06-Layer 2 - LAN Switching
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R8530Pxx-6W10006-Layer 2 - LAN Switching
14-IEEE8021-CFM-MIB
14-IEEE8021-CFM-MIB 153.16 KB
IEEE8021-CFM-MIB
About this MIB
Connectivity Fault Management (CFM) is the name of the feature defined in IEEE 802.1ag for end-to-end Operations, Administration and Maintenance (OAM) for Ethernet. In the Comware platform, the feature is called Connectivity Fault Detection (CFD).
CFD is an end-to-end per-VLAN link layer OAM mechanism. CFD is used for link connectivity detection, fault verification, and fault location.
This MIB defines how to implement CFD. Use this MIB to configure CFD on managed devices.
MIB file name
ieee8021-cfm.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbered-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).ieee8021CfmMib(8)
Scalar objects
dot1agCfmMdTableNextIndex (1.3.111.2.802.1.1.8.1.5.1)
Object (OID)
Access
Value range
Implementation
read-only
Dot1afCfmIndexIntegerNextFree
Unsigned32 (1..4294967295)
Value to be used as a new index in the MD table.
As per the MIB.
Tabular objects
dot1agCfmMdTable
About this table
Use this table to obtain the MD information.
Support for operations
CreateThe dot1agCfmMdIndex index must be configured. The index is provided by the dot1agCfmMdTableNextIndex object.
The dot1agCfmMdMdLevel object must be configured.
The dot1agCfmMdFormat object is optional. If it is not configured, the default value is charString(4).
The dot1agCfmMdName object is optional. When the dot1agCfmMdFormat object is set to none(1), the MIB will automatically ignore the input value no matter whether the dot1agCfmMdName object is configured. When the dot1agCfmMdFormat object is set to any other value, you must configure the dot1agCfmMdName object, and the MIB will read the input value.
The dot1agCfmMdMhfCreation object is optional. If it is not configured, the default value is defMHFnone(1), and only the value is available.
The dot1agCfmMdMhfIdPermission object is optional. If it is not configured, the default value is sendIdNone(1), and only the value is available.
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table index is dot1agCfmMdIndex.
Object (OID)
Access
Value range
Implementation
dot1agCfmMdIndex (1.3.111.2.802.1.1.8.1.5.2.1.1)
not-accessible
Unsigned32
Unsigned32(1..4294967295)
MD table index.
As per the MIB.
dot1agCfmMdFormat (1.3.111.2.802.1.1.8.1.5.2.1.2)
read-create
Dot1agCfmMaintDomainNameType
INTEGER {
none (1)
dnsLikeName(2)
macAddressAndUint (3)
charString (4)
MD name type.
As per the MIB.
dot1agCfmMdName (1.3.111.2.802.1.1.8.1.5.2.1.3)
read-create
OCTET STRING(1..43)
MD name.
The MD name must be unique. After an MD is created, its name cannot be modified. When the format is set to macAddressAndUint(3), you must enter eight bytes, where the first fix bytes specify the MAC address and the last two bytes specify the subnumber.
dot1agCfmMdMdLevel (1.3.111.2.802.1.1.8.1.5.2.1.4)
read-create
Dot1agCfmMDLevel
Integer32 (0..7)
MD level.
Eight MD levels are available, 0 to 7. The MD level cannot be modified after an MD is created.
dot1agCfmMdMhfCreation (1.3.111.2.802.1.1.8.1.5.2.1.5)
read-create
Dot1agCfmMhfCreation
INTEGER {
defMHFnone(1),
defMHFdefault(2),
defMHFexplicit(3)
Enumerated value indicating whether the management entity can create MHFs (MIP Half Function) for this MD.
This object is insignificant. This object cannot be modified after an MD is created. The default is defMHFnone(1), and only the value is supported.
dot1agCfmMdMhfIdPermission (1.3.111.2.802.1.1.8.1.5.2.1.6)
read-create
Dot1agCfmIdPermission
INTEGER {
sendIdNone(1),
sendIdChassis(2),
sendIdManage(3),
sendIdChassisManage(4)
Enumerated value indicating what, if anything, is to be included in the Sender ID TLV (21.5.3) transmitted by MPs configured in this MD.
The default value is sendIdNone(1), and only the value is available.
dot1agCfmMdMaNextIndex (1.3.111.2.802.1.1.8.1.5.2.1.7)
read-only
Dot1afCfmIndexIntegerNextFree,
Index of the next MA to be created.
As per the MIB.
dot1agCfmMdRowStatus (1.3.111.2.802.1.1.8.1.5.2.1.8)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Available values are active(1), createAndGo(4), and destroy(6).
dot1agCfmMaNetTable
About this table
Use this table to obtain the MA network information.
CreateThe dot1agCfmMdIndex must be configured. The index is provided by dot1agCfmMdIndex in the dot1agCfmMdTable object.
The dot1agCfmMaIndex and dot1agCfmMaNetName indexes are required. When configuring the dot1agCfmMaIndex index, the index is provided by the dot1agCfmMdMaNextIndex in the dot1agCfmMdTable table. When you use the dot1agCfmMaNetName object to configure a name, the name can contain only digits, letters, and underscores (_).
The dot1agCfmMaNetFormat object must be configured.
The dot1agCfmMaNetCcmInterval object is optional. If it is not configured, the default value is interval1s (4).
Edit/ModifyOnly the dot1agCfmMaNetCcmInterval object value can be modified.
The values of the other objects cannot be modified. To modify them, first delete this row, and then create a new one.
DeleteSupported
ReadSupported
Columns
The table indexes are dot1agCfmMdIndex and dot1agCfmMaIndex.
Object (OID)
Access
Value range
Implementation
dot1agCfmMaIndex (1.3.111.2.802.1.1.8.1.6.1.1.1)
not-accessible
Unsigned32
MA index.
This object cannot be modified after being created.
dot1agCfmMaNetFormat (1.3.111.2.802.1.1.8.1.6.1.1.2)
read-create
Dot1agCfmMaintAssocNameType
INTEGER {
primaryVid (1),
charString (2),
unsignedInt16 (3), iccFormat (32)
MA name format.
dot1agCfmMaNetName (1.3.111.2.802.1.1.8.1.6.1.1.3)
read-create
OCTET STRING (1..45)
MA name.
This object cannot be modified after being created. The total length of the MA name and its MD name cannot exceed 44 bytes.
dot1agCfmMaNetCcmInterval (1.3.111.2.802.1.1.8.1.6.1.1.4)
read-create
Dot1agCfmCcmInterval
INTEGER {
intervalInvalid (0),
interval300Hz (1),
interval10ms (2),
interval100ms (3),
interval1s (4),
interval10s (5),
interval1min (6),
interval10min (7)
CCM transmission interval.
As per the MIB.
dot1agCfmMaNetRowStatus (1.3.111.2.802.1.1.8.1.6.1.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
dot1agCfmMaMepListTable
About this table
CreateThe dot1agCfmMdIndex must be configured. The index is provided by the dot1agCfmMdIndex in the dot1agCfmMdTable object.
The dot1agCfmMaIndex must be configured. The index is provided by the dot1agCfmMaIndex in the dot1agCfmMaNetTable object.
The dot1agCfmMaMepListIdentifier object must be configured.
DeleteSupported
ReadSupported
Columns
The table indexes are dot1agCfmMdIndex, dot1agCfmMaIndex, and  dot1agCfmMaMepListIdentifier.
Object (OID)
Access
Value range
Implementation
dot1agCfmMaMepListIdentifier (1.3.111.2.802.1.1.8.1.6.3.1.1)
not-accessible
Dot1agCfmMepId
Unsigned32 (1..8191)
MEP ID.
dot1agCfmMaMepListRowStatus (1.3.111.2.802.1.1.8.1.6.3.1.2)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
dot1agCfmMepTable
About this table
Use this table to obtain the MEP information.
The dot1agCfmMaIndex must be configured. The index is provided by the dot1dot1agCfmMaIndex in the dot1agCfmMaNetTable object.
Indexes dot1agCfmMepIdentifier and dot1agCfmMepIfIndex and non-index dot1agCfmMepDirection must be configured.
Edit/ModifyThe dot1agCfmMepActive and dot1agCfmMepCciEnabled object values can be modified.
DeleteSupported
ReadSupported
Columns
The table indexes are dot1agCfmMdIndex, dot1agCfmMaIndex, and dot1agCfmMepIdentifier.
Object (OID)
Access
Value range
Implementation
dot1agCfmMepIdentifier (1.3.111.2.802.1.1.8.1.7.1.1.1)
not-accessible
Dot1agCfmMepId
MEP ID.
dot1agCfmMepIfIndex (1.3.111.2.802.1.1.8.1.7.1.1.2)
read-create
InterfaceIndexOrZero
Integer32 (0..2147483647)
Interface index of an MEP.
As per the MIB.
dot1agCfmMepDirection (1.3.111.2.802.1.1.8.1.7.1.1.3)
read-create
Dot1agCfmMpDirection
INTEGER {
down  (1),
up (2)
MEP direction.
dot1agCfmMepPrimaryVid (1.3.111.2.802.1.1.8.1.7.1.1.4)
read-create
Unsigned32
Unsigned32(0..16777215)
VLAN of the MEP.
The value 0 indicates that either the primary VID is that of the MEP's MA, or that the MEP's MA is associated with no VID.
dot1agCfmMepActive (1.3.111.2.802.1.1.8.1.7.1.1.5)
read-create
TruthValue
true(1),
false(2)
Enabling state of the MEP.
The value must be true (1), and cannot be modified once the MEP is created.
dot1agCfmMepFngState (1.3.111.2.802.1.1.8.1.7.1.1.6)
read-only
Dot1agCfmFngState
INTEGER {
fngReset (1),
fngDefect (2),
fngReportDefect (3),
fngDefectReported(4),
fngDefectClearing(5)
FNG state machine state of the MEP.
As per the MIB.
dot1agCfmMepCciEnabled (1.3.111.2.802.1.1.8.1.7.1.1.7)
read-create
TruthValue
true(1),
false(2)
Whether to enable the MEP to send CCM packets.
As per the MIB.
dot1agCfmMepCcmLtmPriority (1.3.111.2.802.1.1.8.1.7.1.1.8)
read-create
Unsigned32
Unsigned32(0..7)
Priority of CCM packets sent by the MEP.
Not supported
dot1agCfmMepMacAddress (1.3.111.2.802.1.1.8.1.7.1.1.9)
read-only
MacAddress
OCTET STRING(6)
MEP MAC address.
Not supported
dot1agCfmMepLowPrDef (1.3.111.2.802.1.1.8.1.7.1.1.10)
read-create
Dot1agCfmLowestAlarmPri
INTEGER {
allDef (1),
macRemErrXcon(2),
remErrXcon (3),
errXcon (4),
 xcon (5),
noXcon (6)
Lowest priority defect that is allowed to generate fault alarms.
Not supported
dot1agCfmMepFngAlarmTime (1.3.111.2.802.1.1.8.1.7.1.1.11)
read-create
TimeInterval
250..1000
The time that defects must be present before a fault alarm is issued.
Not supported
dot1agCfmMepFngResetTime (1.3.111.2.802.1.1.8.1.7.1.1.12)
read-create
TimeInterval
250..1000
The time that defects must be absent before resetting a fault alarm.
Not supported
dot1agCfmMepHighestPrDefect (1.3.111.2.802.1.1.8.1.7.1.1.13)
read-only
Dot1agCfmHighestDefectPri
INTEGER {
none  (0),
defRDICCM (1),
defMACstatus  (2),
defRemoteCCM (3),
defErrorCCM (4),
defXconCCM  (5)
Highest-priority fault of the MEP.
In the current software version, only fault types defRemoteCCM(3), defErrorCCM(4), and defXconCCM (5) are supported.
dot1agCfmMepDefects (1.3.111.2.802.1.1.8.1.7.1.1.14)
read-only
Dot1agCfmMepDefects
BITS {             bDefRDICCM(0),
             bDefMACstatus(1),
bDefRemoteCCM(2),
bDefErrorCCM(3),
bDefXconCCM(4)
MEP fault state.
Not supported
dot1agCfmMepErrorCcmLastFailure (1.3.111.2.802.1.1.8.1.7.1.1.15)
read-only
OCTET STRING
OCTET STRING (1..1522)
Last-received CCM packet that triggered a DefError CCM fault.
Not supported
dot1agCfmMepXconCcmLastFailure (1.3.111.2.802.1.1.8.1.7.1.1.16)
read-only
OCTET STRING
Last-received CCM packet that triggered a DefXcon CCM fault.
Not supported
dot1agCfmMepCcmSequenceErrors (1.3.111.2.802.1.1.8.1.7.1.1.17)
read-only
Counter32
Standard MIB values.
Total number of out-of-sequence CCM packets received.
Not supported
dot1agCfmMepCciSentCcms (1.3.111.2.802.1.1.8.1.7.1.1.18)
read-only
Counter32
Total number of CCM packets sent.
Not supported
dot1agCfmMepNextLbmTransId (1.3.111.2.802.1.1.8.1.7.1.1.19)
read-only
Unsigned32
Next sequence number.
Not supported
dot1agCfmMepLbrIn (1.3.111.2.802.1.1.8.1.7.1.1.20)
read-only
Counter32
Total number of LBR packets received.
Not supported
dot1agCfmMepLbrInOutOfOrder (1.3.111.2.802.1.1.8.1.7.1.1.21)
read-only
Counter32
Total number of out-of-sequence LBR packets received.
Not supported
dot1agCfmMepLbrBadMsdu (1.3.111.2.802.1.1.8.1.7.1.1.22)
read-only
Counter32
Total number of bad LBR packets.
Not supported
dot1agCfmMepLtmNextSeqNumber (1.3.111.2.802.1.1.8.1.7.1.1.23)
read-only
Unsigned32
Next sequence number of the LT packet.
Not supported
dot1agCfmMepUnexpLtrIn (1.3.111.2.802.1.1.8.1.7.1.1.24)
read-only
Counter32
Total number of LTR packets
Not supported
dot1agCfmMepLbrOut (1.3.111.2.802.1.1.8.1.7.1.1.25)
read-only
Counter32
Total number of LBR packets sent.
Not supported
dot1agCfmMepTransmitLbmStatus (1.3.111.2.802.1.1.8.1.7.1.1.26)
read-create
TruthValue
true(1),
false(2)
Whether to forward LBM packets.
Not supported
dot1agCfmMepTransmitLbmDestMacAddress (1.3.111.2.802.1.1.8.1.7.1.1.27)
read-create
MacAddress
OCTET STRING(6)
Destination MAC address of LBM packets.
Not supported
dot1agCfmMepTransmitLbmDestMepId (1.3.111.2.802.1.1.8.1.7.1.1.28)
read-create
Dot1agCfmMepIdOrZero
MEP ID.
Not supported
dot1agCfmMepTransmitLbmDestIsMepId (1.3.111.2.802.1.1.8.1.7.1.1.29)
read-create
TruthValue
true(1),
false(2)
Whether the LBM packets are transmitted by using the MEP ID or destination MAC address.
Not supported
dot1agCfmMepTransmitLbmMessages (1.3.111.2.802.1.1.8.1.7.1.1.30)
read-create
Integer32
Integer32(1..1024)
Total number of LBM packets sent.
Not supported
dot1agCfmMepTransmitLbmDataTlv (1.3.111.2.802.1.1.8.1.7.1.1.31)
read-create
OCTET STRING
OCTET STRING (0..1500)
Data in TLVs.
Not supported
dot1agCfmMepTransmitLbmVlanPriority (1.3.111.2.802.1.1.8.1.7.1.1.32)
read-create
Integer32
OCTET STRING (0..7)
Priority.
Not supported
dot1agCfmMepTransmitLbmVlanDropEnable (1.3.111.2.802.1.1.8.1.7.1.1.33)
read-create
TruthValue
true(1),
false(2)
Whether to enable dropping packets.
Not supported
dot1agCfmMepTransmitLbmResultOK (1.3.111.2.802.1.1.8.1.7.1.1.34)
read-only
TruthValue
true(1),
false(2)
Whether to send LBM packets.
Not supported
dot1agCfmMepTransmitLbmSeqNumber (1.3.111.2.802.1.1.8.1.7.1.1.35)
read-only
Unsigned32
ID of the first LBM packet sent.
Not supported
dot1agCfmMepTransmitLtmStatus (1.3.111.2.802.1.1.8.1.7.1.1.36)
read-create
TruthValue
true(1),
false(2)
Whether to send the next LTM packet.
Not supported
dot1agCfmMepTransmitLtmFlags (1.3.111.2.802.1.1.8.1.7.1.1.37)
read-create
BITS
useFDBonly (0)
Flag field in LTM packets.
Not supported
dot1agCfmMepTransmitLtmTargetMacAddress (1.3.111.2.802.1.1.8.1.7.1.1.38)
read-create
MacAddress
OCTET STRING(6)
Destination MAC address.
Not supported
dot1agCfmMepTransmitLtmTargetMepId (1.3.111.2.802.1.1.8.1.7.1.1.39)
read-create
Whether the sent packets carry the destination MAC address.
Not supported
dot1agCfmMepTransmitLtmTargetIsMepId (1.3.111.2.802.1.1.8.1.7.1.1.40)
read-create
TruthValue
true(1),
false(2)
Whether the LTM packets use the MEP ID.
Not supported
dot1agCfmMepTransmitLtmTtl (1.3.111.2.802.1.1.8.1.7.1.1.41)
read-create
Unsigned32
Unsigned32(0..255)
TTL
Not supported
dot1agCfmMepTransmitLtmResult (1.3.111.2.802.1.1.8.1.7.1.1.42)
read-only
TruthValue
true(1),
false(2)
Whether to send LTM packets.
Not supported
dot1agCfmMepTransmitLtmSeqNumber (1.3.111.2.802.1.1.8.1.7.1.1.43)
read-only
Unsigned32
LTM transaction identifier of the LTM sent.
Not supported
dot1agCfmMepTransmitLtmEgressIdentifier (1.3.111.2.802.1.1.8.1.7.1.1.44)
read-create
OCTET STRING
OCTET STRING(8)
ID of the egress of the LTM packets.
Not supported
dot1agCfmMepRowStatus (1.3.111.2.802.1.1.8.1.7.1.1.45)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
dot1agCfmMepPbbTeCanReportPbbTePresence (1.3.111.2.802.1.1.8.1.7.1.1.46)
read-create
TruthValue
true(1),
false(2)
Whether the PBB-TE reporting capability is supported.
Not supported
dot1agCfmMepPbbTeTrafficMismatchDefect (1.3.111.2.802.1.1.8.1.7.1.1.47)
read-only
TruthValue
true(1),
false(2)
Whether traffic mismatch errors have been detected.
Not supported
dot1agCfmMepPbbTransmitLbmLtmReverseVid (1.3.111.2.802.1.1.8.1.7.1.1.48)
read-create
IEEE8021VlanIndex
Unsigned32 (1..4094|4096..4294967295)
PBB VID carried in LTM packets.
Not supported
dot1agCfmMepPbbTeMismatchAlarm      (1.3.111.2.802.1.1.8.1.7.1.1.49)
read-create
TruthValue
true(1),
false(2)
Whether PBB-TE errors or PBB-TE alarms are detected.
Not supported
dot1agCfmMepPbbTeLocalMismatchDefect (1.3.111.2.802.1.1.8.1.7.1.1.50)
read-only
TruthValue
true(1),
false(2)
Whether local PBB-TE errors have been detected.
Not supported
dot1agCfmMepPbbTeLocalMismatchSinceReset (1.3.111.2.802.1.1.8.1.7.1.1.51)
read-only
TruthValue
true(1),
false(2)
Whether the local PBB-TE errors start from the reset state.
Not supported
Notifications
dot1agCfmFaultAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.111.2.802.1.1.8.0.1
A MEP error occurs.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is sent when the MEP continuously fails.
Possible causes might include the following:
The CFD entities at the two ends have inconsistent MDs or MAs.
The CFD entities at the two ends have inconsistent CCM intervals.
The MEP ID in CCMs is not in the MEP ID on the local end.
No CCM is received upon expiration of the specified timer.
System impact
Continuity check cannot be performed. Service traffic switchover or interruption might occur.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.111.2.802.1.1.8.1.5.2.1.1 (dot1agCfmMdIndex)
MD index.
dot1agCfmMdIndex
Integer32
1.. 4294967295
1.3.111.2.802.1.1.8.1.6.1.1.1 (dot1agCfmMaIndex)
MA index.
dot1agCfmMaIndex
Integer32
1.. 4294967295
1.3.111.2.802.1.1.8.1.7.1.1.1 (dot1agCfmMepIdentifier)
MEP ID and ultimate index in the MEP list
dot1agCfmMdIndex
dot1agCfmMaIndex
Integer32
1.. 8191
1.3.111.2.802.1.1.8.1.7.1.1.13 (dot1agCfmMepHighestPrDefect)
Detected faulty MEP.
dot1agCfmMdIndex
dot1agCfmMaIndex
none (0), defRemoteCCM (3), defErrorCCM (4), defXconCCM (5)
Recommended action
To resolve this issue:
1.Identify whether the CFD configuration is correct.
2.Identify whether the port and link states are normal.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
