- 19-Security Configuration Guide
- 01-Object group configuration
- 02-Keychain configuration
- 03-Public key management
- 04-PKI configuration
- 05-Crypto engine configuration
- 06-SSH configuration
- 07-SSL configuration
- 08-Security zone configuration
- 09-Packet filter configuration
- 10-ASPF configuration
- 11-Security policy configuration
- 12-Session management
- 13-ARP attack protection configuration
- 14-ND attack defense configuration
- 15-Attack detection and prevention configuration
- 16-mGRE configuration
- 17-Connection limit configuration
- 18-IP-based attack prevention configuration
- 19-IP source guard configuration
- 20-uRPF configuration
- 21-APR configuration
- 22-FIPS configuration
| 16-mGRE configuration | 388.61 KB |
Restrictions and guidelines: mGRE configuration
Configuring an mGRE tunnel on an NHS
Configuring an mGRE tunnel on an NHC
Configuring IPsec for an mGRE tunnel
Verifying and maintaining mGRE
Displaying and clearing mGRE session information
Displaying and clearing NHRP packet statistics on tunnel interfaces
Displaying NHRP mapping entries
Displaying history NHRP mapping entries
Clearing mGRE session statistics
Clearing history NHRP mapping entries
Example: Configuring a full-mesh mGRE network
Example: Configuring an NHS-NHC mGRE network
Example: Configuring an IPsec-protected full-mesh mGRE network
Example: Configuring an IPsec-protected NHS-NHC mGRE network
Example: Configuring a full-mesh mGRE network with NAT traversal
Configuring mGRE
About mGRE
Multipoint Generic Routing Encapsulation (mGRE) is a dynamic VPN technology that uses the Next Hop Resolution Protocol (NHRP).
Traditional GRE tunnels for a VPN are static and require manual configuration and maintenance, resulting in poor extensibility. If branches of an enterprise access the public network by using dynamic IP addresses, it is difficult to set GRE tunnels between the branches.
mGRE can dynamically establish tunnels for the branches, because NHRP can dynamically map the private IP address of a branch to its public IP address.
mGRE network model
An mGRE network uses the client/server model. It has the following types of nodes:
· NHRP server (NHS)—The hub device in the mGRE network. The NHS is the routing information exchange center. It is also the data forwarding center in a NHS-NHC network.
· NHRP client (NHC)—A spoke device in the mGRE network. Typically, it is the gateway of a branch network. An NHC does not forward data received from other mGRE nodes.
mGRE works with the public IP addresses of interfaces connected to the Internet on NHCs and NHSs and the private IP addresses of mGRE tunnel interfaces. An NHC registers its public and private addresses with the NHS and it registers its public address whenever the public address changes. An NHC obtains the new public address of a peer NHC from the NHS through NHRP, so the two NHCs can establish an mGRE tunnel over the Internet.
mGRE networks support the following types of networking:
· Full-mesh network—As shown in Figure 1, NHCs can establish tunnels between each other for direct communication. The NHS acts as the routing information exchange center.
· Hub-spoke network—Also called an NHS-NHC network. As shown in Figure 2, NHCs cannot establish tunnels between each other. Instead, they establish tunnels with the NHS. The NHS forwards data for the NHCs. The NHS acts as both the routing information exchange center and the data forwarding center.
mGRE operation procedure
The mGRE operation includes the following phases:
· Registration.
· Tunnel establishment.
· Route learning and packet forwarding.
Registration
As shown in Figure 3, the registration process is as follows:
1. The NHC sends a registration request to the NHS.
A registration request contains an NHC's public address, private address, connected private subnet, NHRP packet authentication key, and GRE key.
2. After the NHS receives the request, it performs the NHRP packet authentication key and GRE key matching. If both keys are matched, registration succeeds. The NHS sends a registration success message to the NHC.
An mGRE tunnel is established as follows:
· NHC-NHS tunnel establishment process:
An NHC-NHS tunnel is established in the registration process. During registration, the NHC-NHS tunnel is in initialization state. After registration succeeds, the NHC-NHS tunnel is established.
An NHC-NHS tunnel is permanent. An NHC can establish permanent tunnels to any number of NHSs.
· NHC-NHC tunnel establishment process:
a. In a full-mesh network, when an NHC receives a data packet but finds no tunnel for forwarding the packet, the NHC (initiator) sends an address resolution request to the NHS.
b. After receiving the request, the NHS looks up the local NHRP mapping table to find the peer NHC (responder) and forwards the request to the peer NHC.
c. After receiving the request, the peer NHC creates a temporary tunnel and sends an address resolution response to the initiator.
An NHC-NHC tunnel is dynamic. If no data is exchanged within the NHC-NHC tunnel idle timeout, the tunnel will be deleted.
An NHC-NHC tunnel can traverse a NAT gateway. The tunnel can be established when the tunnel initiator, receiver, or both ends reside behind the NAT gateway.
mGRE nodes learn private routes by using dynamic routing protocols.
Dynamic routing must be configured for all private networks and mGRE tunnel interfaces to ensure IP connectivity among the private networks. From the perspective of private networks, an mGRE tunnel is a link that connects different private networks. A dynamic routing protocol discovers neighbors and updates routes over mGRE tunnels, and establishes a routing table.
When an NHC receives a packet destined for a remote private network, it performs the following operations:
1. Searches the routing table for the next hop address to the target private network.
2. Looks up the local NHRP mapping table to obtain the public address that corresponds to the next hop address.
3. Uses the public address as the tunnel destination address to encapsulate the packet.
4. Sends the encapsulated packet to the peer NHC over the mGRE tunnel.
To set up an mGRE network, first configure the NHSs and then the NHCs.
mGRE tasks at a glance
To configure mGRE on an NHS, perform the following tasks:
1. Configuring an mGRE tunnel on an NHS
3. (Optional.) Configuring IPsec for an mGRE tunnel
To configure mGRE on an NHC, perform the following tasks:
1. Configuring an mGRE tunnel on an NHC
The public address and private address of an NHS must be statically configured.
You must configure the same GRE key or configure no key at both ends of a tunnel.
On the device, you must configure different GRE keys for mGRE tunnel interfaces that have the same source address or source interface.
For more information about the GRE key and tunnel interfaces, see GRE and tunneling configuration in IP Tunneling and Security VPN Configuration Guide.
1. Enter system view.
2. Create an mGRE tunnel interface and enter its view.
interface tunnel number mode mgre
3. Configure a private address for the tunnel interface.
By default, no private address is configured for a tunnel interface.
4. Specify a source address or source interface for the mGRE tunnel.
source { ip-address | interface-type interface-number }
By default, no source address or source interface is configured for an mGRE tunnel.
If you specify a source address, it is used as the source IP address of tunneled packets.
If you specify a source interface, the primary IP address of that interface is used as the source IP address of tunneled packets.
5. Configure an NHRP packet authentication key.
nhrp authentication { cipher | simple } string
By default, no NHRP packet authentication key is configured. NHRP nodes do not authenticate NHRP packets received from each other.
In the same mGRE network, all NHCs and NHSs must use the same NHRP packet authentication key.
6. Configure an NHRP network ID for the mGRE tunnel.
nhrp network-id number
By default, an mGRE tunnel does not have an NHRP network ID.
7. Configure the holdtime for NHRP mapping entries.
nhrp holdtime seconds
By default, the holdtime of NHRP mapping entries is 7200 seconds.
8. Enable the NHS-only feature.
nhrp server-only
By default, the NHS-only feature is disabled.
9. (Optional.) Specify a DSCP value for outgoing NHRP packets.
nhrp dscp
By default, the DSCP value is 48 for outgoing NHRP packets.
10. (Optional.) Configure a GRE key for the tunnel interface.
gre key key
By default, no GRE key is configured for an mGRE tunnel interface.
11. (Optional.) Set the DF bit for tunneled packets.
tunnel dfbit enable
By default, the DF bit is not set. Tunneled packets can be fragmented for forwarding.
The public address of an NHC can be statically configured or dynamically assigned. The private address of an NHC must be statically configured.
You must configure the same GRE key or configure no key on both ends of a tunnel.
For more information about the GRE key and tunnel interfaces, see GRE and tunneling configuration in Layer 3—IP Services Configuration Guide.
4. Configure a source address or source interface for the tunnel interface.
By default, no source address or source interface is configured for a tunnel interface.
If you specify a source interface, the primary IP address of this interface is used as the source IP address of tunneled packets.
After the holdtime expires, the NHC automatically deletes the NHRP mapping entries and re-registers to the NHS.
8. Configure an NHS private-to-public address mapping.
nhrp nhs nhs-address nbma { dns-name | nbma-address }
By default, no NHS private-to-public address mappings are configured.
9. (Optional.) Configure a GRE key for the tunnel interface.
gre key key
10. (Optional.) Set the DF bit for tunneled packets.
tunnel dfbit enable
Configuring routing
NHCs support dynamic routing protocols of OSPF, RIP, and BGP.
When you configure routing for mGRE client, following these restrictions and guidelines:
Network type |
Routing protocols |
Remarks |
Full-mesh network |
RIP |
Not supported. |
OSPF |
You must specify the OSPF interface network type as broadcast. |
BGP |
You need to configure routing policies. Ensure that the local NHC learns a route to the remote private network, and the route's next hop address is the address of the remote NHC. |
NHS-NHC network |
RIP |
You must use the RIP-2 multicast mode and disable the split horizon feature for NHS nodes |
OSPF |
You must specify the OSPF interface network type as p2mp. |
BGP |
You need to configure routing policies. Ensure that the local NHC learns a route to the remote private network, and the route's next hop address is the address of the NHS. |
For more information about the routing protocols and routing policy configuration, see RIP, OSPF, BGP, and routing policy in Layer 3—IP Routing Configuration Guide.
The device supports protecting mGRE tunnel data and control packets by using IPsec profiles.
To configure IPsec for an mGRE tunnel:
1. Configure an IPsec transform set to specify the security protocol, authentication and encryption algorithms, and encapsulation mode.
2. Configure an IKE-based IPsec profile.
3. Apply the IKE-based IPsec profile to the mGRE tunnel interface.
For more information about IPsec configuration, see "Configuring IPsec."
To display mGRE session information, execute the following command in any view:
display mgre session [ interface tunnel interface-number [ peer ipv4-address ] ] [ verbose ]
To clear mGRE session information, execute the following command in user view:
reset mgre session [ interface tunnel interface-number [ peer ipv4-address ] ]
To display NHRP packet statistics on tunnel interfaces, execute the following command in any view:
display nhrp statistics [ interface tunnel interface-number ]
To clear NHRP packet statistics on tunnel interfaces, execute the following command in user view:
reset nhrp statistics [ interface tunnel interface-number ]
To display information about NHRP mapping entries, execute the following command in any view:
display nhrp map [ interface tunnel interface-number [ peer ipv4-address ] ] [ verbose ]
To display NHRP mapping entries that were cleared or have expired, execute the following command in any view:
display nhrp history-map [ count count-number ]
To clear mGRE session statistics, execute the following command in user view:
reset mgre statistics [ interface tunnel interface-number [ peer ipv4-address ] ]
To clear the system recorded NHRP mapping entries, execute the following command in user view:
reset nhrp history-map
mGRE configuration examples
As shown in Figure 4, construct a full-mesh mGRE network. The NHS manages and maintains information for each node.
Set up permanent (static) mGRE tunnels between the NHS and NHCs. Set up temporary (dynamic) mGRE tunnels between NHCs when they need to communicate with each other.
1. Configure the NHS:
# Assign an IP address to interface GigabitEthernet1/0/1.
<NHS> system-view
[NHS] interface gigabitethernet 1/0/1
[NHS-GigabitEthernet1/0/1] ip address 80.1.1.161 255.255.255.0
[NHS-GigabitEthernet1/0/1] quit
# Configure Tunnel0 as an mGRE tunnel interface and assign an IP address to it.
[NHS] interface tunnel0 mode mgre
[NHS-Tunnel0] ip address 192.168.4.161 255.255.255.0
Set the OSPF network type of the interface to broadcast.
[NHS-Tunnel0] ospf network-type broadcast
# Enable OSPF on the interface.
[NHS-Tunnel0] ospf 1 area 0.0.0.1
# Specify GigabitEthernet1/0/1 as the source interface of the mGRE tunnel.
[NHS-Tunnel0] source gigabitethernet 1/0/1
# Set the GRE key to 100000.
[NHS-Tunnel0] gre key 100000
# Set the NHRP network ID to 9.
[NHS-Tunnel0] nhrp network-id 9
# Configure the NHRP packet authentication key as a plaintext string of 12345678.
[NHS-Tunnel0] nhrp authentication simple 12345678
# Set the holdtime of NHRP mapping entries to 3600 seconds.
[NHS-Tunnel0] nhrp holdtime 3600
[NHS-Tunnel0] quit
# Configure basic OSPF.
[NHS] ospf 1
[NHS-ospf-1] area 0.0.0.1
[NHS-ospf-1-area-0.0.0.1] network 192.168.4.0 0.0.0.255
[NHS-ospf-1-area-0.0.0.1] quit
2. Configure NHC 1:
# Assign an IP address to GigabitEthernet 1/0/1.
<NHC1> system-view
[NHC1] interface gigabitethernet 1/0/1
[NHC1-GigabitEthernet1/0/1] ip address 80.1.2.162 255.255.255.0
[NHC1-GigabitEthernet1/0/1] quit
# Assign an IP address to GigabitEthernet 1/0/2.
[NHC1] interface gigabitethernet 1/0/2
[NHC1-GigabitEthernet1/0/2] ip address 192.168.1.162 255.255.255.0
[NHC1-GigabitEthernet1/0/2] quit
# Assign an IP address to mGRE tunnel interface Tunnel0.
[NHC1] interface tunnel0 mode mgre
[NHC1-Tunnel0] ip address 192.168.4.162 255.255.255.0
# Specify the OSPF interface network type as broadcast.
[NHC1-Tunnel0] ospf network-type broadcast
# Enable OSPF for the tunnel interface.
[NHC1-Tunnel0] ospf 1 area 0.0.0.1
# Specify GigabitEthernet 1/0/1 as the source interface of the mGRE tunnel.
[NHC1-Tunnel0] source gigabitethernet 1/0/1
[NHC1-Tunnel0] gre key 100000
[NHC1-Tunnel0] nhrp network-id 9
[NHC1-Tunnel0] nhrp authentication simple 12345678
[NHC1-Tunnel0] nhrp holdtime 3600
# Configure an NHS private-to-public address mapping.
[NHC1-Tunnel0] nhrp nhs 192.168.4.161 nbma 80.1.1.161
[NHC1-Tunnel0] quit
[NHC1] ospf 1
[NHC1-ospf-1] area 0.0.0.1
[NHC1-ospf-1-area-0.0.0.1] network 192.168.4.0 0.0.0.255
[NHC1-ospf-1-area-0.0.0.1] network 192.168.1.0 0.0.0.255
[NHC1-ospf-1-area-0.0.0.1] quit
3. Configure NHC 2:
<NHC2> system-view
[NHC2] interface gigabitethernet 1/0/1
[NHC2-GigabitEthernet1/0/1] ip address 80.1.3.163 255.255.255.0
[NHC2-GigabitEthernet1/0/1] quit
[NHC2] interface gigabitethernet 1/0/2
[NHC2-GigabitEthernet1/0/2] ip address 192.168.0.163 255.255.255.0
[NHC2-GigabitEthernet1/0/2] quit
[NHC2] interface tunnel0 mode mgre
[NHC2-Tunnel0] ip address 192.168.4.163 255.255.255.0
[NHC2-Tunnel0] ospf network-type broadcast
[NHC2-Tunnel0] ospf 1 area 0.0.0.1
[NHC2-Tunnel0] source gigabitethernet 1/0/1
[NHC2-Tunnel0] gre key 100000
[NHC2-Tunnel0] nhrp network-id 9
[NHC2-Tunnel0] nhrp authentication simple 12345678
[NHC2-Tunnel0] nhrp holdtime 3600
[NHC2-Tunnel0] nhrp nhs 192.168.4.161 nbma 80.1.1.161
[NHC2-Tunnel0] quit
[NHC2] ospf 1
[NHC2-ospf-1] area 0.0.0.1
[NHC2-ospf-1-area-0.0.0.1] network 192.168.4.0 0.0.0.255
[NHC2-ospf-1-area-0.0.0.1] network 192.168.0.0 0.0.0.255
[NHC2-ospf-1-area-0.0.0.1] quit
# Display brief information about the NHRP mapping table on the NHS.
[NHS] display nhrp map
Destination/mask Next hop NBMA address Type Interface
192.168.4.161 192.168.4.161 80.1.1.161 static Tunnel0
# Display summary information about mGRE sessions on the NHS.
[NHS] display mgre session
Interface : Tunnel0
Number of sessions: 1
Peer NBMA address Peer protocol address Type State State duration
80.1.1.161 192.168.4.161 S-C Succeeded 00:09:42
The command output shows that the NHS has established a permanent NHS-NHC tunnel.
# Display brief information about the mGRE session on NHC 1.
[NHC1] display mgre session
Interface : Tunnel0
80.1.1.161 192.168.4.161 C-S Succeeded 00:09:42
The output indicates that NHC 1 has established a permanent tunnel with the NHS. The output on NHC 2 is similar.
# Ping the private address 192.168.4.163 of NHC 2 from NHC 1.
[NHC1] ping 192.168.4.163
Ping 192.168.4.163 (192.168.4.163): 56 data bytes, press CTRL_C to break
56 bytes from 192.168.4.163: icmp_seq=0 ttl=255 time=3.314 ms
56 bytes from 192.168.4.163: icmp_seq=1 ttl=255 time=2.786 ms
56 bytes from 192.168.4.163: icmp_seq=2 ttl=255 time=2.317 ms
56 bytes from 192.168.4.163: icmp_seq=3 ttl=255 time=3.060 ms
56 bytes from 192.168.4.163: icmp_seq=4 ttl=255 time=2.258 ms
--- Ping statistics for 192.168.4.163 ---
round-trip min/avg/max/std-dev = 2.258/2.747/3.314/0.411 ms
# Display detailed information about the NHRP mapping table on NHC 1.
[NHC1] display nhrp map verbose
Interface : Tunnel0
Destination/mask : 192.168.4.161/24
Next hop : 192.168.4.161
Creation time : 01:10:25
Expiration time : never expire
Type : static
Flags : up
NBMA address : 80.1.1.161
Interface : Tunnel0
Destination/mask : 192.168.4.163/32
Next hop : 192.168.4.163
Creation time : 00:00:24
Expiration time : 00:01:36
Type : cached
Flags : used up
NBMA address : 80.1.3.163
Interface : Tunnel0
Number of sessions: 2
80.1.1.161 192.168.4.161 C-S Succeeded 00:10:28
80.1.3.163 192.168.4.163 C-C Succeeded 00:00:32
The output indicates that NHC 1 has established a permanent tunnel with the NHS and a temporary tunnel with NHC 2. The output on NHC 2 is similar.
As shown in Figure 5, construct an NHC-NHS mGRE network. The NHS manages and maintains information for each node and forwards packets between NHCs.
<NHS> system-view
Set the OSPF network type of the interface to P2MP.
[NHS-Tunnel0] ospf network-type p2mp
[NHS-Tunnel0] quit
[NHS] ospf 1
2. Configure NHC 1:
<NHC1> system-view
# Specify the OSPF interface network type as P2MP.
[NHC1-Tunnel0] ospf network-type p2mp
[NHC1-Tunnel0] quit
[NHC1] ospf 1
3. Configure NHC 2:
<NHC2> system-view
[NHC2-Tunnel0] ospf network-type p2mp
[NHC2-Tunnel0] quit
[NHC2] ospf 1
# Display detailed information about the NHRP mapping table on the NHS.
[NHS] display nhrp map verbose
Interface : Tunnel0
Destination/mask : 192.168.4.162/24
Next hop : 192.168.4.162
Creation time : 00:14:12
Expiration time : 00:01:28
Type : static
Flags : up
NBMA address : 80.1.2.162
Interface : Tunnel0
Destination/mask : 192.168.4.163/24
Creation time : 00:13:59
Expiration time : 00:01:06
Type : static
Flags : up
NBMA address : 80.1.2.163
Interface : Tunnel0
80.1.2.162 192.168.4.162 S-C Succeeded 00:09:42
80.1.3.163 192.168.4.163 S-C Succeeded 00:09:42
The command output shows that the NHS has established permanent NHS-NHC tunnels.
Interface : Tunnel0
Creation time : 07:50:32
Type : static
Flags : up
Interface : Tunnel0
80.1.1.161 192.168.4.161 C-S Succeeded 07:49:14
# On NHC 1, ping Site 1 and Site 2. The ping operation succeeds.
[NHC1] ping -a 192.168.1.162 192.168.0.163
Ping 192.168.0.163 (192.168.0.163) from 192.168.1.162: 56 data bytes, press CTRL_C to break
56 bytes from 192.168.0.163: icmp_seq=0 ttl=254 time=10.000 ms
56 bytes from 192.168.0.163: icmp_seq=1 ttl=254 time=17.000 ms
56 bytes from 192.168.0.163: icmp_seq=2 ttl=254 time=14.000 ms
56 bytes from 192.168.0.163: icmp_seq=3 ttl=254 time=7.000 ms
56 bytes from 192.168.0.163: icmp_seq=4 ttl=254 time=7.000 ms
--- Ping statistics for 192.168.0.163 ---
round-trip min/avg/max/std-dev = 7.000/11.000/17.000/3.950 ms
As shown in Figure 6, construct a full-mesh mGRE network. The NHS manages and maintains information for each node.
Configure IPsec to protect the mGRE tunnels.
<NHS> system-view
[NHS-Tunnel0] quit
[NHS] ospf 1
# Create IPsec transform set aa, set its encryption algorithm to 56-bit DES, and set its authentication algorithm to HMAC-SHA1.
[NHS] ipsec transform-set aa
[NHS-ipsec-transform-set-aa] esp encryption-algorithm des-cbc
[NHS-ipsec-transform-set-aa] esp authentication-algorithm sha1
[NHS-ipsec-transform-set-aa] quit
# Create IKE keychain 1.
[NHS] ike keychain 1
# Configure the pre-shared key used with the peer 80.1.2.162 as a plaintext string of 12345678.
[NHS-ike-keychain-1] pre-shared-key address 80.1.2.162 24 key simple 12345678
# Configure the pre-shared key used with the peer 80.1.3.163 as a plaintext string of 12345678.
[NHS-ike-keychain-1] pre-shared-key address 80.1.3.163 24 key simple 12345678
[NHS-ike-keychain-1] quit
# Create an IKE profile named abc.
[NHS] ike profile abc
# Specify IKE keychain 1 for the IKE profile.
[NHS-ike-profile-abc] keychain 1
[NHS-ike-profile-abc] quit
# Create an IKE-based IPsec profile named abc.
[NHS] ipsec profile abc isakmp
# Specify IPsec transform set aa for the IPsec profile.
[NHS-ipsec-profile-isakmp-abc] transform-set aa
# Specify IKE profile abc for the IPsec profile.
[NHS-ipsec-profile-isakmp-abc] ike-profile abc
[NHS-ipsec-profile-isakmp-abc] quit
# Apply IPsec profile abc to the mGRE tunnel interface.
[NHS-Tunnel0] tunnel protection ipsec profile abc
[NHS-Tunnel0] quit
2. Configure NHC 1:
<NHC1> system-view
# Set the OSPF interface DR priority to 0.
[NHC1-Tunnel0] ospf dr-priority 0
[NHC1-Tunnel0] quit
[NHC1] ospf 1
[NHC1] ipsec transform-set aa
[NHC1-ipsec-transform-set-aa] esp encryption-algorithm des-cbc
[NHC1-ipsec-transform-set-aa] esp authentication-algorithm sha1
[NHC1-ipsec-transform-set-aa] quit
[NHC1] ike keychain 1
# Configure the pre-shared key used with the peer 80.1.1.161 as a plaintext string of 12345678.
[NHC1-ike-keychain-1] pre-shared-key address 80.1.1.161 24 key simple 12345678
[NHC1-ike-keychain-1] pre-shared-key address 80.1.3.163 24 key simple 12345678
[NHC1-ike-keychain-1] quit
[NHC1] ike profile abc
[NHC1-ike-profile-abc] keychain 1
[NHC1-ike-profile-abc] quit
[NHC1] ipsec profile abc isakmp
[NHC1-ipsec-profile-isakmp-abc] transform-set aa
[NHC1-ipsec-profile-isakmp-abc] ike-profile abc
[NHC1-ipsec-profile-isakmp-abc] quit
[NHC1-Tunnel0] tunnel protection ipsec profile abc
[NHC1-Tunnel0] quit
3. Configure NHC 2:
<NHC2> system-view
[NHC2-Tunnel0] ospf dr-priority 0
[NHC2-Tunnel0] quit
[NHC2] ospf 1
[NHC2] ipsec transform-set aa
[NHC2-ipsec-transform-set-aa] esp encryption-algorithm des-cbc
[NHC2-ipsec-transform-set-aa] esp authentication-algorithm sha1
[NHC2-ipsec-transform-set-aa] quit
[NHC2] ike keychain 1
[NHC2-ike-keychain-1] pre-shared-key address 80.1.1.161 24 key simple 12345678
[NHC2-ike-keychain-1] pre-shared-key address 80.1.2.162 24 key simple 12345678
[NHC2-ike-keychain-1] quit
[NHC2] ike profile abc
[NHC2-ike-profile-abc] keychain 1
[NHC2-ike-profile-abc] quit
[NHC2] ipsec profile abc isakmp
[NHC2-ipsec-profile-isakmp-abc] transform-set aa
[NHC2-ipsec-profile-isakmp-abc] ike-profile abc
[NHC2-ipsec-profile-isakmp-abc] quit
[NHC2-Tunnel0] tunnel protection ipsec profile abc
[NHC2-Tunnel0] quit
Interface : Tunnel0
Type : static
Flags : up ipsec
Interface : Tunnel0
Type : static
Flags : up ipsec
Interface : Tunnel0
Interface : Tunnel0
Creation time : 00:30:51
Type : static
Flags : up ipsec
Interface : Tunnel0
Interface : Tunnel0
Type : static
Flags : up ipsec
Interface : Tunnel0
Type : cached
Flags : used up ipsec
Interface : Tunnel0
The output indicates that NHC 1 has established a permanent tunnel with the NHS and a temporary tunnel with NHC 2. Both tunnels are protected by IPsec. The output on NHC 2 is similar.
# Display IKE SA information on NHC 1. The output on NHC 2 is similar.
[NHC1] display ike sa
Connection-ID Remote Flag DOI
240 80.1.1.161 RD IPsec
241 80.1.3.163 RD IPsec
Flags:
RD--READY RL--REPLACED FD-FADING
# Display IPsec SA information on NHC 1. The output on NHC 2 is similar.
[NHC1] display ipsec sa
Interface: Tunnel0
IPsec profile: abc
Mode: ISAKMP
Tunnel id: 4
Encapsulation mode: tunnel
Perfect forward secrecy:
Path MTU: 1398
Tunnel:
local address: 80.1.2.162
remote address: 80.1.3.163
Flow:
sour addr: 80.1.2.162/255.255.255.255 port: 0 protocol: gre
dest addr: 80.1.3.163/255.255.255.255 port: 0 protocol: gre
[Inbound ESP SAs]
SPI: 1566691874 (0x5d61d222)
Connection ID: 21474836488
Transform set: ESP-ENCRYPT-DES-CBC ESP-AUTH-SHA1
SA duration (kilobytes/sec): 1843200/3600
SA remaining duration (kilobytes/sec): 1843200/3584
Max received sequence-number: 0
Anti-replay check enable: Y
Anti-replay window size: 64
UDP encapsulation used for NAT traversal: N
Status: Active
[Outbound ESP SAs]
SPI: 1199855674 (0x4784583a)
Connection ID: 12884901895
SA remaining duration (kilobytes/sec): 1843199/3584
Max sent sequence-number: 4
Status: Active
IPsec profile: abc
Mode: ISAKMP
Tunnel id: 5
Path MTU: 1398
Tunnel:
remote address: 80.1.1.161
Flow:
dest addr: 80.1.1.161/255.255.255.255 port: 0 protocol: gre
[Inbound ESP SAs]
SPI: 989656188 (0x3afcf47c)
Connection ID: 30064771081
SA remaining duration (kilobytes/sec): 1843198/3560
Max received sequence-number: 12
Status: Active
[Outbound ESP SAs]
SPI: 1408141582 (0x53ee890e)
Connection ID: 38654705674
SA remaining duration (kilobytes/sec): 1843199/3560
Max sent sequence-number: 8
Status: Active
As shown in Figure 7, construct an NHS-NHC mGRE network. The NHS manages and maintains information for each node and forwards packets between NHCs.
<NHS> system-view
[NHS-Tunnel0] quit
[NHS] ospf 1
[NHS-Tunnel0] quit
2. Configure NHC 1:
<NHC1> system-view
[NHC1-Tunnel0] quit
[NHC1] ospf 1
# Create an IKE keychain named 1.
[NHC1-Tunnel0] quit
3. Configure NHC 2:
<NHC2> system-view
[NHC2-Tunnel0] quit
[NHC2] ospf 1
[NHC2-Tunnel0] quit
Interface : Tunnel0
Type : static
Flags : up
Interface : Tunnel0
Type : static
Flags : up
Interface : Tunnel0
Interface : Tunnel0
Creation time : 08:17:14
Type : static
Flags : up ipsec
Interface : Tunnel0
80.1.1.161 192.168.4.161 C-S Succeeded 00:00:18
# On NHC 1, test the connectivity between Site 1 and Site 2. The ping operation succeeds.
3 80.1.1.161 RD IPsec
Flags:
Interface: Tunnel0
IPsec profile: abc
Mode: ISAKMP
Tunnel id: 5
Path MTU: 1398
Tunnel:
Flow:
[Inbound ESP SAs]
SPI: 2791687835 (0xa665c69b)
Connection ID: 12884901898
SA remaining duration (kilobytes/sec): 1843199/3520
Max received sequence-number: 9
Status: Active
[Outbound ESP SAs]
SPI: 1369008262 (0x51996886)
Connection ID: 12884901897
Max sent sequence-number: 10
Status: Active
As shown in Figure 8, the NHS and NHCs reside behind NAT gateways. Construct a full-mesh mGRE network. The NHS manages and maintains information for each node.
Device |
IP address |
Device |
IP address |
NHC 1 |
GE1/0/1 |
80.1.2.162/24 |
NAT 1 |
GE1/0/1 |
80.1.1.4/24 |
GE1/0/2 |
192.168.1.162/24 |
GE1/0/2 |
40.1.1.4/24 |
Tunnel0 |
192.168.4.162/24 |
NAT 2 |
GE1/0/1 |
40.1.1.2/24 |
NHC 2 |
GE1/0/1 |
80.1.3.163/24 |
GE1/0/2 |
80.1.2.2/24 |
GE1/0/2 |
192.168.0.163/24 |
NAT 3 |
GE1/0/1 |
40.1.1.3/24 |
Tunnel0 |
192.168.4.163/24 |
GE1/0/2 |
80.1.3.3/24 |
NHS |
GE1/0/1 |
80.1.1.161/24 |
Tunnel0 |
192.168.4.161/24 |
CAUTION: The aging time for sessions in RAWIP-OPEN state set on NAT devices must be greater than the holdtime for NHRP mapping entries set on NHCs. For information about setting the aging time and holdtime, see the session aging-time state command and the nhrp holdtime command, respectively. |
<NHS> system-view
# Set the holdtime of NHRP mapping entries to 240 seconds.
[NHS-Tunnel0] nhrp holdtime 240
[NHS-Tunnel0] quit
# Configure static routes.
[NHS] ip route-static 40.1.1.0 24 80.1.1.0
[NHS] ip route-static 192.168.0.0 24 192.168.4.163
[NHS] ip route-static 192.168.1.0 24 192.168.4.162
2. Configure NHC 1:
<NHC1> system-view
[NHC1-Tunnel0] nhrp holdtime 240
[NHC1-Tunnel0] nhrp nhs 192.168.4.161 nbma 40.1.1.9
[NHC1-Tunnel0] quit
[NHC1] ip route-static 40.1.1.0 24 80.1.2.2
[NHC1] ip route-static 192.168.0.0 24 192.168.4.163
3. Configure NHC 2:
<NHC2> system-view
[NHC2-Tunnel0] nhrp holdtime 240
[NHC2-Tunnel0] nhrp nhs 192.168.4.161 nbma 40.1.1.9
[NHC2-Tunnel0] quit
[NHC2] ip route-static 40.1.1.0 24 80.1.3.3
[NHC2] ip route-static 192.168.1.0 24 192.168.4.162
4. Configure NAT 1:
<NAT1> system-view
[NAT1] interface gigabitethernet 1/0/1
[NAT1-GigabitEthernet1/0/1] ip address 80.1.1.4 255.255.255.0
[NAT1-GigabitEthernet1/0/1] quit
[NAT1] interface gigabitethernet 1/0/2
[NAT1-GigabitEthernet1/0/2] ip address 40.1.1.4 255.255.255.0
[NAT1-GigabitEthernet1/0/2] quit
# Enable static NAT on GigabitEthernet 1/0/2.
[NAT1-GigabitEthernet1/0/2] nat static enable
# Configure an outbound static NAT mapping between interval IP address 80.1.1.161 and external IP address 40.1.1.9.
[NAT1] nat static outbound 80.1.1.161 40.1.1.9
5. Configure NAT 2:
<NAT2> system-view
[NAT2] interface gigabitethernet 1/0/1
[NAT2-GigabitEthernet1/0/1] ip address 40.1.1.2 255.255.255.0
[NAT2-GigabitEthernet1/0/1] quit
[NAT2] interface gigabitethernet 1/0/2
[NAT2-GigabitEthernet1/0/2] ip address 80.1.2.2 255.255.255.0
[NAT2-GigabitEthernet1/0/2] quit
# Create NAT address group 0, and add addresses 40.1.1.5 and 40.1.1.6 to the group.
[NAT2] nat address-group 0
[NAT2-nat-address-group-0] address 40.1.1.5 40.1.1.6
[NAT2-nat-address-group-0] quit
# Configure an outbound NO-PAT rule on interface GigabitEthernet 1/0/1 to translate the source addresses of outgoing packets into the addresses in address group 0. Enable reverse address translation.
[NAT2-GigabitEthernet1/0/1] nat outbound address-group 0 no-pat reversible
6. Configure NAT 3:
<NAT3> system-view
[NAT3] interface gigabitethernet 1/0/1
[NAT3-GigabitEthernet1/0/1] ip address 40.1.1.3 255.255.255.0
[NAT3-GigabitEthernet1/0/1] quit
[NAT3] interface gigabitethernet 1/0/2
[NAT3-GigabitEthernet1/0/2] ip address 80.1.3.3 255.255.255.0
[NAT3-GigabitEthernet1/0/2] quit
# Create NAT address group 0, and add addresses 40.1.1.7 and 40.1.1.8 to the group.
[NAT3] nat address-group 0
[NAT3-nat-address-group-0] address 40.1.1.7 40.1.1.8
[NAT3-nat-address-group-0] quit
[NAT3-GigabitEthernet1/0/1] nat outbound address-group 0 no-pat reversible
Interface : Tunnel0
Type : static
Flags : up
Interface : Tunnel0
Type : static
Flags : up
Interface : Tunnel0
Interface : Tunnel0
Creation time : 01:12:50
Type : static
Flags : up
NBMA address : 40.1.1.9
Interface : Tunnel0
40.1.1.9 192.168.4.161 C-S Succeeded 01:12:43
Interface : Tunnel0
Type : static
Flags : up
Interface : Tunnel0
Type : cached
Flags : used up
NBMA address : 40.1.1.8
Interface : Tunnel0
40.1.1.9 192.168.4.161 C-S Succeeded 00:10:28
40.1.1.8 192.168.4.163 C-C Succeeded 00:00:32
