05-HH3C-IP-ADDRESS-MIB | 85.44 KB |
hh3cIpAddrNotifyIfIndex (1.3.6.1.4.1.25506.2.67.2.1.1)
hh3cIpAddrOldIpAddress (1.3.6.1.4.1.25506.2.67.2.1.2)
HH3C-IP-ADDRESS-MIB
About this MIB
Use this MIB to obtain and configure IPv4 addresses.
MIB file name
hh3c-ip-address.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpAddrMIB(67)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpAddrNotifyIfIndex (1.3.6.1.4.1.25506.2.67.2.1.1) |
accessible-for-notify |
Integer32 |
Integer32 (1..2147483647) |
Interface index. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpAddrOldIpAddress (1.3.6.1.4.1.25506.2.67.2.1.2) |
InetAddress |
OCTET STRING (0..255) |
Old IP address. |
As per the MIB. |
hh3cIpAddrNewIpAddress (1.3.6.1.4.1.25506.2.67.2.1.3)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpAddrNewIpAddress (1.3.6.1.4.1.25506.2.67.2.1.3) |
InetAddress |
New IP address. |
As per the MIB. |
Tabular objects
hh3cIpAddrSetTable
About this table
Use this table to configure IPv4 addresses.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cIpAddrSetIfIndex, hh3cIpAddrSetAddrType, and hh3cIpAddrSetAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpAddrSetIfIndex (1.3.6.1.4.1.25506.2.67.1.1.1.1.1) |
not-accessible |
Integer32 |
Interface index. |
As per the MIB. |
hh3cIpAddrSetAddrType (1.3.6.1.4.1.25506.2.67.1.1.1.1.2) |
not-accessible |
InetAddressType |
ipv4(1) |
IP address version. |
Only support ipv4(1) |
hh3cIpAddrSetAddr (1.3.6.1.4.1.25506.2.67.1.1.1.1.3) |
not-accessible |
InetAddress |
IP address. |
As per the MIB. |
hh3cIpAddrSetMask (1.3.6.1.4.1.25506.2.67.1.1.1.1.4) |
read-create |
IpAddress |
OCTET STRING (4) |
Address mask. |
As per the MIB. |
hh3cIpAddrSetSourceType (1.3.6.1.4.1.25506.2.67.1.1.1.1.5) |
read-create |
INTEGER |
assignedIp(1) |
Source type of the IPv4 address. |
As per the MIB. |
hh3cIpAddrSetCatalog (1.3.6.1.4.1.25506.2.67.1.1.1.1.6) |
read-create |
INTEGER |
primary(1), sub(2) |
Type of the IPv4 address. |
As per the MIB. |
hh3cIpAddrSetRowStatus (1.3.6.1.4.1.25506.2.67.1.1.1.1.7) |
read-create |
RowStatus |
active(1), createAndGo(4), destroy(6) |
Row status of the IPv4 address. |
Support active(1), createAndGo(4), and destroy(6) The value active(1) is read only. |
hh3cIpAddrReadTable
About this table
Use this table to obtain IPv4 addresses.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cIpAddrReadIfIndex, hh3cIpAddrReadAddrType, hh3cIpAddrReadAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpAddrReadIfIndex (1.3.6.1.4.1.25506.2.67.1.1.2.1.1) |
not-accessible |
Integer32 |
Interface index. |
As per the MIB. |
hh3cIpAddrReadAddrType (1.3.6.1.4.1.25506.2.67.1.1.2.1.2) |
not-accessible |
InetAddressType |
ipv4(1) |
Only support ipv4(1). |
hh3cIpAddrReadAddr (1.3.6.1.4.1.25506.2.67.1.1.2.1.3) |
not-accessible |
InetAddress |
IP address. |
As per the MIB. |
hh3cIpAddrReadMask (1.3.6.1.4.1.25506.2.67.1.1.2.1.4) |
read-only |
IpAddress |
OCTET STRING (4) |
Address mask. |
As per the MIB. |
hh3cIpAddrReadSourceType (1.3.6.1.4.1.25506.2.67.1.1.2.1.5) |
read-only |
INTEGER |
assignedIp(1), cluster(2), dhcp(3), bootp(4), negotiate(5), unnumbered(6), vrrp(7),cellar(8),mad(9) |
As per the MIB. |
hh3cIpAddrReadCatalog (1.3.6.1.4.1.25506.2.67.1.1.2.1.6) |
read-only |
INTEGER |
primary(1), sub(2), cluster(3), vrrp(4),backup(5) |
As per the MIB. |
hh3cIpv4AddrTable
About this table
Use this table to configure the primary IPv4 address of an interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpv4AddrAddr (1.3.6.1.4.1.25506.2.67.1.1.3.1.1) |
read-create |
IpAddress |
OCTET STRING (4) |
IP address. |
If the interface has no primary or secondary IP address, the value is 0.0.0.0. |
hh3cIpv4AddrMask (1.3.6.1.4.1.25506.2.67.1.1.3.1.2) |
read-create |
IpAddress |
OCTET STRING (4) |
Address mask. |
As per the MIB. |
hh3cIpv4AddrRowStatus (1.3.6.1.4.1.25506.2.67.1.1.3.1.3) |
read-create |
RowStatus |
active(1) , notInService(2) , createAndGo(4) , destroy(6) |
Row status of the address configuration. |
Support active(1), notInService(2), createAndGo(4), and destroy(6). If the interface has primary or secondary IP address, the value is active(1). If the interface has no primary or secondary IP address, the value is notInService(2). |
Notifications
hh3cIpAddressChangeNotify
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.67.2.2.0.1 |
Address change. |
Informational |
Warning |
ON |
Notification triggers
This notification is generated when the IP address of an interface changes.
System impact
The IP address of an interface changes, which might cause service interruption.
Status control
The SNMP notification for IP address change cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Interface index. |
N/A |
Integer32 |
Previous IP address. |
N/A |
InetAddress |
New IP address. |
N/A |
InetAddress |
hh3cIpAddrFirstTrapTime (1.3.6.1.4.1.25506.2.67.2.1.4) |
Time when the first SNMP notification was sent. |
N/A |
TimeTicks |
TimeTicks (0 to 4294967295) |
Recommended action
Use the display ip interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief ] command to view the interface IP address and verify that the IP address change is as expected. If the IP address is changed unexpectedly, correct the error in time to avoid service interruption.
