02-HH3C-DHCP-SNOOP2-MIB | 145.50 KB |
hh3cDhcpSnoop2Enabled (1.3.6.1.4.1.25506.2.124.1.1.1)
hh3cDhcpSnoop2BindDbName (1.3.6.1.4.1.25506.2.124.1.1.2)
hh3cDhcpSnoop2BindRefreshIntvl (1.3.6.1.4.1.25506.2.124.1.1.3)
hh3cDhcpSnoop2BindRefresh (1.3.6.1.4.1.25506.2.124.1.1.4)
hh3cDhcpSnoop2PktSentNum (1.3.6.1.4.1.25506.2.124.1.2.1)
hh3cDhcpSnoop2PktRcvNum (1.3.6.1.4.1.25506.2.124.1.2.2)
About this MIB
Use this MIB to implement DHCP snooping configuration, DHCP snooping entry acquisition, and alarm configuration.
MIB file name
hh3c-dhcp-snoop2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDhcpSnoop2(124)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpSnoop2Enabled (1.3.6.1.4.1.25506.2.124.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of DHCP snooping. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpSnoop2BindDbName (1.3.6.1.4.1.25506.2.124.1.1.2) |
read-write |
OCTET STRING |
OCTET STRING (0..255) |
Name of the file for saving DHCP snooping entries. |
The name string cannot exceed the product-specific upper limit. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpSnoop2BindRefreshIntvl (1.3.6.1.4.1.25506.2.124.1.1.3) |
read-write |
Unsigned32 |
Unsigned32(60..864000) |
DHCPv6 snooping entry refreshing interval. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpSnoop2BindRefresh (1.3.6.1.4.1.25506.2.124.1.1.4) |
read-write |
INTEGER |
on(1) |
Immediate saving of DHCP snooping entries. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpSnoop2PktSentNum (1.3.6.1.4.1.25506.2.124.1.2.1) |
read-only |
Counter64 |
INTEGER(0..18446744073709551615) |
Number of packets forwarded by DHCP snooping. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpSnoop2PktRcvNum (1.3.6.1.4.1.25506.2.124.1.2.2) |
read-only |
Counter64 |
Number of packets received by DHCP snooping. |
As per the MIB. |
hh3cDhcpSnoop2PktDropNum (1.3.6.1.4.1.25506.2.124.1.2.3)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpSnoop2PktDropNum (1.3.6.1.4.1.25506.2.124.1.2.3) |
read-only |
Counter64 |
Number of packets dropped by DHCP snooping. |
As per the MIB. |
Tabular objects
hh3cDhcpSnoop2BindTable
About this table
This table describes a DHCP snooping entry.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are h3cDhcpSnoop2BindIpAddr, h3cDhcpSnoop2BindVlanId, and h3cDhcpSnoop2BindSecVlanId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpSnoop2BindIpAddr (1.3.6.1.4.1.25506.2.124.2.1.1.1) |
not-accessible |
InetAddressIPv4 |
OCTET STRING (4) |
IP address assigned to a DHCP client. |
As per the MIB. |
hh3cDhcpSnoop2BindVlanId (1.3.6.1.4.1.25506.2.124.2.1.1.2) |
not-accessible |
Unsigned32 |
Unsigned32(1..4094) |
Outer VLAN tag of the DHCP packet. |
As per the MIB. |
hh3cDhcpSnoop2BindSecVlanId (1.3.6.1.4.1.25506.2.124.2.1.1.3) |
not-accessible |
Unsigned32 |
Unsigned32(1..4094|65535) |
Inner VLAN tag of the DHCP packet. |
As per the MIB. |
hh3cDhcpSnoop2BindMacAddr (1.3.6.1.4.1.25506.2.124.2.1.1.4) |
read-only |
MacAddress |
OCTET STRING (6) |
MAC address of the DHCP client. |
As per the MIB. |
hh3cDhcpSnoop2BindLease (1.3.6.1.4.1.25506.2.124.2.1.1.5) |
read-only |
Unsigned32 |
Standard MIB values. |
Remaining time of the lease for the DHCP client. |
As per the MIB. |
hh3cDhcpSnoop2BindPortIndex (1.3.6.1.4.1.25506.2.124.2.1.1.6) |
read-only |
InterfaceIndexOrZero |
Integer32(0..2147483647) |
Interface that connects to the DHCP client. |
As per the MIB. |
hh3cDhcpSnoop2BindRowStatus (1.3.6.1.4.1.25506.2.124.2.1.1.7) |
read-create |
RowStatus |
Support only the destroy operation |
Row status. |
As per the MIB. |
hh3cDhcpSnoop2IfConfigTable
About this table
This table describes the DHCP snooping configuration on interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifindex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpSnoop2IfTrustStatus (1.3.6.1.4.1.25506.2.124.2.2.1.1) |
read-write |
INTEGER |
untrusted(0), trusted(1) |
Enabling status of the DHCP snooping trusted interface. |
As per the MIB. |
hh3cDhcpSnoop2IfCheckMac (1.3.6.1.4.1.25506.2.124.2.2.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of the MAC address check. |
As per the MIB. |
hh3cDhcpSnoop2IfCheckRequest (1.3.6.1.4.1.25506.2.124.2.2.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of the DHCP-REQUEST check. |
As per the MIB. |
hh3cDhcpSnoop2IfRateLimit (1.3.6.1.4.1.25506.2.124.2.2.1.4) |
read-write |
Unsigned32 |
DHCP snooping packet rate limit on the interface. |
As per the MIB. |
hh3cDhcpSnoop2IfRecordBind (1.3.6.1.4.1.25506.2.124.2.2.1.5) |
read-write |
TruthValue |
true(1), false(2) |
Recording DHCP snooping entries. |
As per the MIB. |
hh3cDhcpSnoop2IfMaxLearnNum (1.3.6.1.4.1.25506.2.124.2.2.1.6) |
read-write |
Unsigned32 |
Unsigned32(0..4294967295) |
Maximum number of DHCP snooping entries that the interface can learn. |
As per the MIB. |
hh3cDhcpSnoop2IfOpt82Enable (1.3.6.1.4.1.25506.2.124.2.2.1.7) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of Option 82 support |
As per the MIB. |
hh3cDhcpSnoop2IfOpt82Strategy (1.3.6.1.4.1.25506.2.124.2.2.1.8) |
read-write |
INTEGER |
drop(1), keep(2), replace(3) |
Option 82 strategy |
As per the MIB. |
hh3cDhcpSnoop2IfOpt82CIDMode (1.3.6.1.4.1.25506.2.124.2.2.1.9) |
read-write |
INTEGER |
normal(1), verbose(2), userDefine(3) bas(4) |
Mode of the Circuit ID sub-option in Option 82. |
As per the MIB. |
hh3cDhcpSnoop2IfOpt82CIDNodeType (1.3.6.1.4.1.25506.2.124.2.2.1.10) |
read-write |
INTEGER |
invalid(1), mac(2), sysname(3), userDefine(4) |
Format of the Circuit ID sub-option in verbose mode. |
As per the MIB. |
hh3cDhcpSnoop2IfOpt82CIDNodeStr (1.3.6.1.4.1.25506.2.124.2.2.1.11) |
read-write |
OCTET STRING |
OCTET STRING (0..50) |
User-defined string for the Circuit ID sub-option in verbose mode. |
As per the MIB. |
hh3cDhcpSnoop2IfOpt82CIDStr (1.3.6.1.4.1.25506.2.124.2.2.1.12) |
read-write |
OCTET STRING |
OCTET STRING (0|3..63) |
User-defined string for the Circuit ID sub-option in user-defined mode. |
As per the MIB. |
hh3cDhcpSnoop2IfOpt82CIDFormat (1.3.6.1.4.1.25506.2.124.2.2.1.13) |
read-write |
INTEGER |
hex(1), ascii(2), undefine(3) |
Padding format of the Circuit ID sub-option. |
As per the MIB. |
hh3cDhcpSnoop2IfOpt82RIDMode (1.3.6.1.4.1.25506.2.124.2.2.1.14) |
read-write |
INTEGER |
normal(1), sysname(2), userDefine(3) |
Mode of the Remote ID sub-option in Option 82. |
As per the MIB. |
hh3cDhcpSnoop2IfOpt82RIDStr (1.3.6.1.4.1.25506.2.124.2.2.1.15) |
read-write |
OCTET STRING |
OCTET STRING (0..63) |
User-defined string for the Remote ID sub-option in user-defined mode. |
As per the MIB. |
hh3cDhcpSnoop2IfOpt82RIDFormat (1.3.6.1.4.1.25506.2.124.2.2.1.16) |
read-write |
INTEGER |
hex(1), ascii(2) |
Padding format of the Remote ID sub-option. |
As per the MIB. |
hh3cDhcpSnoop2IfVlanCIDTable
About this table
This table describes Option 82 Circuit ID sub-option configuration in VLANs.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ifIndex and h3cDhcpSnoop2IfVlanCIDVlanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpSnoop2IfVlanCIDVlanIndex (1.3.6.1.4.1.25506.2.124.2.3.1.1) |
not-accessible |
Unsigned32 |
VLAN ID. |
As per the MIB. |
hh3cDhcpSnoop2IfVlanCIDStr (1.3.6.1.4.1.25506.2.124.2.3.1.2) |
read-create |
OCTET STRING |
OCTET STRING (3..63) |
User-defined string for padding the Circuit ID sub-option. |
As per the MIB. |
hh3cDhcpSnoop2IfVlanCIDRowStatus (1.3.6.1.4.1.25506.2.124.2.3.1.3) |
read-create |
RowStatus |
Active(1), createAndGo(4), destroy(6). |
Row status. |
As per the MIB. |
hh3cDhcpSnoop2IfVlanRIDTable
About this table
This table describes Option 82 Remote ID sub-option configuration in VLANs.
Create |
Edit/Modify |
Delete |
Read |
Supported. It must be bound to h3cDhcpSnoop2IfVlanRIDMode when you create an entry. |
Supported. It must be bound to h3cDhcpSnoop2IfVlanRIDMode when you modify an entry. |
Supported |
Supported |
Columns
The table indexes are ifIndex and h3cDhcpSnoop2IfVlanRIDVlanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDhcpSnoop2IfVlanRIDVlanIndex (1.3.6.1.4.1.25506.2.124.2.4.1.1) |
not-accessible |
Unsigned32 |
VLAN ID. |
As per the MIB. |
hh3cDhcpSnoop2IfVlanRIDMode (1.3.6.1.4.1.25506.2.124.2.4.1.2) |
read-create |
INTEGER |
sysname(1), userDefine(2) |
Padding mode of the Remote ID sub-option. |
As per the MIB. |
hh3cDhcpSnoop2IfVlanRIDStr (1.3.6.1.4.1.25506.2.124.2.4.1.3) |
read-create |
OCTET STRING |
User-defined string for padding the Remote ID sub-option. |
If the padding mode for the Remote ID sub-option is sysname(1), the value read from this object is 0. |
hh3cDhcpSnoop2IfVlanRIDRowStatus (1.3.6.1.4.1.25506.2.124.2.4.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
