09-IP Multicast
HomeSupportRoutersH3C SR8800-F Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-F Routers Alarm Reference-R8530Pxx-6W10009-IP Multicast
03-HH3C-MULTICAST-SNOOPING-MIB
03-HH3C-MULTICAST-SNOOPING-MIB 43.73 KB
About this MIB
Multicast snooping runs on a Layer 2 device as a multicast constraining mechanism to improve multicast forwarding efficiency. It creates Layer 2 multicast forwarding entries from IGMP or MLD packets that are exchanged between the hosts and the Layer 3 device.
Use this MIB to manage IGMP snooping and MLD snooping.
MIB file name
hh3c-multicast-snooping.mib
Notifications
hh3cMcsGlobalEntryExceed
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.123.0.1
The number of Layer 2 multicast groups exceeded the limit.
Fault
Major
ON
Notification triggers
This notification is generated in the following situations:
The number of dynamic Layer 2 multicast forwarding entries exceeds the upper limit allowed by the device, and a protocol learned entry cannot be created.
The number of static Layer 2 multicast forwarding entries exceeds the upper limit allowed by the device, and a manually configured entry cannot be created.
System impact
The corresponding multicast services are unstable.
Status control
ON
CLI: Use the snmp-agent trap enable igmp-snooping global-entry-exceed command.
CLI: Use the snmp-agent trap enable mld-snooping global-entry-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable igmp-snooping global-entry-exceed command.
CLI: Use the ndo snmp-agent trap enable mld-snooping global-entry-exceed command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.123.2.1 (hh3cMcsNotificationsAddressType)
Multicast snooping type.
N/A
InetAddressType
IGMP Snooping,, MLD Snooping
1.3.6.1.4.1.25506.2.123.2.2 (hh3cMcsNotificationsExceedLimit)
Maximum number of Layer 2 multicast groups allowed.
N/A
Unsigned32
Unsigned32(0..4294967295)
Recommended action
To resolve the issue:
1.Identify whether the number of Layer 2 multicast forwarding entries exceeds the upper limit allowed by the device.
  - If yes, execute the reset igmp-snooping group or reset mld-snooping group command to clear dynamic IGMP or MLD snooping group entries; or execute the undo igmp-snooping static-group or undo mld-snooping static-group command to remove the configuration of static member ports.
  - If no, go to step 2.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
