11-MPLS
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10011-MPLS
18-MPLS-LDP-STD-MIB
18-MPLS-LDP-STD-MIB 233.73 KB
MPLS-LDP-STD-MIB
About this MIB
LDP is the core of MPLS and defines the messages and processing procedures involved in the label distribution process.
The Label Distribution Protocol (LDP) dynamically distributes FEC-label mapping information between LSRs to establish LSPs. LSPs can be established between two adjacent LSRs or terminate at the egress node of the network, so that all intermediate nodes in the network use label switching.
MPLS-LDP-STD-MIB is a public MIB defined by RFC 3815.
MIB file name
rfc3815-mpls-ldp-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsLdpStdMIB(4)
Scalar objects
mplsLdpLsrId (1.3.6.1.2.1.10.166.4.1.1.1)
Object (OID)
Access
Value range
Implementation
read-only
Octet string
Octet string
(0..65535)
LDP LSR ID.
As per the MIB.
mplsLdpLsrLoopDetectionCapable (1.3.6.1.2.1.10.166.4.1.1.2)
Object (OID)
Access
Value range
Implementation
read-only
Integer
1:none(1)
2:other(2)
3:hopCount(3)
4:pathVector(4)
5:hopCountAndPathVector(5)
Whether the LSR supports loop detection.
The value of this object is fixed at hopCountAndPathVector(5).
mplsLdpEntityLastChange (1.3.6.1.2.1.10.166.4.1.2.1)
Object (OID)
Access
Value range
Implementation
read-only
TimeTicks
Standard MIB values.
System time when an entry in the mplsLdpEntityTable  table was most recently added, deleted, or modified.
As per the MIB.
mplsLdpEntityIndexNext (1.3.6.1.2.1.10.166.4.1.2.2)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Unsigned32
(0..4294967295)
Next LDP entity index.
This object returns 0, which indicates that the network administrator cannot create mplsLdpEntityTable.
mplsLdpPeerLastChange (1.3.6.1.2.1.10.166.4.1.3.1)
Object (OID)
Access
Value range
Implementation
read-only
TimeStamp
INTEGER
(0..4294967295)
Time when the entry was edited.
As per the MIB.
mplsFecLastChange (1.3.6.1.2.1.10.166.4.1.3.8.1)
Object (OID)
Access
Value range
Implementation
read-only
TimeStamp
INTEGER
(0..4294967295)
System time when the LDP FEC entry was most recently modified.
Not supported
mplsFecIndexNext (1.3.6.1.2.1.10.166.4.1.3.8.2)
Object (OID)
Access
Value range
Implementation
read-only
IndexIntegerNextFree
Gauge32
(1..4294967295)
Next LDP FEC index.
This object returns 0, which indicates that the network administrator cannot create mplsFecTable.
Tabular objects
mplsLdpEntityTable
About this table
This table contains LDP entity information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are mplsLdpEntityLdpId and mplsLdpEntityIndex.
Object (OID)
Access
Value range
Implementation
mplsLdpEntityLdpId (1.3.6.1.2.1.10.166.4.1.2.3.1.1)
not-accessible
MplsLdpIdentifier
OCTET STRING
(6,6)
LDP entity ID.
As per the MIB.
mplsLdpEntityIndex (1.3.6.1.2.1.10.166.4.1.2.3.1.2)
not-accessible
Unsigned32
Unsigned32
(1,4294967295)
LDP entity index.
As per the MIB.
mplsLdpEntityProtocolVersion (1.3.6.1.2.1.10.166.4.1.2.3.1.3)
read-create
Unsigned32
Unsigned32
(1~65535)
Version number of the LDP protocol which will be used in the session initialization message.
As per the MIB.
mplsLdpEntityAdminStatus (1.3.6.1.2.1.10.166.4.1.2.3.1.4)
read-create
INTEGER
enable(1)
disable(2)
Administrative state of the LDP entity.
As per the MIB.
mplsLdpEntityOperStatus (1.3.6.1.2.1.10.166.4.1.2.3.1.5)
read-only
INTEGER
1:unknown(1)
2:enabled(2)
3:disabled(3)
Operational state of the LDP entity.
As per the MIB.
Default: enabled.
mplsLdpEntityTcpPort (1.3.6.1.2.1.10.166.4.1.2.3.1.6)
read-create
Unsigned32
Unsigned32
(0..65535)
TCP port number of the LDP entity.
As per the MIB.
Default: 646.
mplsLdpEntityUdpDscPort (1.3.6.1.2.1.10.166.4.1.2.3.1.7)
read-create
Unsigned32
Unsigned32
(0..65535)
UDP port number of the LDP entity.
As per the MIB.
Default: 646.
mplsLdpEntityMaxPduLength (1.3.6.1.2.1.10.166.4.1.2.3.1.8)
read-create
Unsigned32
Unsigned32
(256..65535)
Maximum PDU length of the LDP entity.
As per the MIB.
Default: 4096.
mplsLdpEntityKeepAliveHoldTimer (1.3.6.1.2.1.10.166.4.1.2.3.1.9)
read-create
Unsigned32
Unsigned32
(1..65535)
Keepalive interval of the LDP entity.
As per the MIB.
Default: 40.
mplsLdpEntityHelloHoldTimer (1.3.6.1.2.1.10.166.4.1.2.3.1.10)
read-create
Unsigned32
Unsigned32
(0..65535)
Hello interval of the LDP entity.
As per the MIB.
Default: 0.
If mplsLdpEntityTargetPeer is set to false, the actual default value is 15. If mplsLdpEntityTargetPeer is set to true, the actual default value is 45.
mplsLdpEntityInitSessionThreshold (1.3.6.1.2.1.10.166.4.1.2.3.1.11)
read-create
Integer32
Integer32
(0..100)
LDP entity session initialization threshold.
As per the MIB.
Default: 8.
mplsLdpEntityLabelDistMethod (1.3.6.1.2.1.10.166.4.1.2.3.1.12)
read-create
INTEGER
downstreamOnDemand(1)
downstreamUnsolicited(2)
LDP entity label distribution method.
As per the MIB.
mplsLdpEntityLabelRetentionMode (1.3.6.1.2.1.10.166.4.1.2.3.1.13)
read-create
INTEGER
conservative(1)
liberal(2)
Label retention mode used by the LDP entity.
As per the MIB.
mplsLdpEntityPathVectorLimit (1.3.6.1.2.1.10.166.4.1.2.3.1.14)
read-create
Integer32
Integer32
(0..255)
LDP entity path vector limit.
As per the MIB.
0 indicates that loop detection is not enabled.
mplsLdpEntityHopCountLimit (1.3.6.1.2.1.10.166.4.1.2.3.1.15)
read-create
Integer32
Integer32
(0..255)
LDP entity hop limit.
As per the MIB.
mplsLdpEntityTransportAddrKind (1.3.6.1.2.1.10.166.4.1.2.3.1.16)
read-create
INTEGER
1:Interface(1)
2:loopback(2)
LDP entity transport address type.
As per the MIB.
Default: loopback(2).
mplsLdpEntityTargetPeer (1.3.6.1.2.1.10.166.4.1.2.3.1.17)
read-create
INTEGER
true(1)
false(2)
If this LDP entity uses targeted peer, set this to true.
As per the MIB.
Default: false.
mplsLdpEntityTargetPeerAddrType (1.3.6.1.2.1.10.166.4.1.2.3.1.18)
read-create
InetAddressType
INTEGER
unknown (0) ,
ipv4(1) ,
ipv6 (2) ,
ipv4z (3) ,
ipv6z (4),
dns(16)
Type of the internetwork layer address used for the Extended Discovery.
As per the MIB.
Supports only ipv4.
mplsLdpEntityTargetPeerAddr (1.3.6.1.2.1.10.166.4.1.2.3.1.19)
read-create
OCTET STRING
OCTET STRING
(0..255)
The value of the internetwork layer address used for the Extended Discovery.
As per the MIB.
mplsLdpEntityLabelType (1.3.6.1.2.1.10.166.4.1.2.3.1.20)
read-create
INTEGER
generic(1),
atmParameters(2),
frameRelayParameters(3)
LDP entity label type.
As per the MIB.
mplsLdpEntityDiscontinuityTime (1.3.6.1.2.1.10.166.4.1.2.3.1.21)
read-only
TimeTicks
System time when any one or more of this entity's counters suffered a discontinuity most recently.
As per the MIB.
mplsLdpEntityStorageType (1.3.6.1.2.1.10.166.4.1.2.3.1.22)
read-create
INTEGER
other(1),
volatile(2),
nonVolatile(3),
 permanent(4),
readOnly(5)
Storage type for the LDP entity.
As per the MIB.
mplsLdpEntityRowStatus (1.3.6.1.2.1.10.166.4.1.2.3.1.23)
read-create
INTEGER
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
mplsLdpEntityStatsTable
About this table
This table contains LDP entity statistics information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
mplsLdpEntityStatsSessionAttempts (1.3.6.1.2.1.10.166.4.1.2.4.1.1)
read-only
Counter32
Counter32
(0..4294967295)
Session initialization messages sent or received by this LDP entity.
As per the MIB.
mplsLdpEntityStatsSessionRejectedNoHelloErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.2)
read-only
Counter32
Counter32
(0..4294967295)
Session Rejected (No Hello Error) notifications sent or received by the LDP entity.
As per the MIB.
mplsLdpEntityStatsSessionRejectedAdErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.3)
read-only
Counter32
Counter32
(0..4294967295)
Session Rejected (Parameters Advertisement Mode Error) notifications sent or received by the LDP entity.
As per the MIB.
mplsLdpEntityStatsSessionRejectedMaxPduErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.4)
read-only
Counter32
Counter32
(0..4294967295)
Session Rejected (Parameters Max Pdu Length Error) notifications sent or received by the LDP entity.
As per the MIB.
mplsLdpEntityStatsSessionRejectedLRErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.5)
read-only
Counter32
Counter32
(0..4294967295)
Session Rejected (Parameters Label Range) notifications sent or received by the LDP entity.
As per the MIB.
mplsLdpEntityStatsBadLdpIdentifierErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.6)
read-only
Counter32
Counter32
(0..4294967295)
Number of Bad LDP Identifier Fatal Errors detected by the sessions associated with this LDP entity.
As per the MIB.
mplsLdpEntityStatsBadPduLengthErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.7)
read-only
Counter32
Counter32
(0..4294967295)
Number of Bad PDU Length Fatal Errors detected by the sessions associated with this LDP entity.
As per the MIB.
mplsLdpEntityStatsBadMessageLengthErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.8)
read-only
Counter32
Counter32
(0..4294967295)
Number of Bad Message Length Fatal Errors detected by the sessions associated with this LDP entity.
As per the MIB.
mplsLdpEntityStatsBadTlvLengthErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.9)
read-only
Counter32
Counter32
(0..4294967295)
Number of Bad TLV Length Fatal Errors detected by the sessions associated with this LDP entity.
As per the MIB.
mplsLdpEntityStatsMalformedTlvValueErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.10)
read-only
Counter32
Counter32
(0..4294967295)
Number of Malformed TLV Value Fatal Errors detected by the sessions associated with this LDP entity.
As per the MIB.
mplsLdpEntityStatsKeepAliveTimerExpErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.11)
read-only
Counter32
Counter32
(0..4294967295)
Number of Session Keep Alive Timer Expired Fatal Errors detected by the sessions associated with this LDP entity.
As per the MIB.
mplsLdpEntityStatsShutdownReceivedNotifications (1.3.6.1.2.1.10.166.4.1.2.4.1.12)
read-only
Counter32
Counter32
(0..4294967295)
Number of shutdown notifications received by sessions associated with the LDP entity.
As per the MIB.
mplsLdpEntityStatsShutdownSentNotifications (1.3.6.1.2.1.10.166.4.1.2.4.1.13)
read-only
Counter32
Counter32
(0..4294967295)
Number of shutdown notifications sent by sessions associated with the LDP entity.
As per the MIB.
mplsLdpPeerTable
About this table
This table contains LDP peer information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is mplsLdpPeerLdpId.
Object (OID)
Access
Value range
Implementation
mplsLdpPeerLdpId (1.3.6.1.2.1.10.166.4.1.3.2.1.1)
not-accessible
OCTET STRING
OCTET STRING
(0..65535)
LDP ID of the LDP peer.
As per the MIB.
mplsLdpPeerLabelDistMethod (1.3.6.1.2.1.10.166.4.1.3.2.1.2)
read-only
INTEGER
downstreamOnDemand(1),
Label distribution method of the LDP peer.
As per the MIB.
mplsLdpPeerPathVectorLimit (1.3.6.1.2.1.10.166.4.1.3.2.1.3)
read-only
Integer32
Integer32
(0..255)
Path vector limit information about the LDP peer.
As per the MIB.
mplsLdpPeerTransportAddrType (1.3.6.1.2.1.10.166.4.1.3.2.1.4)
read-only
INTEGER
unknown(0),
ipv4(1),
 ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
LDP peer address type.
As per the MIB.
mplsLdpPeerTransportAddr (1.3.6.1.2.1.10.166.4.1.3.2.1.5)
read-only
OCTET STRING
OCTET STRING
( 0..255)
LDP peer address.
As per the MIB.
mplsLdpSessionTable
About this table
This table contains LDP session information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
mplsLdpSessionStateLastChange (1.3.6.1.2.1.10.166.4.1.3.3.1.1)
read-only
TimeTicks
Time when the LDP session state changed.
As per the MIB.
mplsLdpSessionState (1.3.6.1.2.1.10.166.4.1.3.3.1.2)
read-only
INTEGER
nonexistent(1),
initialized(2),
openrec(3),
opensent(4),
operational(5)
LDP session state.
As per the MIB.
mplsLdpSessionRole (1.3.6.1.2.1.10.166.4.1.3.3.1.3)
read-only
INTEGER
unknown(1),
active(2),
passive(3)
LDP session role.
As per the MIB.
mplsLdpSessionProtocolVersion (1.3.6.1.2.1.10.166.4.1.3.3.1.4)
read-only
Unsigned32
Unsigned32
(1..65535)
LDP session protocol version.
As per the MIB.
mplsLdpSessionKeepAliveHoldTimeRem (1.3.6.1.2.1.10.166.4.1.3.3.1.5)
read-only
INTEGER
INTEGER (0..2147483647)
Remaining keepalive time.
As per the MIB.
mplsLdpSessionKeepAliveTime (1.3.6.1.2.1.10.166.4.1.3.3.1.6)
read-only
Unsigned32
Unsigned32
(1..65535)
Keepalive interval.
As per the MIB.
mplsLdpSessionMaxPduLength (1.3.6.1.2.1.10.166.4.1.3.3.1.7)
read-only
Unsigned32
Unsigned32
(1..65535)
Maximum PDU length.
As per the MIB.
mplsLdpSessionDiscontinuityTime (1.3.6.1.2.1.10.166.4.1.3.3.1.8)
read-only
TimeTicks
System time when a counter of the LDP session suffered a discontinuity.
As per the MIB.
mplsLdpSessionStatsTable
About this table
This table contains LDP session statistics information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
mplsLdpSessionStatsUnknownMesTypeErrors (1.3.6.1.2.1.10.166.4.1.3.4.1.1)
read-only
Counter32
Counter32
(0..4294967295)
Number of unknown messages detected by the LSR during the session.
As per the MIB.
mplsLdpSessionStatsUnknownTlvErrors (1.3.6.1.2.1.10.166.4.1.3.4.1.2)
read-only
Counter32
Counter32
(0..4294967295)
Number of unknown TLVs detected by the LSR during the session.
As per the MIB.
mplsLdpHelloAdjacencyTable
About this table
This table contains LDP hello adjacency information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is mplsLdpHelloAdjacencyIndex.
Object (OID)
Access
Value range
Implementation
mplsLdpHelloAdjacencyIndex (1.3.6.1.2.1.10.166.4.1.3.5.1.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
LDP hello adjacency index.
As per the MIB.
mplsLdpHelloAdjacencyHoldTimeRem (1.3.6.1.2.1.10.166.4.1.3.5.1.1.2)
read-only
INTEGER
INTEGER
(0..2147483647)
Time remaining for the hello adjacency.
As per the MIB.
mplsLdpHelloAdjacencyHoldTime (1.3.6.1.2.1.10.166.4.1.3.5.1.1.3)
read-only
Unsigned32
Unsigned32
(0..65535)
Hold time for the hello adjacency.
As per the MIB.
Default: 0.
The actual default value is 15 for the Link Hello mode and 45 for the Targeted Hello mode.
mplsLdpHelloAdjacencyType (1.3.6.1.2.1.10.166.4.1.3.5.1.1.4)
read-only
INTEGER
link(1),
targeted(2)
LDP hello adjacency type.
As per the MIB.
mplsInSegmentLdpLspTable
About this table
This table contains LDP incoming label configuration information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is mplsInSegmentLdpLspIndex.
Object (OID)
Access
Value range
Implementation
mplsInSegmentLdpLspIndex (1.3.6.1.2.1.10.166.4.1.3.6.1.1)
not-accessible
OCTET STRING
OCTET STRING
(0..65535)
LDP LSP incoming label index.
0x00 is invalid.
mplsInSegmentLdpLspLabelType (1.3.6.1.2.1.10.166.4.1.3.6.1.2)
read-only
INTEGER
generic(1),
atmParameters(2),
LDP LSP incoming label type.
Supports only the read operation.
Supports only generic.
mplsInSegmentLdpLspType (1.3.6.1.2.1.10.166.4.1.3.6.1.3)
read-only
INTEGER
unknown(1),
terminatingLsp(2),
originatingLsp(3),
crossConnectingLsp(4)
LDP LSP type.
As per the MIB.
mplsOutSegmentLdpLspTable
About this table
This table contains LDP outgoing label table information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is mplsOutSegmentLdpLspIndex.
Object (OID)
Access
Value range
Implementation
mplsOutSegmentLdpLspIndex (1.3.6.1.2.1.10.166.4.1.3.7.1.1)
not-accessible
OCTET STRING
OCTET STRING
(0..65535)
LDP LSP outgoing label index.
0x00 is invalid.
mplsOutSegmentLdpLspLabelType (1.3.6.1.2.1.10.166.4.1.3.7.1.2)
read-only
INTEGER
generic(1),
atmParameters(2),
LDP LSP outgoing label type.
mplsOutSegmentLdpLspType (1.3.6.1.2.1.10.166.4.1.3.7.1.3)
read-only
INTEGER
unknown(1),
terminatingLsp(2),
originatingLsp(3),
LDP LSP type.
As per the MIB.
mplsFecTable
About this table
This table contains LDP FEC information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is mplsFecIndex.
Object (OID)
Access
Value range
Implementation
mplsFecIndex (1.3.6.1.2.1.10.166.4.1.3.8.3.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
LDP FEC index.
As per the MIB.
mplsFecType
(1.3.6.1.2.1.10.166.4.1.3.8.3.1.2)
read-create
INTEGER
prefix(1),
hostAddress(2)
LDP FEC type.
As per the MIB.
mplsFecAddrPrefixLength (1.3.6.1.2.1.10.166.4.1.3.8.3.1.3)
read-create
Unsigned32
Unsigned32
 (0..2040)
This node will not be defined if the mplsFecType is hostAddress(2).
The value for this node is 0 or the IP prefix range defined by mplsFecAddr if the mplsFecType is prefix(1).
If the value for this node is 0, it means that the IP prefix matches all IP addresses.
As per the MIB.
mplsFecAddrType (1.3.6.1.2.1.10.166.4.1.3.8.3.1.4)
read-create
INTEGER
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
LDP FEC address type.
As per the MIB.
mplsFecAddr (1.3.6.1.2.1.10.166.4.1.3.8.3.1.5)
read-create
OCTET STRING
OCTET STRING
 (0..65535)
LDP FEC address.
As per the MIB.
mplsFecStorageType (1.3.6.1.2.1.10.166.4.1.3.8.3.1.6)
read-create
INTEGER
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
LDP FEC storage type.
As per the MIB.
mplsFecRowStatus (1.3.6.1.2.1.10.166.4.1.3.8.3.1.7)
read-create
INTEGER
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
mplsLdpLspFecTable
About this table
This table contains the relationship between LDP LSPs and FECs.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are mplsLdpLspFecSegment, mplsLdpLspFecSegmentIndex, and mplsLdpLspFecIndex.
Object (OID)
Access
Value range
Implementation
mplsLdpLspFecSegment (1.3.6.1.2.1.10.166.4.1.3.10.1.1)
not-accessible
INTEGER
INTEGER
inSegment (1),
outSegment (2)
LDP LSP label type.
If the value of this object is inSegment, mplsLdpLspFecSegmentIndex must be consistent with mplsInSegmentLdpLspIndex. If the value of this object is set to outSegment, mplsLdpLspFecSegmentIndex must be consistent with mplsOutSegmentLdpLspIndex.
mplsLdpLspFecSegmentIndex (1.3.6.1.2.1.10.166.4.1.3.10.1.2)
not-accessible
OCTET STRING
OCTET STRING
(0..65535)
LDP LSP label index.
0x00 is invalid.
mplsLdpLspFecIndex (1.3.6.1.2.1.10.166.4.1.3.10.1.3)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
LDP FEC index.
As per the MIB.
mplsLdpLspFecStorageType
(1.3.6.1.2.1.10.166.4.1.3.10.1.4)
read-create
INTEGER
other(1),
 volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
The value of this object is fixed at volatile.
mplsLdpLspFecRowStatus
(1.3.6.1.2.1.10.166.4.1.3.10.1.5)
read-create
INTEGER
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
The row status is fixed at active(1).
mplsLdpSessionPeerAddrTable
About this table
This table contains LDP session peer address information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is mplsLdpSessionPeerAddrIndex.
Object (OID)
Access
Value range
Implementation
mplsLdpSessionPeerAddrIndex (1.3.6.1.2.1.10.166.4.1.3.11.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Peer address index.
As per the MIB.
mplsLdpSessionPeerNextHopAddrType (1.3.6.1.2.1.10.166.4.1.3.11.1.2)
read-only
INTEGER
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Next hop address type.
As per the MIB.
mplsLdpSessionPeerNextHopAddr (1.3.6.1.2.1.10.166.4.1.3.11.1.3)
read-only
OCTET STRING
OCTET STRING
(0..65535)
Next hop address.
As per the MIB.
Notifications
mplsLdpInitSessionThresholdExceeded
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.10.166.4.0.1
The number of session initialization messages exceeds the limit.
Error
Major
N/A (N/A)
ON
Notification triggers
Wrong LDP session parameter configuration will cause LDP to send initialization messages multiple times. This notification is generated when the number of session initialization messages exceeds the value (not 0) of the mplsLdpEntityInitSessionThreshold object.
System impact
All services based on this LDP session will be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable ldp command.
OFF
CLI: Use the undo snmp-agent trap enable ldp command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.10.166.4.1.2.3.1.11 (mplsLdpEntityInitSessionThreshold)
During the session establishment with an LDP peer, if the number of session initialization messages sent by the LDP entity exceeds the maximum value defined by the mplsLdpInitSessionThresholdExceeded object, the LDP entity will send notifications.
(mplsLdpEntityLdpId)
(mplsLdpEntityIndex)
Integer32
0..100
Recommended action
To resolve this issue:
1.Check the configuration for LDP session parameters:
  - Verify that the keepalive hold time is not 0 on the remote device. Value 0 is not valid. Use a non-zero value for this parameter.
  - Verify that the label advertisement mode is not Downstream On Demand (DoD) on the remote device. H3C does not support the DoD mode. Set the label advertisement mode to Downstream Unsolicited (DU) on the remote device.
  - Check the loop detection configuration on the remote device. If loop detection is enabled, the PV limit cannot be 0. If loop detection is disabled, the PV limit must be 0.
2.If the issue persists, contact H3C Support.
mplsLdpSessionUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.4.0.3
The session state changes to operational.
Recovery
Major
N/A (N/A)
ON
This notification is generated when the value of the mplsLdpSessionState object changes to operational(5). This value indicates that the LDP session is established successfully.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.10.166.4.1.3.3.1.2 (mplsLdpSessionState)
LDP session state.
(mplsLdpPeerLdpId)
INTEGER
nonexistent(1) , initialized(2) , openrec(3) , opensent(4) , operational(5))
1.3.6.1.2.1.10.166.4.1.3.3.1.8 (mplsLdpSessionDiscontinuityTime)
Time when the LDP session is up.
(mplsLdpPeerLdpId)
Timeticks
1.3.6.1.2.1.10.166.4.1.3.4.1.1 (mplsLdpSessionStatsUnknownMesTypeErrors)
(mplsLdpPeerLdpId)
Counter32
1.3.6.1.2.1.10.166.4.1.3.4.1.2 (mplsLdpSessionStatsUnknownTlvErrors)
(mplsLdpPeerLdpId)
Counter32
Recommended action
No action is required.
mplsLdpSessionDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.4.0.4
The session state is not operational.
Error
Major
1.3.6.1.2.1.10.166.4.0.3 (mplsLdpSessionUp)
ON
This notification is generated when the value of the mplsLdpSessionState object is not operational.
Possible reasons for the down state of a session include:
interface not operational.
MPLS disabled on interface.
LDP disabled on interface.
LDP auto-configure disabled on interface.
VPN instance changed on interface.
LDP instance deleted.
targeted peer deleted.
L2VPN disabled targeted peer.
TE tunnel disabled targeted peer.
session protection disabled targeted peer.
OSPF Remote LFA disabled targeted peer.
IS-IS Remote LFA disabled targeted peer
process deactivated.
failed to receive the initialization message.
graceful restart reconnect timer expired.
failed to recover adjacency by NSR.
failed to upgrade session by NSR.
closed the GR session.
keepalive hold timer expired.
hello hold timer expired.
session reset.
TCP connection down.
received a fatal notification message.
internal error.
memory in critical state.
transport address changed on interface.
MD5 password changed
Auto targeted peer deleted
Modify LDP local LSR ID
LDP process stopped
System impact
All services based on the LDP session will be interrupted.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Session state.
mplsLdpEntityLdpId
mplsLdpEntityIndex
mplsLdpPeerLdpId
INTEGER
mplsLdpEntityLdpId
mplsLdpEntityIndex
mplsLdpPeerLdpId
Timeticks
mplsLdpEntityLdpId
mplsLdpEntityIndex
mplsLdpPeerLdpId
Counter32
mplsLdpEntityLdpId
mplsLdpEntityIndex
mplsLdpPeerLdpId
Counter32
Recommended action
Take proper actions according to the reason displayed for the session down state. Table 1 shows the recommended actions.
Reasons for session down and the solutions
Reason for session down
Solution
Verify that the link state of the interface is normal and the interface has a correct IPv4 or IPv6 address configured.
Use the mpls enable command to enable MPLS on the interface in interface view.
Use the mpls ldp enable command to enable LDP on the interface in interface view.
Use the ip binding vpn-instance command in interface view to edit the interface and VPN instance association.
Use the vpn-instance command in LDP view to recover the LDP capability of the specified VPN instance.
Use the target-peer command in LDP view to reconfigure the targeted peer.
See the action for the pwDeleted notification node.
Use the display interface tunnel command to view the TE tunnel interface state. If the state is not Up, see the mplsTunnelDown notification node for the recommended action.
Use the display mpls ldp interface command to view the MPLS and LDP configuration on the interface. If the configuration does not exist, execute the mpls enable and mpls ldp enable commands in interface view.
Use the session protection command in LDP view to recover the session protection configuration.
OSPF calculated that the PQ node address of the remote LFA has changed, so it deleted the corresponding targeted peer. This is a normal operation when the network topology changes and no action is required.
IS-IS calculated that the PQ node address of the remote LFA has changed, so it deleted the corresponding targeted peer. This is a normal operation when the network topology changes and no action is required.
process deactivated
The process is waiting for automatic session recovery to be performed after the LDP process is upgraded.
As a best practice, execute the non-stop-routing command in LDP view to enable NSR to reduce the impact of process upgrading.
Execute the ping -a local-address -c count (more than 100) destination-address command to test the link status. If packet loss occurs, collect alarm information and configuration data, and then contact the technical support for help.
The local-address and destination-address are the LSR ID of the local device and destination device, respectively.
To view the LSR ID of a device, execute the display mpls ldp parameter command on the device.
Execute the display ha service-group ldp command. If the value of the State field is Realtime Backup, it indicates that the data backup has completed. Make sure the state is Realtime Backup and then perform a primary/backup switchover.
Make sure the link is stable, for example, by changing the link or troubleshooting link faults.
session reset
The session is reset manually and will be reestablished automatically. No action is required.
TCP connection down
Identify the specific error information in the message and then take actions accordingly.
internal error
LDP internal error. Collect alarm information and configuration data, and then contact Technical Support for help.
Memory has a level-3 alarm. Collect alarm information and configuration data, and then contact Technical Support for help.
Use the mpls ldp transport-address command in interface view to reconfigure the interface's LDP transport address.
Use the display this command in LDP view to view the value for the md5-authentication field. Make sure the two ends of the session have the same MD5 authentication password configured.
Use the display this command in LDP view to view the accept target-hello configuration:
If the accept target-hello configuration does not exist, check whether it is deleted mistakenly.
If the configuration is accept target-hello prefix-list prefix-list-name, use the display ip prefix-list name prefix-list-name command to check whether this IP prefix list permits the remote LSR ID. Edit the IP prefix list if needed to make sure it permits the remote LSR ID.
If the issue persists, collect alarm information and configuration data, and then contact Technical Support for help.
This operation will cause the session to go down, which is a normal process. Wait for the session to come up again.
LDP process stopped
Execute the display current-configuration configuration ldp command to view the LDP configuration. If LDP configuration exists in the output, the LDP process is stopped abnormally. In this case, collect alarm information and configuration data, and then contact Technical Support for help. If the LDP configuration does not exist, check whether it is deleted mistakenly.
The following information indicates that LDP configuration exists:
<Sysname> display current-configuration configuration  ldp
mpls ldp
return
The following information indicates that LDP configuration does not exist:
return
