05-HH3C-ISIS-MIB | 83.41 KB |
HH3C-ISIS-MIB
About this MIB
Use this MIB to obtain all IS-IS process IDs.
MIB file name
hh3c-isis.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIsis(59)
Tabular objects
hh3cIsisSysTable
About this table
This table displays all IS-IS process IDs.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cIsisSysInstance.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIsisSysInstance (1.3.6.1.4.1.25506.2.59.1.1.1.1.1) |
read-only |
Integer32 |
Integer32 (1..65535) |
IS-IS process ID. |
As per the MIB. |
hh3cIsisCircTable
About this table
This table contains information about all interfaces enabled with IS-IS.
Read:Supported
Columns
The table index is hh3cIsisSysInstance and hh3cIsisCircIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIsisCircIndex (1.3.6.1.4.1.25506.2.59.1.3.1.1.1) |
not-accessible |
Unsigned32 |
Unsigned32(1..100) |
Interface index node. |
As per the MIB. |
hh3cIsisCircIfIndex (1.3.6.1.4.1.25506.2.59.1.3.1.1.2) |
read-only |
Integer32 |
As per the MIB. |
Notifications
hh3cIsisSystemIdConflict
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.59.0.2 |
System ID conflict. |
Informational |
Warning |
ON |
Notification triggers
This notification is generated when a system ID conflict is detected in a received LSP.
The SNMP agent generates this notification only when it detects more than five system ID conflicts within two minutes. This can prevent the agent from generating too many hh3cIsisSystemIdConflict notifications within a short time.
System impact
The LSP might be continuously refreshed, resulting in route flapping.
Status control
ON
CLI: Use the snmp-agent trap enable isis system-id-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable isis system-id-conflict command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.59.1.1.1.1.1 (hh3cIsisSysInstance) |
IS-IS process ID. |
hh3cIsisSysInstance, hh3cIsisCircIndex |
Integer32 |
1.3.6.1.2.1.138.1.10.1.1 (isisNotificationSysLevelIndex) |
System level index. |
N/A |
IsisLevel |
level1(1), level2(2), level1and2(3) |
1.3.6.1.2.1.138.1.10.1.3 (isisPduLspId) |
LSP ID. |
N/A |
IsisLinkStatePDUID |
OCTET STRING (8) |
1.3.6.1.2.1.138.1.1.1.3 (isisSysID) |
System ID. |
N/A |
IsisSystemID |
OCTET STRING (6) |
1.3.6.1.2.1.138.1.10.1.2 (isisNotificationCircIfIndex) |
Interface index. |
N/A |
Unsigned32 |
Unsigned32(1..2147483647) |
1.3.6.1.2.1.31.1.1.1.1 (ifName) |
Interface name. |
ifIndex |
DisplayString |
OCTET STRING(0..255) |
1.3.6.1.4.1.25506.2.59.1.2.1.3 (hh3cIsisLocalAddressType) |
Local IP address type. |
N/A |
InetAddressType |
unknown(0),, ipv4(1),, ipv6(2),, ipv4z(3),, ipv6z(4),, dns(16) |
1.3.6.1.4.1.25506.2.59.1.2.1.4 (hh3cIsisLocalAddress) |
Local IP address. |
N/A |
InetAddress |
OCTET STRING(0..16) |
1.3.6.1.4.1.25506.2.59.1.2.1.5 (hh3cIsisPeerAddressType) |
Neighbor IP address type. |
N/A |
InetAddressType |
1.3.6.1.4.1.25506.2.59.1.2.1.6 (hh3cIsisPeerAddress) |
Neighbor IP address. |
N/A |
InetAddress |
Recommended action
To resolve the issue:
1.Locate and edit the conflicting system ID to make sure that each device in the IS-IS topology has a unique system ID.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
