05-Network Connectivity Command Reference
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesCommand ReferencesH3C WX3800X Series Access Controllers Command References(R1411P02)-6W10005-Network Connectivity Command Reference
20-Fast forwarding commands
20-Fast forwarding commands 63.26 KB
display ip fast-forwarding aging-time
Use display ip fast-forwarding aging-time to display the aging time of fast forwarding entries.
# Display the aging time of fast forwarding entries.
<Sysname> display ip fast-forwarding aging-time
 Aging time: 30
display ip fast-forwarding cache
Use display ip fast-forwarding cache to display fast forwarding entries.
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ]
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays all fast forwarding entries.
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command displays fast forwarding entries for all member devices.
# Display all fast forwarding entries.
<Sysname> display ip fast-forwarding cache
Total number of fast-forwarding entries: 1
SIP            SPort DIP            DPort Pro Input_If   Output_If   Flg
7.0.0.13       68    8.0.0.1        67    17  GE1/0/3    GE1/0/1     5
SIP
Source IP address.
SPort
Source port number.
DIP
Destination IP address.
DPort
Destination port number.
Pro
Protocol number.
Input_If
Input interface type and number.
If no interface is involved in fast forwarding, this field displays N/A.
If the input interface does not exist, this field displays a hyphen (-).
Output_If
Output interface type and number.
If the output interface does not exist, this field displays a hyphen (-).
Flg
Internal tag, marking internal operation information, such as fragmentation.
reset ip fast-forwarding cache
display ip fast-forwarding fragcache
Use display ip fast-forwarding fragcache to display fast forwarding entries for fragmented packets.
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ]
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays fast forwarding entries for all fragmented packets.
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command displays fast forwarding entries for fragmented packets on all member devices.
# Display fast forwarding entries about all fragmented packets.
<Sysname> display ip fast-forwarding fragcache
Total number of fragment fast-forwarding entries: 1
SIP             SPort DIP             DPort Pro Input_If    ID
7.0.0.13        68    8.0.0.1         67    17  GE1/0/3     2
SIP
Source IP address.
SPort
Source port number.
DIP
DPort
Pro
Protocol number.
Input_If
ID
Fragment ID.
Use ip fast-forwarding aging-time to configure the aging time for fast forwarding entries.
Use undo ip fast-forwarding aging-time to restore the default.
ip fast-forwarding aging-time aging-time
The aging time is 30 seconds.
aging-time: Specifies the aging time in the range of 10 to 300 seconds.
# Set the aging time to 20 seconds for fast forwarding entries.
[Sysname] ip fast-forwarding aging-time 20
ip fast-forwarding load-sharing
Use ip fast-forwarding load-sharing to enable fast forwarding load sharing.
Use undo ip fast-forwarding load-sharing to disable fast forwarding load sharing.
Fast forwarding load sharing is enabled.
Fast forwarding load sharing enables the device to load share packets of the same flow. This feature identifies a data flow by using the packet information.
If fast forwarding load sharing is disabled, the device identifies a data flow by the packet information and the input interface. No load sharing is implemented.
# Enable fast forwarding load sharing.
<Sysname> system-Views
[Sysname] ip fast-forwarding load-sharing
Use reset ip fast-forwarding cache to clear the fast forwarding table.
reset ip fast-forwarding cache [ slot slot-number ]
Predefined use roles
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command clears the fast forwarding table for all member devices.
# Clear the fast forwarding table.
<Sysname> reset ip fast-forwarding cache
