09-IP Multicast
HomeSupportRoutersH3C SR8800-F Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-F Routers Alarm Reference-R8530Pxx-6W10009-IP Multicast
04-HH3C-PIM-STD-MIB
04-HH3C-PIM-STD-MIB 90.66 KB
HH3C-PIM-STD-MIB
About this MIB
Use this MIB to manage PIM routers.
MIB file name
hh3c-pim-std.mib
Notifications
hh3cPimNeighborAdd
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.213.0.1
PIM neighbor created.
Informational
Minor
N/A (N/A)
ON
Notification triggers
This notification is generated when a PIM interface receives a hello packet and a PIM neighbor is created.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable pim new-neighbor command.
CLI: Use the snmp-agent trap enable pim6 new-neighbor command.
OFF
CLI: Use the undo snmp-agent trap enable pim new-neighbor command.
CLI: Use the undo snmp-agent trap enable pim6 new-neighbor command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.213.1.3 (hh3cPimNeighborExpiryTime)
Neighbor timeout time.
N/A
TimeTicks
INTEGER (0..4294967295)
1.3.6.1.4.1.25506.2.213.1.1 (hh3cPimInstanceID)
PIM instance ID.
N/A
Unsigned32
Unsigned32(0..4294967295)
1.3.6.1.4.1.25506.2.213.1.2 (hh3cPimInstanceName)
PIM instance name.
N/A
DisplayString
OCTET STRING (0..255)
1.3.6.1.4.1.25506.2.213.1.15 (hh3cPimNbrAddressType)
PIM neighbor address type.
N/A
InetAddressType
unknown(0),, ipv4(1), , ipv6(2)
1.3.6.1.4.1.25506.2.213.1.14 (hh3cPimNbrAddressIfIndex)
PIM neighbor interface.
N/A
InterfaceIndex
Integer32(1..2147483647)
1.3.6.1.4.1.25506.2.213.1.16 (hh3cPimNbrAddress)
PIM neighbor address.
N/A
InetAddress
Recommended action
No action is required.
hh3cPimRouteThresholdExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.213.0.2
The number of global PIM entries exceeded the upper limit that causes a log message to be generated.
Fault
Major
1.3.6.1.4.1.25506.2.213.0.3 (hh3cPimRouteThresholdExceedClear)
ON
This notification is generated when the number of global PIM entries exceeds the alarm threshold.
System impact
Global PIM entries might not be able to be created any more.
Status control
ON
CLI: Use the snmp-agent trap enable pim route-threshold-exceed command.
CLI: Use the snmp-agent trap enable pim6 route-threshold-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-threshold-exceed command.
CLI: Use the undo snmp-agent trap enable pim6 route-threshold-exceed command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.213.1.4 (hh3cPimNotificationLimitType)
PIM entry type.
N/A
INTEGER
sm-star-group(1),, sm-source-group(2)
1.3.6.1.4.1.25506.2.213.1.5 (hh3cPimNotificationAddressFamily)
PIM address type.
N/A
InetAddressType
unknown(0),, ipv4(1), , ipv6(2),
1.3.6.1.4.1.25506.2.213.1.6 (hh3cPimNotificationEntryCount)
Current number of PIM entries.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.213.1.8 (hh3cPimNotificationThresholdCnt)
Upper limit of PIM entries that causes a log message to be generated.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.213.1.9 (hh3cPimThresholdReasonType)
Reason why the number of PIM entries exceeded the upper limit.
N/A
INTEGER
entryCreated(1),, configurationChanged(2)
Recommended action
To resolve the issue:
1.Use the display multicast global statistics or display ipv6 multicast global statistics command to identify whether the upper limit of global PIM entries is low.
  - If yes, go to step 2.
  - If no, go to step 3.
2.Use the multicast global limit or ipv6 multicast global limit command to increase the upper limit.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The number of global PIM entries fell below the upper limit that causes a log message to be generated.
Fault
Major
N/A (N/A)
ON
This notification is generated when the number of global PIM entries falls below the upper limit that causes a log message to be generated.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable pim route-threshold-exceed-clear command.
CLI: Use the snmp-agent trap enable pim6 route-threshold-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-threshold-exceed-clear command.
CLI: Use the undo snmp-agent trap enable pim6 route-threshold-exceed-clear command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.213.1.4 (hh3cPimNotificationLimitType)
PIM entry type.
N/A
INTEGER
PIM address type
N/A
InetAddressType
N/A
Unsigned32
N/A
Unsigned32
1.3.6.1.4.1.25506.2.213.1.11 (hh3cPimThresholdClearReasonType)
N/A
INTEGER
entryDeleted(1),, configurationChanged(2),
Recommended action
hh3cPimRouteExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.213.0.4
The number of global PIM entries exceeded the maximum number.
Fault
Major
1.3.6.1.4.1.25506.2.213.0.5 (hh3cPimRouteExceedClear)
ON
This notification is generated when the number of global PIM entries exceeds the maximum number.
System impact
No global PIM entries can be created any more.
Status control
ON
CLI: Use the snmp-agent trap enable pim route-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-exceed command.
CLI: Use the undo snmp-agent trap enable pim6 route-exceed command.
Object
OID (object name)
Index
Value range
PIM entry type.
N/A
INTEGER
PIM address type.
N/A
InetAddressType
N/A
Unsigned32
1.3.6.1.4.1.25506.2.213.1.7 (hh3cPimNotificationLimitCount)
Maximum number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.213.1.12 (hh3cPimNotificationSourceAddress)
Source address of the PIM entry.
N/A
InetAddress
1.3.6.1.4.1.25506.2.213.1.13 (hh3cPimNotificationGroupAddress)
Group address of the PIM entry.
N/A
InetAddress
PIM instance name.
N/A
DisplayString
Recommended action
1.Use the display multicast global statistics or display ipv6 multicast global statistics command to identify whether the maximum number of global PIM entries is low.
2.Use the multicast global limit or ipv6 multicast global limit command to increase the maximum number.
Basic information
OID
Event
Severity
Default status
The number of global PIM entries fell below the limit.
Fault
Major
N/A (N/A)
ON
This notification is generated when the number of global PIM entries falls below the maximum number.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable pim route-exceed-clear command.
CLI: Use the snmp-agent trap enable pim6 route-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-exceed-clear command.
CLI: Use the undo snmp-agent trap enable pim6 route-exceed-clear command.
Object
OID (object name)
Index
Value range
PIM entry type.
N/A
INTEGER
PIM address type.
N/A
InetAddressType
N/A
Unsigned32
Maximum number.
N/A
Unsigned32
N/A
InetAddress
N/A
InetAddress
1.3.6.1.4.1.25506.2.213.1.10 (hh3cPimRouteEClearReasonType)
Reason why the number of PIM entries fell below the maximum number.
N/A
INTEGER
PIM instance name.
N/A
DisplayString
Recommended action
