03-HH3C-MP-V2-MIB | 119.59 KB |
HH3C-MP-V2-MIB
About this MIB
Use this MIB to configure MP.
MIB file name
hh3c-mp-v2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMultilinkPPPV2(140)
Tabular objects
hh3cMpMultilinkV2Table
About this table
Use this table to obtain the MP link information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMpMultilinkDescrV2 (1.3.6.1.4.1.25506.2.140.1.1.1.1) |
read-only |
DisplayString |
OCTET STRING (0..255) |
Interface name of the father interface on which child channels are bundled. |
As per the MIB. |
hh3cMpBundleNameV2 (1.3.6.1.4.1.25506.2.140.1.1.1.2) |
read-only |
DisplayString |
Bundle name of the MP link. |
For an MP-group interface, the value is Multilink. |
hh3cMpBundledSlotV2 (1.3.6.1.4.1.25506.2.140.1.1.1.3) |
read-only |
Integer32 |
Standard MIB values. |
Slot on which child channels are bundled. |
As per the MIB. |
hh3cMpBundledMemberCntV2 (1.3.6.1.4.1.25506.2.140.1.1.1.4) |
read-only |
Integer32 |
Number of child channels of the MP link. |
As per the MIB. |
hh3cMpLostFragmentsV2 (1.3.6.1.4.1.25506.2.140.1.1.1.5) |
read-only |
Counter32 |
Number of fragments of the MP link discarded. |
As per the MIB. |
hh3cMpReorderedPktsV2 (1.3.6.1.4.1.25506.2.140.1.1.1.6) |
read-only |
Counter32 |
Number of reordered incoming packets of the MP link |
As per the MIB. |
hh3cMpUnassignedPktsV2 (1.3.6.1.4.1.25506.2.140.1.1.1.7) |
read-only |
Counter32 |
Number of received packets of the MP link waiting for reordering. |
As per the MIB. |
hh3cMpInterleavedPktsV2 (1.3.6.1.4.1.25506.2.140.1.1.1.8) |
read-only |
Counter32 |
Number of received interleaved packets of the MP link. |
As per the MIB. |
hh3cMpRcvdSequenceV2 (1.3.6.1.4.1.25506.2.140.1.1.1.9) |
read-only |
Integer32 |
Sequence number for the MP link to receive. |
As per the MIB. |
hh3cMpSentSequenceV2 (1.3.6.1.4.1.25506.2.140.1.1.1.10) |
read-only |
Integer32 |
Sequence number for the MP link to send. |
As per the MIB. |
hh3cMpMemberlinkV2Table
About this table
Use this table to configure the child channels of an MP link.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ifIndex and hh3cMpMemberlinkSeqNumberV2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMpMemberlinkSeqNumberV2 (1.3.6.1.4.1.25506.2.140.1.2.1.1) |
read-only |
Integer32 |
Sequence number of a child channel of the MP link. |
As per the MIB. |
hh3cMpMemberlinkIfIndexV2 (1.3.6.1.4.1.25506.2.140.1.2.1.2) |
read-only |
Integer32 |
Interface index of a child channel of the MP link. |
As per the MIB. |
hh3cMpMemberlinkDescrV2 (1.3.6.1.4.1.25506.2.140.1.2.1.3) |
read-only |
DisplayString |
Interface name of a child channel of the MP link. |
As per the MIB. |
hh3cMpMemberlinkMpStatusV2 (1.3.6.1.4.1.25506.2.140.1.2.1.4) |
read-only |
INTEGER |
active(1) inactive(2) |
State of a child channel of the MP link. |
As per the MIB. |
