10-IPV6-MIB | 139.58 KB |
ipv6Forwarding (1.3.6.1.2.1.55.1.1)
ipv6DefaultHopLimit (1.3.6.1.2.1.55.1.2)
ipv6Interfaces (1.3.6.1.2.1.55.1.3)
ipv6RouteNumber (1.3.6.1.2.1.55.1.9)
IPV6-MIB
About this MIB
Use this MIB to implement IPv6.
MIB file name
rfc2465-ipv6.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ipv6MIB(55)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6Forwarding (1.3.6.1.2.1.55.1.1) |
read-write |
INTEGER |
forwarding(1) notForwarding(2) |
Whether this entity is acting as an IPv6 router for the forwarding of datagrams received by, but not addressed to, this entity. |
Read only. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6DefaultHopLimit (1.3.6.1.2.1.55.1.2) |
read-write |
INTEGER |
INTEGER (0..255) |
Default value inserted into the Hop Limit field of the IPv6 header of datagrams originated at this entity. |
Read only. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6Interfaces (1.3.6.1.2.1.55.1.3) |
read-only |
Unsigned32 |
Standard MIB values. |
Number of IPv6 interfaces. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6RouteNumber (1.3.6.1.2.1.55.1.9) |
read-only |
Gauge32 |
Total number of IPv6 unicast routing entries used for packet forwarding to public network destinations. |
As per the MIB. |
ipv6DiscardedRoutes (1.3.6.1.2.1.55.1.10)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6DiscardedRoutes (1.3.6.1.2.1.55.1.10) |
read-only |
Counter32 |
Number of discarded IPv6 routes. |
As per the MIB. |
Tabular objects
ipv6IfTable
About this table
Use this table to obtain IPv6 interface information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ipv6IfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6IfIndex (1.3.6.1.2.1.55.1.5.1.1) |
not-accessible |
Ipv6IfIndex |
(1..2147483647) |
Interface index. |
As per the MIB. |
ipv6IfDescr (1.3.6.1.2.1.55.1.5.1.2) |
read-write |
DisplayString |
(0..255) |
Interface description. |
Cannot exceed 255 characters. |
ipv6IfEffectiveMtu (1.3.6.1.2.1.55.1.5.1.4) |
read-only |
Unsigned32 |
Interface MTU. |
As per the MIB. |
ipv6IfIdentifier (1.3.6.1.2.1.55.1.5.1.6) |
read-write |
Ipv6AddressIfIdentifier |
Interface identifier. |
Read only. |
ipv6IfIdentifierLength (1.3.6.1.2.1.55.1.5.1.7) |
read-write |
INTEGER |
INTEGER(0..64) |
Length of the interface identifier. |
Read only. |
ipv6IfPhysicalAddress (1.3.6.1.2.1.55.1.5.1.8) |
read-only |
PhysAddress |
Physical address of the interface. |
As per the MIB. |
ipv6IfAdminStatus (1.3.6.1.2.1.55.1.5.1.9) |
read-write |
INTEGER |
up(1) down(2) |
Desired state of the interface. |
Read only. |
ipv6IfOperStatus (1.3.6.1.2.1.55.1.5.1.10) |
read-only |
INTEGER |
up(1) down(2) noIfIdentifier(3) unknown(4) notPresent(5) |
Operating state of the interface. |
As per the MIB. |
ipv6IfLastChange (1.3.6.1.2.1.55.1.5.1.11) |
read-only |
TimeStamp |
During since the interface has entered its current operating state. |
As per the MIB. |
ipv6IfStatsTable
About this table
Use this table to obtain the IPv6 interface forwarding statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6IfStatsInReceives (1.3.6.1.2.1.55.1.6.1.1) |
read-only |
Counter32 |
Total number of input datagrams received by the interface. |
As per the MIB. |
ipv6IfStatsInHdrErrors (1.3.6.1.2.1.55.1.6.1.2) |
read-only |
Counter32 |
Number of input datagrams discarded due to errors in their IPv6 headers. |
As per the MIB. |
ipv6IfStatsInTooBigErrors (1.3.6.1.2.1.55.1.6.1.3) |
read-only |
Counter32 |
Number of input datagrams that cannot be forwarded because their size exceeds the link MTU of the outgoing interface. |
As per the MIB. |
ipv6IfStatsInNoRoutes (1.3.6.1.2.1.55.1.6.1.4) |
read-only |
Counter32 |
Number of input datagrams discarded because no route can be found to transmit them to their destinations. |
As per the MIB. |
ipv6IfStatsInAddrErrors (1.3.6.1.2.1.55.1.6.1.5) |
read-only |
Counter32 |
Number of input datagrams discarded because the IPv6 address in their IPv6 header's destination field was not a valid address. |
As per the MIB. |
ipv6IfStatsInUnknownProtos (1.3.6.1.2.1.55.1.6.1.6) |
read-only |
Counter32 |
Number of locally-addressed datagrams received successfully but discarded because of an unknown or unsupported protocol. |
As per the MIB. |
ipv6IfStatsInTruncatedPkts (1.3.6.1.2.1.55.1.6.1.7) |
read-only |
Counter32 |
Number of input datagrams discarded because datagram frame did not carry enough data. |
As per the MIB. |
ipv6IfStatsInDiscards (1.3.6.1.2.1.55.1.6.1.8) |
read-only |
Counter32 |
Number of input IPv6 datagrams discarded due to unknown errors. |
As per the MIB. |
ipv6IfStatsInDelivers (1.3.6.1.2.1.55.1.6.1.9) |
read-only |
Counter32 |
Total number of datagrams successfully delivered. |
As per the MIB. |
ipv6IfStatsOutForwDatagrams (1.3.6.1.2.1.55.1.6.1.10) |
read-only |
Counter32 |
Number of output datagrams this entity received and forwarded to their final destinations. |
As per the MIB. |
ipv6IfStatsOutRequests (1.3.6.1.2.1.55.1.6.1.11) |
read-only |
Counter32 |
Total number of IPv6 datagrams that local protocols supplied to IPv6 in requests for transmission. |
As per the MIB. |
ipv6IfStatsOutDiscards (1.3.6.1.2.1.55.1.6.1.12) |
read-only |
Counter32 |
Number of output IPv6 datagrams discarded due to unknown errors. |
As per the MIB. |
ipv6IfStatsOutFragOKs (1.3.6.1.2.1.55.1.6.1.13) |
read-only |
Counter32 |
Number of IPv6 datagrams that have been successfully fragmented at the interface. |
As per the MIB. |
ipv6IfStatsOutFragFails (1.3.6.1.2.1.55.1.6.1.14) |
read-only |
Counter32 |
Number of IPv6 datagrams that have been discarded because they failed to be fragmented as required at the interface. |
As per the MIB. |
ipv6IfStatsOutFragCreates (1.3.6.1.2.1.55.1.6.1.15) |
read-only |
Counter32 |
Number of output datagram fragments that have been generated as a result of fragmentation at the interface. |
As per the MIB. |
ipv6IfStatsReasmReqds (1.3.6.1.2.1.55.1.6.1.16) |
read-only |
Counter32 |
Number of received IPv6 fragments which that needed to be reassembled at the interface. |
As per the MIB. |
ipv6IfStatsReasmOKs (1.3.6.1.2.1.55.1.6.1.17) |
read-only |
Counter32 |
Number of IPv6 datagrams successfully reassembled. |
As per the MIB. |
ipv6IfStatsReasmFails (1.3.6.1.2.1.55.1.6.1.18) |
read-only |
Counter32 |
Number of failures detected by IPv6 re-assembly. |
As per the MIB. |
ipv6IfStatsInMcastPkts (1.3.6.1.2.1.55.1.6.1.19) |
read-only |
Counter32 |
Number of multicast packets received by the interface. |
As per the MIB. |
ipv6IfStatsOutMcastPkts (1.3.6.1.2.1.55.1.6.1.20) |
read-only |
Counter32 |
Number of multicast packets transmitted by the interface. |
As per the MIB. |
ipv6AddrPrefixTable
About this table
Use this table to obtain the IPv6 address prefix information for an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ipv6IfIndex, ipv6AddrPrefix, and ipv6AddrPrefixLength.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6AddrPrefix (1.3.6.1.2.1.55.1.7.1.1) |
not-accessible |
Ipv6AddressPrefix |
(0..255) |
IPv6 address prefix associated with the interface. |
As per the MIB. |
ipv6AddrPrefixLength (1.3.6.1.2.1.55.1.7.1.2) |
not-accessible |
INTEGER |
INTEGER (0..128) |
Length of the prefix. |
As per the MIB. |
ipv6AddrPrefixOnLinkFlag (1.3.6.1.2.1.55.1.7.1.3) |
read-only |
TruthValue |
true(1) false(2) |
Whether the prefix can be used for on-link determination. |
As per the MIB. |
ipv6AddrPrefixAutonomousFlag(1.3.6.1.2.1.55.1.7.1.4) |
read-only |
TruthValue |
true(1) false(2) |
Autonomous address configuration flag to determine if the prefix can be used to form a local interface address. |
As per the MIB. |
ipv6AddrPrefixAdvPreferredLifetime (1.3.6.1.2.1.55.1.7.1.5) |
read-only |
Unsigned32 |
Length of time in seconds that this prefix will remain preferred. |
As per the MIB. |
ipv6AddrPrefixAdvValidLifetime (1.3.6.1.2.1.55.1.7.1.6) |
read-only |
Unsigned32 |
Length of time in seconds that this prefix will remain valid. |
As per the MIB. |
ipv6AddrTable
About this table
Use this table to obtain the node's IPv6 address information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ipv6IfIndex and ipv6AddrAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6AddrAddress (1.3.6.1.2.1.55.1.8.1.1) |
not-accessible |
Ipv6Address |
IPv6 address to which the entry's addressing information belongs. |
As per the MIB. |
ipv6AddrPfxLength (1.3.6.1.2.1.55.1.8.1.2) |
read-only |
Ipv6Address |
(0..128) |
Length of the prefix associated with the IPv6 address of the entry. |
As per the MIB. |
ipv6AddrType (1.3.6.1.2.1.55.1.8.1.3) |
read-only |
INTEGER |
stateless(1) stateful(2) unknown(3) |
Address type. |
Do not support unknown. |
ipv6AddrAnycastFlag (1.3.6.1.2.1.55.1.8.1.4) |
read-only |
TruthValue |
true(1) false(2) |
Anycast address flag. |
As per the MIB. |
ipv6AddrStatus (1.3.6.1.2.1.55.1.8.1.5) |
read-only |
INTEGER |
preferred(1) deprecated(2) invalid(3) inaccessible(4) unknown(5) |
Address status. |
As per the MIB. |
ipv6RouteTable
About this table
Use this table to obtain IPv6 routing table.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ipv6RouteDest, ipv6RoutePfxLength, and ipv6RouteIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6RouteDest (1.3.6.1.2.1.55.1.11.1.1) |
not-accessible |
Ipv6Address |
Destination IPv6 address of a route. |
As per the MIB. |
ipv6RoutePfxLength (1.3.6.1.2.1.55.1.11.1.2) |
not-accessible |
INTEGER |
INTEGER (0..128) |
Prefix length of the destination address. |
As per the MIB. |
ipv6RouteIndex (1.3.6.1.2.1.55.1.11.1.3) |
not-accessible |
Unsigned32 |
Route index, which uniquely identifies the route among the routes to the same network layer destination. |
As per the MIB. |
ipv6RouteIfIndex (1.3.6.1.2.1.55.1.11.1.4) |
read-only |
Ipv6IfIndexOrZero |
Output interface index. |
As per the MIB. |
ipv6RouteNextHop (1.3.6.1.2.1.55.1.11.1.5) |
read-only |
Ipv6Address |
Nexthop address. |
As per the MIB. |
ipv6RouteType (1.3.6.1.2.1.55.1.11.1.6) |
read-only |
INTEGER |
other(1), discard(2), local(3), remote(4) |
Type of the route. |
As per the MIB. |
ipv6RouteProtocol (1.3.6.1.2.1.55.1.11.1.7) |
read-only |
INTEGER |
other(1), local(2), netmgmt(3), ndisc(4), rip(5), ospf(6), bgp(7), idrp(8), igrp(9) |
Routing protocol type. |
As per the MIB. |
ipv6RoutePolicy (1.3.6.1.2.1.55.1.11.1.8) |
read-only |
Integer32 |
General set of route information. |
As per the MIB. |
ipv6RouteAge (1.3.6.1.2.1.55.1.11.1.9) |
read-only |
Unsigned32 |
Lifetime of the route. |
As per the MIB. |
ipv6RouteNextHopRDI (1.3.6.1.2.1.55.1.11.1.10) |
read-only |
Unsigned32 |
Routing domain ID of the next hop. |
As per the MIB. |
ipv6RouteMetric (1.3.6.1.2.1.55.1.11.1.11) |
read-only |
Unsigned32 |
Metric of the route. |
As per the MIB. |
ipv6RouteWeight (1.3.6.1.2.1.55.1.11.1.12) |
read-only |
Unsigned32 |
Weight of the route. |
As per the MIB. |
ipv6RouteInfo (1.3.6.1.2.1.55.1.11.1.13) |
read-only |
RowPointer |
Route information. |
As per the MIB. |
ipv6RouteValid (1.3.6.1.2.1.55.1.11.1.14) |
read-write |
TruthValue |
true(1), false(2) |
Whether the route is valid. |
Read only. |
ipv6NetToMediaTable
About this table
Use this table to configure the mapping between an IPv6 address and the physical address for an interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ipv6IfIndex and ipv6NetToMediaNetAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6NetToMediaNetAddress (1.3.6.1.2.1.55.1.12.1.1) |
not-accessible |
Ipv6Address |
Interface IPv6 address. |
As per the MIB. |
ipv6NetToMediaPhysAddress (1.3.6.1.2.1.55.1.12.1.2) |
read-only |
PhysAddress |
Interface physical address. |
As per the MIB. |
ipv6NetToMediaType (1.3.6.1.2.1.55.1.12.1.3) |
read-only |
INTEGER |
other(1) dynamic(2) static(3) local(4) |
Mapping type. |
As per the MIB. |
ipv6IfNetToMediaState (1.3.6.1.2.1.55.1.12.1.4) |
read-only |
INTEGER |
reachable(1) stale(2) delay(3) probe(4) invalid(5) unknown(6) |
Neighbor Unreachability Detection state for the interface when the address mapping in this entry is used. |
As per the MIB. |
ipv6IfNetToMediaLastUpdated (1.3.6.1.2.1.55.1.12.1.5) |
read-only |
TimeStamp |
Time since the entry was last updated. |
As per the MIB. |
ipv6NetToMediaValid (1.3.6.1.2.1.55.1.12.1.6) |
read-write |
TruthValue |
true(1) false(2) |
Whether the entry is invalid. |
Read only. |
Notifications
ipv6IfStateChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.55.2.0.1 |
IPv6 interface state change |
Informational |
Warning |
ON |
Notification triggers
This notification is generated when the state of an interface link or the IPv6 address of an interface has changed.
System impact
If the link or interface state is not UP, IPv6 services on the interface might become unavailable.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface information. |
DisplayString |
DisplayString (0..255) |
Interface state. |
ipv6IfIndex |
INTEGER |
Recommended action
Check the interface connection and the interface address.
