03-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath M9000 Configuration Guide(V7)(R9X71)-6W70103-Security Configuration Guide
02-Security policy configuration
02-Security policy configuration 534.76 KB
Configuring security policies· 1
About security policies· 1
Benefits· 1
Security policy rules· 1
Security policy mechanism·· 1
Rule matching acceleration· 2
Security policy rule grouping· 2
vSystem support for features· 2
Application scenarios· 3
Local device access· 3
Remote device access· 3
Direct traffic forwarding· 4
Configuration principles· 5
Common local services· 5
Restrictions and guidelines: Security policy configuration· 5
Configuration procedure diagram·· 6
Prerequisites for security policies· 6
Security policy tasks at a glance· 7
Switching packet filtering to security policy settings· 8
Switching packet filtering to security policy settings before security policies are configured· 8
Switching packet filtering to security policy settings after security policies are configured· 8
Switching object policies to security policies· 9
About switching object policies to security policies· 9
Restrictions and guidelines for switching object policies to security policies· 9
Prerequisites for switching object policies to security policies· 9
Manually switching object policies to security policies· 9
Enabling the security policy feature· 9
Configuring IPv4 security policy rules· 10
Creating a security policy rule· 10
Configuring filtering criteria for a security policy rule· 11
Specifying the action for a security policy rule· 13
Specifying a time range for a security policy rule· 13
Applying a DPI application profile to a security policy rule· 14
Setting the session aging time for a security policy rule· 14
Associating a security policy rule with a track entry· 15
Enabling logging for matched packets· 15
Enabling statistics collection for matched packets· 16
Configuring IPv6 security policy rules· 16
Creating a security policy rule· 16
Configuring filtering criteria for a security policy rule· 17
Specifying the action for a security policy rule· 19
Specifying a time range for a security policy rule· 19
Applying a DPI application profile to a security policy rule· 19
Setting the session aging time for a security policy rule· 20
Associating a security policy rule with a track entry· 20
Enabling logging for matched packets· 21
Enabling statistics collection for matched packets· 21
Changing the rule match order 22
Activating rule matching acceleration· 22
Disabling a security policy rule· 23
Renaming a security policy rule· 23
Configuring security policy rule groups· 23
Creating a security policy rule group· 23
Specifying a security policy rule group for a security policy rule· 24
Moving a security policy rule group· 24
Renaming a security policy rule group· 25
Setting the time for fast output of security policy settings as logs· 25
Configuring logging for security policy configuration changes· 25
Display and maintenance commands for object policies· 25
Security policy configuration examples· 26
Example: Configuring an IPv4 security policy· 26
Example: Configuring domain name-based security policy· 28
Example: Configuring a security policy based on fuzzy domain name matching· 31
Example: Configuring location-based security policy· 33
Example: Configuring user-based security policy· 35
Example: Switching object policies to security policies· 35
Example: Configuring a security policy for OSPF communication· 39
A security policy defines a set of rules for forwarding control and Deep Packet Inspection (DPI). It matches packets against the rules and takes the action stated in the rules on the matched packets.
Benefits
Security policies can provide the same functions as packet filtering and object policies, and support precise network management based on application, protocol, and user. By working with DPI, it can also provide security protection services such as antivirus and intrusion protection.
For more information about packet filtering, see ACL and QoS Configuration Guide. For more information about object policies, see "Configuring object policies."
A security policy contains one or multiple rules. Each security policy rule is a permit or deny, or DPI statement for identifying traffic based on criteria.
Rule numbering
Each rule is uniquely identified by a name and an ID. When you create a rule, the rule name must be manually configured, and the rule ID can be manually configured or automatically assigned by the system.
Rule match criteria
The rule match criteria include the following types: source security zone, destination security zone, source IP address and source MAC address, destination IP address, user and user group, application and application group, terminal, terminal group, location and location group, URL category, VPN instance, and service.
You can specify multiple criteria for each type, except VPN instance. For example, you can configure multiple source security zones for a rule.
Rule and session management
When a security policy is configured, the device generates session entries for permitted packets to record packet information.
You can set session aging times for protocol states, application layer protocols, or rules. The aging time configured for a rule takes precedence over the aging time configured for a protocol state or an application layer protocol. For more information about session management, see "Managing sessions."
As shown in Figure 1, a security policy operates as follows:
1.     After receiving a packet, the device matches the packet against the configured security policy rules.
A security policy rule includes various match criterion types. A packet is considered matched if it matches all the criterion types in the rule. Each criterion type includes one or more criteria, and a packet matches a criterion type if it matches any criterion of the type. Source MAC address criteria and source IP address criteria belong to the same criterion type.
¡     If no match is found, the device discards the packet.
¡     If a match is found and the rule action is drop, the device discards the packet.
¡     If a match is found and the rule action is pass, the device goes to the next step.
2.     If a DPI application profile is configured for the matched rule, the device uses the specified profile to perform DPI on the packet. If no DPI application profile is specified, the device allows the packet to pass.
Figure 1 Security policy mechanism
This feature accelerates security policy rule matching to enhance connection establishment and packet forwarding performance, especially for a device using multiple rules to match packets from multiple users.
Security policy rule grouping allows users to enable, disable, delete, and move security policy rules in batches. A security policy rule in a security policy rule group takes effect only when both the rule and the group are enabled.
Non-default vSystems do not support the following features:
·     Disable the security policy feature.
·     Associate a security policy rule with a track entry.
·     Set the time for fast output of security policy settings as logs.
For information about the support of non-default vSystems for the commands, see security policy command reference. For information about vSystem, see Virtual Technologies Configuration Guide.
Local device access
In a local access scenario, you must configure security policy rules for the following operations to be performed successfully:
·     Local device access through a non-management local port, including ping, telnet, Web access, and FTP operations.
·     Protocol packet exchange triggered by any other devices (such as packet exchanges of Dynamic Routing Protocol or VPN tunneling).
For example, as shown in Figure 2, for a PC (10.1.1.10) in the Trust security zone to access the Web interface of the local device (10.1.1.1) through HTTPS, you must configure a security policy rule as described in Table 1.
Figure 2 Local device access
Table 1 Security policy rule configuration
Rule name
Source security zone
Destination security zone
Source IP address
Destination IP address
Service
Action
httpslocalin
Trust
Local
10.1.1.10
10.1.1.1
https
pass
For more information about permitting protocol packets, see "Common local services."
In a remote access scenario, you must configure security policy rules for the following operations to be performed successfully:
·     Remote device access through a non-management local port, including ping, telnet, Web access, and FTP operations.
·     Protocol packet exchange triggered by the local device (such as packet exchanges of Dynamic Routing Protocol or VPN tunneling).
For example, as shown in Figure 3, for the local device (10.1.1.1) to access the FTP service provided by the FTP server (10.1.1.20) in the Trust security zone, you must configure a security policy rule as described in Table 2.
Figure 3 Remote device access
Table 2 Configuration of local device accessing other devices
Rule name
Source IP address
Service
Action
ftplocalout
Local
Trust
10.1.1.1
10.1.1.20
ftp
pass
For the local device to forward traffic that is either sent from or destined to the local device, you must configure security policy rules to permit traffic from the corresponding security zones.
For example, as shown in Figure 4, for a PC (10.1.1.10) in the Trust zone to visit a website in the Untrust zone through HTTP, you must configure a security policy rule as shown in Table 3.
Figure 4 Direct traffic forwarding
Table 3 Direct traffic forwarding
Rule name
Source IP address
Service
Action
trust-untrust
Trust
Untrust
10.1.1.10
http
pass
As a best practice to achieve the optimal performance, follow these principles when you configure security policy rules:
·     Configure matching criteria as strict as possible.
·     Follow the depth-first order during rule creation to create rules with stricter match criteria first because the system matches packets against rules in the order the rules were created.
·     For packets from and to the same security zone, configure two rules to control packet exchanges between interfaces instead of using one rule that allows traffic between any interfaces in the zone to pass.
·     Place security policy rules using the Local security zone as a matching criteria in front of all the other rules to ensure that local service packets can be correctly processed.
You must configure security policy rules to permit local service traffic from or to specific security zones. Table 4 lists the common local services that require security policy permission. Support for the common local services varies by device.
Table 4 Common local services that require security policy permission
Service
Required security policy configuration
OSPF/IS-IS/RIP/BGP
Configure rules for the service traffic from or to the local zone.
IPsec/SSL/L2TP/MPLS/GRE
DNS/DHCP/FTP (client)
Configure rules only for the service traffic from the local zone.
DNS/DHCP/FTP (server)
Configure rules only for the service traffic to the local zone.
SSH/Telnet/Ping/Tracet (locally triggered)
SSH/Telnet/SNMP/HTTP/HTTPS (local access)
BFD
Configure rules only for the service traffic from or to the local zone.
LB
As a best practice, do not configure packet filtering, object policies, and security policies at the same time. If you do so, some policies might fail to take effect, causing service interruption.
Before configuring security policies, verify if the device is configured with packet filtering or object policies. As a best practice, switch packet filtering and object policies to security policies because security policies take precedence over packet filtering and object policies lose effect the first time you enter security policy view. For more information, see "Switching packet filtering to security policy settings" and "Switching object policies to security policies."
Figure 5 shows how to configure a security policy.
Figure 5 Security policy configuration procedure
Before you configure security policies, perform the following tasks:
·     Configure a time range. See time range configuration in ACL and QoS Configuration Guide.
·     Configure IP address object groups and service object groups. See "Configuring object groups."
·     Configure applications and application groups. See "Configuring APR."
·     Configure terminals and terminal groups. See "Identifying terminals."
·     Configure user and user groups. See "Configuring user identification."
·     Configure location and location groups. See "Configuring location identification."
·     Configure URL categories. See DPI Configuration Guide.
·     Configure security zones. See "Configuring security zones."
·     Configure DPI. See DPI Configuration Guide.
To configure object policies, perform the following tasks:
1.     (Optional.) Switching packet filtering to security policy settings
2.     (Optional.) Switching object policies to security policies
3.     Enabling the security policy feature
4.     Configuring IPv4 security policy rules
a.     Creating a security policy rule
b.     Configuring filtering criteria for a security policy rule
c.     Specifying the action for a security policy rule
d.     (Optional.) Specifying a time range for a security policy rule
e.     (Optional.) Applying a DPI application profile to a security policy rule
f.     (Optional.) Setting the session aging time for a security policy rule
g.     (Optional.) Associating a security policy rule with a track entry
h.     (Optional.) Enabling logging for matched packets
i.     (Optional.) Enabling statistics collection for matched packets
5.     Configuring IPv6 security policy rules
6.     (Optional.) Manage security policies
a.     Changing the rule match order
b.     Activating rule matching acceleration
c.     Disabling a security policy rule
d.     Renaming a security policy rule
7.     (Optional.) Configuring security policy rule groups
a.     Creating a security policy rule group
b.     Specifying a security policy rule group for a security policy rule
c.     Moving a security policy rule group
d.     Renaming a security policy rule group
8.     (Optional.) Setting the time for fast output of security policy settings as logs
9.     (Optional.) Configuring logging for security policy configuration changes
When security policies are configured, packet filtering is performed only on packets that do not match any security policy rule. As a best practice to avoid interruption of services permitted by packet filtering, do not configure packet filtering and security policies at the same time.
If packet filtering is configured, switch packet filtering to security policy settings as a best practice before enabling the security policy feature.
1.     Execute the security-policy disable command to disable the security policy feature.
2.     Enter security policy view, configure filtering criteria and actions for security policy rules based on the packet filtering configuration.
3.     Execute the undo security-policy disable command to enable the security policy feature.
4.     (Optional.) Delete the packet filtering configuration from the device.
You can perform this task from the Web interface (recommended) or CLI.
To perform this task from the CLI:
1.     Access the CLI of the device. As a best practice, access the device through the Console port or interface of the Management security zone in case the connection is terminated by packet filtering.
2.     Enter security policy view, and configure filtering criteria and actions for security policy rules based on the packet filtering configuration.
CAUTION
CAUTION:
After using the rule [ rule-id ] name rule-name command to create the first security policy rule, configure the filtering criteria and actions based on packet filtering as soon as possible to shorten service interruption. With no filtering criteria or action specified, the rule matches and drops all packets. You can configure other security policy settings when the service is not busy as a best practice.
3.     (Optional.) Delete the packet filtering configuration from the device.
To avoid service interruption, switch object policies to security policies before configuring security policies for the first time because object policies lose effect once security policies are configured.
After the switching, the device deletes object policy settings and their relations with security zone pairs, and security policy rules switched from object policy rules that are not applied to any security zone pairs are in inactive state and do not take effect.
When you switch object policies to security policies, follow these restrictions and guidelines:
·     Perform the undo security-policy disable command to enable the security policy feature before you execute the manual switching command, and then save the configuration.
·     Do not configure any security policy settings before switching.
·     Use this feature only after you upgrade the device from a security policy-incapable version to a version that supports security policy.
·     Make sure the working directory is on a fixed storage medium in the device, for example, the flash memory, instead of a removable storage medium, such as a hard disk.
·     After a configuration rollback from security policies to object policies, disable the security feature by using the security-policy disable command for the object policies to take effect.
Before configuring a security policy, complete the following tasks:
·     Change the object policy rule match order to make sure the rules are created in the depth-first order.
·     Make sure no object policy is applied to zone pairs that use security zone any as the source or destination security zone.
·     Make sure configuration file encryption is disabled.
2.     Switch object policy settings in the specified configuration file to security policy settings.
security-policy switch-from object-policy object-filename security-filename
Security policy settings take effect only when the security policy feature is enabled.
After the device starts up, the device automatically executes the security-policy disable command to disable the security policy feature if object policy settings exist in the configuration file. If object policy settings do not exist in the configuration file, the device enables the security policy feature.
Security policies and object policies cannot take effect at the same time on a device. If security policy is enabled, object policies lose effect at the first time security policy view is entered. If you are to manually configure security policies item by item based on object policy settings, keep the security policy feature disabled until you finish the configuration.
After a configuration rollback from security policies to object policies, disable the security feature for the object policies to take effect.
2.     Enable the security policy feature.
By default, the security policy feature is enabled.
CAUTION
CAUTION:
The security-policy disable command disables the security policy feature and might cause traffic interruption.
By default, no rules exist in a security policy, and the device allows only packets exchanged between the Management security zone and the Local security zone to pass. For the device to process packets correctly, configure policy rules for each security policy.
If a configured feature, such as dynamic routing, tunneling, and VPN, requires exchanges with the device, configure security policy rules for the Local security zone to communicate with the specific zones.
2.     Enter IPv4 security policy view.
security-policy ip
3.     (Optional.) Configure a description for the policy.
By default, a security policy does not have a description.
4.     Create a security policy rule.
5.     (Optional.) Configure a description for the rule.
By default, a security policy rule does not have a description.
A rule matches all packets if no criteria are specified for the rule. If no action is set for the rule, the device drops the matched packets by default.
If a specified object group has no objects, the rule cannot match any packets.
Packets exchanged between the Management and Local security zones are allowed to pass by default and can only match local-to-management or management-to-local security policy rules. To discard packets between the Management and Local security zones, configure local-to-management and management-to-local rules and specify the rule actions as drop.
Security policy rules specified with an IP address object group that uses a user or user group cannot match packets. To filter packets by user or user group, configure security policy rules specified with user or user group criteria.
security-policy ip
3.     Enter security policy rule view.
rule { rule-id | [ rule-id ] name rule-name }
4.     Configure source filtering criteria:
¡     Specify a source security zone as a filtering criterion.
source-zone source-zone-name
By default, no source security zone is specified as a filtering criterion.
¡     Specify a source IPv4 address object group as a filtering criterion.
source-ip object-group-name
By default, no source IPv4 address object group is specified as a filtering criterion.
¡     Specify a source IPv4 host address as a filtering criterion.
source-ip-host ip-address
By default, no source IPv4 host address is specified as a filtering criterion.
¡     Specify a source IPv4 subnet as a filtering criterion.
source-ip-subnet ip-address { mask-length | mask }
By default, no source IPv4 subnet is specified as a filtering criterion.
¡     Specify a source IPv4 address range as a filtering criterion.
source-ip-range ip-address1 ip-address2
By default, no source IPv4 address range is specified as a filtering criterion.
¡     Specify a source MAC address object group as a filtering criterion.
source-mac object-group-name
By default, no source MAC address object group is specified as a filtering criterion.
¡     Specify a source location as a filtering criterion.
source-location location-name
By default, no source location is specified as a filtering criterion.
¡     Specify a source location group as a filtering criterion.
source-location-group location-group-name
By default, no source location group is specified as a filtering criterion.
5.     Configure destination filtering criteria:
¡     Specify a destination security zone as a filtering criterion.
destination-zone destination-zone-name
By default, no destination security zone is specified as a filtering criterion.
¡     Specify a destination IPv4 address object group as a filtering criterion.
destination-ip object-group-name
By default, no destination IPv4 address object group is specified as a filtering criterion.
¡     Specify a destination IPv4 host address as a filtering criterion.
destination-ip-host ip-address
By default, no destination IPv4 host address is specified as a filtering criterion.
¡     Specify a destination IPv4 subnet as a filtering criterion.
destination-ip-subnet ip-address { mask-length | mask }
By default, no destination IPv4 subnet is specified as a filtering criterion.
¡     Specify a destination IPv4 address range as a filtering criterion.
destination-ip-range ip-address1 ip-address2
By default, no destination IPv4 address range is specified as a filtering criterion.
¡     Specify a destination location as a filtering criterion.
destination-location location-name
By default, no destination location is specified as a filtering criterion.
¡     Specify a destination location group as a filtering criterion.
destination-location-group location-group-name
By default, no destination location group is specified as a filtering criterion.
6.     Specify a service object group as a filtering criterion.
service { object-group-name | any }
By default, no service object group is specified as a filtering criterion.
7.     Specify a service port as a filtering criterion.
service-port protocol [ { destination { { eq | lt | gt } port | range port1 port2 } | source { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ]
By default, no service port is specified as a filtering criterion.
8.     Configure application filtering criteria:
¡     Specify an application as a filtering criterion.
application application-name
By default, no application is specified as a filtering criterion.
For the application filtering criteria to be identified, you must permit the dependent applications to pass through.
¡     Specify an application group as a filtering criterion.
app-group app-group-name
By default, no application group is specified as a filtering criterion.
9.     Configure terminal filtering criterion:
¡     Specify a terminal as a filtering criterion.
terminal terminal-name
By default, no terminal is specified as a filtering criterion.
For the terminal filtering criteria to be identified, you must permit packets of protocols on which the terminals depend to pass through.
¡     Specify a terminal group as a filtering criterion.
terminal-group terminal-group-name
By default, no terminal group is specified as a filtering criterion.
10.     Configure user filtering criterion:
¡     Specify a user as a filtering criterion.
user username [ domain domain-name ]
By default, no user is specified as a filtering criterion.
¡     Specify a user group as a filtering criterion.
user-group user-group-name [ domain domain-name ]
By default, no user group is specified as a filtering criterion.
11.     Specify a URL category as a filtering criterion.
url-category url-category-name
By default, no URL category is specified as a filtering criterion.
12.     Configure the rule to take effect on received packets of the specified VPN instance.
vrf vrf-name
By default, a security policy rule takes effect on received packets of the public network.
security-policy ip
4.     Specify the action for the security policy rule.
action { drop | pass }
By default, the action for a security policy rule is drop.
security-policy ip
4.     Specify a time range during which the security policy rule is in effect.
time-range time-range-name
By default, a security policy rule is in effect at any time.
This feature enables the device to perform DPI on packets matching the specified rule. For more information about DPI, see DPI Configuration Guide.
This feature takes effect only when the rule action is pass.
security-policy ip
4.     Specify the rule action as pass.
action pass
5.     Apply a DPI application profile to the rule.
profile app-profile-name
By default, no DPI application profile is applied to a rule.
Perform this task to specify the aging time for stable sessions and persistent sessions. The configuration takes effect on both existing sessions and sessions established afterwards.
The configured aging time for persistent sessions is effective only on TCP sessions in ESTABLISHED state.
The priorities of the session aging times configured by using the session persistent aging-time, session aging-time, and session persistent acl commands are in descending order.
security-policy ip
4.     Set the session aging time.
session aging-time time-value
By default, the session aging time is not configured.
5.     Set the aging time for persistent sessions.
session persistent aging-time time-value
By default, the aging time for persistent sessions is not configured.
CAUTION
CAUTION:
Setting too long an aging time might cause persistent sessions to increase rapidly and therefore cause the CPU usage to be high.
Perform this task to enable the collaboration between the track module and a security policy rule. The collaboration operates as follows:
·     If a rule is associated with the Negative state of a track entry, the device:
¡     Sets the rule state to Active if the track entry is in Negative state.
¡     Sets the rule state to Inactive if the track entry is in Positive state.
·     If a rule is associated with the Positive state of a track entry, the device:
¡     Sets the rule state to Active if the track entry is in Positive state.
¡     Sets the rule state to Inactive if the track entry is in Negative state.
For more information about track entries, see Network Management and Monitoring Configuration Guide.
security-policy ip
4.     Associate the rule with a track entry.
track { negative | positive } track-entry-number
By default, no track entry is associated with a rule.
This feature enables the device to log matching packets and send the log to the information center or fast output the log for processing. The log destinations and output rules are determined by the information center and fast log output settings. For more information about the information center and fast log output, see Network Management and Monitoring Configuration Guide.
security-policy ip
4.     Enable logging for matched packets.
logging enable
By default, logging for matched packets is disabled.
Perform this task to enable the device to collect statistics about matched packets. The collected statistics can be viewed by executing the display security-policy statistics command.
If an enabling period is specified, the system disables the statistics collection feature and removes the configuration at period expiration. If no enabling period is specified, you must execute the undo command to disable the statistics collection feature.
When inter-VLAN bridge forwarding is configured, this feature collects statistics only about packets discarded by security policies and DPI. Statistics about permitted packets are not collected. For more information about inter-VLAN bridge forwarding, see Layer 2 forwarding in Layer 2—LAN Switching Configuration Guide.
security-policy ip
4.     Enable statistics collection for matched packets.
counting enable [ period value ]
By default, the device does not collect statistics about matched packets.
2.     Enter IPv6 security policy view.
security-policy ipv6
¡     Specify a source IPv6 address object group as a filtering criterion.
By default, no source IPv6 address object group is specified as a filtering criterion.
¡     Specify a source IPv6 host address as a filtering criterion.
source-ip-host ipv6-address
By default, no source IPv6 host address is specified as a filtering criterion.
¡     Specify a source IPv6 subnet as a filtering criterion.
source-ip-subnet ipv6-address prefix-length
By default, no source IPv6 subnet is specified as a filtering criterion.
¡     Specify a source IPv6 address range as a filtering criterion.
source-ip-range ipv6-address1 ipv6-address2
By default, no source IPv6 address range is specified as a filtering criterion.
¡     Specify a destination IPv6 address object group as a filtering criterion.
By default, no destination IPv6 address object group is specified as a filtering criterion.
¡     Specify a destination IPv6 host address as a filtering criterion.
destination-ip-host ipv6-address
By default, no destination IPv6 host address is specified as a filtering criterion.
¡     Specify a destination IPv6 subnet as a filtering criterion.
destination-ip-subnet ipv6-address prefix-length
By default, no destination IPv6 subnet is specified as a filtering criterion.
¡     Specify a destination IPv6 address range as a filtering criterion.
destination-ip-range ipv6-address1 ipv6-address2
By default, no destination IPv6 address range is specified as a filtering criterion.
service-port protocol [ { destination { { eq | lt | gt } port | range port1 port2 } | source { { eq | lt | gt } port | range port1 port2 } } * | icmpv6-type icmpv6-code ]
vrf vrf-name
action pass
CAUTION
CAUTION:
logging enable
The device matches packets against security policy rules in the order the rules were created. You can change the rule match order by changing the position of a security policy rule in the rule list.
2.     Enter IPv4 or IPv6 security policy view.
security-policy { ip | ipv6 }
3.     Move a security policy rule.
¡     Move a security policy rule by rule ID.
move rule rule-id1 { { after | before } rule-id2 | bottom | down | top | up }
¡     Move a security policy rule by rule name.
move rule name rule-name1 { { after | before } name rule-name2 | bottom | down | top | up }
Rule matching acceleration does not take effect on newly added, modified, and moved rules unless the feature is activated for the rules. By default, the system automatically activates rule matching acceleration for such rules at dynamically calculated intervals.
To activate rule matching acceleration immediately after a rule change, you can perform this task.
If no rule change is detected, the system does not perform an activation operation.
Insufficient memory can cause rule matching acceleration failures. Unaccelerated rules do not take effect, and rules that have been accelerated are not affected.
3.     Activate rule matching acceleration.
accelerate enhanced enable
4.     Disable the security policy rule.
disable
By default, a security policy rule is enabled.
3.     Rename a security policy rule.
rule rename old-name new-name
Perform this task to create a security policy rule group and add security policy rules to the group.
To add a list of security policy rules, make sure the end rule is listed behind the start rule and the specified rules do not belong to any other security policy rule group.
A security policy rule group can contain only IPv4 rules or IPv6 rules.
3.     Create a security policy rule group and add security policy rules to the group.
group name group-name [ from rule-name1 to rule-name2 ] [ disable | enable ] [ description description-text ]
4.     Specify a security policy rule group for the security policy rule.
parent-group group-name
Perform this task to move a security policy rule group to change the match order of security policy rules.
If you specify a target security policy rule that belongs to a security policy rule group, follow these restrictions and guidelines:
·     If the target rule is neither the start nor end rule of the group, you cannot move a security policy rule group to the place before or after the rule.
·     If the target rule is the start rule of the group, you can only move a security policy rule group to the place before the rule.
·     If the target rule is the end rule of the group, you can only move a security policy rule group to the place after the rule.
You can move a security policy rule group before or after a security policy rule or group of the same type (IPv4 or IPv6).
3.     Move a security policy rule group.
group move group-name1 { after | before } { group group-name2 | rule rule-name }
3.     Rename a security policy rule group.
group rename old-name new-name
After the customlog format security-policy sgcc command is executed, the device fast outputs settings of enabled security policies as logs in SGCC format every day at the specified time. For more information about fast log output, see Network Management and Monitoring Configuration Guide.
2.     Set the time at which the device fast outputs security policy settings as logs every day.
security-policy config-logging send-time time
By default, the device fast outputs security policy settings as logs every day at 0 o'clock.
This feature logs security policy configuration changes. With this feature disabled, the system generates no log when security policy configuration is changed.
2.     Enable logging for security policy configuration changes.
security-policy config-changelog enable
By default, logging is enabled for security policy configuration changes.
IMPORTANT
IMPORTANT:
Non-default vSystems do not support some of the display and maintenance commands. For information about vSystem support for these commands, see security policy command reference.
Display security policy configuration.
display security-policy { ip | ipv6 } [ brief | rule name rule-name ]
Display IPv4 security policy rule configuration with the specified filtering criteria.
display security-policy ip query { destination-ip { destination-ip-address | any } | destination-zone { destination-zone-name | any } | protocol { protocol-number | any | { tcp | udp | sctp } [ source-port source-port | destination-port destination-port ] * | icmp [ icmp-type icmp-type [ icmp-code icmp-code ] ] } | source-ip { source-ip-address | any } | source-zone { source-zone-name | any } } * [ brief ]
Display IPv6 security policy rule configuration with the specified filtering criteria.
display security-policy ipv6 query { destination-ip { destination-ipv6-address | any } | destination-zone { destination-zone-name | any } | protocol { protocol-number | any | { tcp | udp | sctp } [ source-port source-port | destination-port destination-port ] * | icmpv6 [ icmpv6-type icmpv6-type [ icmpv6-code icmpv6-code ] ] } | source-ip { source-ipv6-address | any } | source-zone { source-zone-name | any} } * [ brief ]
Display security policy statistics.
display security-policy statistics { ip | ipv6 } [ rule rule-name ]
Display the security policy switching result.
display security-policy switch-result
Clear security policy statistics.
reset security-policy statistics [ ip | ipv6 ] [ rule rule-name ]
Configure security policy to achieve the following goals:
·     The president office can access the financial database server through HTTP at any time.
·     The financial office can access the financial database server through HTTP from 8:00 to 18:00 on weekdays.
·     The marketing office cannot access the financial database server through HTTP at any time.
Figure 6 Network diagram
1.     Assign IP addresses to interfaces.
# Assign an IP address to interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] ip address 192.168.0.1 255.255.255.0
2.     Add interfaces to security zones.
[Device] security-zone name database
[Device-security-zone-database] import interface gigabitethernet 1/0/1
[Device-security-zone-database] quit
[Device] security-zone name president
[Device-security-zone-president] import interface gigabitethernet 1/0/2
[Device-security-zone-president] quit
[Device] security-zone name finance
[Device-security-zone-finance] import interface gigabitethernet 1/0/3
[Device-security-zone-finance] quit
[Device] security-zone name market
[Device-security-zone-market] import interface gigabitethernet 1/0/4
[Device-security-zone-market] quit
3.     Create a time range named work to cover 8:00 to 18:00 on weekdays.
[Device] time-range work 08:00 to 18:00 working-day
4.     Configure a security policy:
# Configure a rule named president-database to allow the president office to access the financial database server through HTTP at any time.
[Device] security-policy ip
[Device-security-policy-ip] rule name president-database
[Device-security-policy-ip-0-president-database] source-zone president
[Device-security-policy-ip-0-president-database] destination-zone database
[Device-security-policy-ip-0-president-database] source-ip-subnet 192.168.1.0 24
[Device-security-policy-ip-0-president-database] destination-ip-subnet 192.168.0.0 24
[Device-security-policy-ip-0-president-database] service http
[Device-security-policy-ip-0-president-database] action pass
[Device-security-policy-ip-0-president-database] quit
# Configure a rule named finance-database to allow the financial office to access the financial database server through HTTP from 8:00 to 18:00 on weekdays.
[Device-security-policy-ip] rule name finance-database
[Device-security-policy-ip-1-finance-database] source-zone finance
[Device-security-policy-ip-1-finance-database] destination-zone database
[Device-security-policy-ip-1-finance-database] source-ip-subnet 192.168.2.0 24
[Device-security-policy-ip-1-finance-database] destination-ip-subnet 192.168.0.0 24
[Device-security-policy-ip-1-finance-database] service-port tcp destination eq 80
[Device-security-policy-ip-1-finance-database] action pass
[Device-security-policy-ip-1-finance-database] time-range work
[Device-security-policy-ip-1-finance-database] quit
# Configure a named market-database to prohibit the marketing office from accessing the financial database server through HTTP at any time.
[Device-security-policy-ip] rule name market-database
[Device-security-policy-ip-2-market-database] source-zone market
[Device-security-policy-ip-2-market-database] destination-zone database
[Device-security-policy-ip-2-market-database] source-ip-subnet 192.168.3.0 24
[Device-security-policy-ip-2-market-database] destination-ip-subnet 192.168.0.0 24
[Device-security-policy-ip-2-market-database] service http
[Device-security-policy-ip-2-market-database] action drop
[Device-security-policy-ip-2-market-database] quit
5.     Activate rule matching acceleration.
[Device-security-policy-ip] accelerate enhanced enable
[Device-security-policy-ip] quit
# Use a PC in each office to access the Web service of the financial database server through the browser. (Details not shown.)
As shown in Figure 7, a Web server with domain name www.example.com is deployed to process financial affairs. The domain name has been registered on the DNS server.
·     The financial office can access the financial Web server through HTTP.
·     The marketing office cannot access the financial Web server through HTTP at any time.
Figure 7 Network diagram
[Device-GigabitEthernet1/0/1] ip address 10.0.13.1 255.255.255.0
[Device] security-zone name web
[Device-security-zone-web] import interface gigabitethernet 1/0/1
[Device-security-zone-web] quit
[Device-security-zone-market] import interface gigabitethernet 1/0/2
[Device] security-zone name dns
[Device-security-zone-dns] import interface gigabitethernet 1/0/4
[Device-security-zone-dns] quit
3.     Create an IPv4 address object group named web. Configure an IPv4 address object with host name www.example.com for the group.
[Device] object-group ip address web
[Device-obj-grp-ip-web] network host name www.example.com
[Device-obj-grp-ip-web] quit
4.     Specify the IP address of the DNS server as 10.10.10.10.
[Device] dns server 10.10.10.10
5.     Configure a security policy:
# Configure a rule named dnslocalout to allow the device to send packets to the DNS server.
[Device-security-policy-ip] rule name dnslocalout
[Device-security-policy-ip-0-dnslocalout] source-zone local
[Device-security-policy-ip-0-dnslocalout] destination-zone dns
[Device-security-policy-ip-0-dnslocalout] destination-ip-host 10.10.10.10
[Device-security-policy-ip-0-dnslocalout] action pass
[Device-security-policy-ip-0-dnslocalout] quit
# Configure a rule named host-dns to allow the financial department and marketing department to access the DNS server.
[Device-security-policy-ip] rule name host-dns
[Device-security-policy-ip-1-host-dns] source-zone finance
[Device-security-policy-ip-1-host-dns] source-zone market
[Device-security-policy-ip-1-host-dns] destination-zone dns
[Device-security-policy-ip-1-host-dns] source-ip-subnet 10.0.11.0 24
[Device-security-policy-ip-1-host-dns] source-ip-subnet 10.0.12.0 24
[Device-security-policy-ip-1-host-dns] destination-ip-host 10.10.10.10
[Device-security-policy-ip-1-host-dns] service dns-udp
[Device-security-policy-ip-1-host-dns] action pass
[Device-security-policy-ip-1-host-dns] quit
# Configue a rule named finance-web to allow the financial department to access the financial Web server through HTTP.
[Device-security-policy-ip] rule name finance-web
[Device-security-policy-ip-2-finance-web] source-zone finance
[Device-security-policy-ip-2-finance-web] destination-zone web
[Device-security-policy-ip-2-finance-web] source-ip-subnet 10.0.11.0 24
[Device-security-policy-ip-2-finance-web] destination-ip web
[Device-security-policy-ip-2-finance-web] service http
[Device-security-policy-ip-2-finance-web] action pass
[Device-security-policy-ip-2-finance-web] quit
# Configure a rule named market-web to forbid the marketing department from accessing the financial Web server through HTTP.
[Device-security-policy-ip] rule name market-web
[Device-security-policy-ip-3-market-web] source-zone market
[Device-security-policy-ip-3-market-web] destination-zone web
[Device-security-policy-ip-3-market-web] source-ip-subnet 10.0.12.0 24
[Device-security-policy-ip-3-market-web] destination-ip web
[Device-security-policy-ip-3-market-web] service http
[Device-security-policy-ip-3-market-web] action drop
[Device-security-policy-ip-3-market-web] quit
6.     Activate rule matching acceleration.
# Use a PC in each office to access the Web service of the financial server. (Details not shown.)
As shown in Figure 8, Web servers with domain names www.example.com, finance.example.com, and bbs.example.com are deployed. The domain names have been registered on the DNS server.
·     The financial office can access all Web servers through HTTP based on fuzzy domain name matching.
·     The marketing office can access the bbs.example.com server through HTTP based on exact domain matching.
Figure 8 Network diagram
1.     Specify the address of the DNS server for intranet hosts as the IP address of the device.
2.     Assign IP addresses to interfaces:
3.     Add interfaces to security zones.
4.     Create object groups:
# Create an IPv4 address object group named web. Configure an IPv4 address object with host name *.example.com for the group. The host name can match all domain names that contain the .example.com string.
[Device-obj-grp-ip-web] network host name *.example.com
# Create an IPv4 address object group named bbs. Configure an IPv4 address object with host name bbs.example.com for the group.
[Device] object-group ip address bbs
[Device-obj-grp-ip-bbs] network host name bbs.example.com
[Device-obj-grp-ip-bbs] quit
5.     Configure DNS settings:
# Enable DNS proxy.
[Device] dns proxy enable
# Specify the IP address of the DNS server as 10.10.10.10.
6.     Configure security policies:
# Configure a rule named local-dns to allow the device to send packets to the DNS server.
[Device-security-policy-ip] rule name local-dns
[Device-security-policy-ip-0-local-dns] source-zone local
[Device-security-policy-ip-0-local-dns] destination-zone dns
[Device-security-policy-ip-0-local-dns] destination-ip-host 10.10.10.10
[Device-security-policy-ip-0-local-dns] service dns-udp
[Device-security-policy-ip-0-local-dns] service dns-tcp
[Device-security-policy-ip-0-local-dns] action pass
[Device-security-policy-ip-0-local-dns] quit
# Configure a rule named host-localdns to allow the financial department and marketing department to access DNS proxy.
[Device-security-policy-ip] rule name host-localdns
[Device-security-policy-ip-1-host-localdns] source-zone finance
[Device-security-policy-ip-1-host-localdns] source-zone market
[Device-security-policy-ip-1-host-localdns] destination-zone local
[Device-security-policy-ip-1-host-localdns] source-ip-subnet 10.0.11.0 24
[Device-security-policy-ip-1-host-localdns] source-ip-subnet 10.0.12.0 24
[Device-security-policy-ip-1-host-localdns] service dns-udp
[Device-security-policy-ip-1-host-localdns] service dns-tcp
[Device-security-policy-ip-1-host-localdns] action pass
# Configure a rule named finance-web to allow the financial department to access all Web servers through HTTP.
# Configure a rule named market-web to allow the marketing department to access the bbs.example.com server through HTTP.
[Device-security-policy-ip-3-market-web] destination-ip bbs
[Device-security-policy-ip-3-market-web] action pass
7.     Activate rule matching acceleration.
# Use a PC in the financial office to access all Web servers and a PC in the marketing office to access the bbs.example.com server. (Details not shown.)
As shown in Figure 9, a server is deployed in the headquarters in Beijing.
Configure a security policy to allow only employees in the branches in Shanghai and Hangzhou to access the server.
Figure 9 Network diagram
1.     Assign IP addresses to interfaces:
[Device-GigabitEthernet1/0/1] ip address 123.50.11.1 255.255.255.0
2.     Configure settings for routing.
This example configures static routes, and the next hop in the routes is 123.50.12.254.
[Device] ip route-static 0.0.0.0 0 123.50.12.254
[Device] security-zone name trust
[Device-security-zone-trust] import interface gigabitethernet 1/0/1
[Device-security-zone-trust] quit
[Device] security-zone name untrust
[Device-security-zone-untrust] import interface gigabitethernet 1/0/2
[Device-security-zone-untrust] quit
# Configure a rule named untrust-trust to allow employees in the branches in Shanghai and Hangzhou to access the server.
[Device-security-policy-ip] rule name untrust-trust
[Device-security-policy-ip-0-untrust-trust] source-zone untrust
[Device-security-policy-ip-0-untrust-trust] destination-zone trust
[Device-security-policy-ip-0-untrust-trust] source-location shanghai
[Device-security-policy-ip-0-untrust-trust] source-location hangzhou
[Device-security-policy-ip-0-untrust-trust] destination-ip-host 123.50.11.5
[Device-security-policy-ip-0-untrust-trust] action pass
[Device-security-policy-ip-0-untrust-trust] quit
# Activate rule matching acceleration.
# Verify that only employees in the branches in Shanghai and Hangzhou can access the server. (Details not shown.)
Object policies are already configured to achieve the following goals:
·     The financial office can access the financial database server through HTTP during working hours.
The device software needs to be upgraded to a version that supports security policy. Switch object policy settings to security policy settings after software upgrade to achieve the same goals and ensure correct network operation.
Figure 10 Network diagram
1.     Make sure you have completed the tasks in "Prerequisites for switching object policies to security policies."
2.     Switch object policy settings to security policy settings.
# Enter system view.
# Switch object policy settings in configuration file startup.cfg to security policy settings.
[Device] security-policy switch-from object-policy startup.cfg startup_secp.cfg
Configuration switching begins...
Object policies in the specified configuration file have been switched to securi
ty policies.
[Device]
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test
# Verify that the security policy settings are consistent with the object policy settings. The following shows the sample settings.
·     Object policy settings:
object-group ip address database
 0 network subnet 192.168.0.0 255.255.255.0
object-group ip address finance
 0 network subnet 192.168.2.0 255.255.255.0
object-group ip address market
 0 network subnet 192.168.3.0 255.255.255.0
object-group ip address president
 0 network subnet 192.168.1.0 255.255.255.0
object-group service web
 0 service tcp destination eq 80
object-policy ip finance-database
 rule 0 pass source-ip finance destination-ip database service web time-range work
object-policy ip market-database
 rule 0 drop source-ip market destination-ip database service web
object-policy ip president-database
 rule 0 pass source-ip president destination-ip database service web
security-zone name Local
security-zone name Trust
security-zone name DMZ
security-zone name Untrust
 import interface GigabitEthernet1/0/1
 import interface GigabitEthernet1/0/3
 import interface GigabitEthernet1/0/4
 import interface GigabitEthernet1/0/2
zone-pair security source finance destination database
 object-policy apply ip finance-database
zone-pair security source market destination database
 object-policy apply ip market-database
zone-pair security source president destination database
 object-policy apply ip president-database
·     Security policy settings:
security-policy ip
 rule 0 name finance-database-0
  action pass
  time-range work
  source-zone finance
  source-ip finance
  service web
 rule 1 name market-database-1
  source-zone market
  source-ip market
  service web
 rule 2 name president-database-2
  action pass
  source-ip president
  service web
As shown in Figure 11, OSPF is configured and the network is divided into three areas. Device A and Device B act as ABRs to exchange traffic between areas.
Configure the IPv4 security policy to make sure each router can learn the routes to all network segments in the AS.
Figure 11 Network diagram
Configuring Device A
[Device-GigabitEthernet1/0/1] ip address 1.1.1.1 255.255.255.0
[DeviceA] security-zone name untrust
[DeviceA-security-zone-Untrust] import interface gigabitethernet 1/0/1
[DeviceA-security-zone-Untrust] quit
[DeviceA] security-zone name trust
[DeviceA-security-zone-Trust] import interface gigabitethernet 1/0/2
[DeviceA-security-zone-Trust] quit
3.     Configure a security policy:
a.     Configure rules to permit traffic between the Untrust and Local security zones, so the devices can establish OSPF neighbor relations:
# Configure a rule named ospflocalin to permit the packets from security zone Untrust to security zone Local.
[DeviceA] security-policy ip
[DeviceA-security-policy-ip] rule name ospflocalin
[DeviceA-security-policy-ip-0-ospflocalin] source-zone untrust
[DeviceA-security-policy-ip-0-ospflocalin] destination-zone local
[DeviceA-security-policy-ip-0-ospflocalin] service ospf
[DeviceA-security-policy-ip-0-ospflocalin] action pass
[DeviceA-security-policy-ip-0-ospflocalin] quit
# Configure a rule named ospflocalout to permit the packets from security zone Local to security zone Untrust.
[DeviceA-security-policy-ip] rule name ospflocalout
[DeviceA-security-policy-ip-1-ospflocalout] source-zone local
[DeviceA-security-policy-ip-1-ospflocalout] destination-zone untrust
[DeviceA-security-policy-ip-1-ospflocalout] service ospf
[DeviceA-security-policy-ip-1-ospflocalout] action pass
[DeviceA-security-policy-ip-1-ospflocalout] quit
b.     Configure rules to permit traffic between the Untrust and Trust security zones, so devices in area 1 can communicate with devices in area 2.
# Configure a rule named trust-untrust to permit the packets from security zone Trust to security zone Untrust.
[DeviceA-security-policy-ip] rule name trust-untrust
[DeviceA-security-policy-ip-2-trust-untrust] source-zone trust
[DeviceA-security-policy-ip-2-trust-untrust] destination-zone untrust
[DeviceA-security-policy-ip-2-trust-untrust] source-ip-subnet 2.2.2.0 24
[DeviceA-security-policy-ip-2-trust-untrust] destination-ip-subnet 3.3.3.0 24
[DeviceA-security-policy-ip-2-trust-untrust] action pass
[DeviceA-security-policy-ip-2-trust-untrust] quit
# Configure a rule named untrust-trust to permit the packets from security zone Untrust to security zone Trust.
[DeviceA-security-policy-ip] rule name untrust-trust
[DeviceA-security-policy-ip-3-untrust-trust] source-zone untrust
[DeviceA-security-policy-ip-3-untrust-trust] destination-zone trust
[DeviceA-security-policy-ip-3-untrust-trust] source-ip-subnet 3.3.3.0 24
[DeviceA-security-policy-ip-3-untrust-trust] destination-ip-subnet 2.2.2.0 24
[DeviceA-security-policy-ip-3-untrust-trust] action pass
[DeviceA-security-policy-ip-3-untrust-trust] quit
[DeviceA-security-policy-ip] quit
4.     Configure basic OSPF functions.
[DeviceA] router id 2.2.2.1
[DeviceA] ospf
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 1.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] area 1
[DeviceA-ospf-1-area-0.0.0.1] network 2.2.2.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.1] quit
[DeviceA-ospf-1] quit
Configuring Device B
[Device-GigabitEthernet1/0/1] ip address 1.1.1.2 255.255.255.0
[Device-GigabitEthernet1/0/2] ip address 3.3.3.1 255.255.255.0
[DeviceB] security-zone name untrust
[DeviceB-security-zone-Untrust] import interface gigabitethernet 1/0/1
[DeviceB-security-zone-Untrust] quit
[DeviceB] security-zone name trust
[DeviceB-security-zone-Trust] import interface gigabitethernet 1/0/2
[DeviceB-security-zone-Trust] quit
a.     Configure rules to permit traffic between the Untrust and Local security zones, so the device can establish OSPF neighbor relations:
[DeviceB] security-policy ip
[DeviceB-security-policy-ip] rule name ospflocalin
[DeviceB-security-policy-ip-0-ospflocalin] source-zone untrust
[DeviceB-security-policy-ip-0-ospflocalin] destination-zone local
[DeviceB-security-policy-ip-0-ospflocalin] service ospf
[DeviceB-security-policy-ip-0-ospflocalin] action pass
[DeviceB-security-policy-ip-0-ospflocalin] quit
[DeviceB-security-policy-ip] rule name ospflocalout
[DeviceB-security-policy-ip-1-ospflocalout] source-zone local
[DeviceB-security-policy-ip-1-ospflocalout] destination-zone untrust
[DeviceB-security-policy-ip-1-ospflocalout] service ospf
[DeviceB-security-policy-ip-1-ospflocalout] action pass
[DeviceB-security-policy-ip-1-ospflocalout] quit
b.     Configure rules to permit traffic between the Trust and Untrust security zones, so devices in area 1 can communicate with devices in area 2:
[DeviceB-security-policy-ip] rule name trust-untrust
[DeviceB-security-policy-ip-2-trust-untrust] source-zone trust
[DeviceB-security-policy-ip-2-trust-untrust] destination-zone untrust
[DeviceB-security-policy-ip-2-trust-untrust] source-ip-subnet 3.3.3.0 24
[DeviceB-security-policy-ip-2-trust-untrust] destination-ip-subnet 2.2.2.0 24
[DeviceB-security-policy-ip-2-trust-untrust] action pass
[DeviceB-security-policy-ip-2-trust-untrust] quit
[DeviceB-security-policy-ip] rule name untrust-trust
[DeviceB-security-policy-ip-3-untrust-trust] source-zone untrust
[DeviceB-security-policy-ip-3-untrust-trust] destination-zone trust
[DeviceB-security-policy-ip-3-untrust-trust] source-ip-subnet 2.2.2.0 24
[DeviceB-security-policy-ip-3-untrust-trust] destination-ip-subnet 3.3.3.0 24
[DeviceB-security-policy-ip-3-untrust-trust] action pass
[DeviceB-security-policy-ip-3-untrust-trust] quit
[DeviceB-security-policy-ip] quit
[DeviceB] router id 3.3.3.1
[DeviceB] ospf
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 1.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] area 2
[DeviceB-ospf-1-area-0.0.0.2] network 3.3.3.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.2] quit
[DeviceB-ospf-1] quit
# View detailed information about OSPF neighbors on Device A.
[DeviceA] display ospf peer verbose
OSPF Process 1 with Router ID 2.2.2.1
                  Neighbors
 Area 0.0.0.0 interface 1.1.1.1(GigabitEthernet1/0/1)'s neighbors
 Router ID: 3.3.3.1          Address: 1.1.1.2          GR State: Normal
   DR: 1.1.1.1  BDR: 1.1.1.2  MTU: 0
   Options is 0x42 (-|O|-|-|-|-|E|-)
   Dead timer due in 32  sec
   Neighbor is up for 00:07:08
   Neighbor state change count: 5
   BFD status: Disabled
# View OSPF routing information on Device A.
[DeviceA] display ospf routing
                   Routing Table
 Routing for network
 3.3.3.0/24         2        Inter   1.1.1.2         3.3.3.1         0.0.0.0
 2.2.2.0/24         1        Stub    0.0.0.0         2.2.2.1         0.0.0.1
 1.1.1.0/24         1        Transit 0.0.0.0         2.2.2.1         0.0.0.0
 Total nets: 3
 Intra area: 2  Inter area: 1  ASE: 0  NSSA: 0
# Verify that PCs in area 1 can ping PCs in area 2. (Details not shown.)
