06-Layer 2 - LAN Switching
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R8530Pxx-6W10006-Layer 2 - LAN Switching
01-BRIDGE-MIB
01-BRIDGE-MIB 79.88 KB
BRIDGE-MIB
About this MIB
Use this MIB to obtain basic bridge information, collect diagnosis information, and configure the system operating mode.
MIB file name
rfc1493-bridge.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).dot1dBridge(17)
Tabular objects
dot1dBasePortTable
About this table
This table contains generic information about every port that is associated with this bridge.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is dot1dBasePort.
Object (OID)
Access
Value range
Implementation
dot1dBasePort (1.3.6.1.2.1.17.1.4.1.1)
read-only
INTEGER
(1..65535)
Port number of the port for which this entry contains bridge management information.
As per the MIB.
dot1dBasePortIfIndex (1.3.6.1.2.1.17.1.4.1.2)
read-only
INTEGER
Standard MIB values.
Value of the instance of the ifIndex object for the interface corresponding to this port.
As per the MIB.
dot1dBasePortCircuit (1.3.6.1.2.1.17.1.4.1.3)
read-only
OBJECT IDENTIFIER
Name of an object instance unique to this port.
As per the MIB.
dot1dBasePortDelayExceededDiscards (1.3.6.1.2.1.17.1.4.1.4)
read-only
Counter
Number of frames discarded by this port due to excessive transit delay through the bridge.
As per the MIB.
dot1dBasePortMtuExceededDiscards (1.3.6.1.2.1.17.1.4.1.5)
read-only
Counter
Number of frames discarded by this port due to an excessive size.
As per the MIB.
dot1dStpPortTable
About this table
This table that contains port-specific information for the Spanning Tree Protocol.
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is dot1dStpPort.
Object (OID)
Access
Value range
Implementation
dot1dStpPort (1.3.6.1.2.1.17.2.15.1.1)
read-only
INTEGER
(1..65535)
Port number of the port for which this entry contains Spanning Tree Protocol management information.
As per the MIB.
dot1dStpPortPriority (1.3.6.1.2.1.17.2.15.1.2)
read-write
INTEGER
(0..240)
Value of the priority field which is contained in the first (in network byte order) octet of the (2 octet long) Port ID.
As per the MIB.
dot1dStpPortState (1.3.6.1.2.1.17.2.15.1.3)
read-only
INTEGER
disabled(1),
blocking(2),
listening(3),
learning(4),
forwarding(5),
broken(6)
Port's current state as defined by application of the Spanning Tree Protocol.
As per the MIB.
dot1dStpPortEnable (1.3.6.1.2.1.17.2.15.1.4)
read-write
INTEGER
enabled(1),
disabled(2)
Enabled/disabled status of the port.
As per the MIB.
dot1dStpPortPathCost (1.3.6.1.2.1.17.2.15.1.5)
read-write
INTEGER
(1..65535)
Contribution of this port to the path cost of paths towards the spanning tree root which include this port.
In the current software version, this object supports only the IEEE802.1d-1990 standard, and the value range is 1 to 65535. If the actual value is greater than 65535 in another standard, the object value is 65535.
dot1dStpPortDesignatedRoot (1.3.6.1.2.1.17.2.15.1.6)
read-only
BridgeId
Unique Bridge Identifier of the Bridge recorded as the Root in the Configuration BPDUs transmitted by the Designated Bridge for the segment to which the port is attached.
As per the MIB.
dot1dStpPortDesignatedCost (1.3.6.1.2.1.17.2.15.1.7)
read-only
INTEGER
Path cost.
As per the MIB.
dot1dStpPortDesignatedBridge (1.3.6.1.2.1.17.2.15.1.8)
read-only
BridgeId
Bridge identifier.
As per the MIB.
dot1dStpPortDesignatedPort (1.3.6.1.2.1.17.2.15.1.9)
read-only
OCTET STRING
(SIZE (2))
Port identifier of the port on the Designated Bridge for this port's segment.
As per the MIB.
dot1dStpPortForwardTransition (1.3.6.1.2.1.17.2.15.1.10)
read-only
Counter
Number of times this port has transitioned from the Learning state to the Forwarding state.
As per the MIB.
