10-IP Multicast
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10010-IP Multicast
04-HH3C-MPM-MIB
04-HH3C-MPM-MIB 97.24 KB
HH3C-MPM-MIB
About this MIB
The h3cHostStaticJoinTable table was added to this MIB to configure a host as a static member of a multicast group.
MIB file name
hh3c-mpm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMpm(51)
Scalar objects
hh3cMPortGroupLimitMinNumber (1.3.6.1.4.1.25506.2.51.1.1)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Standard MIB values.
Minimum number of groups that a port can join.
The value of this object is always 0.
hh3cMPortGroupLimitMaxNumber (1.3.6.1.4.1.25506.2.51.1.2)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Maximum number of groups that a port can join.
The value of this object is always 4294967295.
Tabular objects
hh3cMPortGroupJoinTable
About this table
Use this table to configure a port in a VLAN to join a multicast group.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table indexes are ifIndex, hh3cMPortGroupJoinVlanID, hh3cMPortGroupJoinAddressType, and hh3cMPortGroupJoinAddress.
Object (OID)
Access
Value range
Implementation
hh3cMPortGroupJoinVlanID (1.3.6.1.4.1.25506.2.51.2.1.1.1)
not-accessible
Integer32
An index uniquely identifying a port in a VLAN which joined the multicast group.
As per the MIB.
hh3cMPortGroupJoinAddressType (1.3.6.1.4.1.25506.2.51.2.1.1.2)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Type of the multicast group address.
As per the MIB.
hh3cMPortGroupJoinAddress (1.3.6.1.4.1.25506.2.51.2.1.1.3)
not-accessible
InetAddress
OCTET STRING (0..255)
Address of the multicast group. It must be a valid multicast IP address.
As per the MIB.
hh3cMPortGroupJoinStatus (1.3.6.1.4.1.25506.2.51.2.1.1.4)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status.
Supports only the following values: active(1), createAndGo(4), and destroy(6).
hh3cMPortGroupTable
About this table
This table contains information about the status of a port which joined a multicast group in a VLAN.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ifIndex, hh3cMPortGroupVlanID, hh3cMPortGroupAddressType, and hh3cMPortGroupAddress.
Object (OID)
Access
Value range
Implementation
hh3cMPortGroupVlanID (1.3.6.1.4.1.25506.2.51.2.2.1.1)
not-accessible
Integer32
An index uniquely identifies that a port belongs to a specified VLAN.
As per the MIB.
hh3cMPortGroupAddressType (1.3.6.1.4.1.25506.2.51.2.2.1.2)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
As per the MIB.
(1.3.6.1.4.1.25506.2.51.2.2.1.3)
read-only
InetAddress
As per the MIB.
hh3cMPortConfigTable
About this table
This table contians information about the fast-leaving status, group limit number, and group policy parameters of a port in a VLAN.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are ifIndex and hh3cMPortConfigVlanID.
Object (OID)
Access
Value range
Implementation
hh3cMPortConfigVlanID (1.3.6.1.4.1.25506.2.51.2.3.1.1)
not-accessible
Integer32
As per the MIB.
hh3cMPortGroupLimitNumber (1.3.6.1.4.1.25506.2.51.2.3.1.2)
read-create
Unsigned32
As per the MIB.
hh3cMPortFastLeaveStatus (1.3.6.1.4.1.25506.2.51.2.3.1.3)
read-create
EnabledStatus
INTEGER{
enabled(1),
disabled(2)
Fast-leaving status of the port.
As per the MIB.
hh3cMPortGroupPolicyParameter (1.3.6.1.4.1.25506.2.51.2.3.1.4)
read-create
Integer32
Integer32(0|2000..2999)
ACL number which is used as the group policy of the port.
As per the MIB.
hh3cMPortConfigRowStatus (1.3.6.1.4.1.25506.2.51.2.3.1.5)
read-create
RowStatus
active(1),
notReady(3),
createAndGo(4),
destroy(6)
Row status.
Supports only the following values: destroy(6), notReady(3),, createAndGo(4), and destroy(6).
hh3cMPortGroupLimitReplace (1.3.6.1.4.1.25506.2.51.2.3.1.6)
read-create
EnabledStatus
INTEGER{
enabled(1),
disabled(2)
This object is related to the object hh3cMPortGroupLimitNumber.  If the current IGMP group number is less than the value of hh3cMPortGroupLimitNumber, any new IGMP group is permitted.
As per the MIB.
hh3cHostStaticJoinTable
About this table
Use this table to configure a host on a port in a VLAN statically to join a multicast group.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are ifIndex, h3cHostStaticJoinVlanID, h3cHostStaticJoinAddressType, and h3cHostStaticJoinAddress.
Object (OID)
Access
Value range
Implementation
hh3cHostStaticJoinVlanID (1.3.6.1.4.1.25506.2.51.2.4.1.1)
not-accessible
Integer32
An index uniquely identifies the VLAN in which a host on a port statically joined a multicast group.
As per the MIB.
hh3cHostStaticJoinAddressType (1.3.6.1.4.1.25506.2.51.2.4.1.2)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
As per the MIB.
hh3cHostStaticJoinAddress (1.3.6.1.4.1.25506.2.51.2.4.1.3)
not-accessible
InetAddress
As per the MIB.
hh3cHostStaticJoinStatus (1.3.6.1.4.1.25506.2.51.2.4.1.4)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status.
Supports only the following values: createAndGo(4), active(1), and destroy(6).
