- 08-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-Basic BGP configuration
- 07-Advanced BGP configuration
- 08-Policy-based routing configuration
- 09-IPv6 static routing configuration
- 10-RIPng configuration
- 11-OSPFv3 configuration
- 12-IPv6 policy-based routing configuration
- 13-Routing policy configuration
- 14-RIR configuration
06-Basic BGP configuration | 2.11 MB |
Settlements for problems in large-scale BGP networks
BGP diagnostic troubleshooting
Restrictions: Licensing requirements for BGP
Basic BGP network configuration tasks at a glance (IPv4 unicast/IPv4 multicast)
Basic BGP network configuration tasks at a glance (IPv6 unicast/IPv6 multicast)
Configuring an IBGP peer group
Configuring an EBGP peer group
Specifying the source address of TCP connections
Controlling BGP route generation
Configuring BGP route summarization
Advertising a default route to a peer or peer group
Controlling BGP route advertisement
Advertising optimal routes in the IP routing table
Enabling prioritized withdrawal of the default route
Enabling prioritized withdrawal of specific routes
Configuring BGP route distribution filtering policies
Enabling first-AS-number check for EBGP routes before route advertisement
Setting the BGP route sending rate
Configuring BGP route update delay
Control the frequency of sending the same route update
Applying route update interval setting to withdrawn routes
Configuring BGP route advertisement delay
Configuring a startup policy for BGP route updates
Setting the send buffer size for BGP sessions
Configuring the BGP update message sending parameters
Setting the update interval and the maximum number of update messages that can be sent each time
Setting the update message send queue parameters
Controlling BGP route reception
Limiting routes received from a peer or peer group
Configuring BGP route reception filtering policies
Configuring the keepalive interval and hold time
Setting the session retry timer
Setting an update delay for local MPLS labels
Configuring BGP logging and notifications
Enabling logging for session state changes
Enabling logging for BGP route flapping
Configuring BGP network management
Verifying and maintaining basic BGP network configuration
Verifying BGP configuration and running status (IPv4 unicast address family)
Verifying BGP configuration and running status (IPv6 unicast address family)
Verifying BGP configuration and running status (IPv4 multicast address family)
Verifying BGP configuration and running status (IPv6 multicast address family)
Displaying and clearing BGP route flapping statistics
Basic IPv4 BGP network configuration examples
Example: Configuring basic BGP
Example: Configuring BGP and IGP route redistribution
Example: Configuring dynamic BGP peers
Example: Configuring BGP route summarization
Example: Configuring multicast BGP
Basic IPv6 BGP network configuration examples
Example: Configuring IPv6 BGP basics
Example: Configuring IPv6 multicast BGP
State of the connection to a peer cannot become established
Configuring large-scale BGP networks
Large-scale BGP network configuration tasks at a glance
Configuring BGP route dampening
Configuring BGP route reflection
Configuring a BGP route reflector
Ignoring the ORIGINATOR_ID attribute
Configuring BGP confederation settings
Configuring a BGP confederation
Configuring confederation compatibility
Verifying and maintaining large-scale BGP network configuration
Large-scale BGP network configuration examples
Example: Configuring BGP communities
Example: Configuring BGP route reflector
Example: Configuring BGP confederation
Controlling BGP path selection
BGP path selection control tasks at a glance
Configuring preferences for BGP routes
Configuring the NEXT_HOP attribute
Setting the local device IP as the next hop
Disabling nexthop changing for routes advertised to a peer or peer group
Advertising only the global unicast address in the NEXT_HOP attribute
Setting a preferred value for received routes
Configuring the default local preference
Configuring the AS_PATH attribute
Permitting local AS number to appear in routes from a peer or peer group
Ignoring the AS_PATH attribute during optimal route selection
Advertising a fake AS number to a peer or peer group
Configuring AS number substitution
Removing/replacing private AS numbers in BGP updates
Ignoring the first AS number of EBGP route updates
Setting an AS number quantity threshold
Configuring the default MED value
Enabling MED comparison for routes from different ASs
Enabling MED comparison for routes on a per-AS basis
Enabling MED comparison for routes from confederation peers
Enabling BGP to use the MED and IGP metric together for optimal route selection
Configuring the link bandwidth attribute
Minimizing the priority of BGP routes advertised to peers
Minimizing the priority of BGP routes advertised to peers with a DOWN-to-UP state change
Minimizing the priority of BGP routes advertised to peers after a device reboot
Restoring the priority of advertised BGP routes
Preferring routes learned from a peer or peer group during optimal route selection
Configuring the AIGP attribute
Ignoring IGP metrics during optimal route selection
Ignoring router IDs during optimal route selection
Configuring the next hop type selection rule for optimal route selection
About tunnel-type recursive next hops
Preferring BGP routes of a specific recursive next hop type during optimal route selection
Associating a track entry with a BGP peer or peer group
Verifying and maintaining BGP path selection control
BGP overview
Border Gateway Protocol (BGP) is an exterior gateway protocol (EGP). It is called internal BGP (IBGP) when it runs within an AS and called external BGP (EBGP) when it runs between ASs. The current version in use is BGP-4 (RFC 4271).
BGP characteristics
BGP has the following characteristics:
· Focuses on route control and selection rather than route discovery and calculation.
· Uses TCP to enhance reliability.
· Measures the distance of a route by using a list of ASs that the route must travel through to reach the destination. BGP is also called a path-vector protocol.
· Supports CIDR.
· Reduces bandwidth consumption by advertising only incremental updates. BGP is very suitable to advertise large numbers of routes on the Internet.
· Eliminates routing loops by adding AS path information to BGP route updates.
· Uses policies to implement flexible route filtering and selection.
· Has good scalability.
BGP speaker and BGP peer
A router running BGP is a BGP speaker. A BGP speaker establishes peer relationships with other BGP speakers to exchange routing information over TCP connections.
BGP peers include the following types:
· IBGP peers—Reside in the same AS as the local router.
· EBGP peers—Reside in different ASs from the local router.
Based on the IP version, a BGP peer can be either of the following types:
· IPv4 peer—Uses an IPv4 address to establish a peer relationship with the local router.
· IPv6 peer—Uses an IPv6 address to establish a peer relationship with the local router.
BGP message types
BGP uses the following message types:
· Open—After establishing a TCP connection, BGP sends an OPEN message to establish a session to the peer.
· Update—BGP sends UPDATE messages to exchange routing information between peers. Each UPDATE message can advertise a group of feasible routes with identical attributes and multiple withdrawn routes.
· Keepalive—BGP sends KEEPALIVE messages between peers to maintain connectivity.
· Route-refresh—BGP sends a ROUTE-REFRESH message to request the routing information for a specific address family from a peer.
· Notification—BGP sends a NOTIFICATION message upon detecting an error and immediately closes the connection.
BGP finite state machine
During session establishment, the devices at the two ends transition between different BGP states, as shown in Figure 1.
Figure 1 BGP finite state machine
Idle
This state is the initial BGP state. In this state, BGP rejects any connection requests. Only upon receiving a Start event, the device assigns resources to BGP, and attempts to establish a TCP connection and transition to Connect state.
BGP transitions to Idle state from the remaining states upon a TCP disconnection error, packet error, connection closed due to configuration issues, and reception of a NOTIFICATION message.
Connect
In this state, BGP starts a Connect Retry timer and waits for TCP connection establishment to be completed.
· If TCP connection establishment succeeds before the Connect Retry timer expires, BGP closes the Connect Retry timer, sends an OPEN message to the peer, and transitions to OpenSent state.
· If TCP connection establishment fails before the Connect Retry timer expires, BGP transitions to Active state.
· If the Connect Retry timer expires, and no connection response is received, BGP resets the Connect Retry timer, tries to establish a TCP connection with the peer again, and stays in Connect state.
Active
In this state, BGP continuously attempts to establish a TCP connection.
· If TCP connection establishment succeeds, BGP closes the Connect Retry timer, sends an OPEN message to the peer, and transitions to OpenSent state.
· If TCP connection establishment fails, BGP resets the Connect Retry timer and stays in Active state.
· If the Connect Retry timer expires and no connection response is received, BGP resets the Connect Retry timer and transitions to Connect state.
OpenSent
In this state, BGP waits for an OPEN message from the peer, and checks the BGP version number and AS number in the OPEN message.
· If the OPEN message is correct, BGP sends a KEEPALIVE message to the peer, and transitions to OpenConfirm state.
· If the OPEN message is incorrect, BGP sends a NOTIFICATION message to the peer, and transitions to Idle state.
If the TCP connection is disconnected in this state, BGP resets the Connect Retry timer, transitions to Active state, and tries to establish a TCP connection again.
OpenConfirm
In this state, BGP waits for a KEEPALIVE or NOTIFICATION message.
· Upon receiving a KEEPALIVE message, BGP transitions to Established state.
· Upon receiving a NOTIFICATION message, BGP transitions to Idle state.
Established
In this state, BGP can exchange UPDATE, KEEPALIVE, ROUTE-REFRESH, and NOTIFICATION messages with the peer.
· Upon receiving a correct UPDATE or KEEPALIVE message, BGP stays in Established state.
· Upon receiving an incorrect UPDATE or KEEPALIVE message, BGP sends a NOTIFICATION message to the peer and transitions to Idle state.
· Upon receiving a ROUTE-REFRESH message, BGP does not change its state.
BGP path attributes
BGP uses the following path attributes in UPDATE messages for route filtering and selection:
ORIGIN
The ORIGIN attribute specifies the origin of BGP routes. This attribute has the following types:
· IGP—Has the highest priority. Routes generated in the local AS have the IGP attribute.
· EGP—Has the second highest priority. Routes obtained through EGP have the EGP attribute.
· INCOMPLETE—Has the lowest priority. The source of routes with this attribute is unknown. Routes redistributed from other routing protocols have the INCOMPLETE attribute.
AS_PATH
The AS_PATH attribute identifies the ASs through which a route has passed. Before advertising a route to another AS, BGP adds the local AS number into the AS_PATH attribute, so the receiver can determine ASs to route the message back.
The AS_PATH attribute has the following types:
· AS_SEQUENCE—Arranges AS numbers in sequence. As shown in Figure 2, the number of the AS closest to the receiver's AS is leftmost.
· AS_SET—Arranges AS numbers randomly.
Figure 2 AS_PATH attribute
BGP uses the AS_PATH attribute to implement the following functions:
· Avoid routing loops—A BGP router does not receive routes containing the local AS number to avoid routing loops.
· Affect route selection—BGP gives priority to the route with the shortest AS_PATH length if other factors are the same. As shown in Figure 2, the BGP router in AS 50 gives priority to the route passing AS 40 for sending data to the destination 8.0.0.0. In some applications, you can apply a routing policy to control BGP route selection by modifying the AS_PATH length. For more information about routing policy, see "Configuring routing policies."
· Filter routes—By using an AS path list, you can filter routes based on AS numbers contained in the AS_PATH attribute. For more information about AS path list, see "Configuring routing policies."
NEXT_HOP
The NEXT_HOP attribute may not be the IP address of a directly connected router. Its value is determined as follows:
· When a BGP speaker advertises a self-originated route to a BGP peer, it sets the address of the sending interface as the NEXT_HOP.
· When a BGP speaker sends a received route to an EBGP peer, it sets the address of the sending interface as the NEXT_HOP.
· When a BGP speaker sends a route received from an EBGP peer to an IBGP peer, it does not modify the NEXT_HOP attribute. If load balancing is configured, BGP modifies the NEXT_HOP attribute for the equal-cost routes. For load balancing information, see "BGP load balancing."
MED (MULTI_EXIT_DISC)
BGP advertises the MED attribute between two neighboring ASs, each of which does not advertise the attribute to any other AS.
Similar to metrics used by IGPs, MED is used to determine the optimal route for traffic going into an AS. When a BGP router obtains multiple routes to the same destination but with different next hops, it selects the route with the smallest MED value as the optimal route. As shown in Figure 4, traffic from AS 10 to AS 20 travels through Router B that is selected according to MED.
Figure 4 MED attribute
Generally BGP only compares MEDs of routes received from the same AS. You can also use the compare-different-as-med command to force BGP to compare MED values of routes received from different ASs.
LOCAL_PREF
The LOCAL_PREF attribute is exchanged between IBGP peers only, and is not advertised to any other AS. It indicates the priority of a BGP router.
BGP uses LOCAL_PREF to determine the optimal route for traffic leaving the local AS. When a BGP router obtains multiple routes to the same destination but with different next hops, it selects the route with the highest LOCAL_PREF value as the optimal route. As shown in Figure 5, traffic from AS 20 to AS 10 travels through Router C that is selected according to LOCAL_PREF.
Figure 5 LOCAL_PREF attribute
COMMUNITY
The COMMUNITY attribute identifies the community of BGP routes. A BGP community is a group of routes with the same characteristics. It has no geographical boundaries. Routes of different ASs can belong to the same community.
A route can carry one or more COMMUNITY attribute values (each of which is represented by a 4-byte integer). A router uses the COMMUNITY attribute to determine whether to advertise the route and the advertising scope without using complex filters such as ACLs. This mechanism simplifies routing policy configuration, management, and maintenance.
Well-known COMMUNITY attributes involve the following:
· INTERNET—By default, all routes belong to the Internet community. Routes with this attribute can be advertised to all BGP peers.
· NO_EXPORT—Routes with this attribute cannot be advertised out of the local AS or out of the local confederation, but can be advertised to other sub-ASs in the confederation. For confederation information, see "Settlements for problems in large-scale BGP networks."
· No_ADVERTISE—Routes with this attribute cannot be advertised to other BGP peers.
· No_EXPORT_SUBCONFED—Routes with this attribute cannot be advertised out of the local AS or other sub-ASs in the local confederation.
You can configure BGP community lists to filter BGP routes based on the BGP COMMUNITY attribute.
Extended community attribute
To meet new demands, BGP defines the extended community attribute. The extended community attribute has the following advantages over the COMMUNITY attribute:
· Provides more attribute values by extending the attribute length to eight bytes.
· Allows for using different types of extended community attributes in different scenarios to enhance route filtering and control and simplify configuration and management.
The device supports the route target attribute, the Site of Origin (SoO) attribute, the link bandwidth attribute, the color attribute, and the Priority-Color attribute. For information about route target, see MPLS Configuration Guide. For information about the color attribute, see routing policy configuration in Layer 3—IP Routing Configuration Guide. For information about the Priority-Color attribute, see SDWAN configuration in SDWAN Configuration Guide.
The link bandwidth attribute is used for BGP route-based UCMP load balancing. For information about the link bandwidth attribute, see "Configuring the link bandwidth attribute."
The SoO attribute specifies the site where the route originated. It prevents advertising a route back to the originating site. If the AS-path attribute is lost, the router can use the SoO attribute to avoid routing loops.
The SoO attribute has the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 100:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
· 32-bit IP address/IPv4 address mask length:16-bit user-defined number. For example, 192.168.122.15/24:1.
· 32-bit AS number in dotted format:16-bit user-defined number. For example, 65535.65535:1.
BGP route selection
BGP discards routes with unreachable next hops and routes with next hops not recursed to IP addresses. If the bestroute nexthop-resolved tunnel command is executed, BGP does not discards routes with next hops recursed to tunnels rather than IP addresses. In this situation, BGP still discards routes with next hops recursed to neither tunnels nor IP addresses.
If multiple routes to the same destination are available, BGP selects the optimal route in the following sequence:
1. The route with the highest-priority RPKI validation result if the bestroute origin-as-validation command is executed.
If the bestroute origin-as-validation command is not executed, BGP skips this route selection rule.
2. The route with the highest Preferred_value.
3. The route of the encapsulation type specified in the bestroute encap-type preferred command.
This route selection rule does not take effect in public BGP instances.
If the bestroute encap-type preferred command is not executed, BGP skips this route selection rule.
4. The route whose recursive next hop matches the configuration of the bestroute nexthop-type preferred command.
If the bestroute nexthop-type preferred command is not executed, BGP skips this route selection rule.
5. The route with the highest LOCAL_PREF.
6. The route of the encapsulation type specified in the bestroute encap-type command.
If the bestroute encap-type command is not executed, BGP skips this route selection rule.
7. The route generated by the network command, the route redistributed by the import-route command, or the summary route in turn.
8. The route with the smallest AIGP attribute value.
9. The route with the shortest AS_PATH.
10. The IGP, EGP, or INCOMPLETE route in turn.
11. The route with the smallest MED value.
12. The route learned from EBGP, confederation EBGP, confederation IBGP, or IBGP in turn.
13. The route learned from the peer or peer group specified in the peer high-priority command.
If the peer high-priority command is not executed, BGP skips this route selection rule.
14. The route with the smallest IGP metric.
If the bestroute igp-metric-ignore command is executed, BGP skips this route selection rule.
15. The route with the smallest recursion depth.
16. The route whose recursive next hop matches the configuration of the bestroute nexthop-type command.
If the bestroute nexthop-type command is not executed, BGP skips this route selection rule.
17. If a route received from an EBGP peer is the current optimal route, BGP does not change the optimal route when it receives routes from other EBGP peers.
18. The route advertised by the router with the smallest router ID.
If one of the routes is advertised by a route reflector, BGP compares the ORIGINATOR_ID of the route with the router IDs of other routers. Then, BGP selects the route with the smallest ID as the optimal route.
If the bestroute router-id-ignore command is executed, BGP skips this route selection rule.
19. The route with the shortest CLUSTER_LIST.
20. The route with an IPv6 next hop if the bestroute ipv6-nexthop command is executed.
If the bestroute ipv6-nexthop command is not executed, BGP skips this route selection rule.
21. The route with an IPv4 next hop.
22. The route advertised by the peer with the lowest IP address.
The CLUSTER_IDs of route reflectors form a CLUSTER_LIST. If a route reflector receives a route that contains its own CLUSTER ID in the CLUSTER_LIST, the router discards the route to avoid routing loops.
If load balancing is configured, the system selects available routes to implement load balancing.
For more information about the bestroute encap-type command, see SRv6 TE policy commands in Segment Routing Command Reference.
BGP route advertisement rules
BGP follows these rules for route advertisement:
· When multiple feasible routes to a destination exist, BGP advertises only the optimal route to its peers. If the advertise-rib-active command is configured, BGP advertises the optimal route in the IP routing table. If not, BGP advertises the optimal route in the BGP routing table.
· BGP advertises only routes that it uses.
· BGP advertises routes learned from an EBGP peer to all BGP peers, including both EBGP and IBGP peers.
· BGP advertises routes learned from an IBGP peer to EBGP peers, rather than other IBGP peers.
· After establishing a session to a new BGP peer, BGP advertises all the routes matching the above rules to the peer. After that, BGP advertises only incremental updates to the peer.
BGP load balancing
BGP load balancing is applicable between EBGP peers, between IBGP peers, and between confederations.
BGP implements load balancing through route recursion and route selection.
BGP load balancing through route recursion
The next hop of a BGP route might not be directly connected. One of the reasons is that the next hop information exchanged between IBGP peers is not modified. The BGP router must find the directly connected next hop through IGP. The matching route with the direct next hop is called the recursive route. The process of finding a recursive route is route recursion.
If multiple recursive routes to the same destination are load balanced, BGP generates the same number of next hops to forward packets.
BGP load balancing based on route recursion is always enabled in the system.
BGP load balancing through route selection
IGP routing protocols, such as RIP and OSPF, can use route metrics as criteria to load balance between routes that have the same metric. BGP cannot load balance between routes by route metrics as an IGP protocol does, because BGP does not have a route computation algorithm.
BGP uses the following load balancing criteria to determine load balanced routes:
· The routes have the same ORIGIN, LOCAL_PREF, AIGP, and MED attributes.
· The routes meet the following requirements on the AS_PATH attribute:
¡ If the balance as-path-neglect command is configured, the routes can have different AS_PATH attributes.
¡ If only the balance as-path-relax command is configured, the routes can have different AS_PATH attributes, but the length of the AS_PATH attributes must be the same.
¡ If neither the balance as-path-neglect nor the balance as-path-relax command is configured, the routes must have the same AS_PATH attribute.
· The next hops of the routes meet the following requirements on IGP metrics:
¡ If neither the bestroute igp-metric-ignore command nor the balance igp-metric-ignore command is configured, the next hops of the routes must have the same IGP metric value.
¡ If either the bestroute igp-metric-ignore command or the balance igp-metric-ignore command is configured, the next hops of the routes can have different IGP metric values.
· The routes have the same MPLS label assignment status (labeled or not labeled).
BGP does not use the route selection rules described in "BGP route selection" for load balancing.
As shown in Figure 6, Router A and Router B are IBGP peers of Router C. Router C allows a maximum number of two ECMP routes for load balancing.
Router D and Router E both advertise a route 9.0.0.0 to Router C. Router C installs the two routes to its routing table for load balancing if the routes meet the BGP load balancing criteria. After that, Router C forwards to Router A and Router B a single route whose attributes are changed as follows:
· AS_PATH attribute:
¡ If the balance as-path-neglect and balance as-path-relax commands are not configured, the AS_PATH attribute does not change.
¡ If the balance as-path-neglect or balance as-path-relax command is configured, the AS_PATH attribute is changed to the attribute of the optimal route.
· The NEXT_HOP attribute is changed to the IP address of Router C.
· Other attributes are changed to be the same as the optimal route.
You can use the following methods to facilitate management and improve route distribution efficiency on a large-scale BGP network.
Route summarization
Route summarization can reduce the BGP routing table size by advertising summary routes rather than more specific routes.
The system supports both manual and automatic route summarization. Manual route summarization allows you to determine the attribute of a summary route and whether to advertise more specific routes.
Route dampening
Route flapping (a route comes up and disappears in the routing table frequently) causes BGP to send many routing updates. It can consume too many resources and affect other operations.
In most cases, BGP runs in complex networks where route changes are more frequent. To solve the issue caused by route flapping, you can use BGP route dampening to suppress unstable routes.
BGP route dampening uses a penalty value to judge the stability of a route. The bigger the value, the less stable the route. Each time a route state changes from reachable to unreachable, or a reachable route's attribute changes, BGP adds a penalty value of 1000 to the route. When the penalty value of the route exceeds the suppress value, the route is suppressed and cannot become the optimal route. When the penalty value reaches the upper limit, no penalty value is added.
If the suppressed route does not flap, its penalty value gradually decreases to half of the suppress value after a period of time. This period is called "Half-life." When the value decreases to the reusable threshold value, the route is usable again.
Figure 7 BGP route dampening
Peer group
You can organize BGP peers with the same attributes into a group to simplify their configurations.
When a peer joins the peer group, the peer obtains the same configuration as the peer group. If the configuration of the peer group is changed, the configuration of group members is changed.
Community
You can apply a community list or an extended community list to a routing policy for route control. For more information, see "BGP path attributes."
Route reflector
IBGP peers must be fully meshed to maintain connectivity. If n routers exist in an AS, the number of IBGP connections is n(n-1)/2. If a large number of IBGP peers exist, large amounts of network and CPU resources are consumed to maintain sessions.
Using route reflectors can solve this issue. In an AS, a router acts as a route reflector, and other routers act as clients connecting to the route reflector. The route reflector forwards routing information received from a client to other clients. In this way, all clients can receive routing information from one another without establishing BGP sessions.
A router that is neither a route reflector nor a client is a non-client, which, as shown in Figure 8, must establish BGP sessions to the route reflector and other non-clients.
Figure 8 Network diagram for a route reflector
The route reflector and clients form a cluster. Typically a cluster has one route reflector. The ID of the route reflector is the Cluster_ID. You can configure more than one route reflector in a cluster to improve availability, as shown in Figure 9. The configured route reflectors must have the same Cluster_ID to avoid routing loops.
Figure 9 Network diagram for route reflectors
When the BGP routers in an AS are fully meshed, route reflection is unnecessary because it consumes more bandwidth resources. You can use commands to disable route reflection instead of modifying network configuration or changing network topology.
After route reflection is disabled between clients, routes can still be reflected between a client and a non-client.
Confederation
Confederation is another method to manage growing IBGP connections in an AS. It splits an AS into multiple sub-ASs. In each sub-AS, IBGP peers are fully meshed. As shown in Figure 10, intra-confederation EBGP connections are established between sub-ASs in AS 200.
Figure 10 Confederation network diagram
A non-confederation BGP speaker does not need to know sub-ASs in the confederation. To the BGP speaker, the confederation is one AS and the confederation ID is the AS number. In the above figure, AS 200 is the confederation ID.
Confederation has a deficiency. When you change an AS into a confederation, you must reconfigure the routers, and the topology will be changed.
In large-scale BGP networks, you can use both route reflector and confederation.
MP-BGP
Supported address families
BGP-4 can only advertise IPv4 unicast routing information. Multiprotocol Extensions for BGP-4 (MP-BGP) can advertise routing information for the following address families:
· IPv6 unicast address family.
· IPv4 multicast address family and IPv6 multicast address family.
PIM uses static and dynamic unicast routes to perform RPF check before creating multicast routing entries. When the multicast and unicast topologies are different, you can use MP-BGP to advertise the routes for RPF check. MP-BGP stores the routes in the BGP multicast routing table. For more information about PIM and RPF check, see IP Multicast Configuration Guide.
· VPNv4 address family and VPNv6 address family.
For more information, see MPLS Configuration Guide.
· Labeled IPv4 unicast address family and IPv6 unicast address family.
MP-BGP advertises IPv4 unicast/IPv6 unicast routes and MPLS labels assigned for the routes. Labeled IPv4 unicast routes apply to inter-AS Option C for MPLS L3VPN. Labeled IPv6 unicast routes apply to 6PE and inter-AS Option C for MPLS L3VPN. For more information about inter-AS Option C, see MPLS Configuration Guide.
· L2VPN address family.
L2VPN information includes label block information and remote peer information. For more information about L2VPN and VPLS, see MPLS Configuration Guide.
· EVPN address family.
MP-BGP advertises EVPN routes to implement automatic VTEP discovery, VXLAN tunnel establishment and assignment, and MAC and ARP information advertisement. For more information about EVPN, see EVPN Configuration Guide.
· IPv4 MDT address family.
MP-BGP advertises MDT information including the PE address and default group so that multicast VPN can create a default MDT that uses the PE as the root on the public network. For more information about multicast VPN, see IP Multicast Configuration Guide.
· MVPN
MP-BGP advertises MVPN routing information so that RSVP-TE can establish inclusive tunnels and selective tunnels. For more information about MVPN RSVP-TE, see multicast VPN configuration in IP Multicast Configuration Guide.
· IPv4 tunnel-encap-ext address family.
MP-BGP advertises IPv4 tunnel-encap-ext routes to implement intelligent path selection on a SDWAN network. An IPv4 tunnel-encap-ext route carries the following information:
¡ TTE information that can be used to establish an SDWAN tunnel between two customer provided edge devices (CPE).
¡ SaaS path quality information that can be used to implement resilient intelligent routing (RIR) for different applications.
For more information, see SDWAN Configuration Guide.
MP-BGP extended attributes
Prefixes and next hops are key routing information. BGP-4 uses UPDATE messages to carry the following information:
· Feasible route prefixes in the Network Layer Reachability Information (NLRI) field.
· Unfeasible route prefixes in the withdrawn routes field.
· Next hops in the NEXT_HOP attribute.
BGP-4 cannot carry routing information for multiple network layer protocols.
To support multiple network layer protocols, MP-BGP defines the following path attributes:
· MP_REACH_NLRI—Carries feasible route prefixes and next hops for multiple network layer protocols.
· MP_UNREACH_NLRI—Carries unfeasible route prefixes for multiple network layer protocols.
MP-BGP uses these two attributes to advertise feasible and unfeasible routes for different network layer protocols. BGP speakers not supporting MP-BGP ignore updates containing these attributes and do not forward them to its peers.
Address family
MP-BGP uses address families and subsequent address families to identify different network layer protocols for routes contained in the MP_REACH_NLRI and MP_UNREACH_NLRI attributes. For example, an Address Family Identifier (AFI) of 2 and a Subsequent Address Family Identifier (SAFI) of 1 identify IPv6 unicast routing information carried in the MP_REACH_NLRI attribute. For address family values, see RFC 1700.
Exchanging IPv4 and IPv6 routes in both IPv4 and IPv6 address families
MP-BGP supports IPv4 route exchange between IPv6 peers and IPv6 route exchange between IPv4 peers as follows:
· When the next hop of an IPv6 route is an IPv4 address, MP-BGP maps the IPv4 address to an IPv6 address encapsulated in the NEXT_HOP attribute of update messages. In this scenario, you must specify a routing policy to change the next hop of the IPv6 route to the IPv6 address of the peer.
· When the next hop of an IPv4 route is an IPv6 address, BGP negotiates the extended next hop encoding capability with its peer. Then, BGP encapsulates the IPv4 NLRI in the MP_REACH_NLRI attribute of update messages. In this scenario, you must specify a routing policy to change the next hop of the IPv4 route to the IPv4 address of the peer.
Figure 11 Exchanging IPv4 and IPv6 routes in both IPv4 and IPv6 address families
As shown in Figure 11, an IPv6 BGP peer relationship is established between Device A and Device B, between Device B and Device C, and between Device C and Device D. An IPv4 BGP peer relationship is established between Device A and Device B and between Device C and Device D. Device A and Device D can learn both IPv4 and IPv6 routes from each other and traffic is forwarded correctly in both IPv4 and IPv6 address families. For Device C to correctly receive IPv4 routes using the IPv6 address of Device B as the next hop, configure a routing policy on Device C. Use the routing policy to change the next hop of these routes to the IPv4 address of Device B.
BGP multi-instance
A BGP router can run multiple BGP processes. Each BGP process corresponds to a BGP instance. BGP maintains an independent routing table for each BGP instance.
When you create multiple BGP instances, follow these guidelines:
· You can create multiple public address families for a BGP instance. However, each public address family (except for IPv4 unicast address family, IPv6 unicast address family, VPNv4 address family, VPNv6 address family, VPNv4 flowspec address family, VPNv6 flowspec address family, IPv4 RT-filter address family, and IPv6 SR policy address family) can belong to only one BGP instance.
· You can create multiple VPN instances for a BGP instance, and each VPN instance can have multiple address families. A VPN instance can belong to only one BGP instance.
· On the public network, a peer address can establish a session to only one BGP instance. Multiple BGP instances cannot synchronously establish sessions to the same peer address.
· The IPv4 and IPv6 multicast address families must belong to the same BGP instance.
· Different BGP instances can have the same AS number but cannot have the same name.
BGP configuration views
BGP uses different views to manage routing information for different BGP instances, VPN instances, and address families. Most BGP commands are available in all BGP views. BGP supports multiple VPN instances by establishing a separate routing table for each VPN instance.
Table 1 describes different BGP configuration views.
Table 1 BGP configuration views
View names |
Ways to enter the views |
Remarks |
BGP instance view |
You can create a BGP instance and enter its view by specifying the instance keyword in the bgp command. Configurations in this view apply to all public address families for the specified BGP instance. Some configurations (such as confederation, GR, and logging configurations) also apply to the address families of VPN instances. |
BGP IPv4 unicast address family view |
Configurations in this view apply to public IPv4 unicast routes and peers of the specified BGP instance. |
BGP IPv6 unicast address family view |
Configurations in this view apply to public IPv6 unicast routes and peers of the specified BGP instance. |
BGP IPv4 multicast address family view |
Configurations in this view apply to IPv4 multicast routes and peers of the specified BGP instance. |
BGP IPv6 multicast address family view |
Configurations in this view apply to IPv6 multicast routes and peers of the specified BGP instance. |
BGP VPNv4 address family view |
Configurations in this view apply to VPNv4 routes and peers of the specified BGP instance. For more information about BGP VPNv4 address family view, see MPLS Configuration Guide. |
BGP VPNv6 address family view |
Configurations in this view apply to VPNv6 routes and peers of the specified BGP instance. For more information about BGP VPNv6 address family view, see MPLS Configuration Guide. |
BGP L2VPN address family view |
Configurations in this view apply to L2VPN information and L2VPN peers of the specified BGP instance. For more information about BGP L2VPN address family view, see MPLS Configuration Guide. |
BGP EVPN address family view |
Configurations in this view apply to EVPN routes and peers of the specified BGP instance. For more information about BGP EVPN address family view, see EVPN Configuration Guide. |
BGP-VPN instance view |
Configurations in this view apply to all address families in the specified VPN instance of the specified BGP instance. For more information about VPN instances, see MPLS L3VPN configuration in MPLS Configuration Guide. |
BGP-VPN IPv4 unicast address family view |
Configurations in this view apply to IPv4 unicast routes and peers in the specified VPN instance of the specified BGP instance. For more information about VPN instances, see MPLS L3VPN configuration in MPLS Configuration Guide. |
BGP-VPN IPv6 unicast address family view |
Configurations in this view apply to IPv6 unicast routes and peers in the specified VPN instance of the specified BGP instance. For more information about VPN instances, see MPLS L3VPN configuration in MPLS Configuration Guide. |
BGP-VPN VPNv4 address family view |
Configurations in this view apply to VPNv4 routes and peers in the specified VPN instance of the specified BGP instance. For more information about BGP-VPN VPNv4 address family view, see MPLS Configuration Guide. |
BGP MDT address family view |
Configurations in this view apply to MDT routes and peers of the specified BGP instance. For more information about BGP MDT address family view, see IP Multicast Configuration Guide. |
BGP IPv4 MVPN address family view |
Configurations in this view apply to MVPN routes and peers of the specified BGP instance. For more information about BGP IPv4 MVPN address family view, see multicast VPN configuration in IP Multicast Configuration Guide. |
BGP LS address family view |
Configurations in this view apply to LS messages and peers of the specified BGP instance. |
BGP IPv4 RT filter address family view |
Configurations in this view apply to IPv4 RT filter routes and peers of the specified BGP instance. For more information about BGP IPv4 RT filter address family view, see MPLS L3VPN Configuration Guide. |
BGP IPv6 SR policy address family view |
Configurations in this view apply to IPv6 SR policy routes and peers of the specified BGP instance. For more information about BGP IPv6 SR policy address family view, see Segment Routing Configuration Guide. |
BGP IPv4 tunnel-encap-ext address family view |
Configurations in this view apply to IPv4 tunnel-encap-ext routes and peers of the specified BGP instance. For more information about BGP IPv4 tunnel-encap-ext address family view, see SDWAN Configuration Guide. |
Use this feature to verify whether BGP is functioning correctly and help users find the causes of BGP issues, such as BGP session establishment failure and peer disconnection. For more information about BGP diagnostic troubleshooting, see diagnostic troubleshooting configuration in Intelligent Operations Configuration Guide.
Protocols and standards
· RFC 1700, ASSIGNED NUMBERS
· RFC 1997, BGP Communities Attribute
· RFC 2439, BGP Route Flap Damping
· RFC 2545, Use of BGP-4 Multiprotocol Extensions for IPv6 Inter-Domain Routing
· RFC 2918, Route Refresh Capability for BGP-4
· RFC 3107, Carrying Label Information in BGP-4
· RFC 4271, A Border Gateway Protocol 4 (BGP-4)
· RFC 4275, BGP-4 MIB Implementation Survey
· RFC 4277, Experience with the BGP-4 Protocol
· RFC 4360, BGP Extended Communities Attribute
· RFC 4364, BGP/MPLS IP Virtual Private Networks (VPNs)
· RFC 4382, MPLS/BGP Layer 3 Virtual Private Network (VPN) Management
· RFC 4451, BGP MULTI_EXIT_DISC (MED) Consideration
· RFC 4456, BGP Route Reflection: An Alternative to Full Mesh Internal BGP
· RFC 4486, Subcodes for BGP Cease Notification Message
· RFC 4659, BGP-MPLS IP Virtual Private Network (VPN) Extension for IPv6 VPN
· RFC 4684, Constrained Route Distribution for Border Gateway Protocol/MultiProtocol Label Switching (BGP/MPLS) Internet Protocol (IP) Virtual Private Networks (VPNs)
· RFC 4724, Graceful Restart Mechanism for BGP
· RFC 4760, Multiprotocol Extensions for BGP-4
· RFC 4781, Graceful Restart Mechanism for BGP with MPLS
· RFC 5004, Avoid BGP Best Path Transitions from One External to Another
· RFC 5065, Autonomous System Confederations for BGP
· RFC 5082, The Generalized TTL Security Mechanism (GTSM)
· RFC 5291, Outbound Route Filtering Capability for BGP-4
· RFC 5292, Address-Prefix-Based Outbound Route Filter for BGP-4
· RFC 5492, Capabilities Advertisement with BGP-4
· RFC 5549, Advertising IPv4 Network Layer Reachability Information with an IPv6 Next Hop
· RFC 5668, 4-Octet AS Specific BGP Extended Community
· RFC 6037, Cisco Systems' Solution for Multicast in BGP MPLS IP VPNs
· RFC 6198, Requirements for the Graceful Shutdown of BGP Sessions
· RFC 6368, Internal BGP as the Provider/Customer Edge Protocol for BGP/MPLS IP
· RFC 6513, Multicast in MPLS/BGP IP VPNs
· RFC 6514, BGP Encodings and Procedures for Multicast in MPLS/BGP IP VPNs
· RFC 6515, IPv4 and IPv6 Infrastructure Addresses in BGP Updates for Multicast VPN
· RFC 6624, Layer 2 Virtual Private Networks Using BGP for Auto-Discovery and Signaling
· RFC 6793, BGP Support for Four-Octet Autonomous System (AS) Number Space
· RFC 7432, BGP MPLS-Based Ethernet VPN
· RFC 7752, North-Bound Distribution of Link-State and Traffic Engineering (TE) Information Using BGP
· RFC 7854, BGP Monitoring Protocol (BMP)
· RFC 7911, Advertisement of Multiple Paths in BGP
Building basic BGP networks
You can install a license to increase the maximum number of BGP routes supported by the device, if the default settings are not sufficient. For more information about licensing, see Fundamentals Configuration Guide.
To build basic BGP networks for the IPv4 unicast or IPv4 multicast address family, perform the following tasks:
a. Enabling BGP
c. Configuring dynamic BGP peers
d. Configuring an IBGP peer group
Configure BGP peer groups on large-scale BGP networks for easy configuration and maintenance.
e. Configuring an EBGP peer group
f. (Optional.) Specifying the source address of TCP connections
2. Controlling BGP route generation
¡ (Optional.) Configuring BGP route summarization
¡ (Optional.) Advertising a default route to a peer or peer group
3. (Optional.) Controlling BGP route advertisement
¡ Advertising optimal routes in the IP routing table
BGP cannot advertise optimal routes in the IP routing table for IPv4 multicast address family.
¡ Enabling prioritized withdrawal of the default route
¡ Enabling prioritized withdrawal of specific routes
¡ Configuring BGP route distribution filtering policies
¡ Enabling first-AS-number check for EBGP routes before route advertisement
¡ Setting the BGP route sending rate
¡ Configuring BGP route update delay
¡ Control the frequency of sending the same route update
¡ Applying route update interval setting to withdrawn routes
¡ Configuring BGP route advertisement delay
¡ Configuring a startup policy for BGP route updates
¡ Setting the send buffer size for BGP sessions
4. (Optional.) Configuring the BGP update message sending parameters
5. (Optional.) Controlling BGP route reception
¡ Limiting routes received from a peer or peer group
¡ Configuring BGP route reception filtering policies
¡ Configuring the SoO attribute
6. (Optional.) Configuring BGP timers
¡ Configuring the keepalive interval and hold time
¡ Setting the session retry timer
¡ Setting an update delay for local MPLS labels
7. (Optional.) Configuring BGP logging and notifications
¡ Enabling logging for session state changes
¡ Enabling logging for BGP route flapping
¡ Configuring BGP network management
To build basic BGP networks for the IPv6 unicast or IPv6 multicast address family, perform the following tasks:
a. Enabling BGP
BGP cannot advertise optimal routes in the IP routing table for IPv6 multicast address family.
Enabling BGP
A router ID is the unique identifier of a BGP router in an AS.
· To ensure the uniqueness of a router ID and enhance availability, specify in BGP instance view the IP address of a local loopback interface as the router ID. Different BGP instances can have the same router ID.
· If no router ID is specified in BGP instance view, the global router ID is used.
· To modify a non-zero router ID of a BGP instance , use the router-id command in BGP instance view, rather than the router id command in system view.
· If you specify a router ID in BGP instance view and then remove the interface that owns the router ID, the router does not select a new router ID. To select a new router ID, use the undo router-id command in BGP instance view.
1. Enter system view.
2. Configure a global router ID.
router id router-id
By default, no global router ID is configured.
If no global router ID is configured, the following rules apply:
¡ If loopback interfaces configured with an IP address exist, BGP uses the highest loopback interface IP address as the router ID.
¡ If no loopback interface IP address is available, BGP uses the highest physical interface IP address as the route ID regardless of the interface status.
3. Enable BGP and enter BGP instance view.
By default, BGP is disabled and no BGP instances exist.
4. (Optional.) Configure a router ID for the BGP instance.
router-id router-id
By default, no router ID is configured for a BGP instance, and the BGP instance uses the global router ID configured by the router-id command in system view.
5. (Optional.) Enter BGP-VPN instance view.
The specified VPN instance must have been created and have an RD.
6. (Optional.) Configure a router ID for the BGP VPN instance.
By default, no router ID is configured for a BGP VPN instance.
The BGP VPN instance uses the router ID configured in BGP instance view. If no router ID is configured in BGP instance view, the BGP VPN instance uses the global router ID configured in system view.
Configuring a BGP peer
A BGP peer at an IPv6 link-local address must be directly connected to the local router. On the local router, you must use the peer connect-interface command to specify the interface directly connected to the BGP peer as the source interface of TCP connections.
Procedure (Exchanging IPv4 unicast routes with IPv4 peers)
2. Enter BGP instance view or BGP-VPN instance view.
¡ Enter BGP instance view.
¡ Execute the following commands in sequence to enter BGP-VPN instance view.
3. Create an IPv4 BGP peer and specify its AS number.
4. (Optional.) Configure a description for a peer.
By default, no description is configured for a peer.
5. Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
6. Enable the router to exchange IPv4 unicast routing information with the specified peer.
peer ipv4-address enable
By default, the router cannot exchange IPv4 unicast routing information with the peer.
Procedure (Exchanging IPv6 unicast routes with IPv4 peers)
¡ Execute the following commands in sequence to enter BGP-VPN instance view:
4. (Optional.) Configure a description for the peer.
5. Create the BGP IPv6 unicast address family and enter its view.
6. Enable BGP to exchange IPv6 unicast routing information with the IPv4 peer.
By default, BGP cannot exchange IPv6 unicast routing information with an IPv4 peer.
7. Use a routing policy to modify the next hop of routes received from the IPv4 peer.
peer ipv4-address route-policy route-policy-name import
Procedure (Exchanging IPv6 unicast routes with IPv6 peers)
3. Create an IPv6 BGP peer and specify its AS number.
5. Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
6. Enable the router to exchange IPv6 unicast routing information with the specified peer.
peer ipv6-address enable
By default, the router cannot exchange IPv6 unicast routing information with the peer.
Procedure (Exchanging IPv4 unicast routes with IPv6 peers)
5. Create the BGP IPv4 unicast address family and enter its view.
6. Enable BGP to exchange IPv4 unicast routing information with the IPv6 peer.
By default, BGP cannot exchange IPv4 unicast routing information with an IPv6 peer.
7. Use a routing policy to modify the next hop of routes received from the IPv6 peer.
peer ipv6-address route-policy route-policy-name import
Procedure (Exchanging IPv4 multicast routes with IPv4 peers)
2. Enter BGP instance view.
5. Create the BGP IPv4 multicast address family and enter its view.
address-family ipv4 multicast
6. Enable the router to exchange IPv4 unicast routing information used for RPF check with the specified peer.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peer.
Procedure (Exchanging IPv6 multicast routes with IPv6 peers)
5. Create the BGP IPv6 multicast address family and enter its view.
address-family ipv6 multicast
6. Enable the router to exchange IPv6 unicast routing information used for RPF check with the specified peer.
By default, the router cannot exchange IPv6 unicast routing information used for RPF check with the peer.
This feature enables BGP to establish dynamic BGP peer relationships with devices in a network. BGP accepts connection requests from the network but it does not initiate connection requests to the network.
After a device in the network initiates a connection request, BGP establishes a dynamic peer relationship with the device.
If multiple BGP peers reside in the same network, you can use this feature to simplify BGP peer configuration.
For a remote device to establish a peer relationship with the local device, you must specify the IP address of the local device on the remote device.
If the local device has established a dynamic peer relationship with an IP address through network segment matching, you cannot configure that IP address as a static peer. Before you configure an IP address as a static peer, make sure that IP address is not in the network segment to which any existing dynamic peer belongs. If the IP address belongs to a predefined dynamic-peer network segment, create that network segment as a dynamic peer only after you finish configuring the IP address as a static peer. For example, if you configure network segment 10.1.1.0/24 as a dynamic peer and the local device establishes a BGP connection with 10.1.1.1, you cannot configure 10.1.1.1 as a static peer. In contrast, if you first configure 10.1.1.1 as a static peer, you can continue to configure network segment 10.1.1.0/24 as a dynamic peer.
Procedure (Exchanging IPv4 unicast routes with dynamic IPv4 peers)
3. Specify devices in a network as dynamic BGP peers and specify an AS number for the peers.
4. (Optional.) Configure a description for dynamic BGP peers.
By default, no description is configured for dynamic BGP peers.
6. Enable BGP to exchange IPv4 unicast routing information with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv4 unicast routing information with dynamic BGP peers.
Procedure (Exchanging IPv6 unicast routes with dynamic IPv4 peers)
3. Specify devices in an IPv4 network as dynamic IPv4 BGP peers and specify an AS number for the peers.
By default, no description is configured for dynamic peers.
6. Enable BGP to exchange IPv6 unicast routing information with the dynamic IPv4 peers.
By default, BGP cannot exchange IPv6 unicast routing information with dynamic IPv4 peers.
7. Use a routing policy to modify the next hop of routes received from the dynamic IPv4 peers.
peer ipv4-address mask-length route-policy route-policy-name import
Procedure (Exchanging IPv6 unicast routes with dynamic IPv6 peers)
6. Enable BGP to exchange IPv6 unicast routing information with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv6 unicast routing information with dynamic BGP peers.
Procedure (Exchanging IPv4 unicast routes with dynamic IPv6 peers)
3. Specify devices in an IPv6 network as dynamic IPv6 BGP peers and specify an AS number for the peers.
4. (Optional.) Configure a description for the dynamic IPv6 peers.
6. Enable BGP to exchange IPv4 unicast routing information with dynamic IPv6 peers.
By default, BGP cannot exchange IPv4 unicast routing information with dynamic IPv6 peers.
7. Use a routing policy to modify the next hop of routes received from the dynamic IPv6 peers.
peer ipv6-address mask-length route-policy route-policy-name import
Procedure (Exchanging IPv4 multicast routes with dynamic IPv4 peers)
6. Enable BGP to exchange IPv4 unicast routing information used for RPF check with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv4 unicast routing information used for RPF check with dynamic BGP peers.
Procedure (Exchanging IPv6 multicast routes with dynamic IPv6 peers)
6. Enable BGP to exchange IPv6 unicast routing information used for RPF check with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv6 unicast routing information used for RPF check with dynamic BGP peers.
A peer group is an IBGP peer group if peers in it belong to the same AS as the local router.
After you create an IBGP peer group and then add a peer into it, the system creates the peer in BGP instance view and specifies the local AS number for the peer.
To exchange IPv4 routes with an IPv6 peer or exchange IPv6 routes with an IPv4 peer, you must configure a routing policy to perform the following tasks:
· Change the next hop of IPv4 routes received from the IPv6 peer to the IPv4 address of the interface that the peer uses to connect to the local router.
· Change the next hop of IPv6 routes received from the IPv4 peer to the IPv6 address of the interface that the peer uses to connect to the local router.
If you configure a BGP setting at both the peer group and the peer level, the most recent configuration takes effect on the peer.
3. Create an IBGP peer group.
group group-name [ internal ]
4. Add a peer into the IBGP peer group.
The as-number as-number option must specify the local AS number.
5. (Optional.) Configure a description for the peer group.
By default, no description is configured for the peer group.
6. Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
7. Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
peer group-name enable
By default, the router cannot exchange IPv4 unicast routing information with the peers.
4. Add an IPv4 peer into the IBGP peer group.
By default, no description is configured for a peer group.
6. Create the BGP IPv6 unicast address family and enter its view.
7. Enable BGP to exchange IPv6 unicast routing information with peers in the peer group.
By default, BGP cannot exchange IPv6 unicast routing information with peers in a peer group.
8. Use a routing policy to modify the next hop of routes received from peers in the peer group.
peer group-name route-policy route-policy-name import
6. Create the BGP IPv4 multicast address family and enter its view.
7. Enable the router to exchange IPv4 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peers in the peer group.
6. Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
7. Enable the router to exchange IPv6 unicast routing information with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information with the peers.
4. Add an IPv6 peer into the IBGP peer group.
6. Create the BGP IPv4 unicast address family and enter its view.
7. Enable BGP to exchange IPv4 unicast routing information with peers in the peer group.
By default, BGP cannot exchange IPv4 unicast routing information with peers in a peer group.
6. Create the BGP IPv6 multicast address family and enter its view.
7. Enable the router to exchange IPv6 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information used for RPF check with the peers in the peer group.
A peer group is an EBGP peer group if peers in it belong to different ASs.
If peers in an EBGP group belong to the same external AS, the EBGP peer group is a pure EBGP peer group. If not, it is a mixed EBGP peer group.
Use one of the following methods to configure an EBGP peer group:
· Method 1—Create an EBGP peer group, specify its AS number, and add peers into it. All the added peers have the same AS number. All peers in the peer group have the same AS number as the peer group. You can specify an AS number for a peer before adding it into the peer group. The AS number must be the same as that of the peer group.
· Method 2—Create an EBGP peer group, specify an AS number for a peer, and add the peer into the peer group. Peers added in the group can have different AS numbers.
· Method 3—Create an EBGP peer group and add a peer with an AS number into it. Peers added in the group can have different AS numbers.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv4 unicast routes with IPv4 peers)
3. Create an EBGP peer group.
group group-name external
4. Specify the AS number of the group.
By default, no AS number is specified.
If a peer group contains peers, you cannot remove or change its AS number.
5. Add a peer into the EBGP peer group.
The as-number as-number option must specify the same AS number as the peer group-name as-number as-number command.
6. (Optional.) Configure a description for the peer group.
7. Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
8. Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv4 unicast routes with IPv4 peers)
4. Create an IPv4 BGP peer and specify its AS number.
5. Add the peer into the EBGP peer group.
The as-number as-number option must specify the same AS number as the peer ipv4-address [ mask-length ] as-number as-number command.
Configuring an EBGP peer group by using Method 3 (Exchanging IPv4 unicast routes with IPv4 peers)
4. Add a peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv6 unicast routes with IPv4 peers)
4. Specify an AS number for the peer group.
By default, no AS number is specified for a peer group.
5. Add an IPv4 peer into the EBGP peer group.
7. Create the BGP IPv6 unicast address family and enter its view.
8. Enable BGP to exchange IPv6 unicast routing information with peers in the peer group.
9. Use a routing policy to modify the next hop of routes received from peers in the peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv6 unicast routes with IPv4 peers)
5. Add the IPv4 peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 3 (Exchanging IPv6 unicast routes with IPv4 peers)
4. Add an IPv4 peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv4 multicast routes with IPv4 peers)
5. Add an IPv4 BGP peer into the EBGP peer group.
7. Create the BGP IPv4 multicast address family and enter its view.
8. Enable the router to exchange IPv4 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peers in the group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv4 multicast routes with IPv4 peers)
Configuring an EBGP peer group by using Method 3 (Exchanging IPv4 multicast routes with IPv4 peers)
4. Add an IPv4 BGP peer into the EBGP peer group.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peers.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv6 unicast routes with IPv6 peers)
7. Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
8. Enable the router to exchange IPv6 unicast routing information with peers in the specified peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv6 unicast routes with IPv6 peers)
4. Create an IPv6 BGP peer and specify its AS number.
peer ipv6-address [ prefix-length ] as-number as-number
The as-number as-number option must specify the same AS number as the peer ipv6-address [ prefix-length ] as-number as-number command.
Configuring an EBGP peer group by using Method 3 (Exchanging IPv6 unicast routes with IPv6 peers)
Configuring an EBGP peer group by using Method 1 (Exchanging IPv4 unicast routes with IPv6 peers)
5. Add an IPv6 peer into the EBGP peer group.
7. Create the BGP IPv4 unicast address family and enter its view.
8. Enable BGP to exchange IPv4 unicast routing information with peers in the peer group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv4 unicast routes with IPv6 peers)
5. Add the IPv6 peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 3 (Exchanging IPv4 unicast routes with IPv6 peers)
4. Add an IPv6 peer into the EBGP peer group.
Configuring an EBGP peer group by using Method 1 (Exchanging IPv6 multicast routes with IPv6 peers)
5. Add an IPv6 BGP peer into the EBGP peer group.
7. Create the BGP IPv6 multicast address family and enter its view.
8. Enable the router to exchange IPv6 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information used for RPF check with the peers in the group.
Configuring an EBGP peer group by using Method 2 (Exchanging IPv6 multicast routes with IPv6 peers)
Configuring an EBGP peer group by using Method 3 (Exchanging IPv6 multicast routes with IPv6 peers)
4. Add an IPv6 BGP peer into the EBGP peer group.
BGP uses TCP as the transport layer protocol. Perform this task in the following scenarios to specify the source address or source interface of TCP connections to a peer or peer group:
· The peer's IPv4/IPv6 address does not belong to the interface directly connected to the local router. To ensure successful TCP connection establishment, use one of the following methods:
¡ Specify the interface to which the IPv4/IPv6 address belongs as the source interface on the peer.
¡ Specify the IPv4/IPv6 address of the interface directly connected to the local router as the source address on the peer.
· A BGP peer at an IPv6 link-local address must be directly connected to the local router. On the local router, you must use the peer connect-interface command to specify the interface directly connected to the BGP peer as the source interface of TCP connections.
· On a BGP router that has multiple links to a peer, the source interface for TCP connection changes because the primary source interface fails. To avoid this issue, specify a loopback interface as the source interface or specify the IP address of a loopback interface as the source address.
· You want to establish multiple BGP sessions to a router. In this case, BGP might fail to determine the source address for each TCP connection based on the optimal route to the peer. To prevent this issue, use one of the following methods:
¡ If the BGP sessions use IP addresses of different interfaces, specify a source interface or source address for each session.
¡ If the BGP sessions use different IP addresses of the same interface, specify a source address for each session.
BGP immediately tears down the session to an IBGP peer or peer group when the following conditions exist:
· The source interface of TCP connections to the IBGP peer or peer group is a physical interface.
· The source interface fails and the link to the IBGP peer or peer group goes down.
Procedure (IPv4 peers)
3. Specify the source address or source interface of TCP connections to a peer or peer group.
¡ Specify the source address of TCP connections to a peer or peer group.
¡ Specify the source interface of TCP connections to a peer or peer group.
By default, BGP uses the primary IPv4 address of the output interface in the optimal route to a peer or peer group as the source address of TCP connections to the peer or peer group.
Procedure (IPv6 peers)
3. Specify the source IPv6 address or source interface of TCP connections to a peer or peer group.
¡ Specify the source IPv6 address of TCP connections to a peer or peer group.
By default, BGP uses the IPv6 address of the output interface in the optimal route to the BGP peer or peer group as the source address of TCP connections to the peer or peer group.
Injecting a local network
Perform this task to inject a network in the local routing table to the BGP routing table, so BGP can advertise the network to BGP peers. The ORIGIN attribute of BGP routes advertised in this way is IGP. You can also use a routing policy to control route advertisement.
The specified network must be available and active in the local IP routing table.
Procedure (IPv4 unicast/multicast address family)
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv4 multicast address family view:
3. Configure BGP to advertise a local network.
By default, BGP does not advertise local networks.
Procedure (IPv6 unicast/multicast address family)
2. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv6 multicast address family view:
Redistributing IGP routes
Perform this task to configure route redistribution from an IGP to BGP.
By default, BGP does not redistribute default IGP routes. You can use the default-route imported command to redistribute default IGP routes into the BGP routing table.
The ORIGIN attribute of BGP routes redistributed from IGPs is INCOMPLETE.
Only active routes can be redistributed. To view route state information, use the display ip routing-table protocol or display ipv6 routing-table protocol command. For more information about the commands, see Layer 3—IP Routing Command Reference.
If you execute the import-route command multiple times for an IGP process, the most recent configuration takes effect. To redistribute more routes from an IGP process without overwriting the routes redistributed before, use the import-route-append command.
When you execute both the import-route and import-route-append commands for an IGP process, the commands take effect as follows:
· A route is redistributed as long as it matches the criteria of either command.
· If a route matches the criteria of both commands, the route is redistributed, and the apply clauses in the routing policies specified in the two commands take effect as follows:
¡ If the apply clauses do not conflict, all apply clauses take effect.
¡ If conflicts occur between the apply clauses, only the apply clauses in the import-route-append command take effect.
· The MED value specified by the import-route-append command takes precedence over that specified by the import-route command.
3. Enable route redistribution from the specified IGP into BGP.
¡ Redistribute IS-IS, OSPF, or RIP routes.
¡ Redistribute direct or static routes.
import-route { direct | static } [ med med-value | route-policy route-policy-name ] *
¡ Redistribute EIGRP routes.
import-route eigrp [ { eigrp-as | all-as } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
By default, BGP does not redistribute IGP routes.
4. (Optional.) Redistribute routes from an IGP without overwriting the routes redistributed by the import-route command.
import-route-append { isis | ospf | rip } [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
import-route-append { direct | static } [ med med-value | route-policy route-policy-name ] *
import-route-append eigrp [ { eigrp-as | all-as } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
5. (Optional.) Redistribute all routes with the same destination address.
import-route multipath
This command is not supported in BGP IPv4 multicast address family view.
By default, BGP redistributes only the optimal routes to its routing table when multiple routes with the same destination address exist.
This command takes effect only on the routes redistributed by the import-route command in the same address family.
6. (Optional.) Enable default route redistribution into BGP.
By default, BGP does not redistribute default routes.
¡ Redistribute IPv6 IS-IS, OSPFv3, or RIPng routes.
import-route-append { isisv6 | ospfv3 | ripng } [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
This command is not supported in BGP IPv6 multicast address family view.
Route summarization can reduce the number of redistributed routes and the routing table size. IPv4 BGP supports automatic route summarization and manual route summarization. Manual summarization takes precedence over automatic summarization. IPv6 BGP supports only manual route summarization.
Automatic route summarization enables BGP to summarize IGP subnet routes redistributed by the import-route command, so BGP advertises only natural network routes.
By configuring manual route summarization, you can do the following:
· Summarize both redistributed routes and routes injected using the network command.
· Determine the mask length for a summary route.
Restrictions and guidelines for configuring BGP route summarization
The output interface of a BGP summary route is Null 0 on the originating router. Therefore, a summary route must not be an optimal route on the originating router. Otherwise, BGP will fail to forward packets matching the route. If a summarized specific route has the same mask as the summary route, but has a lower priority, the summary route becomes the optimal route. To ensure correct packet forwarding, change the priority of the summary or specific route to make the specific route the optimal route.
Configuring automatic route summarization (IPv4 unicast/multicast address family)
3. Configure automatic route summarization.
summary automatic
By default, automatic route summarization is not configured.
Configuring manual route summarization (IPv4 unicast/multicast address family)
3. Create a summary route in the BGP routing table.
By default, no summary routes are configured.
Configuring BGP manual route summarization (IPv6 unicast/multicast address family)
3. Create a summary route in the IPv6 BGP routing table.
Perform this task to advertise a default BGP route with the next hop being the advertising router to a peer or peer group.
3. Advertise a default route to a peer or peer group.
By default, no default route is advertised.
peer { group-name | ipv6-address [ prefix-length ] } default-route-advertise [ route-policy route-policy-name ]
By default, BGP advertises optimal routes in the BGP routing table, which may not be optimal in the IP routing table. This task allows you to advertise BGP routes that are optimal in the IP routing table.
Procedure (IPv4 unicast)
3. Enable BGP to advertise optimal routes in the IP routing table.
By default, BGP advertises optimal routes in the BGP routing table.
4. Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
¡ Enter BGP IPv4 unicast address family view.
5. Enable BGP to advertise optimal routes in the IP routing table of the address family in the VPN instance.
By default, the setting is the same as that in BGP instance view.
Procedure (IPv6 unicast)
3. Enable BGP to advertise optimal routes in the IPv6 routing table.
4. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
¡ Enter BGP IPv6 unicast address family view.
5. Enable BGP to advertise optimal routes in the IPv6 routing table of the address family in the VPN instance.
Typically a BGP router does not send withdrawal messages of the default route prior to other routes to its peers. If the peer relationship is down, the default route cannot be withdrawn first. Traffic interruption might occur. Perform this task to configure BGP to send the withdrawal messages of the default route prior to other routes. This can reduce the traffic interruption time when the peer relationship is down.
3. Enable BGP to send withdrawal messages of the default route prior to other routes.
default-route update-first
By default, BGP does not send withdrawal messages of the default route prior to other routes.
Perform this task to configure BGP to send the withdrawal messages of specific routes prior to other routes. This can achieve fast route switchover and reduce the traffic interruption time.
3. Enable BGP to send withdrawal messages of routes matching the specified routing policy prior to other routes.
By default, BGP does not send withdrawal messages of specific routes prior to other routes.
To configure BGP route distribution filtering policies, use the following methods:
· Use an ACL or prefix list to filter routing information advertised to all peers.
· Use a routing policy, ACL, AS path list, or prefix list to filter routing information advertised to a peer or peer group.
If you configure multiple filtering policies, apply them in the following sequence:
1. filter-policy export
2. peer filter-policy export
3. peer as-path-acl export
4. peer prefix-list export
5. peer route-policy export
Only routes passing all the configured policies can be advertised.
Before you configure BGP routing filtering policies, configure the following filters used for route filtering as needed:
· ACL (see ACL and QoS Configuration Guide).
· Prefix list (see "Configuring routing policies").
· Routing policy (see "Configuring routing policies").
· AS path list (see "Configuring routing policies").
When you specify an ACL, prefix list, or routing policy as a filtering policy to filter BGP routing information, follow these restrictions and guidelines:
· If the specified ACL, prefix list, or routing policy does not exist, all BGP routes can pass the filtering policy.
· When you specify an ACL or prefix list as a BGP route filtering policy (for example, use filter-policy export to specify an ACL for route filtering), the following rules apply:
¡ BGP routes can pass the filtering policy only when one of the following conditions exists:
- They match a permit rule in the specified ACL.
- They match a permit item in the specified prefix list.
When the ACL has only deny rules or the prefix list has only deny items, no BGP routes can pass the filtering policy.
¡ When the ACL match order is config, BGP routes match against rules in ascending order of rule ID. When BGP routes match against the items of the prefix list, an item with a smaller index number is matched first.
In either of the match modes above, a BGP route does not match against the next ACL rule or prefix list item when it already matches the current ACL rule or prefix list item. To avoid wasting filter resources, set a small match range for each ACL rule or prefix list item when you configure multiple ACL rules or prefix list items for an ACL or prefix list.
¡ You can use the rule [ rule-id ] permit ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command to create a rule for an advanced ACL to match specific routes. The source sour-addr sour-wildcard option represents the destination network address and the destination dest-addr dest-wildcard option represents the mask in dotted decimal notation. For example, to match route 3.3.3.0/24, the rule configuration should be rule [ rule-id ] permit ip source 3.3.3.0 0.0.0.255 destination 255.255.255.0 0.0.0.255.
· When you specify a routing policy as a BGP route filtering policy, the following rules apply:
¡ BGP routes can pass the filtering policy only when they match a permit node in the routing policy.
¡ A BGP route matches against the nodes of the routing policy in ascending order of node number. It does not match against the next node when it already matches the current node (unless a continue clause exists).
¡ If the routing policy has an ACL or prefix-list if-match clause, a BGP route can pass the filtering policy only when the following conditions exist:
i The route matches a permit rule in the ACL or a permit item in the prefix list.
ii The route matches a permit node in the routing policy.
3. Configure BGP route distribution filtering policies. Choose the options to configure as needed:
¡ Reference an ACL or IP prefix list to filter advertised BGP routes.
filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list ipv4-prefix-list-name } export [ direct | { isis | ospf | rip } process-id | static ]
¡ Specify a routing policy as the existent policy to control route advertisement.
This command is available only in BGP IPv4 unicast address family view.
¡ Specify a routing policy as the nonexistent policy to control route advertisement.
¡ Reference a routing policy to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name export
¡ Reference an ACL to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy ipv4-acl-number export
¡ Reference an AS path list to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl as-path-acl-number export
¡ Reference an IPv4 prefix list to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv4-prefix-list-name export
By default, no BGP distribution filtering policy is configured.
The ipv6-address [ prefix-length ] argument is not supported in BGP IPv4 multicast address family view.
¡ Reference an ACL or IPv6 prefix list to filter advertised BGP routes.
filter-policy { ipv6-acl-number | name ipv6-acl-name | prefix-list ipv6-prefix-list-name } export [ direct | { isisv6 | ospfv3 | ripng } process-id | static ]
This command is available only in BGP IPv6 unicast address family view.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy ipv6-acl-number export
¡ Reference an IPv6 prefix list to filter BGP routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-list-name export
The ipv4-address [ mask-length ] argument is not supported in BGP IPv6 multicast address family view.
By default, BGP does not check the first AS number of a received EBGP route and directly advertises it to all peers except the source peer. The default setting for EBGP route advertisement brings about a large number of BGP routes and is not friendly to network maintenance.
To resolve this issue, perform this task. When the first AS number of an EBGP route to be advertised is the same as that of an EBGP peer, BGP does not advertise the route to that peer. This can reduce the number of routes received by EBGP peers.
2. Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
3. Enable BGP to perform first-AS-number check for EBGP routes before route advertisement.
peer-as-check enable
2. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
If a device sends many new routes within a short time period, it might be unable to add the routes to the FIB before the peer device adds them. This might result in traffic forwarding failure. To avoid this issue, you can perform this task to set an appropriate route sending rate for the device.
If the device performance is high, set a high BGP route sending rate as needed. Otherwise, set a low rate.
To prevent route withdrawal failures when network flapping occurs, avoid setting the rate to 0 or a small value and make sure the rate is high enough for the network.
This task applies only to IPv4 unicast routes and IPv6 unicast routes.
3. Set the BGP route sending rate.
route-rate-limit rate
By default, the BGP route sending rate is not limited.
With this task performed, BGP delays sending route updates when it restores after a device reboot. During the delay time, BGP learns all routes from other neighbors, and then selects the optimal route. After the delay time elapses, BGP will advertise the optimal route. This can reduce traffic loss.
You can specify a prefix list and enable BGP to immediately send route updates for routes that match the prefix list.
For BGP EVPN routes, this feature takes effect only on IP prefix routes and MAC/IP advertisement routes that carry IP routing information.
3. Configure BGP to delay sending route updates when it restores after a device reboot.
By default, BGP immediately sends route updates to BGP peers in established state when it restores after a device reboot.
4. (Optional.) Enable BGP to immediately send route updates for IPv4 routes that match a prefix list.
By default, no prefix list is specified to filter IPv4 routes.
5. (Optional.) Enable BGP to immediately send route updates for IPv6 routes that match a prefix list.
bgp update-delay on-startup ipv6-prefix-list ipv6-prefix-list-name
By default, no prefix list is specified to filter IPv6 routes.
A BGP router sends an UPDATE message to its peers when a route is changed. If the route changes frequently, the BGP router keeps sending updates for the same route, resulting route flapping. This task can reduce the impact of routing flaps by suppressing the frequency of sending the same route update to a peer or peer group.
To control the frequency of sending the same route update, use one of the following methods:
· Configure the interval for sending the same route update.
BGP will send a route update at the specified intervals to a peer or peer group.
· Apply the intelligent timer to control the frequency of sending the same route update.
BGP can flexibly control the interval for sending the same route update to a peer or peer group according to the network condition.
If you apply the intelligent timer, the initial route-update suppression interval takes effect after BGP sends a route update. During the suppression interval, the number of times that BGP can send the same route update to a peer is limited. The length of the next suppression interval depends on the number of route flaps that occur within the current suppression interval as follows:
¡ If the number of route flaps increases, the next suppression interval also shortens.
¡ If the number of route flaps reduces, the next suppression interval is the same as the current suppression interval or shortens.
After the current suppression interval elapses, BGP can resend the route update, and then the next suppression interval takes effect.
For more information about how to calculate the suppression interval and how it works, see the route-update-interval intelligent-timer command in the command reference.
The route-update-interval intelligent-timer command takes effect only when you use it together with the peer route-update-interval intelligent-timer command.
BGP compares the timer values specified for a BGP peer by using the route-update-delay command and the peer route-update-interval command. Only the larger timer value takes effect. If you did not execute the peer route-update-interval command, BGP compares the BGP route advertisement delay timer with the default value of the peer route-update-interval command.
Configuring the interval for sending the same route update
3. Configure the interval for sending updates for the same route to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-update-interval interval
By default, the interval is 15 seconds for an IBGP peer and 30 seconds for an EBGP peer.
Applying the intelligent timer for route update suppression
3. Configure the intelligent timer parameters for route-update suppression interval calculation.
route-update-interval intelligent-timer min-update-interval [ max-update-interval [ ignore-delay-count [ incremental-interval ] ] ]
By default, the following intelligent timer settings take effect:
¡ The maximum update suppression interval is 30 seconds.
¡ The minimum update suppression interval is 5 seconds.
¡ BGP can send the same route update to peers three times in a suppression interval.
¡ The penalty increment interval is 1 second.
4. Apply the intelligent timer to suppress the frequency of sending the same update.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-update-interval intelligent-timer
By default, the interval for sending the same update to an IBGP peer is 15 seconds and the interval for sending the same update to an EBGP peer is 30 seconds.
By default, for a route to be withdrawn, a BGP router immediately sends a withdrawal message to its peers. If the route changes frequently, the BGP router sends many updates for the route, resulting in routing flaps. To avoid this issue, use this feature to apply the route update interval configured in the peer route-update-interval command to withdrawn routes. BGP will send withdrawn and update messages at the specified intervals.
This feature does not take effect on routes that exist before the feature is configured.
1. Enter BGP instance view.
2. Apply route update interval setting to withdrawn routes.
route-update-interval withdrawn enable
By default, route update interval setting does not apply to withdrawn routes. BGP sends withdrawal messages for withdrawn routes immediately.
BGP sends update messages to peers when route changes occur or peer relationship establishment is complete. If a large number of routes need to be updated within a short time period, BGP might send update messages to peers before issuing the updated routes to the FIB. As a result, some packets might be discarded because BGP cannot find the forwarding path for the packets.
To resolve this issue, perform this task to enable BGP route advertisement delay and set a delay timer. When route changes occur or peer relationship establishment is complete, BGP cannot send any update messages unless the delay timer expires.
This feature applies to BGP IPv4 unicast routes, BGP IPv6 unicast routes, BGP VPNv4 routes, and BGP VPNv6 routes.
3. Enable BGP route advertisement delay and set a delay timer.
route-update-delay delay-value
By default, BGP route advertisement delay is disabled.
Perform this task to configure BGP to send route updates with the specified attributes within the specified period after reboot.
As shown in Figure 12, if Router B restarts and sends route updates before route convergence completes, traffic sent from Router A through Router B might be lost. This feature enables Router B to send route updates with the specified attribute values within the specified period after reboot, so that Router A can forward traffic through Router C.
3. Specify the period after reboot within which the startup policy is effective.
By default, the startup policy does not take effect.
4. Specify a MED attribute value in the startup policy.
By default, the MED attribute value in the startup policy is 4294967295.
A small send buffer size might cause a long convergence time when there are a large number of update messages to send. Execute this command to set an appropriate send buffer size to improve the convergence performance.
This feature takes effect only on BGP sessions established or re-established after the feature is configured.
You can perform this task for all BGP peers or for a specific BGP peer or peer group. For a BGP peer or peer group, the configuration of the peer send-buffer-size command takes precedence over that of the send-buffer-size command. If you do not configure the peer send-buffer-size command for the peer or peer group, the configuration of the send-buffer-size command takes effect on the peer or peer group.
Procedure (global configuration)
3. Set the send buffer size for BGP sessions.
send-buffer-size size
By default, the send buffer size is 32768 bytes.
Procedure (Configuration for a peer or peer group)
3. Set the send buffer size for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } send-buffer-size size
By default, the send buffer size for a peer or peer group is not set. The send buffer size configured by the send-buffer-size command applies.
The configuration of this command takes precedence over that of the send-buffer-size command.
A BGP speaker uses update messages to advertise route updates to peers. Perform this task to prevent the device from sending a large number of update messages in a short time period, which saves system resources and improves the network convergence performance.
The BGP update message sending parameters are determined by the following configuration:
· Update message sending interval and the maximum number of update messages that can be sent each time.
· Update message send queue parameters.
Setting the update interval and the maximum number of update messages that can be sent each time
After you perform this task, the device does not send update messages to its peers within the interval. You can set the update interval and the maximum number of update messages that can be sent each time together.
You can perform this task for all BGP peers or for a specific BGP peer or peer group. For a BGP peer or peer group, the configuration of the peer advertisement-interval command takes precedence over that of the advertisement-interval command. If you do not configure the peer advertisement-interval command for the peer or peer group, the configuration of the advertisement-interval command takes effect on the peer or peer group.
3. Set the interval for sending update messages and the maximum number of update messages that can be sent each time.
advertisement-interval interval count
By default, the device sends update messages to its peers immediately if it needs to update routes. The maximum number of update messages that can be sent each time is unlimited.
Procedure (configuration for a peer or peer group)
3. Set the interval for sending update messages and the maximum number of update messages that can be sent each time to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertisement-interval interval count
By default, the two parameters are not set and the configuration of the advertisement-interval command takes effect.
The configuration of this command takes precedence over that of the advertisement-interval command.
Setting the update message send queue parameters
BGP sessions take turns to send update messages. Before taking the turn, a BGP session queues up its update messages that need to be sent. If the number of messages in the send queue reaches the specified limit, the session stops generating update messages. The BGP session sends a specified quantity of update messages at the head of the send queue.
3. Set the update message send queue parameters.
bgp queue-limit { packet packet-count | send send-count } *
By default, the maximum number of BGP update message in the send queue is 100 and the number of update messages sent each time is 5.
This feature can prevent attacks that send a large number of BGP routes to the router.
If the number of routes received from a peer or peer group exceeds the upper limit, the router takes one of the following actions based on your configuration:
· Tears down the BGP session to the peer or peer group and does not attempt to re-establish the session.
· Continues to receive routes from the peer or peer group and generates a log message.
· Retains the session to the peer or peer group, but it discards excess routes and generates a log message.
· Tears down the BGP session to the peer or peer group and, after a specific period of time, re-establishes a BGP session to the peer or peer group.
You can specify a percentage threshold for the router to generate a log message. When the ratio of the number of received routes to the maximum number reaches the percentage value, the router generates a log message.
3. Specify the maximum number of routes that a router can receive from a peer or peer group.
By default, the number of routes that a router can receive from a peer or peer group is not limited.
peer { group-name | | ipv4-address [ mask-length ] ipv6-address [ prefix-length ] } route-limit prefix-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ] *
You can use the following methods to configure BGP route reception filtering policies:
· Use an ACL or prefix list to filter routing information received from all peers.
· Use a routing policy, ACL, AS path list, or prefix list to filter routing information received from a peer or peer group.
1. filter-policy import
2. peer filter-policy import
3. peer as-path-acl import
4. peer prefix-list import
5. peer route-policy import
Only routes passing all the configured policies can be received.
Before you configure BGP route reception filtering policies, configure the following filters used for route filtering as needed:
¡ In either of the match modes above, a BGP route does not match against the next ACL rule or prefix list item when it already matches the current ACL rule or prefix list item. To avoid wasting filter resources, set a small match range for each ACL rule or prefix list item when you configure multiple ACL rules or prefix list items for an ACL or prefix list.
3. Configure BGP route reception filtering policies. Choose the options to configure as needed:
¡ Reference an ACL or IP prefix list to filter BGP routes received from all peers.
¡ Reference a routing policy to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name import
¡ Reference an ACL to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy ipv4-acl-number import
¡ Reference an AS path list to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl as-path-acl-number import
¡ Reference an IPv4 prefix list to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv4-prefix-list-name import
By default, no route reception filtering is configured.
¡ Reference ACL or IPv6 prefix list to filter BGP routes received from all peers.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy ipv6-acl-number import
¡ Reference an IPv6 prefix list to filter BGP routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-list-name import
After you configure the SoO attribute for a BGP peer or peer group, BGP adds the SoO attribute into the route updates received from the BGP peer or peer group. In addition, before advertising route updates to the peer or peer group, BGP checks the SoO attribute of the route update against the configured SoO attribute. If they are the same, BGP does not advertise the route updates to the BGP peer or peer group.
3. Configure the SoO attribute for a peer or peer group.
By default, no SoO attribute is configured for a peer or peer group.
BGP sends KEEPALIVE messages regularly to keep the BGP session between two routers.
If a router receives no KEEPALIVE or UPDATE message from a peer within the hold time, it tears down the session.
You can configure the keepalive interval and hold time globally or for a peer or peer group. The individual settings take precedence over the global settings.
The actual keepalive interval and hold time are determined as follows:
· If the hold time settings on the local and peer routers are different, the smaller setting is used. If the hold time is 0, BGP does not send KEEPALIVE messages to its peers and never tears down the session.
· If the keepalive interval is not 0, the actual keepalive interval is the smaller one between 1/3 of the hold time and the keepalive interval.
The hold time must be a minimum of three times the keepalive interval.
You can perform this task for all BGP peers or for a specific BGP peer or peer group. For a BGP peer or peer group, the configuration of the peer timer command takes precedence over that of the timer command. If you do not configure the peer timer command for the peer or peer group, the configuration of the timer command takes effect on the peer or peer group.
3. Configure the keepalive interval and hold time.
¡ Configure the global keepalive interval and hold time.
This command takes effect for new BGP sessions and does not affect existing sessions.
¡ Configure the keepalive interval and hold time for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } timer keepalive keepalive hold holdtime
By default, the keepalive interval is 60 seconds, and hold time is 180 seconds.
The timers configured with the timer and peer timer commands do not take effect until a session is re-established (for example, a session is reset).
peer { group-name | ipv6-address [ prefix-length ] } timer keepalive keepalive hold holdtime
To speed up session establishment to a peer or peer group and route convergence, set a small session retry timer. If the BGP session flaps, you can set a large session retry timer to reduce the impact.
The timer set by the peer timer connect-retry command takes precedence over the timer set by the timer connect-retry command.
3. Set the session retry timer. Choose an option to configure as needed:
¡ Set the session retry timer for all peers or peer groups.
¡ Set the session retry timer for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } timer connect-retry retry-time
By default, the session retry timer is 32 seconds for a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } timer connect-retry retry-time
BGP includes local MPLS labels in advertised VPNv4 routes, VPNv6 routes, labeled IPv6 unicast routes, and labeled IPv4 unicast routes.
When a local label is changed, BGP removes the old label and advertises the new label. Traffic interruption occurs if BGP peers use the old label to forward packets before they learn the new label. To resolve this issue, set an update delay for local MPLS labels. BGP does not remove the old label before the update delay timer expires.
3. Set an update delay for local MPLS labels.
retain local-label retain-time
By default, the update delay is 60 seconds.
Perform this task to enable BGP to log BGP session establishment and disconnection events. To display the log information, use the display bgp peer ipv4 unicast log-info command or the display bgp peer ipv6 unicast log-info command. The logs are sent to the information center. The output rules of the logs (whether to output the logs and where to output) are determined by the information center configuration.
For more information about information center configuration, see System Management Configuration Guide.
3. Enable logging for session state changes globally.
log-peer-change
By default, logging for session state changes is enabled globally.
4. (Optional.) Enter BGP-VPN instance view.
5. Enable logging for session state changes for a peer or peer group.
By default, logging for session state changes is enabled for all peers and peer groups.
log-peer-change
peer { group-name | ipv6-address [ prefix-length ] } log-change
Enabling logging for BGP route flapping
This feature enables BGP to generate logs for BGP route flapping events that trigger log generation. The generated logs are sent to the information center. For the logs to be output correctly, you must also configure information center on the device. For more information about the information center, see System Management Configuration Guide.
Procedure (IPv4 unicast/IPv4 multicast)
3. Enable logging for BGP route flapping.
By default, logging for BGP route flapping is disabled.
Procedure (IPv6 unicast/IPv6 multicast)
Configuring BGP network management
After you enable SNMP notifications for BGP, the device generates a notification when a BGP session state change occurs. The notification includes the neighbor address, the error code and subcode of the most recent error, and the current neighbor state. For BGP notifications to be sent correctly, you must also configure SNMP on the device.
BGP does not know the BGP instance to which a managed MIB node belongs. To resolve this issue, configure different SNMP contexts for different BGP instances.
The device selects a MIB for an SNMP packet according to the context (for SNMPv3) or community name (for SNMPv1/v2c) in the following ways:
· For an SNMPv3 packet:
¡ The device selects the MIB of the default BGP instance if the packet does not carry a context and no SNMP context is configured for the default BGP instance.
¡ The device selects the MIB of a BGP instance if the packet meets the following conditions:
- Carries a context that is configured with the snmp-agent context command in system view.
- Matches the context of the BGP instance.
¡ The device does not process any MIBs in other situations.
· For an SNMPv1/v2c packet:
¡ The device selects the MIB of the default BGP instance if the following conditions are met:
- No community name-to-SNMP context mapping is configured with the snmp-agent community-map command in system view.
- No SNMP context is configured for the default BGP instance.
¡ The device selects the MIB of a BGP instance if the community name is mapped to an SNMP context and the context matches the context of the BGP instance.
For more information about SNMP contexts and community names, see SNMP configuration in Network Management and Monitoring Configuration Guide.
After you configure the snmp-agent trap enable bgp command, the following rules apply:
· Whether the device generates notifications specified by the following keywords depends on the configuration of the peer route-limit command:
¡ peer-addrfamily-routeexceed
¡ peer-addrfamily-routeexceed-clear
¡ peer-addrfamily-routethreshold-exceed
¡ peer-addrfamily-routethreshold-clear
¡ peer-routeexceed
¡ peer-routeexceed-clear
¡ peer-routethreshold-clear
¡ peer-routethreshold-exceed
The peer route-limit command determines the number of routes that the router can receive and the log generation threshold. If the peer route-limit command is not executed, the maximum number of routes that triggers notifications is 4294967295 and the route quantity alarm threshold is 70%.
· Whether the device generates the notifications specified by the peer-rpkisession-roaexceed or peer-rpkisession-roaexceed-clear keyword depends on the configuration of the rpki-limit command. If the rpki-limit command is not configured in RPKI server view, the device generates notifications when the number of ROAs received from the RPKI server reaches or exceeds 4294967295.
1. Enter system view.
2. Enable SNMP notifications for BGP.
snmp-agent trap enable bgp [ instance instance-name ] [ peer-addrfamily-routeexceed | peer-addrfamily-routeexceed-clear | peer-addrfamily-routethreshold-clear | peer-addrfamily-routethreshold-exceed | peer-backward-transition | peer-established | peer-gr-status-change | peer-routeexceed | peer-routeexceed-clear | peer-routethreshold-clear | peer-routethreshold-exceed | peer-rpkisession-roaexceed | peer-rpkisession-roaexceed-clear ] *
By default, SNMP notifications for BGP are enabled.
If you do not specify any notification types, this command enables all types of notifications for BGP. If you specify notification types, this command enables only the specified types of notifications for BGP.
3. Enter BGP instance view.
4. Configure an SNMP context for the BGP instance.
By default, no SNMP context is configured for the BGP instance.
Verifying and maintaining basic BGP network configuration
Verifying BGP configuration and running status (IPv4 unicast address family)
· Display BGP IPv4 unicast peer group information.
display bgp [ instance instance-name ] group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name group-name ]
· Display information about a peer or peer group in BGP IPv4 unicast address family.
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | ipv6-address log-info | [ ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer ipv4 [ unicast ] vpn-instance-all [ verbose ]
· Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command.
display bgp [ instance instance-name ] network ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
· Display BGP IPv4 unicast route information.
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | ipv4-address [ mask-length | mask ] { as-path | cluster-list | community | ext-community } | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] as-path-acl { as-path-acl-number | as-path-acl-name }
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ statistics ] community-list { basic-community-list-number | comm-list-name | adv-community-list-number } [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ statistics ] ext-community [ bandwidth link-bandwidth-value | color color | rt route-target | soo site-of-origin ]&<1-32> [ whole-match ]
· Display information about BGP peer relationship down events.
display bgp [ instance instance-name ] troubleshooting [ event-count ] [ reverse ]
· Display update group information in BGP IPv4 unicast address family.
display bgp [ instance instance-name ] update-group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address | ipv6-address ]
· Display summary information about BGP peers and routes.
display bgp [ instance instance-name ] ipv4 vpn-instance vpn-instance-name summary
· Display information about all BGP instances.
display bgp instance-info
Verifying BGP configuration and running status (IPv6 unicast address family)
· Display BGP IPv6 unicast peer group information.
display bgp [ instance instance-name ] group ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name group-name ]
· Display information about a peer or peer group in BGP IPv6 unicast address family.
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ ipv4-address mask-length | ipv4-address log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer ipv6 [ unicast ] vpn-instance-all [ verbose ]
display bgp [ instance instance-name ] network ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
· Display BGP IPv6 unicast route information.
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length [ advertise-info ] | ipv6-address prefix-length { as-path | cluster-list | community | ext-community } | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ ipv6-address display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] peer ipv4-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] prefix-length | statistics ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] as-path-acl { as-path-acl-number | as-path-acl-name }
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ statistics ] community-list { basic-community-list-number | comm-list-name | adv-community-list-number } [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ statistics ] ext-community [ bandwidth link-bandwidth-value | color color | rt route-target | soo site-of-origin ]&<1-32> [ whole-match ]
· Display BGP IPv6 unicast address family update group information.
display bgp [ instance instance-name ] update-group ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address | ipv6-address ]
display bgp [ instance instance-name ] ipv6 vpn-instance vpn-instance-name summary
Verifying BGP configuration and running status (IPv4 multicast address family)
· Display BGP IPv4 multicast peer group information.
display bgp [ instance instance-name ] group ipv4 multicast [ group-name group-name ]
· Display BGP IPv4 multicast peer or peer group information.
display bgp [ instance instance-name ] peer ipv4 multicast [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] network ipv4 multicast
· Display BGP route attribute information.
· Display BGP IPv4 multicast route information.
display bgp [ instance instance-name ] routing-table ipv4 multicast [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | ipv4-address [ mask-length | mask ] { as-path | cluster-list | community | ext-community } | peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv4 multicast as-path-acl { as-path-acl-number | as-path-acl-name }
display bgp [ instance instance-name ] routing-table ipv4 multicast [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv4 multicast [ statistics ] community-list { basic-community-list-number | comm-list-name | adv-community-list-number } [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv4 multicast [ statistics ] ext-community [ bandwidth link-bandwidth-value | color color | rt route-target | soo site-of-origin ]&<1-32> [ whole-match ]
· Display BGP IPv4 multicast address family update group information.
display bgp [ instance instance-name ] update-group ipv4 multicast [ ipv4-address ]
Verifying BGP configuration and running status (IPv6 multicast address family)
· Display BGP IPv6 multicast peer group information.
display bgp [ instance instance-name ] group ipv6 multicast [ group-name group-name ]
· Display BGP IPv6 multicast peer or peer group information.
display bgp [ instance instance-name ] peer ipv6 multicast [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ]
display bgp [ instance instance-name ] network ipv6 multicast
· Display BGP IPv6 multicast route information.
display bgp [ instance instance-name ] routing-table ipv6 multicast [ ipv6-address prefix-length [ advertise-info ] | ipv6-address prefix-length { as-path | cluster-list | community | ext-community } | peer ipv6-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv6 multicast as-path-acl { as-path-acl-number | as-path-acl-name }
display bgp [ instance instance-name ] routing-table ipv6 multicast [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv6 multicast [ statistics ] community-list { basic-community-list-number | comm-list-name | adv-community-list-number } [ whole-match ]
display bgp [ instance instance-name ] routing-table ipv6 multicast [ statistics ] ext-community [ bandwidth link-bandwidth-value | color color | rt route-target | soo site-of-origin ]&<1-32> [ whole-match ]
· Display BGP IPv6 multicast address family update group information.
display bgp [ instance instance-name ] update-group ipv6 multicast [ ipv6-address ]
Resetting BGP sessions
A reset operation enables the router to apply a new route selection policy by re-establishing BGP sessions.
A reset operation tears down BGP sessions for a short period of time.
Perform reset tasks in user view.
· Reset BGP sessions for IPv4 unicast address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
reset bgp ipv6-address [ mask-length ] ipv4 [ unicast ]
· Reset BGP sessions for IPv4 multicast address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 multicast
· Reset BGP sessions for IPv6 unicast address family.
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
reset bgp ipv4-address [ mask-length ] ipv6 [ unicast ]
· Reset BGP sessions for IPv6 multicast address family.
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 multicast
· Reset all BGP sessions.
Displaying and clearing BGP route flapping statistics
Displaying BGP route flapping statistics
· Display BGP IPv4 unicast route flapping statistics.
display bgp [ instance instance-name ] routing-table flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ]
· Display BGP IPv6 unicast route flapping statistics.
display bgp [ instance instance-name ] routing-table flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } ]
· Display BGP IPv4 multicast route flapping statistics.
display bgp [ instance instance-name ] routing-table flap-info ipv4 multicast [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ]
· Display BGP IPv6 multicast route flapping statistics.
display bgp [ instance instance-name ] routing-table flap-info ipv6 multicast [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } ]
Clearing BGP route flapping statistics
Perform clear tasks in user view.
· Clear BGP IPv4 unicast route flapping statistics.
reset bgp [ instance instance-name ] flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask ] | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv4-address [ mask-length ] ]
· Clear BGP IPv4 multicast route flapping statistics.
reset bgp [ instance instance-name ] flap-info ipv4 multicast [ ipv4-address [ mask-length | mask ] | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv4-address [ mask-length ] ]
· Clear BGP IPv6 unicast route flapping statistics.
reset bgp [ instance instance-name ] flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv6-address [ prefix-length ] ]
· Clear BGP IPv6 multicast route flapping statistics.
reset bgp [ instance instance-name ] flap-info ipv6 multicast [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv6-address [ prefix-length ] ]
Basic IPv4 BGP network configuration examples
Example: Configuring basic BGP
As shown in Figure 13, all routers run BGP. Run EBGP between Router A and Router B, and run IBGP between Router B and Router C to allow Router C to access network 8.1.1.0/24 connected to Router A.
1. Configure IP addresses for interfaces. (Details not shown.)
2. Configure IBGP:
¡ To prevent route flapping caused by port state changes, this example uses loopback interfaces to establish IBGP connections.
¡ Because loopback interfaces are virtual interfaces, you need to use the peer connect-interface command to specify the loopback interface as the source interface for establishing BGP connections.
¡ Enable OSPF in AS 65009 to ensure that Router B can communicate with Router C through loopback interfaces.
# Configure Router B.
<RouterB> system-view
[RouterB] bgp 65009
[RouterB-bgp-default] router-id 2.2.2.2
[RouterB-bgp-default] peer 3.3.3.3 as-number 65009
[RouterB-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[RouterB-bgp-default] address-family ipv4 unicast
[RouterB-bgp-default-ipv4] peer 3.3.3.3 enable
[RouterB-bgp-default-ipv4] quit
[RouterB-bgp-default] quit
[RouterB] ospf 1
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 9.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
# Configure Router C.
<RouterC> system-view
[RouterC] bgp 65009
[RouterC-bgp-default] router-id 3.3.3.3
[RouterC-bgp-default] peer 2.2.2.2 as-number 65009
[RouterC-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[RouterC-bgp-default] address-family ipv4 unicast
[RouterC-bgp-default-ipv4] peer 2.2.2.2 enable
[RouterC-bgp-default-ipv4] quit
[RouterC-bgp-default] quit
[RouterC] ospf 1
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[RouterC-ospf-1-area-0.0.0.0] network 9.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
[RouterC] display bgp peer ipv4
BGP local router ID : 3.3.3.3
Local AS number : 65009
Total number of peers : 1 Peers in established state : 1
* - Dynamically created peer
2.2.2.2 65009 7 10 0 0 00:06:09 Established
The output shows that Router C has established an IBGP peer relationship with Router B.
3. Configure EBGP:
¡ The EBGP peers, Router A and Router B (usually in different ISPs), are located in different ASs. Typically, their loopback interfaces are not reachable to each other, so directly connected interfaces are used for establishing EBGP sessions.
¡ To enable Router C to access the network 8.1.1.0/24 connected directly to Router A, inject network 8.1.1.0/24 to the BGP routing table of Router A.
# Configure Router A.
[RouterA] bgp 65008
[RouterA-bgp-default] router-id 1.1.1.1
[RouterA-bgp-default] peer 3.1.1.1 as-number 65009
[RouterA-bgp-default] address-family ipv4 unicast
[RouterA-bgp-default-ipv4] peer 3.1.1.1 enable
[RouterA-bgp-default-ipv4] network 8.1.1.0 24
[RouterA-bgp-default-ipv4] quit
[RouterA-bgp-default] quit
[RouterB] bgp 65009
[RouterB-bgp-default] peer 3.1.1.2 as-number 65008
[RouterB-bgp-default-ipv4] peer 3.1.1.2 enable
# Display BGP peer information on Router B.
[RouterB] display bgp peer ipv4
BGP local router ID : 2.2.2.2
Total number of peers : 2 Peers in established state : 2
3.3.3.3 65009 12 10 0 3 00:09:16 Established
3.1.1.2 65008 3 3 0 1 00:00:08 Established
The output shows that Router B has established an IBGP peer relationship with Router C and an EBGP peer relationship with Router A.
# Display the BGP routing table on Router A.
[RouterA] display bgp routing-table ipv4
Total number of routes: 1
a – additional-path
* > 8.1.1.0/24 8.1.1.1 0 32768 i
# Display the BGP routing table on Router B.
[RouterB] display bgp routing-table ipv4
a – additional-path
* >e 8.1.1.0/24 3.1.1.2 0 0 65008i
# Display the BGP routing table on Router C.
[RouterC] display bgp routing-table ipv4
a – additional-path
i 8.1.1.0/24 3.1.1.2 0 100 0 65008i
The outputs show that Router A has no route to AS 65009, and Router C has learned network 8.1.1.0, but the next hop 3.1.1.2 is unreachable. As a result, the route is invalid.
4. Redistribute direct routes:
Configure BGP to redistribute direct routes on Router B, so Router A can obtain the route to 9.1.1.0/24, and Router C can obtain the route to 3.1.1.0/24.
[RouterB] bgp 65009
[RouterB-bgp-default-ipv4] import-route direct
Total number of routes: 4
a – additional-path
* >e 2.2.2.2/32 3.1.1.1 0 0 65009?
* >e 3.1.1.0/24 3.1.1.1 0 0 65009?
* >e 9.1.1.0/24 3.1.1.1 0 0 65009?
Two routes 2.2.2.2/32 and 9.1.1.0/24 have been added in Router A's routing table.
a – additional-path
* >i 2.2.2.2/32 2.2.2.2 0 100 0 ?
* >i 3.1.1.0/24 2.2.2.2 0 100 0 ?
* >i 8.1.1.0/24 3.1.1.2 0 100 0 65008i
* >i 9.1.1.0/24 2.2.2.2 0 100 0 ?
The output shows that the route 8.1.1.0 has become valid and the next hop is Router A.
# Verify that Router C can ping 8.1.1.1.
[RouterC] ping 8.1.1.1
Ping 8.1.1.1 (8.1.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 8.1.1.1: icmp_seq=0 ttl=255 time=2.000 ms
56 bytes from 8.1.1.1: icmp_seq=1 ttl=255 time=0.000 ms
56 bytes from 8.1.1.1: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 8.1.1.1: icmp_seq=3 ttl=255 time=0.000 ms
56 bytes from 8.1.1.1: icmp_seq=4 ttl=255 time=1.000 ms
round-trip min/avg/max/std-dev = 0.000/0.600/2.000/0.800 ms
Example: Configuring BGP and IGP route redistribution
As shown in Figure 14, all devices of company A belong to AS 65008 and all devices of company B belong to AS 65009.
Configure BGP and IGP route redistribution to allow Router A to access network 9.1.2.0/24 in AS 65009, and Router C to access network 8.1.1.0/24 in AS 65008.
2. Configure OSPF:
Enable OSPF in AS 65009, so Router B can obtain the route to 9.1.2.0/24.
[RouterB] ospf 1
[RouterC] ospf 1
[RouterC-ospf-1] import-route direct
3. Configure the EBGP connection:
Configure the EBGP connection and inject network 8.1.1.0/24 to the BGP routing table of Router A, so Router B can obtain the route to 8.1.1.0/24.
[RouterA] bgp 65008
[RouterB] bgp 65009
4. Configure BGP and IGP route redistribution:
¡ Configure BGP to redistribute routes from OSPF on Router B, so Router A can obtain the route to 9.1.2.0/24.
¡ Configure OSPF to redistribute routes from BGP on Router B, so that Router C can obtain the route to 8.1.1.0/24.
# Configure route redistribution between BGP and OSPF on Router B.
[RouterB-bgp-default-ipv4] import-route ospf 1
[RouterB] ospf 1
[RouterB-ospf-1] import-route bgp
Total number of routes: 3
a – additional-path
* >e 3.3.3.3/32 3.1.1.1 1 0 65009?
* >e 9.1.2.0/24 3.1.1.1 1 0 65009?
# Display the OSPF routing table on Router C.
[RouterC] display ospf routing
Routing Tables
Routing for Network
Destination Cost Type NextHop AdvRouter Area
9.1.1.0/24 1 Transit 9.1.1.2 3.3.3.3 0.0.0.0
2.2.2.2/32 1 Stub 9.1.1.1 2.2.2.2 0.0.0.0
Routing for ASEs
Destination Cost Type Tag NextHop AdvRouter
8.1.1.0/24 1 Type2 1 9.1.1.1 2.2.2.2
Total Nets: 3
Intra Area: 2 Inter Area: 0 ASE: 1 NSSA: 0
# Use ping to test connectivity.
[RouterA] ping -a 8.1.1.1 9.1.2.1
Ping 9.1.2.1 (9.1.2.1) from 8.1.1.1: 56 data bytes, press CTRL+C to break
[RouterC] ping -a 9.1.2.1 8.1.1.1
Ping 8.1.1.1 (8.1.1.1) from 9.1.2.1: 56 data bytes, press CTRL+C to break
Example: Configuring dynamic BGP peers
As shown in Figure 15, Router A needs to establish IBGP peer relationships with Router B, Router C, and Router D in network 10.1.0.0/16. Configure dynamic BGP peers to simplify the configuration.
Configure Router A as the route reflector, and configure Router B, Router C, and Router D as its clients.
2. Configure IBGP peer relationships:
# Configure Router A to establish dynamic BGP peer relationships with routers in network 10.1.0.0/16.
[RouterA] bgp 200
[RouterA-bgp-default] peer 10.1.0.0 16 as-number 200
[RouterA-bgp-default-ipv4] peer 10.1.0.0 16 enable
# Configure Router B to establish an IBGP peer relationship with Router A.
[RouterB] bgp 200
[RouterB-bgp-default] peer 10.1.1.1 as-number 200
[RouterB-bgp-default-ipv4] peer 10.1.1.1 enable
# Configure Router C to establish an IBGP peer relationship with Router A.
[RouterC] bgp 200
[RouterC-bgp-default] peer 10.1.2.1 as-number 200
[RouterC-bgp-default-ipv4] peer 10.1.2.1 enable
# Configure Router D to establish an IBGP peer relationship with Router A.
<RouterD> system-view
[RouterD] bgp 200
[RouterD-bgp-default] router-id 4.4.4.4
[RouterD-bgp-default] peer 10.1.3.1 as-number 200
[RouterD-bgp-default] address-family ipv4
[RouterD-bgp-default-ipv4] peer 10.1.3.1 enable
# Display BGP peer information on Router A. The output shows that Router A has established IBGP peer relationships with Router B, Router C, and Router D.
[RouterA] display bgp peer ipv4
BGP local router ID : 1.1.1.1
Local AS number : 200
Total number of peers : 3 Peers in established state : 3
*10.1.1.2 200 7 10 0 0 00:06:09 Established
*10.1.2.2 200 7 10 0 0 00:06:09 Established
*10.1.3.2 200 7 10 0 0 00:06:09 Established
3. Configure Router A as the route reflector, and configure peers in network 10.1.0.0/16 as its clients.
[RouterA-bgp-default-ipv4] peer 10.1.0.0 16 reflect-client
4. Configure Router C to advertise network 9.1.1.0/24.
[RouterC-bgp-default-ipv4] network 9.1.1.0 24
# Verify that route 9.1.1.0/24 exists in the BGP routing table on Router A, Router B, Router D. This example uses Router A.
[RouterA-bgp-default] display bgp routing-table ipv4
Total Number of Routes: 1
a – additional-path
* i 9.1.1.0/24 10.1.2.2 0 100 0 ?
Example: Configuring BGP route summarization
As shown in Figure 16, run EBGP between Router C and Router D, so the internal network and external network can communicate with each other.
· In AS 65106, perform the following configurations so the devices in the internal network can communicate:
¡ Configure static routing between Router A and Router B.
¡ Configure OSPF between Router B and Router C.
¡ Configure OSPF to redistribute static routes.
· Configure route summarization on Router C so BGP advertises a summary route instead of advertising routes to the 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 networks to Router D.
2. Configure static routing between Router A and Router B:
# Configure a default route with the next hop 192.168.212.1 on Router A.
[RouterA] ip route-static 0.0.0.0 0 192.168.212.1
# Configure static routes to 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 with the same next hop 192.168.212.161 on Router B.
[RouterB] ip route-static 192.168.64.0 24 192.168.212.161
[RouterB] ip route-static 192.168.74.0 24 192.168.212.161
[RouterB] ip route-static 192.168.99.0 24 192.168.212.161
3. Configure OSPF between Router B and Router C and configure OSPF on Router B to redistribute static routes:
# Configure OSPF to advertise the local network and enable OSPF to redistribute static routes on Router B.
[RouterB] ospf
[RouterB-ospf-1-area-0.0.0.0] network 172.17.100.0 0.0.0.255
[RouterB-ospf-1] import-route static
# Configure OSPF to advertise local networks on Router C.
[RouterC] ospf
[RouterC-ospf-1-area-0.0.0.0] network 172.17.100.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 10.220.2.0 0.0.0.255
# Display the IP routing table on Router C.
[RouterC] display ip routing-table protocol ospf
Summary count : 5
Summary count : 3
192.168.64.0/24 O_ASE2 150 1 172.17.100.1 GE1/0/1
192.168.74.0/24 O_ASE2 150 1 172.17.100.1 GE1/0/1
192.168.99.0/24 O_ASE2 150 1 172.17.100.1 GE1/0/1
Summary count : 2
10.220.2.0/24 O_INTRA 10 1 10.220.2.16 GE1/0/2
172.17.100.0/24 O_INTRA 10 1 172.17.100.2 GE1/0/1
The output shows that Router C has learned routes to 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 through OSPF.
4. Configure BGP between Router C and Router D and configure BGP on Router C to redistribute OSPF routes:
# On Router C, enable BGP, specify Router D as an EBGP peer, and configure BGP to redistribute OSPF routes.
[RouterC] bgp 65106
[RouterC-bgp-default] peer 10.220.2.217 as-number 64631
[RouterC-bgp-default-ipv4] peer 10.220.2.217 enable
[RouterC-bgp-default-ipv4] import-route ospf
# Enable BGP, and configure Router C as an EBGP peer on Router D.
[RouterD] bgp 64631
[RouterD-bgp-default] peer 10.220.2.16 as-number 65106
[RouterD-bgp-default] address-family ipv4 unicast
[RouterD-bgp-default-ipv4] peer 10.220.2.16 enable
[RouterD-bgp-default-ipv4] quit
[RouterD-bgp-default] quit
# Display routing table information on Router D.
[RouterD] display ip routing-table protocol bgp
Summary count : 3
Summary count : 3
192.168.64.0/24 BGP 255 1 10.220.2.16 GE1/0/1
192.168.74.0/24 BGP 255 1 10.220.2.16 GE1/0/1
192.168.99.0/24 BGP 255 1 10.220.2.16 GE1/0/1
Summary count : 0
The output shows that Router D has learned routes to 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 through BGP.
# Ping the hosts on networks 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 from Router D. The ping operations succeed.
5. Configure route summarization on Router C to summarize 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 into a single route 192.168.64.0/18, and disable advertisement of specific routes.
[RouterC-bgp-default-ipv4] aggregate 192.168.64.0 18 detail-suppressed
# Display IP routing table information on Router C.
[RouterC] display ip routing-table | include 192.168
192.168.64.0/18 BGP 130 0 127.0.0.1 NULL0
The output shows that Router C has a summary route 192.168.64.0/18 with the output interface Null 0.
# Display the IP routing table information on Router D.
Summary count : 1
Summary count : 1
192.168.64.0/18 BGP 255 0 10.220.2.16 GE1/0/1
Summary count : 0
The output shows that Router D has only one route 192.168.64.0/18 to AS 65106.
# Verify that Router D can ping the hosts on subnets 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24. (Details not shown.)
Example: Configuring multicast BGP
As shown in Figure 17, OSPF runs within AS 100 and AS 200 to ensure intra-AS connectivity. MBGP runs between the two ASs to exchange IPv4 unicast routes used for RPF check.
· Configure the Loopback 0 interface of Router A and Router B as the C-BSR and C-RP.
· Configure Router A and Router B to establish a Multicast Source Discovery Protocol (MSDP) peer relationship through MBGP, so that the receiver can receive multicast traffic from the source.
Device |
IP address |
Device |
IP address |
Source |
N/A |
10.110.1.100/24 |
Router C |
GE1/0/1 |
10.110.2.1/24 |
Router A |
GE1/0/1 |
10.110.1.1/24 |
GE1/0/2 |
192.168.2.2/24 |
GE1/0/2 |
192.168.1.1/24 |
GE1/0/3 |
192.168.4.1/24 |
Loop0 |
1.1.1.1/32 |
Loop0 |
3.3.3.3/32 |
Router B |
GE1/0/1 |
192.168.1.2/24 |
Router D |
GE1/0/1 |
192.168.3.2/24 |
GE1/0/2 |
192.168.3.1/24 |
GE1/0/2 |
192.168.4.2/24 |
GE1/0/3 |
192.168.2.1/24 |
Loop0 |
4.4.4.4/32 |
Loop0 |
2.2.2.2/32 |
1. Configure IP addresses for interfaces and configure OSPF (this example uses OSPF process 1) in AS 200 to ensure intra-AS connectivity. (Details not shown.)
2. Enable IP multicast routing, PIM-SM, and IGMP, and configure BSR boundaries:
# On Router A, enable multicast routing globally, and enable PIM-SM on interfaces.
[RouterA] multicast routing
[RouterA-mrib] quit
[RouterA-GigabitEthernet1/0/1] pim sm
[RouterA-GigabitEthernet1/0/2] pim sm
# Configure Router B and Router D in the same way that Router A was configured.
# On Router C, enable multicast routing globally.
[RouterC] multicast routing
[RouterC-mrib] quit
# Enable PIM-SM on interfaces, and enable IGMP on GigabitEthernet 1/0/1.
[RouterC-GigabitEthernet1/0/2] pim sm
[RouterC] interface gigabitethernet 1/0/3
[RouterC-GigabitEthernet1/0/3] pim sm
[RouterC-GigabitEthernet1/0/3] quit
[RouterC-GigabitEthernet1/0/1] pim sm
[RouterC-GigabitEthernet1/0/1] igmp enable
# Configure the BSR boundary on Router A.
[RouterA-GigabitEthernet1/0/2] pim bsr-boundary
# Configure the BSR boundary on Router B.
[RouterB-GigabitEthernet1/0/1] pim bsr-boundary
3. Configure Loopback 0, C-BSR, and C-RP:
# Configure the Loopback 0 interface and specify it as the C-BSR and C-RP on Router A.
[RouterA-LoopBack0] ip address 1.1.1.1 32
[RouterA-LoopBack0] pim sm
[RouterA-LoopBack0] quit
[RouterA] pim
[RouterA-pim] c-bsr 1.1.1.1
[RouterA-pim] c-rp 1.1.1.1
[RouterA-pim] quit
# Configure the Loopback 0 interface and specify it as the C-BSR and C-RP on Router B.
[RouterB-LoopBack0] ip address 2.2.2.2 32
[RouterB-LoopBack0] pim sm
[RouterB-LoopBack0] quit
[RouterB] pim
[RouterB-pim] c-bsr 2.2.2.2
[RouterB-pim] c-rp 2.2.2.2
[RouterB-pim] quit
4. Configure BGP to establish BGP IPv4 multicast peers and redistribute routes:
# On Router A, establish an EBGP session to Router B.
[RouterA] bgp 100
[RouterA-bgp-default] peer 192.168.1.2 as-number 200
# Enable exchange of IPv4 unicast routes used for RPF check with Router B.
[RouterA-bgp-default] address-family ipv4 multicast
[RouterA-bgp-default-mul-ipv4] peer 192.168.1.2 enable
# Redistribute direct routes into BGP.
[RouterA-bgp-default-mul-ipv4] import-route direct
[RouterA-bgp-default-mul-ipv4] quit
# On Router B, establish an EBGP session to Router A.
[RouterB] bgp 200
[RouterB-bgp-default] peer 192.168.1.1 as-number 100
[RouterB-bgp-default] address-family ipv4 multicast
[RouterB-bgp-default-mul-ipv4] peer 192.168.1.1 enable
# Redistribute OSPF routes into BGP.
[RouterB-bgp-default-mul-ipv4] import-route ospf 1
[RouterB-bgp-default-mul-ipv4] quit
5. Configure MSDP peers:
# Configure an MSDP peer on Router A.
[RouterA] msdp
[RouterA-msdp] peer 192.168.1.2 connect-interface gigabitethernet 1/0/2
[RouterA-msdp] quit
# Configure an MSDP peer on Router B.
[RouterB] msdp
[RouterB-msdp] peer 192.168.1.1 connect-interface gigabitethernet 1/0/1
[RouterB-msdp] quit
# Verify the BGP IPv4 multicast peer information on Router B.
[RouterB] display bgp peer ipv4 multicast
192.168.1.1 100 56 56 0 0 00:40:54 Established
# Verify the MSDP peer information on Router B.
[RouterB] display msdp brief
Configured Established Listen Connect Shutdown Disabled
1 1 0 0 0 0
Peer address State Up/Down time AS SA count Reset count
192.168.1.1 Established 00:07:17 100 1 0
Basic IPv6 BGP network configuration examples
Example: Configuring IPv6 BGP basics
As shown in Figure 18, all routers run BGP. Run EBGP between Router A and Router B, and run IBGP between Router B and Router C to allow Router C to access network 50::/64 connected to Router A.
2. Configure IBGP:
[RouterB] bgp 65009
[RouterB-bgp-default] peer 9::2 as-number 65009
[RouterB-bgp-default] address-family ipv6
[RouterB-bgp-default-ipv6] peer 9::2 enable
[RouterB-bgp-default-ipv6] quit
[RouterC] bgp 65009
[RouterC-bgp-default] peer 9::1 as-number 65009
[RouterC-bgp-default] address-family ipv6
[RouterC-bgp-default-ipv6] peer 9::1 enable
3. Configure EBGP:
[RouterA] bgp 65008
[RouterA-bgp-default] peer 10::1 as-number 65009
[RouterA-bgp-default] address-family ipv6
[RouterA-bgp-default-ipv6] peer 10::1 enable
[RouterB-bgp-default] peer 10::2 as-number 65008
[RouterB-bgp-default-ipv6] peer 10::2 enable
4. Inject network routes to the BGP routing table:
[RouterA-bgp-default-ipv6] network 10:: 64
[RouterA-bgp-default-ipv6] network 50:: 64
[RouterA-bgp-default-ipv6] quit
[RouterB-bgp-default-ipv6] network 10:: 64
[RouterB-bgp-default-ipv6] network 9:: 64
[RouterC-bgp-default-ipv6] network 9:: 64
[RouterC-bgp-default-ipv6] quit
# Display IPv6 BGP peer information on Router B.
[RouterB] display bgp peer ipv6
BGP local router ID: 2.2.2.2
Local AS number: 65009
Total number of peers: 2 Peers in established state: 2
9::2 65009 41 43 0 1 00:29:00 Established
10::2 65008 38 38 0 2 00:27:20 Established
The output shows that Router A and Router B have established an EBGP connection, and Router B and Router C have established an IBGP connection.
# Display IPv6 BGP routing table information on Router A.
[RouterA] display bgp routing-table ipv6
a – additional-path
* >e Network : 9:: PrefixLen : 64
NextHop : 10::1 LocPrf :
PrefVal : 0 OutLabel : NULL
MED : 0
Path/Ogn: 65009i
* > Network : 10:: PrefixLen : 64
NextHop : :: LocPrf :
MED : 0
Path/Ogn: i
* e Network : 10:: PrefixLen : 64
MED : 0
Path/Ogn: 65009i
* > Network : 50:: PrefixLen : 64
MED : 0
Path/Ogn: i
The output shows that Router A has learned routing information of AS 65009.
# Display IPv6 BGP routing table information on Router C.
[RouterC] display bgp routing-table ipv6
a – additional-path
* > Network : 9:: PrefixLen : 64
MED : 0
Path/Ogn: i
* i Network : 9:: PrefixLen : 64
NextHop : 9::1 LocPrf : 100
MED : 0
Path/Ogn: i
* >i Network : 10:: PrefixLen : 64
MED : 0
Path/Ogn: i
* >i Network : 50:: PrefixLen : 64
NextHop : 10::2 LocPrf : 100
MED : 0
Path/Ogn: 65008i
The output shows that Router C has learned the route 50::/64.
# Verify that Router C can ping hosts on network 50::/64. (Details not shown.)
Example: Configuring IPv6 multicast BGP
As shown in Figure 19, OSPFv3 runs within AS 100 and AS 200 to ensure intra-AS connectivity. IPv6 MBGP runs between the two ASs to exchange IPv6 unicast routes used for RPF check.
Enable Anycast RP on Router A and Router B.
Table 3 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Source |
N/A |
1002::100/64 |
Router B |
GE1/0/1 |
1001::2/64 |
Router A |
GE1/0/1 |
1002::1/64 |
GE1/0/2 |
2002::1/64 |
GE1/0/2 |
1001::1/64 |
GE1/0/3 |
2001::1/64 |
Loop0 |
1:1::1/128 |
Loop0 |
1:1::1/128 |
Loop1 |
1:1::2/128 |
Loop1 |
2:2::2/128 |
Router C |
GE1/0/1 |
3002::1/64 |
Router D |
GE1/0/1 |
2002::2/64 |
GE1/0/2 |
2001::2/64 |
GE1/0/2 |
3001::2/64 |
GE1/0/3 |
3001::1/64 |
1. Configure IPv6 addresses for interfaces and configure OSPFv3 (this example uses OSPFv3 process 1) in AS 200 to ensure intra-AS connectivity. (Details not shown.)
2. Enable IPv6 multicast routing, IPv6 PIM-SM, and MLD, and configure BSR boundaries:
# On Router A, enable IPv6 multicast routing globally, and enable IPv6 PIM-SM on interfaces.
[RouterA-mrib6] quit
[RouterA-GigabitEthernet1/0/1] ipv6 pim sm
[RouterA-GigabitEthernet1/0/2] ipv6 pim sm
[RouterA-LoopBack0] ipv6 pim sm
# On Router C, enable IPv6 multicast routing globally.
[RouterC] ipv6 multicast routing
[RouterC-mrib6] quit
# Enable IPv6 PIM-SM on interfaces, and enable MLD on GigabitEthernet 1/0/1.
[RouterC-GigabitEthernet1/0/2] ipv6 pim sm
[RouterC-GigabitEthernet1/0/3] ipv6 pim sm
[RouterC-GigabitEthernet1/0/1] ipv6 pim sm
[RouterC-GigabitEthernet1/0/1] mld enable
[RouterA-GigabitEthernet1/0/2] ipv6 pim bsr-boundary
[RouterB-GigabitEthernet1/0/1] ipv6 pim bsr-boundary
3. Enable Anycast RP, and specify C-BSR and C-RP:
[RouterA] ipv6 pim
[RouterA-pim6] anycast-rp 1:1::1 1:1::2
[RouterA-pim6] anycast-rp 1:1::1 2:2::2
[RouterA-pim6] c-bsr 1:1::1
[RouterA-pim6] c-rp 1:1::1
[RouterA-pim6] quit
[RouterB] ipv6 pim
[RouterB-pim6] anycast-rp 1:1::1 1:1::2
[RouterB-pim6] anycast-rp 1:1::1 2:2::2
[RouterB-pim6] c-bsr 1:1::1
[RouterB-pim6] c-rp 1:1::1
[RouterB-pim6] quit
4. Configure BGP to establish BGP IPv6 multicast peers and redistribute routes:
[RouterA] bgp 100
[RouterA-bgp-default] peer 1001::2 as-number 200
# Enable exchange of IPv6 unicast routes used for RPF check with Router B.
[RouterA-bgp-default] address-family ipv6 multicast
[RouterA-bgp-default-mul-ipv6] peer 1001::2 enable
[RouterA-bgp-default-mul-ipv6] import-route direct
[RouterA-bgp-default-mul-ipv6] quit
[RouterB] bgp 200
[RouterB-bgp-default] peer 1001::1 as-number 100
[RouterB-bgp-default] address-family ipv6 multicast
[RouterB-bgp-default-mul-ipv6] peer 1001::1 enable
# Redistribute OSPFv3 routes into BGP.
[RouterB-bgp-default-mul-ipv6] import-route ospfv3 1
[RouterB-bgp-default-mul-ipv6] quit
5. Establish BGP IPv6 unicast peer relationships between Router A and Router B and redistribute routes:
# On Router A, enable BGP to exchange IPv6 unicast routes with Router B, and redistribute direct routes into BGP.
[RouterA-bgp-default] address-family ipv6 unicast
[RouterA-bgp-default-ipv6] peer 1001::2 enable
[RouterA-bgp-default-ipv6] import-route direct
# On Router B, enable BGP to exchange IPv6 unicast routes with Router A, and redistribute direct routes into BGP.
[RouterB-bgp-default] address-family ipv6 unicast
[RouterB-bgp-default-ipv6] peer 1001::1 enable
[RouterB-bgp-default-ipv6] import-route direct
# Verify the BGP IPv6 multicast peer information on Router B.
[RouterB] display bgp peer ipv6 multicast
1001::1 100 56 56 0 0 00:40:54 Established
# Verify the RPF information for the multicast source on Router B.
[RouterB] display ipv6 multicast rpf-info 1002::1
RPF information about source 1002::1:
RPF interface: GE1/0/1, RPF neighbor: 1001::1
Referenced prefix/prefix length: 1002::/64
Referenced route type: mbgp
Load splitting rule: disable
Troubleshooting BGP
State of the connection to a peer cannot become established
Symptom
The display bgp peer ipv4 unicast or display bgp peer ipv6 unicast command output shows that the state of the connection to a peer cannot become established.
Analysis
To become BGP peers, any two routers must establish a TCP connection using port 179 and exchange OPEN messages successfully.
Solution
1. To resolve the issue:
a. Use the display current-configuration command to verify the current configuration, and verify that the peer's AS number is correct.
b. Use the display bgp peer ipv4 unicast or display bgp peer ipv6 unicast command to verify that the peer's IP/IPv6 address is correct.
c. If a loopback interface is used, verify that the loopback interface is specified with the peer connect-interface command.
d. If the peer is a non-direct EBGP peer, verify that the peer ebgp-max-hop command is configured.
e. If the peer ttl-security hops command is configured, verify that the command is configured on the peer. Verify that the hop-count values configured on them are greater than the number of hops between them.
f. Verify that a valid route to the peer is available.
g. Use the ping command to verify the connectivity to the peer.
h. Use the display tcp verbose or display ipv6 tcp verbose command to verify the TCP connection.
i. Verify that no ACL rule is applied to disable TCP port 179.
2. If the issue persists, contact H3C Support.
Configuring large-scale BGP networks
Large-scale BGP network configuration tasks at a glance
To configure large-scale BGP networks, perform the following tasks:
· Configuring BGP route dampening
· Configuring BGP route reflection
· Configuring BGP confederation settings
¡ Configuring a BGP confederation
¡ (Optional.) Configuring confederation compatibility
Route dampening enables BGP to not select unstable routes as optimal routes.
This feature applies to EBGP routes but not to IBGP routes.
If an EBGP peer goes down after you configure this feature, routes coming from the peer are dampened but not deleted.
After an active/standby switchover, BGP route dampening processes and information will be reset. The device needs to recalculate the dampening mechanism of BGP routes.
Procedure (IPv4 unicast/multicast address family)
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv4 multicast address family view:
3. Configure BGP route dampening.
By default, BGP route dampening is not configured.
Procedure (IPv6 unicast/multicast address family)
2. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP IPv6 multicast address family view:
3. Configure IPv6 BGP route dampening.
By default, IPv6 BGP route dampening is not configured.
Configuring BGP communities
By default, a router does not advertise the COMMUNITY or extended community attribute to its peers or peer groups. When the router receives a route carrying the COMMUNITY or extended community attribute, it removes the attribute before advertising the route to other peers or peer groups.
Perform this task to enable a router to advertise the COMMUNITY or extended community attribute to its peers for route filtering and control. You can also use a routing policy to add or modify the COMMUNITY or extended community attribute for specific routes. For more information about routing policy, see "Configuring routing policies."
2. Create a routing policy and a node, and enter routing policy node view.
For more information about this command, see routing policy commands in Layer 3—IP Routing Command Reference.
3. (Optional.) Configure if-match clauses as BGP route match criteria.
The routing policy can configure the COMMUNITY attribute of BGP routes only when these routes match a permit node.
For more information about if-match clauses, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
4. Configure the COMMUNITY attribute and extended community attribute of BGP routes.
¡ Set the COMMUNITY attribute for BGP routes.
¡ Delete COMMUNITY attribute values from BGP routes.
By default, no COMMUNITY attribute value is deleted from BGP routes.
¡ Set the link bandwidth or RT extended community attribute for BGP routes.
apply extcommunity { bandwidth link-bandwidth-value | { rt route-target }&<1-32> } [ additive ]
¡ Set the color extended community attribute for BGP routes.
apply extcommunity color color [ additive ]
¡ Set the SoO extended community attribute for BGP routes.
For more information about these commands, see routing policy commands in Layer 3—IP Routing Command Reference.
5. Return to system view.
6. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
7. Advertise the COMMUNITY attribute to a peer or peer group.
By default, the COMMUNITY attribute is not advertised.
The ipv6-address [ prefix-length ] argument is not supported in BGP IPv4 multicast address family view.
8. Advertise the extended community attribute to a peer or peer group.
By default, the extended community attribute is not advertised.
9. (Optional.) Apply a routing policy to routes advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name export
By default, no routing policy is applied.
6. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
The ipv4-address [ mask-length ] argument is not supported in BGP IPv6 multicast address family view.
9. Apply a routing policy to routes advertised to a peer or peer group.
Configuring a BGP route reflector
Perform this task to configure a BGP route reflector and its clients. The route reflector and its clients automatically form a cluster identified by the router ID of the route reflector. The route reflector forwards route updates among its clients.
To improve availability, you can specify multiple route reflectors for a cluster. The route reflectors in the cluster must have the same cluster ID to avoid routing loops.
When a route reflector connects to multiple clusters, you can configure different cluster IDs for different peers or peer groups.
You only need to configure BGP route reflection on the device that acts as a route reflector. Other devices do not need to know the role of the local device in route reflection.
After you configure a device as a route reflector, it advertises routes as follows:
· Advertises routes received from a non-client IBGP peer to all clients.
· Advertises routes received from an IBGP peer that acts as a client to all peers.
· Advertises routes received from an EBGP peer to all peers.
If you do not configure the peer cluster-id command for a peer or peer group, the peer or peer group uses the cluster ID configured by the reflector cluster-id command.
For a peer or peer group, the cluster ID configured by the peer cluster-id command takes precedence over the cluster ID configured by the reflector cluster-id command.
By default, the route reflector does not change the attributes of routes before route reflection to avoid routing loops. When you replan network traffic, you can perform this task to allow the route reflector to change the attributes of the routes to be reflected.
After using the reflect change-path-attribute command, you can use the peer route-policy export command to apply a routing policy that can change the attributes of the routes to be reflected. The following apply commands can define how the routing policy modifies route attributes:
· Use apply origin to change the ORIGIN attribute of routes.
· Use apply ip-address next-hop or apply ipv6 next-hop to change the NEXT_HOP attribute of routes.
· Use apply cost to change the MED attribute of routes.
· Use apply local-preference to change the local preference for routes.
· Use apply community to configure the COMMUNITY attribute of routes. For BGP to advertise the COMMUNITY attribute to a peer or peer group, use the peer advertise-community command.
· Use apply comm-list delete to delete COMMUNITY attribute values from routes.
· Use apply extcommunity to configure the link bandwidth or RT extended community attribute of routes. For BGP to advertise extended COMMUNITY attributes to a peer or peer group, use the peer advertise-ext-community command.
· Use apply extcommunity color to configure the color extended community attribute of routes.
· Use apply extcommunity soo to configure the SoO extended community attribute of routes.
· Use apply aigp to configure the AIGP attribute for BGP routes. For BGP to advertise the AIGP attribute to a peer or peer group, use the peer aigp command.
For more information about the apply commands, see routing policy commands in Layer 3—IP Routing Command Reference.
2. Enter BGP instance view or BGP-VPN instance view.
¡ Enter BGP instance view.
¡ Execute the following commands in sequence to enter BGP-VPN instance view:
3. Configure the cluster ID of the route reflector for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } cluster-id cluster-id
By default, the cluster ID of the route reflector is not configured for a peer or peer group.
4. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
This command is available only in BGP instance view.
5. Configure the router as a route reflector and specify a peer or peer group as its client.
By default, no route reflector or client is configured.
6. (Optional.) Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
7. (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its own router ID as the cluster ID.
8. (Optional.) Enable the route reflector to change the attributes of routes to be reflected.
By default, the route reflector cannot change the attributes of routes to be reflected.
peer { group-name | ipv6-address [ prefix-length ] } cluster-id cluster-id
4. Enter BGP IPv6 unicast address family view or BGP IPv6 multicast address family view.
¡ Execute the following commands in sequence to execute the following commands in sequence to enter BGP IPv6 unicast address family view:
¡ Execute the following commands in sequence to execute the following commands in sequence to enter BGP IPv6 multicast address family view:
Ignoring the ORIGINATOR_ID attribute
By default, BGP drops incoming route updates whose ORIGINATOR_ID attribute is the same as the local router ID. Some special networks such as firewall networks require BGP to accept such route updates. To meet the requirement, you must configure BGP to ignore the ORIGINATOR_ID attribute.
Make sure this command does not result in a routing loop.
After you execute this command, BGP also ignores the CLUSTER_LIST attribute.
Procedure (IPv4 peers)
¡ Execute the following commands in sequence to enter BGP-VPN instance view.
3. Ignore the ORIGINATOR_ID attribute.
By default, BGP does not ignore the ORIGINATOR_ID attribute.
Procedure (IPv6 peers)
peer { group-name | ipv6-address [ prefix-length ] } ignore-originatorid
About BGP confederation
BGP confederation provides another way to reduce IBGP connections in an AS.
A confederation contains sub-ASs. In each sub-AS, IBGP peers are fully meshed. Sub-ASs establish EBGP connections in between.
2. Enter BGP instance view.
3. Configure a confederation ID.
confederation id as-number
By default, no confederation ID is configured.
From an outsider's perspective, the sub-ASs of the confederation is a single AS, which is identified by the confederation ID.
4. Specify confederation peer sub-ASs in the confederation.
By default, no confederation peer sub-ASs are specified.
A confederation can contain a maximum of 32 sub-ASs. The AS number of a sub-AS is effective only in the confederation.
If the router needs to establish EBGP connections to other sub-ASs, you must specify the peering sub-ASs in the confederation.
If any routers in the confederation do not comply with RFC 3065, enable confederation compatibility to allow the router to work with those routers.
3. Enable confederation compatibility.
confederation nonstandard
By default, confederation compatibility is disabled.
Verifying and maintaining large-scale BGP network configuration
· Display BGP IPv4 unicast route dampening parameter information.
display bgp [ instance instance-name ] dampening parameter ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ ipv6-address prefix-length | ipv6-address log-info | [ ipv6-address ] verbose ]
· Display dampened BGP IPv4 unicast route information.
display bgp [ instance instance-name ] routing-table dampened ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
· Display BGP IPv6 unicast route dampening parameter information.
display bgp [ instance instance-name ] dampening parameter ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
· Display information about a peer or peer group information in BGP IPv6 unicast address family.
· Display dampened BGP IPv6 unicast route information.
display bgp [ instance instance-name ] routing-table dampened ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
· Display dampened BGP IPv4 multicast route information.
display bgp [ instance instance-name ] routing-table dampened ipv4 multicast
· Display BGP IPv4 multicast route dampening parameter information.
display bgp [ instance instance-name ] dampening parameter ipv4 multicast
· Display dampened BGP IPv6 multicast route information.
display bgp [ instance instance-name ] routing-table dampened ipv6 multicast
· Display BGP IPv6 multicast route dampening parameter information.
display bgp [ instance instance-name ] dampening parameter ipv6 multicast
Large-scale BGP network configuration examples
Example: Configuring BGP communities
As shown in Figure 20, Router B establishes EBGP connections to Router A and Router C. Configure NO_EXPORT community attribute on Router A so that AS 20 does not advertise routes received from AS 10 to any other AS.
2. Configure EBGP connections:
[RouterA] bgp 10
[RouterA-bgp-default] peer 200.1.2.2 as-number 20
[RouterA-bgp-default-ipv4] peer 200.1.2.2 enable
[RouterA-bgp-default-ipv4] network 9.1.1.0 255.255.255.0
[RouterB] bgp 20
[RouterB-bgp-default] peer 200.1.2.1 as-number 10
[RouterB-bgp-default] peer 200.1.3.2 as-number 30
[RouterB-bgp-default-ipv4] peer 200.1.2.1 enable
[RouterB-bgp-default-ipv4] peer 200.1.3.2 enable
[RouterC] bgp 30
[RouterC-bgp-default] peer 200.1.3.1 as-number 20
[RouterC-bgp-default-ipv4] peer 200.1.3.1 enable
# Display the BGP route 9.1.1.0 on Router B.
[RouterB] display bgp routing-table ipv4 9.1.1.0
Local AS number: 20
Paths: 1 available, 1 best
Rely nexthop : 200.1.2.1
Original nexthop: 200.1.2.1
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 10
Origin : igp
Attribute value : pref-val 0
State : valid, external, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
VPN-Peer UserID : N/A
DSCP : N/A
EXP : N/A
# Display advertisement information for the route 9.1.1.0 on Router B.
[RouterB] display bgp routing-table ipv4 9.1.1.0 advertise-info
Local AS number: 20
Paths: 1 best
200.1.3.2
The output shows that Router B can advertise the route with the destination 9.1.1.0/24 to other ASs through BGP.
a – additional-path
* >e 9.1.1.0/24 200.1.3.1 0 20 10i
Router C has learned the route to the destination 9.1.1.0/24 from Router B.
3. Configure the BGP COMMUNITY attribute:
# Configure a routing policy.
[RouterA] route-policy comm_policy permit node 0
[RouterA-route-policy-comm_policy-0] apply community no-export
[RouterA-route-policy-comm_policy-0] quit
# Apply the routing policy.
[RouterA] bgp 10
[RouterA-bgp-default-ipv4] peer 200.1.2.2 route-policy comm_policy export
[RouterA-bgp-default-ipv4] peer 200.1.2.2 advertise-community
Local AS number: 20
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
Community : No-Export
AS-path : 10
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
DSCP : N/A
EXP : N/A
Local AS number: 20
Paths: 1 best
Total number of routes: 0
The output shows that BGP has not learned any route.
Example: Configuring BGP route reflector
As shown in Figure 21, all routers run BGP. Run EBGP between Router A and Router B, run IBGP between Router C and Router B, and between Router C and Router D.
Configure Router C as a route reflector with clients Router B and D to allow Router D to learn route 20.0.0.0/8 from Router C.
1. Configure IP addresses for interfaces and configure OSPF in AS 200. (Details not shown.)
2. Configure BGP connections:
[RouterA] bgp 100
[RouterA-bgp-default] peer 192.1.1.2 as-number 200
[RouterA-bgp-default-ipv4] peer 192.1.1.2 enable
# Inject network 20.0.0.0/8 to the BGP routing table.
[RouterA-bgp-default-ipv4] network 20.0.0.0
[RouterB] bgp 200
[RouterB-bgp-default] peer 192.1.1.1 as-number 100
[RouterB-bgp-default] peer 193.1.1.1 as-number 200
[RouterB-bgp-default-ipv4] peer 192.1.1.1 enable
[RouterB-bgp-default-ipv4] peer 193.1.1.1 enable
[RouterB-bgp-default-ipv4] peer 193.1.1.1 next-hop-local
[RouterC] bgp 200
[RouterC-bgp-default] peer 193.1.1.2 as-number 200
[RouterC-bgp-default] peer 194.1.1.2 as-number 200
[RouterC-bgp-default-ipv4] peer 193.1.1.2 enable
[RouterC-bgp-default-ipv4] peer 194.1.1.2 enable
# Configure Router D.
[RouterD] bgp 200
[RouterD-bgp-default] peer 194.1.1.1 as-number 200
[RouterD-bgp-default-ipv4] peer 194.1.1.1 enable
3. Configure Router C as the route reflector.
[RouterC] bgp 200
[RouterC-bgp-default-ipv4] peer 193.1.1.2 reflect-client
[RouterC-bgp-default-ipv4] peer 194.1.1.2 reflect-client
a – additional-path
* >e 20.0.0.0/8 192.1.1.1 0 0 100i
# Display the BGP routing table on Router D.
[RouterD] display bgp routing-table ipv4
a – additional-path
* >i 20.0.0.0/8 193.1.1.2 0 100 0 100i
The output shows that Router D has learned the route 20.0.0.0/8 from Router C.
Example: Configuring BGP confederation
As shown in Figure 22, split AS 200 into three sub-ASs (AS 65001, AS 65002, and AS 65003) to reduce IBGP connections. Routers in AS 65001 are fully meshed.
Table 4 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
GE1/0/1 |
10.1.2.1/24 |
Router D |
GE1/0/1 |
10.1.5.1/24 |
GE1/0/2 |
10.1.3.1/24 |
GE1/0/2 |
10.1.3.2/24 |
GE1/0/3 |
10.1.4.1/24 |
Router E |
GE1/0/1 |
10.1.5.2/24 |
GE1/0/4 |
200.1.1.1/24 |
GE1/0/2 |
10.1.4.2/24 |
GE1/0/5 |
10.1.1.1/24 |
Router F |
GE1/0/1 |
9.1.1.1/24 |
Router B |
GE1/0/1 |
10.1.1.2/24 |
GE1/0/2 |
200.1.1.2/24 |
Router C |
GE1/0/1 |
10.1.2.2/24 |
2. Configure the BGP confederation:
[RouterA] bgp 65001
[RouterA-bgp-default] confederation id 200
[RouterA-bgp-default] confederation peer-as 65002 65003
[RouterA-bgp-default] peer 10.1.1.2 as-number 65002
[RouterA-bgp-default] peer 10.1.2.2 as-number 65003
[RouterA-bgp-default-ipv4] peer 10.1.1.2 enable
[RouterA-bgp-default-ipv4] peer 10.1.2.2 enable
[RouterA-bgp-default-ipv4] peer 10.1.1.2 next-hop-local
[RouterA-bgp-default-ipv4] peer 10.1.2.2 next-hop-local
[RouterB] bgp 65002
[RouterB-bgp-default] confederation id 200
[RouterB-bgp-default] confederation peer-as 65001 65003
[RouterB-bgp-default] peer 10.1.1.1 as-number 65001
[RouterC] bgp 65003
[RouterC-bgp-default] confederation id 200
[RouterC-bgp-default] confederation peer-as 65001 65002
[RouterC-bgp-default] peer 10.1.2.1 as-number 65001
3. Configure IBGP connections in AS65001:
[RouterA] bgp 65001
[RouterA-bgp-default] peer 10.1.3.2 as-number 65001
[RouterA-bgp-default] peer 10.1.4.2 as-number 65001
[RouterA-bgp-default-ipv4] peer 10.1.3.2 enable
[RouterA-bgp-default-ipv4] peer 10.1.4.2 enable
[RouterA-bgp-default-ipv4] peer 10.1.3.2 next-hop-local
[RouterA-bgp-default-ipv4] peer 10.1.4.2 next-hop-local
[RouterD] bgp 65001
[RouterD-bgp-default] confederation id 200
[RouterD-bgp-default] peer 10.1.3.1 as-number 65001
[RouterD-bgp-default] peer 10.1.5.2 as-number 65001
[RouterD-bgp-default-ipv4] peer 10.1.5.2 enable
# Configure Router E.
<RouterE> system-view
[RouterE] bgp 65001
[RouterE-bgp-default] router-id 5.5.5.5
[RouterE-bgp-default] confederation id 200
[RouterE-bgp-default] peer 10.1.4.1 as-number 65001
[RouterE-bgp-default] peer 10.1.5.1 as-number 65001
[RouterE-bgp-default] address-family ipv4 unicast
[RouterE-bgp-default-ipv4] peer 10.1.4.1 enable
[RouterE-bgp-default-ipv4] peer 10.1.5.1 enable
[RouterE-bgp-default-ipv4] quit
[RouterE-bgp-default] quit
4. Configure the EBGP connection between AS 100 and AS 200:
[RouterA] bgp 65001
[RouterA-bgp-default] peer 200.1.1.2 as-number 100
[RouterA-bgp-default-ipv4] peer 200.1.1.2 enable
# Configure Router F.
<RouterF> system-view
[RouterF] bgp 100
[RouterF-bgp-default] router-id 6.6.6.6
[RouterF-bgp-default] peer 200.1.1.1 as-number 200
[RouterF-bgp-default] address-family ipv4 unicast
[RouterF-bgp-default-ipv4] peer 200.1.1.1 enable
[RouterF-bgp-default-ipv4] network 9.1.1.0 255.255.255.0
[RouterF-bgp-default-ipv4] quit
[RouterF-bgp-default] quit
a – additional-path
* >i 9.1.1.0/24 10.1.1.1 0 100 0 (65001)
100i
Local AS number: 65002
Rely nexthop : 10.1.1.1
Original nexthop: 10.1.1.1
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : (65001) 100
Origin : igp
State : valid, external-confed, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
DSCP : N/A
EXP : N/A
a – additional-path
* >i 9.1.1.0/24 10.1.3.1 0 100 0 100i
[RouterD] display bgp routing-table ipv4 9.1.1.0
BGP local router ID: 4.4.4.4
Local AS number: 65001
Rely nexthop : 10.1.3.1
Original nexthop: 10.1.3.1
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 100
Origin : igp
State : valid, internal-confed, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
DSCP : N/A
EXP : N/A
· Router F can send route information to Router B and Router C through the confederation by establishing only an EBGP connection with Router A.
· Router B and Router D are in the same confederation, but belong to different sub-ASs. They obtain external route information from Router A and generate identical BGP route entries although they have no direct connection in between.
Controlling BGP path selection
BGP path selection control tasks at a glance
By configuring BGP path attributes, you can control BGP path selection.
To control BGP path selection, perform the following tasks:
1. Configuring preferences for BGP routes
2. Configuring the NEXT_HOP attribute
¡ Setting the local device IP as the next hop
¡ Disabling nexthop changing for routes advertised to a peer or peer group
¡ Advertising only the global unicast address in the NEXT_HOP attribute
3. Setting a preferred value for received routes
4. Configuring the default local preference
5. Configuring the AS_PATH attribute
¡ Permitting local AS number to appear in routes from a peer or peer group
¡ Ignoring the AS_PATH attribute during optimal route selection
¡ Advertising a fake AS number to a peer or peer group
¡ Configuring AS number substitution
¡ Removing/replacing private AS numbers in BGP updates
¡ Ignoring the first AS number of EBGP route updates
¡ Setting an AS number quantity threshold
6. Configuring the MED attribute
¡ Configuring the default MED value
¡ Enabling MED comparison for routes from different ASs
¡ Enabling MED comparison for routes on a per-AS basis
¡ Enabling MED comparison for routes from confederation peers
¡ Enabling BGP to use the MED and IGP metric together for optimal route selection
7. Configuring the link bandwidth attribute
8. Minimizing the priority of BGP routes advertised to peers
¡ Minimizing the priority of BGP routes advertised to peers with a DOWN-to-UP state change
¡ Minimizing the priority of BGP routes advertised to peers after a device reboot
¡ Restoring the priority of advertised BGP routes
9. Preferring routes learned from a peer or peer group during optimal route selection
10. Configuring the AIGP attribute
11. Ignoring IGP metrics during optimal route selection
12. Ignoring router IDs during optimal route selection
13. Configuring the next hop type selection rule for optimal route selection
¡ Preferring BGP routes of a specific recursive next hop type during optimal route selection
14. Associating a track entry with a BGP peer or peer group
Routing protocols each have a default preference. If they find multiple routes destined for the same network, the route found by the routing protocol with the highest preference is selected as the optimal route. A smaller preference value indicates a higher preference.
You can use the preference command to modify preferences for EBGP, IBGP, and local BGP routes, or use a routing policy to set a preference for matching routes. For routes not matching the routing policy, the default preference applies.
If a device has an EBGP route and a local BGP route to reach the same destination, it does not select the EBGP route because the EBGP route has a lower preference than the local BGP route by default. You can use the network short-cut command to configure the EBGP route as a shortcut route that has the same preference as the local BGP route. The EBGP route will more likely become the optimal route.
1. Enter system view.
3. Configure preferences for EBGP, IBGP, and local BGP routes.
By default, the preferences for EBGP, IBGP, and local BGP routes are 255, 255, and 130, respectively.
4. (Optional.) Configure an EBGP route as a shortcut route.
By default, an EBGP route has a preference of 255.
By default, a BGP router does not set itself as the next hop for routes advertised to an IBGP peer or peer group. In some cases, however, you must configure the advertising router as the next hop to ensure that the BGP peer can find the correct next hop.
For example, as shown in Figure 23, Router A and Router B establish an EBGP neighbor relationship, and Router B and Router C establish an IBGP neighbor relationship. If Router C has no route destined for IP address 1.1.1.1/24, you must configure Router B to set itself 3.1.1.1/24 as the next hop for the network 2.1.1.1/24 advertised to Router C.
Figure 23 NEXT_HOP attribute configuration
If a BGP router has two peers on a broadcast network, it does not set itself as the next hop for routes sent to an EBGP peer by default. As shown in Figure 24, Router A and Router B establish an EBGP neighbor relationship, and Router B and Router C establish an IBGP neighbor relationship. They are on the same broadcast network 1.1.1.0/24. When Router B sends EBGP routes to Router A, it does not set itself as the next hop by default. However, you can configure Router B to set it (1.1.1.2/24) as the next hop for routes sent to Router A by using the peer next-hop-local command as needed.
Figure 24 NEXT_HOP attribute configuration
If you have configured BGP load balancing, the router sets itself as the next hop for routes sent to an IBGP peer or peer group regardless of whether the peer next-hop-local command is configured.
3. Specify the local device IP as the next hop for routes sent to a peer or peer group.
The default settings are as follows:
¡ When the device advertises a route to an EBGP peer, it processes the next hop of that route as follows:
- If the EBGP peer is a directly connected peer and the next hop of the route is in the same network as the peer-facing interface of the local device, the device does not change the next hop of the route.
- In other scenarios, the device sets the local device IP as the next hop of the route.
¡ The device does not change the next hops of routes sent to an IBGP peer or peer group. When the device sends ECMP BGP routes to IBGP peers, it sets the local device IP as the next hop of the optimal route among these routes.
This feature disables the device from changing the NEXT_HOP attribute of routes advertised to peers. It is applicable to the networks where the advertisement of default routes hampers that of other routes.
For example, on a multi-AS network, configure this feature for a device to disable it from changing the NEXT_HOP attribute of routes advertised to a peer or peer group in a different AS. As shown in Figure 25, PE1 and PE2 are located in different ASs. They communicate with each other through the public network and exchange BGP IPv4 and IPv6 routes. To ensure service scheduling, the next hop of routes on PE1 must be PE2 and the next hop of routes on PE2 must be PE1.
PE3 and PE4 runs on the backbone network. PE1 has established an EBGP relationship with PE3 and PE2 has established an EBGP relationship with PE4, which allows PE1 and PE2 to exchange routes. On the receipt of routes from PE1, PE3 will forward the routes to PE4. Then, PE4 will change the next hop of the routes before forwarding them to PE2. As a result, the next hop of the routes received by PE2 is not PE1. To resolve this issue, you can use the peer next-hop-invariable command to disable PE4 from changing the next hop of routes.
To ensure that directly-connected EBGP peers can receive routes from the device, be cautious when you configure this feature for these peers on the device. A directly-connected EBGP peers does not receive any route whose next hop is not in the same subnet as that of the peer.
To change the NEXT_HOP attribute of routes after configuring this feature, you can configure a BGP route distribution policy that includes a routing policy.
When the device advertises the redistributed routes to IBGP peers, it changes the NEXT_HOP attribute of these routes regardless of the configuration of this feature.
The following commands are mutually exclusive when you execute them for the same peer or peer group:
· peer next-hop-local
· peer next-hop-invariable
3. Disable the device from changing the NEXT_HOP attribute of routes advertised to a peer or peer group.
By default, the device sets its IP address as the next hop for all routes advertised to an EBGP peer or peer group. It does not set its IP address as the next hop for routes advertised to an IBGP peer or peer group. When the device sends equal-cost routes to IBGP peers, it sets its IP address as the next hop of the optimal route among these routes.
The ipv6-address [ prefix-length ] option is not supported in BGP IPv4 multicast address family view.
The ipv4-address [ mask-length ] option is not supported in BGP IPv6 multicast address family view.
With the undo nexthop global-address-only command configured, the device can advertise both the link-local address and the global unicast address in the NEXT_HOP attribute to direct IPv6 EBGP peers. A directly-connected IPv6 EBGP peer might fail to learn routes if it cannot parse a route update that contains both the link-local address and the global unicast address. To resolve this issue, perform this task to enable the local device to advertise only the global unicast address in the NEXT_HOP attribute to its IPv6 peers.
This feature might not apply to EBGP peers established through directly connected broadcast interfaces. If the next hop of the advertised route and the directly connected broadcast interfaces belong to the same subnet, this feature does not take effect.
Procedure (IPv4 unicast address family)
2. Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
3. Enable the device to advertise only the global unicast address in the NEXT_HOP attribute to its IPv6 peers.
By default, the device advertises only the global unicast address in the NEXT_HOP attribute to its IPv6 peers.
Perform this task to set a preferred value for specific routes to control BGP path selection.
Among multiple routes that have the same destination/mask and are learned from different peers, the one with the greatest preferred value is selected as the optimal route.
3. Set a preferred value for routes received from a peer or peer group.
By default, the preferred value is 0 for routes received from a peer or peer group.
The local preference is used to determine the optimal route for traffic leaving the local AS. When a BGP router obtains from several IBGP peers multiple routes to the same destination, but with different next hops, it selects the route with the highest local preference as the optimal route.
This task allows you to specify the default local preference for routes sent to IBGP peers.
3. Configure the default local preference.
The default local preference is 100.
In general, BGP checks whether the AS_PATH attribute of a route from a peer contains the local AS number. If yes, it discards the route to avoid routing loops.
In certain network environments (for example, a Hub&Spoke network in MPLS L3VPN), however, the AS_PATH attribute of a route from a peer must be allowed to contain the local AS number. Otherwise, the route cannot be advertised correctly.
3. Permit the local AS number to appear in routes from a peer or peer group and set the appearance times.
By default, the local AS number is not allowed in routes from a peer or peer group.
3. Configure BGP to ignore the AS_PATH attribute during optimal route selection.
bestroute as-path-neglect
By default, BGP includes the AS_PATH attribute in optimal route selection.
After you move a BGP router from an AS to another AS (from AS 2 to AS 3 for example), you have to modify the AS number of the router on all its EBGP peers. To avoid such modifications, you can configure the router to advertise a fake AS number 2 to its EBGP peers so that the EBGP peers still think that Router A is in AS 2.
When you configure the peer fake-as command, you can specify the following keywords:
· dual-as—Initiates session requests to a peer using the real AS number and fake AS number in turn until a session is established successfully. The first session request contains the real AS number.
When the session goes down and BGP re-initiates session requests to the peer, the first session request contains the most recent AS number before the session goes down.
· prepend-fake-as—Adds the fake AS number to the AS_PATH attribute in packets received from a peer.
· prepend-global-as—Adds the real AS number to the AS_PATH attribute in packets sent to a peer.
The prepend-fake-as and prepend-global-as keywords take effect only when BGP establishes a session to its peer using a fake AS number.
The peer fake-as command is applicable only to EBGP peers or peer groups. When you set the AS number of the specified peer as the fake AS number in the peer fake-as command, follow these restrictions and guidelines:
· If the device successfully establishes a session to the specified peer by using the fake AS number, the device considers the peer as an IBGP peer.
· If the device successfully establishes a session to the specified peer by using the actual AS number, the device considers the peer as an EBGP peer.
· Both the features supported only by IBGP peers and the features supported only by EBGP peers are configurable for the peer. However, only the features supported by the peer can take effect on the peer.
· BGP clears the configuration that takes effect on only IBGP peers for the peer if one of the following conditions exists:
¡ The value for the as-number argument in the peer fake-as command is different from that in the peer as-number command.
¡ You have executed the undo peer fake-as command.
3. Advertise a fake AS number to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } fake-as as-number [ dual-as | prepend-fake-as | prepend-global-as ] *
By default, no fake AS number is advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } fake-as as-number [ dual-as | prepend-fake-as | prepend-global-as ] *
To use EBGP between PE and CE in MPLS L3VPN, VPN sites in different geographical areas should have different AS numbers. Otherwise, BGP discards route updates containing the local AS number. If two CEs connected to different PEs use the same AS number, you must configure AS number substitution on each PE. This substitution can replace the AS number in route updates originated by the remote CE as its own AS number before advertising them to the connected CE.
Figure 26 AS number substitution configuration (in an IPv4 network)
As shown in Figure 26, CE 1 and CE 2 use the same AS number 800. To ensure bidirectional communication between the two sites, configure AS number substitution on PE 2. PE 2 replaces AS 800 with AS 100 for the BGP route update originated from CE 1 before advertising it to CE 2. Perform the same configuration on PE 1.
Do not configure AS number substitution in normal circumstances. Otherwise, routing loops might occur.
3. Configure AS number substitution for a peer or peer group.
By default, AS number substitution is not configured.
peer { group-name | ipv6-address [ prefix-length ] } substitute-as
Private AS numbers are typically used in test networks, and should not be transmitted in public networks. The range of private AS numbers is from 64512 to 65535.
You can perform this task to remove or replace private AS numbers with the local AS number in BGP updates as follows:
· When you execute the peer public-as-only command without specifying the force keyword or the limited keyword, the following rules apply:
¡ If the AS_PATH attribute of a BGP update carries only private AS numbers, the device removes the AS numbers before sending the update to the specified peer or peer group.
¡ If the AS_PATH attribute of an update carries both public and private AS numbers, this command does not take effect. BGP directly sends the update to the specified peer or peer group.
¡ If the AS_PATH attribute of an update carries the AS number of the specified peer or peer group, this command does not take effect. BGP directly sends the update to the specified peer or peer group.
· When you execute the peer public-as-only command with the force keyword specified, this command works as Table 5 shows.
Keyword |
replace |
Whether this keyword is specified: · Specified—This command replaces all private AS numbers with the local AS number in the AS_PATH attribute. · Not specified—This command removes all private AS numbers from the AS_PATH attribute. |
include-peer-as |
Whether this keyword is specified: · Specified—This command removes or replaces the AS number of the specified peer or peer group if it is a private AS. · Not specified—This command does not remove or replace the private AS number of the specified peer or peer group. |
· When you execute the peer public-as-only command with the limited keyword specified, this command works as Table 6 shows.
Keyword |
replace |
Whether this keyword is specified: · Specified—This command replaces all private AS numbers on the left of the first non-private AS number in the AS_PATH attribute. · Not specified—This command removes all private AS numbers on the left of the first non-private AS number from the AS_PATH attribute. |
include-peer-as |
Whether this keyword is specified: · Specified—This command removes or replaces the private AS number of the specified peer or peer group on the left of the first non-private AS number in the AS_PATH attribute. · Not specified—This command does not remove or replace the private AS number of the specified peer or peer group. |
This feature is applicable only to EBGP peers or peer groups.
Use this feature with caution, because changing the AS_PATH attribute might cause routing loops.
3. Configure BGP to remove private AS numbers from the AS_PATH attribute of updates sent to an EBGP peer or peer group.
By default, BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
This command is applicable to only EBGP peers or peer group.
By default, BGP checks the first AS number of an EBGP-learned route update. If the first AS number is neither the AS number of the BGP peer nor a private AS number, the BGP router disconnects the BGP session to the peer.
3. Configure BGP to ignore the first AS number of EBGP route updates.
ignore-first-as
By default, BGP checks the first AS number of EBGP-learned route updates.
Ignoring the first AS number of EBGP route updates received from a peer or peer group (IPv4 peers)
3. Configure BGP to ignore the first AS number of EBGP route updates received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } ignore-first-as
Ignoring the first AS number of EBGP route updates received from a peer or peer group (IPv6 peers)
peer { group-name | ipv6-address [ prefix-length ] } ignore-first-as
Perform this task to enable BGP to filter routes based on the quantity of AS numbers contained in the AS_PATH attribute. BGP will discard incoming and outgoing routes, and withdraw routes that have been advertised if they exceed the specified quantity threshold.
This feature does not take effect on routes that have been received or on local summary routes.
3. Set an AS number quantity threshold.
as-path-limit [ as-numbers ]
By default, no AS number quantity threshold is configured.
About the MED attribute
BGP uses MED to determine the optimal route for traffic going into an AS. When a BGP router obtains multiple routes with the same destination but with different next hops, it selects the route with the smallest MED value as the optimal route if other conditions are the same.
Configuring the default MED value (IPv4 unicast/multicast address family)
3. Configure the default MED value.
default med med-value
The default MED value is 0.
Configuring the default MED value (IPv6 unicast/multicast address family)
By default, BGP only compares the MEDs of routes from the same AS. This task enables BGP to compare the MEDs of routes from different ASs.
3. Enable MED comparison for routes from different ASs.
compare-different-as-med
By default, MED comparison for routes from different ASs is disabled.
This task enables BGP to compare the MEDs of routes from an AS.
Figure 27 Route selection based on MED (in an IPv4 network)
As shown in Figure 27, Device D establishes indirect EBGP peer relationships with Device A, Device B, and Device C, and learns addresses 1.1.1.1/32, 2.2.2.2/32, and 3.3.3.3/32 through OSPF. The following output shows the routing information on Device D.
1.1.1.1/32 O_INTRA 10 10 11.1.1.2 Interface D1
2.2.2.2/32 O_INTRA 10 20 12.1.1.2 Interface D2
3.3.3.3/32 O_INTRA 10 30 13.1.1.2 Interface D3
Device D learns network 10.0.0.0 from both Device A and Device B. Because the route learned from Device B has a smaller IGP metric, the route is optimal. The following output shows the BGP routing table on Device D.
*>e 10.0.0.0 2.2.2.2 50 0 300 400e
* e 3.3.3.3 50 0 200 400e
When Device D learns network 10.0.0.0 from Device C, it compares the route with the optimal route in its routing table. Because Device C and Device B reside in different ASs, BGP does not compare the MEDs of the two routes. The route from Device C has a smaller IGP metric than the route from Device B, so the route from Device C becomes optimal. The following output shows the BGP routing table on Device D.
*>e 10.0.0.0 1.1.1.1 60 0 200 400e
* e 10.0.0.0 2.2.2.2 50 0 300 400e
However, Device C and Device A reside in the same AS, and Device C has a greater MED, so network 10.0.0.0 learned from Device C should not be optimal.
To avoid this issue, you can configure the bestroute compare-med command to enable MED comparison for routes from the same AS on Device D. After that, Device D puts the routes received from each AS into a group, selects the route with the lowest MED from each group, and compares routes from different groups. Network 10.0.0.0 learned from Device B is the optimal route. The following output shows the BGP routing table on Device D.
* e 1.1.1.1 60 0 200 400e
3. Enable MED comparison for routes on a per-AS basis.
By default, MED comparison for routes on a per-AS basis is disabled.
This task enables BGP to compare the MEDs of routes received from confederation peers. However, if a route received from a confederation peer has an AS number that does not belong to the confederation, BGP does not compare the route with other routes. For example, a confederation has three AS numbers 65006, 65007, and 65009. BGP receives three routes from different confederation peers. The AS_PATH attributes of these routes are 65006 65009, 65007 65009, and 65008 65009, and the MED values of them are 2, 3, and 1. Because the third route's AS_PATH attribute contains AS number 65008 that does not belong to the confederation, BGP does not compare it with other routes. As a result, the first route becomes the optimal route.
3. Enable MED comparison for routes from confederation peers.
bestroute med-confederation
By default, MED comparison for routes from confederation peers is disabled.
By default, BGP uses the MED value and the IGP metric value separately for optimal route selection. With this command executed, BGP performs the following tasks when it selects the optimal route by MED comparison:
1. Multiply the MED value and IGP metric value for each route by the MED value multiplier and the IGP metric value multiplier, respectively.
2. Calculate the sum of the new MED value and IGP metric value for each route.
3. Select the route with the smallest sum as the optimal route.
BGP cannot use routes with different MED values to implement load balancing. To resolve this issue, set the multipliers as needed to ensure that the sums of the calculated MED and IGP metric values for these routes are the same.
If a BGP route has no MED attribute, the MED value for this route is 0.
This feature is not supported for BGP L2VPN address family view.
3. Enable BGP to use the MED and IGP metric together for optimal route selection.
bestroute med-plus-igp [ igp-multiplier igp-multiplier | med-multiplier med-multiplier ] *
By default, BGP selects the route with the lowest MED value as the optimal route when it selects the optimal route by MED comparison.
ECMP load balancing equally distributes traffic to the equal-cost links without considering link bandwidth differences. This might cause insufficient usage of high-speed links and traffic congestion on low-speed links. To resolve this issue, you can configure Unequal Cost Multiple Path (UCMP) load balancing based on the link bandwidth attributes of BGP routes.
The link bandwidth attribute of a route indicates the link bandwidth of the outgoing interface of the route. After UCMP load balancing is enabled for an EBGP peer on the device, the device adds the link bandwidth attribute into the route received from the EBGP peer. This attribute carries the AS number of the current BGP process and the interface bandwidth for direct EBGP session establishment. UCMP BGP routes are formed in the following situation:
· BGP route load balancing is configured by the balance command.
· All BGP routes used for load balancing carry a link bandwidth attribute.
During traffic forwarding, the proportion of the traffic carried on each BGP route is that of the route's link bandwidth to the total link bandwidth of all UCMP routes. As shown in Figure 28, Device A receives routes for the same destination address from three EBGP peers. Assume Device A adds link bandwidth attribute values 500 kbps, 1000 kbps, and 500 kbps for the three BGP routes. The traffic load proportions carried on the three BGP routes are 25%, 50%, and 25%, respectively.
Figure 28 UCMP load balancing based on BGP routes with link bandwidth attributes
By default, the BGP routes with link bandwidth attributes are advertised only to IBGP peers and the added link bandwidth attributes are optional non-transitive attributes. You can change the advertisement rule for BGP routes with link bandwidth attributes as needed:
· To advertise link bandwidth attributes to EBGP peers, execute the peer advertise ebgp bandwidth command.
· To make BGP peers that cannot identify link bandwidth attributes to carry link bandwidth attributes when they forward BGP routes, execute the peer advertise bandwidth transitive command. This command can convert the link bandwidth attributes carried in BGP routes into optional transitive attributes.
When you configure this feature to add link bandwidth attributes to BGP routes, follow these restrictions and guidelines:
· This feature applies only to direct EBGP peers or peer groups. If the specified peer or peer group becomes an indirectly connected one, BGP stops adding the link bandwidth attribute to routes received from the EBGP peer or peer group.
· Only if all BGP routes for the same destination address carry the link bandwidth attributes, can these routes provide UCMP load balancing. Otherwise, the routes can only provide ECMP load balancing.
· A BGP route can carry a maximum of one link bandwidth attribute. If a received route already has a link bandwidth attribute, the device cannot add a link bandwidth attribute to the route any more.
In advertisement of BGP routes with link bandwidth attributes, the following restrictions apply:
· For a BGP peer or peer group, the configuration of the peer route-policy export command takes precedence over that of the peer bandwidth command when the following requirements are met:
¡ You use the peer route-policy export command to apply a routing policy to the BGP peer or peer group. The routing policy uses the apply extcommunity command to configure a link bandwidth attribute for BGP routes.
¡ You configure the peer bandwidth command for the BGP peer or peer group.
· Before advertisement, the device deletes the link bandwidth attribute of a received route if the device needs to change the next hop of that route. This is because the forwarding link instructed by this route has changed and thus the original link bandwidth no longer indicates the bandwidth of the real forwarding link. This restriction does not exist if the device receives a route without any link bandwidth attribute and adds a link bandwidth attribute to the route.
· For UCMP routes, if the Add-Path feature is configured to advertise only one optimal route, the link bandwidth attribute value for the optimal route equals the total link bandwidth of all UCMP routes. If the Add-Path feature is configured to advertise more than one optimal route, the advertised routes carry their respective link bandwidth attributes.
Configure the peer advertise-ext-community command. BGP can advertise the link bandwidth attribute to a BGP peer or peer group only after you execute this command for the BGP peer or peer group.
Procedure (IPv4 unicast/IPv4 multicast address family)
address-family ipv4 multicast
3. Configure a link bandwidth attribute for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } bandwidth [ bandwidth-value ]
By default, no link bandwidth attribute is configured for a peer or peer group.
4. (Optional.) Enable advertising the link bandwidth attribute to EBGP peers.
peer { group-name | ipv4-address [ mask-length ] } advertise ebgp bandwidth
By default, the device does not advertise the link bandwidth attribute to EBGP peers.
5. (Optional.) Transform the type of the link bandwidth attribute to optional transitive for BGP routes advertised to a peer.
peer { group-name | ipv4-address [ mask-length ] } advertise bandwidth transitive
By default, the link bandwidth attribute of BGP routes is optional non-transitive.
Procedure (IPv6 unicast/IPv6 multicast address family)
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } bandwidth [ bandwidth-value ]
The ipv4-address [ mask-length ] option is supported only in BGP IPv6 unicast address family view.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise ebgp bandwidth
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise bandwidth transitive
By default, the device sends BGP routes immediately to a peer when the peer state changes to UP. If the device advertises routes before completing ARP or ND table convergence, the traffic matching these advertised routes might not be forwarded correctly, which causes traffic loss.
To resolve this issue, use this feature to minimize the priority of the routes to be advertised after the state of a peer changes from DOWN to UP. The peer will not select the routes received from the device as the optimal routes. After the device completes ARP or ND table convergence and the specified wait time elapses, the device restores the priority of the routes advertised to the peer.
After you use this feature, the device performs the following tasks when the state of a peer changes from DOWN to UP:
1. Set the local preference value to the minimum (zero) and the MED value to the maximum (4294967295) for the routes to be advertised.
2. After the specified wait time elapses, restore the local preference value and the MED value for the advertised routes, and then advertise these routes immediately.
To have the device restore the priority of the advertised routes before the specified wait time elapses, use one of the following commands:
¡ reset bgp advertise lowest-priority on-peer-up
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to the peer. If the state of a peer changes from DOWN to UP later, the device still minimizes the priority of the routes advertised to that peer.
¡ undo advertise lowest-priority on-peer-up duration
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to the peer. The device does not change the original local preference value and MED value for the subsequent routes advertised to peers.
You can use the advertise lowest-priority on-peer-up duration command in BGP instance view or BGP address family view:
· If you use this command in the view of a BGP instance, this command takes effect on all address families in the instance.
· If you use this command in the view of a BGP address family, this command takes effect only on the address family.
· For a BGP address family, the configuration of this command in BGP address family view takes precedence over that in BGP instance view.
You can use this command multiple times to change the wait time. After you change the wait time, the following rules apply:
· If the original wait time setting is taking effect, the new wait time setting will immediately take over and the device will update the time to wait for route priority restoration.
For example, you can set the wait time to 10 seconds by using the advertise lowest-priority on-peer-up duration 10 command. Then, you use the advertise lowest-priority on-peer-up duration 6 command to set a new wait time six seconds after the state of a peer changes from DOWN to UP. The device will still minimize the priority of the routes advertised to the peer during the following six seconds.
· If the original wait time is not taking effect, the new wait time will take effect when the state of a peer changes from DOWN to UP.
The following commands can influence each other:
· advertise lowest-priority on-peer-up duration
· advertise lowest-priority on-startup duration
· bgp update-delay on-startup
· route-update-delay
When you use two of the commands above together, the configuration result varies by command as follows:
Command A |
Command B |
Configuration result |
bgp update-delay on-startup |
advertise lowest-priority on-startup duration in BGP instance view |
Command A and command B overwrite each other. The command used at last takes effect. |
advertise lowest-priority on-peer-up duration in BGP instance view |
Provided that the delay time specified in command A is TA and the wait time specified in command B is TB, the two commands take effect as follows after the device restarts and the BGP process recovers: · If TA ≥ TB, only command A takes effect. · If TA < TB, the device performs the following tasks: a. The device does not send any BGP routes to peers within TA. b. After TA elapses, the device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TA). c. After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to peers. The device does not minimize the priority of the subsequent routes advertised to peers. |
Both command A and command B take effect after the device restarts and the BGP process recovers. Provided that the delay time specified in command A is TA, the device can advertise BGP routes to a peer only after TA plus TS elapses. TS represents the larger interval among the intervals specified in the peer route-update-interval command and command B. If you did not execute the peer route-update-interval command for the peer, the device uses the default value of this command to compare with the interval configured in command B. |
advertise lowest-priority on-startup duration in the view of a BGP address family |
· In the address family configured with command B, only command B takes effect. · In the address families not configured with command B, command A takes effect. |
advertise lowest-priority on-peer-up duration in the view of a BGP address family |
Provided that the delay time specified in command A is TA and the wait time specified in command B is TB, the following rules apply: · In the address families not configured with command B, only command A takes effect. · In the address family configured with command B, the two commands take effect as follows after the device restarts and the BGP process recovers: ¡ If TA ≥ TB, only command A takes effect. ¡ If TA < TB, the device performs the following tasks: i. The device does not send any BGP routes to peers within TA. ii. The device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TA). iii. After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to peers. The device does not minimize the priority of the subsequent routes advertised to peers. |
route-update-delay |
The following description applies to BGP IPv4 unicast address family, BGP-VPN IPv4 unicast address family, BGP IPv6 unicast address family, and BGP-VPN IPv6 unicast address family. Provided that the wait time specified in command B is TB, the two commands take effect as follows after the device restarts and the BGP process recovers: · If TS ≥ TB, only command A takes effect. · If TS < TB, the device performs the following tasks: a. The device does not send any BGP routes to peers within TS. b. After TS elapses, the device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TS). c. After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to peers. The device does not minimize the priority of the subsequent routes advertised to peers. TS represents the larger interval among the intervals specified in the peer route-update-interval command and command A. If you did not execute the peer route-update-interval command for the peers, the device uses the default value of this command to compare with the interval configured in command A. |
The following description applies to BGP IPv4 unicast address family, BGP-VPN IPv4 unicast address family, BGP IPv6 unicast address family, and BGP-VPN IPv6 unicast address family. Provided that the wait time specified in command B is TB, the two commands take effect as follows when the state of a peer changes from DOWN to UP: · If TS ≥ TB, only command A takes effect. · If TS < TB, the device performs the following tasks: a. The device does not send any BGP routes to the peer within TS. b. After TS elapses, the device sends BGP routes to the peer and minimizes the priority of these routes during the remaining time (TB minus TS). c. After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to the peer. The device does not minimize the priority of the subsequent routes advertised to the peer. TS represents the larger interval among the intervals specified in the peer route-update-interval command and command A. If you did not execute the peer route-update-interval command for the peer, the device uses the default value of this command to compare with the interval configured in command A. |
advertise lowest-priority on-startup duration in BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv6 unicast address family view, or BGP-VPN IPv6 unicast address family view |
Provided that the wait time specified in command B is TB, the following rules apply: · In the address families not configured with command B, only command A takes effect. · In the address family configured with command B, the two commands take effect as follows after the device restarts and the BGP process recovers: ¡ If TS ≥ TB, only command A takes effect. ¡ If TS < TB, the device performs the following tasks: i. The device does not send any BGP routes to peers within TS. ii. After TS elapses, the device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TS). iii. After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to peers. The device does not minimize the priority of the subsequent routes advertised to peers. · TS represents the larger interval among the intervals specified in the peer route-update-interval command and command A. If you did not execute the peer route-update-interval command for the peers, the device uses the default value of this command to compare with the interval configured in command A. |
advertise lowest-priority on-peer-up duration in BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv6 unicast address family view, or BGP-VPN IPv6 unicast address family view |
Provided that the wait time specified in command B is TB, the following rules apply: · In the address families not configured with command B, only command A takes effect. · In the address family configured with command B, the two commands take effect as follows when the state of a peer changes from DOWN to UP: ¡ If TS ≥ TB, only command A takes effect. ¡ If TS < TB, the device performs the following tasks: i. The device does not send any BGP routes to the peer within TS. ii. After TS elapses, the device sends BGP routes to the peer and minimizes the priority of these routes during the remaining time (TB minus TS). iii. After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to the peer. The device does not minimize the priority of the subsequent routes advertised to the peer. · TS represents the larger interval among the intervals specified in the peer route-update-interval command and command A. If you did not execute the peer route-update-interval command for the peer, the device uses the default value of this command to compare with the interval configured in command A. |
Command A is mutually exclusive with command B. |
· In the address family configured with command B, only command B takes effect. · In the address families not configured with command B, only command A takes effect. |
Command A is mutually exclusive with command B in the same address family. |
Procedure (BGP instance view)
3. Minimize the priority of the routes advertised to a peer after the peer state changes from DOWN to UP.
advertise lowest-priority on-peer-up duration seconds
By default, BGP does not change the priority of the routes advertised to its peers.
Procedure (BGP IPv4 unicast)
¡ Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
Procedure (BGP IPv6 unicast)
2. Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
By default, the device sends BGP routes immediately to peers after the device restarts and the BGP process recovers. If the device advertises routes before completing ARP or ND table convergence, the traffic matching these advertised routes might not be forwarded correctly, which causes traffic loss.
To resolve this issue, use this feature to minimize the priority of the routes to be advertised after the device restarts and the BGP process recovers. Peers will not select the routes received from the device as the optimal routes. After the device completes ARP or ND table convergence and the specified wait time elapses, the device restores the priority of the routes advertised to the peers.
After you use this feature, the device performs the following tasks after the device restarts and the BGP process recovers:
¡ reset bgp advertise lowest-priority on-startup
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to peers. The device does not minimize the priority of the subsequent routes advertised to the peers unless the device restarts again.
¡ undo advertise lowest-priority on-startup duration
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to peers. The device does not change the original local preference value and MED value for the subsequent routes advertised to the peers.
When you use the advertise lowest-priority on-startup duration command, follows these guidelines:
· You can use this command in BGP instance view or BGP address family view:
¡ If you use this command in the view of a BGP instance, this command takes effect on all address families in the instance.
¡ If you use this command in the view of a BGP address family, this command takes effect only on the address family.
¡ For a BGP address family, the configuration of this command in BGP address family view takes precedence over that in BGP instance view.
· The configuration of this command does not take effect immediately. It takes effect only after the device restarts.
The following commands can influence the configuration of each other:
When you use two of the commands above together, the configuration result varies by command. For more information, see Table 7.
3. Minimize the priority of the routes advertised to peers after the device restarts and the BGP process recovers.
advertise lowest-priority on-startup duration seconds
Before performing this task, make sure the following conditions exist:
· The device has completed ARP or ND table convergence and is ready to advertise routes with original priority.
· The advertise lowest-priority on-peer-up duration or advertise lowest-priority on-startup duration command still takes effect after a peer comes up or the device restarts.
After you perform this task, the device immediately sends BGP routes with the original local preference value and MED value to peers.
· If the state of a peer changes from DOWN to UP later, the device still minimizes the priority of the routes advertised to that peer.
· If the device restarts again later, the device still minimizes the priority of the routes advertised to peers.
To restore the priority of the advertised BGP routes, use the reset bgp [ instance instance-name ] advertise lowest-priority { on-peer-up | on-startup } command in user view.
By default, BGP selects an optimal route based on rules in "BGP route selection." It does not prefer routes learned from any peer or peer groups during optimal route selection.
After you perform this task, routes learned from the specified peer or peer group take precedence over other routes if these routes have the same prefix. BGP uses this rule to continue route selection if it fails to select an optimal route by using the peer type selection rule. If BGP still fails route selection, it uses the IGP metric selection rule to select an optimal route.
Procedure (IPv4 unicast/multicast address family)
2. Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv4 multicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv4 multicast address family view:
3. Prefer routes learned from the specified peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } high-priority
By default, BGP does not prefer routes learned from any peer or peer groups during optimal route selection.
Procedure (IPv6 unicast/multicast address family)
2. Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
¡ Execute the following commands in sequence to enter BGP IPv6 multicast address family view:
address-family ipv6 multicast
An Accumulated Interior Gateway Protocol (AIGP) administrative domain is a collection of multiple ASs that run the same IGP under one administrative control. Within the domain, BGP accumulates the IGP metrics all along the forwarding path for a route. Then, it uses the accumulated value as the AIGP attribute for the route to implement metric-based route selection.
By default, BGP does not advertise the AIGP attribute to its peers or peer groups. When BGP receives a route carrying the AIGP attribute, it ignores and removes the attribute before advertising the route to other peers or peer groups. Perform this task to enable BGP to advertise the AIGP attribute to its peers or peer groups.
With this feature enabled, a router processes the AIGP attribute in a received route as follows:
· If the router sets itself as the next hop for the route, it adds to the AIGP attribute value the IGP metric from itself to the original next hop and advertises the new AIGP attribute value.
· If the router does not set itself as the next hop for the route, it does not change the AIGP attribute value.
BGP uses the AIGP attribute to select the optimal route as follows:
· A route carrying the AIGP attribute takes precedence over a route not carrying the AIGP attribute.
· A route that has a smaller computed AIGP attribute value has a higher priority.
When the AIGP attribute of a route changes, BGP sends a route update with the new AIGP attribute.
As a best practice, do not configure the peer aigp command on border routers of an AIGP administrative domain.
When a router receives a route not carrying the AIGP attribute, it does not advertise the AIGP attribute to a peer or peer group if you configure only the peer aigp command. To enable the router to advertise the AIGP attribute, you must configure both the peer aigp and apply aigp commands. For information about the apply aigp command, see "Configuring routing policies."
Procedure (IPv4)
3. Configure BGP to advertise the AIGP attribute to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp
By default, BGP does not advertise the AIGP attribute to a peer or peer group and ignores the AIGP attribute in routes received from the peer or peer group.
4. (Optional.) Replace the MED value with AIGP value in routes advertised to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp send med
By default, BGP does not replace the MED value with AIGP value in routes advertised to a peer or peer group.
Use this command to send the AIGP attribute to a peer or peer group that does not support AIGP.
Procedure (IPv6)
peer { group-name | ipv6-address [ prefix-length ] } aigp
peer { group-name | ipv6-address [ prefix-length ] } aigp send med
By default, BGP takes IGP metrics into account during optimal route selection. If multiple routes to the same destination are available, BGP selects the route with the smallest IGP metric as the optimal route.
Perform this task to enable BGP to ignore IGP metrics during optimal route selection.
2. Enter BGP instance view or BGP-VPN instance view.
¡ Enter BGP instance view.
¡ Execute the following commands in sequence to enter BGP-VPN instance view.
3. Configure BGP to ignore IGP metrics during optimal route selection.
bestroute igp-metric-ignore
By default, BGP includes IGP metrics in optimal route selection.
By default, BGP compares router IDs during optimal route selection. If multiple routes to the same destination are available, BGP selects the route with the smallest router ID as the optimal route.
Perform this task to enable BGP to ignore router IDs during optimal route selection.
¡ Execute the following commands in sequence to enter BGP-VPN instance view:
3. Configure BGP to ignore router IDs during optimal route selection.
bestroute router-id-ignore
By default, BGP selects the route with the smallest router ID as the optimal route.
About tunnel-type recursive next hops
NOTE: In this section, a recursive next hop refers to a next hop obtained through route recursion. Recursive next hops include the following: · IP-type recursive next hops: This type of recursive next hops are IP addresses. · Tunnel-type recursive next hops: This type of recursive next hops are tunnels. |
When the next hop of a BGP route is recursed to a tunnel, the tunnel can be one of the following:
· Label switched path (LSP) or MPLS TE tunnel.
· GRE or VXLAN tunnels.
· SR-MPLS TE policy or SRv6 TE policy.
Each tunnel-type recursive next hop has a unique tunnel ID. To view the tunnel-type recursive next hops of BGP routes, see the Rely tunnel IDs field in the output of the display bgp routing-table command.
Permitting BGP routes with only tunnel-type recursive next hops to participate in optimal route selection
The next hop of a BGP route can be recursed to an IP addresses and a tunnel synchronously. By default, a BGP route can participate in optimal route selection only when its next hop is recursed to an IP address. In some special networks, the next hop of a route might be a tunnel only after route recursion if its AS_PATH attribute is modified by an intermediate device. In this situation, the route cannot participate in optimal route selection though its next hop is reachable, which leads to traffic forwarding failure. To resolve this issue, use the bestroute nexthop-resolved tunnel command. This command allows BGP routes that have only tunnel-type recursive next hops to participate in optimal route selection.
¡ Enter BGP-VPN instance view.
3. Permit BGP routes that have only tunnel-type recursive next hops to participate in optimal route selection.
By default, BGP routes can participate in optimal route selection only when their next hops are recursed to IP addresses.
By default, the recursive next hops of BGP routes does not affect their priorities during optimal route selection. If the next hop of a BGP route is recursed to an IP address and that of another BGP route is recursed to a tunnel, the two routes still have the same priority during optimal route selection.
This feature enables BGP to prefer routes with IP-type or tunnel-type recursive next hops during optimal route selection.
To view the priority of the route selection rule configured by this feature during optimal route selection, see "BGP route selection."
BGP routes that do not have IP-type recursive next hops cannot participate in optimal route selection. BGP routes that have only tunnel-type recursive next hops cannot participate in optimal route selection even if you have performed this task. To resolve this issue, use the bestroute nexthop-resolved tunnel command.
3. Prefer routes with IP-type or tunnel-type recursive next hops during optimal route selection.
bestroute nexthop-type { ip | tunnel } [ preferred ]
This feature enables BGP to monitor the session to each peer, such as the link state of a peer interface. BGP can adjust the priority of routes received from a peer or peer group based on the track entry state. If a network state change occurs, BGP can response quickly to avoid traffic loss due to network issues, such as link failures.
After BGP associates a track entry with a peer, BGP adjusts the priority of routes received from the peer as follows:
· When the state of the associated track entry becomes negative, BGP increases the MED value of the routes to the maximum and set the route priority to the lowest.
· When the state of the associated track entry restores to positive, BGP restores the MED value and the priority of the routes to the original values.
When you specify a track entry to be associated with a peer, the track entry must have been created. As a best practice, use a track entry associated with the link state of the peer interface. The track feature can obtain the link state of the peer interface easily and notify BGP to adjust the route priority when the link state changes to down.
For more information about track entries, see track configuration in High Availability Configuration Guide.
Procedure (IPv4 unicast)
3. Associate a track entry with a BGP peer or peer group for route priority adjustment.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-priority-track track-entry-number
By default, BGP does not use track entries for route priority adjustment.
Procedure (IPv6 unicast)
Verifying and maintaining BGP path selection control
To display BGP route attribute information, execute the following command in any view:
To restore the priority of the routes to be advertised during the time to wait for route priority restoration, execute the following command in user view:
BGP path selection control configuration examples
Example: Configuring BGP path selection
As shown in Figure 29, all routers run BGP.
· EBGP runs between Router A and Router B, and between Router A and Router C.
· IBGP runs between Router B and Router D, and between Router D and Router C. OSPF is the IGP protocol in AS 200.
Configure routing policies to make Router D give priority to the route 1.0.0.0/8 learned from Router C.
Table 8 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
GE1/0/1 |
1.0.0.1/8 |
Router D |
GE1/0/1 |
195.1.1.1/24 |
GE1/0/2 |
192.1.1.1/24 |
GE1/0/2 |
194.1.1.1/24 |
GE1/0/3 |
193.1.1.1/24 |
Router C |
GE1/0/1 |
193.1.1.2/24 |
Router B |
GE1/0/1 |
192.1.1.2/24 |
GE1/0/2 |
195.1.1.2/24 |
GE1/0/2 |
194.1.1.2/24 |
1. Configure IP addresses for interfaces. (Details not shown.)
2. Configure OSPF on Router B, Router C, and Router D:
# Configure Router B.
<RouterB> system-view
[RouterB] ospf
[RouterB-ospf] area 0
[RouterB-ospf-1-area-0.0.0.0] network 192.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 194.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
# Configure Router C.
<RouterC> system-view
[RouterC] ospf
[RouterC-ospf] area 0
[RouterC-ospf-1-area-0.0.0.0] network 193.1.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 195.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
# Configure Router D.
<RouterD> system-view
[RouterD] ospf
[RouterD-ospf] area 0
[RouterD-ospf-1-area-0.0.0.0] network 194.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] network 195.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] quit
[RouterD-ospf-1] quit
3. Configure BGP connections:
# Configure Router A.
[RouterA] bgp 100
[RouterA-bgp-default] peer 192.1.1.2 as-number 200
[RouterA-bgp-default] peer 193.1.1.2 as-number 200
[RouterA-bgp-default] address-family ipv4 unicast
[RouterA-bgp-default-ipv4] peer 192.1.1.2 enable
[RouterA-bgp-default-ipv4] peer 193.1.1.2 enable
# Inject network 1.0.0.0/8 into the BGP routing table of Router A.
[RouterA-bgp-default-ipv4] network 1.0.0.0 8
[RouterA-bgp-default-ipv4] quit
[RouterA-bgp-default] quit
[RouterB] bgp 200
[RouterB-bgp-default] peer 192.1.1.1 as-number 100
[RouterB-bgp-default] peer 194.1.1.1 as-number 200
[RouterB-bgp-default] address-family ipv4 unicast
[RouterB-bgp-default-ipv4] peer 192.1.1.1 enable
[RouterB-bgp-default-ipv4] peer 194.1.1.1 enable
[RouterB-bgp-default-ipv4] quit
[RouterB-bgp-default] quit
[RouterC] bgp 200
[RouterC-bgp-default] peer 193.1.1.1 as-number 100
[RouterC-bgp-default] peer 195.1.1.1 as-number 200
[RouterC-bgp-default] address-family ipv4 unicast
[RouterC-bgp-default-ipv4] peer 193.1.1.1 enable
[RouterC-bgp-default-ipv4] peer 195.1.1.1 enable
[RouterC-bgp-default-ipv4] quit
[RouterC-bgp-default] quit
[RouterD] bgp 200
[RouterD-bgp-default] peer 194.1.1.2 as-number 200
[RouterD-bgp-default] peer 195.1.1.2 as-number 200
[RouterD-bgp-default] address-family ipv4 unicast
[RouterD-bgp-default-ipv4] peer 194.1.1.2 enable
[RouterD-bgp-default-ipv4] peer 195.1.1.2 enable
[RouterD-bgp-default-ipv4] quit
[RouterD-bgp-default] quit
4. Configure local preference for the route 1.0.0.0/8 to make Router D give priority to the route learned from Router C:
# Define IPv4 basic ACL 2000 to permit the route 1.0.0.0/8 on Router C.
[RouterC] acl basic 2000
[RouterC-acl-ipv4-basic-2000] rule permit source 1.0.0.0 0.255.255.255
[RouterC-acl-ipv4-basic-2000] quit
# Define routing policy localpref on Router C to set the local preference of route 1.0.0.0/8 to 200 (the default is 100).
[RouterC] route-policy localpref permit node 10
[RouterC-route-policy-localpref-10] if-match ip address acl 2000
[RouterC-route-policy-localpref-10] apply local-preference 200
[RouterC-route-policy-localpref-10] quit
# Apply the routing policy localpref to the route from the peer 193.1.1.1 on Router C.
[RouterC] bgp 200
[RouterC-bgp-default-ipv4] peer 193.1.1.1 route-policy localpref import
# Display the BGP routing table on Router D.
[RouterD] display bgp routing-table ipv4
Total number of routes: 2
a – additional-path
* >i 1.0.0.0/8 193.1.1.1 200 0 100i
* i 192.1.1.1 100 0 100i
The route 1.0.0.0/8 learned from Router C is the optimal route.
