18-Security Configuration Guide
HomeSupportRoutersSR6600-M SeriesConfigure & DeployConfiguration GuidesH3C SR6608-M Router Configuration Guides-R9141-6W10118-Security Configuration Guide
14-Crypto engine configuration
14-Crypto engine configuration 47.03 KB
Configuring crypto engines
About crypto engines
Crypto engines encrypt and decrypt data for service modules.
Crypto engine types
Crypto engines include the following types:
·     Hardware crypto engines—A hardware crypto engine is a coprocessor integrated on a CPU or hardware crypto card. Hardware crypto engines can accelerate encryption/decryption speed, which improves device processing efficiency. You can enable or disable hardware crypto engines globally as needed. By default, hardware crypto engines are enabled.
·     Software crypto engines—A software crypto engine is a set of software encryption algorithms. The device uses software crypto engines to encrypt and decrypt data for service modules. They are always enabled. You cannot enable or disable software crypto engines.
Crypto engine processing mechanism
Crypto engines provide encryption/decryption services for service modules, for example, the IPsec module. When a service module requires data encryption/decryption, it sends the desired data to a crypto engine. After the crypto engine completes data encryption/decryption, it sends the data back to the service module.
Verifying and maintaining crypto engines
Displaying crypto engine information
To display crypto engine information, execute the following command in any view:
display crypto-engine
Displaying and clearing crypto engine statistics
To display crypto engine statistics, execute the following command in any view:
display crypto-engine statistics [ engine-id engine-id slot slot-number ]
To clear crypto engine statistics, execute the following command in user view:
reset crypto-engine statistics [ engine-id engine-id slot slot-number ]
