- 14-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-iFIT commands
- 05-SRPM commands
- 06-NTP commands
- 07-PTP commands
- 08-Network synchronization commands
- 09-SNMP commands
- 10-RMON commands
- 11-NETCONF commands
- 12-CWMP commands
- 13-EAA commands
- 14-Process monitoring and maintenance commands
- 15-Sampler commands
- 16-Mirroring commands
- 17-NetStream commands
- 18-IPv6 NetStream commands
- 19-TCP connection trace commands
- 20-Performance management commands
- 21-Flow log commands
- 22-Information center commands
- 23-Packet capture commands
- 24-Flow monitor commands
| 00-Preface | 110.60 KB |
Preface
This command reference covers the commands that help you manage and monitor your network, for example, manage system events, collect traffic statistics, sample packets, assess network performance, and test network connectivity.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
