06-Layer 2 - LAN Switching
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R8530Pxx-6W10006-Layer 2 - LAN Switching
20-LLDP-EXT-DOT1-MIB
20-LLDP-EXT-DOT1-MIB 120.91 KB
LLDP-EXT-DOT1-MIB
About this MIB
For network managers to discover inconsistent or incorrect VLAN configurations and different supported protocols on interconnected ports, LLDP must implement the IEEE 802.1 organizationally specific extended features.
LLDP-EXT-DOT1-MIB is one of the four MIBs available for LLDP, which also include LLDP-MIB, LLDP-EXT-DOT3-MIB, and LLDP-MED-MIB. This MIB is a standard public MIB, which contains LDDP configuration, local and neighboring LLDP information.
MIB file name
lldp-ext-dot1.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).lldpMIB(2).lldpObjects(1).lldpExtnesions(5).lldpXdot1MIB(32962)
Tabular objects
lldpXdot1ConfigPortVlanTable
About this table
This table controls selection of LLDP Port VLAN-ID TLVs to be transmitted on individual ports.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is lldpPortConfigPortNum.
Object (OID)
Access
Value range
Implementation
lldpXdot1ConfigPortVlanTxEnable (1.0.8802.1.1.2.1.5.32962.1.1.1.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable port VLAN TLV transmission on a given LLDP transmission capable port.
Default: true.
lldpXdot1ConfigVlanNameTable
About this table
This table controls selection of LLDP VLAN name TLV instances to be transmitted on individual ports.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
The table indexes are lldpLocPortNum and lldpXdot1LocVlanId.
Object (OID)
Access
Value range
Implementation
lldpXdot1ConfigVlanNameTxEnable (1.0.8802.1.1.2.1.5.32962.1.1.2.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable VLAN name TLV transmission on a given LLDP transmission capable port.
Default: false.
As a best practice, do not perform the walk operation from the MIB browser, because it takes a long time to walk through all ports and VLANs.
lldpXdot1ConfigProtoVlanTable
About this table
This table controls selection of LLDP port and protocol VLAN ID TLV instances to be transmitted on individual ports.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are lldpLocPortNum and lldpXdot1LocProtoVlanId.
Object (OID)
Access
Value range
Implementation
lldpXdot1ConfigProtoVlanTxEnable (1.0.8802.1.1.2.1.5.32962.1.1.3.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable Port and Protocol VLAN ID TLV transmission on a given LLDP transmission capable port.
Default: false.
lldpXdot1ConfigProtocolTable
About this table
This table controls selection of LLDP Protocol TLV instances to be transmitted on individual ports.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadNot supported
Columns
The table indexes are lldpLocPortNum and lldpXdot1LocProtocolIndex.
Object (OID)
Access
Value range
Implementation
lldpXdot1ConfigProtocolTxEnable (1.0.8802.1.1.2.1.5.32962.1.1.4.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable Protocol Identity TLV transmission on a given LLDP transmission capable port.
Not supported. The default is false if the port is operating in bridge mode.
lldpXdot1LocTable
About this table
This table contains one row per port for IEEE 802.1 organizationally defined LLDP extension on the local system.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is lldpLocPortNum.
Object (OID)
Access
Value range
Implementation
lldpXdot1LocPortVlanId (1.0.8802.1.1.2.1.5.32962.1.2.1.1.1)
read-only
Integer32
Integer32(0|1..4094)
PPVID.
As per the MIB.
lldpXdot1LocProtoVlanTable
About this table
This table contains one or more rows per Port and Protocol VLAN information about the local system.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
lldpXdot1LocProtoVlanId (1.0.8802.1.1.2.1.5.32962.1.2.2.1.1)
not-accessible
Integer32
Port and protocol VLAN ID.
As per the MIB.
lldpXdot1LocProtoVlanSupported (1.0.8802.1.1.2.1.5.32962.1.2.2.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether the given port (associated with the local system) supports port and protocol VLANs.
As per the MIB.
lldpXdot1LocProtoVlanEnabled (1.0.8802.1.1.2.1.5.32962.1.2.2.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates whether the port and protocol VLANs are enabled on the given port associated with the local system.
As per the MIB.
lldpXdot1LocVlanNameTable
About this table
This table contains one or more rows of VLAN name information on the local system.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
lldpXdot1LocVlanId (1.0.8802.1.1.2.1.5.32962.1.2.3.1.1)
not-accessible
VlanId
Standard MIB values.
ID of the VLAN to which the port belongs.
As per the MIB.
lldpXdot1LocVlanName (1.0.8802.1.1.2.1.5.32962.1.2.3.1.2)
read-only
SnmpAdminString
OCTET STRING (1..32)
VLAN name identified by the VLAN ID associated with the given port on the local system.
As per the MIB.
lldpXdot1LocProtocolTable
About this table
This table contains one or more rows per protocol identity information on the local system.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
Object (OID)
Access
Value range
Implementation
lldpXdot1LocProtocolIndex (1.0.8802.1.1.2.1.5.32962.1.2.4.1.1)
not-accessible
Integer32
Integer32(1..2147483647)
Protocol index.
Not supported. The value is 1 if the port is operating in bridge mode.
lldpXdot1RemTable
About this table
This table contains one or more rows per physical network connection.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, and lldpRemIndex.
Object (OID)
Access
Value range
Implementation
lldpXdot1RemPortVlanId (1.0.8802.1.1.2.1.5.32962.1.3.1.1.1)
read-only
Integer32
PVID of the given port on a neighboring device.
As per the MIB.
lldpXdot1RemProtoVlanTable
About this table
This table contains one or more rows per port and protocol VLAN information about the neighboring devices received on the given port.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, and lldpXdot1RemProtoVlanId.
Object (OID)
Access
Value range
Implementation
lldpXdot1RemProtoVlanId (1.0.8802.1.1.2.1.5.32962.1.3.2.1.1)
not-accessible
Integer32
Port and protocol VLAN ID of the given port on a neighboring device.
As per the MIB.
lldpXdot1RemProtoVlanSupported (1.0.8802.1.1.2.1.5.32962.1.3.2.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether the given port on the neighboring device supports port and protocol VLANs.
As per the MIB.
lldpXdot1RemProtoVlanEnabled (1.0.8802.1.1.2.1.5.32962.1.3.2.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates whether the port and protocol VLANs are enabled for the given port on the neighboring device.
As per the MIB.
lldpXdot1RemVlanNameTable
About this table
This table contains one or more rows per IEEE 802.1Q VLAN name information about the neighboring devices, received on the given port.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, lldpXdot1RemVlanId.
Object (OID)
Access
Value range
Implementation
lldpXdot1RemVlanId (1.0.8802.1.1.2.1.5.32962.1.3.3.1.1)
not-accessible
VlanId
ID of the VLAN to which the given port on a neighboring device belongs.
As per the MIB.
lldpXdot1RemVlanName (1.0.8802.1.1.2.1.5.32962.1.3.3.1.2)
read-only
SnmpAdminString
VLAN name identified by the VLAN ID on the neighboring device.
As per the MIB.
lldpXdot1RemProtocolTable
About this table
This table contains one or more rows per protocol information about the neighbor, received on the given port.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, lldpXdot1RemProtocolIndex.
Object (OID)
Access
Value range
Implementation
lldpXdot1RemProtocolIndex (1.0.8802.1.1.2.1.5.32962.1.3.4.1.1)
not-accessible
Integer32
Protocol index.
As per the MIB.
lldpXdot1RemProtocolId (1.0.8802.1.1.2.1.5.32962.1.3.4.1.2)
read-only
OCTET STRING
OCTET STRING (1..255)
ID of the protocol associated with the given port of a neighboring device.
As per the MIB.
