13-OSPFV3-MIB | 433.49 KB |
ospfv3RouterId (1.3.6.1.2.1.191.1.1.1)
ospfv3AdminStatus (1.3.6.1.2.1.191.1.1.2)
ospfv3VersionNumber (1.3.6.1.2.1.191.1.1.3)
ospfv3AreaBdrRtrStatus (1.3.6.1.2.1.191.1.1.4)
ospfv3ASBdrRtrStatus (1.3.6.1.2.1.191.1.1.5)
ospfv3AsScopeLsaCount (1.3.6.1.2.1.191.1.1.6)
ospfv3AsScopeLsaCksumSum (1.3.6.1.2.1.191.1.1.7)
ospfv3OriginateNewLsas (1.3.6.1.2.1.191.1.1.8)
ospfv3RxNewLsas (1.3.6.1.2.1.191.1.1.9)
ospfv3ExtLsaCount (1.3.6.1.2.1.191.1.1.10)
ospfv3ExtAreaLsdbLimit (1.3.6.1.2.1.191.1.1.11)
ospfv3ExitOverflowInterval (1.3.6.1.2.1.191.1.1.12)
ospfv3DemandExtensions (1.3.6.1.2.1.191.1.1.13)
ospfv3ReferenceBandwidth (1.3.6.1.2.1.191.1.1.14)
ospfv3RestartSupport (1.3.6.1.2.1.191.1.1.15)
ospfv3RestartInterval (1.3.6.1.2.1.191.1.1.16)
ospfv3RestartStrictLsaChecking (1.3.6.1.2.1.191.1.1.17)
ospfv3RestartStatus (1.3.6.1.2.1.191.1.1.18)
ospfv3RestartAge (1.3.6.1.2.1.191.1.1.19)
ospfv3RestartExitReason (1.3.6.1.2.1.191.1.1.20)
ospfv3NotificationEnable (1.3.6.1.2.1.191.1.1.21)
ospfv3StubRouterSupport (1.3.6.1.2.1.191.1.1.22)
ospfv3StubRouterAdvertisement (1.3.6.1.2.1.191.1.1.23)
ospfv3DiscontinuityTime (1.3.6.1.2.1.191.1.1.24)
ospfv3RestartTime (1.3.6.1.2.1.191.1.1.25)
ospfv3NssaTranslatorStatusChange
ospfv3NbrRestartHelperStatusChange
ospfv3VirtNbrRestartHelperStatusChange
OSPFV3-MIB
About this MIB
Use this MIB to obtain OSPFv3 information.
MIB file name
rfc5643-ospfv3.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ospfv3MIB(191)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3RouterId (1.3.6.1.2.1.191.1.1.1) |
read-write |
Ospfv3RouterIdTC |
Unsigned32(1..'FFFFFFFF'h) |
Unique identifier of a router in an AS. |
Supports only the read operation. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3AdminStatus (1.3.6.1.2.1.191.1.1.2) |
read-write |
Status |
INTEGER{ enabled (1), disabled (2) } |
Enabled indicates that a minimum of one interface is in up state. Disabled indicates that no interface is in up state. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3VersionNumber (1.3.6.1.2.1.191.1.1.3) |
read-only |
INTEGER |
version3 (3) |
Version number (3). |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3AreaBdrRtrStatus (1.3.6.1.2.1.191.1.1.4) |
read-only |
TruthValue |
true(1), false(2) |
Whether the device is an ABR. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3ASBdrRtrStatus (1.3.6.1.2.1.191.1.1.5) |
read-write |
TruthValue |
true(1), false(2) |
Whether the device is an ASBR. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3AsScopeLsaCount (1.3.6.1.2.1.191.1.1.6) |
read-only |
Gauge32 |
INTEGER(0..4294967295) |
Number of AS external LSAs. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3AsScopeLsaCksumSum (1.3.6.1.2.1.191.1.1.7) |
read-only |
Unsigned32 |
Standard MIB values. |
Sum of checksums in external LSAs. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3OriginateNewLsas (1.3.6.1.2.1.191.1.1.8) |
read-only |
Counter32 |
Number of new LSAs that have been originated. This number is incremented each time the device originates a new LSA. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3RxNewLsas (1.3.6.1.2.1.191.1.1.9) |
read-only |
Counter32 |
Number of newly received LSAs, excluding self-originated LSAs. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3ExtLsaCount (1.3.6.1.2.1.191.1.1.10) |
read-only |
Gauge32 |
Number of Type-5 LSAs. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3ExtAreaLsdbLimit (1.3.6.1.2.1.191.1.1.11) |
read-write |
Integer32 |
Integer32(-1..'7FFFFFFF'h) |
Maximum number of non-default ASEs in the LSDB. A value of -1 indicates no limit. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3ExitOverflowInterval (1.3.6.1.2.1.191.1.1.12) |
read-write |
Unsigned32 |
Time that the router takes to leave the OverflowState. 0 indicates the router does not leave the OverflowState until it is restarted. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3DemandExtensions (1.3.6.1.2.1.191.1.1.13) |
read-write |
TruthValue |
true(1), false(2) |
Support for demand routing. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3ReferenceBandwidth (1.3.6.1.2.1.191.1.1.14) |
read-write |
Unsigned32 |
Reference bandwidth in Kbps for calculating the interface cost. |
When the value is divided by 1000, the decimal number will be ignored. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3RestartSupport (1.3.6.1.2.1.191.1.1.15) |
read-write |
INTEGER |
none(1), plannedOnly(2), plannedAndUnplanned(3) |
Support for GR. |
If the value changes from 1 to 2 or 3, IETF GR is supported. If the value changes between 2 and 3, the original GR type remains unchanged. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3RestartInterval (1.3.6.1.2.1.191.1.1.16) |
read-write |
Ospfv3UpToRefreshIntervalTC |
Unsigned32 (40..1800) |
GR timeout timer. |
Value range: 40 to 1800. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3RestartStrictLsaChecking (1.3.6.1.2.1.191.1.1.17) |
read-write |
TruthValue |
true(1), false(2) |
Whether the strict LSA checking capability is enabled for GR. |
Default: false(2). |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3RestartStatus (1.3.6.1.2.1.191.1.1.18) |
read-only |
INTEGER |
notRestarting(1), plannedRestart(2), unplannedRestart(3) |
Graceful restart state. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3RestartAge (1.3.6.1.2.1.191.1.1.19) |
read-only |
Unsigned32 (1..1800) |
Remaining time for the current graceful restart. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3RestartExitReason (1.3.6.1.2.1.191.1.1.20) |
read-only |
INTEGER |
none(1), inProgress(2), completed(3) timedOut(4), topologyChanged(5) |
GR exit reason. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3NotificationEnable (1.3.6.1.2.1.191.1.1.21) |
read-write |
TruthValue |
true(1), false(2) |
Whether OSPFv3 notification is enabled. |
If the value of this object is true(1), all OSPFv3 notifications are enabled. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3StubRouterSupport (1.3.6.1.2.1.191.1.1.22) |
read-only |
TruthValue |
true(1), false(2) |
Support for stub router. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3StubRouterAdvertisement (1.3.6.1.2.1.191.1.1.23) |
read-write |
INTEGER |
doNotAdvertise(1), advertise(2) |
Whether to advertise stub router LSAs. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3DiscontinuityTime (1.3.6.1.2.1.191.1.1.24) |
read-only |
TimeStamp |
TimeTicks |
Most recent system startup time. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3RestartTime (1.3.6.1.2.1.191.1.1.25) |
read-only |
TimeStamp |
TimeTicks |
Time when the most recent GR occurred. |
As per the MIB. |
Tabular objects
ospfv3AreaTable
About this table
This table contains parameter and statistics information about each area on the device.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table index is ospfv3AreaId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3AreaId (1.3.6.1.2.1.191.1.2.1.1) |
not-accessible |
Ospfv3AreaIdTC |
Unsigned32 (0..'FFFFFFFF'h) |
Area ID, a 32-bit integer that uniquely identifies an area. |
As per the MIB. |
ospfv3AreaImportAsExtern (1.3.6.1.2.1.191.1.2.1.2) |
read-create |
INTEGER |
importExternal(1), importNoExternal(2), importNssa(3) |
Area type, stub, NSSA, or common area. |
ospfv3AreaSpfRuns (1.3.6.1.2.1.191.1.2.1.3) |
read-only |
Counter32 |
Time of route calculations in the area. |
As per the MIB. |
ospfv3AreaBdrRtrCount (1.3.6.1.2.1.191.1.2.1.4) |
read-only |
Gauge32 |
Number of reachable ABRs in the area. |
As per the MIB. |
ospfv3AreaAsBdrRtrCount (1.3.6.1.2.1.191.1.2.1.5) |
read-only |
Gauge32 |
Number of reachable ASBRs in the area. |
As per the MIB. |
ospfv3AreaScopeLsaCount (1.3.6.1.2.1.191.1.2.1.6) |
read-only |
Gauge32 |
Number of LSAs in the LSDB of the area. |
As per the MIB. |
ospfv3AreaScopeLsaCksumSum (1.3.6.1.2.1.191.1.2.1.7) |
read-only |
Unsigned32 |
Sum of the checksums of the LSAs in the area. |
As per the MIB. |
ospfv3AreaSummary (1.3.6.1.2.1.191.1.2.1.8) |
read-create |
INTEGER |
noAreaSummary(1), sendAreaSummary(2) |
Whether to send summary LSAs to stub and NSSA areas. |
Supports read and write operations. |
ospfv3AreaRowStatus (1.3.6.1.2.1.191.1.2.1.9) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Area state. |
ospfv3AreaStubMetric (1.3.6.1.2.1.191.1.2.1.10) |
read-create |
BigMetric |
Integer32(0..16777215) |
Cost of the default route advertised to a stub or NSSA area. |
Supports read and write operations. Default: 1. Value range: 0 to 16777214. |
ospfv3AreaNssaTranslatorRole (1.3.6.1.2.1.191.1.2.1.11) |
read-create |
INTEGER |
always(1), candidate(2) |
Ability of the NSSA ABR to translate Type-7 LSAs into Type-5 LSAs. |
ospfv3AreaNssaTranslatorState (1.3.6.1.2.1.191.1.2.1.12) |
read-only |
INTEGER |
enabled(1), elected(2), disabled(3) |
State for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs. |
As per the MIB. |
ospfv3AreaNssaTranslatorStabInterval (1.3.6.1.2.1.191.1.2.1.13) |
read-create |
Unsigned32 |
Time period during which the elected translator continues to perform translation after determining that its services are no longer required. |
Supports read and write operations. Default: 0. Value range: 0 to 900. |
ospfv3AreaNssaTranslatorEvents (1.3.6.1.2.1.191.1.2.1.14) |
read-only |
Counter32 |
Number of role changes. |
As per the MIB. |
ospfv3AreaStubMetricType (1.3.6.1.2.1.191.1.2.1.15) |
read-create |
INTEGER |
ospfv3Metric(1), ableCost(2), mparable(3) |
Cost type of the default route advertised to a stub or NSSA area. |
ospfv3AreaTEEnabled (1.3.6.1.2.1.191.1.2.1.16) |
read-create |
TruthValue |
true(1), false(2) |
Whether TE is enabled. |
Supports only the read and write operations. |
ospfv3AsLsdbTable
About this table
This table contains information about LSDB information of an AS.
Edit/Modify:Not supported
Read:Supported
Columns
The table indexes are ospfv3AsLsdbType, ospfv3AsLsdbRouterId, and ospfv3AsLsdbLsid.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3AsLsdbType (1.3.6.1.2.1.191.1.3.1.1) |
not-accessible |
Unsigned32 |
Unsigned32(0..'FFFFFFFF'h) |
LSA type. |
As per the MIB. |
ospfv3AsLsdbRouterId (1.3.6.1.2.1.191.1.3.1.2) |
not-accessible |
Ospfv3RouterIdTC |
Router ID of the device that generates the LSA. |
As per the MIB. |
ospfv3AsLsdbLsid (1.3.6.1.2.1.191.1.3.1.3) |
not-accessible |
Ospfv3LsIdTC |
Unsigned32 (1..'FFFFFFFF'h) |
LS ID. |
As per the MIB. |
ospfv3AsLsdbSequence (1.3.6.1.2.1.191.1.3.1.4) |
read-only |
Ospfv3LsaSequenceTC |
Integer32 |
LSA sequence number. |
As per the MIB. |
ospfv3AsLsdbAge (1.3.6.1.2.1.191.1.3.1.5) |
read-only |
Ospfv3LsaAgeTC |
Unsigned32 (0..3600) |
LSA age. |
As per the MIB. |
ospfv3AsLsdbChecksum (1.3.6.1.2.1.191.1.3.1.6) |
read-only |
Integer32 |
Checksum. |
As per the MIB. |
ospfv3AsLsdbAdvertisement (1.3.6.1.2.1.191.1.3.1.7) |
read-only |
OCTET STRING |
OCTET STRING(1..65535) |
LSA information, including the header. |
As per the MIB. |
ospfv3AsLsdbTypeKnown (1.3.6.1.2.1.191.1.3.1.8) |
read-only |
TruthValue |
true(1), false(2) |
Whether the LSA type is unknown. |
As per the MIB. |
ospfv3AreaLsdbTable
About this table
This table contains information about LSDB information of an area.
Read:Supported
Columns
The table indexes are ospfv3AreaLsdbAreaId, ospfv3AreaLsdbType, ospfv3AreaLsdbRouterId, and ospfv3AreaLsdbLsid.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3AreaLsdbAreaId (1.3.6.1.2.1.191.1.4.1.1) |
not-accessible |
Ospfv3AreaIdTC |
Area from which the LSA was received. |
As per the MIB. |
ospfv3AreaLsdbType (1.3.6.1.2.1.191.1.4.1.2) |
not-accessible |
Unsigned32 |
LSA type. |
As per the MIB. |
ospfv3AreaLsdbRouterId (1.3.6.1.2.1.191.1.4.1.3) |
not-accessible |
Ospfv3RouterIdTC |
As per the MIB. |
ospfv3AreaLsdbLsid (1.3.6.1.2.1.191.1.4.1.4) |
not-accessible |
Ospfv3LsIdTC |
LS ID. |
As per the MIB. |
ospfv3AreaLsdbSequence (1.3.6.1.2.1.191.1.4.1.5) |
read-only |
Integer32 |
As per the MIB. |
ospfv3AreaLsdbAge (1.3.6.1.2.1.191.1.4.1.6) |
read-only |
Ospfv3LsaAgeTC |
LSA age. |
As per the MIB. |
ospfv3AreaLsdbChecksum (1.3.6.1.2.1.191.1.4.1.7) |
read-only |
Integer32 |
Checksum. |
As per the MIB. |
ospfv3AreaLsdbAdvertisement (1.3.6.1.2.1.191.1.4.1.8) |
read-only |
OCTET STRING |
As per the MIB. |
ospfv3AreaLsdbTypeKnown (1.3.6.1.2.1.191.1.4.1.9) |
read-only |
TruthValue |
true(1), false(2) |
As per the MIB. |
ospfv3LinkLsdbTable
About this table
This table contains link-scope LSDB information.
Read:Supported
Columns
The table indexes are ospfv3LinkLsdbIfIndex, ospfv3LinkLsdbIfInstId, ospfv3LinkLsdbType, ospfv3LinkLsdbRouterId, and ospfv3LinkLsdbLsid.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3LinkLsdbIfIndex (1.3.6.1.2.1.191.1.5.1.1) |
not-accessible |
InterfaceIndex |
Integer32(1..2147483647) |
Interface index. |
As per the MIB. |
ospfv3LinkLsdbIfInstId (1.3.6.1.2.1.191.1.5.1.2) |
not-accessible |
Ospfv3IfInstIdTC |
Unsigned32(0..255) |
Instance ID. |
As per the MIB. |
ospfv3LinkLsdbType (1.3.6.1.2.1.191.1.5.1.3) |
not-accessible |
Unsigned32 |
LSA type. |
As per the MIB. |
ospfv3LinkLsdbRouterId (1.3.6.1.2.1.191.1.5.1.4) |
not-accessible |
Ospfv3RouterIdTC |
As per the MIB. |
ospfv3LinkLsdbLsid (1.3.6.1.2.1.191.1.5.1.5) |
not-accessible |
Ospfv3LsIdTC |
LS ID. |
As per the MIB. |
ospfv3LinkLsdbSequence (1.3.6.1.2.1.191.1.5.1.6) |
read-only |
Integer32 |
As per the MIB. |
ospfv3LinkLsdbAge (1.3.6.1.2.1.191.1.5.1.7) |
read-only |
Ospfv3LsaAgeTC |
LSA age. |
As per the MIB. |
ospfv3LinkLsdbChecksum (1.3.6.1.2.1.191.1.5.1.8) |
read-only |
Integer32 |
Checksum. |
As per the MIB. |
ospfv3LinkLsdbAdvertisement (1.3.6.1.2.1.191.1.5.1.9) |
read-only |
OCTET STRING |
As per the MIB. |
ospfv3LinkLsdbTypeKnown (1.3.6.1.2.1.191.1.5.1.10) |
read-only |
TruthValue |
true(1), false(2) |
As per the MIB. |
ospfv3HostTable
About this table
This table contains host route information (not supported in the current software version).
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are ospfv3HostAddressType and ospfv3HostAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3HostAddressType (1.3.6.1.2.1.191.1.6.1.1) |
not-accessible |
InetAddressType |
unknown(0), ipv4(1), ipv6(2), ipv4z(3), ipv6z(4), dns(16) |
Host route address type. |
Not supported |
ospfv3HostAddress (1.3.6.1.2.1.191.1.6.1.2) |
not-accessible |
InetAddress |
OCTET STRING(0..255) |
Host route address. |
Not supported |
ospfv3HostMetric (1.3.6.1.2.1.191.1.6.1.3) |
read-create |
Metric |
Integer32(0..'FFFF'h) |
Host route cost. |
Not supported |
ospfv3HostAreaID (1.3.6.1.2.1.191.1.6.1.5) |
read-create |
Ospfv3AreaIdTC |
ID of the area to which the host route belongs. |
Not supported |
ospfv3IfTable
About this table
This table contains OSPFv3 interface information.
Read:Supported
Columns
The table indexes are ospfv3IfIndex and ospfv3IfInstId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3IfIndex (1.3.6.1.2.1.191.1.7.1.1) |
not-accessible |
InterfaceIndex |
Interface index. |
As per the MIB. |
ospfv3IfInstId (1.3.6.1.2.1.191.1.7.1.2) |
not-accessible |
Ospfv3IfInstIdTC |
Interface instance ID. |
As per the MIB. |
ospfv3IfAreaId (1.3.6.1.2.1.191.1.7.1.3) |
read-create |
Ospfv3AreaIdTC |
Area ID. |
ospfv3IfType (1.3.6.1.2.1.191.1.7.1.4) |
read-create |
INTEGER |
broadcast(1), nbma(2), pointToPoint(3), pointToMultipoint(5) |
Interface type. |
Supports read and write operations. Loopback interfaces do not support the write operation. |
ospfv3IfAdminStatus (1.3.6.1.2.1.191.1.7.1.5) |
read-create |
Status |
Administrative state of the interface. |
ospfv3IfRtrPriority (1.3.6.1.2.1.191.1.7.1.6) |
read-create |
DesignatedRouterPriority |
Integer32(0..'FF'h) |
DR priority of the interface. |
ospfv3IfTransitDelay (1.3.6.1.2.1.191.1.7.1.7) |
read-create |
LSA transmission delay. |
Supports read and write operations. Loopback interfaces do not support the write operation. Value range: 1 to 1800. |
ospfv3IfRetransInterval (1.3.6.1.2.1.191.1.7.1.8) |
read-create |
Retransmission interval of the interface. |
ospfv3IfHelloInterval (1.3.6.1.2.1.191.1.7.1.9) |
read-create |
HelloRange |
Integer32(1..'FFFF'h) |
Hello interval of the interface. |
ospfv3IfRtrDeadInterval (1.3.6.1.2.1.191.1.7.1.10) |
read-create |
Ospfv3DeadIntervalRangeTC |
Dead interval. |
Supports read and write operations. Loopback interfaces do not support the write operation. When the value of ospfv3IfRtrDeadInterval is larger than 65535, this object returns 65535. |
ospfv3IfPollInterval (1.3.6.1.2.1.191.1.7.1.11) |
read-create |
Unsigned32 |
Poll interval. |
Supports read and write operations. Value range: 1 to 65535. Loopback interfaces do not support the write operation. |
ospfv3IfState (1.3.6.1.2.1.191.1.7.1.12) |
read-only |
INTEGER |
down(1), loopback(2), waiting(3), pointToPoint(4), designatedRouter(5), backupDesignatedRouter(6), otherDesignatedRouter(7), standby(8) |
Interface state. |
As per the MIB. |
ospfv3IfDesignatedRouter (1.3.6.1.2.1.191.1.7.1.13) |
read-only |
Ospfv3RouterIdTC |
DR address. |
As per the MIB. |
ospfv3IfBackupDesignatedRouter (1.3.6.1.2.1.191.1.7.1.14) |
read-only |
Ospfv3RouterIdTC |
BDR address. |
As per the MIB. |
ospfv3IfEvents(1.3.6.1.2.1.191.1.7.1.15) |
read-only |
Counter32 |
Number of interface state changes. |
As per the MIB. |
ospfv3IfRowStatus (1.3.6.1.2.1.191.1.7.1.16) |
read-create |
RowStatus |
Row status. |
ospfv3IfDemand (1.3.6.1.2.1.191.1.7.1.17) |
read-create |
TruthValue |
true(1), false(2) |
Whether the interface performs demand routing. |
ospfv3IfMetricValue (1.3.6.1.2.1.191.1.7.1.18) |
read-create |
Metric |
Interface cost. |
Supports read and write operations. Value range for loopback interfaces: 0 to 65535. Value range for other interfaces: 1 to 65535. |
ospfv3IfLinkScopeLsaCount (1.3.6.1.2.1.191.1.7.1.19) |
read-only |
Gauge32 |
Number of link-scope LSAs. |
As per the MIB. |
ospfv3IfLinkLsaCksumSum (1.3.6.1.2.1.191.1.7.1.20) |
read-only |
Unsigned32 |
LSA checksum. |
As per the MIB. |
ospfv3IfDemandNbrProbe (1.3.6.1.2.1.191.1.7.1.21) |
read-create |
TruthValue |
true(1), false(2) |
Whether neighbor probing is enabled. |
ospfv3IfDemandNbrProbeRetransLimit (1.3.6.1.2.1.191.1.7.1.22) |
read-create |
Unsigned32 |
Number of neighbor probing times. |
ospfv3IfDemandNbrProbeInterval (1.3.6.1.2.1.191.1.7.1.23) |
read-create |
Unsigned32 |
Neighbor probing interval. |
ospfv3IfTEDisabled (1.3.6.1.2.1.191.1.7.1.24) |
read-create |
TruthValue |
true(1), false(2) |
Whether TE is enabled on the interface. |
Supports only the read operation. The value is fixed at false(2). |
ospfv3IfLinkLSASuppression (1.3.6.1.2.1.191.1.7.1.25) |
read-create |
TruthValue |
true(1), false(2) |
Whether LSA suppression is enabled. |
ospfv3VirtIfTable
About this table
This table contains OSPFv3 virtual interface information.
Read:Supported
Columns
The table indexes are ospfv3VirtIfAreaId and ospfv3VirtIfNeighbor.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3VirtIfAreaId (1.3.6.1.2.1.191.1.8.1.1) |
not-accessible |
Ospfv3AreaIdTC |
ID of the area to which the virtual interface belongs. |
As per the MIB. |
ospfv3VirtIfNeighbor (1.3.6.1.2.1.191.1.8.1.2) |
not-accessible |
Ospfv3RouterIdTC |
Router ID of the virtual neighbor. |
As per the MIB. |
ospfv3VirtIfIndex (1.3.6.1.2.1.191.1.8.1.3) |
read-only |
InterfaceIndex |
Virtual interface index. |
As per the MIB. |
ospfv3VirtIfInstId (1.3.6.1.2.1.191.1.8.1.4) |
read-only |
Ospfv3IfInstIdTC |
Virtual interface instance ID. |
As per the MIB. |
ospfv3VirtIfTransitDelay (1.3.6.1.2.1.191.1.8.1.5) |
read-create |
Transmission delay of the virtual interface. |
Supports read and write operations. Value range: 1 to 1800. |
ospfv3VirtIfRetransInterval (1.3.6.1.2.1.191.1.8.1.6) |
read-create |
Retransmission interval of the virtual interface. |
ospfv3VirtIfHelloInterval (1.3.6.1.2.1.191.1.8.1.7) |
read-create |
HelloRange |
Hello interval of the virtual interface. |
Supports read and write operations. Value range: 1 to 8192. |
ospfv3VirtIfRtrDeadInterval (1.3.6.1.2.1.191.1.8.1.8) |
read-create |
Dead interval of the virtual interface. |
Supports read and write operations. Default: 40. Value range: 1 to 32768. |
ospfv3VirtIfState (1.3.6.1.2.1.191.1.8.1.9) |
read-only |
INTEGER |
down(1), pointToPoint(4) |
Virtual interface state. |
As per the MIB. |
ospfv3VirtIfEvents (1.3.6.1.2.1.191.1.8.1.10) |
read-only |
Counter32 |
Number of virtual interface state changes. |
As per the MIB. |
ospfv3VirtIfRowStatus (1.3.6.1.2.1.191.1.8.1.11) |
read-create |
RowStatus |
Row status. |
ospfv3VirtIfLinkScopeLsaCount (1.3.6.1.2.1.191.1.8.1.12) |
read-only |
Gauge32 |
Number of link LSAs on the virtual interface. |
As per the MIB. |
ospfv3VirtIfLinkLsaCksumSum (1.3.6.1.2.1.191.1.8.1.13) |
read-only |
Unsigned32 |
Sum of checksums in link-scope LSAs. |
As per the MIB. |
ospfv3NbrTable
About this table
This table contains OSPFv3 neighbor information.
Read:Supported
Columns
The table indexes are ospfv3NbrIfIndex, ospfv3NbrIfInstId, and ospfv3NbrRtrId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3NbrIfIndex (1.3.6.1.2.1.191.1.9.1.1) |
not-accessible |
InterfaceIndex |
Egress interface index. |
As per the MIB. |
ospfv3NbrIfInstId (1.3.6.1.2.1.191.1.9.1.2) |
not-accessible |
Ospfv3IfInstIdTC |
Egress interface instance ID. |
As per the MIB. |
ospfv3NbrRtrId (1.3.6.1.2.1.191.1.9.1.3) |
not-accessible |
Ospfv3RouterIdTC |
Router ID of the neighbor. |
As per the MIB. |
ospfv3NbrAddressType (1.3.6.1.2.1.191.1.9.1.4) |
read-only |
InetAddressType |
Neighbor address type. |
As per the MIB. |
ospfv3NbrAddress (1.3.6.1.2.1.191.1.9.1.5) |
read-only |
InetAddress |
Neighbor address. |
As per the MIB. |
ospfv3NbrOptions (1.3.6.1.2.1.191.1.9.1.6) |
read-only |
Integer32 |
Priority of the neighbor. |
As per the MIB. |
ospfv3NbrPriority (1.3.6.1.2.1.191.1.9.1.7) |
read-only |
Option field of the neighbor. |
As per the MIB. |
ospfv3NbrState (1.3.6.1.2.1.191.1.9.1.8) |
read-only |
INTEGER |
down(1), attempt(2), init(3), twoWay(4), exchangeStart(5), exchange(6), loading(7), full(8) |
Neighbor state. |
As per the MIB. |
ospfv3NbrEvents (1.3.6.1.2.1.191.1.9.1.9) |
read-only |
Counter32 |
Number of neighbor state changes. |
As per the MIB. |
ospfv3NbrLsRetransQLen (1.3.6.1.2.1.191.1.9.1.10) |
read-only |
Gauge32 |
Retransmission queue length. |
As per the MIB. |
ospfv3NbrHelloSuppressed (1.3.6.1.2.1.191.1.9.1.11) |
read-only |
TruthValue |
true(1), false(2) |
Whether hello packets are being suppressed to the neighbor. |
As per the MIB. |
ospfv3NbrIfId (1.3.6.1.2.1.191.1.9.1.12) |
read-only |
InterfaceIndex |
Neighbor interface ID. |
As per the MIB. |
ospfv3NbrRestartHelperStatus (1.3.6.1.2.1.191.1.9.1.13) |
read-only |
INTEGER |
notHelping(1), helping(2) |
Whether the router is acting as a GR helper for the neighbor. |
As per the MIB. |
ospfv3NbrRestartHelperAge (1.3.6.1.2.1.191.1.9.1.14) |
read-only |
Remaining time of the GR interval when the router is acting as a GR helper for the neighbor. |
As per the MIB. |
ospfv3NbrRestartHelperExitReason (1.3.6.1.2.1.191.1.9.1.15) |
read-only |
INTEGER |
none(1), inProgress(2), completed(3), timedOut(4), topologyChanged(5) |
GR helper exit reason. |
As per the MIB. |
ospfv3CfgNbrTable
About this table
Read:Supported
Columns
The table indexes are ospfv3CfgNbrIfIndex, ospfv3CfgNbrIfInstId, ospfv3CfgNbrAddressType, and ospfv3CfgNbrAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3CfgNbrIfIndex (1.3.6.1.2.1.191.1.10.1.1) |
not-accessible |
InterfaceIndex |
Configured neighbor interface index. |
As per the MIB. |
ospfv3CfgNbrIfInstId (1.3.6.1.2.1.191.1.10.1.2) |
not-accessible |
Ospfv3IfInstIdTC |
Configured neighbor interface instance ID. |
As per the MIB. |
ospfv3CfgNbrAddressType (1.3.6.1.2.1.191.1.10.1.3) |
not-accessible |
InetAddressType |
Configured neighbor address type. |
As per the MIB. |
ospfv3CfgNbrAddress (1.3.6.1.2.1.191.1.10.1.4) |
not-accessible |
InetAddress |
Configured neighbor address. |
As per the MIB. |
ospfv3CfgNbrPriority (1.3.6.1.2.1.191.1.10.1.5) |
read-create |
Configured neighbor priority. |
Supports read and write operations. Only neighbors on an NBMA network support the write operation. |
ospfv3CfgNbrRowStatus (1.3.6.1.2.1.191.1.10.1.6) |
read-create |
RowStatus |
Row status. |
ospfv3VirtNbrTable
About this table
This table contains OSPFv3 virtual neighbor information.
Read:Supported
Columns
The table indexes are ospfv3VirtNbrArea and ospfv3VirtNbrRtrId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3VirtNbrArea (1.3.6.1.2.1.191.1.11.1.1) |
not-accessible |
Ospfv3AreaIdTC |
Area to which the virtual neighbor belongs. |
As per the MIB. |
ospfv3VirtNbrRtrId (1.3.6.1.2.1.191.1.11.1.2) |
not-accessible |
Ospfv3RouterIdTC |
As per the MIB. |
ospfv3VirtNbrIfIndex (1.3.6.1.2.1.191.1.11.1.3) |
read-only |
InterfaceIndex |
As per the MIB. |
ospfv3VirtNbrIfInstId (1.3.6.1.2.1.191.1.11.1.4) |
read-only |
Ospfv3IfInstIdTC |
As per the MIB. |
ospfv3VirtNbrAddressType (1.3.6.1.2.1.191.1.11.1.5) |
read-only |
InetAddressType |
Virtual neighbor address type. |
As per the MIB. |
ospfv3VirtNbrAddress (1.3.6.1.2.1.191.1.11.1.6) |
read-only |
InetAddress |
Virtual neighbor address. |
As per the MIB. |
ospfv3VirtNbrOptions (1.3.6.1.2.1.191.1.11.1.7) |
read-only |
Integer32 |
Option field of the virtual neighbor. |
As per the MIB. |
ospfv3VirtNbrState (1.3.6.1.2.1.191.1.11.1.8) |
read-only |
INTEGER |
State of the virtual neighbor. |
As per the MIB. |
ospfv3VirtNbrEvents (1.3.6.1.2.1.191.1.11.1.9) |
read-only |
Counter32 |
Number of virtual neighbor state changes. |
As per the MIB. |
ospfv3VirtNbrLsRetransQLen(1.3.6.1.2.1.191.1.11.1.10) |
read-only |
Gauge32 |
As per the MIB. |
ospfv3VirtNbrHelloSuppressed (1.3.6.1.2.1.191.1.11.1.11) |
read-only |
TruthValue |
true(1), false(2) |
Whether hello packets are being suppressed to the virtual neighbor. |
As per the MIB. |
ospfv3VirtNbrIfId (1.3.6.1.2.1.191.1.11.1.12) |
read-only |
InterfaceIndex |
As per the MIB. |
ospfv3VirtNbrRestartHelperStatus (1.3.6.1.2.1.191.1.11.1.13) |
read-only |
INTEGER |
Whether the router is acting as a GR helper for the virtual neighbor. |
As per the MIB. |
ospfv3VirtNbrRestartHelperAge (1.3.6.1.2.1.191.1.11.1.14) |
read-only |
Remaining time of the GR interval when the router is acting as a GR helper for the virtual neighbor. |
As per the MIB. |
ospfv3VirtNbrRestartHelperExitReason (1.3.6.1.2.1.191.1.11.1.15) |
read-only |
INTEGER |
As per the MIB. |
ospfv3AreaAggregateTable
About this table
This table contains information about configured OSPFv3 summary routes.
Read:Supported
Columns
The table indexes are ospfv3AreaAggregateAreaID, ospfv3AreaAggregateAreaLsdbType, ospfv3AreaAggregatePrefixType, ospfv3AreaAggregatePrefix, and ospfv3AreaAggregatePrefixLength.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3AreaAggregateAreaID (1.3.6.1.2.1.191.1.12.1.1) |
not-accessible |
Ospfv3AreaIdTC |
Area where the summary route resides. |
As per the MIB. |
ospfv3AreaAggregateAreaLsdbType (1.3.6.1.2.1.191.1.12.1.2) |
not-accessible |
INTEGER |
interAreaPrefixLsa(8195), nssaExternalLsa(8199) |
LSA type. |
As per the MIB. |
ospfv3AreaAggregatePrefixType (1.3.6.1.2.1.191.1.12.1.3) |
not-accessible |
InetAddressType |
Summary network address type. |
As per the MIB. |
ospfv3AreaAggregatePrefix (1.3.6.1.2.1.191.1.12.1.4) |
not-accessible |
InetAddress |
OCTET STRING(0..16) |
Summary network address. |
As per the MIB. |
ospfv3AreaAggregatePrefixLength (1.3.6.1.2.1.191.1.12.1.5) |
not-accessible |
InetAddressPrefixLength |
Unsigned32(3..128) |
Summary network address length. |
As per the MIB. |
ospfv3AreaAggregateRowStatus (1.3.6.1.2.1.191.1.12.1.6) |
read-create |
RowStatus |
Row status. |
ospfv3AreaAggregateEffect (1.3.6.1.2.1.191.1.12.1.7) |
read-create |
INTEGER |
advertiseMatching(1), doNotAdvertiseMatching(2) |
Whether subnets are included in the summary route. |
ospfv3AreaAggregateRouteTag (1.3.6.1.2.1.191.1.12.1.8) |
read-create |
Unsigned32 |
Tag information. |
ospfv3VirtLinkLsdbTable
About this table
This table contains OSPFv3 link-scope LSDB information.
Read:Supported
Columns
The table indexes are ospfv3VirtLinkLsdbIfAreaId, ospfv3VirtLinkLsdbIfNeighbor, ospfv3VirtLinkLsdbType, ospfv3VirtLinkLsdbRouterId, and ospfv3VirtLinkLsdbLsid.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3VirtLinkLsdbIfAreaId (1.3.6.1.2.1.191.1.13.1.1) |
not-accessible |
Ospfv3AreaIdTC |
ID of the area to which the virtual link belongs. |
As per the MIB. |
ospfv3VirtLinkLsdbIfNeighbor(1.3.6.1.2.1.191.1.13.1.2) |
not-accessible |
Ospfv3RouterIdTC |
As per the MIB. |
ospfv3VirtLinkLsdbType (1.3.6.1.2.1.191.1.13.1.3) |
not-accessible |
Unsigned32 |
LSA type. |
As per the MIB. |
ospfv3VirtLinkLsdbRouterId (1.3.6.1.2.1.191.1.13.1.4) |
not-accessible |
Ospfv3RouterIdTC |
As per the MIB. |
ospfv3VirtLinkLsdbLsid (1.3.6.1.2.1.191.1.13.1.5) |
not-accessible |
Ospfv3LsIdTC |
LSA LS ID. |
As per the MIB. |
ospfv3VirtLinkLsdbSequence(1.3.6.1.2.1.191.1.13.1.6) |
read-only |
Integer32 |
As per the MIB. |
ospfv3VirtLinkLsdbAge (1.3.6.1.2.1.191.1.13.1.7) |
read-only |
Ospfv3LsaAgeTC |
LSA age. |
As per the MIB. |
ospfv3VirtLinkLsdbChecksum(1.3.6.1.2.1.191.1.13.1.8) |
read-only |
Integer32 |
LSA checksum information. |
As per the MIB. |
ospfv3VirtLinkLsdbAdvertisement (1.3.6.1.2.1.191.1.13.1.9) |
read-only |
OCTET STRING |
LSA advertisement content. |
As per the MIB. |
ospfv3VirtLinkLsdbTypeKnown (1.3.6.1.2.1.191.1.13.1.10) |
read-only |
TruthValue |
true(1), false(2) |
Whether the LSA type is known. |
As per the MIB. |
ospfv3NotificationEntry
About this table
This table contains information used for OSPFv3 notification generation.
Read:Supported
Columns
The table has no indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfv3ConfigErrorType (1.3.6.1.2.1.191.1.14.1) |
accessible-for-notify |
INTEGER |
badVersion(1), areaMismatch(2), unknownNbmaNbr(3), unknownVirtualNbr(4), helloIntervalMismatch(5), deadIntervalMismatch(6), optionMismatch(7), mtuMismatch(8), duplicateRouterId(9), noError(10) |
Type of the configuration error. |
As per the MIB. |
ospfv3PacketType (1.3.6.1.2.1.191.1.14.2) |
INTEGER |
hello(1), dbDescript(2), lsReq(3), lsUpdate(4), lsAck(5), nullPacket(6) |
Packet type. |
As per the MIB. |
ospfv3PacketSrc (1.3.6.1.2.1.191.1.14.3) |
InetAddressIPv6 |
Source address of the packet. |
As per the MIB. |
Notifications
ospfv3VirtIfStateChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.191.0.1 |
Virtual interface state changes. |
Informational |
Informational |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when the state of a virtual interface changes to Point-to-Point or changes from Point-to-Point to another state. To reduce unnecessary notifications caused by virtual interface up events, no virtual interface state change notification will be sent within 2 times the dead interval since the virtual interface state changes to a value other than DOWN.
This issue occurs when one of the following conditions exists:
The state of a virtual interface changes from P2P to Down, or from Down to P2P.
The router ID of a virtual link neighbor changes.
System impact
If the state of a virtual interface changes from Down to P2P, it has no negative impact on services.
If the state of a virtual interface changes from P2P to Down, the virtual interface will be disconnected and OSPFV3 route calculation will fail. Services might be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-state-change command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.191.1.1.1 (ospfv3RouterId) |
N/A |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.8.1.9 (ospfv3VirtIfState) |
ospfv3VirtIfAreaId ospfv3VirtIfNeighbor |
INTEGER |
Recommended action
To resolve this issue:
1.Use the display ospfv3 vlink command to view the state of the virtual interface.
- If the state of the virtual interface changes from Down to P2P, no action is required.
- If the state of the virtual interface changes from P2P to Down, proceed to step 2.
2.Use the display ospfv3 spf-tree command to identify whether the flags of the SPF node corresponding to the neighbor router ID of the virtual interface include the S flag. This flag indicates that the neighbor is reachable.
- If yes, check whether the virtual interface settings are configured correctly on both the local end and the remote end.
- If no, check for the cause of the unreachability.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3NbrStateChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.2 |
Neighbor state changes. |
Informational |
Informational |
N/A (N/A) |
ON |
For DR and BDR, this notification is generated when the state of a neighbor changes to FULL or changes from FULL to another state. For DRother, this notification is sent when the state of a neighbor changes to 2-way or changes from 2-way to another state.
To reduce unnecessary notifications caused by interface up events, no neighbor state change notification will be sent within 2 times the dead interval since the interface state changes to a value other than DOWN.
The state of a neighbor changes from Attempt or any other state to 1-Way or Down, or from Down or any other state to 2-Way or Full.
The local and remote ends have different interface settings (such as the hello timer, dead timer, and authentication settings).
OSPFv3 is restarted by the reset ospfv3 process command.
The state of a neighbor in an NBMA or broadcast network changes from Full to another state or changes from another state to Full.
System impact
The process of OSPFv3 neighbor establishment involves a series of neighbor state changes, including Down, Attempt, Init, 2-Way, ExStart, Exchange, Loading, and Full.
If the state of a neighbor progresses, it has no negative impact on services.
If the state of a neighbor regresses, services might be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 neighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 neighbor-state-change command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.9.1.8 (ospfv3NbrState) |
Neighbor state. |
ospfv3NbrIfIndex ospfv3NbrIfInstId ospfv3NbrRtrId |
INTEGER |
Recommended action
1.Use the display ospfv3 peer command to view the state of the neighbor. You can view the State field in the command output.
- If the neighbor state is Full, no action is required.
- If the neighbor state is not Full, proceed to step 2.
2.Use the display interface interface-type interface-number command to view the state of the neighbor-facing interface on the local end.
- If the interface is up, proceed to step 3.
- If the neighbor interface is down, check whether the shutdown command is executed on the interface.
If yes, execute the undo shutdown command on the interface, and then proceed to step 3.
If no, proceed to step 3.
3.Use the ping command to identify whether the IPv6 address of the remote interface is reachable.
- If yes, proceed to step 4.
- If no, proceed to step 6.
4.Use the display ospfv3 interface command to view the state of the OSPFv3 interface. You can view the State field in the command output.
- If the neighbor-facing interface is down, proceed to step 6.
- If the neighbor-facing interface is not down, proceed to step 5.
5.Use the display ospfv3 interface verbose command to check whether the local and remote ends use the same interface settings, including the hello timer, dead timer, poll timer, OSPFv3 network type, and authentication settings.
- If yes, proceed to step 6.
- If no, use the following commands to modify inconsistent interface settings and make sure that the local and remote ends use the same interface settings.
ospfv3 timer hello
ospfv3 timer dead
ospfv3 timer poll
ospfv3 network-type
ospfv3 authentication-mode
6.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3VirtNbrStateChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.3 |
Virtual neighbor state changes. |
Informational |
Informational |
N/A (N/A) |
ON |
This notification is generated when the state of a virtual neighbor changes to FULL or changes from FULL to another state. To reduce unnecessary notifications caused by virtual interface up events, no virtual neighbor state change notification will be sent within 2 times the dead interval since the virtual interface state changes to a value other than DOWN.
The state of a virtual neighbor regresses (for example, changing from Full to 1-Way or Down) or progresses to the final state (for example, Full).
The state of the physical interface on which the virtual link is established changes.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtneighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtneighbor-state-change command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.11.1.8 (ospfv3VirtNbrState) |
Virtual neighbor state. |
ospfv3VirtNbrArea ospfv3VirtNbrRtrId |
INTEGER |
Recommended action
1.Use the display ospfv3 interface and display ipv6 interface brief commands to view the state of the physical interface on which the virtual link is established.
- If the physical state of the interface is Down, check whether the interface has been shut down.
If yes, execute the undo shutdown command on the interface, and then proceed to step 2.
If no, proceed to step 2.
- If the link layer protocol state of the interface is Up, proceed to step 2.
2.Use the display ospfv3 peer command to view the state of the neighbor.
- If the State field displays Full, proceed to step 3.
- If the State field does not display Full, proceed to step 5.
3.Use the display ospfv3 spf-tree command to identify whether the flags of the SPF node corresponding to the neighbor router ID of the virtual interface include the S flag. This flag indicates that the neighbor is reachable.
- If no, proceed to step 5.
4.Use the display ospfv3 vlink and display current-configuration configuration ospfv3 commands to identify whether the local and remote ends use the same settings, such as the hello timer, dead timer, and poll timer.
- If yes, proceed to step 5.
- If no, use the vlink-peer command to configure the same settings for both the local and remote ends, and then check whether the notification is cleared.
If yes, the troubleshooting is complete.
5.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3IfConfigError
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.4 |
Interface configuration error. |
Informational |
Informational |
N/A (N/A) |
ON |
This notification is generated when a non-virtual interface receives a packet from another router with mismatched configuration. This issue occurs when one of the following conditions exists:
The local interface and the remote interface use different interface settings.
The link layer protocol changes.
System impact
This issue typically has no negative impact as long as the local interface and the remote interface use the same settings after configuration correction.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-cfg-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-cfg-error command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.7.1.12 (ospfv3IfState) |
Interface state. |
ospfv3IfIndex ospfv3IfInstId |
INTEGER |
1.3.6.1.2.1.191.1.14.3 (ospfv3PacketSrc) |
IPv6 packet that cannot be identified by a neighbor. |
N/A |
InetAddressIPv6 |
OCTET STRING (16) |
1.3.6.1.2.1.191.1.14.1 (ospfv3ConfigErrorType) |
OSPFv3 configuration error type. |
N/A |
INTEGER |
1.3.6.1.2.1.191.1.14.2 (ospfv3PacketType) |
OSPFv3 data packet type. |
N/A |
INTEGER |
Recommended action
1.Use the display ospfv3 interface interface-type interface-number command to identify whether the local OSPFv3 interface and the remote OSPFv3 interface use the same settings.
- If yes, proceed to step 3.
- If no, proceed to step 2.
2.Perform the following tasks to clear the notification:
Use the following commands to reconfigure the local or remote OSPFv3 interface, ensuring that the two interfaces use the same settings:
ospfv3 timer hello
ospfv3 timer dead
ospfv3 timer poll
Identify whether the notification is cleared:
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
ospfv3VirtIfConfigError
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.5 |
Virtual interface configuration error. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when an OSPFv3 virtual interface on a router receives a packet from another router with mismatched configuration. This issue occurs when the interface settings on the ends of a virtual link are not the same.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-cfg-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-cfg-error command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Ospfv3RouterIdTC |
INTEGER |
N/A |
INTEGER |
N/A |
INTEGER |
Recommended action
1.Use the display ospfv3 vlink and display current-configuration configuration ospfv3 commands to identify whether the two ends of the virtual link use the same interface settings.
2.Use the vlink-peer command to reconfigure an end of the virtual link, ensuring that the two ends of the virtual link use the same settings. Then, identify whether the notification is cleared:
- If yes, the troubleshooting is complete.
- If no, proceed to step 3.
ospfv3IfRxBadPacket
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.6 |
A non-virtual interface receives an error packet. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when a non-virtual interface receives an OSPFv3 packet that cannot be parsed. This issue occurs when one of the following conditions exists:
The length of the OSPFv3 packet is incorrect.
The OSPFv3 packet has content errors.
System impact
When a non-virtual interface receives an OSPFv3 packet that cannot be parsed, it discards the packet. If the packet is a hello packet, the neighbor that sends the packet might go down.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-bad-pkt command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-bad-pkt command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Ospfv3RouterIdTC |
Interface state. |
INTEGER |
IPv6 packet that cannot be identified by the neighbor. |
N/A |
InetAddressIPv6 |
OCTET STRING (16) |
N/A |
INTEGER |
Recommended action
Collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3VirtIfRxBadPacket
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.7 |
A virtual interface receives an error packet. |
Informational |
Informational |
N/A (N/A) |
ON |
This notification is generated when a virtual interface receives an OSPFv3 packet that cannot be parsed. This issue occurs when one of the following conditions exists:
System impact
When a virtual interface receives an OSPFv3 packet that cannot be parsed, it discards the packet. If the packet is a hello packet, the neighbor that sends the packet might go down.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-bad-pkt command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-bad-pkt command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Ospfv3RouterIdTC |
INTEGER |
N/A |
INTEGER |
Recommended action
ospfv3IfStateChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.10 |
Interface state changes. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the state of a non-virtual interface changes from DR to Down or changes to the Point-to-Point, DR, BDR, or DRother state. This issue occurs when one of the following conditions exists:
The physical interface comes up or goes down.
The router priority for the interface changes and DR/BDR election is performed.
System impact
This issue might affect the state of neighbors. If the state of an OSPFv3 interface regresses (for example, changing to Down), it will be disconnected from its neighbors.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-state-change command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Ospfv3RouterIdTC |
Interface state. |
INTEGER |
Recommended action
1.Use the display ospfv3 interface command to view the interface state.
- If the interface state is Down, proceed to step 2.
- If the interface state is not Down, no action is required.
2.Use the display interface interface-type interface-number command to view the state of the interface.
- If the interface is in up, proceed to step 3.
- If the interface is not up, check whether the interface has been shut down.
If yes, execute the undo shutdown command on the interface.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.11 |
A router's ability to translate type-7 LSAs into type-5 LSAs changes. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when a router's ability to translate OSPFv3 type-7 LSAs into OSPFv3 type-5 LSAs changes. This issue occurs when one of the following conditions exists:
The translate-always keyword of the nssa command is configured or canceled on an NSSA ABR.
An NSSA ABR has been configured with a new router ID and the change is already in effect.
The device becomes an ABR or its role changes from ABR to another.
System impact
When the translator in an NSSA area changes, the former translator must flush the Type-5 LSAs translated from Type-7 LSAs and the new translator translates new OSPFv3 type-7 LSAs into OSPFv3 type-5 LSAs. This might cause temporary AES route flapping.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 nssatranslator-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 nssatranslator-status-change command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.2.1.12 (ospfv3AreaNssaTranslatorState) |
Method for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs. |
ospfv3AreaId |
INTEGER |
Recommended action
1.If the nssa translate-always command is configured on the local device, use the display ospfv3 command to identify whether the 7/5 translator state field displays Enabled.
- If yes, no action is required.
- If no, proceed to step 7.
If the nssa translate-always command is canceled on the local device, use the display ospfv3 command to identify whether the 7/5 translator state field displays Disabled.
- If the 7/5 translator state field displays Disabled, proceed to step 2.
- If the 7/5 translator state field displays Elected, no action is required.
2.Use the display ospfv3 lsdb router command to identify whether the Options field in the router LSAs of an NSSA ABR contains the Nt bit.
3.If the local device has been configured with a new router ID and the change is already in effect, identify whether the NSSA translator role is correct after the network topology is stable.
- If no, proceed to step 4.
4.Identify whether other NSSA ABRs have been configured with new router IDs. After the network topology is stable, identify whether one of the new router IDs is larger than the local router ID.
5.If a new NSSA ABR has been added in the area, identify whether the router ID of the new NSSA ABR is larger than the local router ID after the network topology is stable.
If the new device is not an ABR, proceed to step 6.
6.Check whether the ospfv3NbrStateChange or ospfv3IfStateChange notification is generated on the local and neighbor devices.
- If yes, perform the recommended actions to clear the notification.
7.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3RestartStatusChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.12 |
GR restarter state changes. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the state of the GR restarter changes. This issue occurs when one of the following conditions exists:
The device stops GR.
The device starts GR.
System impact
If the state of the GR restarter changes due to a GR failure, this issue will affect services.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 grrestarter-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 grrestarter-status-change command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.1.18 (ospfv3RestartStatus) |
GR restarter state. |
N/A |
INTEGER |
1.3.6.1.2.1.191.1.1.16 (ospfv3RestartInterval) |
GR timeout interval. |
N/A |
1.3.6.1.2.1.191.1.1.20 (ospfv3RestartExitReason) |
Reason why the device exited GR restarter state. |
N/A |
INTEGER |
Recommended action
1.If you are manually performing an active/standby switchover or restarting the OSPFv3 process with GR, no action is required. Otherwise, proceed to step 2.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.13 |
The GR helper state of a neighbor changes. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the GR helper state of a neighbor changes. This issue occurs when one of the following conditions exists:
The neighbor becomes the GR helper.
The neighbor stops being the GR helper.
System impact
If the GR helper state of a neighbor changes due to a GR failure, this issue will affect services.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 grhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 grhelper-status-change command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.9.1.13 (ospfv3NbrRestartHelperStatus) |
GR helper state of the neighbor. |
INTEGER |
1.3.6.1.2.1.191.1.9.1.14 (ospfv3NbrRestartHelperAge) |
GR helper aging timer. |
1.3.6.1.2.1.191.1.9.1.15 (ospfv3NbrRestartHelperExitReason) |
Reason why the neighbor exited GR helper state. |
INTEGER |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.191.0.14 |
The GR helper state of a virtual neighbor changes. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the GR helper state of a virtual neighbor changes. This issue occurs when one of the following conditions exists:
The virtual neighbor becomes the GR helper.
The virtual neighbor stops being the GR helper.
System impact
If the GR helper state of a virtual neighbor changes due to a GR failure, this issue will affect services.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtgrhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtgrhelper-status-change command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Ospfv3RouterIdTC |
1.3.6.1.2.1.191.1.11.1.13 (ospfv3VirtNbrRestartHelperStatus) |
GR helper state of the virtual neighbor. |
INTEGER |
1.3.6.1.2.1.191.1.11.1.14 (ospfv3VirtNbrRestartHelperAge) |
1.3.6.1.2.1.191.1.11.1.15 (ospfv3VirtNbrRestartHelperExitReason) |
Reason why the virtual neighbor exited GR helper state. |
INTEGER |
Recommended action
