24-CP and UP Separation
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10024-CP and UP Separation
05-HH3C-VNF-DEVICE-MIB
05-HH3C-VNF-DEVICE-MIB 281.04 KB
HH3C-VNF-DEVICE-MIB
About this MIB
Use this MIB to obtain basic information and notifications about VMs.
MIB file name
hh3c-vnf-device.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2). hh3cVnfDeviceMib(196)
Scalar objects
hh3cVnfmIPType
 (1.3.6.1.4.1.25506.2.196.5.1.1)
Object (OID)
Access
Value range
Implementation
hh3cVnfmIPType
accessible-for-notify
InetAddressType
ipv4(1)
VNFM IP version.
As per the MIB.
hh3cVnfmIP (1.3.6.1.4.1.25506.2.196.5.1.2)
Object (OID)
Access
Value range
Implementation
InetAddress
OCTET STRING (0..255)
VNFM IP address.
As per the MIB.
hh3cVmRetryTimes (1.3.6.1.4.1.25506.2.196.5.2.1)
Object (OID)
Access
Value range
Implementation
Unsigned32
Standard MIB values.
Number of retries.
As per the MIB.
hh3cVmCreateAttr (1.3.6.1.4.1.25506.2.196.5.2.2)
Object (OID)
Access
Value range
Implementation
INTEGER
initDeploy(1)
manu(2)
auto(3)
autoAccept (4)
VM attribute.
As per the MIB.
hh3cVmCreateFailReason (1.3.6.1.4.1.25506.2.196.5.2.3)
Object (OID)
Access
Value range
Implementation
OCTET STRING
OCTET STRING (0..128)
Creation failure cause.
As per the MIB.
hh3cVmDeleteFailReason (1.3.6.1.4.1.25506.2.196.5.2.4)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Deletion failure cause.
As per the MIB.
hh3cVmInconsistFaultReason (1.3.6.1.4.1.25506.2.196.5.2.5)
Object (OID)
Access
Value range
Implementation
INTEGER
exisitOnLocal(1)
existOnVnfm(2)
VM inconsistency cause.
As per the MIB.
hh3cVmResetResult (1.3.6.1.4.1.25506.2.196.5.2.6)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Cause of VM restart failure
As per the MIB.
hh3cVmStatusOnVnfm (1.3.6.1.4.1.25506.2.196.5.2.7)
Object (OID)
Access
Value range
Implementation
INTEGER
building(1),
active(2)
error(3)
unknown(4)
VM status on VNFM.
As per the MIB.
hh3cVmSelfSlot (1.3.6.1.4.1.25506.2.196.5.3.1)
Object (OID)
Access
Value range
Implementation
Unsigned32
Local slot number.
As per the MIB.
hh3cVmPeerSlot (1.3.6.1.4.1.25506.2.196.5.3.2)
Object (OID)
Access
Value range
Implementation
Unsigned32
Peer slot number.
As per the MIB.
hh3cVmChannelType (1.3.6.1.4.1.25506.2.196.5.3.3)
Object (OID)
Access
Value range
Implementation
INTEGER
controlchannel(1)
datachannel(2)
Channel type.
As per the MIB.
hh3cVmChannelVlan (1.3.6.1.4.1.25506.2.196.5.3.4)
Object (OID)
Access
Value range
Implementation
Unsigned32
Unsigned32 (1..4094)
VLAN ID.
As per the MIB.
hh3cVmChannelLinkMacAddress (1.3.6.1.4.1.25506.2.196.5.3.5)
Object (OID)
Access
Value range
Implementation
MacAddress
OCTET STRING(6)
MAC address of a failed interface.
Initial value: 0-0-0-0-0-0
Tabular objects
hh3cVmInfoTable
About this table
This table contains VM registration information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cVmSlot.
Object (OID)
Access
Value range
Implementation
hh3cVmSlot
(1.3.6.1.4.1.25506.2.196.1.1.1.1)
Integer32
VM index.
As per the device.
hh3cVmName (1.3.6.1.4.1.25506.2.196.1.1.1.2)
read-only
DisplayString
OCTET STRING (1..255)
VM name.
As per the MIB.
hh3cVmType
(1.3.6.1.4.1.25506.2.196.1.1.1.3)
read-only
INTEGER
other(1)
ctrlvm(2)
brasvm(3)
fwdvm(4)
mpuvm(5)
lpuvm(6)
VM type.
As per the MIB.
hh3cVmState
(1.3.6.1.4.1.25506.2.196.1.1.1.4)
read-only
INTEGER
absent(1)
normal(2)
fault(3)
other(4)
VM status.
As per the MIB.
hh3cVmRole
(1.3.6.1.4.1.25506.2.196.1.1.1.5)
read-only
INTEGER
master(1)
standby(2)
other(3)
VM role.
As per the MIB.
hh3cVmRegisterStatus
(1.3.6.1.4.1.25506.2.196.1.1.1.6)
read-only
INTEGER
registered(1)
unregistered(2)
unregisteredDestroying(3)
registering4)
maddown(5)
unregisteredMaddown(6)
other(7)
VM registration status.
As per the MIB.
hh3cVmAttr (1.3.6.1.4.1.25506.2.196.1.1.1.7)
read-only
INTEGER
initDeploy(1)
manu(2)
auto(3)
autoAccept(4)
VM attribute.
As per the MIB.
hh3cVmGroup (1.3.6.1.4.1.25506.2.196.1.1.1.8)
read-only
Integer32
Integer32(1..65535)
65535 is invalid.
VM group.
As per the MIB.
Notifications
hh3cVnfmConnectionFault
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.196.2.0.1
Communication failure between the CP and VNFM.
Error
Warning
1.3.6.1.4.1.25506.2.196.2.0.2 (hh3cVnfmConnectionFaultResume)
ON
Notification triggers
This notification is generated when the CP and VNFM fail to communicate.
System impact
The VNFM cannot manage the CP.
Status control
ON
CLI: Use the snmp-agent trap enable vmmgr vnfm command.
OFF
CLI: Use the undo snmp-agent trap enable vmmgr vnfm command.
MIB: This notification cannot be enabled or disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.196.5.1.1 (hh3cVnfmIPType)
VNFM IP version.
N/A
InetAddressType
Only support ipv4(1)
 (hh3cVnfmIP)
VNFM IP address.
N/A
InetAddress
1.3.6.1.4.1.25506.2.196.5.1.3 (hh3cVnfmPort)
VNFM port number.
N/A
unsigned32
Recommended action
To resolve this issue:
1.Execute the display current-configuration command to verify correctness of the VNFM address. If the VNFM address is incorrect, use the vnfm address ipv4-address user user-name password { cipher | simple } string [ vpn-instance vpn-instance-name ] [ http-method ] [ port port-number ] command to modify it.
2.Ping the VNFM address. If the VNFM address is unreachable, troubleshoot routing issues.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
Communication between the CP and VNFM resumed.
Recovery
Warning
ON
This notification is generated when communication between the CP and VNFM resumes.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VNFM IP version.
N/A
InetAddressType
 (hh3cVnfmIP)
VNFM IP address.
N/A
InetAddress
VNFM port number.
N/A
unsigned32
Recommended action
No action is required.
hh3cVnvmAuthenFault
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.2.0.3
The CP failed the authentication performed with the VNFM.
Informational
Warning
ON
This notification is generated when the CP fails to perform authentication with VNFM.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VNFM IP version.
N/A
InetAddressType
 (hh3cVnfmIP)
VNFM IP address.
N/A
InetAddress
VNFM port number.
N/A
unsigned32
Recommended action
1.Execute the display current-configuration command to verify correctness of the VNFM address, username, and password. If the VNFM address, username, or password is incorrect, use the vnfm address ipv4-address user user-name password { cipher | simple } string [ vpn-instance vpn-instance-name ] [ http-method ] [ port port-number ] command to modify the incorrect information.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cVmCreate
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.3.0.1
A VM was created.
Informational
Warning
ON
This notification is generated when a VM is created.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable vmmgr vm command.
OFF
CLI: Use the undo snmp-agent trap enable vmmgr vm command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.196.1.1.1.1 (hh3cVmSlot)
VM index.
hh3cVmSlot
Integer32
1.3.6.1.4.1.25506.2.196.1.1.1.3 (hh3cVmType)
VM type.
hh3cVmSlot
INTEGER
 (hh3cVmAttr)
VM attribute.
hh3cVmSlot
INTEGER
1.3.6.1.4.1.25506.2.196.1.1.1.8 (hh3cVmGroup)
VM group.
hh3cVmSlot
Integer32
Recommended action
hh3cVmDelete
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.3.0.2
A VM was deleted.
Informational
Warning
ON
This notification is generated when a VM is deleted.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VM index.
hh3cVmSlot
Integer32
VM type.
hh3cVmSlot
INTEGER
 (hh3cVmAttr)
VM attribute.
hh3cVmSlot
INTEGER
VM group.
hh3cVmSlot
Integer32
Recommended action
hh3cVmCreateSuccess
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.3.0.3
A VM was created successfully.
Informational
Warning
ON
This notification is generated when a VM is created successfully.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VM index.
hh3cVmSlot
Integer32
VM type.
hh3cVmSlot
INTEGER
 (hh3cVmAttr)
VM attribute.
hh3cVmSlot
INTEGER
 (hh3cVmGroup)
VM group.
hh3cVmSlot
Integer32
1.3.6.1.4.1.25506.2.196.5.2.1 (hh3cVmRetryTimes)
Number of retried operations on the VM.
N/A
Integer32
Recommended action
hh3cVmCreateFail
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.3.0.4
VM creation failed.
Informational
Warning
ON
This notification is generated when creation of a VM fails.
System impact
Traffic forwarding might be affected.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VM index.
hh3cVmSlot
Integer32
VM type.
hh3cVmSlot
INTEGER
 (hh3cVmAttr)
VM attribute.
hh3cVmSlot
INTEGER
 (hh3cVmGroup)
VM group.
hh3cVmSlot
Integer32
N/A
INTEGER
1.3.6.1.4.1.25506.2.196.5.2.3 (hh3cVmCreateFailReason)
VM creation failure cause.
N/A
OCTET STRING(0-128)
Recommended action
1.Identify the cause and resolve the issue accordingly:
  - If the cause is resource insufficiency, execute the display memory command to check the resource usage and create the VM again when resources are sufficient.
  - If the cause is VNFM connection failure, verify correctness of the VNFM address and VNFM connectivity, and create the VM again when VNFM is reachable at Layer 3.
2.Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
hh3cVmDeleteSuccess
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.3.0.5
A VM was deleted successfully.
Informational
Warning
ON
This notification is generated when a VM is deleted successfully.
System impact
The CP system might be affected.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VM index.
hh3cVmSlot
Integer32
VM type.
hh3cVmSlot
INTEGER
 (hh3cVmAttr)
VM attribute.
hh3cVmSlot
INTEGER
 (hh3cVmGroup)
VM group.
hh3cVmSlot
Integer32
N/A
INTEGER
Recommended action
hh3cVmInconsist
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.3.0.7
Inconsistency was detected between local VM resources and the VM resources on VNFM.
Error
Warning
1.3.6.1.4.1.25506.2.196.3.0.8 (hh3cVmInconsistResume)
ON
This notification is generated when inconsistency is detected between local VM resources and the VM resources on VNFM.
System impact
If a local VM is not created on VNFM, services might be affected.
If a local VM is not deleted from VNFM, VM creation might be affected.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VM index.
hh3cVmSlot
Integer32
1.3.6.1.4.1.25506.2.196.1.1.1.2 (hh3cVmName)
VM name.
hh3cVmSlot
DisplayString
1.3.6.1.4.1.25506.2.196.5.2.7 (hh3cVmStatusOnVnfm)
VM status on VNFM.
N/A
INTEGER
1.3.6.1.4.1.25506.2.196.5.2.5 (hh3cVmInconsistFaultReason)
Cause of VM resource inconsistency.
N/A
INTEGER
Recommended action
1.Check for VNFM connection failure, and verify correctness of the VNFM address and VNFM connectivity.
2.Verify Layer 3 reachability to VNFM.
3.Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
Consistency between local VM resources and the VM resources on VNFM was restored.
Recovery
Warning
ON
This notification is generated when the local VM resources and the VM resources on VNFM become consistent.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VM index.
hh3cVmSlot
Integer32
 (hh3cVmName)
VM name.
hh3cVmSlot
DisplayString
VM status on VNFM.
N/A
INTEGER
N/A
INTEGER
Recommended action
hh3cVmAcceptInconsistVm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.3.0.9
The CP accepted an unconfigured VM.
Informational
Warning
ON
This notification is generated when the CP accepts a VM that is not created automatically for expansion or manually.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VM index.
hh3cVmSlot
Integer32
 (hh3cVmName)
VM name.
hh3cVmSlot
DisplayString
VM type.
hh3cVmSlot
INTEGER
VM group.
hh3cVmSlot
Integer32
Recommended action
1.Verify that the VM is created from CAS.
2.Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cVmReset
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.3.0.10
A VM was restarted from VNFM.
Informational
Warning
ON
This notification is generated when a VM is restarted from VNFM.
System impact
Services running on the restarted VM are suspended or migrated to other backup VMs.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VM index.
hh3cVmSlot
Integer32
VM type.
hh3cVmSlot
INTEGER
 (hh3cVmGroup)
VM group.
hh3cVmSlot
Integer32
1.3.6.1.4.1.25506.2.196.5.2.6 (hh3cVmResetResult)
VM restart failure cause.
N/A
DisplayString
Recommended action
Troubleshoot the issue based on the cause.
hh3cVmUnregisterLongtime
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.3.0.11
The offline duration for a VM reached the alarm threshold.
Informational
Warning
ON
This notification is generated when the offline duration for a VM reaches the alarm threshold.
System impact
Service traffic forwarding might be affected.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VM index.
hh3cVmSlot
Integer32
 (hh3cVmName)
VM name.
hh3cVmSlot
DisplayString
VM type.
hh3cVmSlot
INTEGER
VM group.
hh3cVmSlot
Integer32
Recommended action
1.Verify connectivity to the VM.
hh3cVmIsolate
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.3.0.12
A VM was isolated.
Informational
Warning
ON
This notification is generated when a VM is isolated by VNFM.
System impact
The isolated VM does not provide services, but still occupies system resources.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VM index.
hh3cVmSlot
Integer32
VM type.
hh3cVmSlot
INTEGER
VM group.
hh3cVmSlot
Integer32
Recommended action
1.Verify whether the VM is in need:
  - If the VM is still needed, restart it from VNFM. After the VM restarts, execute the display vm command and verify that the VM is in normal state and its registration state is registered. For a Ctrl-VM, the Registration field displays two minus signs (--).
  - If the VM is no longer needed, delete it from VNFM.
hh3cVmChannelHealthNormal
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.4.0.1
The VM control channel or data channel passed health check.
Recovery
Warning
ON
This notification is generated when the VM control channel or data channel passes health check.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable vmmgr channel-health command.
OFF
CLI: Use the undo snmp-agent trap enable vmmgr channel-health command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.196.5.3.1 (hh3cVmSelfSlot)
Local slot number.
N/A
unsigned32
1.3.6.1.4.1.25506.2.196.5.3.2 (hh3cVmPeerSlot)
Peer slot number.
N/A
unsigned32
1.3.6.1.4.1.25506.2.196.5.3.3 (hh3cVmChannelType)
Channel type.
N/A
INTEGER
1.3.6.1.4.1.25506.2.196.5.3.4 (hh3cVmChannelVlan)
VLAN ID for the channel.
N/A
unsigned32
Recommended action
hh3cVmChannelHealthMinor
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.4.0.2
The VM control channel or data channel was placed in minor state.
Error
Warning
1.3.6.1.4.1.25506.2.196.4.0.1 (hh3cVmChannelHealthNormal)
ON
This notification is generated when the VM control channel or data channel is placed in minor state.
System impact
Traffic loss might occur on the VM control or data channel, and inter-VM traffic forwarding might be affected.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Local slot number.
N/A
unsigned32
Peer slot number.
N/A
unsigned32
Channel type.
N/A
INTEGER
N/A
unsigned32
Recommended action
1.Verify network connectivity.
hh3cVmChannelHealthSevere
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.4.0.3
The VM control channel or data channel was placed in severe state.
Error
Warning
ON
This notification is generated when the VM control channel or data channel is placed in severe state.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Local slot number.
N/A
unsigned32
Peer slot number.
N/A
unsigned32
Channel type.
N/A
INTEGER
N/A
unsigned32
Recommended action
hh3cVmChannelLinkSwitch
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.196.4.0.4
A link switchover occurred for the VM channel.
Informational
Warning
ON
This notification is generated when a link switchover occurs for the VM channel.
System impact
The VM data or control channel might fail.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Local slot number.
N/A
unsigned32
Channel type.
N/A
INTEGER
N/A
unsigned32
1.3.6.1.4.1.25506.2.196.5.3.5 (hh3cVmChannelLinkMacAddress)
MAC address of the failed interface.
N/A
MacAddress
Recommended action
