02-HH3C-MGMD-STD-MIB | 45.22 KB |
HH3C-MGMD-STD-MIB
About this MIB
Use this MIB to manage IGMP and MLD.
MIB file name
hh3c-mgmd-std.mib
Notifications
hh3cMgmdStdGmpJoin
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.223.0.1 |
An IGMPv1, IGMPv2, or MLDv1 join message was received. |
Informational |
Warning |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when an interface receives an IGMPv1, IGMPv2, or MLDv1 leave message or the corresponding multicast group timer times out.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable igmp leave command.
CLI: Use the snmp-agent trap enable mld leave command.
OFF
CLI: Use the undo snmp-agent trap enable igmp leave command.
CLI: Use the undo snmp-agent trap enable mld leave command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.223.1.1 (hh3cMgmdStdInterfaceName) |
Interface name. |
N/A |
DisplayString (SIZE(1..64)) |
OCTET STRING (1..64) |
1.3.6.1.4.1.25506.2.223.1.2 (hh3cMgmdStdInterfaceIfIndex) |
Interface index. |
N/A |
InterfaceIndex |
Integer32(1..2147483647) |
1.3.6.1.4.1.25506.2.223.1.4 (hh3cMgmdStdAddressType) |
Address type of IGMP/ MLD leave messages. |
N/A |
InetAddressType |
unknown(0),, ipv4(1), , ipv6(2). |
1.3.6.1.4.1.25506.2.223.1.5 (hh3cMgmdStdGmpJoinSrcAddr) |
Source address of IGMP/ MLD leave messages. |
N/A |
InetAddress |
OCTET STRING (0..255) |
1.3.6.1.4.1.25506.2.223.1.6 (hh3cMgmdStdGmpJoinGrpAddr) |
Group address of IGMP/ MLD leave messages. |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.223.1.7 (hh3cMgmdStdGmpJoinSenderIp) |
Sender IP address of IGMP/ MLD leave messages. |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.223.1.8 (hh3cMgmdStdInstanceName) |
VPN instance name. |
N/A |
DisplayString |
Recommended action
No action is required.
