- 05-Network Connectivity Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-Loop detection commands
- 06-Spanning tree commands
- 07-LLDP commands
- 08-Layer 2 forwarding commands
- 09-L2TP commands
- 10-ARP commands
- 11-IP addressing commands
- 12-DHCP commands
- 13-DHCP snooping commands
- 14-DHCPv6 commands
- 15-DHCPv6 snooping commands
- 16-DNS commands
- 17-HTTP commands
- 18-HTTP redirect commands
- 19-IP forwarding basics commands
- 20-Fast forwarding commands
- 21-Adjacency table commands
- 22-IP performance optimization commands
- 23-IPv6 basics commands
- 24-IPv6 neighbor discovery commands
- 25-IPv6 fast forwarding commands
- 26-NAT commands
- 27-GRE commands
- 28-Basic IP routing commands
- 29-Static routing commands
- 30-OSPF commands
- 31-Policy-based routing commands
- 32-IPv6 static routing commands
- 33-IPv6 policy-based routing commands
- 34-IGMP snooping commands
- 35-MLD snooping commands
| 00-Preface | 108.74 KB |
Preface
This command reference describes the network connectivity configuration commands.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
