11-Segment Routing Configuration Guide
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration GuidesH3C MSR5680-X3 Router Configuration Guides-R9141-6W10111-Segment Routing Configuration Guide
05-EVPN L3VPN over SRv6 configuration
05-EVPN L3VPN over SRv6 configuration 666.80 KB
Configuring EVPN L3VPN over SRv6· 1
About EVPN L3VPN over SRv6· 1
Basic principle· 1
Route advertisement 1
Packet forwarding· 2
Inter-AS option B VPN· 3
End.T SID·· 3
Route advertisement 3
Traffic forwarding· 4
Intercommunication between SRv6 and MPLS L3VPN networks· 4
Intercommunication between SRv6 and EVPN VXLAN networks· 6
Transit proxies for SRv6 SIDs in cross-AS EVPN L3VPN over SRv6 networks· 8
Intercommunication between EVPN L3VPN over SRv6 and IP L3VPN over SRv6 networks· 9
EVPN L3VPN over SRv6 FRR· 11
EVPN L3VPN over SRv6 tasks at a glance· 11
Configuring SRv6 SIDs· 12
Applying a locator to a BGP VPN instance· 13
Configuring SRv6-encapsulated EVPN route advertisement 14
Configuring PEs to exchange BGP EVPN routes· 15
Configuring next hop-based dynamic End.DX4 or End.DX6 SID allocation for BGP routes· 15
Configuring BGP EVPN route settings· 16
Restrictions and guidelines for BGP EVPN route configuration· 16
Configuring BGP route reflection· 16
Configuring attributes of BGP EVPN routes· 17
Filtering BGP EVPN routes· 18
Configuring the BGP Additional Paths feature· 18
Configuring the route recursion mode· 19
Specifying a source address for the outer IPv6 header of SRv6-encapsulated EVPN L3VPN packets· 20
Enabling SRv6 VPN compatibility for a peer or peer group· 20
Configuring inter-AS option B VPN· 21
Configuring intercommunication between SRv6 and MPLS L3VPN networks· 22
Enabling intercommunication between SRv6 and EVPN VXLAN networks· 23
Configuring transit proxies for SRv6 SIDs in cross-AS EVPN L3VPN over SRv6 networks· 23
Configuring intercommunication between EVPN L3VPN over SRv6 and IP L3VPN over SRv6 networks· 24
Configuring EVPN L3VPN over SRv6 FRR· 25
Configuring SBFD for SRv6 locators· 26
Configuring a TTL processing mode for tunnels associated with a VPN instance· 27
Verifying and maintaining EVPN L3VPN over SRv6· 28
Displaying the running status and configuration of EVPN L3VPN over SRv6· 28
Resetting BGP sessions· 28
EVPN L3VPN over SRv6 configuration examples· 29
Example: Configuring IPv4 EVPN L3VPN over SRv6 in SRv6 BE mode· 29
Example: Configuring inter-AS option B VPN· 36
EVPN L3VPN over SRv6 uses SRv6 tunnels to carry EVPN L3VPN services. This technology establishes SRv6 tunnels among geographically dispersed customer sites over the IPv6 backbone network and transparently forwards EVPN L3VPN customer traffic through the tunnels. For more information about EVPN L3VPN configuration, see EVPN Configuration Guide.
Basic principle
Figure 1 shows a typical EVPN L3VPN over SRv6 network.
·     PE 1 and PE 2 use MP-BGP to advertise EVPN IP advertisement routes to each other over the IPv6 backbone network. The EVPN IP advertisement routes contain IPv4 or IPv6 VPN routing information and SID information.
·     The PEs have a single-hop SRv6 tunnel between them and they use the SRv6 tunnel to forward EVPN L3VPN traffic across sites.
·     The devices in the IPv6 backbone network forward the SRv6-encapsulated EVPN L3VPN traffic through the optimal path calculated by IGP.
EVPN L3VPN over SRv6 connects geographically dispersed sites that belong to the same VPN over the IPv6 backbone network.
Figure 1 Network diagram
Route advertisement
The route advertisement process of IPv4 EVPN L3VPN over SRv6 is similar to that of IPv6 EVPN L3VPN over SRv6. This section uses IPv4 EVPN L3VPN over SRv6 to illustrate the process.
As shown in Figure 1, local routes of CE 1 are advertised to CE 2 by using the following process:
1.     CE 1 uses static routing, RIP, OSPF, IS-IS, EBGP, or IBGP to advertise routes of the local site to PE 1.
2.     PE 1 stores the routes advertised by CE 1 to the routing table of VPN 1. Then, PE 1 converts the routes to BGP EVPN IP advertisement routes and advertises the IP advertisement routes to PE 2 by using MP-BGP. The IP advertisement routes carry RD, RT, and SID attributes (the SID attribute is used as the private network label).
¡     If next hop-based dynamic SID allocation is not used, all private network routes of the VPN instance are allocated the same End.DT4 or End.DT46 SID.
¡     If next hop-based dynamic SID allocation is used, private network routes with the same next hop are allocated the same End.DX4 SID in the VPN instance.
3.     PE 2 adds the IP advertisement routes to the routing table of VPN 1, converts the IP advertisement routes to IPv4 routes, and advertises the IPv4 routes to CE 2.
4.     By adding the received IPv4 routes to the routing table, CE 2 learns the private network routes of CE 1.
Packet forwarding
EVPN L3VPN over SRv6 supports the following route recursion modes:
·     SRv6 BE mode.
·     SRv6 TE mode.
·     SRv6 TE and SRv6 BE hybrid mode.
The packet forwarding process differs by the route recursion mode in use.
SRv6 BE mode
This mode is also called SID-based forwarding mode. In this mode, a PE forwards an SRv6 packet by searching the IPv6 routing table based on the SRv6 SID encapsulated in the packet.
The packet forwarding process of IPv4 EVPN L3VPN over SRv6 is similar to that of IPv6 EVPN L3VPN over SRv6. This section uses IPv4 EVPN L3VPN over SRv6 to illustrate the process.
As shown in Figure 1, CE 2 forwards an IPv4 packet to CE 1 as follows:
1.     CE 2 sends the IPv4 packet to PE 2.
2.     PE 2 receives the packet on an interface associated with VPN 1. PE 2 searches for a route that matches the destination IPv4 address of the packet in the routing table of VPN 1. The corresponding End.DT4, End.DT46, or End.DX4 SID is found. Then, PE 2 encapsulates an outer IPv6 header for the packet. The End.DT4, End.DT46, or End.DX4 SID is encapsulated in the outer IPv6 header as the destination address.
3.     PE 2 searches the IPv6 routing table based on the End.DT4, End.DT46, or End.DX4 SID for the optimal IGP route and forwards the packet to P through the route.
4.     P searches the IPv6 routing table based on the End.DT4, End.DT46, or End.DX4 SID for the optimal IGP route and forwards the packet to PE 1 through the route.
5.     When PE 1 receives the packet, it processes the packet as follows:
¡     If the packet header contains an End.DT4 or End.DT46 SID, PE 1 searches the local SID forwarding table for the SID and removes the outer IPv6 header. Then, PE 1 matches the packet to VPN 1 based on the SID, searches the routing table of VPN 1 for the optimal route  and forwards the packet to CE 1.
¡     If the packet header contains an End.DX4 SID, PE 1 searches the local SID forwarding table for the SID and removes the outer IPv6 header. Then, PE 1 forwards the packet to CE 1 according to the next hop and output interface bound to the SID.
SRv6 TE mode
This mode is also called SRv6 TE policy-based forwarding mode. In this mode, when a PE forwards a customer packet, it first searches for a matching SRv6 TE policy based on the packet attributes. Then, the PE adds an SRH to the packet. The SRH includes the destination SRv6 SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet based on the SRv6 TE policy.
The following modes are available to steer traffic to an SRv6 TE policy:
·     Color—The device searches for an SRv6 TE policy that has the same color and endpoint address as the color and nexthop address of a BGP EVPN route. If a matching SRv6 TE policy exists, the device recurses the BGP EVPN route to that SRv6 TE policy. When the device receives packets that match the BGP EVPN route, it forwards the packets through the SRv6 TE policy.
·     Tunnel policy—The device searches the tunnel policies for a matching SRv6 TE policy based on the next hop of a matching route. Configure a preferred tunnel or load sharing tunnel policy that uses the SRv6 TE policy. In this way, the SRv6 TE policy will be used as the public tunnel to forward the packets of private network packets.
For more information about tunnel policies, see MPLS Configuration Guide. For more information about SRv6 TE policies, see "Configuring SRv6 TE policies."
In this mode, the PE preferentially uses the SRv6 TE mode to forward a packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6 BE mode.
If the EVPN routes at one site must pass through both SRv6 and MPLS networks to reach another site, ensure that the SRv6 and MPLS networks can communicate with each other. For this purpose, you can use inter-AS option B VPN.
As shown in Figure 2, an MPLS network and an SRv6 network are in different ASs. For inter-AS communication, the devices must support SRv6 SID and MPLS label exchange.
Figure 2 Inter-AS option B VPN network diagram
End.T SID
The ASBR in the SRv6 network allocates End.T SIDs based on FECs and advertises the SIDs to other SRv6 nodes through an IGP. An FEC is a destination IP address/mask or destination IPv6 address/prefix length.
The function of an End.T SID is removing the outer IPv6 header and looking up the IPv6 FIB table based on the End.T SID to forward packets.
The ASBR in the SRv6 network encapsulates an End.T SID to the packets forwarded from the SRv6 network to the MPLS network.
Route advertisement
As shown in Figure 2, the route of CE 1 is advertised to CE 2 in the following process:
1.     After PE 1 learns the private network route of CE 1, it assigns MPLS label L1 to the private network route. Then, PE 1 advertises the route to ASBR 1 through MP-IBGP.
2.     ASBR 1 receives the EVPN IP prefix advertisement route from PE 1 and reoriginates the route. ASBR 1 changes the next hop address of the route to its address, assign MPLS label L2 to the route, and maps MPLS label L2 and MPLS label L1. Then, the ASBR advertises the EVPN IP prefix advertisement route to ASBR 2 through MP-EBGP.
3.     ASBR 2 receives the EVPN IP prefix advertisement route from ASBR 1 and reoriginates the route. ASBR 2 changes the next hop address of the route to its address, allocates an End.T SID to the route, and maps the End.T SID and MPLS label L2. Then, the ASBR advertises the route to PE 2 through MP-IBGP.
4.     PE 2 advertises the route to CE 2.
As shown in Figure 2, the route of CE 2 is advertised to CE 1 in the following process:
1.     After PE 2 learns the private network route of CE 2, it assigns an SRv6 SID to the private network route. Then, PE 2 advertises the route to ASBR 2 through MP-IBGP. The supported SRv6 SIDs include End.DT4, End.DT6, End.DT46, End.DX4, and End.DX6 SIDs.
2.     ASBR 2 receives the EVPN IP prefix advertisement route from PE 2 and reoriginates the route. ASBR 2 changes the next hop address of the route to its address, assign MPLS label L2 to the route, and maps MPLS label L2 and the SRv6 SID. Then, the ASBR advertises the EVPN IP prefix advertisement route to ASBR 1 through MP-EBGP.
3.     ASBR 1 receives the EVPN IP prefix advertisement route from ASBR 2 and reoriginates the route. ASBR 1 changes the next hop address of the route to its address, allocates MPLS label L1 to the route, and maps MPLS label 1 and MPLS label L2. Then, the ASBR advertises the route to PE 1 through MP-IBGP.
4.     PE 1 advertises the route to CE 1.
In the inter-AS option B VPN scenario, the ASBRs need to receive all inter-AS VPN routes. On the ASBRs, do not filter received EVPN IP prefix advertisement routes based on route targets.
Traffic forwarding
As shown in Figure 2, packets are forwarded from CE 2 to CE 1 in the following process:
1.     When PE 2 receives a packet from CE 2, it encapsulates an End.T SID to the packet and forwards the packet to ASBR 2.
2.     When ASBR 2 receives the packet, it removes the outer IPv6 header and looks up the IPv6 FIB table based on the End.T SID. ASBR 2 finds that the out label is L2. Then, the ASBR reencapsulates MPLS label 2 to the packet and forwards the packet to ASBR 1. The packet includes only one layer of MPLS label.
3.     ASBR 1 replaces MPLS label L2 with MPLS label L1 and adds the public label that identifies the public tunnel from ASBR 1 to PE 1 to the packet. Then, ASBR 1 forwards the packet to PE 1.
4.     PE 1 removes the public and private labels from the packet and forwards the packet to CE 1.
Packets are forwarded from CE 1 to CE 2 in the following process:
1.     When PE 1 receives a packet from CE 1, it encapsulates two layers of MPLS labels to the packet and forwards the packet to ASBR 1. The private label is L1 and the public label identifies the public tunnel from PE 1 to ASBR 1.
2.     When ASBR 1 receives the packet, it removes the public label from the packet and replaces private label L1 with private label L2. Then, ASBR 1 forwards the packet to ASBR 2. The packet includes only one layer of MPLS label.
3.     ASBR 2 replaces private label L2 with an SRv6 SID and forwards the packet to PE 2 according to the SRv6 SID.
4.     PE 2 executes the function of the SRv6 SID and forwards the packet to CE 2.
As shown in Figure 3, MPLS L3VPN networks are deployed for the data centers connected through an EVPN L3VPN over SRv6 network. For communication between the data centers, you need to implement intercommunication between SRv6 and MPLS L3VPN networks on the ASBRs of the data centers.
Figure 3 Intercommunication between SRv6 and MPLS L3VPN networks
After you configure intercommunication between SRv6 and MPLS L3VPN networks on the ASBR, the ASBR performs the following operations:
·     After receiving BGP VPNv4 routes from the MPLS L3VPN network, the ASBR performs the following operations:
a.     Matches the route targets of the routes with the import route targets of local VPN instances.
b.     Adds the routes to the routing tables of the VPN instances, and reoriginates EVPN IP prefix advertisement routes. In addition, the ASBR adds an SRv6 SID to the routes.
c.     Advertises the reoriginated EVPN IP prefix advertisement routes with the SRv6 SID to the EVPN L3VPN over SRv6 network.
·     After receiving EVPN IP prefix advertisement routes from the EVPN L3VPN over SRv6 network, the ASBR performs the following operations:
b.     Adds the routes to the routing tables of the VPN instances, and reoriginates VPNv4 routes. In addition, the ASBR adds an MPLS label to the routes.
c.     Advertises the reoriginated VPNv4 routes with the MPLS label to the MPLS L3VPN network.
After route reorigination, you need to enable intercommunication between SRv6 and MPLS networks on the ASBR to associate SRv6 SIDs with MPLS labels.
Figure 4 Packet forwarding between SRv6 and MPLS L3VPN networks
As shown in Figure 4, after the PEs and ASBRs complete route learning, packets between site 1 and site 2 are forwarded as follows:
1.     Upon receiving a packet from site 2, PE 2 adds a private network label to the packet, and forwards the packet to ASBR 2 through the public network tunnel.
2.     ASBR 2 performs a routing table lookup in the VPN instance associated with the private network label of the packet, encapsulates an SRv6 SID, and forwards the packet to ASBR 1 in SRv6 BE or SRv6 TE mode.
3.     ASBR 1 determines the VPN instance associated with the SRv6 SID of the packet, removes the SRv6 SID, performs a routing table lookup in the VPN instance, and adds a private network label to the packet. Then ASBR 1 forwards the packet to PE 1 through the public network tunnel.
4.     Upon receiving the packet, PE 1 performs a routing table lookup in the VPN instance associated with the private network label of the packet, locates the output interface, removes the private network label, and forwards the packet to site 1.
As shown in Figure 5, EVPN VXLAN is deployed at each site for inter-site Layer 2 connectivity and EVPN gateways are deployed for Layer 3 connectivity across sites. The sites are connected by an EVPN L3VPN over SRv6 network. To ensure connectivity between the sites over the EVPN L3VPN over SRv6 network, enable intercommunication between SRv6 and EVPN VXLAN networks on the border devices.
Figure 5 Network diagram for intercommunication between SRv6 and EVPN VXLAN networks
When intercommunication between SRv6 and EVPN VXLAN networks is enabled on a border device, the border device processes routes as follows:
·     When the border device receives EVPN IP prefix advertisement routes that include an L3 VXLAN ID from the EVPN VXLAN network, it matches the route targets with the local import route targets. If a matching VPN instance is found, the border device adds the routes to the routing table of the matching VPN instance. Then, the border device allocates an SRv6 SID to the routes based on the VPN instance configuration. Finally, the border device advertises the EVPN IP prefix advertisement routes that include an SRv6 SID to the EVPN L3VPN over SRv6 network.
·     When the border device receives EVPN IP prefix advertisement routes that include an SRv6 SID from the EVPN L3VPN over SRv6 network, it matches the route targets with the local import route targets. If a matching VPN instance is found, the border device adds the routes to the routing table of the matching VPN instance. Then, the border device allocates an L3 VXLAN ID to the routes based on the VPN instance configuration. Finally, the border device advertises the EVPN IP prefix advertisement routes that include an L3 VXLAN ID to the EVPN VXLAN network.
Figure 6 Packet forwarding between SRv6 and EVPN VXLAN networks
After the VTEPs and border devices finish route learning, packets from Site 2 to Site 1 are forwarded as follows:
1.     When VTEP 2 receives packets from Site 2, it adds VXLAN encapsulation to the packets and forwards the packets to Border 2. The VXLAN ID encapsulated in the packets is the L3 VXLAN ID.
2.     Border 2 performs the following operations:
a.     Identifies the VPN instance of the packets based on the L3 VXLAN ID.
b.     Removes the VXLAN encapsulation.
c.     Looks up the routing table of the VPN instance for a matching route.
d.     Adds an SRv6 SID to the packets and encapsulates other SRv6 information to the packets.
e.     Forwards the packets to Border 1 in SRv6 BE or SRv6 TE mode.
3.     Border 1 performs the following operations:
a.     Identifies the VPN instance of the packets based on the SRv6 SID.
b.     Removes the SRv6 encapsulation.
c.     Looks up the routing table of the VPN instance.
d.     Adds VXLAN encapsulation to the packets. The VXLAN ID encapsulated in the packets is the L3 VXLAN ID.
e.     Forwards the packets to VTEP 1.
4.     When VTEP 1 receives the packets, it removes the VXLAN encapsulation and forwards the packets to CE 1.
In a cross-AS SRv6 VPN network where SRv6 is deployed in multiple ASs, to implement cross-AS communication, you typically need to advertise locator routes across the ASs. (For example, you can redistribute the locator routes advertised by IGP into BGP for cross-AS route advertisement.) After cross-AS advertisement for the locator routes, the PEs in different ASs can establish an SRv6 forwarding path. For security purposes, if you do not want to transmit locator routes across ASs, you can configure the ASBRs as transit proxy devices to change the SRv6 SIDs carried in routes to the SRv6 SIDs in the local VPN instances. This avoids locator route advertisement to another AS. The PEs in different ASs can establish a cross-AS SRv6 forwarding path.
Figure 7 Transit proxies for SRv6 SIDs in a cross-AS EVPN L3VPN over SRv6 network
As shown in Figure 7, to disable forwarding of locator routes on PE 1 to PE 2 and implement communication between site 1 and site 2, configure ASBR 2 to change the SRv6 SIDs carried in BGP routes. ASBR 2 then process BGP routes as follows:
·     Upon receiving an IP prefix route carrying an SRv6 SID from ASBR 1, ASBR 2 adds the route to the routing table of the VPN instance matching the local RT, and delete SRv6 SID from the route. ASBR 2 then re-applies for an SRv6 SID for the IP prefix route in the VPN instance matching the local RT. The re-applied SRv6 SID is the same type as the original SID.
IMPORTANT
IMPORTANT:
End.DX4 SIDs and End.DX6 SIDs cannot be re-applied.
·     When forwarding received IP prefix routes to PE 2, ASBR 2 forwards only the routes with new SRv6 SIDs.
Figure 8 Forwarding of SRv6 SID packets by the transit proxy in a cross-AS EVPN L3VPN over SRv6 network
As shown in Figure 8, after route learning, packets are forwarded from site 2 to site 1 as follows:
1.     Upon receiving a packet from site 2, PE 2 looks up in the VPN routing table for route-associated SRv6 SID. Then it encapsulates the SRv6 SID (re-applied by ASBR 2 for the BGP route in the local VPN instance) for the packet, and sends the packet to ASBR 2 in SRv6 BE or SRv6 TE mode.
2.     ASBR 2 determines the VPN instance of the received packet based on the SRv6 SID, removes the SRv6 encapsulation, and looks up in the routing table of the associated VPN instance. After obtaining the route-associated SRv6 SID, it encapsulates the SRv6 SID (original SRv6 SID advertised by PE 1) for the packet, and sends the packet to PE 1 in SRv6 BE or SRv6 TE mode.
3.     Upon receiving the packet, PE 1 determines the VPN instance of the received packet based on the SRv6 SID, removes the SRv6 encapsulation, looks up in the routing table of the associated VPN instance, and forwards the packet to site 1.
The packet forwarding procedure requires the ASBR to obtain the PE-advertised locator route in the peer AS. The PE does not need to obtain the PE-advertised locator route in the peer AS. It only requires the ASBR-advertised locator route in the local AS. The transit proxy behavior of the ASBR resolves the communication issues between SRv6 sites when locator routes are not advertised across ASs.
As shown in Figure 9, the ASBR connects both the EVPN L3VPN over SRv6 network and the IP L3VPN over SRv6 network. The ASBR advertises BGP routes between different networks by converting between IP prefix routes and BGP VPNv4/VPNv6 routes for intercommunication between the EVPN L3VPN over SRv6 and IP L3VPN over SRv6 networks.
Figure 9 Intercommunication between EVPN L3VPN over SRv6 and IP L3VPN over SRv6 networks
With intercommunication between EVPN L3VPN over SRv6 and IP L3VPN over SRv6 networks configured, the ASBR process BGP routes as follows:
·     Upon receiving an IP prefix route from the EVPN L3VPN over SRv6 network, the ASBR reoriginates a BGP VPNv4/VPNv6 route with the same prefix in the VPN instance matching the RT of the IP prefix route. In addition, it re-applies for an SRv6 SID for the reoriginated BGP VPNv4 route in the VPN instance. The ASBR advertises the reoriginated BGP VPNv4/VPNv6 route to the PE in the IP L3VPN over SRv6 network.
·     Upon receiving a BGP VPNv4/VPNv6 from the IP L3VPN over SRv6 network, the ASBR reoriginates an IP prefix route with the same prefix in the VPN instance matching the RT of the BGP VPNv4/VPNv6 route. In addition, it re-applies for an SRv6 SID for the reoriginated IP prefix route in the VPN instance. The ASBR advertises the reoriginated IP prefix route to the PE in the L3VPN L3VPN over SRv6 network.
Figure 10 Packet forwarding between EVPN L3VPN over SRv6 and IP L3VPN over SRv6 networks
As shown in Figure 10, after route learning, IPv4 packets are forwarded from site 2 to site 1 as follows:
1.     Upon receiving a packet from site 2, PE 2 looks up in the VPN routing table for route-associated SRv6 SID. Then it encapsulates the SRv6 SID (re-applied by the ASBR for the BGP VPNv4 route in the local VPN instance) for the packet, and sends the packet to the ASBR in SRv6 BE or SRv6 TE mode.
2.     The ASBR determines the VPN instance of the received packet based on the SRv6 SID, removes the SRv6 encapsulation, and looks up in the routing table of the associated VPN instance. After obtaining the route-associated SRv6 SID, it encapsulates the SRv6 SID (original SRv6 SID in the IP prefix route advertised by PE 1) for the packet, and sends the packet to PE 1 in SRv6 BE or SRv6 TE mode.
EVPN L3VPN over SRv6 Fast Reroute (FRR) is applicable to a dualhomed scenario, as shown in Figure 11. By using static BFD to detect the primary link, FRR enables a PE to use the backup link when the primary link fails. The PE then selects a new optimal route, and uses the new optimal route to forward traffic.
EVPN L3VPN over SRv6 uses EVPN route backup for an EVPN route.
Figure 11 Network diagram of EVPN route backup for an EVPN route
As shown in Figure 11, configure FRR on the ingress node PE 1, and specify the backup next hop for VPN 1 as PE 3. When PE 1 receives an EVPN route to CE 2 from both PE 2 and PE 3, it uses the route from PE 2 as the primary link, and the route from PE 3 as the backup link.
Configure static BFD for public tunnels on PE 1 to detect the connectivity of the public tunnel from PE 1 to PE 2. When the tunnel PE 1PE 2 operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2. When the tunnel fails, the traffic goes through the path CE 1—PE 1—PE 3—CE 2.
In this scenario, PE 1 is responsible for primary link detection and traffic switchover.
For more information about static BFD, see BFD configuration in High Availability Configuration Guide.
To configure EVPN L3VPN over SRv6, perform the following tasks:
1.     Configuring a VPN instance and associating interfaces connected to CEs with the VPN instance
Perform this task on PEs. For more information, see MPLS L3VPN in MPLS Configuration Guide.
2.     Configuring route exchange between a PE and a CE
Configure an IPv4 routing protocol (static routing, RIP, OSPF, IS-IS, EBGP, or IBGP) or an IPv6 routing protocol (IPv6 static routing, RIPng, OSPFv3, IPv6 IS-IS, EBGP, or IBGP) to exchange routes between a PE and a CE
On the CE, configure an IPv4 or IPv6 routing protocol to advertise routes of the local site to the PE. On the PE, associate the routing protocol with the VPN instance. For more information about routing protocol configurations, see Layer 3—IP Routing Configuration Guide.
3.     Configuring route exchange between PEs
a.     Configuring SRv6 SIDs
Perform this task to manually configure End.DT4, End.DT6, End.DT46, End.DX4, or End.DX6 SIDs.
b.     Applying a locator to a BGP VPN instance
BGP can advertise SRv6 SIDs through BGP routes only after you apply a locator to BGP.
c.     Configuring SRv6-encapsulated EVPN route advertisement
Perform this task to advertise VPN routes as EVPN routes to a peer or peer group in the EVPN L3VPN over SRv6 network.
d.     Configuring PEs to exchange BGP EVPN routes
e.     (Optional.) Configuring next hop-based dynamic End.DX4 or End.DX6 SID allocation for BGP routes
This feature enables a PE to dynamically allocate End.DX4 or End.DX6 SIDs to BGP private network routes based on the route next hops.
f.     (Optional.) Configuring BGP EVPN route settings
4.     Configuring the route recursion mode
5.     Specifying a source address for the outer IPv6 header of SRv6-encapsulated EVPN L3VPN packets
This feature specifies the source address of the outer IPv6 header for SRv6 packets forwarded between two private network sites over the backbone network.
6.     (Optional.) Enabling SRv6 VPN compatibility for a peer or peer group
7.     (Optional.) Configuring inter-AS option B VPN
8.     (Optional.) Configuring intercommunication between SRv6 and MPLS L3VPN networks
9.     (Optional.) Enabling intercommunication between SRv6 and EVPN VXLAN networks
10.     (Optional.) Configuring transit proxies for SRv6 SIDs in cross-AS EVPN L3VPN over SRv6 networks
11.     (Optional.) Configuring intercommunication between EVPN L3VPN over SRv6 and IP L3VPN over SRv6 networks
12.     (Optional.) Configuring EVPN L3VPN over SRv6 FRR
13.     (Optional.) Configuring SBFD for SRv6 locators
14.     (Optional.) Configuring a TTL processing mode for tunnels associated with a VPN instance
2.     Enable SRv6 and enter SRv6 view.
segment-routing ipv6
3.     Configure a locator and enter SRv6 locator view.
locator locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
4.     Configure an opcode. Perform one of the following tasks:
¡     Configure End.DT4 SIDs.
opcode { opcode | hex hex-opcode } end-dt4 vpn-instance vpn-instance-name evpn
The specified VPN instance must exist. The same End.DT4 SIDs cannot be configured in different VPN instances.
¡     Configure End.DT6 SIDs.
opcode { opcode | hex hex-opcode } end-dt6 vpn-instance vpn-instance-name evpn
The specified VPN instance must exist. The same End.DT6 SIDs cannot be configured in different VPN instances.
¡     Configure End.DT46 SIDs.
opcode { opcode | hex hex-opcode } end-dt46 vpn-instance vpn-instance-name evpn
The specified VPN instance must exist. The same End.DT46 SIDs cannot be configured in different VPN instances.
¡     Configure End.DX4 SIDs.
opcode { opcode | hex hex-opcode } end-dx4 interface interface-type interface-number nexthop nexthop-ipv4-address vpn-instance vpn-instance-name evpn
The specified VPN instance must exist. The same End.DX4 SIDs cannot be configured with different output interfaces or next hops.
¡     Configure End.DX6 SIDs.
opcode { opcode | hex hex-opcode } end-dx6 interface interface-type interface-number nexthop nexthop-ipv6-address vpn-instance vpn-instance-name evpn
The specified VPN instance must exist. The same End.DX6 SIDs cannot be configured with different output interfaces or next hops.
Use this feature in BGP-VPN IPv4 or IPv6 unicast address family view of a VPN instance to apply for SRv6 SIDs for the private network routes of the VPN instance.
Use this feature if the device will use End.DT4, End.DT6, End.DT46, End.DX4, or End.DX6 SIDs to deliver EVPN traffic across sites.
The VPN instance of the specified locator must be the same as the VPN instance of the private network. To specify a VPN instance for a locator, use the opcode end-dt4, opcode end-dt6, opcode end-dt46, opcode end-dx4, or opcode end-dx6 command in SRv6 locator view.
Before you perform this task, you must create the specified locator.
3.     Enter BGP-VPN instance view.
4.     Enter BGP-VPN IPv4 unicast address family view or BGP-VPN IPv6 unicast address family view.
¡     Enter BGP-VPN IPv4 unicast address family view.
¡     Enter BGP-VPN IPv6 unicast address family view.
5.     Apply a locator to the BGP VPN instance.
¡     Apply a common locator to the BGP VPN instance.
segment-routing ipv6 locator locator-name evpn [ auto-sid-disable ]
¡     Apply an anycast locator to the BGP VPN instance.
segment-routing ipv6 locator locator-name anycast evpn
After configuring this command, you must configure the peer advertise encap-type srv6 command with the anycast keyword in order to advertise EVPN routes to the specified peer or peer group.
By default, no locator is applied to a BGP VPN instance.
Perform this task to ensure that a PE can advertise VPN routes as EVPN routes to a peer or peer group in an EVPN L3VPN over SRv6 network.
Perform this task on the edge nodes of the EVPN L3VPN network and RRs.
3.     Enter BGP EVPN address family view.
address-family l2vpn evpn
4.     Enable SRv6 encapsulation for the EVPN IP prefix advertisement routes advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise encap-type srv6 [ anycast ]
By default, IP prefix advertisement routes use VXLAN encapsulation.
After specifying the anycast keyword, you must configure the segment-routing ipv6 locator anycast command in order to exchange SRv6 SID information in the anycast locator through EVPN routes.
To ensure optimal route selection and SRv6 tunnel traffic forwarding, make sure a pair of PEs are not both IPv4 and IPv6 peers to each other.
3.     Configure an IPv6 peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } as-number as-number
4.     Specify the source interface of TCP connections to a peer or peer group.
By default, BGP uses the IPv6 address of the output interface in the optimal route to the BGP peer or peer group as the source address of TCP connections to the peer or peer group.
5.     Enter BGP EVPN address family view.
6.     Enable BGP to exchange EVPN routes with an IPv6 peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } enable
By default, BGP cannot exchange EVPN routes with an IPv6 peer or peer group.
Perform this task to forward an SRv6 decapsulated VPN packet to the next hop without looking up the routing table of the VPN instance.
If you assign an End.DT4 SID, End.DT6 SID, or End.DT46 SID to a BGP VPN instance, all BGP private network routes of the instance are allocated that SID. When a PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the VPN instance based on the SID for an optimal route. Then, the PE forwards the packet to a CE. To forward the packet to the next hop without looking up the routing table of the VPN instance, perform this task.
This task dynamically allocates End.DX4 or End.DX6 SIDs to specific next hops or all next hops of the BGP private network routes in a VPN instance based on the next hop addresses. When forwarding a packet, the PE searches for the output interface and next hop based on the End.DX4 or End.DX6 SID of the packet. Then, the PE directly forwards the packet out of the output interface to the next hop.
Before you perform this task in BGP-VPN IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
This feature cannot allocate End.DX4 or End.DX6 SIDs to direct routes.
5.     Configure next hop-based dynamic End.DX4 or End.DX6 SID allocation for BGP private network routes. Choose one of the following tasks:
¡     Automatically allocate an End.DX4 or End.DX6 SID to each next hop of BGP private network routes.
segment-routing ipv6 apply-sid all-nexthop evpn
¡     Execute the following commands in sequence to automatically allocate an End.DX4 or End.DX6 SID to the specified next hop of BGP private network routes:
segment-routing ipv6 apply-sid specify-nexthop evpn
nexthop nexthop-address interface interface-type interface-number
By default, VPN instance-based SID allocation is used for private network routes.
For more information about the commands in this section, see BGP commands in Layer 3—IP Routing Command Reference.
4.     Configure the device as an RR and specify a peer or peer group as its client.
peer { group-name | ipv6-address [ prefix-length ] } reflect-client
By default, no RR or client is configured.
5.     (Optional.) Enable BGP EVPN route reflection between clients.
reflect between-clients
By default, BGP EVPN route reflection between clients is enabled.
6.     (Optional.) Configure the cluster ID of the RR.
By default, an RR uses its own router ID as the cluster ID.
7.     (Optional.) Create a reflection policy for the RR to filter reflected BGP EVPN routes.
rr-filter { ext-comm-list-number | ext-comm-list-name }
By default, an RR does not filter reflected BGP EVPN routes.
8.     (Optional.) Enable the RR to change the attributes of routes to be reflected.
reflect change-path-attribute
By default, an RR cannot change the attributes of routes to be reflected.
4.     Configure the NEXT_HOP attribute. Choose one option as needed:
¡     Specify the router as the next hop for routes sent to a peer or peer group.
¡     Configure the device to not change the next hop of routes advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } next-hop-invariable
By default, the router sets itself as the next hop for routes sent to a peer or peer group.
The peer next-hop-local and peer next-hop-invariable commands are mutually exclusive.
5.     Permit the local AS number to appear in routes from a peer or peer group and set the number of appearances.
peer { group-name | ipv6-address [ prefix-length ] } allow-as-loop [ number ]
By default, the local AS number is not allowed in routes from peers.
6.     Advertise the COMMUNITY attribute to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise-community
By default, the device does not advertise the COMMUNITY attribute to peers or peer groups.
7.     Advertise the Large community attribute to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise-large-community
By default, the Large community attribute is not advertised to a peer or peer group.
8.     Enable BGP to filter next hop routes obtained through recursive lookup based on a routing policy.
nexthop recursive-lookup route-policy route-policy-name
By default, BGP does not filter next hop routes obtained through recursive lookup based on a routing policy.
CAUTION
CAUTION:
If all next hops routes obtained through recursive lookup in an address family fail to match the specified routing policy, all BGP routes in the address family become unreachable. To avoid this issue, before configuring the command, make sure the target next hop routes can match the permit-mode node in the routing policy.
4.     Filter routes advertised to a peer or peer group.
filter-policy { mac-acl-number | name mac-acl-name } export
By default, routes advertised to peers or peer groups are not filtered.
5.     Filter routes received from a peer or peer group.
filter-policy { mac-acl-number | name mac-acl-name } import
By default, routes received from peers or peer groups are not filtered.
6.     Apply a routing policy to routes received from or advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } route-policy route-policy-name { export | import }
By default, no routing policies are applied to routes received from or advertised to peers or peer groups.
7.     Enable route target filtering for BGP EVPN routes.
policy vpn-target
By default, route target filtering is enabled for BGP EVPN routes.
4.     Configure the BGP Additional Paths capabilities.
peer { group-name | ipv6-address [ prefix-length ] } additional-paths { receive | send } *
By default, no BGP Additional Paths capabilities are configured.
5.     Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise additional-paths best number
By default, a maximum of one Add-Path optimal route can be advertised to a peer or peer group.
6.     Set the maximum number of Add-Path optimal routes that can be advertised to all peers.
By default, a maximum number of one Add-Path optimal route can be advertised to all peers.
7.     (Optional.) Set the optimal route selection delay timer.
By default, the optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
After a PE receives a customer packet destined for an SRv6 SID, it forwards the packet according to the route recursion mode.
·     SRv6 BE mode—This mode is also called SID-based forwarding mode. In this mode, the PE first encapsulates the End.DT4, End.DT6, or End.DT46 SID into the packet. Then, the PE searches the IPv6 routing table based on the SID encapsulated in the packet to forward the packet.
·     SRv6 TE mode—This mode is also called SRv6 TE policy-based forwarding mode. In this mode, the PE first searches for a matching SRv6 TE policy based on the packet attributes. Then, the PE adds an SRH to the packet. The SRH includes the End.DT4, End.DT6, or End.DT46 SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet through the SRv6 TE policy. For more information, see "Configuring SRv6 TE policies."
·     SRv6 TE and SRv6 BE hybrid mode—In this mode, the PE preferentially uses the SRv6 TE mode to forward the packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6 BE mode.
·     SRv6 TE and SRv6 BE FRR mode—This mode implements FRR by using the SRv6 TE path (primary path) and SRv6 BE path (backup path). If the SRv6 TE path fails or does not exist, traffic is immediately switched to the SRv6 BE path to ensure service continuity.
5.     Configure the route recursion mode.
segment-routing ipv6 { best-effort | traffic-engineering | traffic-engineering best-effort | traffic-engineering best-effort-backup } evpn
By default, a PE searches the IPv6 routing table based on the next hop of a matching route to forward traffic.
To ensure correct VPN traffic forwarding in an EVPN L3VPN over SRv6 network, you must specify a source address for the outer IPv6 header of SRv6-encapsulated EVPN L3VPN packets.
You cannot specify a loopback address, link-local address, multicast address, or unspecified address as the source IPv6 address. You must specify an IPv6 address of the local device as the source IPv6 address, and make sure the IPv6 address has been advertised by a routing protocol. As a best practice, specify a loopback interface address of the local device as the source IPv6 address.
2.     Enter SRv6 view.
3.     Specify a source address for the outer IPv6 header of SRv6-encapsulated EVPN L3VPN packets.
encapsulation source-address ipv6-address [ ip-ttl ttl-value ]
By default, no source address is specified for the outer IPv6 header of SRv6-encapsulated EVPN L3VPN packets.
In an EVPN L3VPN over SRv6 network, PE devices from different vendors might use different formats to encrypt SRv6 SIDs in the EVPN routes. As a result, the PE devices might fail to identify the received EVPN routes, causing route advertisement failure. To resolve this issue, you can perform this task to change the SRv6 SID encryption format for BGP routes sent by H3C devices for interoperability with devices from other vendors.
4.     Enable SRv6 VPN compatibility for a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } srv6-vpn compatible srv6-sid-transposition
By default, SRv6 VPN compatibility is disabled for a peer or peer group. The device encapsulates SRv6 SIDs for sent BGP routes in the non-Transposition-Scheme format as defined in RFC 9252.
For intercommunication between an MPLS network in one AS and an SRv6 network in another AS, enable SRv6 and MPLS interworking on the ASBR in the SRv6 network. This feature enables End.T SID allocation and establishes mappings between End.T SIDs and MPLS labels.
After you enable SRv6 and MPLS interworking, the per-next-hop label allocation mode applies to routes forwarded from SRv6 networks to MPLS networks. The label allocation mode is not affected by the label-allocation-mode or apply-label command. For more information about the label-allocation-mode command, see BGP commands in Layer 3—IP Routing Command Reference. For more information about the apply-label command, see MPLS L3VPN commands in MPLS Command Reference.
4.     Enable the device to reoriginate BGP EVPN routes based on the BGP EVPN routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ replace-rt ]
By default, the device does not reoriginate BGP EVPN routes based on received BGP EVPN routes.
5.     (Optional.) Enable the device to advertise original BGP EVPN routes to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise original-route
By default, the device advertises only reoriginated BGP EVPN routes to peers and peer groups after the peer re-originated command is executed.
6.     (Optional.) Suppress advertisement of reoriginated BGP EVPN routes to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated ip-prefix
By default, the device advertises reoriginated BGP EVPN routes to peers and peer groups after the peer re-originated command is executed.
7.     Enable SRv6 and MPLS interworking.
srv6-mpls-interworking enable
By default, SRv6 and MPLS interworking is disabled.
8.     Apply a locator to the BGP VPN instance.
9.     Configure the route recursion mode.
segment-routing ipv6 { best-effort | traffic-engineering | traffic-engineering best-effort } evpn
For communication between the data centers deployed with MPLS L3VPN networks and connected through an EVPN L3VPN over SRv6 network, configure this feature on the ASBRs of data centers.
Before you perform this task, enable SRv6 and MPLS interworking on the ASBR.
Reoriginating VPNv4/VPNv6 routes as EVPN IP prefix advertisement routes
3.     Enter BGP VPNv4 address family view or BGP VPNv6 address family view.
¡     Enter BGP VPNv4 address family view.
address-family vpnv4
¡     Enter BGP VPNv6 address family view.
address-family vpnv6
4.     Reoriginate routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated stitch-evpn
By default, routes received from a peer or peer group are not reoriginated.
Reoriginating EVPN IP prefix advertisement routes as VPNv4/VPNv6 routes
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ] stitch-l3vpn
When EVPN VXLAN is deployed within data centers and the data centers are interconnected through an EVPN L3VPN over SRv6 network, configure this feature on the border device for each data center. This feature enables intercommunication between the data centers.
In a cross-AS SRv6 network, you can configure this feature on the ASBR to disable locator route advertisement to another AS. The feature implements transit proxy for cross-AS SRv6 network communication by changing the SRv6 SIDs carried in BGP routes.
Upon receiving an IP prefix route carrying an SRv6 SID from the peer, the device adds the route to the routing table of the VPN instance matching the local RT, and delete SRv6 SID from the route. The device then re-applies for an SRv6 SID for the IP prefix route in the VPN instance matching the local RT. The re-applied SRv6 SID is the same type as the original SID. When forwarding received IP prefix routes, the device only needs to send routes with the new SRv6 SID.
4.     Change the SRv6 SIDs of the routes received from the specified peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ] [ replace-rt ] replace-sid
By default, the device does not change information about IP prefix routes received from the peer or peer group.
For more information about this command, see EVPN commands in EVPN Command Reference.
To implement intercommunication between EVPN L3VPN over SRv6 and IP L3VPN over SRv6 networks, you need to configure this feature on the ASBR connecting the two networks.
4.     Enable advertisement of BGP VPNv4 or VPNv6 routes through the BGP EVPN address family to peer.
advertise l3vpn route [ replace-rt ] replace-sid [ advertise-policy policy-name ]
By default, the device does not send BGP VPNv4 or VPNv6 routes through the EVPN address family.
5.     Return to BGP instance view.
6.     Enter BGP VPNv4 or BGP VPNv6 address family view.
7.     Enable advertisement of BGP EVPN routes through the BGP VPNv4 or VPNv6 address family to peer.
advertise evpn route [ replace-rt ] replace-sid [ advertise-policy policy-name ]
By default, the device does not send BGP EVPN routes through the BGP VPNv4 or VPNv6 address family.
EVPN L3VPN over SRv6 FRR enables the device to calculate backup routes for all routes of the current address family to reduce the traffic interruption caused by link or device failures on the backbone. If the device learns two unequal-cost routes destined for the same network from different peers, the optimal route is backed up by the other route. When the optimal route becomes unavailable, the device uses the backup route to forward traffic. At the same time, the device calculates a new optimal route and then uses it to direct traffic forwarding.
This feature might cause routing loops in certain conditions. Make sure you are fully aware of this feature when you use it on a live network.
2.     Configure static BFD.
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address [ track-interface interface-type interface-number ] ]
3.     Specify the local and remote discriminators for the static BFD session.
discriminator { local local-value | remote remote-value }
By default, no local discriminator or remote discriminator is specified for a static BFD session.
4.     Return to system view.
5.     Enter BGP instance view.
6.     Configure BGP FRR to use BFD to detect next hop connectivity for the primary route.
primary-path-detect bfd echo
By default, BGP FRR uses ARP to detect the connectivity to the next hop of the primary route.
For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
7.     Enter BGP-VPN IPv4 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP EVPN address family view.
¡     Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
¡     Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
¡     Enter BGP EVPN address family view.
8.     Enable FRR for the address family.
pic
By default, FRR is disabled.
On a PE deployed with a VPN instance, as a best practice, configure this command in BGP-VPN IPv4 unicast address family view or BGP-VPN IPv6 unicast address family view.
On the ASBR not deployed with a VPN instance, as a best practice, configure this command in BGP EVPN address family view.
As shown in Figure 12, in the EVPN L3VPN over SRv6 BE scenario, CE 2 is dual homed to PE 2 and PE 3. After you enable FRR on PE 1, a primary path and a backup path are generated on PE 1. When the primary path fails, you can configure this feature for fast traffic switchover to the backup path. Use SBFD to detect connectivity of SRv6 locators advertised by PE 2 (used as next hop addresses obtained through route recursion for private network routes) to fast locate primary path failures and switch traffic over to the backup path.
Figure 12 Using SBFD to detect SRv6 locators in a dual-homed network
SBFD detects the connectivity of SRv6 locators as follows:
1.     PE 1 sends SBFD packets as the initiator. The SRv6 locators are the destination addresses of the SBFD packets. The IP address specified in the sbfd source-ipv6 command is used as the source IP address of SBFD packets.
2.     When PE 2 and PE 3 receive the SBFD packets as reflectors, they compare the remote discriminators in the packets with the locally configured discriminators.
¡     If they are consistent, the reflectors send SBFD response packets to the initiator through IPv6 routes.
¡     If they are inconsistent, the reflectors drop the received SBFD packets.
3.     If the initiator can receive SBFD response packets before the detection timer expires, it determines that the SRv6 locators are reachable. If not, the initiator determines that the SRv6 locators are unreachable, and switches over to the backup path.
To have this feature take effect, execute the sbfd destination ipv6 remote-discriminator command on PE 1 to configure the mappings between the detected SRv6 locators and remote discriminators. In addition, execute the sbfd local-discriminator command on PE 2 and PE 3 to configure the local discriminators on the reflector end. Make sure PE 1 have consistent discriminator settings with PE 2 and PE 3. For more information about the sbfd destination ipv6 remote-discriminator and sbfd local-discriminator commands, see BFD commands in High Availability Command Reference.
2.     Enter SRv6 view.
3.     Configure SBFD for SRv6 locators.
locator-sbfd enable [ template template-name ] [ prefix-list prefix-list-name ]
By default, SBFD is not configured for SRv6 locators.
A tunnel associated with a VPN instance supports the following TTL processing modes:
·     Pipe—When an IP or IPv6 packet enters the tunnel of the VPN instance, the ingress node adds a new header to the packet. The ingress node sets the TTL value or hop limit in the new header to 255 or the value specified by using the encapsulation source-address ip-ttl command in SRv6 view. When the packet leaves the tunnel of the VPN instance, the egress node removes the new header from the packet.The TTL value or hop limit in the original packet does not change when the packet is forwarded in the tunnel. Therefore, the public network nodes are invisible to user networks, and the tracert facility cannot show the real path in the public network.
·     Uniform—When an IP or IPv6 packet enters the tunnel of the VPN instance, the ingress node adds a new header to the packet. The ingress node copies the TTL value or the hop limit of the original packet to the TTL or hop limit field of the new header. When the packet leaves the tunnel of the VPN instance, the egress node copies the remaining TTL value or hop limit in the new header back to the original packet. The TTL value or hop limit can reflect how many hops the packet has traversed in the public network. The tracert facility can show the real path along which the packet has traveled.
In the current software version, you can configure a TTL processing mode only for SRv6 tunnels associated with VPN instances.
2.     Enter VPN instance view.
ip vpn-instance vpn-instance-name [ index vpn-index ]
3.     Configure a TTL processing mode for the tunnels associated with the VPN instance.
ttl-mode { pipe | uniform }
By default, the TTL processing mode for the tunnels associated with a VPN instance is pipe.
For more information about this command, see MPLS L3VPN commands in MPLS Command Reference.
To display BGP EVPN route information, execute the following command in any view:
display bgp [ instance instance-name ] l2vpn evpn [ peer ipv4-address { advertised-routes | received-routes } [ statistics ] | route-distinguisher route-distinguisher [ route-type ip-prefix ] [ evpn-route route-length [ advertise-info ] ] | route-type { auto-discovery | es | imet | ip-prefix | mac-ip } | statistics ]
For more information about this command, see EVPN Command Reference.
For BGP setting changes to take effect, you must reset or soft-reset BGP sessions. Soft-resetting BGP sessions updates BGP routing information without tearing down the BGP sessions. Resetting BGP sessions updates BGP routing information by tearing down and re-establishing the BGP sessions. Soft-reset requires that both the local router and the peer support ROUTE-REFRESH messages.
For more information about the commands in this task, see basic BGP commands in Layer 3—IP Routing Command Reference.
Perform the tasks in user view.
·     Soft-reset BGP sessions of the BGP EVPN address family.
refresh bgp [ instance instance-name ] ipv6-address [ prefix-length ] { export | import } l2vpn evpn
·     Reset BGP sessions of the BGP EVPN address family.
reset bgp [ instance instance-name ] ipv6-address [ prefix-length ] l2vpn evpn
As shown in Figure 13, the backbone network is an IPv6 network, and VPN 1 is an IPv4 network. Deploy EVPN L3VPN over SRv6 in SRv6 BE mode between PE 1 and PE 2 and use an SRv6 tunnel to transmit EVPN traffic between the PEs.
·     Configure EBGP to exchange VPN routing information between the CEs and PEs.
·     Configure IPv6 IS-IS on the PEs in the same AS to realize IPv6 network connectivity.
·     Configure MP-IBGP to exchange EVPN routing information between the PEs.
Figure 13 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
10.1.1.2/24
PE 2
Loop0
3::3/128
PE 1
Loop0
1::1/128
GE1/0/1
10.2.1.1/24
GE1/0/1
10.1.1.1/24
GE1/0/2
2002::1/96
GE1/0/2
2001::1/96
CE 2
GE1/0/1
10.2.1.2/24
P
Loop0
2::2/128
GE1/0/1
2001::2/96
GE1/0/2
2002::2/96
1.     Configure IPv6 IS-IS on the PEs and device P for network connectivity between the devices:
# Configure PE 1.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] is-level level-1
[PE1-isis-1] cost-style wide
[PE1-isis-1] network-entity 10.1111.1111.1111.00
[PE1-isis-1] address-family ipv6 unicast
[PE1-isis-1-ipv6] quit
[PE1-isis-1] quit
[PE1] interface loopback 0
[PE1-LoopBack0] ipv6 address 1::1 128
[PE1-LoopBack0] isis ipv6 enable 1
[PE1-LoopBack0] quit
[PE1] interface gigabitethernet 1/0/2
[PE1-GigabitEthernet1/0/2] ipv6 address 2001::1 96
[PE1-GigabitEthernet1/0/2] isis ipv6 enable
[PE1-GigabitEthernet1/0/2] quit
# Configure P.
<P> system-view
[P] isis
[P-isis-1] is-level level-1
[P-isis-1] cost-style wide
[P-isis-1] network-entity 10.2222.2222.2222.00
[P-isis-1] address-family ipv6 unicast
[P-isis-1-ipv6] quit
[P-isis-1] quit
[P] interface loopback 0
[P-LoopBack0] ipv6 address 2::2 128
[P-LoopBack0] isis ipv6 enable
[P-LoopBack0] quit
[P] interface gigabitethernet 1/0/1
[P-GigabitEthernet1/0/1] ipv6 address 2001::2 96
[P-GigabitEthernet1/0/1] isis ipv6 enable
[P-GigabitEthernet1/0/1] quit
[P] interface gigabitethernet 1/0/2
[P-GigabitEthernet1/0/2] ipv6 address 2002::2 96
[P-GigabitEthernet1/0/2] isis ipv6 enable
[P-GigabitEthernet1/0/2] quit
# Configure PE 2.
<PE2> system-view
[PE2] isis
[PE2-isis-1] is-level level-1
[PE2-isis-1] cost-style wide
[PE2-isis-1] network-entity 10.3333.3333.3333.00
[PE2-isis-1] address-family ipv6 unicast
[PE2-isis-1-ipv6] quit
[PE2-isis-1] quit
[PE2] interface loopback 0
[PE2-LoopBack0] ipv6 address 3::3 128
[PE2-LoopBack0] isis ipv6 enable
[PE2-LoopBack0] quit
[PE2] interface gigabitethernet 1/0/2
[PE2-GigabitEthernet1/0/2] ipv6 address 2002::1 96
[PE2-GigabitEthernet1/0/2] isis ipv6 enable
[PE2-GigabitEthernet1/0/2] quit
# Verify that PE 1, P, and PE 2 have established IPv6 IS-IS neighbor relationships and the neighbor state is up.
[PE1] display isis peer
[P] display isis peer
[PE2] display isis peer
# Verify that PE 1 and PE 2 each learn a route destined for the loopback interface of each other.
[PE1] display isis route ipv6
[PE2] display isis route ipv6
2.     Configure VPN instance settings on PE 1 and PE 2 and verify that each CE can access its local PE:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
[PE1-GigabitEthernet1/0/1] ip address 10.1.1.1 24
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
[PE2] interface gigabitethernet 1/0/1
[PE2-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
[PE2-GigabitEthernet1/0/1] ip address 10.2.1.1 24
[PE2-GigabitEthernet1/0/1] quit
# Configure IP addresses for the interfaces on the CEs, as shown in Figure 13. (Details not shown.)
# Display VPN instance settings on each PE. This step uses PE 1 as an example.
[PE1] display ip vpn-instance
  Total IPv4 VPN-Instances configured : 1
  Total IPv6 VPN-Instances configured : 1
  VPN-Instance Name     RD              Address family      Create time
  vpn1                  100:1           N/A                 2019/08/12 13:59:39
# Verify that each PE can ping its local CE. This step uses PE 1 and CE 1 as an example.
[PE1] ping -vpn-instance vpn1 10.1.1.2
Ping 10.1.1.2 (10.1.1.2): 56 data bytes, press CTRL+C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=255 time=2.000 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=255 time=0.000 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=255 time=1.000 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=255 time=0.000 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=255 time=0.000 ms
--- Ping statistics for 10.1.1.2 in VPN instance vpn1 ---
round-trip min/avg/max/std-dev = 0.000/0.600/2.000/0.800 ms
3.     Set up an EBGP peer relationship between each PE and its local CE and distribute VPN routes to EBGP:
# Configure CE 1.
<CE1> system-view
[CE1] bgp 65410
[CE1-bgp-default] peer 10.1.1.1 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.1 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
# Configure CE 2 in the same way as CE 1 is configured. (Details not shown.)
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] router-id 1.1.1.1
[PE1-bgp-default-vpn1] peer 10.1.1.2 as-number 65410
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.2 enable
[PE1-bgp-default-vpn1] quit
# Configure PE 2 in the same way PE 1 is configured. (Details not shown.)
# Verify that the PEs have established BGP peer relationships with their local CEs and the peers are in established state.
[PE1] display bgp peer ipv4 vpn-instance
[PE2] display bgp peer ipv4 vpn-instance
4.     Set up an MP-IBGP peer relationship between PE 1 and PE 2:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 3::3 as-number 100
[PE1-bgp-default] peer 3::3 connect-interface loopback 0
[PE1-bgp-default] address-family l2vpn evpn
[PE1-bgp-default-evpn] peer 3::3 enable
[PE1-bgp-default-evpn] quit
[PE1-bgp-default] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 1::1 as-number 100
[PE2-bgp-default] peer 1::1 connect-interface loopback 0
[PE2-bgp-default] address-family l2vpn evpn
[PE2-bgp-default-evpn] peer 1::1 enable
[PE2-bgp-default-evpn] quit
[PE2-bgp-default] quit
# Verify that the PEs have established a BGP peer relationship and the peers are in established state.
[PE1] display bgp peer l2vpn evpn
[PE2] display bgp peer l2vpn evpn
5.     Specify a source address for the outer IPv6 header of SRv6-encapsulated IPv4 EVPN L3VPN packets on PE 1 and PE 2:
# Configure PE 1.
[PE1] segment-routing ipv6
[PE1-segment-routing-ipv6] encapsulation source-address 1::1
# Configure PE 2.
[PE2] segment-routing ipv6
[PE2-segment-routing-ipv6] encapsulation source-address 3::3
6.     Configure the destination address (End.DT4 SID) of the outer IPv6 header for SRv6-encapsulated IPv4 EVPN L3VPN packets:
# Configure PE 1.
[PE1-segment-routing-ipv6] locator aaa ipv6-prefix 1:2::1:0 96 static 8
[PE1-segment-routing-ipv6-locator-aaa] quit
[PE1-segment-routing-ipv6] quit
[PE1] isis 1
[PE1-isis-1-ipv6] segment-routing ipv6 locator aaa
[PE1-isis-1] quit
# Configure PE 2.
[PE2-segment-routing-ipv6] locator bbb ipv6-prefix 6:5::1:0 96 static 8
[PE2-segment-routing-ipv6-locator-bbb] quit
[PE2-segment-routing-ipv6] quit
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator bbb
[PE2-isis-1] quit
# Verify that the PEs have distributed the End.DT4 SIDs to the routing table and generated SRv6 routes. This step uses PE 1 as an example.
[PE1] display ipv6 routing-table protocol srv6
Summary count : 1
SRv6 Routing table status : <Active>
Summary count : 1
Destination: 1:2::101/128                                Protocol  : SRv6
NextHop    : ::1                                         Preference: 4
Interface  : InLoop0                                     Cost      : 0
SRv6 Routing table status : <Inactive>
Summary count : 0
7.     Add End.DT4 SIDs to private network routes on PE 1 and PE 2:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 locator aaa evpn
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 locator bbb evpn
[PE2-bgp-default-vpn1] quit
8.     Enable IPv6 peers on the PEs to exchange End.DT4 SIDs and enable SRv6 BE mode:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 3::3 advertise encap-type srv6
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort evpn
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-evpn] peer 1::1 advertise encap-type srv6
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort evpn
# Display BGP EVPN routing information on each PE and verify that the routes advertised by the PEs have the SID attribute. This step uses PE 1 as an example.
[PE1] display bgp l2vpn evpn [5][0][24][10.2.1.0]/80
 BGP local router ID: 1.1.1.1
 Local AS number: 100
 Route distinguisher: 100:1(vpn1)
 Total number of routes: 1
 Paths:   1 available, 1 best
 BGP routing table information of [5][0][24][10.2.1.0]/80:
 Rely nexthop    : FE80::2A96:34FF:FE9D:216
 Original nexthop: 3::3
 Out interface   : GigabitEthernet1/0/2
 Route age       : 00h14m23s
 OutLabel        : NULL
 Ext-Community   : <RT: 111:1>
 RxPathID        : 0x0
 TxPathID        : 0x0
 PrefixSID       : End.DT4 SID <6:5::101>
 AS-path         : 65420
 Origin          : incomplete
 State           : valid, internal, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IP prefix advertisement route
 ESI             : 0000.0000.0000.0000.0000
 Ethernet tag ID : 0
 IP prefix       : 10.2.1.0/24
 Gateway address : 0.0.0.0
 MPLS label      : 16777215
 Tunnel policy   : NULL
 Rely tunnel IDs : N/A
# Display IPv4 routing table information on the PEs and verify that each PE has a route destined for the remote CE and the next hop of the route is the End.DT4 SID of the route. This step uses PE 1 as an example.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 11       Routes : 11
10.1.1.0/24        Direct  0   0           10.1.1.1        GE1/0/1
10.1.1.0/32        Direct  0   0           10.1.1.1        GE1/0/1
10.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
10.1.1.255/32      Direct  0   0           10.1.1.1        GE1/0/1
10.2.1.0/24        BGP     255 0           6:5::1:0        GE1/0/2
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Example: Configuring inter-AS option B VPN
As shown in Figure 14, an EVPN L3VPN network is deployed in AS 100 and an EVPN L3VPN over SRv6 network is deployed in AS 200. Configure inter-AS option B VPN to permit users in the same VPN instance to communicate with each other across the EVPN L3VPN and EVPN L3VPN over SRv6 networks.
Figure 14 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
10.1.1.2/24
CE 2
GE1/0/1
20.1.1.2/24
PE 1
Loop0
1.1.1.1/32
PE 2
Loop0
1::1/128
GE1/0/1
10.1.1.1/24
GE1/0/1
20.1.1.1/24
GE1/0/2
11.1.1.1/24
GE1/0/2
100::1/96
ASBR 1
Loop0
2.2.2.2/32
ASBR 2
Loop0
2::2/128
GE1/0/1
11.1.1.2/24
GE1/0/1
100::2/96
GE1/0/2
12.1.1.1/24
GE1/0/2
12.1.1.2/24
1.     Configure CE 1:
# Establish EBGP peer relationship with PE 1 and import VPN routes.
<CE1> system-view
[CE1] bgp 101
2.     Configure PE 1:
# Run IS-IS on PE 1.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] quit
# Specify an LSR ID and enable MPLS and LDP.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
# On interface GigabitEthernet 1/0/2, specify an IP address, run IS-IS, and enable MPLS and LDP.
[PE1-GigabitEthernet1/0/2] ip address 11.1.1.1 255.0.0.0
[PE1-GigabitEthernet1/0/2] isis enable 1
[PE1-GigabitEthernet1/0/2] mpls enable
[PE1-GigabitEthernet1/0/2] mpls ldp enable
# Create interface Loopback 0, specify an IP address for the interface, and run IS-IS on the interface.
[PE1-LoopBack0] isis enable 1
# Create a VPN instance named vpn1, enable EVPN to advertise the routes of the VPN instance, and configure a RD and route target for the VPN instance.
[PE1-vpn-instance-vpn1] vpn-target 100:1
[PE1-vpn-instance-vpn1] address-family ipv4
[PE1-vpn-ipv4-vpn1] evpn mpls routing-enable
[PE1-vpn-ipv4-vpn1] quit
# Associate the interface connected to CE 1 with VPN instance vpn1.
# Run BGP on PE 1.
[PE1] bgp 100
# Configure PE 1 to exchange BGP EVPN routes with peer 2.2.2.2.
[PE1-bgp-default] peer 2.2.2.2 as-number 100
[PE1-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[PE1-bgp-default-evpn] peer 2.2.2.2 enable
[PE1-bgp-default-evpn] peer 2.2.2.2 advertise encap-type mpls
# Establish EBGP peer relationship with CE 1 and import VPN routes.
[PE1-bgp-default-vpn1] peer 10.1.1.2 as-number 101
3.     Configure ASBR 1:
# Run IS-IS on ASBR 1.
<ASBR1> system-view
[ASBR1] isis 1
[ASBR1-isis-1] cost-style wide
[ASBR1-isis-1] network-entity 10.2222.2222.2222.00
[ASBR1-isis-1] quit
[ASBR1] mpls lsr-id 2.2.2.2
[ASBR1] mpls ldp
[ASBR1-ldp] quit
# On interface GigabitEthernet 1/0/1, specify an IP address, run IS-IS, and enable MPLS and LDP.
[ASBR1] interface gigabitethernet 1/0/1
[ASBR1-GigabitEthernet1/0/1] ip address 11.1.1.2 255.0.0.0
[ASBR1-GigabitEthernet1/0/1] isis enable 1
[ASBR1-GigabitEthernet1/0/1] mpls enable
[ASBR1-GigabitEthernet1/0/1] mpls ldp enable
[ASBR1-GigabitEthernet1/0/1] quit
# On interface GigabitEthernet 1/0/2, specify an IP address and enable MPLS.
[ASBR1] interface gigabitethernet 1/0/2
[ASBR1-GigabitEthernet1/0/2] ip address 12.1.1.1 255.0.0.0
[ASBR1-GigabitEthernet1/0/2] mpls enable
[ASBR1-GigabitEthernet1/0/2] quit
# Create interface Loopback 0, specify an IP address and run IS-IS on the interface.
[ASBR1] interface loopback 0
[ASBR1-LoopBack0] ip address 2.2.2.2 32
[ASBR1-LoopBack0] isis enable 1
[ASBR1-LoopBack0] quit
# Run BGP on ASBR 1.
[ASBR1] bgp 100
[ASBR1-bgp-default] router-id 2.2.2.2
[ASBR1-bgp-default] peer 1.1.1.1 as-number 100
[ASBR1-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[ASBR1-bgp-default] peer 12.1.1.2 as-number 200
# Configure BGP to not filter received BGP EVPN routes based on route targets.
[ASBR1-bgp-default] address-family l2vpn evpn
[ASBR1-bgp-default-evpn] undo policy vpn-target
# Configure ASBR 1 to exchange BGP EVPN routes with IBGP peer 1.1.1.1 and EBGP peer 12.1.1.2.
[ASBR1-bgp-default-evpn] peer 12.1.1.2 enable
[ASBR1-bgp-default-evpn] peer 12.1.1.2 advertise encap-type mpls
[ASBR1-bgp-default-evpn] peer 1.1.1.1 enable
[ASBR1-bgp-default-evpn] peer 1.1.1.1 next-hop-local
[ASBR1-bgp-default-evpn] peer 1.1.1.1 advertise encap-type mpls
[ASBR1-bgp-default-evpn] quit
[ASBR1-bgp-default] quit
4.     Configure ASBR 2:
# Run IPv6 IS-IS on ASBR 2.
<ASBR2> system-view
[ASBR2] isis 1
[ASBR2-isis-1] cost-style wide
[ASBR2-isis-1] network-entity 10.3333.3333.3333.00
[ASBR2-isis-1] address-family ipv6 unicast
[ASBR2-isis-1-ipv6] quit
[ASBR2-isis-1] quit
# On interface GigabitEthernet 1/0/1, specify an IPv6 address and run IPv6 IS-IS.
[ASBR2] interface gigabitethernet 1/0/1
[ASBR2-GigabitEthernet1/0/1] ipv6 address 100::2 96
[ASBR2-GigabitEthernet1/0/1] isis ipv6 enable 1
[ASBR2-GigabitEthernet1/0/1] quit
[ASBR2] interface gigabitethernet 1/0/2
[ASBR2-GigabitEthernet1/0/2] ip address 12.1.1.2 255.0.0.0
[ASBR2-GigabitEthernet1/0/2] mpls enable
[ASBR2-GigabitEthernet1/0/2] quit
# Create interface Loopback 0, specify an IPv6 address for the interface, and run IPv6 IS-IS on the interface.
[ASBR2] interface loopback 0
[ASBR2-LoopBack0] ipv6 address 2::2 128
[ASBR2-LoopBack0] isis ipv6 enable 1
[ASBR2-LoopBack0] quit
# Run BGP on ASBR 2.
[ASBR2] bgp 200
[ASBR2-bgp-default] router-id 3.3.3.3
[ASBR2-bgp-default] peer 12.1.1.1 as-number 100
[ASBR2-bgp-default] peer 1::1 as-number 200
[ASBR2-bgp-default] peer 1::1 connect-interface loopback 0
[ASBR2-bgp-default] address-family l2vpn evpn
[ASBR2-bgp-default-evpn] undo policy vpn-target
# Configure ASBR 2 to exchange BGP EVPN routes with IBGP peer 1::1 and EBGP peer 12.1.1.1.
[ASBR2-bgp-default-evpn] peer 12.1.1.1 enable
[ASBR2-bgp-default-evpn] peer 12.1.1.1 advertise encap-type mpls
[ASBR2-bgp-default-evpn] peer 1::1 enable
[ASBR2-bgp-default-evpn] peer 1::1 next-hop-local
[ASBR2-bgp-default-evpn] quit
[ASBR2-bgp-default] quit
# Configure EVPN L3VPN over SRv6 BE.
[ASBR2] segment-routing ipv6
[ASBR2-segment-routing-ipv6] encapsulation source-address 2::2
[ASBR2-segment-routing-ipv6] locator abc ipv6-prefix 43:1:: 64 static 32
[ASBR2-segment-routing-ipv6-locator-abc] quit
[ASBR2-segment-routing-ipv6] quit
[ASBR2] bgp 200
[ASBR2-bgp-default-evpn] peer 1::1 advertise encap-type srv6
[ASBR2-bgp-default-evpn] segment-routing ipv6 best-effort evpn
[ASBR2-bgp-default-evpn] segment-routing ipv6 locator abc evpn
# Enable SRv6 and MPLS interworking.
[ASBR2-bgp-default-evpn] srv6-mpls-interworking enable
# Apply a locator to IPv6 IS-IS.
[ASBR2] isis 1
[ASBR2-isis-1-ipv6] segment-routing ipv6 locator abc
[ASBR2-isis-1] quit
5.     Configure PE 2:
# Run IPv6 IS-IS on PE 2.
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] network-entity 10.4444.4444.4444.00
[PE2-isis-1] quit
# On interface GigabitEthernet 1/0/2, specify an IPv6 address and run IPv6 IS-IS.
[PE2-GigabitEthernet1/0/2] ipv6 address 100::1 96
[PE2-GigabitEthernet1/0/2] isis ipv6 enable 1
# Create interface Loopback 0, specify an IPv6 address and run IPv6 IS-IS on the interface.
[PE2-LoopBack0] ipv6 address 1::1 128
[PE2-LoopBack0] isis ipv6 enable 1
# Create a VPN instance named vpn1 and configure a RD and route target for the VPN instance.
[PE2-vpn-instance-vpn1] vpn-target 100:1
# Associate the interface connected to CE 2 with VPN instance vpn1.
[PE2-GigabitEthernet1/0/1] ip address 20.1.1.1 24
# Run BGP on PE 2.
[PE2] bgp 200
[PE2-bgp-default] router-id 4.4.4.4
# Configure PE 2 to exchange BGP EVPN routes with IBGP peer 2::2.
[PE2-bgp-default] peer 2::2 as-number 200
[PE2-bgp-default] peer 2::2 connect-interface loopback 0
[PE2-bgp-default-evpn] peer 2::2 enable
# Establish EBGP peer relationship with CE 2 and import VPN routes.
[PE2-bgp-default-vpn1] peer 20.1.1.2 as-number 201
[PE2-bgp-default-ipv4-vpn1] peer 20.1.1.2 enable
# Configure L3VPN over SRv6 BE.
[PE2-segment-routing-ipv6] encapsulation source-address 1::1
[PE2-segment-routing-ipv6] locator abc ipv6-prefix 42:1:: 64 static 32
[PE2-segment-routing-ipv6-locator-abc] quit
[PE2] bgp 200
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc evpn
[PE2-bgp-default-evpn] peer 2::2 advertise encap-type srv6
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator abc
[PE2-isis-1] quit
6.     Configure CE 2:
# Establish EBGP peer relationship with PE 2 and import VPN routes.
<CE2> system-view
[CE2] bgp 201
[CE2-bgp-default] peer 20.1.1.1 as-number 200
[CE2-bgp-default-ipv4] peer 20.1.1.1 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
# On ASBR 2, verify that the MPLS label and SRv6 SID have established mapping relationship. The LSP out label is the SRv6 SID.
[ASBR2] display mpls lsp srv6-mpls-interworking
FEC            : 3::3/43:1::1:0:2
Protocol       : BGP
In Label       : 600127
Out SRv6 SID   : 43:1::1:0:2
Path ID        : 0x16000000.1
