13-Security Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-R8530Pxx-6W10113-Security Configuration Guide
10-Object group configuration
10-Object group configuration 64.28 KB
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL or object group to identify packets. Object groups are divided into the following types:
·     IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet or match the user from whom a packet comes.
·     IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet or match the user from whom a packet comes.
·     Port object group—A group of port objects used to match the protocol port number in a packet.
Configuring an IPv4 address object group
2.     Configure an IPv4 address object group and enter its view.
object-group ip address object-group-name
The system has one default IPv4 address object group named any.
3.     (Optional.) Configure a description for the IPv4 address object group.
By default, an object group does not have a description.
4.     Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask } | range ip-address1 ip-address2 }
Configuring an IPv6 address object group
2.     Configure an IPv6 address object group and enter its view.
object-group ipv6 address object-group-name
The system has one default IPv6 address object group named any.
3.     (Optional.) Configure a description for the IPv6 address object group.
4.     Configure an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ipv6-address prefix-length | range ipv6-address1 ipv6-address2 }
Configuring a port object group
2.     Configure a port object group and enter its view.
object-group port object-group-name
The system has one default port object group named any.
3.     (Optional.) Configure a description for the port object group.
4.     Configure a port object.
[ object-id ] port { { eq | lt | gt } port | range port1 port2 | }
Configuring aging of DNS-resolved IP addresses from host names
In load balancing scenarios where one host name maps to several IP addresses, DNS-resolved IP address for a host name changes between these mapping addresses. Upon every change, the object group module notifies relevant policies of the change, which causes policies to submit changes frequently and consumes memory. To resolve this issue, you can enable aging of DNS-resolved IP addresses from host names.
With this feature enabled, the system maintains an IP address group for each host name. If a resolved IP address is not in the group, the system adds the address to the group and notifies relevant policies of the change. If a resolved IP address is in the group, the system does not notify relevant policies.
As a best practice, set the aging time to be longer than the TTL of resolution records on the DNS server.
2.     Enable aging of DNS-resolved IP addresses from host names.
object-group dns-aging [ time aging-time ]
By default, aging of DNS-resolved IP addresses from host names is disabled.
Display and maintenance commands for object groups
Display information about object groups.
display object-group [ { { ip | ipv6 } address | port } [ default ] [ name object-group-name ] | name object-group-name ]
Display IPv4 or IPv6 addresses for host names.
In standalone mode:
display object-group { ip | ipv6 } host { object-group-name object-group-name | name host-name [ vpn-instance vpn-instance-name ] } * [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display object-group { ip | ipv6 } host { object-group-name object-group-name | name host-name [ vpn-instance vpn-instance-name ] } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
