02-HH3C-CUPM-CP-MIB | 112.98 KB |
hh3cCupmUpNum(1.3.6.1.4.1.25506.2.194.2.1)
hh3cCupmCpVbUpID (1.3.6.1.4.1.25506.2.194.1.1)
hh3cCupmCpVbVxlanID (1.3.6.1.4.1.25506.2.194.1.2)
hh3cCupmCpVbSrcAddrType (1.3.6.1.4.1.25506.2.194.1.3)
hh3cCupmCpVbSrcAddr (1.3.6.1.4.1.25506.2.194.1.4)
hh3cCupmCpVbDestAddrType (1.3.6.1.4.1.25506.2.194.1.5)
hh3cCupmCpVbDestAddr (1.3.6.1.4.1.25506.2.194.1.6)
hh3cCupmCpVbVpnName (1.3.6.1.4.1.25506.2.194.1.7)
hh3cCupmCpVbVxlanState (1.3.6.1.4.1.25506.2.194.1.8)
HH3C-CUPM-CP-MIB
About this MIB
Use this MIB to implement features associated with VXLAN channels and trap notifications.
MIB file name
hh3c-cupm-cp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cCupmCp(194)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCupmUpNum(1.3.6.1.4.1.25506.2.194.2.1) |
read-only |
Integer32 |
Integer32(1..2147483647) |
Number of UPs |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCupmCpVbUpID (1.3.6.1.4.1.25506.2.194.1.1) |
accessible-for-notify |
Integer32 |
Standard MIB values. |
UP ID value |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCupmCpVbVxlanID (1.3.6.1.4.1.25506.2.194.1.2) |
Integer32 |
VXLAN ID |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCupmCpVbSrcAddrType (1.3.6.1.4.1.25506.2.194.1.3) |
InetAddressType |
Address type |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCupmCpVbSrcAddr (1.3.6.1.4.1.25506.2.194.1.4) |
IpAddress |
Source IP address |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCupmCpVbDestAddrType (1.3.6.1.4.1.25506.2.194.1.5) |
InetAddressType |
Address type |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCupmCpVbDestAddr (1.3.6.1.4.1.25506.2.194.1.6) |
IpAddress |
Destination IP address. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCupmCpVbVpnName (1.3.6.1.4.1.25506.2.194.1.7) |
OCTET STRING |
VPN name |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCupmCpVbVxlanState (1.3.6.1.4.1.25506.2.194.1.8) |
INTEGER |
VXLAN tunnel state |
As per the MIB. |
Tabular objects
hh3cCupmUpListTable
About this table
Use this table to configure the UP functions.
Support for operations
Create:Supported
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cCupmUpID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCupmUpID(1.3.6.1.4.1.25506.2.194.3.1.1.1) |
Integer32 |
UP ID |
As per the MIB. |
hh3cCupmUpDescr(1.3.6.1.4.1.25506.2.194.3.1.1.2) |
read-create |
OCTET STRING |
OCTET STRING (0..255) |
Description of the UP |
As per the MIB. |
hh3cCupmUpListRowStatus(1.3.6.1.4.1.25506.2.194.3.1.1.3) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), Destroy(6) |
Row status |
Available values are active(1), createAndGo(4), and destroy(6). Active(1) can be used only to modify the Hh3cUpDescr value. |
hh3cCupmCpProtoTnlTable
About this table
Use this table to configure the VXLAN tunnel list on the CP.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cCupmUpID, hh3cCupmCpProtoTnlVxlanID, hh3cCupmCpProtoTnlSrcAddrType, hh3cCupmCpProtoTnlSrcAddr, hh3cCupmCpProtoTnlDstAddrType, and hh3cCupmCpProtoTnlDstAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCupmCpProtoTnlVxlanID(1.3.6.1.4.1.25506.2.194.3.2.1.1) |
read-only |
Integer32 |
VXLAN ID |
As per the MIB. |
hh3cCupmCpProtoTnlSrcAddrType(1.3.6.1.4.1.25506.2.194.3.2.1.2) |
read-only |
InetAddressType |
unknown(0), ipv4(1), ipv6(2), ipv4z(3), ipv6z(4), dns(16) |
This object can only be IPv4 and IPv6. |
As per the MIB. |
hh3cCupmCpProtoTnlSrcAddr(1.3.6.1.4.1.25506.2.194.3.2.1.3) |
read-only |
InetAddress |
Source IP address |
As per the MIB. |
hh3cCupmCpProtoTnlDstAddrType(1.3.6.1.4.1.25506.2.194.3.2.1.4) |
read-only |
InetAddressType |
As per the MIB. |
hh3cCupmCpProtoTnlDstAddr(1.3.6.1.4.1.25506.2.194.3.2.1.5) |
read-only |
InetAddress |
Destination IP address |
As per the MIB. |
hh3cCupmCpProtoTnlVpnName(1.3.6.1.4.1.25506.2.194.3.2.1.6) |
read-create |
OCTET STRING |
OCTET STRING (0..31) |
VPN name |
As per the MIB. |
hh3cCupmCpProtoTnlState(1.3.6.1.4.1.25506.2.194.3.2.1.7) |
read-only |
INTEGER |
unknown(0), up(1), down(2) |
The object can only be read. |
hh3cCupmCpProtoTnlRowStatus(1.3.6.1.4.1.25506.2.194.3.2.1.8) |
read-create |
RowStatus |
Row status |
Available values are active(1), createAndGo(4), and destroy(6). Active(1) can be used only to modify the Hh3cCpSrcPort and Hh3cCpVpnName values. |
hh3cCupmAgtProtoTnlTable
About this table
Use this table to configure the VXLAN list on the UP.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cCupmUpID, hh3cCupmAgtProtoTnlVxlanID, hh3cCupmAgtProtoTnlSrcAddrType, hh3cCupmAgtProtoTnlSrcAddr, hh3cCupmAgtProtoTnlDstAddrType, and hh3cCupmAgtProtoTnlDstAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCupmAgtProtoTnlVxlanID(1.3.6.1.4.1.25506.2.194.3.3.1.1) |
read-only |
Integer32 |
VXLAN ID |
As per the MIB. |
hh3cCupmAgtProtoTnlSrcAddrType(1.3.6.1.4.1.25506.2.194.3.3.1.2) |
read-only |
InetAddressType |
As per the MIB. |
hh3cCupmAgtProtoTnlSrcAddr(1.3.6.1.4.1.25506.2.194.3.3.1.3) |
read-only |
InetAddress |
Source IP address |
As per the MIB. |
hh3cCupmAgtProtoTnlDstAddrType(1.3.6.1.4.1.25506.2.194.3.3.1.4) |
read-only |
InetAddressType |
As per the MIB. |
hh3cCupmAgtProtoTnlDstAddr(1.3.6.1.4.1.25506.2.194.3.3.1.5) |
read-only |
InetAddress |
As per the MIB. |
hh3cCupmAgtProtoTnlVpnName(1.3.6.1.4.1.25506.2.194.3.3.1.6) |
read-create |
OCTET STRING |
VPN name |
As per the MIB. |
hh3cCupmAgtProtoTnlRowStatus(1.3.6.1.4.1.25506.2.194.3.3.1.7) |
read-create |
RowStatus |
Row status |
Available values are active(1), createAndGo(4), and destroy(6). Active(1) can be used only to modify the Hh3cUpSrcPort and Hh3cUpVpnName values. |
