09-Layer 3 - IP Routing
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10009-Layer 3 - IP Routing
02-HH3C-BGP-VPN-MIB
02-HH3C-BGP-VPN-MIB 337.20 KB
HH3C-BGP-VPN-MIB
About this MIB
This document contains route and packet information about peers in the address families supported by BGP (MBGP or MP-BGP).
MIB file name
hh3c-bgp-vpn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cBgpVpn(202)
Tabular objects
hh3cBgpPeerAddrFamilyTable
About this table
This table contains BGP peer address family information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadNot supported
Columns
The table indexes are hh3cBgpPeerInstanceId, hh3cBgpPeerVpnIndex, hh3cBgpPeerAddrFamilyId, hh3cBgpPeerSubAddrFamilyId, hh3cBgpPeerType, hh3cBgpPeerIPAddr.
Object (OID)
Access
Value range
Implementation
hh3cBgpPeerInstanceId (1.3.6.1.4.1.25506.2.202.1.1.1.1.1)
not-accessible
Unsigned32
Standard MIB values.
Index of the BGP instance to which the BGP peer belongs.
As per the MIB.
hh3cBgpPeerVpnIndex (1.3.6.1.4.1.25506.2.202.1.1.1.1.2)
not-accessible
Unsigned32
VPN instance index of the BGP peer.
As per the MIB.
hh3cBgpPeerAddrFamilyId (1.3.6.1.4.1.25506.2.202.1.1.1.1.3)
not-accessible
Hh3cBgpAfi
INTEGER{ipv4(1),ipv6(2),l2vpn(25),l2vpnDraft(196),dedicated(6000)}
Address family index of the BGP peer.
As per the MIB.
hh3cBgpPeerSubAddrFamilyId (1.3.6.1.4.1.25506.2.202.1.1.1.1.4)
not-accessible
Hh3cBgpSAfi
INTEGER{unicast(1),multicast(2),mpls(4),mcastVpn(5),l2vpn(65),mdt(66),evpn(70),vpn(128),routeTarget(132),dedicated(255)}
Subsequent address family index of the BGP peer.
As per the MIB.
hh3cBgpPeerType (1.3.6.1.4.1.25506.2.202.1.1.1.1.5)
not-accessible
InetAddressType
IPv4(1)
IPv6 (2)
Address family type of the BGP peer.
As per the MIB.
hh3cBgpPeerIPAddr (1.3.6.1.4.1.25506.2.202.1.1.1.1.6)
not-accessible
InetAddress
OCTET STRING{(0,255)}
IP address of the BGP peer.
As per the MIB.
hh3cBgpPeerVpnName (1.3.6.1.4.1.25506.2.202.1.1.1.1.7)
read-only
Hh3cMplsVpnId
OCTET STRING(0..31)
VPN instance name.
As per the MIB.
hh3cBgpPeerTable
About this table
This table contains BGP peer information.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cBgpPeerNegotiatedVersion (1.3.6.1.4.1.25506.2.202.1.1.2.1.1)
read-only
Unsigned32
Negotiated BGP version number.
As per the MIB.
hh3cBgpPeerRemoteAs (1.3.6.1.4.1.25506.2.202.1.1.2.1.2)
read-only
Counter32
AS number of the BGP peer.
As per the MIB.
hh3cBgpPeerRemoteAddr (1.3.6.1.4.1.25506.2.202.1.1.2.1.3)
read-only
As per the MIB.
hh3cBgpPeerState (1.3.6.1.4.1.25506.2.202.1.1.2.1.4)
read-only
INTEGER
INTEGER{(idle,1),(connect,2),(active,3),(opensent,4),(openconfirm,5),(established,6)}
BGP peer state:
Idle(1)
Connect(2)
Active(3)
Opensent(4)
Openconfirm(5)
Established(6)
As per the MIB.
hh3cBgpPeerFsmEstablishedCounter (1.3.6.1.4.1.25506.2.202.1.1.2.1.5)
read-write
Unsigned32
Counter of successful BGP peer connections.
Each time BGP connects to the BGP peer successfully, this value increases by one. You can reset the counter.
Only read-only is supported.
hh3cBgpPeerFsmEstablishedTime (1.3.6.1.4.1.25506.2.202.1.1.2.1.6)
read-only
Gauge32
Time when BGP connected to the BGP peer successfully.
As per the MIB.
hh3cBgpPeerGRStatus (1.3.6.1.4.1.25506.2.202.1.1.2.1.7)
accessible-for-notify
INTEGER
INTEGER{(peerNotBeingHelped,1),(peerRestarting,2),(peerFinishRestart,3),(peerHelping,4)}
GR status of the BGP peer:
peerNotBeingHelped—The peer is not assisted in restarting.
peerRestarting—The peer is restarting.
peerFinishRestart—The peer has finished restarting.
peerHelping—The peer helps BGP perform GR.
As per the MIB.
hh3cBgpPeerLastError
(1.3.6.1.4.1.25506.2.202.1.1.2.1.8)
read-only
OCTET STRING
Error code and subcode for the most recent peer connection error. The first byte represents the error code and the second one represents the subcode.
If no error code exists, this field displays 0.
As per the MIB.
hh3cBgpPeerUnAvaiReason
(1.3.6.1.4.1.25506.2.202.1.1.2.1.9)
read-only
Unsigned32
Reason why the BGP peer went down:
Unknown ErrCode/Unknown ErrSubcode(1)
ErrSubCode Unspecified(2)
Unknown ErrSubcode(3)
Connection Not Synchronized(4)
Bad Message Length(5)
Bad Message Type(6)
Unsupported Version Number(7)
Bad Peer AS(8)
Bad BGP Identifier(9)
Unsupported Optional Parameter(10)
Authentication Failure(11)
Unacceptable Hold Time(12)
Unsupported Capability(13)
Malformed Attribute List(14)
Unrecognized Well-known Attr(15)
Missing Well-known Attribute(16)
Attribute Flags Error(17)
Attribute Length Error(18)
Invalid ORIGIN Attribute(19)
AS Routing Loop(20)
Invalid NEXT_HOP Attribute(21)
Optional Attribute Error(22)
Invalid Network Field(23)
Malformed AS_PATH(24)
Receive Unexpected Message in OpenSent(25)
Receive Unexpected Message in OpenConfirm(26)
Receive Unexpected Message in Established(27)
Maximum Number of Prefixes Reached(28)
Administrative Shutdown(29)
Peer De-configured(30)
Administrative Reset(31)
Connection Rejected(32)
Other Configuration Change(33)
Connection Collision Resolution(34)
Out of Resources(35)
As per the MIB.
hh3cBgpPeerAdminStatus
(1.3.6.1.4.1.25506.2.202.1.1.2.1.10)
read-only
INTEGER
INTEGER{(stop,1),(start,2)}
BGP peer connection state. A BGP start event will be generated if you change the state from stop to start. A BGP stop event will be generated if you change the state from start to stop.
This field is used for restarting BGP peer connections.
If you do not enable identity authentication, protect the access and write operations on this object.
As per the MIB.
hh3cBgpPeerRouteTable
About this table
This table contains route and packet information about BGP peers.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cBgpPeerRouteRcvCount (1.3.6.1.4.1.25506.2.202.1.1.3.1.1)
read-only
Counter32
Number of route prefixes received from BGP peers.
As per the MIB.
hh3cBgpPeerRouteActiveCount (1.3.6.1.4.1.25506.2.202.1.1.3.1.2)
read-only
Counter32
Number of active route prefixes received from BGP peers.
As per the MIB.
hh3cBgpPeerRouteAdvCount (1.3.6.1.4.1.25506.2.202.1.1.3.1.3)
read-only
Counter32
Number of route prefixes sent to BGP peers.
As per the MIB.
hh3cBgpPeerConfigTable
About this table
This table contains BGP peer configuration information.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
The table indexes are hh3cBgpPeerInstanceId, hh3cBgpPeerVpnIndex, hh3cBgpPeerAddrFamilyId, hh3cBgpPeerSubAddrFamilyId, hh3cBgpPeerType, and hh3cBgpPeerIPAddr.
Object (OID)
Access
Value range
Implementation
hh3cBgpPeerConfigRouteLimitNum
 (1.3.6.1.4.1.25506.2.202.1.1.4.1.1)
read-only
Unsigned32
Maximum number of routes that can be received from BGP peers.
As per the MIB.
hh3cBgpPeerConfigRouteLimitThreshold (1.3.6.1.4.1.25506.2.202.1.1.4.1.2)
read-only
Unsigned32
Unsigned32{(0,100)}
Threshold value that triggers route number limit notifications, in percentage.
As per the MIB.
hh3cBgpPeerStatisticTable
About this table
This table displays BGP peer statistics. Each entry records information about a BGP peer.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
The table indexes are hh3cBgpPeerProcessId, hh3cBgpPeerVrfInstanceId, and hh3cBgpPeerAddr.
Object (OID)
Access
Value range
Implementation
hh3cBgpPeerProcessId (1.3.6.1.4.1.25506.2.202.1.1.5.1.1)
not-accessible
Unsigned32
BGP process ID.
As per the MIB.
hh3cBgpPeerVrfInstanceId (1.3.6.1.4.1.25506.2.202.1.1.5.1.2)
not-accessible
Unsigned32
As per the MIB.
hh3cBgpPeerAddr (1.3.6.1.4.1.25506.2.202.1.1.5.1.3)
not-accessible
OCTET STRING
As per the MIB.
hh3cBgpPeerFsmEstablishedTransitions (1.3.6.1.4.1.25506.2.202.1.1.5.1.4)
read-only
Counter32
Number of times that the BGP peer entered the established state.
As per the MIB.
hh3cBgpPeerDownCounts (1.3.6.1.4.1.25506.2.202.1.1.5.1.5)
read-only
Counter32
Number of times that the BGP peer entered another state from the established state.
As per the MIB.
hh3cBgpPeerInUpdateMsgs (1.3.6.1.4.1.25506.2.202.1.1.5.1.6)
read-only
Counter32
Number of UPDATE messages received from the BGP peer.
As per the MIB.
hh3cBgpPeerOutUpdateMsgs (1.3.6.1.4.1.25506.2.202.1.1.5.1.7)
read-only
Counter32
Number of UPDATE messages sent to the BGP peer.
As per the MIB.
hh3cBgpPeerInTotalMsgs (1.3.6.1.4.1.25506.2.202.1.1.5.1.8)
read-only
Counter32
Number of packets received from the BGP peer.
As per the MIB.
hh3cBgpPeerOutTotalMsgs (1.3.6.1.4.1.25506.2.202.1.1.5.1.9)
read-only
Counter32
Number of packets sent to the BGP peer.
As per the MIB.
hh3cBgpPeerSessionTable
About this table
This table contains BGP peer session information.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
The table indexes are hh3cBgpPeerSessionVrfId, hh3cBgpPeerSessionRemoteAddrType, and hh3cBgpPeerSessionRemoteAddr.
Object (OID)
Access
Value range
Implementation
hh3cBgpPeerSessionVrfId (1.3.6.1.4.1.25506.2.202.1.1.6.1.1)
not-accessible
Unsigned32
Index of the VPN instance to which the BGP peer belongs.
As per the MIB.
hh3cBgpPeerSessionRemoteAddrType (1.3.6.1.4.1.25506.2.202.1.1.6.1.2)
not-accessible
INTEGER
INTEGER{(unknown,0),(ipv4,1),(ipv6,2),(ipv4z,3),(ipv6z,4),(dns,16)}
IP address type of the BGP peer.
As per the MIB.
hh3cBgpPeerSessionRemoteAddr (1.3.6.1.4.1.25506.2.202.1.1.6.1.3)
not-accessible
OCTET STRING
As per the MIB.
hh3cBgpPeerSessionRemotePort (1.3.6.1.4.1.25506.2.202.1.1.6.1.4)
read-only
Integer32
Integer32(0..65535)
Remote port number of the peer connection.
As per the MIB.
hh3cBgpPeerSessionLocalAddrType (1.3.6.1.4.1.25506.2.202.1.1.6.1.5)
read-only
INTEGER
IP address type of the local peer.
As per the MIB.
hh3cBgpPeerSessionLocalAddr (1.3.6.1.4.1.25506.2.202.1.1.6.1.6)
read-only
OCTET STRING
IP address of the local peer.
As per the MIB.
hh3cBgpPeerSessionLocalPort (1.3.6.1.4.1.25506.2.202.1.1.6.1.7)
read-only
Integer32
Integer32(0..65535)
Local port number of the peer connection.
As per the MIB.
hh3cBgpPeerSessionUnavailableType (1.3.6.1.4.1.25506.2.202.1.1.6.1.8)
read-only
INTEGER
INTEGER{(uptodown,1),(alwaysdown,2)}
Peer unavailability type:
1: Up To Down(1)
2: Always Down(2)
As per the MIB.
hh3cBgpPeerSessionLocalIfName (1.3.6.1.4.1.25506.2.202.1.1.6.1.9)
read-only
OCTET STRING
Local interface name of the peer connection.
As per the MIB.
hh3cBgpPeerSessionReason (1.3.6.1.4.1.25506.2.202.1.1.6.1.10)
read-only
INTEGER
INTEGER{(configurationLeadPeerDown,1),(receiveNotification,2),(receiveErrorPacket,3),(holdTimerExpire,4),(remotePeerNotReachable,5),(directConnectInterfaceDown,6),(routeLimit,7),(peerIsNotUpForASpecifiedPeriodOfTime,8),(unknown,90),(alarmClear,100)}
Reason why the peer went down:
1: Configuration lead peer down(1)
2: Receive notification(2)
3: Receive error packet(3)
4: Hold timer expire(4)
5: Remote peer not reachable(5)
6: Direct connect-interface down(6)
7: Route limit(7)
8: Peer is not up for a specified long time(8)
90: unknown(90)
100: Alarm clear(100)
As per the MIB.
hh3cBgpPeerSessionVrfName (1.3.6.1.4.1.25506.2.202.1.1.6.1.11)
read-only
OCTET STRING
VPN instance name.
As per the MIB.
hh3cBgpPeerMessageTable
About this table
This table contains statistics of packets sent to or received from BGP peers.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cBgpPeerInTotalMsgCounter (1.3.6.1.4.1.25506.2.202.1.1.7.1.1)
read-only
INTEGER
INTEGER (0..4294967295)
Number of packets received from BGP peers.
As per the MIB.
hh3cBgpPeerOutTotalMsgCounter (1.3.6.1.4.1.25506.2.202.1.1.7.1.2)
read-only
INTEGER
Number of packets sent to BGP peers.
As per the MIB.
hh3cBgpPeerInOpenMsgCounter (1.3.6.1.4.1.25506.2.202.1.1.7.1.3)
read-only
INTEGER
Number of OPEN messages received from BGP peers.
As per the MIB.
hh3cBgpPeerInUpdateMsgCounter (1.3.6.1.4.1.25506.2.202.1.1.7.1.4)
read-only
INTEGER
Number of UPDATE messages received from BGP peers.
As per the MIB.
hh3cBgpPeerInNotificationMsgCounter (1.3.6.1.4.1.25506.2.202.1.1.7.1.5)
read-only
INTEGER
Number of messages received from BGP peers.
As per the MIB.
hh3cBgpPeerInKeepAliveMsgCounter (1.3.6.1.4.1.25506.2.202.1.1.7.1.6)
read-only
INTEGER
Number of KEEPALIVE messages received from BGP peers.
As per the MIB.
hh3cBgpPeerInRouteFreshMsgCounter (1.3.6.1.4.1.25506.2.202.1.1.7.1.7)
read-only
INTEGER
Number of ROUTE-REFRESH messages received from BGP peers.
As per the MIB.
hh3cBgpPeerOutOpenMsgCounter (1.3.6.1.4.1.25506.2.202.1.1.7.1.8)
read-only
INTEGER
Number of OPEN messages sent to BGP peers.
As per the MIB.
hh3cBgpPeerOutUpdateMsgCounter (1.3.6.1.4.1.25506.2.202.1.1.7.1.9)
read-only
INTEGER
Number of UPDATE messages sent to BGP peers.
As per the MIB.
hh3cBgpPeerOutNotificationMsgCounter (1.3.6.1.4.1.25506.2.202.1.1.7.1.10)
read-only
INTEGER
Number of NOTIFICATION messages sent to BGP peers.
As per the MIB.
hh3cBgpPeerOutKeepAliveMsgCounter (1.3.6.1.4.1.25506.2.202.1.1.7.1.11)
read-only
INTEGER
Number of KEEPALIVE messages sent to BGP peers.
As per the MIB.
hh3cBgpPeerOutRouteFreshMsgCounter (1.3.6.1.4.1.25506.2.202.1.1.7.1.12)
read-only
INTEGER
Number of ROUTE-REFRESH messages sent to BGP peers.
As per the MIB.
hh3cBgpVpnRouteTable
About this table
This table contains BGP VPN route information.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
The table indexes are hh3cBgpVpnRouteType, hh3cBgpVpnInstName, and hh3cBgpVpnAddressFamily.
Object (OID)
Access
Value range
Implementation
hh3cBgpVpnRouteType (1.3.6.1.4.1.25506.2.202.1.2.1.1.1)
Unsigned32
VPN route type.
As per the MIB.
hh3cBgpVpnInstName (1.3.6.1.4.1.25506.2.202.1.2.1.1.2)
OCTET STRING
OCTET STRING{(0,31)}
VPN instance name.
As per the MIB.
hh3cBgpVpnAddressFamily (1.3.6.1.4.1.25506.2.202.1.2.1.1.3)
Unsigned32
Address family.
As per the MIB.
hh3cBgpVpnCurrRouteNum (1.3.6.1.4.1.25506.2.202.1.2.1.1.4)
read-only
Unsigned32
Number of VPN routes.
As per the MIB.
hh3cBgpVpnThresholdValue (1.3.6.1.4.1.25506.2.202.1.2.1.1.5)
read-only
Unsigned32
Threshold for route count notifications.
As per the MIB.
hh3cBgpVpnScalars
About this table
This table contains L3VPN configuration information.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
The table has no indexes. All address families supported in a VPN instance are added.
Object (OID)
Access
Value range
Implementation
hh3cBgpConfiguredVrfs (1.3.6.1.4.1.25506.2.202.1.3.1)
read-only
INTEGER
Number of VPN instances.
As per the MIB.
hh3cBgpConfiguredIpv4Vrfs (1.3.6.1.4.1.25506.2.202.1.3.2)
read-only
INTEGER
Number of IPv4 VPN instances.
As per the MIB.
hh3cBgpConfiguredIpv6Vrfs (1.3.6.1.4.1.25506.2.202.1.3.3)
read-only
INTEGER
Number of IPv6 VPN instances.
As per the MIB.
hh3cBgpConfiguredIpv4Flowspec (1.3.6.1.4.1.25506.2.202.1.3.4)
read-only
INTEGER
Number of IPv4 flowspec VPN instances.
As per the MIB.
hh3cBgpConfiguredIpv6Flowspec (1.3.6.1.4.1.25506.2.202.1.3.5)
read-only
INTEGER
Number of IPv6 flowspec VPN instances.
As per the MIB.
hh3cBgpConfiguredEvpnVrfs (1.3.6.1.4.1.25506.2.202.1.3.6)
read-only
INTEGER
Number of EVPN instances.
As per the MIB.
hh3cBgpInstanceCommTable
About this table
This table contains BGP instance information.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
The table index is hh3cBgpInstanceName.
Object (OID)
Access
Value range
Implementation
hh3cBgpInstanceName (1.3.6.1.4.1.25506.2.202.2.1.1.1.1)
read-only
OCTET STRING
{(1,31)}
BGP instance name.
As per the MIB.
hh3cBgpInstanceId (1.3.6.1.4.1.25506.2.202.2.1.1.1.2)
read-only
Unsigned32
Unsigned32{(0,100)}
BGP instance ID.
As per the MIB.
hh3cBgpVpnRpkiSessions
About this table
This table contains RPKI session information.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
Object (OID)
Object (OID)
Access
Value range
Implementation
hh3cBgpVpnRpkiSessionVrfName (1.3.6.1.4.1.25506.2.202.3.1.1)
OCTET STRING
VPN instance index of the session.
The actual access permission is accessible-for-notify.
This object is used only as a VB-bound object of the notification module.
hh3cBgpVpnRpkiSessionType (1.3.6.1.4.1.25506.2.202.3.1.2)
INTEGER
Address family type.
hh3cBgpVpnRpkiSessionIPAddr (1.3.6.1.4.1.25506.2.202.3.1.3)
OCTET STRING
IP address of the RPKI session.
hh3cBgpVpnRpkiSessionRoaLimitNum (1.3.6.1.4.1.25506.2.202.3.1.4)
Unsigned32
Limit on the number of ROAs.
Notifications
hh3cBgpPeerRouteNumThresholdExceed
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.202.4.0.1
The number of routes received from a peer has exceeded the alarm threshold.
Error
Major
1.3.6.1.4.1.25506.2.202.4.0.2 (hh3cBgpPeerRouteNumThresholdClear)
ON
Notification triggers
This notification is generated when the number of routes received from a peer has reached the alarm threshold. The alarm threshold refers to the value specified for the percentage-value argument when you execute the peer route-limit command for the peer. The device generates an alarm message when the ratio of M to N exceeds the alarm threshold:
The M argument represents the number of routes received from the peer.
The N argument represents the maximum number of routes that can be received from the peer.
System impact
The impact on the system varies by the alarm threshold configuration of the peer route-limit command:
If the alarm threshold is set to 100% for the peer, the device will be disconnected from the peer or cannot receive new routes from the peer.
If the alarm threshold is set to a value other than 100% for the peer, this issue has no negative impact on the system. This alarm message aims at informing users of the potential impact, that is, the number of routes received from the peer is reaching the upper limit.
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-routethreshold-exceed ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-routethreshold-exceed ] command.
Object
OID (object name)
Index
Value range
 (1.3.6.1.4.1.25506.2.202.1.1.4.1.1 (hh3cBgpPeerConfigRouteLimitNum)
Limit on the number of routes that can be received from a peer or peer group.
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
1.3.6.1.4.1.25506.2.202.1.1.4.1.2 (hh3cBgpPeerConfigRouteLimitThreshold)
Threshold value for the device to generate an alarm notification.
The device generates an alarm notification when the ratio of the number of received routes to the limit on the number of received routes exceeds the threshold.
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
Unsigned32{(0,100)}
Recommended action
To resolve the issue:
1.Execute the display bgp peer verbose command and view the NLRI statistics and Message statistics fields in the command output to check whether the number of routes received from the peer has reached the alarm threshold:
  - If the number of routes received from the peer has reached the alarm threshold, proceed to step 2.
  - If the number of routes received from the peer has not reached the alarm threshold, proceed to step 10.
2.Identify whether the overflowing received routes are necessary for forwarding services.
  - If the overflowing received routes are necessary, proceed to step 8.
  - If the overflowing received routes are not necessary, proceed to step 3.
3.Execute the display current-configuration configuration bgp command to view the current BGP configurations. Check for configurations that cause the local device to receive too many unnecessary routes. Such configurations include peer prefix-list, peer filter-policy, peer as-path-acl, filter-policy, and peer route-policy.
  - If the local device has some configurations that affect the route reception policy, proceed to step 4.
  - If the local device does not have configurations that affect the route reception policy, proceed to step 5.
4.Edit those configurations to reduce the number of routes received by the local device, and then proceed to step 9.
5.Contact the administrator of the peer to check whether the number of BGP routes sent to the local device is appropriate:
  - If the number of BGP routes sent to the local device is appropriate, proceed to step 6.
  - If the number of BGP routes sent to the local device is not appropriate, proceed to step 7.
6.Notify the administrator of the BGP peer to reduce the number of BGP routes sent to the local device, and then proceed to step 9. To reduce the number of BGP routes sent to the local device, the administrator can use the following methods:
  - Summarize the routes sent to the local device.
  - Suppress the advertisement of summaried routes.
7.Notify the administrator of the BGP peer to edit the policy of route distribution to the local device, which prevents the local device from receiving unnecessary routes. Then, proceed to step 9.
8.Use the peer route-limit command to increase the maximum number of BGP routes that can be received from the peer or increase the alarm threshold. Then, proceed to step 9.
9.Check whether the hh3cBgpPeerRouteNumThresholdCleard message is generated on the device.
  - If the message is generated, the issue is cleared and the troubleshooting completes.
  - If the message is not generated, proceed to step 10.
10.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The number of routes received from a peer has dropped below the alarm threshold.
Recovery
Major
N/A (N/A)
ON
This notification is generated when the number of routes received from a peer has dropped below the alarm threshold. The alarm threshold refers to the value specified for the percentage-value argument when you execute the peer route-limit command for the peer. The device generates an alarm message when the ratio of M to N exceeds the alarm threshold:
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-routethreshold-clear ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-routethreshold-clear ] command.
Object
OID (object name)
Index
Value range
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
Unsigned32{(0,100)}
Recommended action
No action is required.
hh3cBgpPeerRouteExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.202.4.0.3
The number of routes received from a peer has exceeded the upper limit.
Error
Major
1.3.6.1.4.1.25506.2.202.4.0.4 (hh3cBgpPeerRouteExceedClear)
ON
This notification is generated when the number of routes received from a peer has exceeded the upper limit. The upper limit refers to the value specified for the prefix-number argument when you execute the peer route-limit command for the peer.
System impact
The device will be disconnected from the peer or cannot receive new routes from the peer.
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-routeexceed ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-routeexceed ] command.
Object
OID (object name)
Index
Value range
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
Unsigned32{(0,100)}
Recommended action
To resolve this issue:
1.Identify whether the overflowing received routes are necessary for forwarding services.
  - If the overflowing received routes are necessary, proceed to step 7.
  - If the overflowing received routes are not necessary, proceed to step 2.
2.Execute the display current-configuration configuration bgp command to view the current BGP configurations. Check for configurations that cause the local device to receive too many unnecessary routes. Such configurations include peer prefix-list, peer filter-policy, peer as-path-acl, filter-policy, and peer route-policy.
  - If the local device has some configurations that affect the route reception policy, proceed to step 3.
  - If the local device does not have configurations that affect the route reception policy, proceed to step 4.
3.Edit those configurations to reduce the number of routes received by the local device, and then proceed to step 8.
4.Contact the administrator of the peer to check whether the number of BGP routes sent to the local device is appropriate:
  - If the number of BGP routes sent to the local device is appropriate, proceed to step 5.
  - If the number of BGP routes sent to the local device is not appropriate, proceed to step 6.
5.Notify the administrator of the BGP peer to reduce the number of BGP routes sent to the local device, and then proceed to step 8. To reduce the number of BGP routes sent to the local device, the administrator can use the following methods:
6.Notify the administrator of the BGP peer to edit the policy of route distribution to the local device, which prevents the local device from receiving unnecessary routes. Then, proceed to step 8.
7.Use the peer route-limit command to increase the maximum number of BGP routes that can be received from the peer. Then, proceed to step 8.
8.Check whether the hh3cBgpPeerRouteExceedClear message is generated on the device.
  - If the message is not generated, proceed to step 9.
9.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The number of routes received from a peer has dropped below the upper limit.
Recovery
Major
N/A (N/A)
ON
This notification is generated when the number of routes received from a peer has dropped below the upper limit. The upper limit refers to the value specified for the prefix-number argument when you execute the peer route-limit command for the peer.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-routeexceed-clear ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-routeexceed-clear ] command.
Object
OID (object name)
Index
Value range
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
Unsigned32{(0,100)}
Recommended action
hh3cBgpPeerEstablished
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.202.4.0.5
A peer session enters Established state
Recovery
Major
N/A (N/A)
ON
This notification is generated when the BGP session to a BGP peer is successfully established.
System impact
The BGP session is correctly established. If an SNMP notification is generated upon a BGP session state change in a VPN instance, the corresponding SNMPv3 packet will contain information about that VPN instance.
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-established ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-established ] command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.202.1.1.2.1.8 (hh3cBgpPeerLastError)
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
DisplayString
OCTET STRING (2)
1.3.6.1.4.1.25506.2.202.1.1.2.1.4 (hh3cBgpPeerState)
Peer state.
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
INTEGER
idle(1), connect(2), active(3), opensent(4), openconfirm(5), established(6)
Recommended action
hh3cBgpPeerBackwardTransition
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.202.4.0.6
A peer session enters a lower-level state.
Error
Major
1.3.6.1.4.1.25506.2.202.4.0.5 (hh3cBgpPeerEstablished)
ON
This notification is generated when the state of a BGP peer session transitions from an upper level (for example, Established) to a lower level (for example, OpenConfirm). A typical example is that the BFD session is disconnected. Possible reasons for generating this notification are as follows:
Incorrect BGP configuration.
BGP receives a notification because an error event occurs.
BGP message receiving or sending times out.
The BGP peer IP address is unreachable.
An incorrect BGP packet is received.
The directly connected BGP interface goes down.
The number of BGP routes exceeds the maximum number of BGP routes that can be received.
System impact
The device might not have the associated BGP route to guide traffic forwarding, resulting in service interruption. If an SNMP notification is generated upon a BGP session state change in a VPN instance, the corresponding SNMPv3 packet will contain information about that VPN instance.
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-backward-transition ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-backward-transition ] command.
Object
OID (object name)
Index
Value range
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
DisplayString
OCTET STRING (2)
Peer state.
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
INTEGER
1.3.6.1.4.1.25506.2.202.1.1.2.1.9 (hh3cBgpPeerUnAvaiReason)
Reason why the peer went down.
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
Recommended action
1.Execute the display current-configuration configuration bgp command to identify the settings that affect BGP session state.
  - If a setting that causes BGP session disconnection exists, execute the relevant command to cancel the setting.
  - If BGP uses a loopback interface as the source interface of TCP connections, execute the peer connect-interface or peer source-address command to specify the loopback interface as the source interface for establishing TCP connections.
  - To establish an EBGP session to an indirectly connected peer, make sure the peer ebgp-max-hop command is executed on both ends of the session.
  - If the peer ttl-security command is configured to enable BGP GTSM on the device, the device receives the BGP packets with a TTL in the range from 255 – the configured hop count + 1 to 255.
  - If no settings affect BGP session state, proceed to step 2.
2.Wait for a short period of time to exclude the cause of disconnection by BGP session reset. If the BGP session fails to restore to the Established state within a long period of time, proceed to step 3.
3.Execute the display current-configuration configuration bgp command to check for the configuration of the peer route-limit command, and the BGP/4/BGP_EXCEED_ROUTE_LIMIT log printed by the device.
  - If both the configuration and the log exist, the BGP session is disconnected because excessive BGP routes are received. In this case, verify that the maximum number of routes that can be received configured with the peer route-limit command is appropriate:
If the setting is appropriate, notify the administrator of the BGP peer to reduce the number of BGP routes sent to the local end.
If the setting is inappropriate, increase the maximum number of BGP routes that can be received on the local end.
  - If the configuration or the log does not exist, or neither of them exists, receiving excessive BGP routes is not the cause for the BGP session disconnection. In this case, proceed to step 4.
4.Execute the display bgp peer log-info command. From the command output, identify the BGP session disconnection cause based on the error code or subcode printed in the Notification Error/SubError field.
  - If the error code (Error) is 4, the local end fails to receive any keepalive or update messages from the peer end within the BGP session hold time. This results in BGP session disconnection. If the error code is 5 or 6, the BGP session is disconnected because the TCP connection has an error or the connection is actively disconnected. You can perform troubleshooting by using the following methods:
On the local end, ping the source address used for establishing TCP connections on the BGP peer. If the ping operation fails, execute the display ip routing-table command to identify whether a route is available to the BGP peer. If no routes are available to the BGP peer, troubleshoot IGP route, static route, or direct route settings.
Execute the display memory-threshold command to identify whether the device has reached the memory usage threshold. If the memory usage threshold is reached, proceed to step 5.
Execute the display cpu-usage command to identify whether the CPU usage is too high. If the CPU usage is too high, proceed to step 5.
Execute the display acl all command to identify whether a rule exists that denies port bgp or 179. If such an ACL exists, delete the ACL.
Execute the display interface command to identify whether the output interface associated with the next hop of the route to the BGP peer is up. If the output interface is down, execute the undo shutdown command to bring up the interface in the view of the interface. If the interface fails to be brought up, or the interface is up but the notification persists, proceed to step 5.
  - If the error code (Error) is 1 or 3, the device has received wrong BGP packets. Proceed to step 5.
5.If the issue persists, collect alarm information, configuration data, and the output information from the previous commands, and then contact H3C Support for help.
hh3cBgpVrfRouteNumReachThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.202.4.0.7
The number of VPN routes received from peers has exceeded the alarm threshold.
Error
Major
1.3.6.1.4.1.25506.2.202.4.0.8 (hh3cBgpVrfRouteNumReachThresholdClear)
ON
This notification is generated when the number of routes received from peers in an address family of a VPN instance has exceeded the alarm threshold.
System impact
The number of routes received by the VPN instance has exceeded the alarm threshold and the VPN instance stops receiving new routes.
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ vrfroutenum-threshold-exceed ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ vrfroutenum-threshold-exceed ] command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.202.1.2.1.1.1 (hh3cBgpVpnRouteType)
Route type.
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
Unsigned32
1.3.6.1.4.1.25506.2.202.1.2.1.1.2 (hh3cBgpVpnInstName)
VPN instance name.
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
OCTET STRING
0..31
1.3.6.1.4.1.25506.2.202.1.2.1.1.3 (hh3cBgpVpnAddressFamily)
Address family.
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
Unsigned32
1.3.6.1.4.1.25506.2.202.1.2.1.1.4 (hh3cBgpVpnCurrRouteNum)
Number of VPN routes in the BGP routing table.
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
Unsigned32
1.3.6.1.4.1.25506.2.202.1.2.1.1.5 (hh3cBgpVpnThresholdValue)
The device generates an alarm notification when the ratio of the number of VPN routes to the maximum number of VPN routes exceeds the threshold.
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
Unsigned32
Recommended action
1.Use the display bgp routing-table { ipv4 | ipv6 } vpn-instace command to check whether the number of routes received from peers in the VPN instance has reached the alarm threshold.
  - If the alarm threshold is reached, proceed to step 2.
  - If the alarm threshold is not reached, proceed to step 10.
8.In the corresponding address family view, increase the maximum number of BGP routes that can be received from peers or increase the alarm threshold. Then, proceed to step 9.
9.Check whether the hh3cBgpVrfRouteNumReachThresholdClear message is generated on the device.
Basic information
OID
Event
Severity
Default status
The number of VPN routes received from peers has dropped below the alarm threshold.
Recovery
Major
N/A (N/A)
ON
This notification is generated when the number of routes received from peers in an address family of a VPN instance has dropped below the alarm threshold.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ vrfroutenum-threshold-clear ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ vrfroutenum-threshold-clear ] command.
Object
OID (object name)
Index
Value range
Route type.
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
Unsigned32
VPN instance name.
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
OCTET STRING
0..31
Address family.
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
Unsigned32
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
Unsigned32
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
Unsigned32
Recommended action
hh3cBgpPeerAFRouteThresholdExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.202.4.0.9
The number of routes received from a peer in an address family has exceeded the alarm threshold.
Error
Major
1.3.6.1.4.1.25506.2.202.4.0.10 (hh3cBgpPeerAFRouteThresholdClear)
ON
This notification is generated when the number of routes received from a peer in an address family has reached the alarm threshold. The alarm threshold refers to the value specified for the percentage-value argument when you execute the peer route-limit command for the peer. The device generates an alarm message when the ratio of M to N exceeds the alarm threshold:
System impact
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-addrfamily-routethreshold-exceed ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-addrfamily-routethreshold-exceed ] command.
Object
OID (object name)
Index
Value range
Address family.
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
Unsigned32
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
1.3.6.1.4.1.25506.2.202.2.1.1.1.1 (hh3cBgpInstanceName)
BGP process name.
hh3cBgpInstanceName
{(1,31)}
Recommended action
8.In the corresponding address family view, use the peer route-limit command to increase the maximum number of BGP routes that can be received from the peer or increase the alarm threshold. Then, proceed to step 9.
9.Check whether the hh3cBgpPeerAFRouteThresholdClear message is generated on the device.
Basic information
OID
Event
Severity
Default status
The number of routes received from a peer in an address family has dropped below the alarm threshold.
Recovery
Major
N/A (N/A)
ON
This notification is generated when the number of routes received from a peer in an address family has dropped below the alarm threshold. The alarm threshold refers to the value specified for the percentage-value argument when you execute the peer route-limit command for the peer. The device generates an alarm message when the ratio of M to N exceeds the alarm threshold:
System impact
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-addrfamily-routethreshold-clear ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-addrfamily-routethreshold-clear ] command.
Object
OID (object name)
Index
Value range
Address family.
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
Unsigned32
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
BGP process name.
hh3cBgpInstanceName
{(1,31)}
Recommended action
hh3cBgpPeerAFRouteExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.202.4.0.11
The number of routes received from a peer in an address family has exceeded the upper limit.
Error
Major
1.3.6.1.4.1.25506.2.202.4.0.12 (hh3cBgpPeerAFRouteExceedClear)
ON
This notification is generated when the number of routes received from a peer in an address family has exceeded the upper limit. The upper limit refers to the value specified for the prefix-number argument when you execute the peer route-limit command for the peer.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-addrfamily-routeexceed ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-addrfamily-routeexceed ] command.
Object
OID (object name)
Index
Value range
Address family.
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
Unsigned32
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
BGP process name.
hh3cBgpInstanceName
{(1,31)}
Recommended action
7.In the corresponding address family view, use the peer route-limit command to increase the maximum number of BGP routes that can be received from the peer. Then, proceed to step 8.
8.Check whether the hh3cBgpPeerAFRouteExceedClear message is generated on the device.
Basic information
OID
Event
Severity
Default status
The number of routes received from a peer in an address family has dropped below the upper limit.
Recovery
Major
N/A (N/A)
ON
This notification is generated when the number of routes received from a peer or peer group in an address family has dropped below the upper limit. The upper limit refers to the value specified for the prefix-number argument when you execute the peer route-limit command for the peer.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-addrfamily-routeexceed-clear ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-addrfamily-routeexceed-clear ] command.
Object
OID (object name)
Index
Value range
Address family.
hh3cBgpVpnRouteType
hh3cBgpVpnInstName
Unsigned32
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
Unsigned32
BGP process name.
hh3cBgpInstanceName
{(1,31)}
Recommended action
hh3cBgpPeerGRStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.202.4.0.13
The GR state of a BGP peer has changed.
Informational
Major
N/A (N/A)
ON
This notification is generated when the GR state of a BGP peer in a GR-capable BGP session has changed.
System impact
This alarm message notifies that the device starts the BGP GR process or exits from the BGP GR process. If the device unexpectedly exits from the BGP GR process when the alarm message is generated, the device must recreate the BGP peer session and performs route convergence, which might cause service interruption.
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-gr-status-change ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-gr-status-change ] command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.202.1.1.2.1.7 (hh3cBgpPeerGRStatus)
GR state of a remote BGP peer.
hh3cBgpPeerVpnIndex
hh3cBgpPeerType
hh3cBgpPeerIPAddr
INTEGER
peerNotBeingHelped(1),, peerRestarting(2),, peerFinishRestart(3),, peerHelping(4)
Recommended action
1.View the alarm message and determine whether this alarm message is a normal message generated during the GR process.
  - If the alarm message is a normal message, no action is required.
  - If the alarm message is not a normal message, proceed to step 2.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cBgpVpnRpkiSessionRoaExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.202.3.2.0.1
The number of ROAs received from an RPKI server has exceeded the upper limit.
Error
Major
1.3.6.1.4.1.25506.2.202.3.2.0.2 (hh3cBgpVpnRpkiSessionRoaExceedClear)
ON
This notification is generated when the number of ROAs received from an RPKI server has exceeded the upper limit. The upper limit refers to the value specified for the limit argument when you execute the rpki-limit command for the RPKI server.
System impact
The impact on the system varies by the configuration of the rpki-limit command:
If the alert-only keyword is not specified, the TCP connection between the device and the RPKI server will be terminated.
If the alert-only keyword is specified, this issue has no negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-rpkisession-roaexceed ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-rpkisession-roaexceed ] command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.202.3.1.4 (hh3cBgpVpnRpkiSessionRoaLimitNum)
Maximum number of ROAs that can be received from an RPKI server.
N/A
Unsigned32
Recommended action
1.Execute the display bgp rpki server command and view the ROAs(IPv4/IPv6) field in the command output to check whether the number of ROAs received from the RPKI server has reached the upper limit.
  - If the number of ROAs received from the RPKI server has reached the upper limit, proceed to step 2.
  - If the number of ROAs received from the RPKI server has not reached the upper limit, proceed to step 6.
2.Identify whether the overflowing received ROAs are necessary for current services.
  - If the overflowing received ROAs are necessary, proceed to step 5.
  - If the overflowing received ROAs are not necessary, proceed to step 3.
3.Contact the administrator of the RPKI server to check whether the ROAs advertised to the device are all necessary.
  - If the ROAs advertised to the device are all necessary, proceed to step 5.
  - If some of the ROAs advertised to the device are not necessary, proceed to step 4.
4.Notify the administrator of the RPKI server to withdraw unnecessary ROAs. If this issue persists, proceed to step 6.
5.Use the rpki-limit command on the device to increase the maximum number of ROAs that can be received from the RPKI server. If this issue persists, proceed to step 6.
6.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The number of ROAs received from an RPKI server has dropped below the upper limit.
Recovery
Major
N/A (N/A)
ON
This notification is generated when the number of ROAs received from an RPKI server has dropped below the upper limit. The upper limit refers to the value specified for the prefix-number argument when you execute the peer route-limit command for the peer.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable bgp [ peer-rpkisession-roaexceed-clear ] command.
OFF
CLI: Use the undo snmp-agent trap enable bgp [ peer-rpkisession-roaexceed-clear ] command.
Object
OID (object name)
Index
Value range
N/A
Unsigned32
Recommended action
