- 18-Security Configuration Guide
- 01-APR configuration
- 02-ARP attack protection configuration
- 03-ASPF configuration
- 04-FIPS configuration
- 05-Keychain configuration
- 06-mGRE configuration
- 07-ND attack defense configuration
- 08-PKI configuration
- 09-SSH configuration
- 10-SSL configuration
- 11-uRPF configuration
- 12-Session management
- 13-Public key management
- 14-Crypto engine configuration
- 15-IP-based attack prevention configuration
- 16-Security zone configuration
- 17-Security policy configuration
- 18-Object group configuration
- 19-Attack detection and prevention configuration
- 20-Connection limit configuration
- 21-Packet filter configuration
- 22-IP source guard configuration
| 16-Security zone configuration | 76.12 KB |
Security zone-based packet processing rules
Security zone configuration tasks at a glance
Adding members to a security zone
Specifying the default action for packets between interfaces in the same security zone
Verifying and maintaining security zones
Configuring security zones
About security zones
You can configure security zones to implement security zone-based security management.
Basic concepts
The security zone feature includes the following basic concepts:
· Security zone—A security zone is a collection of interfaces that have the same security requirements.
· System-defined security zones—The device provides the following system-defined security zones: Local, Trust, DMZ, Management, and Untrust. The system creates these security zones automatically when one of following events occurs:
¡ The first command for creating a security zone is executed.
¡ The first command related to creating an interzone policy is executed.
System-defined security zones cannot be deleted.
· DMZ—A demilitarized zone is a network that is separate from the internal network and the external network both logically and physically. Typically, a DMZ contains devices for the public to access, such as the Web servers and FTP servers.
The following table describes how the device handles packets when security zone-based security management is configured:
Packets |
Action |
Packets between an interface that is in a security zone and an interface that is not in any security zone |
Discard. |
Packets between two interfaces that are in the same security zone |
Discard by default. |
Packets between two interfaces that belong to different security zones |
Forward or discard, depending on the matching interzone policy. If no policy is applied or the policy does not exist or does not take effect, the packets are discarded. For more information, see "Creating a security zone." |
Packets between two interfaces that are not in any security zone |
Packets originated from or destined for the device itself |
Forward or discard, depending on the matching interzone policy. By default, these packets are discarded. |
Application scenarios
As a best practice, use security zone-based security management if the firewall is connected to multiple network segments or the network topology might change.
The traditional security management technology is based on interfaces. To filter packets, you must apply interzone policies on the inbound and outbound interfaces of a firewall. When the firewall is connected to multiple network segments, deploying interzone policies is time consuming and complicated. If the network topology changes, you might have to reconfigure interzone policies.
To configure security zones, perform the following tasks:
· Adding members to a security zone
· (Optional.) Specifying the default action for packets between interfaces in the same security zone
1. Enter system view.
2. Create a security zone and enter security zone view.
security-zone name zone-name
By default, security zones Local, Trust, DMZ, Management, and Untrust exist.
A security zone can include member types listed in Table 1.
Table 1 Security zone members and objects that the members identify
Security zone member |
Objects that each member identifies |
Layer 3 interface: · Layer 3 Ethernet interface · Layer 3 logical interface, such as a Layer 3 subinterface |
All packets received or sent on the interface |
IPv4 subnet |
All packets sourced from or destined for the IPv4 subnet. |
IPv6 subnet |
All packets sourced from or destined for the IPv6 subnet. |
If a security zone has multiple types of members, a packet is matched in the following order: subnet and interface. The match operation stops when the first matching member is found.
2. Enter security zone view.
3. Add members to the security zone.
Choose one option as needed:
¡ Add a Layer 3 Ethernet interface.
import interface layer3-interface-type layer3-interface-number
By default, a security zone does not have Layer 3 Ethernet interface members.
You can perform this step multiple times to add multiple Layer 3 Ethernet interface members.
¡ Add an IPv4 subnet.
import ip ip-address { mask-length | mask }
By default, a security zone does not have IPv4 subnet members.
You can perform this step multiple times to add multiple IPv4 subnet members.
¡ Add an IPv6 subnet.
import ipv6 ipv6-address prefix-length
By default, a security zone does not have IPv6 subnet members.
You can perform this step multiple times to add multiple IPv6 subnet members.
The system uses the default action for packets that are exchanged between interfaces in the same security zone in the following situations:
· A zone pair from the security zone to the security zone itself is not configured.
· A zone pair from the security zone to the security zone itself is configured, but no interzone policy is applied to the zone pair.
2. Specify the default action for packets exchanged between interfaces in the same security zone.
¡ Set the default action to permit.
security-zone intra-zone default permit
¡ Set the default action to deny.
undo security-zone intra-zone default permit
By default, the default action is deny.
To display security zone information, execute the following command in any view:
display security-zone [ name zone-name ]
