24-CP and UP Separation
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10024-CP and UP Separation
04-HH3C-NCM-MIB
04-HH3C-NCM-MIB 131.72 KB
HH3C-NCM-MIB
About this MIB
Use this MIB to manage the NETCONF channels of the device.
MIB file name
hh3c-ncm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNcm(201)
Scalar objects
hh3cNcmTrapUpId (1.3.6.1.4.1.25506.2.201.2.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Integer32
Integer32 (1..2147483647)
UP ID of an NCM connection
Implementation varies by product.
hh3cNcmTrapConnUserName (1.3.6.1.4.1.25506.2.201.2.1.3)
Object (OID)
Access
Value range
Implementation
DisplayString
OCTET STRING (1..80)
Username of an NCM connection.
As per the MIB.
hh3cNcmTrapConnFailedReason (1.3.6.1.4.1.25506.2.201.2.1.4)
Object (OID)
Access
Value range
Implementation
DisplayString
OCTET STRING (1..63)
Failure reason of an NCM connection.
As per the MIB.
hh3cNcmTrapFeatureName (1.3.6.1.4.1.25506.2.201.2.1.5)
Object (OID)
Access
Value range
Implementation
DisplayString
Module name.
As per the MIB.
Tabular objects
hh3cNcmConnectionTable
About this table
Use this table to obtain NCM connection information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cUpId and hh3cSessionId.
Object (OID)
Access
Value range
Implementation
hh3cNcmUpId (1.3.6.1.4.1.25506.2.201.1.1.1.1)
not-accessible
Integer32
Integer32
(1..2147483647)
UP ID of an NCM connection.
hh3cNcmSessionId (1.3.6.1.4.1.25506.2.201.1.1.1.2)
not-accessible
INTEGER
Integer32 (1..32)
Session ID of the NCM connection.
As per the MIB.
hh3cNcmConnName (1.3.6.1.4.1.25506.2.201.1.1.1.3)
read-only
DisplayString
Name of the NCM connection.
As per the MIB.
hh3cNcmConnUserName (1.3.6.1.4.1.25506.2.201.1.1.1.4)
read-only
DisplayString
Username of the NCM connection.
As per the MIB.
hh3cNcmConnSrcIpAddressType
(1.3.6.1.4.1.25506.2.201.1.1.1.5)
read-only
InetAddressType
Standard MIB values.
Type of the source IP address for the NCM connection.
As per the MIB.
hh3cNcmConnSrcIpAddress (1.3.6.1.4.1.25506.2.201.1.1.1.6)
read-only
IpAddress
Source IP address of the NCM connection.
As per the MIB.
hh3cNcmConnDestIpAddressType
(1.3.6.1.4.1.25506.2.201.1.1.1.7)
read-only
InetAddressType
Type of the destination IP address for the NCM connection.
As per the MIB.
hh3cNcmConnDestIpAddress (1.3.6.1.4.1.25506.2.201.1.1.1.8)
read-only
IpAddress
Destination IP address of the NCM connection.
As per the MIB.
hh3cNcmConnVrf (1.3.6.1.4.1.25506.2.201.1.1.1.9)
read-only
DisplayString
OCTET STRING (1..31)
VPN instance to which the NCM connection belongs.
As per the MIB.
hh3cNcmConnPort (1.3.6.1.4.1.25506.2.201.1.1.1.10)
read-only
Integer32
Integer32 (1..65535)
Port on the NCM connection.
As per the MIB.
hh3cNcmSessionState (1.3.6.1.4.1.25506.2.201.1.1.1.11)
read-only
INTEGER
initialed(1),
connected(2),
Session status of the NCM connection.
As per the MIB.
Notifications
hh3cNcmCUConnDisconnected
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.201.3.0.1
An NCM connection was lost.
Error
Warning
1.3.6.1.4.1.25506.2.201.3.0.2 (hh3cNcmCUConnReconnected)
ON
Notification triggers
This notification is generated when the CP is disconnected from the UP because of link failure.
System impact
The CP cannot deploy configuration to the UP.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
 (hh3cNcmTrapUpId)
None
Integer32
Integer32 , (1..2147483647)
1.3.6.1.4.1.25506.2.201.2.1.2
 (hh3cNcmTrapConnIpAndPort)
IP address and port number of the NCM connection.
None
DisplayString
 (hh3cNcmTrapConnUserName)
None
DisplayString
1.3.6.1.4.1.25506.2.201.2.1.4 (hh3cNcmTrapConnFailedReason)
Connection failure reason of the NCM connection.
None
DisplayString
Recommended action
To resolve this issue:
1.Execute the display interface brief command in any view on the CP to identify whether the state of the interface connecting to the UP is normal.
2.Identify whether the NETCONF channel configuration is normal on the CP.
  - Execute the display this command in NETCONF client view to identify whether the username and password of the connection are valid username and password of the UP and whether the IP address and port number are the IP address and listening port number of the UP.
  - Execute the display this command in UP management view to verify that the bind netconf-connection command is correctly executed to bind a valid NETCONF connection profile to the UP.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
A connection recovered.
Recovery
Warning
ON
This notification is generated when the connection between the CP and UP recovers.
System impact
The system is not impacted.
Status control
Object
OID (object name)
Index
Value range
 (hh3cNcmTrapUpId)
None
Integer32
None
DisplayString
1.3.6.1.4.1.25506.2.201.2.1.3 (hh3cNcmTrapConnUserName)
None
DisplayString
Recommended action
No action is required.
hh3cNcmCUConnectFailed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.201.3.0.3
The system failed to set up a connection.
Error
Warning
1.3.6.1.4.1.25506.2.201.3.0.4 (hh3cNcmCUConnectSuccess)
ON
This notification is generated when the NETCONF channel cannot be established because of the username/password configuration or link failure.
System impact
Status control
Object
OID (object name)
Index
Value range
 (hh3cNcmTrapUpId)
None
Integer32
None
DisplayString
None
DisplayString
None
DisplayString
Recommended action
Basic information
OID
Event
Severity
Default status
A connection was set up successfully.
Recovery
Warning
ON
This notification is generated because the NETCONF channel between the CP and UP is successfully established.
System impact
Status control
Object
OID (object name)
Index
Value range
 (hh3cNcmTrapUpId)
None
Integer32
None
DisplayString
None
DisplayString
Recommended action
hh3cNcmCUConfigFailed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.201.3.0.5
Configuration failed
Informational
Warning
ON
This notification is generated when the configuration fails to be deployed to the remote device..
System impact
Configuration deployment is affected.
Status control
Object
OID (object name)
Index
Value range
 (hh3cNcmTrapUpId)
None
Integer32
IP address and port of an NCM connection.
None
DisplayString
None
DisplayString
1.3.6.1.4.1.25506.2.201.2.1.5 (hh3cNcmTrapFeatureName)
NCM module name.
None
DisplayString
Recommended action
To resolve this issue, collect alarm information and configuration data, and then contact H3C Support.
