication server and the portal Web server. This example uses IMC PLAT 7.1(E0303), IMC UAM 7.1(E0305), and IMC EIP 7.1(E0305). The RADIUS server supports MAC binding, acts as the authentication, authorization, and accounting server, and performs MAC binding. The FTP server is an internal network server.
Figure 86 Network diagram
# Enable DHCP.
# Enable DHCP.
# Create a remote BAS IP address pool named pool1 for the DHCP relay agent.
[Device-radius-rs1] primary authentication 4.4.4.1
[Device-radius-rs1] primary accounting 4.4.4.1
m.     Configure IPoE:
# Configure Web MAC authentication for IPoE users on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber authentication-method web mac-auth
3.     Configure the RADIUS server.
For more information about configuring AAA and MAC binding on the RADIUS server, see the configuration guide for the RADIUS server.
-     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page, as shown in Figure 87.
-     Click OK.
Figure 87 Portal server configuration page
-     Click Add to open the page as shown in Figure 88.
-     Click OK.
Figure 88 Adding an IP address group
-     Click Add to open the page as shown in Figure 89.
-     Click OK.
Figure 89 Adding a portal device
-     Click the icon in the Port Group Information Management column of device NAS to open the port group configuration page, as shown in Figure 90.
-     Click Add to open the page as shown in Figure 91.
-     Click OK.
Figure 90 Device list
Figure 91 Port group configuration
            IPv6 address
As shown in Figure 92, the Web login page opens after preauthentication. Enter the username and password on the page.
Figure 92 Web login page
            IPv6 address
# Click Log Out on the page as shown in Figure 92.
            IPv6 address
# Open the browser, and enter any address in the address bar to access http://63.1.1.240/. Display session information. The output shows that the user has come online through Web authentication.
            IPv6 address
Example: Configuring IPoE HTTP extension header authentication (Layer 2 transparent)
·     The DHCP client accesses the BRAS through a Layer 2 network by using IPoE.
·     The BRAS acts a DHCP relay agent to request IP addresses from the remote DHCP server.
·     Deploy a RADIUS server that supports MAC binding to process authentication, authorization, accounting, and MAC binding.
Figure 93 Network diagram
Assign IP addresses to the interfaces and make sure the devices have a route to each other. (Details not shown.)
1.     ‍‍Configure the DHCP server:
# Enable DHCP globally.
# Create address pool pool1 and enter its view.
# Specify primary subnet 192.168.0.0/24 for dynamic allocation in the address pool. Specify gateway address 192.168.0.1 and DNS server address 8.8.8.8 in the address pool.
# Exclude IP address 192.168.0.1 from dynamic allocation.
# Configure a default route.
2.     Configure Device:
a.     ‍Configure the DHCP relay agent:
[[Device] dhcp enable
# Enter the view of interface Ten-GigabitEthernet 0/0/16.
# Enable the DHCPv4 relay agent on the interface.
# Create remote BAS IP address pool pool1, and specify the gateway address, excluded IP address, and DHCP server for the address pool.
b.     Configure the HTTPS redirect listening port number:
# Specify the HTTPS redirect listening port number. Make sure it does not conflict with a port in use. To view the TCP port numbers used by other services, execute the display tcp command.
[[Device] http-redirect https-port 11111
c.     Create local user groups:
# Create a user group named pre for the preauthentication domain.
d.     Configure the ACLs for users in the preauthentication domain:
# Create an IPv4 advanced ACL named neiwang, and configure a rule to match the packets destined to the internal network server from users in user group pre.
[[Device] acl advanced name neiwang
[[Device-acl-ipv4-adv-neiwang] rule 0 permit ip destination 4.4.4.6 0 user-group pre
[[Device-acl-ipv4-adv-neiwang] quit
# Create an IPv4 advanced ACL named web_http, and configure a rule to match the TCP packets with destination port 80 (HTTP packets) from users in user group pre.
[[Device] acl advanced name web_http
[[Device-acl-ipv4-adv-web_http] rule 0 permit tcp destination-port eq www user-group pre
[[Device-acl-ipv4-adv-web_http] quit
# Create an IPv4 advanced ACL named web_https, and configure a rule to match the TCP packets with destination port 443 (HTTPS packets) from users in user group pre.
[[Device] acl advanced name web_https
[[Device-acl-ipv4-adv-web_https] rule 0 permit tcp destination-port eq 443 user-group pre
[[Device-acl-ipv4-adv-web_https] quit
# Create an IPv4 advanced ACL named ip, and configure a rule to match all IP packets from users in user group pre.
[[Device] acl advanced name ip
[[Device-acl-ipv4-adv-ip] rule 0 permit ip user-group pre
[[Device-acl-ipv4-adv-ip] quit
# Create an IPv4 advanced ACL named neiwang_out, and configure a rule to match packets sourced from the internal network server to users in user group pre.
[[Device] acl advanced name neiwang_out
[[Device-acl-ipv4-adv-neiwang_out] rule 0 permit ip source 4.4.4.6 0 user-group pre
[[Device-acl-ipv4-adv-neiwang_out] quit
e.     Configure traffic classes for users in the preauthentication domain:
# Create a traffic class named neiwang, and use ACL neiwang as the match criterion.
[[Device] traffic classifier neiwang operator and
[[Device-classifier-neiwang] if-match acl name neiwang
[[Device-classifier-neiwang] quit
# Create a traffic class named web_http, and use ACL web_http as a match criterion.
[[Device] traffic classifier web_http operator and
[[Device-classifier-web_http] if-match acl name web_http
[[Device-classifier-web_http] quit
# Create a traffic class named web_https, and use ACL web_https as the match criterion.
[[Device] traffic classifier web_https operator and
[[Device-classifier-web_https] if-match acl name web_https
[[Device-classifier-web_https] quit
# Create a traffic class named ip_cpu, and use ACL ip as the match criterion.
[[Device] traffic classifier ip_cpu operator and
[[Device-classifier-ip_cpu] if-match acl name ip
[[Device-classifier-ip_cpu] quit
# Create a traffic class named ip_deny, and use ACL ip as the match criterion.
[[Device] traffic classifier ip_deny operator and
[[Device-classifier-ip_deny] if-match acl name ip
[[Device-classifier-ip_deny] quit
# Create a traffic class named neiwang_out, and use ACL neiwang_out as the match criterion.
[[Device] traffic classifier neiwang_out operator and
[[Device-classifier-neiwang_out] if-match acl name neiwang_out
[[Device-classifier-neiwang_out] quit
f.     Configure traffic behaviors:
# Configure a traffic behavior named neiwang, and configure an action of permitting packets from users in user group pre to the internal network server to pass through.
[[Device] traffic behavior neiwang
[[Device-behavior-neiwang] filter permit
[[Device-behavior-neiwang] quit
# Create a traffic behavior named web_http, and configure an action of redirecting the TCP packets with destination port 80 (HTTP packets) to the CPU.
[[Device] traffic behavior web_http
[[Device-behavior-web_http] redirect http-to-cpu
[[Device-behavior-web_http] quit
# Create a traffic behavior named web_https, and configure an action of redirecting the TCP packets with destination port 443 (HTTPS packets) to the CPU.
[[Device] traffic behavior web_https
[[Device-behavior-web_https] redirect https-to-cpu
[[Device-behavior-web_https] quit
# Create a traffic behavior named web_cpu to redirect IP packets.
[[Device] traffic behavior web_cpu
[[Device-behavior-web_cpu] redirect cpu
[[Device-behavior-web_cpu] quit
# Create a traffic behavior named web_deny, and configure an action of denying all IP packets from users in user group pre.
[[Device] traffic behavior web_deny
[[Device-behavior-web_deny] filter deny
[[Device-behavior-web_deny] free account
[[Device-behavior-web_deny] quit
# Create a traffic behavior named neiwang_out, and configure an action of permitting packets from the internal network server to users in user group pre to pass through.
[[Device] traffic behavior neiwang_out
[[Device-behavior-neiwang_out] filter permit
[[Device-behavior-neiwang_out] quit
g.     Configure QoS policies:
# Configure a QoS policy named web for inbound traffic.
[[Device] qos policy web
# Associate traffic classes with traffic behaviors. For users in user group pre:
-     Redirect packets with destination port 80 (HTTP packets) and packets with destination port 443 (HTTPS packets) to the CPU.
-     Redirect all the other packets to the CPU. If transparent authentication after redirection fails, the packets will be dropped.
[[Device-qospolicy-web] classifier neiwang behavior neiwang
[[Device-qospolicy-web] classifier web_http behavior web_http
[[Device-qospolicy-web] classifier web_https behavior web_https
[[Device-qospolicy-web] classifier ip_cpu behavior web_cpu
[[Device-qospolicy-web] classifier ip_deny behavior web_deny
[[Device-qospolicy-web] quit
# Configure a QoS policy named out for outbound traffic.
[[Device] qos policy out
# Associate traffic classes with traffic behaviors to permit packet sourced from the internal network server for users in user group pre and deny any other packets.
[[Device-qospolicy-out] classifier neiwang_out behavior neiwang_out
[[Device-qospolicy-out] classifier ip_deny behavior web_deny
[[Device-qospolicy-out] quit
h.     Apply QoS policies:
# Apply QoS policy web to the incoming traffic. (To view the application status of QoS policies applied in the inbound direction, execute the display qos policy global inbound command.)
[[Device] qos apply policy web global inbound
# Apply QoS policy out to the outgoing traffic. (To view the application status of QoS policies applied in the outbound direction, execute the display qos policy global outbound command.)
[[Device] qos apply policy out global outbound
i.     Configure the RADIUS scheme:
# Create RADIUS scheme  rs1, and enter its view.
[[Device] radius scheme rs1
# Specify the primary authentication server and primary accounting server and specify the authentication and accounting keys.
[[Device-radius-rs1] primary authentication 4.4.4.1
[[Device-radius-rs1] primary accounting 4.4.4.1
[[Device-radius-rs1] key authentication simple radius
[[Device-radius-rs1] key accounting simple radius
# Exclude the ISP domain name from the username sent to the RADIUS server.
[[Device-radius-rs1] quit
# (Optional.) Enable the session-control feature. As a best practice, enable this feature when IMC acts as a RADIUS server.
[[Device] radius session-control enable
j.     Configure the preauthentication domain and Web authentication domain:
# Configure the preauthentication domain for IPoE users.
[[Device] domain name dm1
[[Device-isp-dm1] authentication ipoe none
[[Device-isp-dm1] authorization ipoe none
[[Device-isp-dm1] accounting ipoe none
# Configure the authorized address pool and user group.
[[Device-isp-dm1] authorization-attribute user-group pre
[[Device-isp-dm1] authorization-attribute ip-pool pool1
# Configure the Web server URL redirected to the user to carry the original URL accessed by the user.
[[Device-isp-dm1] web-server url-parameter url original-url
# Configure the extension header URL to which packets will be redirected.
[[Device-isp-dm1] web-server url http://4.4.4.9/
[[Device-isp-dm1] quit
# Configure ISP domain dm2 for IPoE user Web authentication.
[[Device] domain name dm2
[[Device-isp-dm2] authentication ipoe radius-scheme rs1
[[Device-isp-dm2] authorization ipoe radius-scheme rs1
[[Device-isp-dm2] accounting ipoe radius-scheme rs1
[[Device-isp-dm2] quit
k.     Configure IPoE:
# Enable IPoE and configure the Layer 2 access mode.
# Configure the HTTP extension header authentication method for IPoE users.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber authentication-method http-x-header
# Specify ISP domain dm1 as the Web preauthentication domain and ISP domain dm2 as the Web authentication domain.
For how to configure AAA and MAC binding on the RADIUS server, see the configuration guide for the RADIUS server.
# After a user passes preauthentication, use the following command to view online IPoE user information. The output shows that the user obtains IP address 192.168. 0.2.
[[Device] display access-user auth-type pre-auth
            IPv6 address
# After a user passes preauthentication, the user accesses any webpage. Execute the following command to view the online information of the IPoE user.
[[Device] display access-user auth-type web-auth
            IPv6 address
            user1@dm2            Web auth
Example: Configuring IPoE transparent MAC-trigger authentication (Layer 3 transparent)
As shown in Figure 94, the host accesses the BRAS as a DHCP client though a Layer 3 network. The BRAS also acts as the DHCP server. A server installed with H3C IMC acts as the RADIUS server, the portal authentication server, the portal Web server, and the MAC binding server. This example uses IMC PLAT 7.1(E0303), IMC UAM 7.1(E0305), and IMC EIP 7.1(E0305). The FTP server is an internal network server.
Figure 94 Network diagram
1.     ‍‍Configure the DHCP relay agent:
# Enable DHCP.
[RouterA] dhcp enable
# Enable the DHCP relay agent to record client information in relay entries.
[RouterA] dhcp relay client-information record
# Disable the DHCP relay agent from periodically refreshing dynamic relay entries.
[RouterA] undo dhcp relay client-information refresh enable
# Enable the DHCP relay agent and specify DHCP server address 2.2.2.2 on Ten-GigabitEthernet 0/0/16.
[RouterA] interface ten-gigabitethernet 0/0/16
[RouterA–Ten-GigabitEthernet0/0/16] dhcp select relay
[RouterA–Ten-GigabitEthernet0/0/16] dhcp relay server-address 2.2.2.2
[RouterA–Ten-GigabitEthernet0/0/16] quit
# Configure the default route from the DHCP relay agent to the BRAS.
[RouterA] ip route-static 0.0.0.0 0 2.2.2.2
2.     Configure Router B:
a.     ‍Configure the DHCP server:
# Enable DHCP.
<RouterB> system-view
[RouterB] dhcp enable
[RouterB] dhcp server request-ip-address check
# Create a common IP address pool named pool1 and enter its view.
[RouterB] ip pool pool1
# Specify subnet 192.168.0.0/24 for dynamic allocation in address pool pool1.
[RouterB-ip-pool-pool1] network 192.168.0.0 24
[RouterB-ip-pool-pool1] gateway 192.168.0.1
[RouterB-ip-pool-pool1] dns-list 8.8.8.8
[RouterB-ip-pool-pool1] forbidden-ip 192.168.0.1
[RouterB-ip-pool-pool1] quit
# Configure a static route to the DHCP relay agent.
[RouterB] ip route-static 192.168.0.0 24 2.2.2.1
[RouterB] portal server newpt
[RouterB-portal-server-newpt] ip 4.4.4.5 key simple 123456
[RouterB-portal-server-newpt] quit
[RouterB] http-redirect https-port 11111
[RouterB] user-group pre
[RouterB-ugroup-pre] quit
[RouterB] acl advanced name web_permit
[RouterB-acl-ipv4-adv-web_permit] rule 0 permit ip destination 4.4.4.5 0 user-group pre
[RouterB-acl-ipv4-adv-web_permit] quit
[RouterB] acl advanced name neiwang
[RouterB-acl-ipv4-adv-neiwang] rule 0 permit ip destination 4.4.4.6 0 user-group pre
[RouterB-acl-ipv4-adv-neiwang] quit
[RouterB] acl advanced name web_http
[RouterB-acl-ipv4-adv-web_http] rule 0 permit tcp destination-port eq www user-group pre
[RouterB-acl-ipv4-adv-web_http] quit
[RouterB] acl advanced name web_https
[RouterB-acl-ipv4-adv-web_https] rule 0 permit tcp destination-port eq 443 user-group pre
[RouterB-acl-ipv4-adv-web_https] quit
[RouterB] acl advanced name ip
[RouterB-acl-ipv4-adv-ip] rule 0 permit ip user-group pre
[RouterB-acl-ipv4-adv-ip] quit
[RouterB] acl advanced name neiwang_out
[RouterB-acl-ipv4-adv-neiwang_out] rule 0 permit ip source 4.4.4.6 0 user-group pre
[RouterB-acl-ipv4-adv-neiwang_out] quit
[RouterB] acl advanced name web_out
[RouterB-acl-ipv4-adv-web_out] rule 0 permit ip source 4.4.4.5 0 user-group pre
[RouterB-acl-ipv4-adv-web_out] quit
[RouterB] traffic classifier web_permit operator and
[RouterB-classifier-web_permit] if-match acl name web_permit
[RouterB-classifier-web_permit] quit
[RouterB] traffic classifier neiwang operator and
[RouterB-classifier-neiwang] if-match acl name neiwang
[RouterB-classifier-neiwang] quit
[RouterB] traffic classifier web_http operator and
[RouterB-classifier-web_http] if-match acl name web_http
[RouterB-classifier-web_http] quit
[RouterB] traffic classifier web_https operator and
[RouterB-classifier-web_https] if-match acl name web_https
[RouterB-classifier-web_https] quit
[RouterB] traffic classifier neiwang_out operator and
[RouterB-classifier-neiwang_out] if-match acl name neiwang_out
[RouterB-classifier-neiwang_out] quit
[RouterB] traffic classifier web_out operator and
[RouterB-classifier-web_out] if-match acl name web_out
[RouterB-classifier-web_out] quit
[RouterB] traffic behavior web_permit
[RouterB-behavior-web_permit] filter permit
[RouterB-behavior-web_permit] free account
[RouterB-behavior-web_permit] quit
[RouterB] traffic behavior neiwang
[RouterB-behavior-neiwang] filter permit
[RouterB-behavior-neiwang] quit
[RouterB] traffic behavior web_http
[RouterB-behavior-web_http] redirect http-to-cpu
[RouterB-behavior-web_http] quit
[RouterB] traffic behavior web_https
[RouterB-behavior-web_https] redirect https-to-cpu
[RouterB-behavior-web_https] quit
[RouterB] traffic behavior web_deny
[RouterB-behavior-web_deny] filter deny
[RouterB-behavior-web_deny] free account
[RouterB-behavior-web_deny] quit
[RouterB] traffic behavior neiwang_out
[RouterB-behavior-neiwang_out] filter permit
[RouterB-behavior-neiwang_out] quit
[RouterB] traffic behavior web_out
[RouterB-behavior-web_out] filter permit
[RouterB-behavior-web_out] free account
[RouterB-behavior-web_out] quit
[RouterB] qos policy web
[RouterB-qospolicy-web] classifier web_permit behavior web_permit
[RouterB-qospolicy-web] classifier neiwang behavior neiwang
[RouterB-qospolicy-web] classifier web_http behavior web_http
[RouterB-qospolicy-web] classifier web_https behavior web_https
[RouterB-qospolicy-web] quit
[RouterB] qos policy out
[RouterB-qospolicy-out] classifier web_out behavior web_out
[RouterB-qospolicy-out] classifier neiwang_out behavior neiwang_out
[RouterB-qospolicy-out] classifier ip_deny behavior web_deny
[RouterB-qospolicy-out] quit
[RouterB] qos apply policy web global inbound
[RouterB] qos apply policy out global outbound
[RouterB] radius scheme rs1
[RouterB-radius-rs1] primary authentication 4.4.4.5
[RouterB-radius-rs1] primary accounting 4.4.4.5
[RouterB-radius-rs1] key authentication simple radius
[RouterB-radius-rs1] key accounting simple radius
[RouterB-radius-rs1] user-name-format without-domain
[RouterB-radius-rs1] quit
[RouterB] radius session-control enable
[RouterB] domain name dm1
[RouterB-isp-dm1] authentication ipoe none
[RouterB-isp-dm1] authorization ipoe none
[RouterB-isp-dm1] accounting ipoe none
[RouterB-isp-dm1] authorization-attribute user-group pre
[RouterB-isp-dm1] authorization-attribute ip-pool pool1
[RouterB-isp-dm1] web-server url http://4.4.4.5:8080/portal/
# Consider a user as idle and forcibly log out the user if the user generates less than 10240 bytes of data traffic within the detection period of 30 minutes.
[RouterB-isp-dm1] authorization-attribute idle-cut 30 10240
[RouterB-isp-dm1] quit
[RouterB] domain name dm2
[RouterB-isp-dm2] authentication ipoe radius-scheme rs1
[RouterB-isp-dm2] authorization ipoe radius-scheme rs1
[RouterB-isp-dm2] accounting ipoe radius-scheme rs1
[RouterB-isp-dm2] authorization-attribute idle-cut 30 10240
[RouterB-isp-dm2] quit
m.     Configure IPoE:
# Enable IPoE and configure Layer 3 access mode on Ten-GigabitEthernet 0/0/16.
[RouterB] interface ten-gigabitethernet 0/0/16
[RouterB–Ten-GigabitEthernet0/0/16] ip subscriber routed enable
[RouterB–Ten-GigabitEthernet0/0/16] ip subscriber authentication-method web
[RouterB–Ten-GigabitEthernet0/0/16] ip subscriber pre-auth domain dm1
[RouterB–Ten-GigabitEthernet0/0/16] ip subscriber web-auth domain dm2
# Disable online detection on Ten-GigabitEthernet 0/0/16.
The detection packet type is ARP by default. To use Layer 3 transparent authentication, as a best practice, disable online detection.
[RouterB–Ten-GigabitEthernet0/0/16] undo ip subscriber user-detect ip
[RouterB–Ten-GigabitEthernet0/0/16] quit
[RouterB] portal mac-trigger server mts
[RouterB-portal-mac-trigger-server-mts] ip 4.4.4.5
[RouterB-portal-mac-trigger-server-mts] quit
[RouterB–Ten-GigabitEthernet0/0/16] portal apply mac-trigger-server mts
a.     ‍Configure the access device:
-     Click Add to open the page as shown in Figure 95.
Figure 95 Adding an access device
-     Click Add Manually in the Device List area to open the page as shown in Figure 96.
-     Click OK.
Figure 96 Manually adding an access device
-     Click Add to open the page as shown in Figure 97.
Figure 97 Adding an access policy
-     Click Add to open the page as shown in Figure 98.
Figure 98 Adding an access service
d.     Add a user:
-     Select User Management > Add User from the navigation tree to open the adding user page, as shown in Figure 99.
-     Click OK.
Figure 99 Adding a user
-     Click Add to open the page as shown in Figure 100.
Figure 100 Adding an access user
a.     ‍Configure the portal homepage:
-     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page, as shown in Figure 101.
-     Click OK.
Figure 101 Portal server configuration page
-     Click Add to open the page as shown in Figure 102.
-     Click OK.
Figure 102 Adding an IP address group
-     Click Add to open the page as shown in Figure 103.
-     Click OK.
Figure 103 Adding a portal device
-     Click the icon in the Port Group Information Management column of device NAS to open the port group configuration page, as shown in Figure 104.
-     Click Add to open the page as shown in Figure 105.
-     Click OK.
Figure 104 Device list
Figure 105 Port group configuration
[RouterB] display access-user auth-type pre-auth
            IPv6 address
            0015e947f4d4         L3 IPoE dynamic(D/-)
As shown in Figure 106, the Web login page opens after preauthentication. Enter the username and password on the page.
Figure 106 Web login page
            IPv6 address
# Click Log Out on the Web login page as shown in Figure 106.
            IPv6 address
[RouterB] display access-user auth-type web-auth
            IPv6 address
Example: Configuring IPoE transparent MAC authentication (Layer 3 transparent)
As shown in Figure 107, the host accesses the BRAS as a DHCP client though a Layer 3 network. The BRAS also acts as the DHCP server. A server installed with H3C IMC acts as the portal authentication server and the portal Web server. This example uses IMC PLAT 7.1(E0303), IMC UAM 7.1(E0305), and IMC EIP 7.1(E0305). A RADIUS server that supports MAC binding acts as the authentication, authorization, and accounting server and performs MAC binding. The FTP server is an internal network server.
Figure 107 Network diagram
# Enable DHCP.
# Enable DHCP.
[RouterB] portal access-info trust arp
[RouterB] portal access-info trust nd
New user group added.
# Create an IPv4 advanced ACL named web_permit. Configure a rule to permit all packets destined for the portal server from users in user group pre.
# Create an IPv4 advanced ACL named neiwang. Configure a rule to permit all packets destined for the internal network server from users in user group pre.
# Create an IPv4 advanced ACL named web_http. Configure a rule to permit TCP packets with the destination port 80 (HTTP packets) from users in user group pre.
# Create an IPv4 advanced ACL named web_https, and configure a rule to permit TCP packets with the destination port 443 (HTTPS packets) from users in user group pre.
# Create an IPv4 advanced ACL named ip, and configure a rule to permit IP packets from users in user group pre.
# Create an IPv4 advanced ACL named neiwang_out, and configure a rule to permit IP packets from the internal network server in user group pre.
# Create an IPv4 advanced ACL named web_out, and configure a rule to permit IP packets from the portal server in user group pre.
# Create the traffic class web_permit and specify ACL web_permit as the match criterion.
# Create the traffic class neiwang and specify ACL neiwang as the match criterion.
# Create the traffic class web_http and specify ACL web_http as the match criterion.
# Create the traffic class web_https and specify ACL web_https as the match criterion.
[RouterB] traffic classifier ip_cpu operator or
[RouterB-classifier-ip_cpu] if-match acl name ip
[RouterB-classifier-ip_cpu] if-match acl ipv6 name ip
[RouterB-classifier-ip_cpu] quit
[RouterB] traffic classifier ip_deny operator or
[RouterB-classifier-ip_deny] if-match acl name ip
[RouterB-classifier-ip_deny] if-match acl ipv6 name ip
[RouterB-classifier-ip_deny] quit
# Create the traffic class neiwang_out and specify ACL neiwang_out as the match criterion.
# Create the traffic class web_out and specify ACL web_out as the match criterion.
# Configure the traffic behavior web_permit to permit traffic to pass through without rate limiting or accounting.
# Configure the traffic behavior neiwang to permit traffic to pass through.
# Configure the traffic behavior web_http to redirect HTTP packets to the CPU.
# Configure the traffic behavior web_https to redirect HTTPS packets to the CPU.
# Configure the traffic behavior web_deny to deny traffic.
# Configure the traffic behavior neiwang_out to permit traffic to pass through.
# Configure the traffic behavior web_out to permit traffic without rate limiting or traffic accounting.
# Create a QoS policy named web.
# Associate the traffic class web_permit with the traffic behavior web_permit.
# Associate the traffic class neiwang with the traffic behavior neiwang.
# Associate the traffic class web_http with the traffic behavior web_http.
# Associate the traffic class web_https with the traffic behavior web_https.
[RouterB-qospolicy-web] classifier ip_cpu behavior web_cpu
[RouterB-qospolicy-web] classifier ip_deny behavior web_deny
# Configure a QoS policy named out.
# Associate the traffic class web_out with the traffic behavior web_out. Associate the traffic class web_out with the traffic behavior web_out. Associate the traffic class web_deny with the traffic behavior web_deny.
# Apply the QoS Policy web to the inbound traffic globally. To identify whether the QoS policy takes effect, execute the display qos policy global inbound command.
# Apply the QoS Policy out to the outbound traffic globally. To identify whether the QoS policy takes effect, execute the display qos policy global outbound command.
[RouterB-radius-rs1] primary authentication 4.4.4.1
[RouterB-radius-rs1] primary accounting 4.4.4.1
# (Optional.) Enable RADIUS session control. As a best practice, configure this feature when an IMC server acts as the RADIUS server.
# Configure the ISP domain dm1 for IPoE user preauthentication.
# Configure the ISP domain dm2 for IPoE user Web authentication.
m.     Configure IPoE:
[RouterB–Ten-GigabitEthernet0/0/16] ip subscriber authentication-method web mac-auth
# Configure the ISP domain dm1 for preauthentication and the ISP domain dm2 for preauthentication on Ten-GigabitEthernet 0/0/16.
-     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page, as shown in Figure 108.
-     Click OK.
Figure 108 Portal server configuration page
-     Click Add to open the page as shown in Figure 109.
-     Click OK.
Figure 109 Adding an IP address group
-     Click Add to open the page as shown in Figure 110.
-     Click OK.
Figure 110 Adding a portal device
-     Click the icon in the Port Group Information Management column of device NAS to open the port group configuration page, as shown in Figure 111.
-     Click Add to open the page as shown in Figure 112.
-     Click OK.
Figure 111 Device list
Figure 112 Port group configuration
            IPv6 address
As shown in Figure 113, the Web login page opens after preauthentication. Enter the username and password on the page.
Figure 113 Web login page
            IPv6 address
# Click Log Out on the page as shown in Figure 113.
            IPv6 address
            IPv6 address
Example: Configuring IPoE Web authentication with EAP
As shown in Figure 114, the host accesses the BRAS as a DHCP client through a Layer 2 device. It obtains configuration information from the DHCP server through the BRAS. A server installed with H3C IMC acts as the RADIUS server, the portal authentication server, and the portal Web server. This example uses IMC PLAT 7.1(E0303), IMC UAM 7.1(E0305), and IMC EIP 7.1(E0305).
Figure 114 Network diagram
1.     ‍ Configure the DHCP server:
# Enable DHCP.
# Enable DHCP.
# Enable the DHCP relay agent on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] dhcp select relay
[Device-ip-pool-pool1] gateway 192.168.0.1 24
b.     Configure the IP address of the portal authentication server newpt as 4.4.4.1 and the plaintext key 123456.
[Device-portal-server-newpt] ip 4.4.4.1 key simple 123456
[Device-portal-server-newpt] quit
c.     Configure a RADIUS scheme:
[Device-radius-rs1] key authentication simple 123456
[Device-radius-rs1] key accounting simple 123456
d.     Configure the preauthentication ISP domain and Web authentication ISP domain:
# Configure the Web authentication page URL and Web server IP address in ISP domain dm1.
[Device-isp-dm1] web-server url http://4.4.4.1:8080/portal/
[Device-isp-dm1] web-server ip 4.4.4.1
e.     Configure IPoE:
# Configure Web authentication for IPoE users on Ten-GigabitEthernet 0/0/16.
The operation may cut all users on this interface. Continue?[Y/N]:y
# Configure the ISP domain dm1 for preauthentication and the ISP domain dm2 for Web authentication on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber pre-auth domain dm1
[Device–Ten-GigabitEthernet0/0/16] ip subscriber web-auth domain dm2
-     Log in to the IMC platform and click the User tab.
-     Select User Access Policy > Access Device Management > Access Device from the navigation tree to open the access device configuration page.
-     Click Add to open the page as shown in Figure 115.
-     Enter the shared key radius.
-     Use the default settings for other parameters.
Figure 115 Adding an access device
-     Click Add Manually in the Device List area to open the page as shown in Figure 116.
-     Enter the access device's IP address 4.4.4.2.
-     Click OK.
Figure 116 Manually adding an access device
-     Select User Access Policy > Access Policy from the navigation tree to open the access policy page.
-     Click Add to open the page as shown in Figure 117.
-     Enter the access policy name.
-     Select EAP for Certificate Authentication.
-     Click OK.
Figure 117 Adding an access policy
-     Select User Access Policy > Access Service from the navigation tree to open the access service page.
-     Click Add to open the page as shown in Figure 118.
-     Enter the service name.
-     Select AccessPolicy from the Default Access Policy list.
-     Click OK.
Figure 118 Adding an access service
d.     Add an access user:
-     Select Access User > All Access Users from the navigation tree to open the access user page.
-     Click Add to open the page as shown in Figure 119.
-     Select an access user.
-     Set the password.
-     Click OK.
Figure 119 Adding an access user
# Select User Access Policy > Service Parameters > Validate System Configuration from the navigation tree to validate the configurations.
-     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page, as shown in Figure 120.
-     Click OK.
Figure 120 Portal server configuration page
-     Select User Access Policy > Portal Service > IP Group from the navigation tree to open the portal IP address group configuration page.
-     Click Add to open the page as shown in Figure 121.
-     Enter the IP group name IPoE_Web_User.
-     Enter the start IP address (192.168.0.1) and end IP address (192.168.0.255) of the IP group. Make sure the host IP address is in the IP group.
-     Click OK.
Figure 121 Adding an IP address group
-     Select User Access Policy > Portal Service > Device from the navigation tree to open the portal device configuration page.
-     Click Add to open the page as shown in Figure 122.
-     Enter the device name NAS.
-     Enter the IP address of the portal packets' outgoing interface Ten-GigabitEthernet 0/0/15 (4.4.4.2).
-     Enter the key 123456.
-     Select Directly Connect for access method.
-     Click OK.
Figure 122 Adding a portal device
-     Click the icon in the Port Group Information Management column of device NAS to open the port group configuration page, as shown in Figure 123.
-     Click Add to open the page as shown in Figure 124.
-     Enter the port group name group.
-     Select the configured IP address group IPoE_Web_User. Make sure the IP address used by the user to access the network is within this IP address group.
-     Select EAP from the Authentication Type list.
-     Click OK.
Figure 123 Device list
Figure 124 Port group configuration
# Display IPoE session information to verify that the host has passed preauthentication.
            IPv6 address
0x33d       XGE0/0/16            192.168.0.2             0015-e947-f4d4  -/-
# As shown in Figure 125, open the iNode login page after preauthentication. Enter the server address, the username, and the password on the page. Click the dropdown arrow next to Disconnect. The page shown in Figure 126 opens.
Figure 125 iNode login page
# As shown in Figure 126, select Certificate Authentication in the Enable advanced authentication list and select an authentication type (EAP-TLS in this example) in the Advanced tab of the Properties dialog box. In the Certificate Options area, click Client Certificate, select a certificate on the window that opens, and select Validate server certificate chain.
Figure 126 Setting iNode client attribute
# After the configuration of iNode client attribute, click OK to return to the iNode client authentication page.
# Click Connect on the iNode authentication page to perform EAP authentication. Display IPoE session information to verify that the host has passed Web authentication and come online.
            IPv6 address
            client               Web auth(D/-)
# Click Disconnect on the iNode login page as shown in Figure 125.
            IPv6 address
Example: Configuring IPoE 802.1X authentication
As shown in Figure 127:
·     An 802.1X client accesses the BRAS in IPoE mode through a Layer 2 network.
Figure 127 Network diagram
1.     ‍Configure the RADIUS server:
This section uses the Linux Free RADIUS server as an example.
# Configure the RADIUS client. Add the following contents to the clients.conf file.
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
The contents above configure the RADIUS client IP address as 4.4.4.2 and configure the shared key as radius.
# Configure users. Add the username and password to the users user information file. The username is user1 and the password is pass1.
user1  Cleartext-Password :="pass1"
2.     Configure the DHCP server:
[DHCP-server-ip-pool-pool1] network 192.168.0.0 24
[DHCP-server-ip-pool-pool1] gateway-list 192.168.0.1
[DHCP-server-dhcp-pool-pool1] dns-list 8.8.8.8
[DHCP-server-ip-pool-pool1] forbidden-ip 192.168.0.1
3.     Configure Device:
# Enable recording client information in relay entries.
[Device] dhcp relay client-information record
[Device] undo dhcp relay client-information refresh enable
[Device-ip-pool-pool1] forbidden-ip 192.168.0.1
b.     Create a user group named dot1x for the preauthentication domain.
[Device] user-group dot1x
[Device-ugroup-dot1x] quit
c.     Configure the ACLs for users in the preauthentication domain:
# Configure IPv4 advanced ACL neiwang to match packets destined to the internal network server for users in user group dot1x.
[Device-acl-ipv4-adv-neiwang] rule 0 permit ip destination 4.4.4.6 0 user-group dot1x
# Configure IPv4 advanced ACL ip to match IP packets for users in user group dot1x.
[Device-acl-ipv4-adv-ip] rule 0 permit ip user-group dot1x
# Configure IPv4 advanced ACL neiwang_out to match packets sourced from the internal network server for users in user group dot1x.
[Device-acl-ipv4-adv-neiwang_out] rule 0 permit ip source 4.4.4.6 0 user-group dot1x
d.     Configure traffic classes for users in the preauthentication domain:
# Create a traffic class named dot1x_deny, and use ACL ip as the match criterion.
[Device] traffic classifier dot1x_deny operator and
[Device-classifier-dot1x_deny] if-match acl name ip
[Device-classifier-dot1x_deny] quit
e.     Configure traffic behaviors:
# Configure a traffic behavior named neiwang to permit packets.
# Create a traffic behavior named dot1x_deny to deny packets.
[Device] traffic behavior dot1x_deny
[Device-behavior-dot1x_deny] filter deny
[Device-behavior-dot1x_deny] free account
[Device-behavior-dot1x_deny] quit
# Configure a traffic behavior named neiwang_out to permit packets.
f.     Configure QoS policies:
# Configure a QoS policy named dot1x for inbound traffic.
[Device] qos policy dot1x
# Associate traffic classes with traffic behaviors to permit packets destined to the internal network server and deny any other packets for users in user group dot1x.
[Device-qospolicy-dot1x] classifier neiwang behavior neiwang
[Device-qospolicy-dot1x] classifier dot1x_deny behavior dot1x_deny
[Device-qospolicy-dot1x] quit
# Associate traffic classes with traffic behaviors to permit packet sourced from the internal network server and deny any other packets for users in user group dot1x.
[Device-qospolicy-out] classifier dot1x_deny behavior dot1x_deny
g.     Apply QoS policies:
# Apply QoS policy dot1x to the received user traffic.
[Device] qos apply policy dot1x global inbound
# Apply QoS policy out to the online user traffic sent.
h.     Configure a RADIUS scheme:
[Device-radius-rs1] primary authentication 4.4.4.5
[Device-radius-rs1] primary accounting 4.4.4.5
i.     Configure the preauthentication domain and 802.1X authentication domain:
# Configure the authorized address pool and user group in the preauthentication domain.
[Device-isp-dm1] authorization-attribute user-group dot1x
# Configure the 802.1X authentication domain for IPoE users.
[Device] domain name dot1x
[Device-isp-dot1x] authentication lan-access radius-scheme rs1
[Device-isp-dot1x] authorization lan-access radius-scheme rs1
[Device-isp-dot1x] accounting lan-access radius-scheme rs1
# Configure the authorized address pool. (This step is required when 802.1X authentication is prioritized and optional in this example.)
[Device-isp-dot1x] authorization-attribute ip-pool pool1
[Device-isp-dot1x] quit
j.     Configure IPoE:
# Configure the 802.1X authentication method for IPoE users.
When endpoint users using the IOS system exist on the network and these users use the 802.1X service of the IOS system for authentication, prioritize 802.1X authentication as a best practice. If you do not do that, the users might fail to use the 802.1X service of the IOS system to perform 802.1X authentication. In this example, 802.1X authentication is not prioritized.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber authentication-method dot1x
The operation might cut all users on this interface. Continue?[Y/N]:y
# Configure the preauthentication domain as dm1 and 802.1X authentication domain as dot1x.
[Device–Ten-GigabitEthernet0/0/16] dot1x mandatory-domain dot1x
# (Optional.) Forcibly log out the 802.1X client of an IPoE user when the IP address of an IPoE user is released. (If you want to log out the 802.1X client of an IPoE user when the IPoE user goes offline because the IP address lease expires or fails to be renewed or the device receives the DHCP-RELEASE, DHCP-DECLINE, and DHCP-NAK packets from the IPoE user, this step is required.)
[Device–Ten-GigabitEthernet0/0/16] ip subscriber dhcp-release-ip dot1x-offline
# (Optional.) Forcibly log out an IPoE user when the 802.1X client of the IPoE user goes offline. (If you want to log out an IPoE user when the 802.1X client of the IPoE user goes offline, this step is required.)
[Device–Ten-GigabitEthernet0/0/16] ip subscriber dot1x-offline user-offline
# (Optional.) Enable the online user handshake feature, and enable the 802.1X online user handshake reply feature. (If you want to perform online detection for an 802.1X client and log out the 802.1X client when the detection fails, this step is required. To set the handshake timer (15 seconds by default), use the dot1x timer handshake-period command. To set the maximum handshake attempts (2 by default), use the dot1x retry command.
[Device–Ten-GigabitEthernet0/0/16] dot1x handshake
[Device–Ten-GigabitEthernet0/0/16] dot1x handshake reply enable
# (Optional.) Enable the online user handshake security feature. (This step is required  on the network where the iNode client and IMC server are used.)
[Device–Ten-GigabitEthernet0/0/16] dot1x handshake secure
[Device] display access-user interface ten-gigabitethernet 0/0/16
UserID      Interface            IP address              MAC address     S-/C-VLAN
            Username             Access type
            IPv6 address
0x5c        XGE0/0/16            192.168.0.2             000c-29a6-b656  -/-
            000c29a6b656         L2 IPoE dynamic(D/-)
# An 802.1X client uses username user1 and password pass1 to perform 802.1X authentication. Use the following command to view online IPoE user information.
            IPv6 address
            user1                L2 IPoE dynamic(D/-)
As shown in Figure 128, the host accesses the BRAS as a DHCP client though a Layer 2 device. It obtains configuration information from the DHCP server through the BRAS. The BRAS performs AAA for the host through the RADIUS server. A server installed with H3C IMC acts as the RADIUS server, the portal authentication server, and the portal Web server. This example uses IMC PLAT 7.1(E0303), IMC UAM 7.1(E0305), and IMC EIP 7.1(E0305). The FTP server is an internal network server. Limit the access rate to 5 Mbps for the user after passing Web authentication.
When a student does not pass IPoE Web authentication or has passed IPoE Web authentication but has owed fees, the student is still allowed to access the internal websites of the campus. In this way, the student can still learn and communicate normally.
When a student owes fees, the student is still allowed to access the payment page of the service provider and pay the charge on the payment page pushed by the service provider. In this way, the student can quickly restore access to Internet.
Figure 128 Network diagram
Analysis
To ensure that an unauthenticated or defaulting user can still access the internal websites of the campus and actively pay the charge, you can configure the object group-based URL allowlist and add the internal websites of the campus (FTP server and IMC server in this example) and the payment page address (https://www.alipay.com/xxx in this example) to the URL allowlist.
To facilitate QoS policy-based control for users, assign users to different user groups based on their states:
·     Preauthentication users: In this phase, users have not passed IPoE Web authentication and need access control. Assign these users to the user group named pre.
·     Defaulting users: Defaulting users need access control. Assign these users to the user group named qianfei.
·     Normal users: These users do not need access control. Assign these users to the user group named web.
For users in user group pre and user group qianfei, perform the following QoS policy-based controls separately:
·     Users in user group pre
¡     Can access the addresses on the URL allowlist.
¡     When a user accesses an address not on the URL allowlist through HTTP or HTTPS, all requests are redirected to the Web authentication page (http://www.ipv4web.com or http://www.ipv6.web.com in this example), and the other traffic is dropped.
·     Users in user group qianfei
¡     When a user accesses an address not on the URL allowlist through HTTP or HTTPS, all requests are redirected to the payment page (https://www.alipay.com/xxx in this example), and the other traffic is dropped.
Configure the DNS server correctly, so that the server can parse the IPv4 URL or IPv6 URL for the Web authentication page http://www.ipv4.web.com or http://www.ipv6.web.com based on the first stack through which dual-stack IPoE users come online. (Details not shown.)
Configure IP addresses for interfaces, and make sure devices can reach each other at Layer 3. (Details not shown.)
You must use this feature together with AAA. Before configuring this feature, make sure the AAA server supports H3C private attributes 246 (H3C-Auth-Detail-Result) and 250 (H3C-WEB-URL) and can assign these attributes to defaulting users.
Attribute 246 (H3C-Auth-Detail-Result) indicates the user authentication result details. Possible values for the attribute include:
·     0: Normal user. In this case, the server will cancel assigning attribute 250 and allow the user to access any network resources.
·     1: Defaulting user. In this case, the server will assign attribute 250 and allow the user to access network resources on the URL allowlist. If the user accesses other network resources, the requests will be redirected to the URL defined in attribute 250.
·     2: User whose broadband usage has expired. In this case, the server will assign attribute 250. The first Web access request of the user will be redirected to the URL defined in attribute 250.
Attribute 250 (H3C-WEB-URL) is used to carry the Web redirection URL for users, and is used together with attribute 246.
1.     ‍Configure the DHCP servers:
a.     Configure an IP address pool:
# Enable DHCP.
<DHCP-server> system-view
# Create an IPv4 address pool named pool1 and enter its view.
# Specify primary subnet 192.168.0.0/24 for dynamic allocation and DNS server 8.8.8.8 in address pool pool1.
# Specify gateway address 192.168.0.1 in address pool pool1.
[DHCP-ip-pool-pool1] gateway-list 192.168.0.1
# Exclude IP address 192.168.0.1 from dynamic allocation in address pool pool1.
# Configure the default route.
b.     Configure an IPv6 address pool:
# Create an IPv6 address pool named pool2 and enter its view.
[DHCP-server] ipv6 pool pool2
# Specify primary subnet 192::/64 for dynamic allocation and DNS server 8::8 in address pool pool2.
[DHCP-server-ipv6-pool-pool2] network 192::/64
[DHCP-server-ipv6-pool-pool2] dns-server 8::8
[DHCP-server-ipv6-pool-pool2] quit
# Exclude IP address 192::1 from dynamic allocation in address pool pool2.
[DHCP-server] ipv6 dhcp server forbidden-address 192::1
# Enable the DHCPv6 server on Ten-GigabitEthernet 0/0/15.
[DHCP-server] interface ten-gigabitethernet 0/0/15
[DHCP-server-Ten-GigabitEthernet0/0/15] ipv6 dhcp select server
[DHCP-server-Ten-GigabitEthernet0/0/15] quit
[DHCP-server] ipv6 route-static :: 0 4::2
2.     Configure the BRAS:
a.     Configure the DHCP relay agent:
# Enable DHCP.
# Create a remote BAS IP address pool named pool1.
# Specify DHCP server 4.4.4.3 in address pool pool1.
# Create a remote IPv6 address pool named pool2.
[Device] ipv6 pool pool2
# Specify gateway address 192::1 in address pool pool2.
[Device-ipv6-pool-pool2] gateway-list 192::1
# Specify IPv6 subnet 192::/64  in address pool pool2.
[Device-ipv6-pool-pool2] network 192::/64 export-route
# Specify DHCP server 4::3 in address pool pool2.
[Device-ipv6-pool-pool2] remote-server 4::3
[Device-ipv6-pool-pool2] quit
# Enable the DHCPv4 relay agent on Ten-GigabitEthernet 0/0/16.
[Device] interface ten-gigabitethernet 0/0/16
# Automatically generate a link-local address for Ten-GigabitEthernet 0/0/16.
# Enable the DHCPv6 relay agent on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ipv6 dhcp select relay
# Disable RA message suppression on Ten-GigabitEthernet 0/0/16.
# Set the managed address configuration flag (M) to 1 in RA advertisements to be sent. Then, the host uses a DHCPv6 server to obtain IPv6 addresses.
[Device–Ten-GigabitEthernet0/0/16] ipv6 nd autoconfig managed-address-flag
# Set the other stateful configuration flag (O) to 1 in RA advertisements to be sent. Then, the host uses a DHCPv6 server to obtain configuration information other than IPv6 addresses.
[Device–Ten-GigabitEthernet0/0/16] ipv6 nd autoconfig other-flag
# Disable Ten-GigabitEthernet 0/0/16 from advertising the specified prefix in RA messages, preventing the endpoint from obtaining a temporary IPv6 address. In an IPv6 network, an endpoint might use a temporary IPv6 address for IPoE Web authentication, which will cause authentication failure.
[Device–Ten-GigabitEthernet0/0/16] ipv6 nd ra prefix 192::/64 no-advertise
[Device–Ten-GigabitEthernet0/0/16] quit
b.     Configure the portal servers:
# Configure the IP address of the IPv4 portal authentication server newpt1 as 4.4.4.5 and the plaintext key 123456.
[Device] portal server newpt1
[Device-portal-server-newpt1] ip 4.4.4.5 key simple 123456
[Device-portal-server-newpt1] quit
# Configure the IPv6 address of the IPv6 portal authentication server newpt2 as 4::5 and the plaintext key 123456.
c.     Specify 11111 as the HTTPS redirect listening port number. Make sure the port number is not used by any other service. To see the TCP port numbers used by other services, execute the display tcp command.
d.     Configure the device to get user access information from ARP and ND entries.
[Device] portal access-info trust arp
[Device] portal access-info trust nd
e.     Create local user groups:
# Create a local user group named pre for preauthentication users.
[Device] user-group pre
[Device-ugroup-pre] quit
# Create a user group named qianfei for defaulting users.
[Device] user-group qianfei
[Device-ugroup-qianfei] quit
# Create a user group named web.
[Device] user-group web
[Device-ugroup-web] quit
f.     Configure URL allowlists:
# Create an IP address object group (URL allowlist) named freeurl_ipv4, and add the internal websites of the campus and the payment page to the URL allowlist.
[Device] object-group ip address freeurl_ipv4
[Device-obj-grp-ip-freeurl_ipv4] network host address 4.4.4.1 //FTP server address
[Device-obj-grp-ip-freeurl_ipv4] network host address 4.4.4.5 //iMC server address
[Device-obj-grp-ip-freeurl-ipv4] network host name https://www.alipay.com/xxx //Payment page address
[Device-obj-grp-ip-freeurlipv4] quit
# Create an IPv6 address object group (URL allowlist) named freeurl_ipv6, and add the internal websites of the campus and the payment page to the URL allowlist.
[Device] object-group ipv6 address freeurl_ipv6
[Device-obj-grp-ipv6-freeurl_ipv6] network host address 4::1 //FTP server address
[Device-obj-grp-ipv6-freeurl_ipv6] network host address 4::5 //iMC server address
[Device-obj-grp-ipv6-freeurl_ipv6] network host name https://www.alipay.com/xxx //Payment page address
[Device-obj-grp-ipv6-freeurl_ipv6] quit
g.     Configure common ACLs for URL allowlists, which apply to both preauthentication users and defaulting users:
# Create the following rules for IPv4 and IPv6 advanced ACLs freeurl_permit_in separately to allow packets from users in user group pre and user group qianfei to the addresses on the allowlist.
[Device] acl advanced name freeurl_permit_in
[Device-acl-ipv4-adv-freeurl_permit_in] rule 10 permit ip destination object-group freeurl_ipv4 user-group pre
[Device-acl-ipv4-adv-freeurl_permit_in] rule 20 permit ip destination object-group freeurl_ipv4 user-group qianfei
[Device-acl-ipv4-adv-freeurl_permit_in] quit
[Device] acl ipv6 advanced name freeurl_permit_in
[Device-acl-ipv6-adv-freeurl_permit_in] rule 10 permit ipv6 destination object-group freeurl_ipv6 user-group pre
[Device-acl-ipv6-adv-freeurl_permit_in] rule 20 permit ipv6 destination object-group freeurl_ipv6 user-group qianfei
[Device-acl-ipv6-adv-freeurl_permit_in] quit
# Create the following rules for IPv4 and IPv6 advanced ACLs freeurl_permit_out separately to match packets that users in user group pre and user group qianfei receive from the addresses on the allowlist.
[Device] acl advanced name freeurl_permit_out
[Device-acl-ipv4-adv-freeurl_permit_out] rule 10 permit ip source object-group freeurl_ipv4 user-group pre
[Device-acl-ipv4-adv-freeurl_permit_out] rule 20 permit ip source object-group freeurl_ipv4 user-group qianfei
[Device-acl-ipv4-adv-freeurl_permit_out] quit
[Device] acl ipv6 advanced name freeurl_permit_out
[Device-acl-ipv6-adv-freeurl_permit_out] rule 10 permit ipv6 source object-group freeurl_ipv6 user-group pre
[Device-acl-ipv6-adv-freeurl_permit_out] rule 20 permit ipv6 source object-group freeurl_ipv6 user-group qianfei
[Device-acl-ipv6-adv-freeurl_permit_out] quit
# Create an IPv4 and IPv6 advanced ACL named web_http separately. Configure a rule to permit TCP packets with the destination port 80 (HTTP packets) from users in user group pre.
[Device] acl ipv6 advanced name web_http
[Device-acl-ipv6-adv-web_http] rule 0 permit tcp destination-port eq www user-group pre
[Device-acl-ipv6-adv-web_http] quit
# Create an IPv4 and IPv6 advanced ACL named web_https separately, and configure a rule to permit TCP packets with the destination port 443 (HTTPS packets) from users in user group pre.
[Device] acl ipv6 advanced name web_https
[Device-acl-ipv6-adv-web_https] rule 0 permit tcp destination-port eq 443 user-group pre
[Device-acl-ipv6-adv-web_https] quit
# Create an IPv4 and IPv6 advanced ACL named ip separately, and configure a rule to permit IP packets from users in user group pre.
[Device] acl ipv6 advanced name ip
[Device-acl-ipv6-adv-ip] rule 0 permit ipv6 user-group pre
[Device-acl-ipv6-adv-ip] quit
i.     Configure the ACLs for defaulting users:
# Create the following rules for IPv4 and IPv6 advanced ACLs qianfei_web_http separately to match TCP packets that users in user group qianfei use to access port 80, HTTP packets.
[Device] acl advanced name qianfei_web_http
[Device-acl-ipv4-adv-qianfei_web_http] rule 0 permit tcp destination-port eq www user-group qianfei
[Device-acl-ipv4-adv-qianfei_web_http] quit
[Device] acl ipv6 advanced name qianfei_web_http
[Device-acl-ipv6-adv-qianfei_web_http] rule 0 permit tcp destination-port eq www user-group qianfei
[Device-acl-ipv6-adv-qianfei_web_http] quit
# Create the following rules for IPv4 and IPv6 advanced ACLs qianfei_web_https separately to match packets that users in user group qianfei use to access port 443, HTTPS packets.
[Device] acl advanced name qianfei_web_https
[Device-acl-ipv4-adv-qianfei_web_https] rule 0 permit tcp destination-port eq 443 user-group qianfei
[Device-acl-ipv4-adv-qianfei_web_https] quit
[Device] acl ipv6 advanced name qianfei_web_https
[Device-acl-ipv6-adv-qianfei_web_https] rule 0 permit tcp destination-port eq 443 user-group qianfei
[Device-acl-ipv6-adv-qianfei_web_https] quit
# Create the following rules for IPv4 and IPv6 advanced ACLs qianfei_ip separately to match IP packets of users in user group qianfei.
[Device] acl advanced name qianfei_ip
[Device-acl-ipv4-adv-qianfei_ip] rule 0 permit ip user-group qianfei
[Device-acl-ipv4-adv-qianfei_ip] quit
[Device] acl ipv6 advanced name qianfei_ip
[Device-acl-ipv6-adv-qianfei_ip] rule 0 permit ipv6 user-group qianfei
[Device-acl-ipv6-adv-qianfei_ip] quit
j.     Configure common traffic classes for URL allowlists, which apply to both preauthentication users and defaulting users:
# Create a traffic class named freeurl_permit_in, and use ACL freeurl_permit_in as the match criterion.
[Device] traffic classifier freeurl_permit_in operator or
[Device-classifier-freeurl_permit_in] if-match acl name freeurl_permit_in
[Device-classifier-freeurl_permit_in] if-match acl ipv6 name freeurl_permit_in
[Device-classifier-freeurl_permit_in] quit
# Create a traffic class named freeurl_permit_out, and use ACL freeurl_permit_out as the match criterion.
[Device] traffic classifier freeurl_permit_out operator or
[Device-classifier-freeurl_permit_out] if-match acl name freeurl_permit_out
[Device-classifier-freeurl_permit_out] if-match acl ipv6 name freeurl_permit_out
[Device-classifier-freeurl_permit_out] quit
k.     Configure QoS traffic classes for preauthentication users:
[Device] traffic classifier web_http operator or
[Device-classifier-web_http] if-match acl ipv6 name web_http
[Device] traffic classifier web_https operator or
[Device-classifier-web_https] if-match acl ipv6 name web_https
# Create the traffic class web_deny and specify ACL ip as the match criterion.
[Device] traffic classifier web_deny operator or
[Device-classifier-web_deny] if-match acl name ip
[Device-classifier-web_deny] if-match acl ipv6 name ip
[Device-classifier-web_deny] quit
l.     Configure the traffic classes for defaulting users:
# Create a traffic class named qianfei_web_http and use ACL qianfei_web_http as the match criterion.
[Device] traffic classifier qianfei_web_http operator or
[Device-classifier-qianfei_web_http] if-match acl name qianfei_web_http
[Device-classifier-qianfei_web_http] if-match acl ipv6 name qianfei_web_http
[Device-classifier-qianfei_web_http] quit
# Create a traffic class named qianfei_web_https, and use ACL qianfei_web_https as the match criterion.
[Device] traffic classifier qianfei_web_https operator or
[Device-classifier-qianfei_web_https] if-match acl name qianfei_web_https
[Device-classifier-qianfei_web_https] if-match acl ipv6 name qianfei_web_https
[Device-classifier-qianfei_web_https] quit
# Create a traffic class named qianfei_web_deny, and use ACL qianfei_ip as the match criterion.
[Device] traffic classifier qianfei_web_deny operator or
[Device-classifier-qianfei_web_deny] if-match acl name qianfei_ip
[Device-classifier-qianfei_web_deny] if-match acl ipv6 name qianfei_ip
[Device-classifier-qianfei_web_deny] quit
m.     Configure common traffic behaviors for URL allowlists, which apply to both preauthentication users and defaulting users:
# Create a traffic behavior named freeurl_permit_in, and allow users in user group pre and user group qianfei to access the addresses on the allowlist.
[Device] traffic behavior freeurl_permit_in
[Device-behavior-freeurl_permit_in] filter permit
[Device-behavior-freeurl_permit_in] free account
[Device-behavior-freeurl_permit_in] quit
# Create a traffic behavior named freeurl_permit_out, and allow packets from the addresses on the allowlist to users in user group pre and user group qianfei.
[Device] traffic behavior freeurl_permit_out
[Device-behavior-freeurl_permit_out] filter permit
[Device-behavior-freeurl_permit_out] free account
[Device-behavior-freeurl_permit_out] quit
n.     Configure QoS traffic behaviors for preauthentication users:
o.     Configure traffic behaviors for defaulting users:
# Create a traffic behavior named qianfei_web_http, and redirect TCP packets that users in user group qianfei use to access port 80 (HTTP packets) to the CPU.
[Device] traffic behavior qianfei_web_http
[Device-behavior-qianfei_web_http] redirect http-to-cpu
[Device-behavior-qianfei_web_http] quit
# Create a traffic behavior named qianfei_web_https, and redirect TCP packets that users in user group qianfei use to access port 443 (HTTPS packets) to the CPU.
[Device] traffic behavior qianfei_web_https
[Device-behavior-qianfei_web_https] redirect https-to-cpu
[Device-behavior-qianfei_web_https] quit
# Create a traffic behavior named qianfei_web_deny, and deny all IP packets from the users in user group qianfei.
[Device] traffic behavior qianfei_web_deny
[Device-behavior-qianfei_web_deny] filter deny
[Device-behavior-qianfei_web_deny] free account
[Device-behavior-qianfei_web_deny] quit
p.     Configure the QoS policies:
# Permit the traffic from users in user group pre and user group qianfei to the addresses on the allowlist to pass through. Then, when a student does not pass IPoE Web authentication or has passed IPoE Web authentication but has owed fees, the student is still allowed to access the internal websites of the campus and access the payment page to pay the charge. In this way, the student can still learn and communicate normally.
[Device-qospolicy-web] classifier freeurl_permit_in behavior freeurl_permit_in
# Redirect the HTTP packets from users in user group pre to the Web authentication page.
# Redirect the HTTPS packets from users in user group pre to the Web authentication page.
# Redirect the HTTP packets from users in user group qianfei to the payment page.
[Device-qospolicy-web] classifier qianfei_web_http behavior qianfei_web_http
# Redirect the HTTPS packets from users in user group qianfei to the payment page.
[Device-qospolicy-web] classifier qianfei_web_https behavior qianfei_web_https
# Drop all the other traffic from users in user group pre.
[Device-qospolicy-web] classifier web_deny behavior web_deny
# Drop all the other traffic from users in user group qianfei.
[Device-qospolicy-web] classifier qianfei_web_deny behavior qianfei_web_deny
# Configure an outbound QoS policy named out.
# Allow packets from the addresses on the allowlist to users in user group pre and user group qianfei to pass through.
[Device-qospolicy-out] classifier freeurl_permit_out behavior freeurl_permit_out
[Device-qospolicy-out] classifier web_deny behavior web_deny
[Device-qospolicy-out] classifier qianfei_web_deny behavior qianfei_web_deny
q.     Apply the QoS policies:
r.     Configure a RADIUS scheme:
# Create a RADIUS scheme named rs1 and enter its view.
# Configure primary servers and keys for authentication and accounting.
# Exclude the ISP name from the username sent to the RADIUS server.
[Device-radius-rs1] user-name-format without-domain
# Set the IP address of the RADIUS DAE client to 4.4.4.5, and set the shared key to radius for the RADIUS DAE client to exchange DAE packets.
[Device] radius dynamic-author server
[Device-radius-da-server] client ip 4.4.4.5 key simple radius
[Device-radius-da-server] quit
s.     Configure the preauthentication ISP domain and Web authentication ISP domain:
# Configure the authorized user group and IP address pools in preauthentication ISP domain dm1.
[Device-isp-dm1] authorization-attribute ipv6-pool pool2
# Configure the Web authentication page URL in ISP domain dm1.
[Device-isp-dm1] web-server url http://www.ipv4.web.com
[Device-isp-dm1] web-server ipv6-url http://www.ipv6.web.com
# Configure the ISP domain dm2 for IPoE user Web authentication, and authorize a CAR policy and a user group.
[Device-isp-dm2] authorization-attribute car inbound cir 5120 outbound cir 5120
[Device-isp-dm2] authorization-attribute user-group web
t.     Configure IPoE:
# Enable IPoE and configure Layer 2 access mode on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber l2-connected enable
[Device–Ten-GigabitEthernet0/0/16] ip subscriber authentication-method web
3.     Configure the RADIUS server:
a.     Configure the access device:
-     Click Add to open the page as shown in Figure 129.
Figure 129 Adding an access device
-     Click Add Manually in the Device List area to open the page as shown in Figure 130.
-     Click OK.
Figure 130 Manually adding an access device
b.     Add an access policy:
-     Click Add to open the page as shown in Figure 131.
-     Enter the access policy name AccessPolicy.
Figure 131 Adding an access policy
c.     Add an access service:
-     Click Add to open the page as shown in Figure 132.
-     Enter the service name IPoE_Server.
-     Select AccessPolicy from the default access policy list.
Figure 132 Adding an access service
d.     Add a user:
-     Select User Management > Add User from the navigation tree to open the adding user page, as shown in Figure 133.
-     Enter the username IPoE_Web001 and the user ID 001.
-     Click OK.
Figure 133 Adding a user
e.     Add an access user:
-     Click Add to open the page as shown in Figure 134.
-     Select IPoE_Web001 for the username.
-     Enter the account name user1.
-     Enter the password pass1.
-     Select the access service IPoE_Server.
Figure 134 Adding an access user
4.     Configure the portal server:
a.     Configure the portal homepage:
-     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page, as shown in Figure 135.
-     Click OK.
Figure 135 Portal server configuration page
b.     Configure portal authentication source IP address range:
-     Click Add to open the page as shown in Figure 136.
-     Click OK.
Figure 136 Adding an IP address group (IPv4)
-     Click Add to open the page as shown in Figure 137.
-     Enter the IP group name IPoE_Web_User-2.
-     Select Yes from the IPv6 list.
-     Enter the start IP address (192::1) and end IP address (192::FFFF) of the IP group. Make sure the host IPv6 address is in the IP group.
-     Click OK.
Figure 137 Adding an IP address group (IPv6)
c.     Add portal devices:
-     Click Add to open the page as shown in Figure 138.
-     Enter the IP address of the portal packets' outgoing interface Ten-GigabitEthernet 0/0/16 (4.4.4.2).
-     Select Directly Connect for the access method.
-     Click OK.
Figure 138 Adding a portal device (IPv4)
-     Click Add to open the page as shown in Figure 139.
-     Enter the device name NAS-2.
-     Select Portal 3.0 from the Version list.
-     Enter the IP address of the portal packets' outgoing interface Ten-GigabitEthernet 0/0/16 (4::2).
-     Click OK.
Figure 139 Adding a portal device (IPv6)
d.     Associate the portal device with the IP address group:
-     Click the icon in the Port Group Information Management column of device NAS to open the port group configuration page, as shown in Figure 140.
-     Click Add to open the page as shown in Figure 141.
-     Click OK.
Figure 140 Device list
Figure 141 Port group configuration (IPv4)
-     Click the icon in the Port Group Information Management column of device NAS-2 to open the port group configuration page, as shown in Figure 140.
-     Click Add to open the page as shown in Figure 142.
-     Enter the port group name group-2.
-     Select the configured IP address group IPoE_Web_User-2. Make sure the IPv6 address used by the user to access the network is within this IPv6 address group.
-     Click OK.
Figure 142 Port group configuration (IPv6)
# Display IPoE session information to verify that the host has passed preauthentication and obtained IPv4 address 192.168.0.2 and IPv6 address 192::2.
            IPv6 address
            0015e947f4d4         L2 IPoE dynamic(D/D)
            192::2
As shown in Figure 143, the Web login page opens after preauthentication. Enter the username and password on the page.
Figure 143 Web login page
# Display IPoE session information to verify that the host has passed Web authentication and come online.
            IPv6 address
            user1@dm2            Web auth(D/D)
            192::2
# When a user owes fee, the AAA server assigns the following attributes to the user:
user-name =user1@dm2 , H3C-User-Group = qianfei,h3c-web-url = "www.alipay.com/xxx",H3C-Auth_Detail_Result = 1
Where, each attributes are explained as follows:
·     user-name =user1@dm2   //The username of the defaulting user is user1@dm2.
·     H3C-User-Group = qianfei   //The user group named qianfei is assigned to the defaulting user.
·     H3C-Auth-Detail-Result=1   //The value 1 means the user is a defaulting user and can access only addresses on the URL allowlist. When the user accesses an address not on the URL allowlist through HTTP or HTTPS, the packets are redirected  to the website specified in the H3C-WEB-URL attribute.
·     H3c-WEB-URL="https://www.alipay.com/xxx"   //This attribute specifies the website to which packets from the defaulting user are redirected.
In this case, the user can access only addresses on the URL allowlist through HTTP. When the user accesses an address not on the URL allowlist through HTTP, the packets are redirected to the website https://www.alipay.com/xxx. For example, when you enter http://www.163.com/ in the address bar of a browser, you are redirected to the payment page.
# After the user pays the charge, the AAA server assigns the following attributes to the user:
user-name =user1@dm2 , H3C-User-Group =web ,H3C-Auth_Detail_Result = 0
·     user-name =user1@dm2   //The username of the user who has paid the charge is user1@dm2.
·     H3C-User-Group = web   //The user group named web is assigned to the user who has paid the charge, and the user is removed user group qianfei.
·     H3C-Auth-Detail-Result=0   //The value 0 means the redirection action is canceled for the user.
In this case, the user can access any network resources. For example, when you enter http://www.baidu.com/ in the address bar of a browser, the Baidu page opens normally.
Example: Configuring IPoE common Web authentication and intelligent multi-egress for dual-stack IPoE users
As shown in Figure 144, the host accesses the BRAS as a DHCP client though a Layer 2 device. It obtains configuration information from the DHCP server through the BRAS. The BRAS performs AAA for the host through the RADIUS server. A server installed with H3C IMC acts as the RADIUS server, the portal authentication server, and the portal Web server. This example uses IMC PLAT 7.1(E0303), IMC UAM 7.1(E0305), and IMC EIP 7.1(E0305). The FTP server is an internal network server. Limit the access rate to 5 Mbps for the user after passing Web authentication.
Allow a user to come online in the IPv6 protocol stack only when the user has passed Web authentication and come online in the IPv4 protocol stack. Additionally, an IPv6 address is assigned according to the attributes authorized to the IPv4 protocol stack.
Figure 144 Network diagram
1.     ‍Configure the DNS server.
Configure the DNS server properly, so that the server can parse the IPv4 URL or IPv6 URL corresponding to the Web authentication page http://www.ipv4.web.com or http://www.ipv6.web.com according to the first protocol stack that comes online of the dual-stack IPoE user. (Details not shown.)
2.     Configure the DHCP servers:
# Enable DHCP.
[DHCP-server] dhcp enable
# Enable the DHCP server to return a DHCP-NAK message if the client notions of their IP addresses are incorrect.
[DHCP-server] dhcp server request-ip-address check
[DHCP-server] ip pool pool1
# Specify primary subnet 192.168.0.0/24 for dynamic allocation and DNS server 8.8.8 in address pool pool1.
[DHCP-server-ip-pool-pool1] dns-list 8.8.8.8
[DHCP-server-ip-pool-pool1] quit
[DHCP-server] ip route-static 0.0.0.0 0 4.4.4.2
3.     Configure the BRAS:
# Enable DHCP.
[Device] dhcp enable
[Device] ip pool pool1 bas remote
[Device-ip-pool-pool1] remote-server 4.4.4.3
[Device-ip-pool-pool1] quit
[Device–Ten-GigabitEthernet0/0/16] ipv6 address auto link-local
[Device–Ten-GigabitEthernet0/0/16] undo ipv6 nd ra halt
[Device] portal server newpt2
[Device-portal-server-newpt2] ipv6 4::5 key simple 123456
[Device-portal-server-newpt2] quit
[Device] http-redirect https-port 11111
e.     Create a local user group named pre.
f.     Configure ACLs for preauthentication:
# Create an IPv4 and IPv6 advanced ACL named web_permit separately. Configure a rule to permit all packets destined for the portal server from users in user group pre.
[Device] acl advanced name web_permit
[Device-acl-ipv4-adv-web_permit] rule 0 permit ip destination 4.4.4.5 0 user-group pre
[Device-acl-ipv4-adv-web_permit] quit
[Device] acl ipv6 advanced name web_permit
[Device-acl-ipv6-adv-web_permit] rule 0 permit ipv6 destination 4::5 128 user-group pre
[Device-acl-ipv6-adv-web_permit] quit
# Create an IPv4 and IPv6 advanced ACL named neiwang separately. Configure a rule to permit all packets destined for the internal network server from users in user group pre.
[Device] acl advanced name neiwang
[Device-acl-ipv4-adv-neiwang] rule 0 permit ip destination 4.4.4.1 0 user-group pre
[Device-acl-ipv4-adv-neiwang] quit
[Device] acl ipv6 advanced name neiwang
[Device-acl-ipv6-adv-neiwang] rule 0 permit ipv6 destination 4::1 128 user-group pre
[Device-acl-ipv6-adv-neiwang] quit
[Device] acl advanced name web_http
[Device-acl-ipv4-adv-web_http] rule 0 permit tcp destination-port eq www user-group pre
[Device-acl-ipv4-adv-web_http] quit
[Device] acl advanced name web_https
[Device-acl-ipv4-adv-web_https] rule 0 permit tcp destination-port eq 443 user-group pre
[Device-acl-ipv4-adv-web_https] quit
[Device] acl advanced name ip
[Device-acl-ipv4-adv-ip] rule 0 permit ip user-group pre
[Device-acl-ipv4-adv-ip] quit
# Create an IPv4 and IPv6 advanced ACL named neiwang_out separately, and configure a rule to permit IP packets from the internal network server in user group pre.
[Device] acl advanced name neiwang_out
[Device-acl-ipv4-adv-neiwang_out] rule 0 permit ip source 4.4.4.1 0 user-group pre
[Device-acl-ipv4-adv-neiwang_out] quit
[Device] acl ipv6 advanced name neiwang_out
[Device-acl-ipv6-adv-neiwang_out] rule 0 permit ipv6 source 4::1 128 user-group pre
[Device-acl-ipv6-adv-neiwang_out] quit
# Create an IPv4 and IPv6 advanced ACL named web_out separately, and configure a rule to permit IP packets from the portal server in user group pre.
[Device] acl advanced name web_out
[Device-acl-ipv4-adv-web_out] rule 0 permit ip source 4.4.4.5 0 user-group pre
[Device-acl-ipv4-adv-web_out] quit
[Device] acl ipv6 advanced name web_out
[Device-acl-ipv6-adv-web_out] rule 0 permit ipv6 source 4::5 128 user-group pre
[Device-acl-ipv6-adv-web_out] quit
g.     Configure QoS traffic classes for preauthentication users:
[Device] traffic classifier web_permit operator or
[Device-classifier-web_permit] if-match acl name web_permit
[Device-classifier-web_permit] if-match acl ipv6 name web_permit
[Device-classifier-web_permit] quit
[Device] traffic classifier neiwang operator or
[Device-classifier-neiwang] if-match acl name neiwang
[Device-classifier-neiwang] if-match acl ipv6 name neiwang
[Device-classifier-neiwang] quit
[Device-classifier-web_http] if-match acl name web_http
[Device-classifier-web_http] quit
[Device-classifier-web_https] if-match acl name web_https
[Device-classifier-web_https] quit
[Device] traffic classifier neiwang_out operator or
[Device-classifier-neiwang_out] if-match acl name neiwang_out
[Device-classifier-neiwang_out] if-match acl ipv6 name neiwang_out
[Device-classifier-neiwang_out] quit
[Device] traffic classifier web_out operator or
[Device-classifier-web_out] if-match acl name web_out
[Device-classifier-web_out] if-match acl ipv6 name web_out
[Device-classifier-web_out] quit
h.     Configure QoS traffic behaviors:
[Device] traffic behavior web_permit
[Device-behavior-web_permit] filter permit
[Device-behavior-web_permit] free account
[Device-behavior-web_permit] quit
[Device] traffic behavior neiwang
[Device-behavior-neiwang] filter permit
[Device-behavior-neiwang] quit
[Device] traffic behavior web_http
[Device-behavior-web_http] redirect http-to-cpu
[Device-behavior-web_http] quit
[Device] traffic behavior web_https
[Device-behavior-web_https] redirect https-to-cpu
[Device-behavior-web_https] quit
[Device] traffic behavior web_deny
[Device-behavior-web_deny] filter deny
[Device-behavior-web_deny] free account
[Device-behavior-web_deny] quit
[Device] traffic behavior neiwang_out
[Device-behavior-neiwang_out] filter permit
[Device-behavior-neiwang_out] quit
[Device] traffic behavior web_out
[Device-behavior-web_out] filter permit
[Device-behavior-web_out] free account
[Device-behavior-web_out] quit
i.     Configure the QoS policies:
[Device] qos policy web
[Device-qospolicy-web] classifier web_permit behavior web_permit
[Device-qospolicy-web] classifier neiwang behavior neiwang
[Device-qospolicy-web] classifier web_http behavior web_http
[Device-qospolicy-web] classifier web_https behavior web_https
# Associate the traffic class web_deny with the traffic behavior web_deny.
[Device-qospolicy-web] quit
[Device] qos policy out
# Associate the traffic class web_out with the traffic behavior web_out. Associate the traffic class neiwang_out with the traffic behavior neiwang_out. Associate the traffic class web_deny with the traffic behavior web_deny.
[Device-qospolicy-out] classifier web_out behavior web_out
[Device-qospolicy-out] classifier neiwang_out behavior neiwang_out
[Device-qospolicy-out] quit
j.     Apply the QoS policies:
[Device] qos apply policy web global inbound
[Device] qos apply policy out global outbound
k.     Configure a RADIUS scheme:
[Device] radius scheme rs1
[Device-radius-rs1] key authentication simple radius
[Device-radius-rs1] key accounting simple radius
[Device-radius-rs1] quit
[Device] radius session-control enable
l.     Configure the preauthentication ISP domain and Web authentication ISP domain:
[Device] domain name dm1
[Device-isp-dm1] authentication ipoe none
[Device-isp-dm1] authorization ipoe none
[Device-isp-dm1] accounting ipoe none
# Configure the authorized user group and IPv4 address pools in preauthentication ISP domain dm1.
[Device-isp-dm1] authorization-attribute user-group web
[Device-isp-dm1] authorization-attribute ip-pool pool1
[Device-isp-dm1] quit
[Device] domain name dm2
[Device-isp-dm2] authentication ipoe radius-scheme rs1
[Device-isp-dm2] authorization ipoe radius-scheme rs1
[Device-isp-dm2] accounting ipoe radius-scheme rs1
# Configure the ISP domain dm2 to authorize a CAR policy and an IPv6 address pool in the Web authentication phase.
[Device-isp-dm2] authorization-attribute ipv6-pool pool2
[Device-isp-dm2] quit
m.     Configure IPoE:
# Configure Web authentication for IPoE users on Ten-GigabitEthernet 0/0/16, and specify the IPv6 protocol stack to come online depending on the IPv4 protocol stack.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber authentication-method web basic-service-ipv4
4.     Configure the RADIUS server:
Figure 145 Adding an access device
-     Click OK.
Figure 146 Manually adding an access device
Figure 147 Adding an access policy
Figure 148 Adding an access service
d.     Add a user:
-     Click OK.
Figure 149 Adding a user
Figure 150 Adding an access user
5.     Configure the portal server:
-     Click OK.
Figure 151 Portal server configuration page
-     Click OK.
Figure 152 Adding an IP address group (IPv4)
-     Click OK.
Figure 153 Adding an IP address group (IPv6)
-     Click OK.
Figure 154 Adding a portal device (IPv4)
-     Click OK.
Figure 155 Adding a portal device (IPv6)
-     Click OK.
Figure 156 Device list
Figure 157 Port group configuration (IPv4)
-     Click OK.
Figure 158 Port group configuration (IPv6)
# Display IPoE session information to verify that the host has passed preauthentication and obtained IPv4 address 192.168.0.2 and no IPv6 address.
[Device] display access-user auth-type pre-auth
            IPv6 address
            0015e947f4d4         L2 IPoE dynamic(D/-)
Figure 159 Web login page
# Display IPoE session information to verify that the host has passed Web authentication and come online in the IPv4 protocol stack.
            IPv6 address
            user1@dm2            Web auth(D/-)
# When the device receives DHCPv6 packets, display IPoE session information to verify that the host has come online in the IPv6 protocol stack.
 [Device] display access-user auth-type web-auth
            IPv6 address
            192::2
# Click Log Out. The user returns from the Web authentication phase to the preauthentication phase. Display IPoE session information to verify that the host has been logged out in the IPv6 protocol stack.
            IPv6 address
Example: Configuring IPoE common transparent MAC authentication for dual-stack IPoE users
As shown in Figure 160, the host accesses the BRAS as a DHCP client though a Layer 2 device. It obtains configuration information from the DHCP server through the BRAS. The BRAS performs AAA for the host through the RADIUS server. A server installed with H3C IMC acts as the portal authentication server and the portal Web server. This example uses IMC PLAT 7.1(E0303), IMC UAM 7.1(E0305), and IMC EIP 7.1(E0305). A RADIUS server that supports MAC binding acts as the authentication, authorization, and accounting server and performs MAC binding. The FTP server is an internal network server. Limit the access rate to 5 Mbps for the user after passing Web authentication.
Figure 160 Network diagram
# Enable DHCP.
# Create an IP address pool named pool1 and enter its view.
# Enable DHCP.
# Specify the gateway address in address pool pool1.
[Device-acl-ipv4-adv-neiwang] rule 0 permit ip destination 4.4.4.6 0 user-group pre
[Device-acl-ipv6-adv-neiwang] rule 0 permit ipv6 destination 4::6 128 user-group pre
[Device-acl-ipv4-adv-neiwang_out] rule 0 permit ip source 4.4.4.6 0 user-group pre
[Device-acl-ipv6-adv-neiwang_out] rule 0 permit ipv6 source 4::6 128 user-group pre
# Create the traffic class ip_cpu and specify ACL ip as the match criterion.
[Device] traffic classifier ip_cpu operator or
[Device-classifier-ip_cpu] if-match acl name ip
[Device-classifier-ip_cpu] if-match acl ipv6 name ip
[Device-classifier-ip_cpu] quit
# Create the traffic class ip_deny and specify ACL ip as the match criterion.
[Device] traffic classifier ip_deny operator or
[Device-classifier-ip_deny] if-match acl name ip
[Device-classifier-ip_deny] if-match acl ipv6 name ip
[Device-classifier-ip_deny] quit
# Configure the traffic behavior web_cpu to redirect IP packets to the CPU.
[Device] traffic behavior web_cpu
[Device-behavior-web_cpu] redirect cpu
[Device-behavior-web_cpu] quit
# Associate the traffic class ip_cpu with the traffic behavior web_cpu.
[Device-qospolicy-web] classifier ip_cpu behavior web_cpu
# Associate the traffic class ip_deny with the traffic behavior web_deny.
[Device-qospolicy-web] classifier ip_deny behavior web_deny
[Device-qospolicy-out] classifier ip_deny behavior web_deny
[Device-radius-rs1] primary authentication 4.4.4.1
[Device-radius-rs1] primary accounting 4.4.4.1
# Set the IP address of the RADIUS DAE client to 4.4.4.1, and set the shared key to radius for the RADIUS DAE client to exchange DAE packets.
[Device-radius-da-server] client ip 4.4.4.1 key simple radius
[Device-isp-dm1] authorization-attribute user-group pre
m.     Configure IPoE:
# Configure Web MAC authentication for IPoE users on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber authentication-method web mac-auth
# Configure the ISP domain dm1 for preauthentication and the ISP domain dm2 for Web authentication and Web MAC authentication on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber mac-auth domain dm2
3.     Configure the RADIUS server.
For how to configure AAA and MAC binding on the RADIUS server, see the RADIUS server configuration guide.
-     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page, as shown in Figure 161.
-     Click OK.
Figure 161 Portal server configuration page
-     Click Add to open the page as shown in Figure 162.
-     Click OK.
Figure 162 Adding an IP address group (IPv4)
-     Click Add to open the page as shown in Figure 163.
-     Click OK.
Figure 163 Adding an IP address group (IPv6)
c.     Add a portal device:
-     Click Add to open the page as shown in Figure 164.
-     Click OK.
Figure 164 Adding a portal device (IPv4)
-     Click Add to open the page as shown in Figure 165.
-     Enter the IP address of the portal packets' outgoing interface Ten-GigabitEthernet 0/0/15 (4::2).
-     Click OK.
Figure 165 Adding a portal device (IPv6)
-     Click the icon in the Port Group Information Management column of device NAS to open the port group configuration page, as shown in Figure 166.
-     Click Add to open the page as shown in Figure 167.
-     Click OK.
Figure 166 Device list
Figure 167 Port group configuration (IPv4)
-     Click the icon in the Port Group Information Management column of device NAS-2 to open the port group configuration page, as shown in Figure 166.
-     Click Add to open the page as shown in Figure 168.
-     Click OK.
Figure 168 Port group configuration (IPv6)
e.     From the navigation tree, select User Access Manager > Service Parameters > Validate System Configuration to validate the settings.
            IPv6 address
            192::2
As shown in Figure 169, the Web login page opens after preauthentication. Enter the username and password on the page.
Figure 169 Web login page
            IPv6 address
            192::2
# Click Log Out on the Web login page as shown in Figure 169.
# Verify that the user returns to the preauthentication status.
            IPv6 address
            192::2
# Open the browser, and enter an address randomly, for example, http://63.1.1.240.
# Verify that the user has come online through IPoE Web MAC authentication.
            IPv6 address
            0015e947f4d4         Web auth(D/D)
            192::2
Example: Configuring a dual-stack DHCP user
As shown in Figure 170, the host accesses the BRAS as a dual-stack IPoE user. The host obtains IPv4 and IPv6 addresses from the DHCP server. The BRAS performs AAA for the host through the RADIUS server. This example uses the Linux Free RADIUS server.
Figure 170 Network diagram
# Add BRAS IP address 4.4.4.2 and secret radius to the clients.conf file.
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Add the username and password to the users user information file. The username is the host MAC address and the password is radius.
000c29a6b656  Cleartext-Password :="radius"
# Enable DHCP.
# Specify the subnet 3.3.3.0/24 for dynamic allocation and DNS server 8.8.8.8 in the pool.
[DHCP-server-ip-pool-pool1] network 3.3.3.0 24
# Specify gateway address 3.3.3.1 in the address pool.
[DHCP-server-ip-pool-pool1] gateway-list 3.3.3.1
# Exclude IP address 3.3.3.1 from dynamic allocation in the pool.
[DHCP-server-ip-pool-pool1] forbidden-ip 3.3.3.1
# Specify the subnet 3::/64 for dynamic allocation and DNS server 8::8 in the pool.
[DHCP-server-ipv6-pool-pool2] network 3::/64
# Exclude IPv6 address 3::1 from dynamic allocation in the pool.
[DHCP-server] ipv6 dhcp server forbidden-address 3::1
# Enable DHCP.
# Create a remote BAS IP address pool pool1, specify a gateway address in the address pool, exclude IP address 3.3.3.1 from dynamic allocation in the address pool, and specify a DHCP server for the address pool.
[Device-ip-pool-pool1] gateway 3.3.3.1 24
[Device-ip-pool-pool1] forbidden-ip 3.3.3.1
# Create a remote IPv6 address pool pool2, specify a gateway address in the address pool, specify IPv6 subnet 3::/64 in the address pool, and specify a DHCPv6 server for the address pool.
[Device-ipv6-pool-pool2] gateway-list 3::1
[Device-ipv6-pool-pool2] network 3::/64 export-route
# Enable the DHCPv4 relay agent and DHCPv6 relay agent on Ten-GigabitEthernet 0/0/16.
b.     Configure a RADIUS scheme:
c.     Configure the ISP domain:
# Create an ISP domain named dm1 and enter its view.
# Configure ISP domain dm1 to use RADIUS scheme rs1 and assign address pools.
[Device-isp-dm1] authentication ipoe radius-scheme rs1
[Device-isp-dm1] authorization ipoe radius-scheme rs1
[Device-isp-dm1] accounting ipoe radius-scheme rs1
d.     Configure IPoE:
# Specify dm1 as the ISP domain for DHCP users.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber dhcp domain dm1
# Configure plaintext password radius for authentication.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber password plaintext radius
# Display IPoE session information to verify that the host has come online.
            IPv6 address
0x2c2       XGE0/0/16            3.3.3.2                 000c-29a6-b656  -/-
            000c29a6b656         L2 IPoE dynamic(D/D)
            3::2
Example: Configuring a dynamic/static dual-stack IPoE user
As shown in Figure 171, the host accesses the BRAS as a dual-stack IPoE user. The host comes online as an IPv4 global static individual user and comes online as an IPv6 dynamic DHCP user. The IPv4 address of the host is 3.3.3.2. The host obtains IPv6 addresses from the DHCP server without carrying Option 60 in DHCP packets. The BRAS performs AAA for the host through the RADIUS server. This example uses the Linux Free RADIUS server.
Figure 171 Network diagram
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
a.     Configure an IPv6 address pool:
# Create an IPv6 address pool named pool1 and enter its view.
[DHCP-server] ipv6 pool pool1
# Specify the subnet 3::/64 for dynamic allocation and DNS sever 8::8 in the pool.
[DHCP-server-ipv6-pool-pool1] network 3::/64
[DHCP-server-ipv6-pool-pool1] dns-server 8::8
[DHCP-server-ipv6-pool-pool1] quit
# Create a remote IPv6 address pool pool1, specify a gateway address in the address pool, specify IPv6 subnet 3::/64 in the address pool, and specify a DHCPv6 server for the address pool.
[Device] ipv6 pool pool1
[Device-ipv6-pool-pool1] gateway-list 3::1
[Device-ipv6-pool-pool1] network 3::/64 export-route
[Device-ipv6-pool-pool1] remote-server 4::3
[Device-ipv6-pool-pool1] quit
[Device-isp-dm1] authorization-attribute ipv6-pool pool1
d.     Configure the DHCP server:
# Enable DHCP.
[Device] dhcp server request-ip-address check
# Create a local BAS IP address pool named pool1 and enter its view.
[Device] ip pool pool1 bas local
# Specify gateway address 3.3.3.1 in address pool pool1.
# Exclude IP address 3.3.3.2 from dynamic allocation in address pool pool1.
[Device-ip-pool-pool1] forbidden-ip 3.3.3.2
e.     Configure IPoE:
# Configure a global IPv4 IPoE static individual session with the ISP domain dm1 and enable dual stack support.
[Device] ip subscriber session static ip 3.3.3.2 domain dm1 support-ds
# Enable ARP packet initiation on Ten-GigabitEthernet 0/0/16.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber initiator arp enable
# Use the MAC addresses of the global static individual user and the dynamic user as their respective usernames.
[Device–Ten-GigabitEthernet0/0/16] ip subscriber username mac-address
            IPv6 address
            000c29a6b656         L2 IPoE dynamic(S/D)
            3::2
Example: Configuring an IPoE DHCPv4+IPv6 ND RS dual-stack roaming user
As shown in Figure 172, configure dual-stack IPoE users as follows:
·     In the IPv4 protocol stack:
¡     A host comes online through DHCP packets and accesses the BRAS through a Layer 2 network in IPoE mode.
¡     A host obtains an IP address from the DHCP server.
·     In the IPv6 protocol stack:
¡     A host comes online through IPv6 ND RS packets and accesses the BRAS through a Layer 2 network in IPoE mode.
¡     The BRAS can send IPv6 ND RA packets.
The host can roam between areas and still stay online. The BRAS performs AAA for the host through the RADIUS server. This example uses the Linux Free RADIUS server.
Figure 172 Network diagram
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
# Add the username and password to the users user information file. The username is the host MAC address, the password is radius, and the authorized IPv6 prefix is 10::/64.
Framed-IPv6-Prefix =10::/64
# Enable DHCP.
# Specify the subnet 3.3.3.0/24 for dynamic allocation in the pool.
# Configure the DNS server address as 8.8.8.8.
a.     Configure a RADIUS scheme:
b.     Configure the ISP domain:
# Configure dm1 to use RADIUS scheme rs1 and assign a remote BAS IP address pool.
# Authorize an IPv6 DNS address pool to users.
[Device-isp-dm1] authorization-attribute primary-dns ipv6 8::8
c.     Configure the DHCP relay agent:
# Enable DHCP.
# Enable the DHCP server proxy on the relay agent on Ten-GigabitEthernet 0/0/15 and Ten-GigabitEthernet 0/0/16. (You can skip this step because this configuration exists by default.)
[Device] interface range ten-gigabitethernet 0/0/15 ten-gigabitethernet 0/0/16
[Device–if-range] dhcp-proxy enable
[Device–if-range] quit
# Assign addresses to roaming clients based on their existing address leases and renew the leases when the clients roam.
[Device–if-range] dhcp session-mismatch action roam
# Disable RA message suppression.
[Device–if-range] undo ipv6 nd ra halt
# Automatically generate link-local addresses.
[Device–if-range] ipv6 address auto link-local
d.     Configure IPoE:
# Enable IPoE and configure Layer 2 access mode on Ten-GigabitEthernet 0/0/15 and Ten-GigabitEthernet 0/0/16.
[Device–if-range] ip subscriber l2-connected enable
# Enable IPv6 ND RS packet initiation.
[Device–if-range] ip subscriber initiator ndrs enable
# Enable ARP packet initiation.
[Device–if-range] ip subscriber initiator arp enable
# Enable NS/NA packet initiation.
[Device–if-range] ip subscriber initiator nsna enable
# Enable unclassified-IPv4 packet initiation and unclassified-IPv6 packet initiation.
[Device–if-range] ip subscriber initiator unclassified-ip enable matching-user
[Device–if-range] ip subscriber initiator unclassified-ipv6 enable matching-user
# Enabling roaming for IPoE individual users.
[Device–if-range] ip subscriber roaming enable
[Device–if-range] ip subscriber dhcp domain dm1
# Specify dm1 as the ISP domain for IPv6 ND RS users.
[Device–if-range] ip subscriber password plaintext radius
# Display IPoE session information to verify that the host in area A has come online.
[Device] display access-user interface ten-gigabitethernet 0/0/15
            IPv6 address
0x5c        XGE0/0/15            3.3.3.2                 000c-29a6-b656  -/-
            000c29a6b656         L2 IPoE dynamic(D/N)
            10::20C:29FF:FEA6:B656
# Display IPoE session information to verify that the user has roamed from area A to area B.
            IPv6 address
0x5c        XGE0/0/16            3.3.3.2                 000c-29a6-b656  -/-
Configuring portal authentication
Restrictions and guidelines: Portal configuration
The device does not support users' access to the network through portal authentication. The portal features can only be used in IPoE Web authentication scenarios.
Portal authentication tasks at a glance
To configure portal authentication, perform the following tasks:
1.     Configuring a remote portal service
Perform this task if a remote portal server is used.
¡     Configuring a remote portal authentication server
2.     Configuring a local portal service
Perform this task if the access device acts as a portal authentication server and portal Web server.
¡     Configuring local portal service features
3.     (Optional.) Configuring portal detection features
¡     Configuring portal authentication server detection
¡     Configuring portal user synchronization
4.     (Optional.) Configuring attributes for portal packets and RADIUS packets
¡     Configuring portal packet attributes
This task includes configuring the BAS-IP or BAS-IPv6 attribute for portal notifications packets.
You must configure the BAS-IP or BAS-IPv6 attribute if the device IP address specified on the portal authentication server is not the IP address of the output interface for portal notification packets.
¡     Excluding an attribute from portal protocol packets
5.     (Optional.) Configuring MAC-based quick portal authentication
a.     Configuring a MAC binding server
b.     Specifying a MAC binding server on an interface
6.     Obtaining user access information from ARP or ND entries
On an IPoE Web authentication network, this task is required when DHCP access users and the portal authentication server belong to different VPNs.
 device searches for a portal authentication server for a received portal request packet according to the source IP address and VPN information of the packet.
·     If a matching portal authentication server is found, the device regards the packet valid and sends an authentication response packet to the portal authentication server. After a user logs in to the device, the user interacts with the portal authentication server as needed.
·     If no matching portal authentication server is found, the device drops the packet.
Do not delete a portal authentication server in use. Otherwise, users authenticated by that server cannot log out correctly.
2.     Create a portal authentication server and enter its view.
portal server server-name
You can create multiple portal authentication servers.
3.     Specify the IP address of the portal authentication server.
IPv4:
ip ipv4-address [ vpn-instance vpn-instance-name ] [ key { cipher | simple } string ]
IPv6:
ipv6 ipv6-address [ vpn-instance vpn-instance-name ] [ key { cipher | simple } string ]
By default, no portal authentication server is specified.
4.     (Optional.) Set the destination UDP port number used by the device to send unsolicited portal packets to the portal authentication server.
port port-number
By default, the UDP port number is 50100.
This port number must be the same as the listening port number specified on the portal authentication server.
In a portal proxy network, make sure this port number is the same as the listening port number specified on the portal proxy.
5.     (Optional.) Specify the portal authentication server type.
server-type { cmcc | imc }
By default, the portal authentication server type is IMC.
The specified server type must be the same as the type of the portal authentication server actually used.
6.     (Optional.) Set the maximum number of times and the interval for retransmitting a logout notification packet.
logout-notify retry retries interval interval
By default, the device does not retransmit a logout notification packet.
7.     (Optional.) Configure the device to periodically register with the portal authentication server.
server-register [ interval interval-value ]
By default, the device does not register with a portal authentication server.
About the local portal service
After a local portal service is configured, the device acts as the portal Web server and portal authentication server to perform portal authentication on users. The portal authentication page file is saved in the root directory of the device.
Restrictions and guidelines for configuring local portal service features
For an interface to use the local portal service, the URL of the portal Web server specified for the interface must meet the following requirements:
·     The IP address in the URL must be the IP address of a Layer 3 interface (except 127.0.0.1) on the device, and the IP address must be reachable to portal clients.
·     The URL must be ended with /portal/. For example: https://1.1.1.1/portal/.
You must customize the authentication pages and upload them to the device.
Customizing authentication pages
Authentication pages are HTML files. Local portal authentication requires the following authentication pages:
·     Logon page
·     Logon success page
·     Logon failure page
·     Online page
·     System busy page
·     Logoff success page
You must customize the authentication pages, including the page elements that the authentication pages will use, for example, back.jpg for authentication page Logon.htm.
Follow the authentication page customization rules when you edit the authentication page files.
File name rules
The names of the main authentication page files are fixed (see Table 2). You can define the names of the files other than the main authentication page files. File names and directory names are case insensitive.
Table 2 Main authentication page file names
File name
Logon page
logon.htm
Logon success page
logonSuccess.htm
Logon failure page
logonFail.htm
Online page
Pushed after the user gets online for online notification
online.htm
System busy page
Pushed when the system is busy or the user is in the logon process
busy.htm
Logoff success page
logoffSuccess.htm
Page request rules
The local portal Web service supports only Get and Post requests.
·     Get requests—Used to get the static files in the authentication pages and allow no recursion. For example, if file Logon.htm includes contents that perform Get action on file ca.htm, file ca.htm cannot include any reference to file Logon.htm.
·     Post requests—Used when users submit username and password pairs, log in, and log out.
Post request attribute rules
1.     Observe the following requirements when editing a form of an authentication page:
¡     An authentication page can have multiple forms, but there must be one and only one form whose action is logon.cgi. Otherwise, user information cannot be sent to the access device.
¡     The username attribute is fixed as PtUser. The password attribute is fixed as PtPwd.
¡     The value of the PtButton attribute is either Logon or Logoff, which indicates the action that the user requests.
¡     A logon Post request must contain PtUser, PtPwd, and PtButton attributes.
¡     A logoff Post request must contain the PtButton attribute.
2.     Authentication pages logon.htm and logonFail.htm must contain the logon Post request.
The following example shows part of the script in page logon.htm.
<form action=logon.cgi method = post >
<p>User name:<input type="text" name = "PtUser" style="width:160px;height:22px" maxlength=64>
<p>Password :<input type="password" name = "PtPwd" style="width:160px;height:22px" maxlength=32>
<p><input type=SUBMIT value="Logon" name = "PtButton" style="width:60px;" onclick="form.action=form.action+location.search;">
</form>
3.     Authentication pages logonSuccess.htm and online.htm must contain the logoff Post request.
The following example shows part of the script in page online.htm.
<p><input type=SUBMIT value="Logoff" name="PtButton" style="width:60px;">
</form>
Page file compression and saving rules
You must compress the authentication pages and their page elements into a standard zip file.
·     The name of a zip file can contain only letters, numbers, and underscores.
·     The authentication pages must be placed in the root directory of the zip file.
·     Zip files can be transferred to the device through FTP or TFTP and must be saved in the root directory of the device.
Examples of zip files on the device:
<Sysname> dir
Directory of flash:
   1     -rw-      1405  Feb 28 2008 15:53:20   ssid1.zip
   0     -rw-      1405  Feb 28 2008 15:53:31   ssid2.zip
   2     -rw-      1405  Feb 28 2008 15:53:39   ssid3.zip
   3     -rw-      1405  Feb 28 2008 15:53:44   ssid4.zip
2540 KB total (1319 KB free)
Redirecting authenticated users to a specific webpage
To make the device automatically redirect authenticated users to a specific webpage, do the following in logon.htm and logonSuccess.htm:
1.     In logon.htm, set the target attribute of Form to _blank.
See the contents in gray:
    <form method=post action=logon.cgi target="_blank">
2.     Add the function for page loading pt_init() to logonSuccess.htm.
    <html>
    <head>
    <title>LogonSuccess</title>
    <script type="text/javascript" language="javascript" src="pt_private.js"></script>
    </head>
    <body onload="pt_init();" onbeforeunload="return pt_unload();">
    </body>
</html>
Configuring a local portal Web service
Before you configure an HTTPS-based local portal Web service, you must complete the following tasks:
·     Configure a PKI policy, obtain the CA certificate, and request a local certificate. For more information, see "Configuring PKI."
·     Configure an SSL server policy, and specify the PKI domain configured in the PKI policy.
During SSL connection establishment, the user browser might display a message that it cannot verify server identity by certificate. For users to perform portal authentication without checking such a message, configure an SSL server policy to request a client-trusted certificate on the device. The name of the policy must be https_redirect. For more information about SSL server policy configuration, see "Configuring SSL."
2.     Create an HTTP- or HTTPS-based local portal Web service and enter its view.
portal local-web-server { http | https ssl-server-policy policy-name [ tcp-port port-number ] }
3.     Specify the default authentication page file for the local portal Web service.
default-logon-page filename
By default, no default authentication page file is specified for the local portal Web service.
To provide local portal Web service for users, you must use this command to specify a customized authentication page file as the default authentication page file.
4.     (Optional.) Configure the listening TCP port for the local portal Web service.
By default, the HTTP service listening port number is 80 and the HTTPS service listening port number is the TCP port number set by the portal local-web-server command..
5.     (Optional.) Bind the endpoint name to an authentication page file.
logon-page bind device-name device-name file file-name
By default, no endpoint name is bound to an authentication page file.
During portal authentication, if the communication between the access device and portal authentication server is broken, new portal users are not able to log in. Online portal users are not able to log out normally.
To address this problem, the access device needs to be able to detect the reachability changes of the portal server quickly and take corresponding actions to deal with the changes.
The portal authentication server detection feature enables the device to periodically detect portal packets sent by a portal authentication server to determine the reachability of the server. If the device receives a portal packet within a detection timeout (timeout timeout) and the portal packet is valid, the device considers the portal authentication server to be reachable. Otherwise, the device considers the portal authentication server to be unreachable.
Portal packets include user login packets, user logout packets, and heartbeat packets. Heartbeat packets are periodically sent by a server. By detecting heartbeat packets, the device can detect the server's actual status more quickly than by detecting other portal packets.
Only the IMC portal authentication server supports sending heartbeat packets. To test server reachability by detecting heartbeat packets, you must enable the server heartbeat feature on the IMC portal authentication server.
You can configure the device to take one or two of the following actions when the server reachability status changes:
·     Sending a trap message to the NMS. The trap message contains the name and current state of the portal authentication server.
·     Sending a log message, which contains the name, the current state, and the original state of the portal authentication server.
Make sure the detection timeout configured on the device is greater than the server heartbeat interval configured on the portal authentication server.
2.     Enter portal authentication server view.
3.     Configure portal authentication server detection.
server-detect [ timeout timeout ] { log | trap } *
By default, portal authentication server detection is disabled.
Once the access device loses communication with a portal authentication server, the portal user information on the access device and that on the portal authentication server might be inconsistent after the communication resumes. To address this problem, the device provides the portal user synchronization feature. This feature is implemented by sending and detecting portal synchronization packets, as follows:
1.     The portal authentication server sends the online user information to the access device in a synchronization packet at the user heartbeat interval.
The user heartbeat interval is set on the portal authentication server.
2.     Upon receiving the synchronization packet, the access device compares the users carried in the packet with its own user list and performs the following operations:
¡     If a user contained in the packet does not exist on the access device, the access device informs the portal authentication server to delete the user. The access device starts the synchronization detection timer (timeout timeout) immediately when a user logs in.
¡     If the user does not appear in any synchronization packet within a synchronization detection interval, the access device considers the user does not exist on the portal authentication server and logs the user out.
Portal user synchronization requires a portal authentication server to support the portal user heartbeat function. Only the IMC portal authentication server supports the portal user heartbeat function. To implement the portal user synchronization feature, you also need to configure the user heartbeat function on the portal authentication server. Make sure the user heartbeat interval configured on the portal authentication server is not greater than the synchronization detection timeout configured on the access device.
Deleting a portal authentication server on the access device also deletes the user synchronization configuration for the portal authentication server.
3.     Configure portal user synchronization.
user-sync timeout timeout
By default, portal user synchronization is disabled.
Configuring the BAS-IP or BAS-IPv6 attribute
To avoid portal user offline failure and re-DHCP portal authentication failure, the BAS-IP or BAS-IPv6 attribute must be the same as the device IP address on the portal authentication server. Perform this task to configure the BAS-IP or BAS-IPv6 attribute as the device IP address specified on the portal authentication server. The device uses the BAS-IP or BAS-IPv6 attribute value as the source IP address of portal notification packets sent to the portal authentication server.
This configuration takes effect only on unsolicited portal notification packets sent to the portal authentication server. For IPv4 portal reply packets, the BAS-IP attribute value is the source IPv4 address of the packets. For IPv6 portal reply packets, the BAS-IPv6 attribute value is the source IPv6 address of the packets.
The global BAS-IP or BAS-IPv6 configuration made in system view takes effect on all interfaces. For an interface, the interface-specific BAS-IP or BAS-IPv6 configuration takes precedence over the global configuration..
Configure the BAS-IP or BAS-IPv6 attribute globally
2.     Configure the BAS-IP or BAS-IPv6 attribute.
IPv4:
portal bas-ip ipv4-address
By default, the BAS-IP attribute value of an IPv4 portal notification packet is the IPv4 address of the packet's output interface.
IPv6:
portal bas-ipv6 ipv6-address
By default, the BAS-IPv6 attribute value of an IPv6 portal notification packet is the IPv6 address of the packet's output interface.
Configuring the BAS-IP or BAS-IPv6 attribute on an interface
2.     Enter Layer 3 interface view.
3.     Configure the BAS-IP or BAS-IPv6 attribute.
IPv4:
For an IPv4 portal reply packet, the default BAS-IP attribute value is the source IPv4 address of the packet. For an IPv4 portal notification packet, the default BAS-IP attribute value is the IPv4 address of the packet's output interface.
IPv6:
For an IPv6 portal reply packet, the default BAS-IPv6 attribute value is the source IPv6 address of the packet. For an IPv6 portal notification packet, the default BAS-IPv6 attribute value is the IPv6 address of the packet's output interface.
Support of the portal authentication server for portal protocol attributes varies by the server type. If the device sends the portal authentication server a packet that contains an attribute unsupported by the server, the device and the server cannot communicate.
To address this issue, you can configure portal protocol packets to not carry the attributes unsupported by the portal authentication server.
3.     Exclude an attribute from portal protocol packets.
exclude-attribute number [ ack-auth | ack-challenge | ack-info | ack-logout | ack-ntf-user-heartbeat | ntf-challenge | ntf-logout | ntf-useripchange | ntf-user-notify ]
By default, no attributes are excluded from portal protocol packets.
Restrictions and guidelines for configuring MAC-based quick portal authentication
Only IPv4 direct authentication supports MAC-based quick portal authentication.
In a network where a portal proxy is deployed, the access device and the MAC binding server communicate with each other through the portal proxy. On the access device, you must configure the portal proxy for the MAC binding server for MAC-based quick portal authentication to take effect.
You can configure multiple MAC binding servers on the device.
Perform this task to configure MAC binding server parameters, such as the server's IP address, port number, VPN instance, and the pre-shared key for communication between the access device and the server.
2.     Create a MAC binding server and enter its view.
portal mac-trigger-server server-name
By default, no MAC binder servers exist.
3.     Configure a MAC binding server.
¡     Specify the IP address of the MAC binding server.
By default, no IP address is specified for a MAC binding server.
¡     (Optional.) Set the UDP port number on which the MAC binding server listens for MAC binding query packets.
port port-number
By default, the MAC binding server listens for MAC binding query packets on UDP port 50100.
¡     (Optional.) Set the maximum number of attempts and the interval for sending MAC binding queries to the MAC binding server.
binding-retry { retries | interval interval } *
By default, the maximum number of query attempts is 3 and the query interval is 1 second.
¡     (Optional.) Specify the type of the MAC binding server.
By default, the type of a MAC binding server is IMC.
4.     (Optional.) Set the free-traffic threshold.
free-traffic threshold value
By default, the free-traffic threshold is 0 bytes.
5.     (Optional.) Set the NAS-Port-Type attribute value carried in RADIUS requests sent to the RADIUS server.
nas-port-type value
By default, the NAS-Port-Type attribute value carried in RADIUS requests is not set.
6.      (Optional.) Specify the version of the portal protocol.
version version-number
By default, the version of the portal protocol is 1.
7.     (Optional.) Set the timeout the device waits for portal authentication to complete after receiving the MAC binding query response.
authentication-timeout minutes
By default, the portal authentication timeout time is 3 minutes.
8.     (Optional.) Set the aging time for MAC-trigger entries.
aging-time seconds
By default, the aging time for MAC-trigger entries is 300 seconds.
After a MAC binding server is specified on an interface, the device can implement MAC-based quick portal authentication for portal users on the interface.
3.     Specify a MAC binding server on the interface.
portal apply mac-trigger-server server-name
By default, no MAC binding server is specified on an interface.
In an IPoE Web authentication network, when the device receives portal packets from the portal authentication server, it obtains user access information to complete authentication for users.
By default, the device obtains the user access information from FIB entries in the VPN instance of the portal authentication server. In the following situation, however, the device cannot get user access information from FIB and therefore users cannot pass Web authentication:
·     The DHCP access users and the portal authentication server belong to different VPN instances.
·     The user access interface is not bound to a VPN instance.
To resolve this issue, you can perform this task on the device. When this feature is enabled, the device first attempts to obtain user access information from ARP or ND entries during Web authentication. If the attempt fails, the device obtains user access information from UCM user entries.
As a best practice, configure this feature in all IPoE Web authentication scenarios.
To use this feature, make sure the VPN instances do not have overlapping IP addresses. Otherwise, this feature cannot ensure normal user logins.
2.     Configure the device to obtain user information from ARP or ND entries.
portal access-info trust { arp | nd }
By default, the device obtains user information from FIB entries.
Display and maintenance commands for portal
Display statistics for messages exchanged between portal and IPoE.
display portal ip-subscriber message statistics
Display MAC-trigger entries for portal users.
display portal mac-trigger entry [ ip ipv4-address ]
Display information about MAC binding servers.
display portal mac-trigger-server { all | name server-name }
Display statistics for messages exchanged between the device and MAC binding servers
display portal mac-trigger-server packet statistics
Display packet statistics for portal authentication servers.
display portal packet statistics [ server server-name ]
Display portal authentication server information.
display portal server [ server-name ]
Display session information for portal users or portal-based IPoE authentication users.
display portal session user-type { ipoe | portal }
Clear statistics for messages exchanged between portal and IPoE.
reset portal ip-subscriber message statistics
Clear statistics for messages exchanged between the device and MAC binding servers.
reset portal mac-trigger-server packet statistics
Clear packet statistics for portal authentication servers.
reset portal packet statistics [ server server-name ]
