05-Network Connectivity Command Reference
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesCommand ReferencesH3C WX3800X Series Access Controllers Command References(R1411P02)-6W10005-Network Connectivity Command Reference
29-Static routing commands
29-Static routing commands 143.95 KB
delete static-routes all
Use delete static-routes all to delete all static routes.
CAUTION
CAUTION:
This command might interrupt network communication and cause packet forwarding failure. Before executing the command, make sure you fully understand the potential impact on the network.
When you use this command, the system will prompt you to confirm the operation before deleting all the static routes.
To delete one static route, use the undo ip route-static command. To delete all static routes, including the default route, use the delete static-routes all command.
# Delete all static routes.
[Sysname] delete static-routes all
This will erase all IPv4 static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ip route-static
display route-static nib
Use display route-static nib to display static route next hop information.
display route-static nib [ nib-id ] [ verbose ]
nib-id: Specifies a NIB by its ID, a hexadecimal string of 1 to ffffffff. If you do not specify this argument, the command displays all static route next hop information.
verbose: Displays detailed static route next hop information. If you do not specify this keyword, the command displays brief static route next hop information.
# Displays brief static route next hop information.
<Sysname> display route-static nib
Total number of nexthop(s): 44
      NibID: 0x11000000          Sequence: 0
       Type: 0x21                  Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x111                VrfNthp: 0
   UserKey1: 0x0                   Nexthop: 0.0.0.0
   UserKey2: 0x0                   IFIndex: 0x111
   UserKey3: 0x0                LocalAddr: 0.0.0.0
   TopoNthp: 0                     ExtType: 0x0
      Color: 0                       COFlag: 0x0
     LinkID: 0x0
   SIDIndex: 0x0                   SRPName:
 OriNexthop: 0.0.0.0
      NibID: 0x11000001          Sequence: 1
       Type: 0x41                   Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x0                   VrfNthp: 5
   UserKey1: 0x0                   Nexthop: 2.2.2.2
     LinkID: 0x0
 OriNexthop: 0.0.0.0
NibID
ID of the NIB.
Sequence
Sequence number of the NIB.
Type of the NIB.
Flushed
Indicates whether the route with the NIB has been flushed to the FIB.
Age
Elapsed time since the next hop information was last updated.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
UserKey2
Reserved data 3.
UserKey3
Reserved data 4.
VrfNthp
Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on the public network.
Nexthop
Next hop address.
IFIndex
Interface index
LocalAddr
Local interface address.
TopoNthp
Index of the topology that contains the next hop. This field displays 0 if the next hop is on the public network.
ExtType
NIB extension type.
Color
Color extended community attribute.
COFlag
Flag of the color extended community attribute.
LinkID
Link ID of the SDWAN TTE connection.
SIDIndex
SID index value.
SRPName
SR-MPLS TE policy name.
OriNexthop
Original next hop address of the route.
# Displays detailed static route next hop information.
<Sysname> display route-static nib verbose
        Age: 00h01m50s
   UserKey2: 0x0                    IFIndex: 0x10002
     LinkID: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 2                 FlushRefCnt: 0
       Flag: 0x2                    Version: 1
 1 nexthop(s):
PrefixIndex: 0                 OrigNexthop: 0.0.0.0
  RelyDepth: 0                 RealNexthop: 0.0.0.0
  Interface: NULL0               LocalAddr: 0.0.0.0
  TunnelCnt: 0                           Vrf: default-vrf
   TunnelID: N/A                   Topology: base
     Weight: 1000000                  Flags: 0x0
SRPolicyNID: 4294967295      SRInterface:
ColorWeight: 0                      Locator: N/A
 OrigLinkID: 0x0                RealLinkID: 0x0
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 1                  FlushRefCnt: 0
       Flag: 0x12                    Version: 1
 2 nexthop(s):
PrefixIndex: 0                  OrigNexthop: 2.2.2.2
  RelyDepth: 7                  RealNexthop: 8.8.8.8
  Interface: Vlan11               LocalAddr: 12.12.12.12
  RelyDepth: 9                 RealNexthop: 0.0.0.0
NibID
ID of the NIB.
Sequence
Type of the NIB.
Flushed
Age
UserKey0
Reserved data 1.
VrfNthp
Index of the VPN instance that the next hop belongs to. This field displays 0 if the next hop is on the public network.
UserKey1
Reserved data 2.
UserKey2
Reserved data 3.
UserKey3
Reserved data 4.
Nexthop
Next hop address.
IFIndex
Interface index
LocalAddr
TopoNthp
ExtType
NIB extension type.
Color
COFlag
LinkID
SIDIndex
SID index value.
SRPName
OriNexthop
RefCnt
Reference count of the next hop.
FlushRefCnt
Reference count of the next hop that is flushed to the FIB.
Flag
Flag of the next hop.
Version
Version of the next hop.
x nexthop(s)
Number of next hops.
PrefixIndex
Prefix index of the next hop for an ECMP route.
OrigNexthop
Original next hop.
RelyDepth
Recursion depth.
RealNexthop
Real next hop.
Output interface.
localAddr
TunnelCnt
Number of tunnels after route recursion.
Vrf
VPN instance name. For the public network, this field displays default-vrf.
TunnelID
ID of the tunnel after route recursion.
Topology
Topology name. The topology name for the public network is base.
Weight
ECMP route weight. This field displays 0 for non-ECMP routes.
Flags
Flags of the detailed next hop.
SRPolicyNID
NIB ID of the route obtained from an SR-MPLS TE policy through route recursion.
SRInterface
Output interface of the route obtained from the SR-MPLS TE policy through route recursion.
ColorWeight
Weight value of the color attribute in the SR-MPLS TE policy.
Locator
IPv6 prefix of the locator to which the SID belongs.
If no locator is available, this field displays N/A.
OrigLinkID
Original link ID of the SDWAN TTE connection.
RealLinkID
Real link ID of the SDWAN TTE connection.
display route-static routing-table
Use display route-static routing-table to display static routing table information.
display route-static routing-table [ ip-address { mask-length | mask } ]
ip-address: Specifies the destination IP address in dotted decimal notation. If you do not specify this argument, the command displays all static routing table information.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
# Display static routing table information.
<Sysname> display route-static routing-table
Total number of routes: 24
Status: * - valid
*Destination: 0.0.0.0/0
       NibID: 0x1100000a         NextHop: 2.2.2.10
   MainNibID: N/A              BkNextHop: N/A
     BkNibID: N/A              Interface: Vlan-interface11
     TableID: 0x2            BkInterface: Vlan-interface12
        Flag: 0x82d01           BfdSrcIp: N/A
     DbIndex: 0xd             BfdIfIndex: 0x0
        Type: Normal         BfdVrfIndex: 0
  TrackIndex: 0xffffffff           Label: NULL
  Preference: 60             vrfIndexDst: 0
     BfdMode: N/A             vrfIndexNH: 0
   Permanent: 0                      Tag: 0
       NibID: 0x1100000b         NextHop: 2.2.2.11
     BkNibID: N/A              Interface: Vlan-interface13
     TableID: 0x2            BkInterface: Vlan-interface14
   Permanent: 0                      Tag: 0
destination
Destination address/prefix.
NibID
ID of the NIB.
MainNibID
ID of the primary next hop for static route FRR.
BkNibID
ID of the backup next hop for static route FRR.
NextHop
Next hop address.
BkNextHop
Backup next hop address.
Output interface of the route. (If an SRv6 TE policy or SR-MPLS TE policy is obtained through route recursion for the route, this field displays the policy name.)
BkInterface
Backup output interface.
TableID
ID of the table to which the route belongs.
Flag
Flag of the route.
DbIndex
Index of the database to which the route belongs.
Route type:
·     Normal.
·     DHCP.
·     NAT.
BfdSrcIp
Source IP address of the indirect BFD session.
BfdIfIndex
Index of the interface where BFD is enabled.
BfdVrfIndex
Index of the VPN instance where BFD is enabled. This field displays 0 if BFD is enabled for the public network.
BfdMode
BFD session mode:
·     N/A—No BFD session is configured.
·     Ctrl—Control packet mode
·     Echo—Echo packet mode.
TrackIndex
NQA Track index.
vrfIndexDst
Index of VPN instance to which the destination belongs. For the public network, this field displays 0.
vrfIndexNH
Index of the VPN instance to which the next hop belongs. For the public network, this field displays 0.
Permanent
Permanent static route flag. 1 indicates a permanent static route.
ip route-static
Use ip route-static to configure a static route.
Use undo ip route-static to delete a static route.
ip route-static dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ nexthop-index index-string ] | dhcp ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static dest-address { mask-length | mask } next-hop-address [ nexthop-index index-string ] [ recursive-lookup { host-route | longest-match } ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static group group-name interface-type interface-number [ next-hop-address | dhcp ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static group group-name  next-hop-address [ recursive-lookup { host-route | longest-match } ] | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
undo ip route-static { dest-address { mask-length | mask } | group group-name } [ interface-type interface-number [ next-hop-address ] | next-hop-address ] [ preference preference ]
No static route is configured.
dest-address: Specifies the destination IP address of the static route, in dotted decimal notation.
group group-name: Specifies a static route group by its name, a case-sensitive string of 1 to 31 characters.
interface-type interface-number: Specifies an output interface by its type and number. For more information, see Layer 3—IP Routing Configuration Guide.
next-hop-address: Specifies the IP address of the next hop, in dotted decimal notation. For more information, see Layer 3—IP Routing Configuration Guide.
dhcp: Specifies the default router designated by the DHCP server for the output interface as the next hop of the static route.
nexthop-index index-string: Specifies the index of the next hop. The index-string argument represents the index, which is a case-insensitive string of 1 to 93 characters. If you do not specify an index for the next hop, the static route uses the output interface and the IP address of the next hop as the next hop index. Do not specify the same next hop index for routes to the same destination.
recursive-lookup host-route: Specifies only host routes for static route recursion.
recursive-lookup longest-match: Specifies host routes with the longest matching mask for static route recursion.
backup-interface interface-type interface-number: Specifies a backup output interface by its type and number. If the backup output interface is an NBMA interface or broadcast interface and not a P2P interface, you must specify the backup next hop address.
backup-nexthop backup-nexthop-address: Specifies a backup next hop address.
permanent: Specifies the route as a permanent static route. After you specify this keyword, the static route will always be active, even if the output interface is down.
track track-entry-number: Associates the static route with a track entry specified by its number in the range of 1 to 1024. For more information about Track, see High Availability Configuration Guide.
preference preference: Specifies a preference for the static route, in the range of 1 to 255. The default is 60.
tag tag-value: Sets a tag value for marking the static route, in the range of 1 to 4294967295. The default is 0.
recursive-lookup: Enables support for next hop recursion loops for the IPv4 static route. If you do not specify this keyword, the device does not support next hop recursion loops for the IPv4 static route.
description text: Configures a description of 1 to 150 characters for the static route. The description can include special characters, such as the space, except the question mark (?).
If the destination IP address and the mask are both 0.0.0.0 (or 0), the configured route is a default route. The default route is used for forwarding a packet matching no entry in the routing table.
Implement different routing policies to configure different route preferences. For example, to enable load sharing for multiple routes to the same destination, assign the same preference to the routes. To enable the routes to back up one another, assign different preferences to them.
Follow these guidelines when you specify the output interface or the next hop address of the static route:
·     If the output interface is a Null 0 interface, no next hop address is required.
·     If the output interface is a point-to-point interface, you can specify only the output interface. You do not need to change the configuration of the route even if the peer address is changed.
·     NBMA or P2MP interfaces need IP address-to-link layer address mappings for successful packet delivery. As a best practice, specify the next hop address for the route at the same time if the output interface is an NBMA or P2MP interface.
·     If the output interface is a broadcast interface, the device might have multiple next hops. Therefore, you must specify both the output interface and next hop IP address.
Follow these guidelines when you configure a static route:
·     If a static route needs route recursion, the associated track entry must monitor the next hop of the recursive route instead of that of the static route. Otherwise, a valid route might be mistakenly considered invalid.
·     Do not specify the permanent keyword together with the track keyword.
If you specify a static route group, all prefixes in the static route group will be assigned the next hop and output interface specified by using this command.
After an interface obtains an IP address and gateway address through DHCP, the device automatically generates a static route with the interface as the output interface. The destination address of the static route is 0.0.0.0/0 and the next hop of the static route is the default router (the gateway address designated by the DHCP server). This static route cannot form ECMP routes with manually configured static routes. The device uses this static route to guide traffic forwarding only after the manually configured static routes become invalid.
Specify the dhcp keyword to use both the automatically generated static route and the manually configured static routes to guide traffic forwarding. This keyword is applicable when the device has dual egress WAN links.
The dhcp keyword enables the device to automatically generate a static route destined for the specified network with the DHCP-designated default router of the output interface as the next hop. This static route takes effect only after the output interface obtains an IP address and gateway address through DHCP, and becomes invalid upon the DHCP lease expiration. The next hop of this static route changes as the gateway address of the output interface changes. In addition, this static route can form ECMP routes with manually configured static routes.
To specify the dhcp keyword, make sure the output interface of the static route is a broadcast interface.
If you do not specify the recursive-lookup longest-match or recursive-lookup host-route keyword, the static route preferentially recurses to a direct route. The static route recurses to the route with the longest matching mask only when no matching direct route is found. If the destination network address of the direct route contains the next hop address of the static route, the following conditions might exist:
·     The static route recurses the next hop to the direct route.
·     The device determines that the next hop address of the static route is locally connected.
However, the next hop might be incorrect, which results in failure to forward packets matching the static route. If you specify the recursive-lookup longest-match keyword, the static route recurses to the route with the longest matching mask to ensure correct next hop recursion. If you specify the recursive-lookup host-route keyword, the static route recurses to only a host route with a 32-bit mask, and the static route can be activated only when the host route is reachable.
A recursion loop occurs when an IPv4 static route recurses to a related route whose destination address contains the destination address of the IPv4 static route. For example, a recursion loop occurs when the IPv4 static route destined for 10.1.0.0/24 recurses to a related route whose destination address is 10.1.0.0/16.
·     If the recursive-lookup keyword is not specified, the recursion loop results in route recursion failure. The device further looks up for a related route.
·     If the recursive-lookup keyword is specified, the device determines that the recursion succeeds if the output interface of the related route is an interface directly connected to the device.
If the output interface of an IPv4 static route is found through recursion loops, routing protocols on the device cannot advertise the IPv4 static route to other devices.
The recursive-lookup host-route and recursive-lookup keywords are mutually exclusive. You cannot specify both of the keywords.
# Configure a static route, whose destination address is 1.1.1.1/24, next hop address is 2.2.2.2, tag value is 45, and description information is for internet.
[Sysname] ip route-static 1.1.1.1 24 2.2.2.2 tag 45 description for internet
display ip routing-table protocol
ip route-static-group
prefix
ip route-static arp-request
Use ip route-static arp-request to enable periodic sending of ARP requests to the next hops of static routes.
Use undo ip route-static arp-request to disable periodic sending of ARP requests to the next hops of static routes.
ip route-static arp-request [ interval interval ]
Periodic sending of ARP requests to the next hops of static routes is disabled.
interval: Specifies an ARP request sending interval in the range of 1 to 300 seconds. The default value is 5.
When the following conditions exist, a recursive static route becomes inactive:
·     The static route uses a host route to reach its direct next hop.
·     The host route is obtained by specifying the recursive-lookup host-route keyword in the ip route-static command or by routing policy-based recursive lookup.
·     The host route is unavailable because the direct next hop cannot send gratuitous ARP messages and consequently no ARP entry exists for that host route on the device.
To resolve this issue, you can use this command to enable the device to periodically send ARP requests to the direct next hop. When the device receives an ARP response from the direct next hop, it stops sending ARP requests and activates the recursive static route.
This command applies only to a recursive static route that meets the following requirements:
·     The static route has no output interface specified.
·     The static route fails the next-hop recursion.
# Enable sending of ARP requests to the next hops of static routes and set the sending interval to 10 seconds.
[Sysname] ip route-static arp-request interval 10
ip route-static
protocol nexthop recursive-lookup
ip route-static default-preference
Use ip route-static default-preference to configure a default preference for static routes.
Use undo ip route-static default-preference to restore the default.
ip route-static default-preference default-preference
The default preference of static routes is 60.
default-preference: Specifies a default preference for static routes, in the range of 1 to 255.
If no preference is specified for a static route, the default preference applies.
When the default preference is reconfigured, it applies only to newly added static routes.
# Set a default preference of 120 for static routes.
[Sysname] ip route-static default-preference 120
ip route-static fast-reroute auto
Use ip route-static fast-reroute auto to configure static route FRR to automatically select a backup next hop.
Use undo ip route-static fast-reroute auto to disable static route FRR from automatically selecting a backup next hop.
Static route FRR is disabled from automatically selecting a backup next hop.
# Configure static route FRR to automatically select a backup next hop.
[Sysname] ip route-static fast-reroute auto
Use ip route-static-group to create a static route group and enter its view, or enter the view of an existing static route group.
Use undo ip route-static-group to delete a static route group.
ip route-static-group group-name
undo ip route-static-group group-name
No static route groups exist.
group-name: Specifies the static route group name, a case-sensitive string of 1 to 31 characters.
# Create static route group test and enter its view.
[Sysname] ip route-static-group test
[Sysname-route-static-group-test]
ip route-static
prefix
prefix
Use prefix to add a static route prefix to a static route group.
Use undo prefix to delete a static route prefix from a static route group.
prefix dest-address { mask-length | mask }
undo prefix dest-address { mask-length | mask }
No static route prefix is added to a static route group.
Static route group view
Execute this command repeatedly to add multiple static route prefixes to a static route group.
After you add static route prefixes to a static route group, you can specify that group in the ip route-static group command to configure static routes with the prefixes. To configure more static routes, you only need to add new static route prefixes to the group.
# Add static route prefix 1.1.1.1/32 to static route group test.
[Sysname-route-static-group-test] prefix 1.1.1.1 32
ip route-static
