02-HH3C-3GMODEM-MIB | 192.29 KB |
HH3C-3GMODEM-MIB
About this MIB
Use this MIB to retrieve basic information, collect diagnostic information, and configure network connection settings for the 3G modem.
MIB file name
hh3c-3gmodem.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3c3GModem(98)
Tabular objects
hh3cWirelessCardTable
About this table
Use this table to obtain detailed information about the USB 3G modem/SIC-3G modem.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cWirelessCardIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cWirelessCardIndex (1.3.6.1.4.1.25506.2.98.1.1.1.1.1) |
read-only |
Integer32 |
Integer32 (1..2147483647) |
Index of the 3G modem. |
As per the MIB. |
hh3cWirelessCardModelName (1.3.6.1.4.1.25506.2.98.1.1.1.1.2) |
read-only |
SnmpAdminString |
OCTET STRING (0..255) |
Name of the 3G modem. |
As per the MIB. |
hh3cWirelessCardMfgName (1.3.6.1.4.1.25506.2.98.1.1.1.1.3) |
read-only |
SnmpAdminString |
Manufacturer name of the 3G modem. |
As per the MIB. |
hh3cWirelessCardSerialNumber (1.3.6.1.4.1.25506.2.98.1.1.1.1.5) |
read-only |
SnmpAdminString |
OCTET STRING (0..32) |
Vendor-specific serial number of the 3G modem. |
As per the MIB. |
hh3cWirelessCardHardwareVersion (1.3.6.1.4.1.25506.2.98.1.1.1.1.7) |
read-only |
SnmpAdminString |
Vendor-specific hardware version of the 3G modem. |
As per the MIB. |
hh3cWirelessCardFirmwareVersion (1.3.6.1.4.1.25506.2.98.1.1.1.1.8) |
read-only |
SnmpAdminString |
Vendor-specific firmware version of the 3G modem. |
As per the MIB. |
hh3cWirelessCardPRLVersion (1.3.6.1.4.1.25506.2.98.1.1.1.1.9) |
read-only |
SnmpAdminString |
Preferred roaming list (PRL) version of the 3G modem. |
As per the MIB. |
hh3cWirelessCardInterfaceIndex (1.3.6.1.4.1.25506.2.98.1.1.1.1.10) |
read-only |
InterfaceIndex |
Interface index of the 3G modem. |
As per the MIB. |
hh3cWirelessCardModemStatus (1.3.6.1.4.1.25506.2.98.1.1.1.1.11) |
read-only |
INTEGER |
unknown(1) onLine(2) offLine(3) |
Status of the 3G modem. |
As per the MIB. |
hh3cWirelessCardModemMode (1.3.6.1.4.1.25506.2.98.1.1.1.1.12) |
read-only |
INTEGER |
unknown(1) tdscdma(2) wcdma(3) cdma(4) lte(5) |
Network connection mode of the 3G modem. |
As per the MIB. |
hh3cWirelessCardCurNetConn (1.3.6.1.4.1.25506.2.98.1.1.1.1.13) |
read-only |
INTEGER |
unknown(1) noService(2) gsm(3) gprs(4) edge(5) hsdpa(6) hsupa(7) hsupaAndhsdpa(8) hspaPlus(9) umts(10) dchspaPlus(11) lte(12) onexrtt(13) evdo(14) onexrttAndevdo(15) tdscdma(16) |
Current network connection of the 3G modem. |
As per the MIB. |
hh3cUIMInfoTable
About this table
Use this table to obtain information about UIM cards.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cUIMIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUIMIndex (1.3.6.1.4.1.25506.2.98.1.2.1.1.1) |
not-accessible |
Integer32 |
Integer32 (0..2147483647) |
Index of a UIM card. |
As per the MIB. |
hh3cUIMStatus (1.3.6.1.4.1.25506.2.98.1.2.1.1.2) |
read-only |
INTEGER |
absent(1) initial(2) fault(3) unprotected(4) protected(5) pinLocked(6) pukLocked(7) selfDestruct(8) |
Status of the UIM card. |
As per the MIB. |
hh3cUIMImsi (1.3.6.1.4.1.25506.2.98.1.2.1.1.3) |
read-only |
SnmpAdminString |
International Mobile Subscriber Identification Number (IMSI) of the UIM card. |
As per the MIB. |
hh3c3GCdma1xRttTable
About this table
Use this table to configure CDMA 1xRTT connection settings and obtain statistics about the CDMA 1xRTT connection.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table does not have an index.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3c3GCdma1xRttCurrentRssi (1.3.6.1.4.1.25506.2.98.1.3.1.1.1) |
read-only |
Integer32 |
Integer32 (-2147483648 | -150..0) |
Current Received Signal Strength Indicator(RSSI) of the CDMA 1xRTT connection. |
-2147483648 is an invalid value. |
hh3c3GCdma1xRttRssiMediumThreshold (1.3.6.1.4.1.25506.2.98.1.3.1.1.2) |
read-write |
Integer32 |
Integer32 (-150..0) |
Medium signal threshold for the RSSI of the CDMA 1xRTT connection. |
As per the MIB. |
hh3c3GCdma1xRttRssiWeakThreshold (1.3.6.1.4.1.25506.2.98.1.3.1.1.3) |
read-write |
Integer32 |
Weak signal threshold for the RSSI of the CDMA 1xRTT connection. |
As per the MIB. |
hh3c3GCdma1xRttCurServiceStatus (1.3.6.1.4.1.25506.2.98.1.3.1.1.4) |
read-only |
INTEGER |
unknown(1) available(2) emergency(3) lowPower(4) noService(5) |
Service status of the CDMA 1xRTT connection. |
As per the MIB. |
hh3c3GCdma1xRttCurRoamingStatus (1.3.6.1.4.1.25506.2.98.1.3.1.1.5) |
read-only |
INTEGER |
unknown(1) roaming(2) home(3) |
Roaming status of the CDMA 1xRTT connection. |
As per the MIB. |
hh3c3GCdma1xRttBID (1.3.6.1.4.1.25506.2.98.1.3.1.1.6) |
read-only |
Unsigned32 |
Unsigned32 (0..2147483647) |
Base Station ID (BID) of the CDMA 1xRTT connection. |
As per the MIB. |
hh3c3GCdma1xRttSID (1.3.6.1.4.1.25506.2.98.1.3.1.1.7) |
read-only |
Unsigned32 |
System ID (SID) of the CDMA 1xRTT connection. |
As per the MIB. |
hh3c3GCdma1xRttNID (1.3.6.1.4.1.25506.2.98.1.3.1.1.8) |
read-only |
Unsigned32 |
Network ID (NID) of the CDMA 1xRTT connection. |
As per the MIB. |
hh3c3GCdmaEvDoTable
About this table
Use this table to configure CDMA EvDo connection settings and obtain statistics about the CDMA EvDo connection.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3c3GCdmaEvDoCurrentRssi (1.3.6.1.4.1.25506.2.98.1.3.2.1.1) |
read-only |
Integer32 |
Current RSSI of the CDMA EvDo connection. |
hh3c3GCdmaEvDoRssiMediumThreshold (1.3.6.1.4.1.25506.2.98.1.3.2.1.2) |
read-write |
Integer32 |
Medium signal threshold for the RSSI of the CDMA EvDo connection. |
As per the MIB. |
hh3c3GCdmaEvDoRssiWeakThreshold (1.3.6.1.4.1.25506.2.98.1.3.2.1.3) |
read-write |
Integer32 |
Weak signal threshold for the RSSI of the CDMA EvDo connection. |
As per the MIB. |
hh3c3GCdmaEvDoCurServiceStatus (1.3.6.1.4.1.25506.2.98.1.3.2.1.4) |
read-only |
INTEGER |
Service status of the CDMA EvDo connection. |
As per the MIB. |
hh3c3GCdmaEvDoCurRoamingStatus (1.3.6.1.4.1.25506.2.98.1.3.2.1.5) |
read-only |
INTEGER |
Roaming status of the CDMA EvDo connection. |
As per the MIB. |
hh3c3GCdmaEvDoSubNetID (1.3.6.1.4.1.25506.2.98.1.3.2.1.6) |
read-only |
SnmpAdminString |
Subnet ID of the CDMA EvDo connection. |
Only supported by MC509. |
hh3c3GGsmInfoTable
About this table
Use this table to configure GSM connection settings and obtain statistics about the GSM connection.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3c3GGsmCurrentRssi (1.3.6.1.4.1.25506.2.98.1.4.1.1.1) |
read-only |
Integer32 |
Current RSSI of the GSM connection. |
hh3c3GGsmRssiMediumThreshold (1.3.6.1.4.1.25506.2.98.1.4.1.1.2) |
read-write |
Integer32 |
Medium signal threshold for the RSSI of the GSM connection. |
As per the MIB. |
hh3c3GGsmRssiWeakThreshold (1.3.6.1.4.1.25506.2.98.1.4.1.1.3) |
read-write |
Integer32 |
Weak signal threshold for the RSSI of the GSM connection. |
As per the MIB. |
hh3c3GGsmImsi (1.3.6.1.4.1.25506.2.98.1.4.1.1.4) |
read-only |
SnmpAdminString |
SIM/UIM card IMSI of the GSM connection. |
As per the MIB. |
hh3c3GGsmImei (1.3.6.1.4.1.25506.2.98.1.4.1.1.5) |
read-only |
SnmpAdminString |
3G modem IMEI of the GSM connection. |
As per the MIB. |
hh3c3GGsmApn (1.3.6.1.4.1.25506.2.98.1.4.1.1.6) |
read -write |
SnmpAdminString |
OCTET STRING (0..100) |
3G modem APN of the GSM connection. |
As per the MIB. |
hh3c3GGsmPacketSessionStatus (1.3.6.1.4.1.25506.2.98.1.4.1.1.7) |
read-only |
INTEGER |
unknown(1) active(2) inactive(3) |
3G modem packet session status of the GSM connection. |
As per the MIB. |
hh3c3GGsmNetworkSelectionMode (1.3.6.1.4.1.25506.2.98.1.4.1.1.8) |
read-only |
INTEGER |
unknown(1) automatic(2) manual(3) |
Network selection mode of the GSM connection. |
As per the MIB. |
hh3c3GGsmMobileNetworkName (1.3.6.1.4.1.25506.2.98.1.4.1.1.9) |
read-only |
SnmpAdminString |
Mobile network name of the GSM connection. |
As per the MIB. |
hh3c3GGsmLac (1.3.6.1.4.1.25506.2.98.1.4.1.1.10) |
read-only |
SnmpAdminString |
3G modem Location Area Code (LAC) of the GSM connection. |
As per the MIB. |
hh3c3GGsmCellId (1.3.6.1.4.1.25506.2.98.1.4.1.1.11) |
read-only |
SnmpAdminString |
3G modem cell ID of the GSM connection. |
As per the MIB. |
hh3c3GGsmSimStatus (1.3.6.1.4.1.25506.2.98.1.4.1.1.12) |
read-only |
INTEGER |
unknown(1) ok(2) notInsert(3) networkReject(4) blocked(5) |
3G modem SIM status of the GSM connection. |
As per the MIB. |
hh3c3GGsmCurServiceStatus (1.3.6.1.4.1.25506.2.98.1.4.1.1.13) |
read-only |
INTEGER |
3G modem service status of the GSM connection. |
As per the MIB. |
hh3c3GGsmCurRoamingStatus (1.3.6.1.4.1.25506.2.98.1.4.1.1.14) |
read-only |
INTEGER |
3G modem roaming status of the GSM connection. |
As per the MIB. |
hh3c3GGsmMcc (1.3.6.1.4.1.25506.2.98.1.4.1.1.15) |
read-only |
SnmpAdminString |
Mobile Country Code (MCC) of the GSM connection. |
As per the MIB. |
hh3c3GGsmMnc (1.3.6.1.4.1.25506.2.98.1.4.1.1.16) |
read-only |
SnmpAdminString |
Mobile Network Code (MNC) of the GSM connection. |
As per the MIB. |
hh3c3GWcdmaCurrentEcio (1.3.6.1.4.1.25506.2.98.1.4.1.1.17) |
read-only |
Integer32 |
EC/IO in WCDMA. |
–2147483648 is an invalid value. |
hh3cLteInfoTable
About this table
Use this table to configure LET connection settings and obtain statistics about the LTE connection.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLteCurrentRsrp (1.3.6.1.4.1.25506.2.98.1.5.1.1.1) |
read-only |
Integer32 |
Standard MIB values. |
Reference signal receiving power (RSCP) of the LTE connection. |
As per the MIB. |
hh3cLteCurrentRsrq(1.3.6.1.4.1.25506.2.98.1.5.1.1.2) |
read-only |
Integer32 |
Reference signal receiving quality (RSRQ) of the LTE connection. |
As per the MIB. |
hh3cLteCurrentSinr(1.3.6.1.4.1.25506.2.98.1.5.1.1.3) |
read-only |
Integer32 |
Signal to interface plus noise ratio (SINR) of the LTE connection. |
As per the MIB. |
hh3cLteTxPower(1.3.6.1.4.1.25506.2.98.1.5.1.1.4) |
read-only |
Integer32 |
Transmit power of the LTE connection. |
Only supported by MC7710. |
hh3cLteCurrentRssi(1.3.6.1.4.1.25506.2.98.1.5.1.1.5) |
read-only |
Integer32 |
RSSI of the LTE connection. |
As per the MIB. |
hh3cLteRssiMediumThreshold(1.3.6.1.4.1.25506.2.98.1.5.1.1.6) |
read-write |
Integer32 |
Medium signal threshold for the RSSI of the LTE connection. |
As per the MIB. |
hh3cLteRssiWeakThreshold(1.3.6.1.4.1.25506.2.98.1.5.1.1.7) |
read-write |
Integer32 |
Weak signal threshold for the RSSI of the LTE connection. |
As per the MIB. |
hh3c3GModemTrap
About this table
Use this table to obtain information about modem notifications.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
This table does not have indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevSerialNumber (1.3.6.1.4.1.25506.2.98.2.1) |
accessible-for-notify |
SnmpAdminString |
Serial number of the device. |
As per the MIB. |
hh3cDeviceOUI (1.3.6.1.4.1.25506.2.98.2.2) |
SnmpAdminString |
OCTET STRING (0..64) |
OUI of the device. |
As per the MIB. |
hh3cAccessMedia (1.3.6.1.4.1.25506.2.98.2.3) |
INTEGER |
unknown(1) air(2) cable(3) |
Current network access media. |
As per the MIB. |
hh3c3GCurrentService (1.3.6.1.4.1.25506.2.98.2.4) |
INTEGER |
unknown(1) oneXRtt(2) evDo(3) gsm(4) lte(5) |
Current network service type. |
As per the MIB. |
hh3c3GCurrentRssiBind (1.3.6.1.4.1.25506.2.98.2.5) |
Integer32 |
Current RSSI. |
As per the MIB. |
hh3c3GImsiBind (1.3.6.1.4.1.25506.2.98.2.6) |
SnmpAdminString |
IMSI of the SIM/UIM card. |
As per the MIB. |
hh3cWirelessCardOnlineTable
About this table
Use this table to obtain the online duration of the 3G modem.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table index is hh3cWirelessCardOnlineTime.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cWirelssCardOnlineTime (1.3.6.1.4.1.25506.2.98.1.1.3.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (0..4294967295) |
Online duration of the 3G modem. |
As per the MIB. |
hh3cWirelessCardOnlineType (1.3.6.1.4.1.25506.2.98.1.1.3.1.2) |
not-accessible |
INTEGER |
up(1) down(2) |
Onboarding mode of the 3G modem. |
As per the MIB. |
Notifications
hh3cWirelessCardInserted
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.98.3.0.1 |
A 3G modem inserted. |
Recovery |
Warning |
N/A |
ON |
Notification triggers
This notification is generated when a 3G modem is inserted into the device.
System impact
The wireless network service is available.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.98.2.2 (hh3cDeviceOUI) |
Organizational Unique Identifier (OUI) of the device. |
N/A |
SnmpAdminString |
1.3.6.1.4.1.25506.2.98.2.1 (hh3cDevSerialNumber) |
N/A |
SnmpAdminString |
1.3.6.1.4.1.25506.2.98.1.1.1.1.5 (hh3cWirelessCardSerialNumber) |
N/A |
SnmpAdminString |
1.3.6.1.4.1.25506.2.98.1.2.1.1.3 (hh3cUIMImsi) |
IMSI of the UIM card. |
N/A |
SnmpAdminString |
Recommended action
No action is required.
hh3cWirelessCardPulledOut
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.98.3.0.2 |
A 3G modem pulled out. |
Error |
Minor |
1.3.6.1.4.1.25506.2.98.3.0.1 (A 3G modem inserted.) |
ON |
This notification is generated when a 3G modem is pulled out from the device.
System impact
The wireless network service is not available.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
Recommended action
To resolve the issue:
1. Verify that the 3G modem is removed on purpose manually.
2. If the 3G modem is not removed on purpose manually, verify that it is installed correctly and functions correctly.
3. If the issue persists, contact H3C Support.
hh3cAccessMediaChanged
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.98.3.0.5 |
Access media changed |
Informational |
Warning |
N/A |
ON |
This notification is generated when the access media is changed.
System impact
The wireless network service might be affected.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
1.3.6.1.4.1.25506.2.98.2.3 (hh3cAccessMedia) |
Current access media. |
N/A |
INTEGER |
unknown(1), air(2), cable(3) |
Recommended action
hh3c3GRssiStrongSignalTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.98.3.0.6 |
Current RSSI exceeded the medium signal threshold. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the current RSSI exceeds the medium signal threshold.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.98.1.1.1.1.1 (hh3cWirelessCardIndex) |
N/A |
Integer32 |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
1.3.6.1.4.1.25506.2.98.2.4 (hh3c3GCurrentService) |
N/A |
INTEGER |
unknown(1), oneXRtt(2), evDo(3), gsm(4), lte(5) |
1.3.6.1.4.1.25506.2.98.2.5 (hh3c3GCurrentRssiBind) |
Current RSSI. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.98.2.6 (hh3c3GImsiBind) |
N/A |
SnmpAdminString |
Recommended action
hh3c3GRssiMediumSignalTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.98.3.0.7 |
Current RSSI fell or rose to a value between the medium and weak signal thresholds. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the current RSSI falls or rises to a value between the medium and weak signal thresholds.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
Integer32 |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
INTEGER |
Current RSSI. |
N/A |
Integer32 |
N/A |
SnmpAdminString |
Recommended action
hh3c3GRssiWeakSignalTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.98.3.0.8 |
Current RSSI fell below the weak signal threshold |
Informational |
Warning |
N/A |
ON |
This notification is generated when the current RSSI falls below the weak signal threshold.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
Integer32 |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
INTEGER |
Current RSSI. |
N/A |
Integer32 |
N/A |
SnmpAdminString |
Recommended action
To resolve the issue, check the antenna and remove obstacles that block signals to ensure that the RSSI is in the normal range.
