11-MPLS
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10011-MPLS
22-PW-MPLS-STD-MIB
22-PW-MPLS-STD-MIB 79.79 KB
PW-MPLS-STD-MIB
About this MIB
Use this MIB to configure PWs.
MIB file name
rfc5602-pw-mpls-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).pwMplsStdMIB(181)
Tabular objects
pwMplsTable
About this table
Use this table to configure and obtain settings of the MPLS public tunnel that carries a PW.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table index is pwIndex.
Object (OID)
Access
Value range
Implementation
pwMplsMplsType (1.3.6.1.2.1.181.1.1.1.1)
read-write
BITS
mplsTe(0),
mplsNonTe(1),
pwOnly(2)
Type of the public tunnel.
Supports only the read operation.
pwMplsExpBitsMode (1.3.6.1.2.1.181.1.1.1.2)
read-write
INTEGER
outerTunnel(1),
specifiedValue(2),
serviceDependant(3)
Type of the Exp field of the MPLS label.
As per the MIB.
pwMplsExpBits (1.3.6.1.2.1.181.1.1.1.3)
read-write
Unsigned32
Unsigned32 (0..7)
Value of the Exp field of the MPLS label.
As per the MIB.
pwMplsTtl (1.3.6.1.2.1.181.1.1.1.4)
read-write
Unsigned32
Unsigned32 (0..255)
TTL value of the MPLS PW.
As per the MIB.
pwMplsLocalLdpID (1.3.6.1.2.1.181.1.1.1.5)
read-write
MplsLdpIdentifier
OCTET STRING (6)
LDP identifier of the LDP entity that creates this PW on the local node.
pwMplsLocalLdpEntityIndex (1.3.6.1.2.1.181.1.1.1.6)
read-write
Unsigned32
Unsigned32 (1..2147483647)
LDP entity index of the LDP entity that creates this PW on the local node.
As per the MIB.
pwMplsPeerLdpID (1.3.6.1.2.1.181.1.1.1.7)
read-only
MplsLdpIdentifier
OCTET STRING (6)
The peer LDP identifier of the LDP session.
As per the MIB.
pwMplsStorageType (1.3.6.1.2.1.181.1.1.1.8)
read-write
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type for this role.
This value is always nonVolatile(3).
pwMplsOutboundTable
About this table
Use this table to configure and obtain detailed information about the MPLS public tunnel that carries the PW traffic toward the public network.
CreateSupported
DeleteSupported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
pwMplsOutboundLsrXcIndex (1.3.6.1.2.1.181.1.2.1.1)
read-write
MplsIndexType
OCTET STRING (1..24)
XC index of the public tunnel.
pwMplsOutboundTunnelIndex (1.3.6.1.2.1.181.1.2.1.2)
read-write
MplsIndexIndex
ID of the public tunnel.
pwMplsOutboundTunnelInstance (1.3.6.1.2.1.181.1.2.1.3)
read-only
MplsTunnelInstanceIndex
Unsigned32 (0 | 1..65535 | 65536..2147483647)
CRLSP ID of the public tunnel.
As per the MIB.
pwMplsOutboundTunnelLclLSR (1.3.6.1.2.1.181.1.2.1.4)
read-write
MplsLsrIdentifier
OCTET STRING (4)
Ingress LSR ID of the public tunnel.
pwMplsOutboundTunnelPeerLSR (1.3.6.1.2.1.181.1.2.1.5)
read-write
MplsLsrIdentifier
OCTET STRING (4)
Egress LSR ID of the public tunnel.
pwMplsOutboundIfIndex (1.3.6.1.2.1.181.1.2.1.6)
read-write
InterfaceIndexOrZero
Integer32 (0..2147483647)
Index of the outgoing interface of the public tunnel.
pwMplsOutboundTunnelTypeInUse (1.3.6.1.2.1.181.1.2.1.7)
read-only
INTEGER
notYetKnown(1),
mplsTe(2),
mplsNonTe(3),
pwOnly(4)
Type of the public tunnel that is carrying the PW traffic.
As per the MIB.
