11-MPLS
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10011-MPLS
16-MPLS-FTN-STD-MIB
16-MPLS-FTN-STD-MIB 106.15 KB
MPLS-FTN-STD-MIB
About this MIB
MPLS-FTN-STD-MIB is a public MIB defined by RFC 3814. This MIB mainly defines three tables (mplsFTNTable, mplsFTNMapTable, and mplsFTNPerfTable), which specify FEC to NHLFE (FTN) mappings and corresponding  performance for MPLS.
MIB file name
rfc3814-mpls-ftn-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166)
Scalar objects
mplsFTNIndexNext
(1.3.6.1.2.1.10.166.8.1.1)
Object (OID)
Access
Value range
Implementation
mplsFTNIndexNext
read-only
Unsigned32
Unsigned32
(0..4294967295)
Next available valid value to be used for mplsFTNIndex
As per the MIB.
mplsFTNTableLastChanged
(1.3.6.1.2.1.10.166.8.1.2)
Object (OID)
Access
Value range
Implementation
read-only
TimeTicks
Unsigned32
(0..4294967295)
Last time an entry was added, deleted, or modified in mplsFTNTable.
As per the MIB.
mplsFTNMapTableLastChanged
(1.3.6.1.2.1.10.166.8.1.4)
Object (OID)
Access
Value range
Implementation
read-only
TimeTicks
Unsigned32
(0..4294967295)
Last time an entry was added, deleted, or modified in mplsFTNMapTable.
As per the MIB.
Tabular objects
mplsFTNTable
About this table
This table contains FTN entries. Each entry defines a rule to be applied to incoming packets and an action to be taken on matching packets.
Support for operations
CreateTo create an instance, the following objects must be all specified: mplsFTNRowStatus, mplsFTNAddrType, mplsFTNDestAddrMin, mplsFTNDestAddrMax, mplsFTNActionType, and mplsFTNActionPointer.
Comware 7 classifies FECs by destination address and mask. It requires that mplsFTNDestAddrMin must be the lowest address in the subnet and mplsFTNDestAddrMax must be the highest address in the subnet.
For example:
1. FEC is 100.1.1.0/24. Set mplsFTNDestAddrMin to 100.1.1.0 and mplsFTNDestAddrMax to 100.1.1.255.
2. FEC is 200.1.1.2/32. Set both mplsFTNDestAddrMin and mplsFTNDestAddrMax to 200.1.1.2.
Edit/ModifyNot supported
DeleteSupported
ReadSupported.
Columns
The table index is mplsFTNMapIndex .
Object (OID)
Access
Value range
Implementation
mplsFTNIndex
(1.3.6.1.2.1.10.166.8.1.3.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Index of a row (FTN entry) in mplsFTNTable.
As per the MIB.
mplsFTNRowStatus
(1.3.6.1.2.1.10.166.8.1.3.1.2)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
mplsFTNDescr
(1.3.6.1.2.1.10.166.8.1.3.1.3)
read-create
OCTET STRING
OCTET STRING (0..65535)
Description for the FTN entry.
Supports only the read operation.
mplsFTNMask
(1.3.6.1.2.1.10.166.8.1.3.1.4)
read-create
BITS
sourceAddr(0), destAddr(1), sourcePort(2), destPort(3), protocol(4), dscp(5)
Mask for matching data packets.
mplsFTNAddrType
(1.3.6.1.2.1.10.166.8.1.3.1.5)
read-create
INTEGER
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Type of the address contained in the source and destination address objects.
Supports read and write operations.
Supports only IPv4 address.
mplsFTNSourceAddrMin
(1.3.6.1.2.1.10.166.8.1.3.1.6)
read-create
OCTET STRING
OCTET STRING
(0..255)
Lower end of the source address range.
mplsFTNSourceAddrMax
(1.3.6.1.2.1.10.166.8.1.3.1.7)
read-create
OCTET STRING
OCTET STRING
(0..255)
Upper end of the source address range.
mplsFTNDestAddrMin
(1.3.6.1.2.1.10.166.8.1.3.1.8)
read-create
OCTET STRING
OCTET STRING
(0..255)
Lower end of the destination address range.
mplsFTNDestAddrMax
(1.3.6.1.2.1.10.166.8.1.3.1.9)
read-create
OCTET STRING
OCTET STRING
(0..255)
Higher end of the destination address range.
mplsFTNSourcePortMin
(1.3.6.1.2.1.10.166.8.1.3.1.10)
read-create
Unsigned32
Unsigned32
(0..65535)
Lower end of the source port range.
mplsFTNSourcePortMax
(1.3.6.1.2.1.10.166.8.1.3.1.11)
read-create
Unsigned32
Unsigned32
(0..65535)
Higher end of the source port range.
mplsFTNDestPortMin
(1.3.6.1.2.1.10.166.8.1.3.1.12)
read-create
Unsigned32
Unsigned32
(0..65535)
Lower end of the destination port range.
mplsFTNDestPortMax
(1.3.6.1.2.1.10.166.8.1.3.1.13)
read-create
Unsigned32
Unsigned32
(0..65535)
Higher end of the destination port range.
mplsFTNProtocol
(1.3.6.1.2.1.10.166.8.1.3.1.14)
read-create
Integer32
Integer32
(0..255)
IP protocol to match against the IPv4 protocol number or IPv6 Next-Header number in the packet. A value of 255 means match all.
mplsFTNDscp
(1.3.6.1.2.1.10.166.8.1.3.1.15)
read-create
Integer32
Integer32
(0..2147483647)
Contents of the DSCP field.
mplsFTNActionType
(1.3.6.1.2.1.10.166.8.1.3.1.16)
read-create
INTEGER
redirectLsp(1), redirectTunnel(2)
The type of action to be taken on packets matching this FTN entry.
The write operation supports only the redirectLsp type.
(1.3.6.1.2.1.10.166.8.1.3.1.17)
read-create
OBJECT IDENTIFIER
zeroDotZero
Points to the LSP or tunnel to redirect matching packets to.
mplsFTNStorageType
(1.3.6.1.2.1.10.166.8.1.3.1.18)
read-create
INTEGER
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)}
The storage type for this FTN entry.
mplsFTNMapTable
About this table
This table contains objects which provide the capability to apply or map FTN rules as defined by entries in mplsFTNTable to specific interfaces in the system.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are mplsFTNMapIndex, mplsFTNMapPrevIndex, and mplsFTNMapCurrIndex.
Object (OID)
Access
Value range
Implementation
mplsFTNMapIndex
(1.3.6.1.2.1.10.166.8.1.5.1.1)
not-accessible
Integer32
Integer32
(0..2147483647)
The interface index that this FTN entry is being applied to.
As per the MIB.
mplsFTNMapPrevIndex
(1.3.6.1.2.1.10.166.8.1.5.1.2)
not-accessible
Unsigned32
Unsigned32 (0..4294967295)
The index of the previous FTN entry that was applied to this interface. The special value zero indicates that this should be the first FTN entry in the list.
As per the MIB.
mplsFTNMapCurrIndex
(1.3.6.1.2.1.10.166.8.1.5.1.3)
not-accessible
Unsigned32
Unsigned32(1..4294967295)
Index of the current FTN entry that is being applied to this interface.
As per the MIB.
mplsFTNMapRowStatus
(1.3.6.1.2.1.10.166.8.1.5.1.4)
read-create
INTEGER
active(1),
createAndGo(4),
destroy(6)
Row status.
mplsFTNMapStorageType
(1.3.6.1.2.1.10.166.8.1.5.1.5)
read-create
INTEGER
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)}
The storage type for this entry.
mplsFTNPerfTable
About this table
This table contains performance statistics on FTN entries on a per-interface basis.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are mplsFTNPerfIndex and mplsFTNPerfCurrIndex.
Object (OID)
Access
Value range
Implementation
mplsFTNPerfIndex
(1.3.6.1.2.1.10.166.8.1.6.1.1)
not-accessible
Integer32
Integer32
(0..2147483647)
The interface index of an interface that an FTN entry has been applied/mapped to.
In the current software version, per interface FTN is not supported. The value for mplsFTNPerfIndex must be 0.
As per the MIB.
(1.3.6.1.2.1.10.166.8.1.6.1.2)
not-accessible
Unsigned32
Unsigned32 (1..4294967295)
Index of an FTN entry that has been applied/mapped to the specified interface.
As per the MIB.
