11-OSPF-MIB | 329.80 KB |
ospfRouterId (1.3.6.1.2.1.14.1.1)
ospfAdminStat (1.3.6.1.2.1.14.1.2)
ospfVersionNumber (1.3.6.1.2.1.14.1.3)
ospfAreaBdrRtrStatus (1.3.6.1.2.1.14.1.4)
ospfASBdrRtrStatus (1.3.6.1.2.1.14.1.5)
ospfExternLsaCount (1.3.6.1.2.1.14.1.6)
ospfExternLsaCksumSum (1.3.6.1.2.1.14.1.7)
ospfTOSSupport (1.3.6.1.2.1.14.1.8)
ospfOriginateNewLsas (1.3.6.1.2.1.14.1.9)
ospfRxNewLsas (1.3.6.1.2.1.14.1.10)
ospfExtLsdbLimit (1.3.6.1.2.1.14.1.11)
ospfMulticastExtensions (1.3.6.1.2.1.14.1.12)
ospfExitOverflowInterval (1.3.6.1.2.1.14.1.13)
ospfDemandExtensions (1.3.6.1.2.1.14.1.14)
ospfStubRouterAdvertisement(1.3.6.1.2.1.14.1.27)
OSPF-MIB
About this MIB
This document contains MIB and Trap features compliant with RFC 4750.
MIB file name
rfc4750-ospf.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ospf(14)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfRouterId (1.3.6.1.2.1.14.1.1) |
read-write |
RouterID |
OCTET STRING (4) |
Router ID that uniquely identifies a router in an AS. |
Supports only the read operation. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfAdminStat (1.3.6.1.2.1.14.1.2) |
read-write |
Status |
INTEGER{ enabled(1), disabled(2) } |
OSPF administrative state of the router. Enabled indicates at least one OSPF interface exists. Disabled indicates no OSPF interface exists. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfVersionNumber (1.3.6.1.2.1.14.1.3) |
read-only |
INTEGER |
version2 (2) |
Version number (2). |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfAreaBdrRtrStatus (1.3.6.1.2.1.14.1.4) |
read-only |
TruthValue |
true(1), false(2) |
Whether the router is an ABR. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfASBdrRtrStatus (1.3.6.1.2.1.14.1.5) |
read-write |
TruthValue |
true(1), false(2) |
Whether the router is an ASBR. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfExternLsaCount (1.3.6.1.2.1.14.1.6) |
read-only |
Gauge32 |
INTEGER(0..4294967295) |
Number of Type-5 LSAs. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfExternLsaCksumSum (1.3.6.1.2.1.14.1.7) |
read-only |
Integer32 |
Standard MIB values. |
Sum of checksums in Type-5 LSAs. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfTOSSupport (1.3.6.1.2.1.14.1.8) |
read-write |
TruthValue |
true(1), false(2) |
Whether ToS is supported. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfOriginateNewLsas (1.3.6.1.2.1.14.1.9) |
read-only |
Counter32 |
Number of new LSAs that have been originated. This number is incremented each time the router originates a new LSA. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfRxNewLsas (1.3.6.1.2.1.14.1.10) |
read-only |
Counter32 |
Number of newly received LSAs, excluding self-originated LSAs. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfExtLsdbLimit (1.3.6.1.2.1.14.1.11) |
read-write |
Integer32 |
Integer32(-1..'7FFFFFFF'h) |
Maximum number of non-default ASEs in the LSDB. A value of -1 indicates no limit. |
The value takes -1, or is in the range of 1 to 1000000. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfMulticastExtensions (1.3.6.1.2.1.14.1.12) |
read-write |
Integer32 |
Whether the router is multicast capable. Bit 0 indicates intra-area multicast; bit 1 indicates inter-area multicast; bit 2 indicates inter-AS multicast. The value can be 0, 1, 3, 5, and 7. The default value is 0. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfExitOverflowInterval (1.3.6.1.2.1.14.1.13) |
read-write |
PositiveInteger |
Integer32(0..'7FFFFFFF'h) |
Time that the router takes to leave the OverflowState. 0 indicates the router does not leave the OverflowState until it is restarted. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfDemandExtensions (1.3.6.1.2.1.14.1.14) |
read-write |
TruthValue |
true(1), false(2) |
Support for demand routing. |
ospfRFC1583Compatibility
(1.3.6.1.2.1.14.1.15)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfRFC1583Compatibility (1.3.6.1.2.1.14.1.15) |
read-write |
TruthValue |
true(1), false(2) |
Compatibility with RFC 1583. When compatibility is enabled, only cost will be used when choosing among multiple ASE LSAs advertising the same destination. When compatibility is disabled, preference will be used first. |
As per the MIB. |
ospfOpaqueLsaSupport
(1.3.6.1.2.1.14.1.16)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfOpaqueLsaSupport (1.3.6.1.2.1.14.1.16) |
read-only |
TruthValue |
true(1), false(2) |
Support for Opaque LSAs. |
As per the MIB. |
ospfReferenceBandwidth
(1.3.6.1.2.1.14.1.17)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfReferenceBandwidth (1.3.6.1.2.1.14.1.17) |
read-write |
Unsigned32 |
Reference bandwidth in Kb/s for calculating the interface cost. |
When the value is divided by 1000, the decimal number will be ignored. |
ospfRestartSupport
(1.3.6.1.2.1.14.1.18)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfRestartSupport (1.3.6.1.2.1.14.1.18) |
read-write |
INTEGER |
none (1), plannedOnly (2), plannedAndUnplanned (3) |
Support for GR. |
If the value changes from 1 to 2 or 3, IETF GR is supported. If the value changes between 2 and 3, the original GR type remains unchanged. |
ospfRestartInterval
(1.3.6.1.2.1.14.1.19)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfRestartInterval (1.3.6.1.2.1.14.1.19) |
read-write |
Integer32 |
Integer32(1..1800) |
Graceful restart timeout interval. |
Value range: 40 to 1800. |
ospfRestartStrictLsaChecking
(1.3.6.1.2.1.14.1.20)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfRestartStrictLsaChecking (1.3.6.1.2.1.14.1.20) |
read-write |
TruthValue |
true(1), false(2) |
Whether the strict LSA checking capability is enabled for GR. |
As per the MIB. |
ospfRestartStatus
(1.3.6.1.2.1.14.1.21)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfRestartStatus (1.3.6.1.2.1.14.1.21) |
read-only |
INTEGER |
notRestarting (1), plannedRestart (2), unplannedRestart (3) |
Graceful restart state. |
As per the MIB. |
ospfRestartAge
(1.3.6.1.2.1.14.1.22)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfRestartAge (1.3.6.1.2.1.14.1.22) |
read-only |
Unsigned32 |
Remaining time for the current graceful restart |
As per the MIB. |
ospfRestartExitReason
(1.3.6.1.2.1.14.1.23)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfRestartExitReason (1.3.6.1.2.1.14.1.23) |
read-only |
INTEGER |
none (1), inProgress (2), completed (3), timedOut (4), topologyChanged (5) |
GR exit reason. |
As per the MIB. |
ospfAsLsaCount
(1.3.6.1.2.1.14.1.24)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfAsLsaCount (1.3.6.1.2.1.14.1.24) |
read-only |
Gauge32 |
Number of AS-scope LSAs. |
As per the MIB. |
ospfAsLsaCksumSum
(1.3.6.1.2.1.14.1.25)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfAsLsaCksumSum (1.3.6.1.2.1.14.1.25) |
read-only |
Unsigned32 |
Sum of AS-scope LSA checksums. |
As per the MIB. |
ospfStubRouterSupport
(1.3.6.1.2.1.14.1.26)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfStubRouterSupport (1.3.6.1.2.1.14.1.26) |
read-only |
TruthValue |
true(1), false(2) |
Support for stub router. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfStubRouterAdvertisement(1.3.6.1.2.1.14.1.27) |
read-write |
INTEGER |
doNotAdvertise (1), advertise(2) |
Whether to advertise stub router LSAs. |
As per the MIB. |
ospfDiscontinuityTime
(1.3.6.1.2.1.14.1.28)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfDiscontinuityTime (1.3.6.1.2.1.14.1.28) |
read-only |
TimeStamp |
TimeTicks |
Most recent system startup time. |
As per the MIB. |
Tabular objects
ospfAreaTable
About this table
This table contains parameter and statistics information about each area on the device.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table index is ospfAreaId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfAreaId (1.3.6.1.2.1.14.2.1.1) |
read-only |
AreaID |
OCTET STRING (4) |
Area ID, a 32-bit integer that uniquely identifies an area. |
As per the MIB. |
ospfAuthType (1.3.6.1.2.1.14.2.1.2) |
read-create |
OspfAuthenticationType |
none (0), simplePassword (1), md5 (2) |
Authentication type. |
ospfImportAsExtern (1.3.6.1.2.1.14.2.1.3) |
read-create |
INTEGER |
importExternal(1), importNoExternal (2), importNssa (3) |
Area type, stub, NSSA, or common area. |
ospfSpfRuns (1.3.6.1.2.1.14.2.1.4) |
read-only |
Counter32 |
Time of route calculations in the area. |
As per the MIB. |
ospfAreaBdrRtrCount (1.3.6.1.2.1.14.2.1.5) |
read-only |
Gauge32 |
Number of reachable ABRs in the area. |
As per the MIB. |
ospfAsBdrRtrCount (1.3.6.1.2.1.14.2.1.6) |
read-only |
Gauge32 |
Number of reachable ASBRs in the area. |
As per the MIB. |
ospfAreaLsaCount (1.3.6.1.2.1.14.2.1.7) |
read-only |
Gauge32 |
Number of LSAs in the LSDB of the area. |
As per the MIB. |
ospfAreaLsaCksumSum (1.3.6.1.2.1.14.2.1.8) |
read-only |
Integer32 |
Sum of the checksums of the LSAs in the area. |
As per the MIB. |
ospfAreaSummary (1.3.6.1.2.1.14.2.1.9) |
read-create |
INTEGER |
noAreaSummary (1), sendAreaSummary (2) |
Whether to send summary LSAs to stub and NSSA areas. |
Supports only the read and write operations. |
ospfAreaStatus (1.3.6.1.2.1.14.2.1.10) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Area state. |
ospfAreaNssaTranslatorRole (1.3.6.1.2.1.14.2.1.11) |
read-create |
INTEGER |
always (1), candidate (2) |
Ability of the NSSA ABR to translate Type-7 LSAs into Type-5 LSAs. |
ospfAreaNssaTranslatorState (1.3.6.1.2.1.14.2.1.12) |
read-only |
INTEGER |
enabled (1), elected (2), disabled (3) |
Method for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs. |
As per the MIB. |
ospfAreaNssaTranslatorStabilityInterval(1.3.6.1.2.1.14.2.1.13) |
read-create |
PositiveInteger |
Time for the elected translator to continue to perform translation. |
Supports only the read and write operations. Value range: 0 to 900. |
ospfAreaNssaTranslatorEvents (1.3.6.1.2.1.14.2.1.14) |
read-only |
Counter32 |
Number of translator state changes. |
As per the MIB. |
ospfStubAreaTable
About this table
This table contains cost information that is advertised to a stub area.
Read:Supported
Columns
The table indexes are ospfStubAreaId and ospfStubTOS.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfStubAreaId (1.3.6.1.2.1.14.3.1.1) |
read-only |
AreaID |
OCTET STRING (4) |
Area ID, a 32-bit integer that uniquely identifies a stub area. |
As per the MIB. |
ospfStubTOS (1.3.6.1.2.1.14.3.1.2) |
read-only |
TOSType |
Integer32 (0..30) |
Type of Service associated with the cost. |
As per the MIB. |
ospfStubMetric (1.3.6.1.2.1.14.3.1.3) |
read-create |
BigMetric |
Integer32(0..'FFFFFF'h) |
Default cost of generated default LSAs, including Type-3 and Type-7 LSAs. |
Supports only the read and write operations. Value range: 0 to 16777214. |
ospfStubStatus (1.3.6.1.2.1.14.3.1.4) |
read-create |
RowStatus |
Area state. |
ospfStubMetricType (1.3.6.1.2.1.14.3.1.5) |
read-create |
INTEGER |
ospfMetric (1), comparableCost (2), nonComparable (3) |
Cost type. |
ospfLsdbTable
About this table
This table contains OSPF LSDB information.
Edit/Modify:Not supported
Read:Supported
Columns
The table indexes are ospfLsdbAreaId, ospfLsdbType, ospfLsdbLsid, and ospfLsdbRouterId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfLsdbAreaId (1.3.6.1.2.1.14.4.1.1) |
read-only |
AreaID |
OCTET STRING (4) |
ID of the area from which the LSA was received. |
As per the MIB. |
ospfLsdbType (1.3.6.1.2.1.14.4.1.2) |
read-only |
INTEGER |
routerLink (1), networkLink (2), summaryLink (3), asSummaryLink (4), asExternalLink (5), multicastLink (6), nssaExternalLink (7), areaOpaqueLink (10) |
LSA type. Type-5 LSAs are not displayed. |
As per the MIB. |
ospfLsdbLsid (1.3.6.1.2.1.14.4.1.3) |
read-only |
IpAddress |
OCTET STRING (4) |
LS ID |
As per the MIB. |
ospfLsdbRouterId (1.3.6.1.2.1.14.4.1.4) |
read-only |
RouterID |
OCTET STRING (4) |
Router ID of the LSA originator. |
As per the MIB. |
ospfLsdbSequence (1.3.6.1.2.1.14.4.1.5) |
read-only |
Integer32 |
LSA sequence number. |
As per the MIB. |
ospfLsdbAge (1.3.6.1.2.1.14.4.1.6) |
read-only |
Integer32 |
LSA age. |
As per the MIB. |
ospfLsdbChecksum (1.3.6.1.2.1.14.4.1.7) |
read-only |
Integer32 |
Checksum of the complete contents of the LSA except the age field. |
As per the MIB. |
ospfLsdbAdvertisement (1.3.6.1.2.1.14.4.1.8) |
read-only |
OCTET STRING |
OCTET STRING (1..65535) |
Complete LSA information, including the LSA header. |
As per the MIB. |
ospfHostTable
About this table
This table contains host route information on the device.
Read:Supported
Columns
The table indexes are ospfHostIpAddress and ospfHostTOS.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfHostIpAddress (1.3.6.1.2.1.14.6.1.1) |
read-only |
IpAddress |
OCTET STRING (4) |
IP address of the host route. |
As per the MIB. |
ospfHostTOS (1.3.6.1.2.1.14.6.1.2) |
read-only |
TOSType |
Integer32 (0..30) |
Type of Service. |
As per the MIB. |
ospfHostMetric (1.3.6.1.2.1.14.6.1.3) |
read-create |
Metric |
Integer32(0..'FFFF'h) |
Host route cost. |
Supports only the read and write operations. Value range: 1 to 65535. |
ospfHostStatus (1.3.6.1.2.1.14.6.1.4) |
read-create |
RowStatus |
Host route state. |
ospfHostAreaID (1.3.6.1.2.1.14.6.1.5) |
read-only |
AreaID |
OCTET STRING (4) |
ID of the area to which the host route belongs. |
As per the MIB. |
ospfHostCfgAreaID (1.3.6.1.2.1.14.6.1.6) |
read-create |
AreaID |
OCTET STRING (4) |
Configured area ID of the host route. |
ospfIfTable
About this table
This table contains OSPF interface information.
Read:Supported
Columns
The table indexes are ospfIfIpAddress and ospfAddressLessIf.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfIfIpAddress (1.3.6.1.2.1.14.7.1.1) |
read-only |
IpAddress |
OCTET STRING (4) |
Interface IP address. |
As per the MIB. |
ospfAddressLessIf (1.3.6.1.2.1.14.7.1.2) |
read-only |
InterfaceIndexOrZero |
Integer32(0..2147483647) |
Used to distinguish interface instances with addresses configured and those without addresses configured. |
As per the MIB. |
ospfIfAreaId (1.3.6.1.2.1.14.7.1.3) |
read-create |
AreaID |
OCTET STRING (4) |
Area ID. |
ospfIfType (1.3.6.1.2.1.14.7.1.4) |
read-create |
INTEGER |
broadcast(1), nbma (2), pointToPoint (3), pointToMultipoint (5) |
OSPF interface type. |
Supports only the read and write operations. Loopback interfaces do not support the write operation. |
ospfIfAdminStat (1.3.6.1.2.1.14.7.1.5) |
read-create |
Status |
Administrative state of the OSPF interface. It is enabled when the interface is active and disabled when the interface is in other state. |
ospfIfRtrPriority (1.3.6.1.2.1.14.7.1.6) |
read-create |
DesignatedRouterPriority |
Integer32(0..'FF'h) |
Interface priority. |
ospfIfTransitDelay (1.3.6.1.2.1.14.7.1.7) |
read-create |
UpToMaxAge |
Integer32(0..3600) |
Delay time interval. |
Supports only the read and write operations. Value range: 1 to 3600. Loopback interfaces do not support the write operation. |
ospfIfRetransInterval (1.3.6.1.2.1.14.7.1.8) |
read-create |
UpToMaxAge |
Retransmission interval. |
ospfIfHelloInterval (1.3.6.1.2.1.14.7.1.9) |
read-create |
HelloRange |
Integer32(1..'FFFF'h) |
Hello interval. |
ospfIfRtrDeadInterval (1.3.6.1.2.1.14.7.1.10) |
read-create |
PositiveInteger |
Dead interval. |
Supports only the read and write operations. Value range: 1 to 2147483647. Loopback interfaces do not support the write operation. |
ospfIfPollInterval (1.3.6.1.2.1.14.7.1.11) |
read-create |
PositiveInteger |
Poll interval. |
ospfIfState (1.3.6.1.2.1.14.7.1.12) |
read-only |
INTEGER |
down (1), loopback(2), waiting(3), pointToPoint (4), designatedRouter(5), backupDesignatedRouter (6), otherDesignatedRouter (7) |
Interface state. |
As per the MIB. |
ospfIfDesignatedRouter (1.3.6.1.2.1.14.7.1.13) |
read-only |
IpAddress |
OCTET STRING (4) |
DR address. |
As per the MIB. |
ospfIfBackupDesignatedRouter (1.3.6.1.2.1.14.7.1.14) |
read-only |
IpAddress |
OCTET STRING (4) |
BDR address. |
As per the MIB. |
ospfIfEvents (1.3.6.1.2.1.14.7.1.15) |
read-only |
Counter32 |
Number of interface state changes. |
As per the MIB. |
ospfIfAuthKey (1.3.6.1.2.1.14.7.1.16) |
read-create |
OCTET STRING |
OCTET STRING (0..256) |
Authentication key. |
ospfIfStatus (1.3.6.1.2.1.14.7.1.17) |
read-create |
RowStatus |
Row status. |
ospfIfMulticastForwarding (1.3.6.1.2.1.14.7.1.18) |
read-create |
INTEGER |
blocked(1), multicast(2), unicast (3) |
Multicast forwarding way on the interface. |
ospfIfDemand (1.3.6.1.2.1.14.7.1.19) |
read-create |
TruthValue |
true(1), false(2) |
Whether the interface performs demand routing. |
ospfIfAuthType (1.3.6.1.2.1.14.7.1.20) |
read-create |
ospfIfLsaCount (1.3.6.1.2.1.14.7.1.21) |
read-only |
Gauge32 |
Number of Type-9 LSAs. |
As per the MIB. |
ospfIfLsaCksumSum (1.3.6.1.2.1.14.7.1.22) |
read-only |
Unsigned32 |
Sum of checksums in Type-9 LSAs. |
As per the MIB. |
ospfIfDesignatedRouterId (1.3.6.1.2.1.14.7.1.23) |
read-only |
RouterID |
OCTET STRING (4) |
Router ID of the DR. |
As per the MIB. |
ospfIfBackupDesignatedRouterId(1.3.6.1.2.1.14.7.1.24) |
read-only |
RouterID |
OCTET STRING (4) |
Router ID of the BDR. |
As per the MIB. |
ospfIfMetricTable
About this table
This table contains information about costs to be advertised for a specific interface at various service types.
Read:Supported
Columns
The table indexes are ospfIfMetricIpAddress and ospfIfMetricAddressLessIf.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfIfMetricIpAddress (1.3.6.1.2.1.14.8.1.1) |
read-only |
IpAddress |
OCTET STRING (4) |
IP address of the OSPF interface. |
As per the MIB. |
ospfIfMetricAddressLessIf (1.3.6.1.2.1.14.8.1.2) |
read-only |
As per the MIB. |
ospfIfMetricTOS (1.3.6.1.2.1.14.8.1.3) |
read-only |
TOSType |
Integer32 (0..30) |
ToS cost being used. |
As per the MIB. |
ospfIfMetricValue (1.3.6.1.2.1.14.8.1.4) |
read-create |
Metric |
Interface cost. |
Supports only the read and write operations. Value range for a loopback interface: 0 to 65535. Value range for other interfaces: 1 to 65535. |
ospfIfMetricStatus (1.3.6.1.2.1.14.8.1.5) |
read-create |
RowStatus |
Row status. |
ospfVirtIfTable
About this table
This table contains OSPF virtual interface information of the router.
Read:Supported
Columns
The table indexes are ospfVirtIfAreaId and ospfVirtIfNeighbor.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfVirtIfAreaId (1.3.6.1.2.1.14.9.1.1) |
read-only |
AreaID |
OCTET STRING (4) |
ID of the area to which the virtual link belongs. |
As per the MIB. |
ospfVirtIfNeighbor (1.3.6.1.2.1.14.9.1.2) |
read-only |
RouterID |
OCTET STRING (4) |
Router ID of the virtual neighbor. |
As per the MIB. |
ospfVirtIfTransitDelay (1.3.6.1.2.1.14.9.1.3) |
read-create |
UpToMaxAge |
Delay interval. |
Supports only the read and write operations. Value range: 1 to 3600. |
ospfVirtIfRetransInterval (1.3.6.1.2.1.14.9.1.4) |
read-create |
UpToMaxAge |
ospfVirtIfHelloInterval (1.3.6.1.2.1.14.9.1.5) |
read-create |
HelloRange |
Hello interval. |
Supports only the read and write operations. Value range: 1 to 8192. |
ospfVirtIfRtrDeadInterval (1.3.6.1.2.1.14.9.1.6) |
read-create |
PositiveInteger |
Dead interval. |
Supports only the read and write operations. Value range: 1 to 32768. |
ospfVirtIfState (1.3.6.1.2.1.14.9.1.7) |
read-only |
INTEGER |
down (1), pointToPoint (4) |
OSPF virtual interface state. |
As per the MIB. |
ospfVirtIfEvents (1.3.6.1.2.1.14.9.1.8) |
read-only |
Counter32 |
Number of state changes on the interface. |
As per the MIB. |
ospfVirtIfAuthKey (1.3.6.1.2.1.14.9.1.9) |
read-create |
OCTET STRING |
ospfVirtIfStatus (1.3.6.1.2.1.14.9.1.10) |
read-create |
RowStatus |
Row status. |
ospfVirtIfAuthType (1.3.6.1.2.1.14.9.1.11) |
read-create |
ospfVirtIfLsaCount (1.3.6.1.2.1.14.9.1.12) |
read-only |
Gauge32 |
As per the MIB. |
ospfVirtIfLsaCksumSum (1.3.6.1.2.1.14.9.1.13) |
read-only |
Unsigned32 |
As per the MIB. |
ospfNbrTable
About this table
This table contains information about non-virtual neighbors of the local OSPF router.
Read:Supported
Columns
The table indexes are ospfNbrIpAddr and ospfNbrAddressLessIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfNbrIpAddr (1.3.6.1.2.1.14.10.1.1) |
read-only |
IpAddress |
OCTET STRING (4) |
Neighbor IP address. |
As per the MIB. |
ospfNbrAddressLessIndex (1.3.6.1.2.1.14.10.1.2) |
read-only |
Set to 0 on an interface having an IP address, and set to the value of interface index in the Internet Standard MIB on an interface having no IP address. |
As per the MIB. |
ospfNbrRtrId (1.3.6.1.2.1.14.10.1.3) |
read-only |
RouterID |
OCTET STRING (4) |
Router ID of the neighbor. |
As per the MIB. |
ospfNbrOptions (1.3.6.1.2.1.14.10.1.4) |
read-only |
Integer32 |
Option field of the neighbor. |
As per the MIB. |
ospfNbrPriority (1.3.6.1.2.1.14.10.1.5) |
read-create |
Priority of the neighbor. |
Supports only the read and write operations. NBMA neighbors support only the write operations. |
ospfNbrState (1.3.6.1.2.1.14.10.1.6) |
read-only |
INTEGER |
down (1), attempt (2), init (3), twoWay (4), exchangeStart (5), exchange (6), loading (7), full (8) |
State of the relationship with the neighbor. |
As per the MIB. |
ospfNbrEvents (1.3.6.1.2.1.14.10.1.7) |
read-only |
Counter32 |
Number of neighbor state changes. |
As per the MIB. |
ospfNbrLsRetransQLen (1.3.6.1.2.1.14.10.1.8) |
read-only |
Gauge32 |
Retransmission queue length. |
As per the MIB. |
ospfNbmaNbrStatus (1.3.6.1.2.1.14.10.1.9) |
read-create |
RowStatus |
Row status. |
ospfNbmaNbrPermanence (1.3.6.1.2.1.14.10.1.10) |
read-only |
INTEGER |
dynamic(1), permanent(2) |
Entry status. The values dynamic and permanent refer to how the neighbor became known. |
As per the MIB. |
ospfNbrHelloSuppressed (1.3.6.1.2.1.14.10.1.11) |
read-only |
TruthValue |
true(1), false(2) |
Whether hello packets are being suppressed to the neighbor. |
As per the MIB. |
ospfNbrRestartHelperStatus (1.3.6.1.2.1.14.10.1.12) |
read-only |
INTEGER |
notHelping(1), helping (2) |
Whether the router is acting as a GR helper for the neighbor. |
As per the MIB. |
ospfNbrRestartHelperAge (1.3.6.1.2.1.14.10.1.13) |
read-only |
Unsigned32 |
Remaining time of the GR interval when the router is acting as a GR helper for the neighbor. |
As per the MIB. |
ospfNbrRestartHelperExitReason(1.3.6.1.2.1.14.10.1.14) |
read-only |
INTEGER |
none (1),inProgress (2),completed (3),timedOut (4),topologyChanged (5) |
GR helper exit reason. |
As per the MIB. |
ospfVirtNbrTable
About this table
This table contains information about all virtual neighbors.
Read:Supported
Columns
The table indexes are ospfVirtNbrArea and ospfVirtNbrRtrId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfVirtNbrArea (1.3.6.1.2.1.14.11.1.1) |
read-only |
AreaID |
OCTET STRING (4) |
Transit area identifier. |
As per the MIB. |
ospfVirtNbrRtrId (1.3.6.1.2.1.14.11.1.2) |
read-only |
RouterID |
OCTET STRING (4) |
A 32-bit integer that uniquely identifies the neighboring router in the AS. |
As per the MIB. |
ospfVirtNbrIpAddr (1.3.6.1.2.1.14.11.1.3) |
read-only |
IpAddress |
OCTET STRING (4) |
IP address of the virtual neighbor. |
As per the MIB. |
ospfVirtNbrOptions (1.3.6.1.2.1.14.11.1.4) |
read-only |
Integer32 |
As per the MIB. |
ospfVirtNbrState (1.3.6.1.2.1.14.11.1.5) |
read-only |
INTEGER |
State of the virtual neighbor relationship. |
As per the MIB. |
ospfVirtNbrEvents (1.3.6.1.2.1.14.11.1.6) |
read-only |
Counter32 |
Number of virtual link state changes. |
As per the MIB. |
ospfVirtNbrLsRetransQLen (1.3.6.1.2.1.14.11.1.7) |
read-only |
Gauge32 |
As per the MIB. |
ospfVirtNbrHelloSuppressed (1.3.6.1.2.1.14.11.1.8) |
read-only |
TruthValue |
true(1), false(2) |
As per the MIB. |
ospfVirtNbrRestartHelperStatus (1.3.6.1.2.1.14.11.1.9) |
read-only |
INTEGER |
As per the MIB. |
ospfVirtNbrRestartHelperAge(1.3.6.1.2.1.14.11.1.10) |
read-only |
Unsigned32 |
As per the MIB. |
ospfVirtNbrRestartHelperExitReason (1.3.6.1.2.1.14.11.1.11) |
read-only |
INTEGER |
none(1), inProgress(2), completed (3), timedOut (4), topologyChanged (5) |
As per the MIB. |
ospfExtLsdbTable
About this table
This table contains information about the LSDB of external LSAs for the OSPF process.
Read:Supported
Columns
The table indexes are ospfExtLsdbType, ospfExtLsdbLsid, and ospfExtLsdbRouterId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfExtLsdbType (1.3.6.1.2.1.14.12.1.1) |
read-only |
INTEGER |
asExternalLink(5) |
LSA type. |
As per the MIB. |
ospfExtLsdbLsid (1.3.6.1.2.1.14.12.1.2) |
read-only |
IpAddress |
OCTET STRING (4) |
LS ID, an LS type specific field containing either a router ID or an IP address. |
As per the MIB. |
ospfExtLsdbRouterId (1.3.6.1.2.1.14.12.1.3) |
read-only |
RouterID |
OCTET STRING (4) |
A 32-bit number that uniquely identifies the originating router in the AS. |
As per the MIB. |
ospfExtLsdbSequence (1.3.6.1.2.1.14.12.1.4) |
read-only |
Integer32 |
Sequence number. |
As per the MIB. |
ospfExtLsdbAge (1.3.6.1.2.1.14.12.1.5) |
read-only |
Integer32 |
Age of the LSA. |
As per the MIB. |
ospfExtLsdbChecksum (1.3.6.1.2.1.14.12.1.6) |
read-only |
Integer32 |
Checksum of the complete contents of the LSA, except the age field. |
As per the MIB. |
ospfExtLsdbAdvertisement (1.3.6.1.2.1.14.12.1.7) |
read-only |
OCTET STRING |
OCTET STRING (36) |
Complete LSA information. |
As per the MIB. |
ospfAreaAggregateTable
About this table
This table contains information about configured summary routes.
Read:Supported
Columns
The table indexes are ospfAreaAggregateAreaID, ospfAreaAggregateLsdbType, ospfAreaAggregateNet, and ospfAreaAggregateMask.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfAreaAggregateAreaID (1.3.6.1.2.1.14.14.1.1) |
read-only |
AreaID |
OCTET STRING (4) |
Area where the summary route resides. |
As per the MIB. |
ospfAreaAggregateLsdbType (1.3.6.1.2.1.14.14.1.2) |
read-only |
INTEGER |
summaryLink(3), nssaExternalLink (7) |
Summary route type. |
As per the MIB. |
ospfAreaAggregateNet (1.3.6.1.2.1.14.14.1.3) |
read-only |
IpAddress |
OCTET STRING (4) |
Network address. |
As per the MIB. |
ospfAreaAggregateMask (1.3.6.1.2.1.14.14.1.4) |
read-only |
IpAddress |
OCTET STRING (4) |
Subnet mask. |
As per the MIB. |
ospfAreaAggregateStatus (1.3.6.1.2.1.14.14.1.5) |
read-create |
RowStatus |
Row status. |
ospfAreaAggregateEffect (1.3.6.1.2.1.14.14.1.6) |
read-create |
INTEGER |
advertiseMatching (1), doNotAdvertiseMatching (2) |
Whether subnets are included in the summary route. |
ospfAreaAggregateExtRouteTag(1.3.6.1.2.1.14.14.1.7) |
read-create |
Unsigned32 |
External route tag in Type-7 LSAs. |
Supports only the read and write operations. nssaExternalLink supports only the write operation. |
ospfLocalLsdbTable
About this table
This table contains all local LSDB information.
Read:Supported
Columns
The table indexes are ospfLocalLsdbIpAddress, ospfLocalLsdbAddressLessIf, ospfLocalLsdbType, ospfLocalLsdbLsid, and ospfLocalLsdbRouterId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfLocalLsdbIpAddress (1.3.6.1.2.1.14.17.1.1) |
not-accessible |
IpAddress |
OCTET STRING (4) |
IP address of the interface that received the LSA. |
As per the MIB. |
ospfLocalLsdbAddressLessIf (1.3.6.1.2.1.14.17.1.2) |
not-accessible |
Index of the interface that received the LSA. |
As per the MIB. |
ospfLocalLsdbType (1.3.6.1.2.1.14.17.1.3) |
not-accessible |
INTEGER |
localOpaqueLink (9) |
LSA type. |
As per the MIB. |
ospfLocalLsdbLsid (1.3.6.1.2.1.14.17.1.4) |
not-accessible |
IpAddress |
OCTET STRING (4) |
LS ID. |
As per the MIB. |
ospfLocalLsdbRouterId (1.3.6.1.2.1.14.17.1.5) |
not-accessible |
RouterID |
OCTET STRING (4) |
As per the MIB. |
ospfLocalLsdbSequence (1.3.6.1.2.1.14.17.1.6) |
read-only |
Integer32 |
As per the MIB. |
ospfLocalLsdbAge (1.3.6.1.2.1.14.17.1.7) |
read-only |
Integer32 |
LSA age in seconds. |
As per the MIB. |
ospfLocalLsdbChecksum (1.3.6.1.2.1.14.17.1.8) |
read-only |
Integer32 |
LSA checksum. |
As per the MIB. |
ospfLocalLsdbAdvertisement (1.3.6.1.2.1.14.17.1.9) |
read-only |
OCTET STRING |
As per the MIB. |
ospfVirtLocalLsdbTable
About this table
This table contains local LSDB information for all virtual links.
Read:Supported
Columns
The table indexes are ospfVirtLocalLsdbTransitArea, ospfVirtLocalLsdbNeighbor, ospfVirtLocalLsdbType, ospfVirtLocalLsdbLsid, and ospfVirtLocalLsdbRouterId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfVirtLocalLsdbTransitArea (1.3.6.1.2.1.14.18.1.1) |
not-accessible |
AreaID |
OCTET STRING (4) |
Transit area that the virtual link traverses. |
As per the MIB. |
ospfVirtLocalLsdbNeighbor (1.3.6.1.2.1.14.18.1.2) |
not-accessible |
RouterID |
OCTET STRING (4) |
As per the MIB. |
ospfVirtLocalLsdbType (1.3.6.1.2.1.14.18.1.3) |
not-accessible |
INTEGER |
LSA type. |
As per the MIB. |
ospfVirtLocalLsdbLsid (1.3.6.1.2.1.14.18.1.4) |
not-accessible |
IpAddress |
OCTET STRING (4) |
LS ID. |
As per the MIB. |
ospfVirtLocalLsdbRouterId (1.3.6.1.2.1.14.18.1.5) |
not-accessible |
RouterID |
OCTET STRING (4) |
As per the MIB. |
ospfVirtLocalLsdbSequence (1.3.6.1.2.1.14.18.1.6) |
read-only |
Integer32 |
As per the MIB. |
ospfVirtLocalLsdbAge (1.3.6.1.2.1.14.18.1.7) |
read-only |
Integer32 |
As per the MIB. |
ospfVirtLocalLsdbChecksum (1.3.6.1.2.1.14.18.1.8) |
read-only |
Integer32 |
LSA checksum. |
As per the MIB. |
ospfVirtLocalLsdbAdvertisement (1.3.6.1.2.1.14.18.1.9) |
read-only |
OCTET STRING |
As per the MIB. |
ospfAsLsdbTable
About this table
This table contains information about LSDB information of an AS.
Read:Supported
Columns
The table indexes are ospfAsLsdbType, ospfAsLsdbLsid, and ospfAsLsdbRouterId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfAsLsdbType (1.3.6.1.2.1.14.19.1.1) |
not-accessible |
INTEGER |
asExternalLink (5), asOpaqueLink (11) |
LSA type. |
As per the MIB. |
ospfAsLsdbLsid (1.3.6.1.2.1.14.19.1.2) |
not-accessible |
IpAddress |
OCTET STRING (4) |
LS ID. |
As per the MIB. |
ospfAsLsdbRouterId (1.3.6.1.2.1.14.19.1.3) |
not-accessible |
RouterID |
OCTET STRING (4) |
As per the MIB. |
ospfAsLsdbSequence (1.3.6.1.2.1.14.19.1.4) |
read-only |
Integer32 |
As per the MIB. |
ospfAsLsdbAge (1.3.6.1.2.1.14.19.1.5) |
read-only |
Integer32 |
As per the MIB. |
ospfAsLsdbChecksum (1.3.6.1.2.1.14.19.1.6) |
read-only |
Integer32 |
LSA checksum. |
As per the MIB. |
ospfAsLsdbAdvertisement (1.3.6.1.2.1.14.19.1.7) |
read-only |
OCTET STRING |
As per the MIB. |
ospfAreaLsaCountTable
About this table
This table contains LSA statistics information of all areas and types.
Read:Supported
Columns
The table indexes are ospfAreaLsaCountAreaId and ospfAreaLsaCountLsaType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ospfAreaLsaCountAreaId (1.3.6.1.2.1.14.20.1.1) |
not-accessible |
AreaID |
OCTET STRING (4) |
Area ID. |
As per the MIB. |
ospfAreaLsaCountLsaType (1.3.6.1.2.1.14.20.1.2) |
not-accessible |
INTEGER |
routerLink (1), networkLink (2), summaryLink (3), asSummaryLink (4), multicastLink (6), nssaExternalLink (7), areaOpaqueLink (10) |
LSA type. |
As per the MIB. |
ospfAreaLsaCountNumber (1.3.6.1.2.1.14.20.1.3) |
read-only |
Gauge32 |
Number of LSAs of the specified type in the specified area. |
As per the MIB. |
