- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-PVST-MIB
- 10-HH3C-QINQV2-MIB
- 11-HH3C-VLANTERM-MIB
- 12-HH3C-LswMSTP-MIB
- 13-HH3C-LswVLAN-MIB
- 14-IEEE8021-CFM-MIB
- 15-IEEE8021-CFM-V2-MIB
- 16-IEEE8023-LAG-MIB
- 17-LLDP-EXT-MED-MIB
- 18-LLDP-EXT-DOT3-V2-MIB
- 19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-MIB
- 24-LLDP-V2-MIB
- 25-MAU-MIB
04-HH3C-LLDP-EXT-MIB | 107.72 KB |
HH3C-LLDP-EXT-MIB
About this MIB
The Link Layer Discovery Protocol (LLDP) is a Layer 2 industry-standard protocol (IEEE 802.1AB) that allows network devices from different vendors to discover neighbors and exchange system and configuration information.
This MIB defines private MIB objects for the following extended LLDP management features:
● Global LLDP configuration:
- Global status of LLDP.
- Global status of CDP compatibility.
● LLDP port configuration:
- Port-specific packet transmission settings of CDP-compatible LLDP.
- Protection action taken on ports whose neighbors fail validation.
- Protection action taken on ports whose neighbors age out.
● LLDP neighbor validation criteria:
- Chassis ID subtype.
- Chassis ID.
- Port ID subtype.
- Port ID.
● Feature status on LLDP-enabled ports:
- Neighbor validation status.
- Neighbor aging status.
● Trapping configuration on LLDP-enabled ports:
- Trapping for neighbor validation status changes.
- Trapping for neighbor aging status changes.
MIB file name
hh3c-lldp-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).huawei.h3c(10).h3cCommon(2).h3clldp(100)
Scalar objects
hh3clldpAdminStatus
(1.3.6.1.4.1.25506.2.100.1.1.1)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3clldpAdminStatus (1.3.6.1.4.1.25506.2.100.1.1.1) |
read-write |
TruthValue |
true(1) false(2) |
Global status of LLDP. |
As per the MIB. |
hh3clldpManAddr
(1.3.6.1.4.1.25506.2.100.3.1)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3clldpManAddr (1.3.6.1.4.1.25506.2.100.3.1) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (1..31) |
Management address. |
As per the MIB. |
Tabular objects
hh3clldpPortConfigTable
About this table
Use this table to configure LLDP on ports.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3clldpPortConfigPortNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3clldpPortConfigPortNum (1.3.6.1.4.1.25506.2.100.1.1.3.1.1) |
not-accessible |
LldpPortNumber |
Standard MIB values. |
Port index. |
As per the MIB. |
hh3clldpPortConfigCDPComplianceStatus (1.3.6.1.4.1.25506.2.100.1.1.3.1.2) |
read-write |
INTEGER |
txAndRx(1) disabled(2) |
Packet transmission capabilities of CDP-compatible LLDP. |
As per the MIB. |
hh3clldpPortConfigValidationAction (1.3.6.1.4.1.25506.2.100.1.1.3.1.3) |
read-write |
Integer32 |
Neighbor validation status. |
As per the MIB. |
Notifications
hh3clldpValidationStatusChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.100.2.0.1 |
Neighbor validation status changes. |
Informational |
Warning |
OFF |
Notification triggers
LLDP neighbor validation enables a port to validate the identity of the neighbor based on the neighbor validation criteria configured on the port. Each incoming LLDP packet must match all the validation criteria configured on the port. If the neighbor information in a packet does not match the criteria, the system shuts down the data link layer and disables data transmission on the port.
System impact
No negative impact on services.
Status control
ON
CLI: Use the lldp neighbor-protection validation command.
OFF
CLI: Use the undo lldp neighbor-protection validation command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.100.1.1.5.1.1 (hh3clldpPortStatusPortNum) |
Port index. |
hh3clldpPortStatusPortNum |
LldpPortNumber |
1.3.6.1.4.1.25506.2.100.1.1.5.1.2 (hh3clldpPortValidationStatus) |
Integer32 |
Recommended action
1.Verify that the neighbor matches all neighbor validation criteria configured on the port.
2.If the neighbor does not match all neighbor validation criteria configured on the port, notify the administrator of the neighbor to configure LLDP related settings to establish the LLDP neighbor relationship.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3clldpAgingStatusChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.100.2.0.2 |
Neighbor aging status changes. |
Informational |
Warning |
N/A (N/A) |
OFF |
The system blocks or shuts down an LLDP neighbor aging-enabled port if the neighbor on the port ages out.
System impact
Status control
ON
CLI: Use the lldp neighbor-protection aging { block | shutdown } command.
OFF
CLI: Use the undo lldp neighbor-protection aging command.
Object
OID (object name) |
Index |
Type |
Value range |
Port index. |
LldpPortNumber |
1.3.6.1.4.1.25506.2.100.1.1.5.1.3 (hh3clldpPortAgingStatus) |
Neighbor aging status. |
N/A |
Integer32 |
Recommended action
Identify whether a neighbor has aged out.
hh3clldpGlobalEnableStatus
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.100.2.0.3 |
Enabling status of LLDP changes globally. |
Informational |
Warning |
ON |
This notification is generated when the enabling status of LLDP changes globally.
System impact
Status control
ON
CLI: Use the lldp global enable command.
OFF
CLI: Use the undo lldp global enable command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.100.1.1.1 (hh3clldpAdminStatus) |
Enabling status of LLDP on the device. |
N/A |
TruthValue |
Recommended action
LLDP takes effect on a port only when LLDP is enabled both globally and on the port.
hh3clldpgLocManAddrChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.100.2.0.4 |
Management address advertised by LLDP changes. |
Informational |
Warning |
ON |
This notification is generated when the management address advertised by LLDP changes.
System impact
Status control
ON
CLI: Use the lldp tlv-enable basic-tlv management-address-tlv command.
OFF
CLI: Use the undo lldp tlv-enable basic-tlv management-address-tlv command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.100.3.1 (hh3clldpManAddr) |
N/A |
OCTET STRING |
Recommended action
If the LLDP management address to be advertised is incorrect, execute the lldp tlv-enable basic-tlv management-address-tlv command on the port to change the LLDP management address to be advertised.
