06-HH3C-PIM-STD-MIB | 143.02 KB |
hh3cPimInstanceID (1.3.6.1.4.1.25506.2.213.1.1)
hh3cPimInstanceName (1.3.6.1.4.1.25506.2.213.1.2)
hh3cPimNeighborExpiryTime (1.3.6.1.4.1.25506.2.213.1.3)
hh3cPimNotificationLimitType (1.3.6.1.4.1.25506.2.213.1.4)
hh3cPimNotificationAddressFamily (1.3.6.1.4.1.25506.2.213.1.5)
hh3cPimNotificationEntryCount (1.3.6.1.4.1.25506.2.213.1.6)
hh3cPimNotificationLimitCount (1.3.6.1.4.1.25506.2.213.1.7)
hh3cPimNotificationThresholdCnt (1.3.6.1.4.1.25506.2.213.1.8)
hh3cPimThresholdReasonType (1.3.6.1.4.1.25506.2.213.1.9)
hh3cPimRouteEClearReasonType (1.3.6.1.4.1.25506.2.213.1.10)
hh3cPimThresholdClearReasonType (1.3.6.1.4.1.25506.2.213.1.11)
hh3cPimNotificationSourceAddress (1.3.6.1.4.1.25506.2.213.1.12)
hh3cPimNotificationGroupAddress (1.3.6.1.4.1.25506.2.213.1.13)
hh3cPimNbrAddressIfIndex (1.3.6.1.4.1.25506.2.213.1.14)
hh3cPimNbrAddressType (1.3.6.1.4.1.25506.2.213.1.15)
hh3cPimNbrAddress (1.3.6.1.4.1.25506.2.213.1.16)
hh3cPimNeighborUpTime (1.3.6.1.4.1.25506.2.213.1.17)
hh3cPimRouteThresholdExceedClear
HH3C-PIM-STD-MIB
About this MIB
Use this MIB to manage PIM routers.
MIB file name
hh3c-pim-std.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPimStd(213)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimInstanceID (1.3.6.1.4.1.25506.2.213.1.1) |
accessible-for-notify |
Unsigned32 |
Unsigned32 (0..4294967295) |
PIM instance ID. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimInstanceName (1.3.6.1.4.1.25506.2.213.1.2) |
DisplayString |
OCTET STRING (0..255) |
PIM instance name. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNeighborExpiryTime (1.3.6.1.4.1.25506.2.213.1.3) |
TimeTicks |
INTEGER (0..4294967295) |
Timeout timer. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationLimitType (1.3.6.1.4.1.25506.2.213.1.4) |
INTEGER |
sm-star-group(1), sm-source-group(2) |
Type of the PIM route entry. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationAddressFamily (1.3.6.1.4.1.25506.2.213.1.5) |
InetAddressType |
unknown(0), ipv4(1), ipv6(2), |
Type of the PIM address. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationEntryCount (1.3.6.1.4.1.25506.2.213.1.6) |
Unsigned32 |
Number of current PIM route entries. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationLimitCount (1.3.6.1.4.1.25506.2.213.1.7) |
Unsigned32 |
Maximum number of PIM route entries. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationThresholdCnt (1.3.6.1.4.1.25506.2.213.1.8) |
Unsigned32 |
Upper limit of PIM entries that causes a log message to be generated |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimThresholdReasonType (1.3.6.1.4.1.25506.2.213.1.9) |
INTEGER |
entryCreated(1), configurationChanged(2) |
Reason why the number of PIM route entries exceeds the maximum number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimRouteEClearReasonType (1.3.6.1.4.1.25506.2.213.1.10) |
INTEGER |
entryDeleted(1), configurationChanged(2), |
Reason why the number of PIM route entries falls below the maximum number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimThresholdClearReasonType (1.3.6.1.4.1.25506.2.213.1.11) |
INTEGER |
Reason why the number of PIM route entries falls below the upper limit. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationSourceAddress (1.3.6.1.4.1.25506.2.213.1.12) |
InetAddress |
Source address of a route entry. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNotificationGroupAddress (1.3.6.1.4.1.25506.2.213.1.13) |
InetAddress |
Group address of a route entry. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNbrAddressIfIndex (1.3.6.1.4.1.25506.2.213.1.14) |
InterfaceIndex |
Integer32 (1..2147483647) |
PIM neighbor interface. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNbrAddressType (1.3.6.1.4.1.25506.2.213.1.15) |
InetAddressType |
unknown(0), ipv4(1), ipv6(2) |
PIM neighbor address type. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNbrAddress (1.3.6.1.4.1.25506.2.213.1.16) |
read-only |
InetAddress |
PIM neighbor address. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPimNeighborUpTime (1.3.6.1.4.1.25506.2.213.1.17) |
TimeTicks |
Timeout timer. |
As per the MIB. |
Notifications
hh3cPimNeighborAdd
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.213.0.1 |
PIM neighbor created. |
Informational |
Minor |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when a PIM interface receives a hello packet and a PIM neighbor is created.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable pim new-neighbor command.
CLI: Use the snmp-agent trap enable pim6 new-neighbor command.
OFF
CLI: Use the undo snmp-agent trap enable pim new-neighbor command.
CLI: Use the undo snmp-agent trap enable pim6 new-neighbor command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.213.1.3 (hh3cPimNeighborExpiryTime) |
Neighbor timeout time. |
N/A |
TimeTicks |
1.3.6.1.4.1.25506.2.213.1.1 (hh3cPimInstanceID) |
PIM instance ID. |
N/A |
Unsigned32 |
Unsigned32(0..4294967295) |
1.3.6.1.4.1.25506.2.213.1.2 (hh3cPimInstanceName) |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.213.1.15 (hh3cPimNbrAddressType) |
N/A |
InetAddressType |
unknown(0),, ipv4(1), , ipv6(2) |
1.3.6.1.4.1.25506.2.213.1.14 (hh3cPimNbrAddressIfIndex) |
N/A |
InterfaceIndex |
Integer32(1..2147483647) |
1.3.6.1.4.1.25506.2.213.1.16 (hh3cPimNbrAddress) |
N/A |
InetAddress |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.213.0.2 |
The number of global PIM entries exceeded the upper limit that causes a log message to be generated. |
Fault |
Major |
1.3.6.1.4.1.25506.2.213.0.3 (hh3cPimRouteThresholdExceedClear) |
ON |
This notification is generated when the number of global PIM entries exceeds the alarm threshold.
System impact
Global PIM entries might not be able to be created any more.
Status control
ON
CLI: Use the snmp-agent trap enable pim route-threshold-exceed command.
CLI: Use the snmp-agent trap enable pim6 route-threshold-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-threshold-exceed command.
CLI: Use the undo snmp-agent trap enable pim6 route-threshold-exceed command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.213.1.4 (hh3cPimNotificationLimitType) |
PIM entry type. |
N/A |
INTEGER |
sm-star-group(1),, sm-source-group(2) |
1.3.6.1.4.1.25506.2.213.1.5 (hh3cPimNotificationAddressFamily) |
PIM address type. |
N/A |
InetAddressType |
unknown(0),, ipv4(1), , ipv6(2), |
1.3.6.1.4.1.25506.2.213.1.6 (hh3cPimNotificationEntryCount) |
Current number of PIM entries. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.213.1.8 (hh3cPimNotificationThresholdCnt) |
Upper limit of PIM entries that causes a log message to be generated. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.213.1.9 (hh3cPimThresholdReasonType) |
Reason why the number of PIM entries exceeded the upper limit. |
N/A |
INTEGER |
entryCreated(1),, configurationChanged(2) |
Recommended action
To resolve the issue:
1.Use the display multicast global statistics or display ipv6 multicast global statistics command to identify whether the upper limit of global PIM entries is low.
- If yes, go to step 2.
- If no, go to step 3.
2.Use the multicast global limit or ipv6 multicast global limit command to increase the upper limit.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.213.0.3 |
The number of global PIM entries fell below the upper limit that causes a log message to be generated. |
Fault |
Major |
N/A (N/A) |
ON |
This notification is generated when the number of global PIM entries falls below the upper limit that causes a log message to be generated.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable pim route-threshold-exceed-clear command.
CLI: Use the snmp-agent trap enable pim6 route-threshold-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-threshold-exceed-clear command.
CLI: Use the undo snmp-agent trap enable pim6 route-threshold-exceed-clear command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.213.1.4 (hh3cPimNotificationLimitType) |
PIM entry type. |
N/A |
INTEGER |
PIM address type |
N/A |
InetAddressType |
Current number of PIM entries |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.213.1.11 (hh3cPimThresholdClearReasonType) |
N/A |
INTEGER |
entryDeleted(1),, configurationChanged(2), |
Recommended action
hh3cPimRouteExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.213.0.4 |
The number of global PIM entries exceeded the maximum number. |
Fault |
Major |
1.3.6.1.4.1.25506.2.213.0.5 (hh3cPimRouteExceedClear) |
ON |
This notification is generated when the number of global PIM entries exceeds the maximum number.
System impact
No global PIM entries can be created any more.
Status control
ON
CLI: Use the snmp-agent trap enable pim route-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-exceed command.
CLI: Use the undo snmp-agent trap enable pim6 route-exceed command.
Object
OID (object name) |
Index |
Type |
Value range |
PIM entry type. |
N/A |
INTEGER |
PIM address type. |
N/A |
InetAddressType |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.213.1.7 (hh3cPimNotificationLimitCount) |
Maximum number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.213.1.12 (hh3cPimNotificationSourceAddress) |
Source address of the PIM entry. |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.213.1.13 (hh3cPimNotificationGroupAddress) |
Group address of the PIM entry. |
N/A |
InetAddress |
N/A |
DisplayString |
Recommended action
1.Use the display multicast global statistics or display ipv6 multicast global statistics command to identify whether the maximum number of global PIM entries is low.
2.Use the multicast global limit or ipv6 multicast global limit command to increase the maximum number.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.213.0.5 |
The number of global PIM entries fell below the limit. |
Fault |
Major |
N/A (N/A) |
ON |
This notification is generated when the number of global PIM entries falls below the maximum number.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable pim route-exceed-clear command.
CLI: Use the snmp-agent trap enable pim6 route-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-exceed-clear command.
CLI: Use the undo snmp-agent trap enable pim6 route-exceed-clear command.
Object
OID (object name) |
Index |
Type |
Value range |
PIM entry type. |
N/A |
INTEGER |
PIM address type. |
N/A |
InetAddressType |
N/A |
Unsigned32 |
Maximum number. |
N/A |
Unsigned32 |
N/A |
InetAddress |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.213.1.10 (hh3cPimRouteEClearReasonType) |
Reason why the number of PIM entries fell below the maximum number. |
N/A |
INTEGER |
N/A |
DisplayString |
Recommended action
