08-Layer 2—WAN Access
HomeSupportReference GuidesMIB CompanionH3C MSR Router Series MIB Reference-R6749-6W10008-Layer 2—WAN Access
01-FRAME-RELAY-DTE-MIB
01-FRAME-RELAY-DTE-MIB 96.72 KB
FRAME-RELAY-DTE-MIB
About this MIB
Use this MIB to manage DLC information, PVC information, Frame Relay interface error information, and Frame Relay trap information.
MIB file name
rfc2115-frame-relay-dte.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission (10).frameRelayDTE(32)
Tabular objects
frDlcmiTable
About this table
This table manages DLC information.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is frDlcmiIfIndex.
Object (OID)
Access
Value range
Implementation
frDlcmiIfIndex (1.3.6.1.2.1.10.32.1.1.1)
read-only
InterfaceIndex
Integer32 (1..2147483647)
DLC interface index.
As per the MIB.
frDlcmiState (1.3.6.1.2.1.10.32.1.1.2)
read-create
INTEGER
noLmiConfigured(1)
lmiRev1(2)
ansiT1617D(3)
Annex D(4)
itut933A (5)
ansiT1617D1994(6)
LMI protocol type.
Supports both the read and write operations, and supports only the following protocol LMI protocol types:
·     lmiRev1 (2).
·     ansiT1617D (3).
·     itut933A (5).
frDlcmiAddress (1.3.6.1.2.1.10.32.1.1.3)
read-create
INTEGER
q921(1)
q922March90(2)
q922November90(3)
q922(4)
Address format.
Supports only the read operation and the q922November90(3) value.
frDlcmiAddressLen (1.3.6.1.2.1.10.32.1.1.4)
read-create
INTEGER
twoOctets (2)
threeOctets (3)
fourOctets (4)
Address length.
Supports only the read operation and the twoOctets(2) value.
frDlcmiPollingInterval (1.3.6.1.2.1.10.32.1.1.5)
read-create
Integer32
Integer32(5..30)
Interval for sending status enquiry messages.
Supports only the read operation.
frDlcmiFullEnquiryInterval (1.3.6.1.2.1.10.32.1.1.6)
read-create
Integer32
Integer32(1..255)
Number of full status enquiry messages.
Supports both the read and write operations.
frDlcmiErrorThreshold (1.3.6.1.2.1.10.32.1.1.7)
read-create
Integer32
Integer32(1..10)
LMI error threshold.
frDlcmiMonitoredEvents (1.3.6.1.2.1.10.32.1.1.8)
read-create
Integer32
Integer32(1..10)
LMI event counter.
frDlcmiMaxSupportedVCs (1.3.6.1.2.1.10.32.1.1.9)
read-create
Integer32
Standard MIB values.
Maximum number of VCs supported.
Supports only the read operation. The default value is 992.
frDlcmiMulticast (1.3.6.1.2.1.10.32.1.1.10)
read-create
INTEGER
nonBroadcast (1)
broadcast (2)
Multilink Frame Relay flag.
frDlcmiStatus (1.3.6.1.2.1.10.32.1.1.11)
read-only
INTEGER
running (1)
fault(2)
initializing (3)
DLC status.
Supports only the following values:
·     running (1).
·     fault (2).
frDlcmiRowStatus (1.3.6.1.2.1.10.32.1.1.12)
read-create
RowStatus
DLC row status.
frCircuitTable
About this table
This table manages PVC information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are frCircuitIfIndex and frCircuitDlci.
Object (OID)
Access
Value range
Implementation
frCircuitIfIndex (1.3.6.1.2.1.10.32.2.1.1)
read-only
InterfaceIndex
Interface index.
As per the MIB.
frCircuitDlci (1.3.6.1.2.1.10.32.2.1.2)
read-only
Integer32
DLC  flag.
As per the MIB.
frCircuitState (1.3.6.1.2.1.10.32.2.1.3)
read-create
INTEGER
invalid (1)
active (2)
inactive (3)
Status.
Supports only the read operation and the following values:
·     active (2).
·     inactive (3).
frCircuitReceivedFECNs (1.3.6.1.2.1.10.32.2.1.4)
read-only
Counter32
Number of incoming frames with the FECN bit set.
As per the MIB.
frCircuitReceivedBECNs (1.3.6.1.2.1.10.32.2.1.5)
read-only
Counter32
Number of incoming frames with the BECN bit set.
As per the MIB.
frCircuitSentFrames (1.3.6.1.2.1.10.32.2.1.6)
read-only
Counter32
Number of sent frames.
As per the MIB.
frCircuitSentOctets (1.3.6.1.2.1.10.32.2.1.7)
read-only
Counter32
Number of sent bytes.
As per the MIB.
frCircuitReceivedFrames (1.3.6.1.2.1.10.32.2.1.8)
read-only
Counter32
Number of received frames.
As per the MIB.
frCircuitReceivedOctets (1.3.6.1.2.1.10.32.2.1.9)
read-only
Counter32
Number of received bytes.
As per the MIB.
frCircuitCreationTime (1.3.6.1.2.1.10.32.2.1.10)
read-only
TimeStamp
Creation time.
As per the MIB.
frCircuitLastTimeChange (1.3.6.1.2.1.10.32.2.1.11)
read-only
TimeStamp
Time when the link status last changed.
As per the MIB.
frCircuitCommittedBurst (1.3.6.1.2.1.10.32.2.1.12)
read-create
Integer32
Integer32(0..2147483647)
CBS.
The value range is 300 to 16000000.
frCircuitExcessBurst (1.3.6.1.2.1.10.32.2.1.13)
read-create
Integer32
EBS.
The value range is 0 to 16000000.
frCircuitThroughput (1.3.6.1.2.1.10.32.2.1.14)
read-create
Integer32
Throughput.
The value range is 1000 to 45000000.
frCircuitMulticast (1.3.6.1.2.1.10.32.2.1.15)
read-create
INTEGER
unicast(1)
oneWay(2)
twoWay(3)
nWay(4)
Broadcast attribute.
·     unicast(1).
·     nWay(4).
frCircuitType (1.3.6.1.2.1.10.32.2.1.16)
read-only
INTEGER
static(1)
dynamic(2)
PVC type.
As per the MIB.
frCircuitDiscards (1.3.6.1.2.1.10.32.2.1.17)
read-only
Counter32
Number of incoming frames dropped.
As per the MIB.
frCircuitReceivedDEs (1.3.6.1.2.1.10.32.2.1.18)
read-only
Counter32
Number of incoming frames with the DE bit set.
As per the MIB.
frCircuitSentDEs (1.3.6.1.2.1.10.32.2.1.19)
read-only
Counter32
Number of outgoing frames with the DE bit set.
As per the MIB.
frCircuitLogicalIfIndex (1.3.6.1.2.1.10.32.2.1.20)
read-create
InterfaceIndex
Logical interface index.
frCircuitRowStatus (1.3.6.1.2.1.10.32.2.1.21)
read-create
RowStatus
DLC row status.
·     active(1).
·     createAndgo(4).
·     destroy(6).
frErrTable
About this table
This table manages Frame Relay interface error information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is frErrIfIndex.
Object (OID)
Access
Value range
Implementation
frErrIfIndex (1.3.6.1.2.1.10.32.3.1.1)
read-only
InterfaceIndex
Interface index.
As per the MIB.
frErrType
(1.3.6.1.2.1.10.32.3.1.2)
read-only
INTEGER
unknownError(1)
receiveShort(2)
receiveLong(3)
illegalAddress(4)
unknownAddress(5)
dlcmiProtoErr(6)
dlcmiUnknownIE(7)
dlcmiSequenceErr(8)
dlcmiUnknownRpt(9)
noErrorSinceReset(10)
Error type.
As per the MIB.
frErrData
(1.3.6.1.2.1.10.32.3.1.3)
read-only
OCTET STRING
OCTET STRING (1..1600)
Error packet information.
As per the MIB.
frErrTime
(1.3.6.1.2.1.10.32.3.1.4)
read-only
TimeStamp
Time when the error occurred.
As per the MIB.
frErrFaults
 (1.3.6.1.2.1.10.32.3.1.5)
read-only
Counter32
Number of times the protocol went down.
As per the MIB.
frErrFaultTime (1.3.6.1.2.1.10.32.3.1.6)
read-only
TimeStamp
Time when the link layer protocol went down because the number of LMI negotiation errors exceeded the error threshold.
As per the MIB.
frameRelayTrapControl
About this table
This table manages Frame Relay traps.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
frTrapState (1.3.6.1.2.1.10.32.4.1)
read-write
INTEGER
enabled(1)
disabled(2)
Trap enable status.
As per the MIB.
