- 20-Network Management and Monitoring Command Reference
- 01-Ping and tracert commands
- 02-System debugging commands
- 03-NQA commands
- 04-iNQA commands
- 05-iFIT commands
- 06-NTP commands
- 07-SNMP commands
- 08-RMON commands
- 09-Sampler commands
- 10-Mirroring commands
- 11-NetStream commands
- 12-IPv6 NetStream commands
- 13-sFlow commands
- 14-Cloud connection commands
- 15-Packet capture commands
- 16-IP traffic statistics collection commands
| 02-System debugging commands | 62.80 KB |
debugging
Use debugging to enable debugging for a module.
Use undo debugging to disable debugging for a module or for all modules.
debugging module-name [ option ]
undo debugging { all | module-name [ option ] }
Debugging is disabled for all modules.
module-name: Specifies a module by its name, such as arp or device. For a list of supported modules, use the debugging ? command.
option: Specifies the debugging option for a module. Available options vary by module. To display the debugging options supported by a module, use the debugging module-name ? command.
all: Specifies all modules.
CAUTION: Output of excessive debugging messages increases the CPU usage and downgrades the system performance. To guarantee system performance, enable debugging only for modules that are in an exceptional condition. |
The system sends generated debug messages to the device information center, which then sends the messages to appropriate destinations based on the log output configuration. For more information about the information center, see System Management Configuration Guide.
# Enable debugging for the device management module.
<Sysname> debugging dev
display debugging
debugging-auto-off enable cpu-usage-alarm
Use debugging-auto-off enable cpu-usage-alarm to enable the debugging-auto-off feature to automatically disable all types of debugging when the CPU usage reaches or exceeds the lowest CPU usage alarm threshold.
Use undo debugging enable cpu-usage-alarm to disable the debugging-auto-off feature from automatically disabling all types of debugging when the CPU usage reaches or exceeds the lowest CPU usage alarm threshold.
undo debugging-auto-off enable cpu-usage-alarm
The debugging-auto-off feature is not enabled.
Excessive output from debugging commands might affect system performance. To guarantee system performance, enable the debugging-auto-off feature to automatically disable all types of debugging when the CPU usage reaches or exceeds the lowest CPU usage alarm threshold. The CPU usage alarm thresholds are set by using the monitor cpu-usage threshold command.
The device does not automatically enable all types of debugging after the CPU usage drops to or below the CPU usage recovery threshold. To enable debugging for a module or all modules, use the debugging command.
# Enable the debugging-auto-off feature to automatically disable all types of debugging when the CPU usage reaches or exceeds the lowest CPU usage alarm threshold.
<Sysname> debugging-auto-off enable cpu-usage-alarm
display debugging-auto-off
monitor cpu-usage threshold (System Management Command Reference)
display debugging
Use display debugging to display the enabled debugging features for a module or for all modules.
display debugging [ module-name ]
module-name: Specifies a module by its name. For a list of supported modules, use the display debugging ? command. If you do not specify a module name, this command displays the enabled debugging features for all modules.
# Display all enabled debugging features.
<Sysname> display debugging
DEV debugging switch is on
Debugging
Use display debugging-auto-off to display the enabling status of the debugging-auto-off feature.
To conserve system resources, the device automatically disables all types of debugging in the following situations:
· All users have gone offline.
· The CPU usage reaches or exceeds the lowest CPU usage alarm threshold.
The device always automatically disables all types of debugging when all users have gone offline. This mechanism is not user configurable.
To enable the device to automatically disable all types of debugging when the CPU usage reaches or exceeds the lowest CPU usage alarm threshold, use the debugging-auto-off enable cpu-usage-alarm command.
# Display the enabling status of the debugging-auto-off feature.
<Sysname> display debugging-auto-off
Occasions for the system to automatically turn off all debugging:
When all users log out: Enabled
When the CPU usage reaches or exceeds the CPU usage alarm threshold: Disabled
Occasions for the system to automatically turn off all debugging |
Situations where the device automatically disables all types of debugging. |
When all users log out: Enabled |
The debugging-auto-off feature is always enabled for the situation where all users have gone offline. |
When the CPU usage reaches or exceeds the CPU usage alarm threshold: Enabled |
The debugging-auto-off feature is enabled for the situation where the CPU usage reaches or exceeds the lowest CPU usage alarm threshold. |
When the CPU usage reaches or exceeds the CPU usage alarm threshold: Disabled |
The debugging-auto-off feature is disabled for the situation where the CPU usage reaches or exceeds the lowest CPU usage alarm threshold. |
